MM9Z1-638 Interrupt sample code one for high prority every 10ms and another for Low prority 1000ms
a852013777
Hi Nxp Partner
Do you have sample code for interrupt?
We want to send voltage and current every 10ms and run the process for insulation resistance calculation evey 1000ms , but the insulation resistance caculation will take 50~100ms.
We need to use inturrupt of timer3 to make sure the voltage and current date was send by every 10ms.
Br,
Mike Liang
guoweisun
You project had taken over by local FAE team, I remembered had told to you! You can continue to communicate with them in future.
guoweisun
