The build error encountered while building NXP Radar SDK
1,575件の閲覧回数
AllenLi_Mega
Hi all,
I've installed the zephyr following the document "Zephyr BSP 0.8.0 User Manual for S32R41"
The sample code in the user manual could be built correctly.
Then I tried to build the RFE driver and the RSDK_offline_example.
However, I always get the error message as attached log files.
Could you please advise us if I need to change anything to build the radar SDK projects?
The error messages in the zephyr\build\CMakeFiles\ are also attached.
Allen
タグ(1)
0 返答(返信)
