mystical sensor MPL3115
2,692 次查看
ellisfeguson
Hello, developers!
Now i make a project " portable weather station" based on MPL3115. Primary functions: display current time, e-kompass, pressure, altitude, temperature and weather forecast. its a batterry-operated devices, and components must have minimal Supply Current. when I found a MPL3115 i been really excited, because this IC have all what i need. But now my project is has stalled.
Firstly, i wrote a source code as datasheet recomendations, for set and change mode of MPL3115, read registers and display the results. i test code and sensor at LPC-812 MBED board (because i like LPCXpresso) and sensor board is powered from LPC-812 (3.3 Volt). and I got the some results (pressure, temperature and altitude).
Next, i reading a AN3914 ("Modern Altimeter and Barometer System using the MPL115A") and start to adaptation this algorithm for  MPL3115.
for  make a weather forecast i need to get  pressure change per 1 hour. for this, i chose a 3-hours/180 minutes interval for collected samples in FIFO every ~20 minutes. User should be able get a weather forecast at any time, so program must compare oldest and newest samples (for example, now is 11-10 AM, oldest sample was obtained at 8-00 AM, newest samples at 11-00 AM. i compare  this samples, divided and get a pressure change per 1 hour. then i make a weatern pattern and display it. next samples update will be at 11-20 AM. )
but i get a first STOP: bytes, reading from FIFO, "deleted from the front of the FIFO buffer" (page24 DS). so if I read values ​​from the buffer, I lost them. and if i make a weather pattern as in the above example at 11-10AM, at 11-20 AM i can't get the data from FIFO. next possibility for 1 hour pressure change i will get only via 1 hour!  all the collected data (from 8-20 AM to 11-20 AM) will be LOST!
So. this way is not work.:smileyshocked:
Ok, AN3914 have another faster way to make a weather forecast (page 6)! all i need - it's a  pressure and current altutude (MPL3115 must give all of this). i must calculate "ideal pressure" Pweather (for good sunny day) for current altitude by using the equation: Pweather = (101.3 * exp(((float)(CurrentAltitude))/(-7900))). and compare current pressure with "ideal".
i wrote a code: set Altimeter mode and get a current altitude, set Barometer mode and get a current pressure, calculate and display result of weather pattern. i live in area at 56—178 meters of sea level. i start the test and get a second STOP  :
sensor's PCB is on the table at room temperature (22-24 C) and does not move. source code don't change.  in the morning i have altitude=102 meters, in the dinner =32 meters, in the evening 0 meters. i turn on Debugger and see: when  I read data registers in Altimeter mode, OUT_P_MSB Register= 0xFF, so i get incorrect data from sensor . But i get correct temperature data in this reading operation (i make a cycle read 5 bytes from sensor at one procedure).
So,this way does not inspire confidence...Smiley Sad
I just have to find a shaman! Because I can not find understanding with this really fine sensor.
May be anybody help me?
Best regards, Ellis
标签 (1)
1 回复
1,709 次查看
reyes
Hi Ellis,
We have some code examples and other documentation available in Freescale communities, perhaps it can be useful: https://community.freescale.com/community/sensors/content?filterID=contentstatus%5Bpublished%5D~obje...
Jose
%3CLINGO-SUB%20id%3D%22lingo-sub-251777%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E7%A5%9E%E7%A7%98%E4%BC%A0%E6%84%9F%E5%99%A8%20MPL3115%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-251777%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E5%BC%80%E5%8F%91%E4%BA%BA%E5%91%98%EF%BC%81%3C%2FP%3E%3CP%3E%E7%8E%B0%E5%9C%A8%EF%BC%8C%E6%88%91%E5%88%B6%E4%BD%9C%E4%BA%86%E4%B8%80%E4%B8%AA%E5%9F%BA%E4%BA%8E%20MPL3115%20%E7%9A%84%E9%A1%B9%E7%9B%AE%22%20%E4%BE%BF%E6%90%BA%E5%BC%8F%E6%B0%94%E8%B1%A1%E7%AB%99%22%20%E3%80%82%E4%B8%BB%E8%A6%81%E5%8A%9F%E8%83%BD%EF%BC%9A%E6%98%BE%E7%A4%BA%E5%BD%93%E5%89%8D%E6%97%B6%E9%97%B4%E3%80%81%E7%94%B5%E5%AD%90%E7%BD%97%E7%9B%98%E3%80%81%E6%B0%94%E5%8E%8B%E3%80%81%E6%B5%B7%E6%8B%94%E9%AB%98%E5%BA%A6%E3%80%81%E6%B8%A9%E5%BA%A6%E5%92%8C%E5%A4%A9%E6%B0%94%E9%A2%84%E6%8A%A5%E3%80%82%E5%AE%83%E6%98%AF%E7%94%B5%E6%B1%A0%E4%BE%9B%E7%94%B5%E7%9A%84%E8%AE%BE%E5%A4%87%EF%BC%8C%E5%85%83%E5%99%A8%E4%BB%B6%E7%9A%84%E7%94%B5%E6%BA%90%E7%94%B5%E6%B5%81%E5%BF%85%E9%A1%BB%E6%9C%80%E5%B0%8F%E3%80%82%E5%BD%93%E6%88%91%E5%8F%91%E7%8E%B0%20MPL3115%20%E6%97%B6%EF%BC%8C%E6%88%91%E7%9C%9F%E7%9A%84%E5%BE%88%E5%85%B4%E5%A5%8B%EF%BC%8C%E5%9B%A0%E4%B8%BA%E8%BF%99%E4%B8%AA%E9%9B%86%E6%88%90%E7%94%B5%E8%B7%AF%E6%8B%A5%E6%9C%89%E6%88%91%E6%89%80%E9%9C%80%E8%A6%81%E7%9A%84%E4%B8%80%E5%88%87%E3%80%82%E4%BD%86%E7%8E%B0%E5%9C%A8%E6%88%91%E7%9A%84%E9%A1%B9%E7%9B%AE%E5%81%9C%E6%BB%9E%E4%B8%8D%E5%89%8D%E3%80%82%3C%2FP%3E%3CP%3E%E9%A6%96%E5%85%88%EF%BC%8C%E6%88%91%E6%8C%89%E7%85%A7%E6%95%B0%E6%8D%AE%E6%89%8B%E5%86%8C%E7%9A%84%E5%BB%BA%E8%AE%AE%E7%BC%96%E5%86%99%E4%BA%86%E6%BA%90%E4%BB%A3%E7%A0%81%EF%BC%8C%E7%94%A8%E4%BA%8E%E8%AE%BE%E7%BD%AE%E5%92%8C%E6%9B%B4%E6%94%B9%20MPL3115%20%E7%9A%84%E6%A8%A1%E5%BC%8F%E3%80%81%E8%AF%BB%E5%8F%96%E5%AF%84%E5%AD%98%E5%99%A8%E5%B9%B6%E6%98%BE%E7%A4%BA%E7%BB%93%E6%9E%9C%E3%80%82%E6%88%91%E5%9C%A8%20LPC-812%20MBED%20%E6%9D%BF%E4%B8%8A%E6%B5%8B%E8%AF%95%E4%BB%A3%E7%A0%81%E5%92%8C%E4%BC%A0%E6%84%9F%E5%99%A8%EF%BC%88%E5%9B%A0%E4%B8%BA%E6%88%91%E5%96%9C%E6%AC%A2%20LPCXpresso%EF%BC%89%EF%BC%8C%E8%80%8C%E4%B8%94%E4%BC%A0%E6%84%9F%E5%99%A8%E6%9D%BF%E7%94%B1%20LPC-812%EF%BC%883.3%20%E4%BC%8F%E7%89%B9%EF%BC%89%E4%BE%9B%E7%94%B5%E3%80%82%E6%88%91%E5%BE%97%E5%88%B0%E4%BA%86%E4%B8%80%E4%BA%9B%E7%BB%93%E6%9E%9C%EF%BC%88%E5%8E%8B%E5%8A%9B%E3%80%81%E6%B8%A9%E5%BA%A6%E5%92%8C%E9%AB%98%E5%BA%A6%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%E6%8E%A5%E4%B8%8B%E6%9D%A5%EF%BC%8C%E6%88%91%E9%98%85%E8%AF%BB%E4%BA%86%20AN3914%20(%22%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E4%BD%BF%E7%94%A8%20MPL115A%20%E7%9A%84%20%3C%2FSPAN%3E%E7%8E%B0%E4%BB%A3%E9%AB%98%E5%BA%A6%E8%AE%A1%E5%92%8C%E6%B0%94%E5%8E%8B%E8%AE%A1%E7%B3%BB%E7%BB%9F%22)%20%20%E5%B9%B6%20%E5%BC%80%E5%A7%8B%E4%B8%BA%20MPL3115%20%E8%B0%83%E6%95%B4%E8%AF%A5%E7%AE%97%E6%B3%95%E3%80%82%3C%2FP%3E%3CP%3E%E8%A6%81%E8%BF%9B%E8%A1%8C%E5%A4%A9%E6%B0%94%E9%A2%84%E6%8A%A5%EF%BC%8C%E6%88%91%E9%9C%80%E8%A6%81%E8%8E%B7%E5%BE%97%E6%AF%8F%201%20%E5%B0%8F%E6%97%B6%E7%9A%84%E6%B0%94%E5%8E%8B%E5%8F%98%E5%8C%96%E3%80%82%E4%B8%BA%E6%AD%A4%EF%BC%8C%E6%88%91%E9%80%89%E6%8B%A9%E4%BA%86%203%20%E5%B0%8F%E6%97%B6%2F180%20%E5%88%86%E9%92%9F%E7%9A%84%E9%97%B4%E9%9A%94%E6%97%B6%E9%97%B4%EF%BC%8C%E6%AF%8F%E9%9A%94%E7%BA%A6%2020%20%E5%88%86%E9%92%9F%E4%BB%A5%E5%85%88%E8%BF%9B%E5%85%88%E5%87%BA%E7%9A%84%E6%96%B9%E5%BC%8F%E9%87%87%E9%9B%86%E4%B8%80%E6%AC%A1%E6%A0%B7%E6%9C%AC%E3%80%82%E7%94%A8%E6%88%B7%E5%BA%94%E8%83%BD%E9%9A%8F%E6%97%B6%E8%8E%B7%E5%BE%97%E5%A4%A9%E6%B0%94%E9%A2%84%E6%8A%A5%EF%BC%8C%E5%9B%A0%E6%AD%A4%E7%A8%8B%E5%BA%8F%E5%BF%85%E9%A1%BB%E6%AF%94%E8%BE%83%E6%9C%80%E6%96%B0%E5%92%8C%E6%9C%80%E6%97%A7%E7%9A%84%E6%A0%B7%E6%9C%AC%EF%BC%88%E4%BE%8B%E5%A6%82%EF%BC%8C%E7%8E%B0%E5%9C%A8%E6%98%AF%E4%B8%8A%E5%8D%88%2011%20%E6%97%B6%2010%20%E5%88%86%EF%BC%8C%E6%9C%80%E6%97%A7%E7%9A%84%E6%A0%B7%E6%9C%AC%E6%98%AF%E5%9C%A8%E4%B8%8A%E5%8D%88%208%20%E6%97%B6%2000%20%E5%88%86%E8%8E%B7%E5%BE%97%E7%9A%84%EF%BC%8C%E6%9C%80%E6%96%B0%E7%9A%84%E6%A0%B7%E6%9C%AC%E6%98%AF%E5%9C%A8%E4%B8%8A%E5%8D%88%2011%20%E6%97%B6%2000%20%E5%88%86%E8%8E%B7%E5%BE%97%E7%9A%84%E3%80%82%E7%84%B6%E5%90%8E%EF%BC%8C%E6%88%91%E5%86%8D%E5%88%B6%E4%BD%9C%E4%B8%80%E4%B8%AA%E7%BB%87%E7%BD%91%E5%9B%BE%E6%A1%88%E5%B9%B6%E5%B1%95%E7%A4%BA%E5%87%BA%E6%9D%A5%E3%80%82%E4%B8%8B%E4%B8%80%E6%AC%A1%E6%A0%B7%E6%9C%AC%E6%9B%B4%E6%96%B0%E5%B0%86%E5%9C%A8%E4%B8%8A%E5%8D%88%2011%20%E6%97%B6%E8%87%B3%2020%20%E6%97%B6%E8%BF%9B%E8%A1%8C%E3%80%82)%3C%2FP%3E%3CP%3E%E4%BD%86%E6%88%91%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%E7%AC%AC%E4%B8%80%E6%AC%A1%E5%81%9C%E4%B8%8B%E6%9D%A5%3C%2FSTRONG%3E%3C%2FSPAN%3E%EF%BC%9A%E5%AD%97%E8%8A%82%EF%BC%8C%E4%BB%8E%20FIFO%20%E8%AF%BB%E5%8F%96%EF%BC%8C%22%20%E4%BB%8E%20FIFO%20%E7%BC%93%E5%86%B2%E5%8C%BA%E5%89%8D%E9%9D%A2%E5%88%A0%E9%99%A4%20%22%EF%BC%88page24%20DS%EF%BC%89%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%88%91%E4%BB%8E%E7%BC%93%E5%86%B2%E5%8C%BA%E4%B8%AD%E8%AF%BB%E5%8F%96%E6%95%B0%E5%80%BC%EF%BC%8C%E5%B0%B1%E4%BC%9A%E4%B8%A2%E5%A4%B1%E5%AE%83%E4%BB%AC%E3%80%82%E5%A6%82%E6%9E%9C%E6%88%91%E5%9C%A8%E4%B8%8A%E5%8D%88%2011%20%E6%97%B6%E8%87%B3%2010%20%E6%97%B6%E5%88%B6%E4%BD%9C%E4%BA%86%E4%B8%8A%E8%BF%B0%E7%A4%BA%E4%BE%8B%E4%B8%AD%E7%9A%84%E5%A4%A9%E6%B0%94%E6%A8%A1%E5%BC%8F%EF%BC%8C%E9%82%A3%E4%B9%88%E5%9C%A8%E4%B8%8A%E5%8D%88%2011%20%E6%97%B6%E8%87%B3%2020%20%E6%97%B6%EF%BC%8C%E6%88%91%E5%B0%B1%E6%97%A0%E6%B3%95%E4%BB%8E%20FIFO%20%E8%8E%B7%E5%8F%96%E6%95%B0%E6%8D%AE%EF%BC%81%20%E6%89%80%E6%9C%89%E6%94%B6%E9%9B%86%E5%88%B0%E7%9A%84%E6%95%B0%E6%8D%AE%EF%BC%88%E4%BB%8E%E4%B8%8A%E5%8D%88%208%20%E6%97%B6%2020%20%E5%88%86%E5%88%B0%E4%B8%8A%E5%8D%88%2011%20%E6%97%B6%2020%20%E5%88%86%EF%BC%89%E9%83%BD%E5%B0%86%E4%B8%A2%E5%A4%B1%EF%BC%81%3C%2FP%3E%3CP%3E%E6%89%80%E4%BB%A5%EF%BC%8C%E8%BF%99%E7%A7%8D%E6%96%B9%E6%B3%95%E6%98%AF%E8%A1%8C%E4%B8%8D%E9%80%9A%E7%9A%84%EF%BC%9A%3C%2FP%3E%3CP%3E%E5%A5%BD%E7%9A%84%EF%BC%8CAN3914%20%E6%9C%89%E5%8F%A6%E4%B8%80%E7%A7%8D%E6%9B%B4%E5%BF%AB%E7%9A%84%E5%A4%A9%E6%B0%94%E9%A2%84%E6%8A%A5%E6%96%B9%E6%B3%95%EF%BC%88%E7%AC%AC%206%20%E9%A1%B5%EF%BC%89%EF%BC%81%E6%88%91%E5%8F%AA%E9%9C%80%E8%A6%81%E6%B0%94%E5%8E%8B%E5%92%8C%E5%BD%93%E5%89%8D%E9%AB%98%E5%BA%A6%EF%BC%88MPL3115%20%E5%BF%85%E9%A1%BB%E6%8F%90%E4%BE%9B%E6%89%80%E6%9C%89%E8%BF%99%E4%BA%9B%E4%BF%A1%E6%81%AF%EF%BC%89%E3%80%82%E6%88%91%E5%BF%85%E9%A1%BB%E7%94%A8%E5%85%AC%E5%BC%8F%E8%AE%A1%E7%AE%97%E5%87%BA%22%E7%90%86%E6%83%B3%E6%B0%94%E5%8E%8B%22%20Pweather%EF%BC%88%E6%99%B4%E5%A4%A9%E6%97%B6%EF%BC%89%E5%BD%93%E5%89%8D%E7%9A%84%E6%B5%B7%E6%8B%94%E9%AB%98%E5%BA%A6%EF%BC%9APweather%20%3D%20(101.3*%20exp(((float)(CurrentAltitude))%2F(-7900)).%E5%B9%B6%E5%B0%86%E5%BD%93%E5%89%8D%E5%8E%8B%E5%8A%9B%E4%B8%8E%22%E7%90%86%E6%83%B3%E5%8E%8B%E5%8A%9B%E8%BF%9B%E8%A1%8C%E6%AF%94%E8%BE%83%22%20%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%86%99%E4%BA%86%E4%B8%80%E6%AE%B5%E4%BB%A3%E7%A0%81%EF%BC%9A%E8%AE%BE%E7%BD%AE%E9%AB%98%E5%BA%A6%E8%AE%A1%E6%A8%A1%E5%BC%8F%E5%B9%B6%E8%8E%B7%E5%8F%96%E5%BD%93%E5%89%8D%E9%AB%98%E5%BA%A6%EF%BC%8C%E8%AE%BE%E7%BD%AE%E6%B0%94%E5%8E%8B%E8%AE%A1%E6%A8%A1%E5%BC%8F%E5%B9%B6%E8%8E%B7%E5%8F%96%E5%BD%93%E5%89%8D%E6%B0%94%E5%8E%8B%EF%BC%8C%E8%AE%A1%E7%AE%97%E5%B9%B6%E6%98%BE%E7%A4%BA%E5%A4%A9%E6%B0%94%E6%A8%A1%E5%BC%8F%E7%9A%84%E7%BB%93%E6%9E%9C%E3%80%82%E6%88%91%E4%BD%8F%E5%9C%A8%E6%B5%B7%E6%8B%94%2056-178%20%E7%B1%B3%E7%9A%84%E5%9C%B0%E5%8C%BA%E3%80%82%E6%88%91%E5%BC%80%E5%A7%8B%E6%B5%8B%E8%AF%95%EF%BC%8C%E5%BE%97%E5%88%B0%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%E7%AC%AC%E4%BA%8C%E4%B8%AA%20STOP%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%20%3A%3C%2FP%3E%3CP%3E%E4%BC%A0%E6%84%9F%E5%99%A8%E7%9A%84%E5%8D%B0%E5%88%B7%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%BE%E5%9C%A8%E5%AE%A4%E6%B8%A9%EF%BC%8822-24%20%E6%91%84%E6%B0%8F%E5%BA%A6%EF%BC%89%E4%B8%8B%E7%9A%84%E6%A1%8C%E5%AD%90%E4%B8%8A%EF%BC%8C%E4%B8%8D%E4%BC%9A%E7%A7%BB%E5%8A%A8%E3%80%82%E6%BA%90%E4%BB%A3%E7%A0%81%E4%B8%8D%E4%BC%9A%E6%94%B9%E5%8F%98%E3%80%82%20%E6%97%A9%E4%B8%8A%E6%88%91%E7%9A%84%E6%B5%B7%E6%8B%94%E9%AB%98%E5%BA%A6%E4%B8%BA%20102%20%E7%B1%B3%EF%BC%8C%E6%99%9A%E9%A4%90%E6%97%B6%E4%B8%BA%2032%20%E7%B1%B3%EF%BC%8C%E6%99%9A%E4%B8%8A%E4%B8%BA%200%20%E7%B1%B3%E3%80%82%E6%89%93%E5%BC%80%E8%B0%83%E8%AF%95%E5%99%A8%E5%90%8E%E5%8F%91%E7%8E%B0%EF%BC%9A%E5%9C%A8%E9%AB%98%E5%BA%A6%E8%AE%A1%E6%A8%A1%E5%BC%8F%E4%B8%8B%E8%AF%BB%E5%8F%96%E6%95%B0%E6%8D%AE%E5%AF%84%E5%AD%98%E5%99%A8%E6%97%B6%EF%BC%8COUT_P_MSB%20%E5%AF%84%E5%AD%98%E5%99%A8%3D%200xFF%EF%BC%8C%E5%9B%A0%E6%AD%A4%E4%BB%8E%E4%BC%A0%E6%84%9F%E5%99%A8%E8%8E%B7%E5%8F%96%E7%9A%84%E6%95%B0%E6%8D%AE%E4%B8%8D%E6%AD%A3%E7%A1%AE%E3%80%82%E4%BD%86%E6%98%AF%E5%9C%A8%E8%BF%99%E6%AC%A1%E8%AF%BB%E5%8F%96%E6%93%8D%E4%BD%9C%E4%B8%AD%E6%88%91%E5%BE%97%E5%88%B0%E4%BA%86%E6%AD%A3%E7%A1%AE%E7%9A%84%E6%B8%A9%E5%BA%A6%E6%95%B0%E6%8D%AE%EF%BC%88%E6%88%91%E5%9C%A8%E4%B8%80%E4%B8%AA%E7%A8%8B%E5%BA%8F%E4%B8%AD%E5%BE%AA%E7%8E%AF%E4%BB%8E%E4%BC%A0%E6%84%9F%E5%99%A8%E8%AF%BB%E5%8F%96%205%20%E5%AD%97%E8%8A%82%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%E6%89%80%E4%BB%A5%EF%BC%8C%E8%BF%99%E7%A7%8D%E6%96%B9%E5%BC%8F%E5%B9%B6%E4%B8%8D%E8%83%BD%E7%BB%99%E4%BA%BA%E4%BF%A1%E5%BF%83......%3CIMG%20id%3D%22smileysad%22%20class%3D%22emoticon%20emoticon-smileysad%22%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fi%2Fsmilies%2F16x16_smiley-sad.png%22%20alt%3D%22%E7%AC%91%E8%84%B8%E6%82%B2%E4%BC%A4%22%20title%3D%22%E7%AC%91%E8%84%B8%E6%82%B2%E4%BC%A4%22%20%2F%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%8F%AA%E9%9C%80%E8%A6%81%E6%89%BE%E5%88%B0%E4%B8%80%E4%B8%AA%E5%B7%AB%E5%B8%88%EF%BC%81%E5%9B%A0%E4%B8%BA%E6%88%91%E6%97%A0%E6%B3%95%E7%90%86%E8%A7%A3%E8%BF%99%E4%B8%AA%E9%9D%9E%E5%B8%B8%E7%B2%BE%E7%BB%86%E7%9A%84%E4%BC%A0%E6%84%9F%E5%99%A8%E3%80%82%3C%2FP%3E%3CP%3E%E8%B0%81%E8%83%BD%E5%B8%AE%E5%B8%AE%E6%88%91%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%87%B4%E4%BB%A5%E6%9C%80%E8%AF%9A%E6%8C%9A%E7%9A%84%E9%97%AE%E5%80%99%EF%BC%8C%E5%9F%83%E5%88%A9%E6%96%AF%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-251777%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E5%8E%8B%E5%8A%9B%E4%BC%A0%E6%84%9F%E5%99%A8%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-251778%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20mystical%20sensor%20MPL3115%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-251778%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%97%A8%EF%BC%8C%E5%9F%83%E5%88%A9%E6%96%AF%E3%80%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E5%9C%A8%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%E7%A4%BE%E5%8C%BA%E6%8F%90%E4%BE%9B%E4%BA%86%E4%B8%80%E4%BA%9B%E4%BB%A3%E7%A0%81%E7%A4%BA%E4%BE%8B%E5%92%8C%E5%85%B6%E4%BB%96%E6%96%87%E6%A1%A3%EF%BC%8C%E6%88%96%E8%AE%B8%E5%AF%B9%E6%82%A8%E6%9C%89%E7%94%A8%20%EF%BC%9A%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fcommunity%2Fsensors%2Fcontent%3FfilterID%3Dcontentstatus%5Bpublished%5D~objecttype~objecttype%5Bdocument%5D%26amp%3Bquery%3DMPL3115A2%22%20target%3D%22_blank%22%3E%20https%3A%2F%2Fcommunity.freescale.com%2Fcommunity%2Fsensors%2Fcontent%3FfilterID%3Dcontentstatus%255Bpublished%25%205D~objecttype~objecttype%255Bdocument%25%205D%20%26amp%3Bquery%3DMPL3115A2%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3E%E4%BD%95%E5%A1%9E%3C%2FP%3E%3C%2FLINGO-BODY%3E
