原计划选用MPX2010DP压力传感器做空速管,先发现只能提供3.3V供电电压(MPX2010DP需要10V左电压,不满足要求),求与MPX2010DP各项指标相似,电压3.3V左右的压力传感器!
Dear V. Henry,
please refer to this link for a list of our differential/Gauge pressure sensors with range up to 10kPa. If you need differential pressure sensor with typical supply voltage of 3V, you can consider MP3V5010DP, MPX10D, MPX10DP, MPXC12D or MPXC2011D. The MP3V5010DP is in the same package as the MPX2010DP.
With Best Regards,
Jozef
