SPI mode that is used in NCK2910
已解决
跳至解决方案
1,434 次查看
israelfelix
Greetings everyone! Thank you for your support! The NCK2910 connects to SPI in which mode? Mode 3 or 2? Is it possible to change this in the NCK2910 firmware?
1 解答
1,419 次查看
diazmarin09
Hello israelfelix,
I hope all is great with you. Thank you for using the NXP communities.
Unfortunately, I'm unable to provide support for NCK2910. This is because NCK2910 is secure car access and is out of my scope. Have you contacted your local distributor?
David
在原帖中查看解决方案
2 回复数
1,399 次查看
israelfelix
Thanks for the answer! I am in the process of contacting you to get the NDA.
1,420 次查看
diazmarin09
Hello israelfelix,
David
