mc33771C fault
已解决
mc33771C fault
跳至解决方案
1,733 次查看
alessandro_piazza
I configured GPIO3 to GPIO6 as digital input but UT fault bits in AN_OT_UT_FLT continue to rise (and so in FAULT1_STATUS). I tried to set temp thresholds to min/max but nothing changes. Any help?
thanks!
1 解答
1,647 次查看
guoweisun
If no IIC used, the pack controller has to ignore the content of FAULT1_STATUS[I2C_ERR_FLT].
在原帖中查看解决方案
3 回复数
1,658 次查看
alessandro_piazza
Hi, I've just solved AN_OT_UT_FLT bits (there was an error in the config sequence).
The only alarm I cannot disable remain I2C_ERR_FLT in FAULT1STATUS (I dont use I2C).
Is there any way to disable it?
thanks!
1,648 次查看
guoweisun
1,706 次查看
guoweisun
Could you please let me know your configure steps?
