S32R45 SptEcsIsrCb error!
ソリューションへジャンプ
2,197件の閲覧回数
sinetech
Search for the cause of the alarm is "AXI Read Error In PDMA." What reasons could cause this alarm?
SPT Error queue overflow! Only the first 10 errors are reported. Check last executed kernel!
SPT done
SptEcsIsrCb error!, Status: 0x11005, Error info: 0x10000
RsdkSptRun done. SPT processing done. Ready for next kernel.
2,065件の閲覧回数
petervlna
Likeliest root cause in your scenario:
  1. Stride/alignment mismatch between the kernel’s expected chirp pitch and the actual buffer layout—doubling samples aligns the burst size and masks the bug.
  2. WR_x selection / data width mismatch (real vs complex, 16‑bit vs other), corrected by chance when the sample count changes.
  3. Param order/type mix‑up in kernelParList (ADDR vs VALUE), only manifesting for certain sizes. The mirror thread shows a similar param sequence; it’s easy to slip an index.
  4. WR 24‑bit offset edge that disappears with a different packing/layout after doubling
Peter
4 返答(返信)
2,168件の閲覧回数
petervlna
Here are possible causes:
1. Mismatch Between SPT Input and S32DS Input
SPT kernel input did not match the expected S32DS configuration.
PDMA reads memory at addresses determined by the SPT kernel’s configuration. If buffer dimensions, cube base address, or channel count don’t align, PDMA may attempt to read invalid or unexpected memory locations → AXI read error.
2. Incorrect or Corrupted Work Register (WR_x) Configuration
If PDMA uses a work register pointing to an invalid or misconfigured buffer, the AXI fabric receives illegal read requests → triggers a bus error.
3. Synchronous vs. Asynchronous PDMA Execution Mode
.sync → .async
In .sync mode, PDMA waits for a condition that may never be met due to misconfiguration (e.g., buffer pointers, dependencies).
This can accumulate error flags and produce AXI errors if the PDMA engine attempts repeated invalid reads.
4. Wrong Data Width or Format (e.g., WR_16 vs WR_11)
If the PDMA expects 16‑bit complex data but the target register/buffer is configured for a different width/layout, AXI read bursts may misalign → protocol error → AXI Read Error.
5. AXI Protocol‑Level Errors (General Causes)
Even though not specific to S32R45, AXI read‑error mechanisms apply universally:
  • Invalid burst length or size
  • Attempts to read from unmapped or protected addresses
  • Slave timeout or non‑responsive target
  • Read response errors (SLVERR or DECERR) due to upstream issues
If PDMA generates malformed AXI transactions, the AXI interconnect will return SLVERR, which shows up as a PDMA read error.
Most Probable Causes in Your Case
Based on both your logs, the top suspects are:
  1. Wrong WR_x register (especially WR_5 / WR_16 selection)
    Very commonly misconfigured and leads to invalid AXI read.
  2. SPT kernel input mismatch with S32DS input
    Often overlooked and validated as the root cause in previous cases.
  3. PDMA sync mode causing dependency deadlock
    Try switching .sync → .async for debugging.
Peter
2,109件の閲覧回数
sinetech
Hello peter,
After doubling the number of waveform sampling points in the radar front-end, the error no longer occurs, but the chirp buffer size has not changed. Please help analyze the issue further. Thank you very much.
2,066件の閲覧回数
petervlna
Peter
2,160件の閲覧回数
sinetech
Hello Peter,
thank you very much for your reply.
Following the reasons you listed, I have carefully checked the code, with a particular focus on
WR_5, and did not find any issues. Moreover, I have not modified the SPT kernel code.
code initial list:
AppMemAllocBuffer(pHeapMem, &gSdadcSampleBufferBufH[index], sizeof(uint16_t) * RSDK_SPT_RANGE512_4CH_IN_BUF_SIZE,
                          RSDK_SPT_DATA_ADDR_ALIGN_BYTES, RSDK_OALMEM_CHUNK_ID_CBRAM);
RelocSptCode(gSptModuleCodeRelocBufH.virtAddr, RsdkSptRange512smp128crp4ch, RSDK_SPT_GET_KERNEL_SIZE(RsdkSptRange512smp128crp4ch));
np = 0;
sptContext.kernelParList[np].paramType = RSDK_SPT_PARAM_TYPE_ADDR;
sptContext.kernelParList[np++].paramValue =(uintptr_t)gSdadcSampleBufferBufH[0].phyAddr;
sptContext.kernelParList[np++].paramValue = (uintptr_t)gRadarCubeResultsBufH.phyAddr;
sptContext.kernelParList[np++].paramValue = (uintptr_t(gFft512TwiddleFactorsBufH.phyAddr);
 sprintf(fileName, "%s%s", FILE_IN_PATH, "fft512_twiddle_factors.dat");
/* RSDK data is stored in files big-endian format for compatibility reasons with PPC architectures     Endianess conversion is done ONLY for reading and writing data to/from files. No transformation is necessary in the processing flow.*/
DbgReadFileConvert(fileName, 0, (char *)gFft512TwiddleFactorsBufH.virtAddr, gFft512TwiddleFactorsBufH.numBytes, ENDIAN_CHANGE, DATA_BUFF_IS_CACHED);
sptContext.kernelParList[np++].paramValue = (uintptr_t)gFft512BlackmanWindowBufH.phyAddr;
sprintf(fileName, "%s%s", FILE_IN_PATH, "fft512_win_blackman.dat");
DbgReadFileConvert(fileName, 0, (char *)gFft512BlackmanWindowBufH.virtAddr, gFft512BlackmanWindowBufH.numBytes, ENDIAN_CHANGE, DATA_BUFF_IS_CACHED);
sptContext.kernelParList[np].paramType = RSDK_SPT_PARAM_TYPE_VALUE;
sptContext.kernelParList[np++].paramValue = 3; /* no output shift */
sptContext.kernelParList[np].paramType = RSDK_SPT_PARAM_TYPE_LAST;
PRINT LIST:
gSptModuleCodeRelocBufH.phyAddr: 0x34000000
gSdadcSampleBufferBufH[0].phyAddr: 0x28000000
gSdadcSampleBufferBufH[1].phyAddr: 0x28003000
gSdadcSampleBufferBufH[2].phyAddr: 0x28006000
gSdadcSampleBufferBufH[3].phyAddr: 0x28009000
gRadarCubeResultsBufH.phyAddr: 0x34002000
gFft512TwiddleFactorsBufH.phyAddr: 0x340bd000
gFft512BlackmanWindowBufH.phyAddr: 0x340bf000
%3CLINGO-SUB%20id%3D%22lingo-sub-2300196%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32R45%20SptEcsIsrCb%20%E3%82%A8%E3%83%A9%E3%83%BC!%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2300196%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E3%82%A2%E3%83%A9%E3%83%BC%E3%83%A0%E3%81%AE%E5%8E%9F%E5%9B%A0%E3%82%92%E6%A4%9C%E7%B4%A2%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%80%8CPDMA%20%E3%81%A7%E3%81%AE%20AXI%20%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%82%A8%E3%83%A9%E3%83%BC%E3%80%8D%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%82%A2%E3%83%A9%E3%83%BC%E3%83%A0%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E5%8E%9F%E5%9B%A0%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3ESPT%20%E3%82%A8%E3%83%A9%E3%83%BC%20%E3%82%AD%E3%83%A5%E3%83%BC%E3%81%8C%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%95%E3%83%AD%E3%83%BC%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%9C%80%E5%88%9D%E3%81%AE%2010%20%E4%BB%B6%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AE%E3%81%BF%E3%81%8C%E5%A0%B1%E5%91%8A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E6%9C%80%E5%BE%8C%E3%81%AB%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%9F%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84!%3CBR%20%2F%3ESPT%E5%AE%8C%E4%BA%86%3CBR%20%2F%3ESptEcsIsrCb%20%E3%82%A8%E3%83%A9%E3%83%BC!%E3%80%81%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3A%200x11005%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%E6%83%85%E5%A0%B1%3A%200x10000%3CBR%20%2F%3E%20SptEcsIsrCb%20%E3%82%A8%E3%83%A9%E3%83%BC!%E3%80%81%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3A%200x11005%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%E6%83%85%E5%A0%B1%3A%200x10000%3CBR%20%2F%3E%20SptEcsIsrCb%20%E3%82%A8%E3%83%A9%E3%83%BC!%E3%80%81%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3A%200x11005%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%E6%83%85%E5%A0%B1%3A%200x10000%3CBR%20%2F%3E%20SptEcsIsrCb%20%E3%82%A8%E3%83%A9%E3%83%BC!%E3%80%81%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3A%200x11005%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%E6%83%85%E5%A0%B1%3A%200x10000%3CBR%20%2F%3E%20SptEcsIsrCb%20%E3%82%A8%E3%83%A9%E3%83%BC!%E3%80%81%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3A%200x11005%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%E6%83%85%E5%A0%B1%3A%200x10000%3CBR%20%2F%3E%20SptEcsIsrCb%20%E3%82%A8%E3%83%A9%E3%83%BC!%E3%80%81%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3A%200x11005%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%E6%83%85%E5%A0%B1%3A%200x10000%3CBR%20%2F%3E%20SptEcsIsrCb%20%E3%82%A8%E3%83%A9%E3%83%BC!%E3%80%81%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3A%200x11005%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%E6%83%85%E5%A0%B1%3A%200x10000%3CBR%20%2F%3E%20SptEcsIsrCb%20%E3%82%A8%E3%83%A9%E3%83%BC!%E3%80%81%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3A%200x11005%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%E6%83%85%E5%A0%B1%3A%200x10000%3CBR%20%2F%3E%20SptEcsIsrCb%20%E3%82%A8%E3%83%A9%E3%83%BC!%E3%80%81%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3A%200x11005%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%E6%83%85%E5%A0%B1%3A%200x10000%3CBR%20%2F%3E%20SptEcsIsrCb%20%E3%82%A8%E3%83%A9%E3%83%BC!%E3%80%81%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3A%200x11005%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%E6%83%85%E5%A0%B1%3A%200x10000%3CBR%20%2F%3E%20RsdkSptRun%20%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82SPT%20%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B7%E3%83%B3%E3%82%B0%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%AC%A1%E3%81%AE%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E6%BA%96%E5%82%99%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2300447%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32R45%20SptEcsIsrCb%20error!%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2300447%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%83%94%E3%83%BC%E3%82%BF%E3%83%BC%E3%80%81%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E6%8C%99%E3%81%92%E3%81%9F%E7%90%86%E7%94%B1%E3%81%AB%E5%BE%93%E3%81%84%E3%80%81%E7%A7%81%E3%81%AF%E7%89%B9%E3%81%AB%E4%BB%A5%E4%B8%8B%E3%81%AE%E7%82%B9%E3%81%AB%E9%87%8D%E7%82%B9%E3%82%92%E7%BD%AE%E3%81%84%E3%81%A6%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E6%B3%A8%E6%84%8F%E6%B7%B1%E3%81%8F%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWR_5%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%AF%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E3%81%95%E3%82%89%E3%81%AB%E3%80%81SPT%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%20%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSTRONG%3E%E3%82%B3%E3%83%BC%E3%83%89%E5%88%9D%E6%9C%9F%E3%83%AA%E3%82%B9%E3%83%88%3A%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EAppMemAllocBuffer%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3EpHeapMem%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%20%3CSPAN%3EgSdadcSampleBufferBufH%3C%2FSPAN%3E%20%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%3C%2FSPAN%3E%3CSPAN%3E%5D%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3Esizeof%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3Euint16_t%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%20%3CSPAN%3E*%3C%2FSPAN%3E%20%3CSPAN%3ERSDK_SPT_RANGE512_4CH_IN_BUF_SIZE%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3ERSDK_SPT_DATA_ADDR_ALIGN_BYTES%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3ERSDK_OALMEM_CHUNK_ID_CBRAM%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ERelocSptCode%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3EgSptModuleCodeRelocBufH%3C%2FSPAN%3E%20%3CSPAN%3E.%3C%2FSPAN%3E%20%3CSPAN%3EvirtAddr%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3ERsdkSptRange512smp128crp4ch%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3ERSDK_SPT_GET_KERNEL_SIZE%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3ERsdkSptRange512smp128crp4ch%3C%2FSPAN%3E%20%3CSPAN%3E))%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Enp%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EsptContext%3C%2FSPAN%3E%20%3CSPAN%3E.%3C%2FSPAN%3E%20%3CSPAN%3EkernelParList%3C%2FSPAN%3E%20%3CSPAN%3E%5B%3C%2FSPAN%3E%20%3CSPAN%3Enp%3C%2FSPAN%3E%20%3CSPAN%3E%5D.%3C%2FSPAN%3E%20%3CSPAN%3EparamType%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3ERSDK_SPT_PARAM_TYPE_ADDR%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EsptContext%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%82%3C%2FSPAN%3E%20%3CSPAN%3EkernelParList%3C%2FSPAN%3E%20%3CSPAN%3E%5B%3C%2FSPAN%3E%20%3CSPAN%3Enp%3C%2FSPAN%3E%20%3CSPAN%3E%2B%2B%3C%2FSPAN%3E%20%3CSPAN%3E%5D%E3%80%82%3C%2FSPAN%3E%20%3CSPAN%3EparamValue%3C%2FSPAN%3E%20%3D%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3Euintptr_t%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%20%3CSPAN%3EgSdadcSampleBufferBufH%3C%2FSPAN%3E%20%3CSPAN%3E%5B%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E%5D%E3%80%82%3C%2FSPAN%3E%20%3CSPAN%3EphyAddr%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EsptContext%3C%2FSPAN%3E%20%3CSPAN%3E.%3C%2FSPAN%3E%20%3CSPAN%3EkernelParList%3C%2FSPAN%3E%20%3CSPAN%3E%5B%3C%2FSPAN%3E%20%3CSPAN%3Enp%3C%2FSPAN%3E%20%3CSPAN%3E%5D.%3C%2FSPAN%3E%20%3CSPAN%3EparamType%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3ERSDK_SPT_PARAM_TYPE_ADDR%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EsptContext%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%82%3C%2FSPAN%3E%20%3CSPAN%3EkernelParList%3C%2FSPAN%3E%20%3CSPAN%3E%5B%3C%2FSPAN%3E%20%3CSPAN%3Enp%3C%2FSPAN%3E%20%3CSPAN%3E%2B%2B%3C%2FSPAN%3E%20%3CSPAN%3E%5D%E3%80%82%3C%2FSPAN%3E%20%3CSPAN%3EparamValue%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3Euintptr_t%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%20%3CSPAN%3EgRadarCubeResultsBufH%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%82%3C%2FSPAN%3E%20%3CSPAN%3EphyAddr%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EsptContext%3C%2FSPAN%3E%20%3CSPAN%3E.%3C%2FSPAN%3E%20%3CSPAN%3EkernelParList%3C%2FSPAN%3E%20%3CSPAN%3E%5B%3C%2FSPAN%3E%20%3CSPAN%3Enp%3C%2FSPAN%3E%20%3CSPAN%3E%5D.%3C%2FSPAN%3E%20%3CSPAN%3EparamType%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3ERSDK_SPT_PARAM_TYPE_ADDR%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EsptContext%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%82%3C%2FSPAN%3E%20%3CSPAN%3EkernelParList%3C%2FSPAN%3E%20%3CSPAN%3E%5B%3C%2FSPAN%3E%20%3CSPAN%3Enp%3C%2FSPAN%3E%20%3CSPAN%3E%2B%2B%3C%2FSPAN%3E%20%3CSPAN%3E%5D%E3%80%82%3C%2FSPAN%3E%20%3CSPAN%3EparamValue%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3Euintptr_t%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3EgFft512TwiddleFactorsBufH%3C%2FSPAN%3E%20%3CSPAN%3E.%3C%2FSPAN%3E%20%3CSPAN%3EphyAddr%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3Esprintf%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E5%90%8D%3C%2FSPAN%3E%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3E%22%3C%2FSPAN%3E%20%3CSPAN%3E%25s%25%20s%3C%2FSPAN%3E%20%3CSPAN%3E%22%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EFILE_IN_PATH%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3E%22fft512_twiddle_factors.dat%22%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%2F*%20RSDK%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AF%E3%80%81PPC%E3%82%A2%E3%83%BC%E3%82%AD%E3%83%86%E3%82%AF%E3%83%81%E3%83%A3%E3%81%A8%E3%81%AE%E4%BA%92%E6%8F%9B%E6%80%A7%E3%81%AE%E3%81%9F%E3%82%81%E3%80%81%E3%83%93%E3%83%83%E3%82%B0%E3%82%A8%E3%83%B3%E3%83%87%E3%82%A3%E3%82%A2%E3%83%B3%E5%BD%A2%E5%BC%8F%E3%81%A7%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E4%BF%9D%E5%AD%98%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%3E%E3%82%A8%E3%83%B3%E3%83%87%E3%82%A3%E3%82%A2%E3%83%B3%E3%81%AE%E5%A4%89%E6%8F%9B%E3%81%AF%E3%80%81%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%B8%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AE%E8%AA%AD%E3%81%BF%E6%9B%B8%E3%81%8D%E6%99%82%E3%81%AB%E3%81%AE%E3%81%BF%E8%A1%8C%E3%82%8F%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%95%E3%83%AD%E3%83%BC%E5%86%85%E3%81%A7%E3%81%AE%E5%A4%89%E6%8F%9B%E3%81%AF%E5%BF%85%E8%A6%81%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EDbgReadFileConvert%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3EfileName%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%20(%3C%2FSPAN%3E%20%3CSPAN%3Echar%3C%2FSPAN%3E%20%3CSPAN%3E*%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%20%3CSPAN%3EgFft512TwiddleFactorsBufH%3C%2FSPAN%3E%20%3CSPAN%3E.%3C%2FSPAN%3E%20%3CSPAN%3EvirtAddr%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EgFft512TwiddleFactorsBufH%3C%2FSPAN%3E%20%3CSPAN%3E.%3C%2FSPAN%3E%20%3CSPAN%3EnumBytes%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EENDIAN_CHANGE%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EDATA_BUFF_IS_CACHED%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EsptContext%3C%2FSPAN%3E%20%3CSPAN%3E.%3C%2FSPAN%3E%20%3CSPAN%3EkernelParList%3C%2FSPAN%3E%20%3CSPAN%3E%5B%3C%2FSPAN%3E%20%3CSPAN%3Enp%3C%2FSPAN%3E%20%3CSPAN%3E%5D.%3C%2FSPAN%3E%20%3CSPAN%3EparamType%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3ERSDK_SPT_PARAM_TYPE_ADDR%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EsptContext%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%82%3C%2FSPAN%3E%20%3CSPAN%3EkernelParList%3C%2FSPAN%3E%20%3CSPAN%3E%5B%3C%2FSPAN%3E%20%3CSPAN%3Enp%3C%2FSPAN%3E%20%3CSPAN%3E%2B%2B%3C%2FSPAN%3E%20%3CSPAN%3E%5D%E3%80%82%3C%2FSPAN%3E%20%3CSPAN%3EparamValue%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3Euintptr_t%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%20%3CSPAN%3EgFft512BlackmanWindowBufH%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%82%3C%2FSPAN%3E%20%3CSPAN%3EphyAddr%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Esprintf%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E5%90%8D%3C%2FSPAN%3E%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3E%22%3C%2FSPAN%3E%20%3CSPAN%3E%25s%25%20s%3C%2FSPAN%3E%20%3CSPAN%3E%22%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EFILE_IN_PATH%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3E%22fft512_win_blackman.dat%22%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EDbgReadFileConvert%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3EfileName%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%20(%3C%2FSPAN%3E%20%3CSPAN%3Echar%3C%2FSPAN%3E%20%3CSPAN%3E*%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%20%3CSPAN%3EgFft512BlackmanWindowBufH%3C%2FSPAN%3E%20%3CSPAN%3E.%3C%2FSPAN%3E%20%3CSPAN%3EvirtAddr%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EgFft512BlackmanWindowBufH%3C%2FSPAN%3E%20%3CSPAN%3E.%3C%2FSPAN%3E%20%3CSPAN%3EnumBytes%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EENDIAN_CHANGE%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EDATA_BUFF_IS_CACHED%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EsptContext%3C%2FSPAN%3E%20%3CSPAN%3E.%3C%2FSPAN%3E%20%3CSPAN%3EkernelParList%3C%2FSPAN%3E%20%3CSPAN%3E%5B%3C%2FSPAN%3E%20%3CSPAN%3Enp%3C%2FSPAN%3E%20%3CSPAN%3E%5D.%3C%2FSPAN%3E%20%3CSPAN%3EparamType%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3ERSDK_SPT_PARAM_TYPE_VALUE%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EsptContext%3C%2FSPAN%3E%20%3CSPAN%3E.%3C%2FSPAN%3E%20%3CSPAN%3EkernelParList%3C%2FSPAN%3E%20%3CSPAN%3E%5B%3C%2FSPAN%3E%20%3CSPAN%3Enp%3C%2FSPAN%3E%20%3CSPAN%3E%2B%2B%3C%2FSPAN%3E%20%3CSPAN%3E%5D.%3C%2FSPAN%3E%20%3CSPAN%3EparamValue%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E3%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F*%20%E5%87%BA%E5%8A%9B%E3%82%B7%E3%83%95%E3%83%88%E3%81%AA%E3%81%97%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3EsptContext%3C%2FSPAN%3E%20%3CSPAN%3E.%3C%2FSPAN%3E%20%3CSPAN%3EkernelParList%3C%2FSPAN%3E%20%3CSPAN%3E%5B%3C%2FSPAN%3E%20%3CSPAN%3Enp%3C%2FSPAN%3E%20%3CSPAN%3E%5D.%3C%2FSPAN%3E%20%3CSPAN%3EparamType%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3ERSDK_SPT_PARAM_TYPE_LAST%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSTRONG%3E%E5%8D%B0%E5%88%B7%E3%83%AA%E3%82%B9%E3%83%88%3A%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%3E%3CP%3E%3CBR%20%2F%3EgSptModuleCodeRelocBufH.phyAddr%3A%200x34000000%3C%2FP%3E%3CP%3EgSdadcSampleBufferBufH%5B0%5D.phyAddr%3A%200x28000000%3C%2FP%3E%3CP%3EgSdadcSampleBufferBufH%5B1%5D.phyAddr%3A%200x28003000%3C%2FP%3E%3CP%3EgSdadcSampleBufferBufH%5B2%5D.phyAddr%3A%200x28006000%3C%2FP%3E%3CP%3EgSdadcSampleBufferBufH%5B3%5D.phyAddr%3A%200x28009000%3C%2FP%3E%3CP%3EgRadarCubeResultsBufH.phyAddr%3A%200x34002000%3C%2FP%3E%3CP%3EgFft512TwiddleFactorsBufH.phyAddr%3A%200x340bd000%3C%2FP%3E%3CP%3EgFft512BlackmanWindowBufH.phyAddr%3A%200x340bf000%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2300298%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32R45%20SptEcsIsrCb%20error!%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2300298%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CP%3E%E8%80%83%E3%81%88%E3%82%89%E3%82%8C%E3%82%8B%E5%8E%9F%E5%9B%A0%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%3A%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E1.%20SPT%E5%85%A5%E5%8A%9B%E3%81%A8S32DS%E5%85%A5%E5%8A%9B%E3%81%AE%E4%B8%8D%E4%B8%80%E8%87%B4%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CDIV%3ESPT%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E5%85%A5%E5%8A%9B%E3%81%8C%E4%BA%88%E6%9C%9F%E3%81%95%E3%82%8C%E3%81%9F%20S32DS%20%E6%A7%8B%E6%88%90%E3%81%A8%E4%B8%80%E8%87%B4%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FDIV%3E%0A%3CDIV%3EPDMA%20%E3%81%AF%E3%80%81SPT%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E6%A7%8B%E6%88%90%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E6%B1%BA%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%9F%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%A7%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%20%E3%82%B5%E3%82%A4%E3%82%BA%E3%80%81%E3%82%AD%E3%83%A5%E3%83%BC%E3%83%96%20%E3%83%99%E3%83%BC%E3%82%B9%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%20%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%E3%81%8C%E6%8F%83%E3%81%A3%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81PDMA%20%E3%81%AF%E7%84%A1%E5%8A%B9%E3%81%BE%E3%81%9F%E3%81%AF%E4%BA%88%E6%9C%9F%E3%81%97%E3%81%AA%E3%81%84%E3%83%A1%E3%83%A2%E3%83%AA%E4%BD%8D%E7%BD%AE%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8D%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%20%E2%86%92%20AXI%20%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%82%A8%E3%83%A9%E3%83%BC%E3%80%82%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3E%3CSTRONG%3E2.%20%E4%BD%9C%E6%A5%AD%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%EF%BC%88WR_x%EF%BC%89%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E3%81%AA%E3%81%84%E3%81%8B%E7%A0%B4%E6%90%8D%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%3C%2FSTRONG%3E%3C%2FDIV%3E%0A%3CDIV%3EPDMA%20%E3%81%8C%E7%84%A1%E5%8A%B9%E3%81%BE%E3%81%9F%E3%81%AF%E8%AA%A4%E3%81%A3%E3%81%A6%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%92%E6%8C%87%E3%81%99%E4%BD%9C%E6%A5%AD%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81AXI%20%E3%83%95%E3%82%A1%E3%83%96%E3%83%AA%E3%83%83%E3%82%AF%E3%81%AF%E4%B8%8D%E6%AD%A3%E3%81%AA%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E8%A6%81%E6%B1%82%E3%82%92%E5%8F%97%E4%BF%A1%E3%81%97%E3%80%81%E3%83%90%E3%82%B9%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%0A%3CDIV%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FOther-NXP-Products%2FSPT3-1-1024-128-16range-don-t-work%2Fm-p%2F1621567%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FOther-NXP-Products%2FSPT3-1-1024-128-16range-don-t-work%2Fmp%2F1621567%3C%2FA%3E%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3E%3CSTRONG%3E3.%20%E5%90%8C%E6%9C%9FPDMA%E5%AE%9F%E8%A1%8C%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A8%E9%9D%9E%E5%90%8C%E6%9C%9FPDMA%E5%AE%9F%E8%A1%8C%E3%83%A2%E3%83%BC%E3%83%89%3C%2FSTRONG%3E%3C%2FDIV%3E%0A%3CDIV%3E.sync%20%E2%86%92%20.async%3C%2FDIV%3E%0A%3CDIV%3E.sync%E3%81%A7%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AF%E3%80%81PDMA%20%E3%81%AF%E8%AA%A4%E3%81%A3%E3%81%9F%E6%A7%8B%E6%88%90%20(%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%20%E3%83%9D%E3%82%A4%E3%83%B3%E3%82%BF%E3%80%81%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%81%AA%E3%81%A9)%20%E3%81%AB%E3%82%88%E3%82%8A%E6%BA%80%E3%81%9F%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%AE%E3%81%82%E3%82%8B%E6%9D%A1%E4%BB%B6%E3%82%92%E5%BE%85%E6%A9%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%20%E3%83%95%E3%83%A9%E3%82%B0%E3%81%8C%E8%93%84%E7%A9%8D%E3%81%95%E3%82%8C%E3%80%81PDMA%20%E3%82%A8%E3%83%B3%E3%82%B8%E3%83%B3%E3%81%8C%E7%84%A1%E5%8A%B9%E3%81%AA%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%82%92%E7%B9%B0%E3%82%8A%E8%BF%94%E3%81%97%E8%A9%A6%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%20AXI%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3E%3CSTRONG%3E4.%20%E3%83%87%E3%83%BC%E3%82%BF%E5%B9%85%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%E3%81%8C%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%EF%BC%88%E4%BE%8B%EF%BC%9AWR_16%E3%81%A8WR_11%EF%BC%89%3C%2FSTRONG%3E%3C%2FDIV%3E%0A%3CDIV%3EPDMA%20%E3%81%8C%2016%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E8%A4%87%E5%90%88%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E6%9C%9F%E5%BE%85%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8C%E3%80%81%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%2F%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%8C%E7%95%B0%E3%81%AA%E3%82%8B%E5%B9%85%2F%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81AXI%20%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%83%90%E3%83%BC%E3%82%B9%E3%83%88%E3%81%8C%E4%B8%8D%E6%95%B4%E5%90%88%E3%81%AB%E3%81%AA%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%82%A8%E3%83%A9%E3%83%BC%20%E2%86%92%20AXI%20%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3E%3CSTRONG%3E5.%20AXI%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%AC%E3%83%99%E3%83%AB%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%EF%BC%88%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%AA%E5%8E%9F%E5%9B%A0%EF%BC%89%3C%2FSTRONG%3E%3C%2FDIV%3E%0A%3CDIV%3E%0A%3CP%3ES32R45%20%E3%81%AB%E5%9B%BA%E6%9C%89%E3%81%AE%E3%82%82%E3%81%AE%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81AXI%20%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%82%A8%E3%83%A9%E3%83%BC%20%E3%83%A1%E3%82%AB%E3%83%8B%E3%82%BA%E3%83%A0%E3%81%AF%E6%99%AE%E9%81%8D%E7%9A%84%E3%81%AB%E9%81%A9%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E3%83%90%E3%83%BC%E3%82%B9%E3%83%88%E9%95%B7%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%8C%E7%84%A1%E5%8A%B9%E3%81%A7%E3%81%99%3C%2FLI%3E%0A%3CLI%3E%E3%83%9E%E3%83%83%E3%83%97%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%BE%E3%81%9F%E3%81%AF%E4%BF%9D%E8%AD%B7%E3%81%95%E3%82%8C%E3%81%9F%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%8B%E3%82%89%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%AE%E8%A9%A6%E3%81%BF%3C%2FLI%3E%0A%3CLI%3E%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%BE%E3%81%9F%E3%81%AF%E5%BF%9C%E7%AD%94%E3%81%97%E3%81%AA%E3%81%84%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%3C%2FLI%3E%0A%3CLI%3E%E3%82%A2%E3%83%83%E3%83%97%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E3%82%88%E3%82%8B%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E5%BF%9C%E7%AD%94%E3%82%A8%E3%83%A9%E3%83%BC%EF%BC%88SLVERR%20%E3%81%BE%E3%81%9F%E3%81%AF%20DECERR%EF%BC%89%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3EPDMA%20%E3%81%8C%E4%B8%8D%E6%AD%A3%E3%81%AA%20AXI%20%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B6%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E7%94%9F%E6%88%90%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81AXI%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%88%E3%81%AF%20SLVERR%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%20PDMA%20%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%A8%E3%81%97%E3%81%A6%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSTRONG%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%82%B1%E3%83%BC%E3%82%B9%E3%81%A7%E6%9C%80%E3%82%82%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%AE%E9%AB%98%E3%81%84%E5%8E%9F%E5%9B%A0%3C%2FSTRONG%3E%3CBR%20%2F%3E%E4%B8%A1%E6%96%B9%E3%81%AE%E3%83%AD%E3%82%B0%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%8F%E3%81%A8%E3%80%81%E4%B8%BB%E3%81%AA%E5%AE%B9%E7%96%91%E8%80%85%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3COL%3E%0A%3CLI%3E%E9%96%93%E9%81%95%E3%81%A3%E3%81%9FWR_x%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%EF%BC%88%E7%89%B9%E3%81%ABWR_5%20%2F%20WR_16%E3%81%AE%E9%81%B8%E6%8A%9E%EF%BC%89%3CBR%20%2F%3E%E9%9D%9E%E5%B8%B8%E3%81%AB%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%AB%E3%81%AF%E8%AA%A4%E3%81%A3%E3%81%A6%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%80%81%E7%84%A1%E5%8A%B9%E3%81%AA%20AXI%20%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%AB%E3%81%A4%E3%81%AA%E3%81%8C%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3CLI%3ESPT%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E5%85%A5%E5%8A%9B%E3%81%A8S32DS%E5%85%A5%E5%8A%9B%E3%81%AE%E4%B8%8D%E4%B8%80%E8%87%B4%3CBR%20%2F%3E%E4%BB%A5%E5%89%8D%E3%81%AE%E3%82%B1%E3%83%BC%E3%82%B9%E3%81%A7%E3%81%AF%E3%80%81%E8%A6%8B%E8%90%BD%E3%81%A8%E3%81%95%E3%82%8C%E3%80%81%E6%A0%B9%E6%9C%AC%E5%8E%9F%E5%9B%A0%E3%81%A8%E3%81%97%E3%81%A6%E6%A4%9C%E8%A8%BC%E3%81%95%E3%82%8C%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%88%E3%81%8F%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3CLI%3EPDMA%E5%90%8C%E6%9C%9F%E3%83%A2%E3%83%BC%E3%83%89%E3%81%8C%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%81%AE%E3%83%87%E3%83%83%E3%83%89%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E5%BC%95%E3%81%8D%E8%B5%B7%E3%81%93%E3%81%99%3CBR%20%2F%3E.sync%E3%82%92%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%81%A6%E3%81%BF%E3%82%8B%E2%86%92%20.async%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E7%94%A8%E3%80%82%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%94%E3%83%BC%E3%82%BF%E3%83%BC%3C%2FP%3E%0A%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2301152%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32R45%20SptEcsIsrCb%20error!%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2301152%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%83%94%E3%83%BC%E3%82%BF%E3%83%BC%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%83%AC%E3%83%BC%E3%83%80%E3%83%BC%20%E3%83%95%E3%83%AD%E3%83%B3%E3%83%88%E3%82%A8%E3%83%B3%E3%83%89%E3%81%AE%E6%B3%A2%E5%BD%A2%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AA%E3%83%B3%E3%82%B0%20%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%AE%E6%95%B0%E3%82%92%202%20%E5%80%8D%E3%81%AB%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AF%E7%99%BA%E7%94%9F%E3%81%97%E3%81%AA%E3%81%8F%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%83%81%E3%83%A3%E3%83%BC%E3%83%97%20%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%AE%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AF%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E5%95%8F%E9%A1%8C%E3%82%92%E3%81%95%E3%82%89%E3%81%AB%E5%88%86%E6%9E%90%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AB%E3%81%94%E5%8D%94%E5%8A%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%A9%E3%81%86%E3%82%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2302673%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32R45%20SptEcsIsrCb%20error!%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2302673%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%82%B7%E3%83%8A%E3%83%AA%E3%82%AA%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8B%E6%9C%80%E3%82%82%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%AE%E9%AB%98%E3%81%84%E6%A0%B9%E6%9C%AC%E5%8E%9F%E5%9B%A0%3A%3C%2FP%3E%0A%3COL%3E%0A%3CLI%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E4%BA%88%E6%83%B3%E3%81%95%E3%82%8C%E3%82%8B%E3%83%81%E3%83%A3%E3%83%BC%E3%83%97%E3%83%94%E3%83%83%E3%83%81%E3%81%A8%E5%AE%9F%E9%9A%9B%E3%81%AE%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%E9%96%93%E3%81%AE%E3%82%B9%E3%83%88%E3%83%A9%E3%82%A4%E3%83%89%2F%E3%82%A2%E3%83%A9%E3%82%A4%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AE%E4%B8%8D%E4%B8%80%E8%87%B4%20-%20%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%92%202%20%E5%80%8D%E3%81%AB%E3%81%99%E3%82%8B%E3%81%A8%E3%83%90%E3%83%BC%E3%82%B9%E3%83%88%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%8C%E6%8F%83%E3%81%84%E3%80%81%E3%83%90%E3%82%B0%E3%81%8C%E3%83%9E%E3%82%B9%E3%82%AF%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3CLI%3EWR_x%20%E9%81%B8%E6%8A%9E%20%2F%20%E3%83%87%E3%83%BC%E3%82%BF%E5%B9%85%E3%81%AE%E4%B8%8D%E4%B8%80%E8%87%B4%20(%E5%AE%9F%E6%95%B0%20vs%20%E8%A4%87%E7%B4%A0%E6%95%B0%E3%80%8116%20%E3%83%93%E3%83%83%E3%83%88%20vs%20%E3%81%9D%E3%81%AE%E4%BB%96)%E3%80%82%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E6%95%B0%E3%81%8C%E5%A4%89%E5%8C%96%E3%81%99%E3%82%8B%E3%81%A8%E5%81%B6%E7%84%B6%E3%81%AB%E4%BF%AE%E6%AD%A3%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3CLI%3EkernelParList%20%E5%86%85%E3%81%AE%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E9%A0%86%E5%BA%8F%2F%E3%82%BF%E3%82%A4%E3%83%97%E3%81%AE%E6%B7%B7%E5%90%8C%20(ADDR%20%E3%81%A8%20VALUE)%20%E3%81%8C%E3%80%81%E7%89%B9%E5%AE%9A%E3%81%AE%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AB%E3%81%AE%E3%81%BF%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%9F%E3%83%A9%E3%83%BC%20%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%81%AB%E3%81%AF%E5%90%8C%E6%A7%98%E3%81%AE%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%20%E3%82%B7%E3%83%BC%E3%82%B1%E3%83%B3%E3%82%B9%E3%81%8C%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%E3%82%92%E3%82%B9%E3%83%AA%E3%83%83%E3%83%97%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AF%E7%B0%A1%E5%8D%98%E3%81%A7%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3CLI%3EWR%2024%E3%83%93%E3%83%83%E3%83%88%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%E3%82%A8%E3%83%83%E3%82%B8%E3%81%AF%E3%80%812%E5%80%8D%E3%81%AB%E3%81%99%E3%82%8B%E3%81%A8%E7%95%B0%E3%81%AA%E3%82%8B%E3%83%91%E3%83%83%E3%82%AD%E3%83%B3%E3%82%B0%2F%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%E3%81%A7%E6%B6%88%E3%81%88%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%94%E3%83%BC%E3%82%BF%E3%83%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E
