Hi NXP partner
We use MM9Z1_638 to measure isolation resistance , voltage and current sensor of battery pack.
Can we use CAN bus to update FW? If answer is yes, could you provide the sample code?
Br,
Mike
Solved! Go to Solution.
Hi Mike,
Unfortunately there is currently no CAN bootloader available for the MM9Z1_638.
Tomas
Hi Mike,
Tomas
