P3T1035x(temp sensor) How to read the pointer register in I3C mode
331 次查看
T_B
Does the pointer register setting work with I3C communication?
Because it aborts when writing the pointer value, it looks like an I2C Ack/Nack is returned from the P3T1035x.
Toru
标记 (1)
1 回复
318 次查看
T_B
I will correct my question.
It aborts when receiving T bit after receiving data, sending Slave address and sending the pointer value,
