Using Arduino interface of MIMX RT1170 EVK for sensor connection
SK02
Hello.
I am interfacing ultrasonic sensor to MIMX RT1170 EVK board. For interfacing the sensor I need to use Arduino interface for GPIOs connection. I am not able to find the proper connections for ultrasonic sensor connection, because not getting power at the pins.
I gave supply to board using adapter (J43).
I need reference for pins connection and are there any settings required for powering ON the arduino interface region?
Thank you.
mayliu1
Hi @SK02 ,
Thank you so much for your interest in our products and for using our community.
regarding your issue, could you please verify the following power configuration?
1: The adapter is connected to J43
2:  The SW5 power switch is turned ON
3: J38 is set to pins 1–2 to select the external 5 V input
Once these settings are confirmed, the board power rails—including those supplying the Arduino interface—should be available.
Please try it.
Best Regards
May
%3CLINGO-SUB%20id%3D%22lingo-sub-2379921%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EUsing%20Arduino%20interface%20of%20MIMX%20RT1170%20EVK%20for%20sensor%20connection%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2379921%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello.%3C%2FP%3E%3CP%3EI%20am%20interfacing%20ultrasonic%20sensor%20to%20MIMX%20RT1170%20EVK%20board.%20For%20interfacing%20the%20sensor%20I%20need%20to%20use%20Arduino%20interface%20for%20GPIOs%20connection.%20I%20am%20not%20able%20to%20find%20the%20proper%20connections%20for%20ultrasonic%20sensor%20connection%2C%20because%20not%20getting%20power%20at%20the%20pins.%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3EI%20gave%20supply%20to%20board%20using%20adapter%20(J43).%26nbsp%3B%3CBR%20%2F%3EI%20need%20reference%20for%20pins%20connection%20and%20are%20there%20any%20settings%20required%20for%20powering%20ON%20the%20arduino%20interface%20region%3F%3C%2FP%3E%3CP%3EThank%20you.%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2380495%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Using%20Arduino%20interface%20of%20MIMX%20RT1170%20EVK%20for%20sensor%20connection%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2380495%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F262693%22%20target%3D%22_blank%22%3E%40SK02%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CP%3EThank%20you%20so%20much%20for%20your%20interest%20in%20our%20products%20and%20for%20using%20our%20community.%3C%2FP%3E%0A%3CDIV%3E%0A%3CP%3Eregarding%20your%20issue%2C%20could%20you%20please%20verify%20the%20following%20power%20configuration%3F%3C%2FP%3E%0A%3CP%3E1%3A%20The%20adapter%20is%20connected%20to%20J43%3C%2FP%3E%0A%3CP%3E2%3A%26nbsp%3B%20The%20SW5%20power%20switch%20is%20turned%20ON%3C%2FP%3E%0A%3CP%3E3%3A%20J38%20is%20set%20to%20pins%201%E2%80%932%20to%20select%20the%20external%205%20V%20input%3C%2FP%3E%0A%3CP%3EOnce%20these%20settings%20are%20confirmed%2C%20the%20board%20power%20rails%E2%80%94including%20those%20supplying%20the%20Arduino%20interface%E2%80%94should%20be%20available.%3C%2FP%3E%0A%3CP%3EPlease%20try%20it.%3C%2FP%3E%0A%3CP%3EBest%20Regards%3C%2FP%3E%0A%3CP%3EMay%3C%2FP%3E%0A%3C%2FDIV%3E%3C%2FLINGO-BODY%3E
