IMX8M MINI Camera Driver Integration
AjithAjmal
Hello all,
We are using imx298 camera module with imx8mm board using android 14. can you support us with the camera driver for imx298?
Bio_TICFSL
It is not supported by default but if you had the module you can enable in the terminal and modified the dtb.
Bio_TICFSL
%3CLINGO-SUB%20id%3D%22lingo-sub-1954298%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EIMX8M%20MINI%20Camera%20Driver%20Integration%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1954298%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20all%2C%3C%2FP%3E%3CP%3EWe%20are%20using%20imx298%20camera%20module%20with%20imx8mm%20board%20using%20android%2014.%20can%20you%20support%20us%20with%20the%20camera%20driver%20for%20imx298%3F%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1955661%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20IMX8M%20MINI%20Camera%20Driver%20Integration%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1955661%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CP%3EIt%20is%20not%20supported%20by%20default%20but%20if%20you%20had%20the%20module%20you%20can%20enable%20in%20the%20terminal%20and%20modified%20the%20dtb.%3C%2FP%3E%0A%3CP%3ERegards%3C%2FP%3E%3C%2FLINGO-BODY%3E
