MIKROE 3195 Analogue output issue
Abhishek_Gaikar
I am currently working with MIKROE 3195 board consisting of MPVX6115 sensor from NXP for pressure measurement. The board's analog output isn't showing much fluctuations even after a large change in the pressure applied in my system. The system jumpers are at factory position VOUT jumper = 1v8 position I/O select = 3v3 position I'm using the Raspberry Pi Pico's ADC in order to read the analog output.
The formula I've used for conversion is P = [(VOUT / VS) - 0.92] / 0.007652 +- 1.725 kPa.
Could you please help me with this
ErikaC
Please find the transfer function in the datasheet page 6.
VOUT = VS x (0.007652 x P + 0.92) ± (Pressure Error x Temp. Factor x 0.007652 x VS)
Hope this helps.
