NX20P0477 moisture sensor
Mukhesh
Hi NXP team,
Greetings of the day,
Currently we are using NX20P0477 moisture sensor in our product and we are seeing some challenges in validating the moisture sensor.
Can you please help in getting the Resistor and capacitor combinations for the simulation of the moisture?
h01
Hello, if you are looking for different ranges of capacitors  & resistors.
TomasVaverka
I have noticed that you also created the support ticket (case) #00507245. My colleague Erika working on this case will get back to you later today with the circuit to test moisture detect function of the NX20P0477.
Tomas
Mukhesh
Thank you.
