MMA690xKQ interface sample codes
2,585件の閲覧回数
jayarao
Hi any one share sample code of MMA690xKQ interface sample codes
3 返答(返信)
2,407件の閲覧回数
TomasVaverka
Hi Jaya,
The only example code I am aware of is part of the TWR_SENSOR_AUTO_FW package that can be downloaded from the following website:
Automotive Low-g Accelerometer Tower® Plug-In|NXP
Scroll down to the bottom of the page and download the TWR_SENSOR_AUTO_FW.zip file.
I hope it helps!
Tomas
2,407件の閲覧回数
jayarao
Hi Tomas
Thanks for the reply
I was tried with same example aswell
pelase find tehresponses attached
Always I am getting E6,BC,00...
2,407件の閲覧回数
jayarao
mcm_internal_get_srv_id_for_msg_id: *** msg_id: 600 | MIN: b00 | MAX: b10
mcm_internal_get_srv_id_for_msg_id: *** msg_id: 600 | MIN: 100 | MAX: 10c
mcm_internal_get_srv_id_for_msg_id: *** msg_id: 600 | MIN: 400 | MAX: 427
mcm_internal_get_srv_id_for_msg_id: *** msg_id: 600 | MIN: 300 | MAX: 316
mcm_internal_get_srv_id_for_msg_id: *** msg_id: 600 | MIN: 600 | MAX: 600
mcm_internal_get_srv_id_for_msg_id: found service_id iter:8
server_execute_sync: server_execute_sync Enter
server_execute_sync: user_handle:7, msg_id:600, req_c_struct:e190, req_c_struct_len:208, resp_c_struct:e3a0, resp_c_struct_len:1010
mcm_client_execute_command_sync_ex: mcm_client_execute_command_sync_ex SUCCESS EXITAT command sent:
AT#V24=2,1OK
rx_word-0xbc00
ptr_read[index].word-0xbc00
index - 13AT command sent:
AT#V24=2,0OK
register address:14message transmittedspi read message successfullSTATUS is 0xe6-0x00-0x00-0x00
register address:emessage transmittedspi read message successfullSTATUS is 0x00-0x00-0x00-0x00AT command sent:
AT#V24=2,1OK
rx_word-0xe600AT command sent:
AT#V24=2,0OK
register address:20message transmittedspi read message successfullSTATUS is 0xbc-0x00-0x00-0x00
register address:0message transmittedspi read message successfullSTATUS is 0x00-0x00-0x00-0x00AT command sent:
AT#V24=2,1OK
rx_word-0xbc00
index - 14AT command sent:
AT#V24=2,0OK
register address:10message transmittedspi read message successfullSTATUS is 0x00-0x00-0x00-0x00
register address:fmessage transmittedspi read message successfullSTATUS is 0xe6-0x00-0x00-0x00
AT command sent:
AT#V24=2,1OK
rx_word-0xe6AT command sent:
AT#V24=2,0OK
AT#V24=2,1OK
rx_word-0xbc00
index - 15AT command sent:
AT#V24=2,0OK
register address:10message transmittedspi read message successfullSTATUS is 0xe6-0x00-0x00-0x00AT command sent:
AT#V24=2,1OK
rx_word-0xe6e6AT command sent:
AT#V24=2,0OK
register address:20message transmittedspi read message successfullSTATUS is 0xe6-0x00-0x00-0x00
register address:0message transmittedspi read message successfullSTATUS is 0xff-0x00-0x00-0x00AT command sent:
AT#V24=2,1OK
rx_word-0xe6ff
ptr_read[index].word-0xe6ff
index - 16AT command sent:
AT#V24=2,0OK
register address:11message transmittedspi read message successfullSTATUS is 0xe6-0x00-0x00-0x00AT command sent:
AT#V24=2,1OK
AT#V24=2,0OK
AT#V24=2,1OK
rx_word-0xbc00
index - 17AT command sent:
AT#V24=2,0OK
register address:14message transmittedspi read message successfullSTATUS is 0x00-0x00-0x00-0x00
register address:20message transmittedspi read message successfullSTATUS is 0xbc-0x00-0x00-0x00AT command sent:
AT#V24=2,1OK
rx_word-0xbcAT command sent:
AT#V24=2,0OK
AT#V24=2,1OK
rx_word-0xe6ff
index - 18AT command sent:
AT#V24=2,0OK
register address:21message transmittedspi read message successfullSTATUS is 0xe6-0x00-0x00-0x00AT command sent:
AT#V24=2,1OK
AT#V24=2,0OK
AT#V24=2,1OK
rx_word-0xbc00
index - 19
AT command sent:
AT#V24=2,0OK
register address:22message transmittedspi read message successfullSTATUS is 0xff-0x00-0x00-0x00AT command sent:
AT#V24=2,1OK
rx_word-0xe6ffAT command sent:
AT#V24=2,0OK
register address:0message transmittedspi read message successfullSTATUS is 0xe6-0x00-0x00-0x00AT command sent:
AT#V24=2,1OK
rx_word-0xe6e6
ptr_read[index].word-0xe6e6
index - 20AT command sent:
AT#V24=2,0OK
register address:23message transmittedspi read message successfullSTATUS is 0xbc-0x00-0x00-0x00AT command sent:
AT#V24=2,1OK
rx_word-0xbc
AT command sent:
AT#V24=2,0OK
AT#V24=2,1OK
rx_word-0xe6e6
index - 21AT command sent:
AT#V24=2,0OK
register address:10message transmittedspi read message successfullSTATUS is 0xff-0x00-0x00-0x00
register address:24message transmittedspi read message successfullSTATUS is 0xbc-0x00-0x00-0x00AT command sent:
AT#V24=2,1OK
rx_word-0xffbcAT command sent:
AT#V24=2,0OK
AT#V24=2,1OK
rx_word-0xe6e6
index - 22
AT command sent:
AT#V24=2,0OK
register address:25message transmittedspi read message successfullSTATUS is 0xe6-0x00-0x00-0x00AT command sent:
AT#V24=2,1OK
rx_word-0xe6
AT command sent:
AT#V24=2,0OK
AT#V24=2,1OK
rx_word-0xbc00
index - 23AT command sent:
AT#V24=2,0OK
register address:26message transmittedspi read message successfullSTATUS is 0xe6-0x00-0x00-0x00AT command sent:
AT#V24=2,1OK
rx_word-0xe6e6
AT command sent:
AT#V24=2,0OK
AT#V24=2,1OK
rx_word-0xe6e6
index - 24AT command sent:
AT#V24=2,0OK
register address:27message transmittedspi read message successfullSTATUS is 0xbc-0x00-0x00-0x00AT command sent:
AT#V24=2,1OK
AT#V24=2,0OK
AT#V24=2,1OK
rx_word-0xbc00
index - 25
AT command sent:
AT#V24=2,0OK
AT#V24=2,1OK
rx_word-0x00AT command sent:
AT#V24=2,0OK
AT#V24=2,1OK
rx_word-0xe6ff
index - 26AT command sent:
AT#V24=2,0OK
register address:24message transmittedspi read message successfullSTATUS is 0xe6-0x00-0x00-0x00AT command sent:
AT#V24=2,1OK
rx_word-0xe6
XL AXIS - 230AT command sent:
AT#V24=2,0OK
AT#V24=2,1OK
rx_word-0xbc00AT command sent:
AT#V24=2,0OK
register address:25message transmittedspi read message successfullSTATUS is 0x00-0x00-0x00-0x00AT command sent:
AT#V24=2,1OK
rx_word-0xe600
XH AXIS - 58880AT command sent:
AT#V24=2,0OK
AT#V24=2,1OK
AT#V24=2,0OK
register address:26message transmittedspi read message successfullSTATUS is 0xbc-0x00-0x00-0x00AT command sent:
AT#V24=2,1OK
rx_word-0xbc
YL AXIS - 188AT command sent:
AT#V24=2,0OK
AT#V24=2,1OK
AT#V24=2,0OK
AT#V24=2,1OK
rx_word-0xbc
YH AXIS - 188AT command sent:
AT#V24=2,0OK
register address:20message transmittedspi read message successfullSTATUS is 0xff-0x00-0x00-0x00
AT#V24=2,1OK
rx_word-0xff00
X AXIS - 0
Y AXIS - 58880
X AXIS - 58880-230
Y AXIS - 188-188
mma6900->w_regs -  0
last_write -  0
X AXIS - 0
Y AXIS - 58880
X AXIS - 58880-230
Y AXIS - 188-188
%3CLINGO-SUB%20id%3D%22lingo-sub-815632%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMMA690xKQ%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%B3%E3%83%BC%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-815632%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81MMA690xKQ%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%8F%E3%82%8C%E3%82%8B%E4%BA%BA%E3%81%AF%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-815632%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E5%8A%A0%E9%80%9F%E5%BA%A6%E3%82%BB%E3%83%B3%E3%82%B5%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-815635%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MMA690xKQ%20interface%20sample%20codes%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-815635%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%88%E3%83%BC%E3%83%9E%E3%82%B9%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E7%A7%81%E3%82%82%E5%90%8C%E3%81%98%E4%BE%8B%E3%81%A7%E8%A9%A6%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%E5%9B%9E%E7%AD%94%E3%81%AF%E6%B7%BB%E4%BB%98%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3CP%3E%E5%B8%B8%E3%81%AB%20E6%E3%80%81BC%E3%80%8100%20%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99...%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-815634%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MMA690xKQ%20interface%20sample%20codes%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-815634%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Emcm_internal_get_srv_id_for_msg_id%3A%20***%20msg_id%3A%20600%20%7C%20%E6%9C%80%E5%B0%8F%3A%20b00%20%7C%20%E6%9C%80%E5%A4%A7%3A%20b10%3CBR%20%2F%3E%20mcm_internal_get_srv_id_for_msg_id%3A%20***%20msg_id%3A%20600%20%7C%20%E6%9C%80%E5%B0%8F%3A%20100%20%7C%20%E6%9C%80%E5%A4%A7%3A%2010c%3CBR%20%2F%3E%20mcm_internal_get_srv_id_for_msg_id%3A%20***%20msg_id%3A%20600%20%7C%20%E6%9C%80%E5%B0%8F%3A%20400%20%7C%20%E6%9C%80%E5%A4%A7%3A%20427%3CBR%20%2F%3E%20mcm_internal_get_srv_id_for_msg_id%3A%20***%20msg_id%3A%20600%20%7C%20%E6%9C%80%E5%B0%8F%3A%20300%20%7C%20%E6%9C%80%E5%A4%A7%3A%20316%3CBR%20%2F%3E%20mcm_internal_get_srv_id_for_msg_id%3A%20***%20msg_id%3A%20600%20%7C%20%E6%9C%80%E5%B0%8F%3A%20600%20%7C%20%E6%9C%80%E5%A4%A7%3A%20600%3CBR%20%2F%3E%20mcm_internal_get_srv_id_for_msg_id%3A%20service_id%20iter%3A8%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Eserver_execute_sync%3A%20server_execute_sync%20%E5%85%A5%E5%8A%9B%3CBR%20%2F%3Eserver_execute_sync%3A%20%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%83%8F%E3%83%B3%E3%83%89%E3%83%AB%3A7%E3%80%81%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8ID%3A600%E3%80%81%E8%A6%81%E6%B1%82c%E6%A7%8B%E9%80%A0%E4%BD%93%3Ae190%E3%80%81%E8%A6%81%E6%B1%82c%E6%A7%8B%E9%80%A0%E4%BD%93%E9%95%B7%3A208%E3%80%81%E5%BF%9C%E7%AD%94c%E6%A7%8B%E9%80%A0%E4%BD%93%3Ae3a0%E3%80%81%E5%BF%9C%E7%AD%94c%E6%A7%8B%E9%80%A0%E4%BD%93%E9%95%B7%3A1010%3CBR%20%2F%3E%20mcm_client_execute_command_sync_ex%3A%20mcm_client_execute_command_sync_ex%20SUCCESS%20EXITAT%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C1OK%3CBR%20%2F%3E%20rx_word-0xbc00%3CBR%20%2F%3E%20ptr_read%5B%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%5D.word-0xbc00%3CBR%20%2F%3E%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%20-%2013AT%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C0OK%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A14%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E9%80%81%E4%BF%A1%E3%80%81spi%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E6%88%90%E5%8A%9F%E3%80%81%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF0xe6-0x00-0x00-0x00%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3Ae%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9Fspi%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9FlSTATUS%E3%81%AF0x00-0x00-0x00-0x00AT%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C1OK%3CBR%20%2F%3E%20rx_word-0xe600AT%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C0OK%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E9%80%81%E4%BF%A1%E3%80%81spi%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E6%88%90%E5%8A%9F%E3%80%81%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF0xbc-0x00-0x00-0x00%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A0%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82spi%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF0x00-0x00-0x00-0x00AT%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C1OK%3CBR%20%2F%3E%20rx_word-0xbc00%3CBR%20%2F%3E%20ptr_read%5B%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%5D.word-0xbc00%3CBR%20%2F%3E%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%20-%2014AT%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C0OK%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A10%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E9%80%81%E4%BF%A1%E3%80%81spi%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E6%88%90%E5%8A%9F%E3%80%81%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF0x00-0x00-0x00-0x00%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3Afmessage%20submittedspi%20read%20message%20successfullSTATUS%20is%200xe6-0x00-0x00-0x00%3CBR%20%2F%3E%20AT%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C1OK%3CBR%20%2F%3E%20rx_word-0xe6AT%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C0OK%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E9%80%81%E4%BF%A1%E3%80%81spi%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E6%88%90%E5%8A%9F%E3%80%81%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF0xbc-0x00-0x00-0x00%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A0%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82spi%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF0x00-0x00-0x00-0x00AT%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C1OK%3CBR%20%2F%3E%20rx_word-0xbc00%3CBR%20%2F%3E%20ptr_read%5B%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%5D.word-0xbc00%3CBR%20%2F%3E%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%20-%2015AT%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C0OK%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A14%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E9%80%81%E4%BF%A1%E3%80%81spi%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E6%88%90%E5%8A%9F%E3%80%81%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF0xe6-0x00-0x00-0x00%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A10%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%20spi%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF0xe6-0x00-0x00-0x00AT%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C1OK%3CBR%20%2F%3E%20rx_word-0xe6e6AT%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C0OK%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E9%80%81%E4%BF%A1%E3%80%81spi%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E6%88%90%E5%8A%9F%E3%80%81%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF0xe6-0x00-0x00-0x00%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A0%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82spi%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF0xff-0x00-0x00-0x00AT%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C1OK%3CBR%20%2F%3E%20rx_word-0xe6ff%3CBR%20%2F%3E%20ptr_read%5B%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%5D.word-0xe6ff%3CBR%20%2F%3E%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%20-%2016AT%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C0OK%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A10%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E9%80%81%E4%BF%A1%E3%80%81spi%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E6%88%90%E5%8A%9F%E3%80%81%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF0x00-0x00-0x00-0x00%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A11%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%20spi%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF%200xe6-0x00-0x00-0x00AT%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C1OK%3CBR%20%2F%3E%20rx_word-0xe6AT%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C0OK%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E9%80%81%E4%BF%A1%E3%80%81spi%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E6%88%90%E5%8A%9F%E3%80%81%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF0xbc-0x00-0x00-0x00%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A0%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82spi%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF0x00-0x00-0x00-0x00AT%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C1OK%3CBR%20%2F%3E%20rx_word-0xbc00%3CBR%20%2F%3E%20ptr_read%5B%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%5D.word-0xbc00%3CBR%20%2F%3E%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%20-%2017AT%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C0OK%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A14%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E9%80%81%E4%BF%A1%E3%80%81spi%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E6%88%90%E5%8A%9F%E3%80%81%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF0x00-0x00-0x00-0x00%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A20%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%20spi%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF0xbc-0x00-0x00-0x00AT%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C1OK%3CBR%20%2F%3E%20rx_word-0xbcAT%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C0OK%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E9%80%81%E4%BF%A1%E3%80%81spi%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E6%88%90%E5%8A%9F%E3%80%81%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF0xe6-0x00-0x00-0x00%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A0%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82spi%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF0xff-0x00-0x00-0x00AT%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C1OK%3CBR%20%2F%3E%20rx_word-0xe6ff%3CBR%20%2F%3E%20ptr_read%5B%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%5D.word-0xe6ff%3CBR%20%2F%3E%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%20-%2018AT%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C0OK%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A10%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E9%80%81%E4%BF%A1%E3%80%81spi%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E6%88%90%E5%8A%9F%E3%80%81%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF0x00-0x00-0x00-0x00%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A21%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%20spi%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF%200xe6-0x00-0x00-0x00AT%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C1OK%3CBR%20%2F%3E%20rx_word-0xe6AT%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C0OK%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E9%80%81%E4%BF%A1%E3%80%81spi%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E6%88%90%E5%8A%9F%E3%80%81%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF0xbc-0x00-0x00-0x00%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A0%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82spi%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF0x00-0x00-0x00-0x00AT%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C1OK%3CBR%20%2F%3E%20rx_word-0xbc00%3CBR%20%2F%3E%20ptr_read%5B%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%5D.word-0xbc00%3CBR%20%2F%3E%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%20-%2019%3CBR%20%2F%3E%20AT%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C0OK%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A10%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E9%80%81%E4%BF%A1%E3%80%81spi%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E6%88%90%E5%8A%9F%E3%80%81%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF0xe6-0x00-0x00-0x00%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A22%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%20spi%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF%200xff-0x00-0x00-0x00AT%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C1OK%3CBR%20%2F%3E%20rx_word-0xe6ffAT%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C0OK%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E9%80%81%E4%BF%A1%E3%80%81spi%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E6%88%90%E5%8A%9F%E3%80%81%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF0xe6-0x00-0x00-0x00%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A0%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82spi%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF0xe6-0x00-0x00-0x00AT%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C1OK%3CBR%20%2F%3E%20rx_word-0xe6e6%3CBR%20%2F%3E%20ptr_read%5B%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%5D.word-0xe6e6%3CBR%20%2F%3E%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%20-%2020AT%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C0OK%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A14%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E9%80%81%E4%BF%A1%E3%80%81spi%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E6%88%90%E5%8A%9F%E3%80%81%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF0x00-0x00-0x00-0x00%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A23%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%20spi%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF%200xbc-0x00-0x00-0x00AT%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C1OK%3CBR%20%2F%3E%20rx_word-0xbc%3CBR%20%2F%3E%20AT%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C0OK%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E9%80%81%E4%BF%A1%E3%80%81spi%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E6%88%90%E5%8A%9F%E3%80%81%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF0xe6-0x00-0x00-0x00%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A0%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82spi%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF0xe6-0x00-0x00-0x00AT%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C1OK%3CBR%20%2F%3E%20rx_word-0xe6e6%3CBR%20%2F%3E%20ptr_read%5B%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%5D.word-0xe6e6%3CBR%20%2F%3E%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%20-%2021AT%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C0OK%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A10%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E9%80%81%E4%BF%A1%E3%80%81spi%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E6%88%90%E5%8A%9F%E3%80%81%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF0xff-0x00-0x00-0x00%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A24%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%20spi%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF%200xbc-0x00-0x00-0x00AT%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C1OK%3CBR%20%2F%3E%20rx_word-0xffbcAT%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C0OK%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E9%80%81%E4%BF%A1%E3%80%81spi%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E6%88%90%E5%8A%9F%E3%80%81%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF0xe6-0x00-0x00-0x00%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A0%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82spi%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF0xe6-0x00-0x00-0x00AT%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C1OK%3CBR%20%2F%3E%20rx_word-0xe6e6%3CBR%20%2F%3E%20ptr_read%5B%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%5D.word-0xe6e6%3CBR%20%2F%3E%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%20-%2022%3CBR%20%2F%3E%20AT%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C0OK%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A14%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E9%80%81%E4%BF%A1%E3%80%81spi%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E6%88%90%E5%8A%9F%E3%80%81%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF0x00-0x00-0x00-0x00%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A25%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82spi%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF0xe6-0x00-0x00-0x00AT%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C1OK%3CBR%20%2F%3E%20rx_word-0xe6%3CBR%20%2F%3E%20AT%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C0OK%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E9%80%81%E4%BF%A1%E3%80%81spi%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E6%88%90%E5%8A%9F%E3%80%81%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF0xbc-0x00-0x00-0x00%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A0%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82spi%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF0x00-0x00-0x00-0x00AT%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C1OK%3CBR%20%2F%3E%20rx_word-0xbc00%3CBR%20%2F%3E%20ptr_read%5B%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%5D.word-0xbc00%3CBR%20%2F%3E%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%20-%2023AT%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C0OK%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A14%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E9%80%81%E4%BF%A1%E3%80%81spi%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E6%88%90%E5%8A%9F%E3%80%81%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF0xe6-0x00-0x00-0x00%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A26%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%20spi%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF0xe6-0x00-0x00-0x00AT%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C1OK%3CBR%20%2F%3E%20rx_word-0xe6e6%3CBR%20%2F%3E%20AT%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C0OK%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E9%80%81%E4%BF%A1%E3%80%81spi%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E6%88%90%E5%8A%9F%E3%80%81%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF0xe6-0x00-0x00-0x00%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A0%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82spi%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF0xe6-0x00-0x00-0x00AT%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C1OK%3CBR%20%2F%3E%20rx_word-0xe6e6%3CBR%20%2F%3E%20ptr_read%5B%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%5D.word-0xe6e6%3CBR%20%2F%3E%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%20-%2024AT%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C0OK%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A10%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E9%80%81%E4%BF%A1%E3%80%81spi%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E6%88%90%E5%8A%9F%E3%80%81%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF0x00-0x00-0x00-0x00%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A27%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%20spi%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF%200xbc-0x00-0x00-0x00AT%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C1OK%3CBR%20%2F%3E%20rx_word-0xbcAT%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C0OK%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E9%80%81%E4%BF%A1%E3%80%81spi%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E6%88%90%E5%8A%9F%E3%80%81%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF0xbc-0x00-0x00-0x00%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A0%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82spi%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF0x00-0x00-0x00-0x00AT%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C1OK%3CBR%20%2F%3E%20rx_word-0xbc00%3CBR%20%2F%3E%20ptr_read%5B%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%5D.word-0xbc00%3CBR%20%2F%3E%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%20-%2025%3CBR%20%2F%3E%20AT%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C0OK%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A10%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E9%80%81%E4%BF%A1%E3%80%81spi%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E6%88%90%E5%8A%9F%E3%80%81%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF0x00-0x00-0x00-0x00%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A0%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82spi%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF0x00-0x00-0x00-0x00AT%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C1OK%3CBR%20%2F%3E%20rx_word-0x00AT%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C0OK%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E9%80%81%E4%BF%A1%E3%80%81spi%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E6%88%90%E5%8A%9F%E3%80%81%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF0xe6-0x00-0x00-0x00%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A0%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82spi%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF0xff-0x00-0x00-0x00AT%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C1OK%3CBR%20%2F%3E%20rx_word-0xe6ff%3CBR%20%2F%3E%20ptr_read%5B%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%5D.word-0xe6ff%3CBR%20%2F%3E%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%20-%2026AT%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C0OK%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A10%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E9%80%81%E4%BF%A1%E3%80%81spi%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E6%88%90%E5%8A%9F%E3%80%81%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF0x00-0x00-0x00-0x00%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A24%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%20spi%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF%200xe6-0x00-0x00-0x00AT%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C1OK%3CBR%20%2F%3E%20rx_word-0xe6%3CBR%20%2F%3E%20XL%20AXIS%20-%20230AT%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C0OK%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E9%80%81%E4%BF%A1%E3%80%81spi%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E6%88%90%E5%8A%9F%E3%80%81%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF0xbc-0x00-0x00-0x00%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A0%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82spi%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF0x00-0x00-0x00-0x00AT%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C1OK%3CBR%20%2F%3E%20rx_word-0xbc00AT%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C0OK%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A14%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E9%80%81%E4%BF%A1%E3%80%81spi%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E6%88%90%E5%8A%9F%E3%80%81%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF0xe6-0x00-0x00-0x00%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A25%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82spi%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF0x00-0x00-0x00-0x00AT%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C1OK%3CBR%20%2F%3E%20rx_word-0xe600%3CBR%20%2F%3E%20XH%20AXIS%20-%2058880AT%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C0OK%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E9%80%81%E4%BF%A1%E3%80%81spi%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E6%88%90%E5%8A%9F%E3%80%81%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF0xbc-0x00-0x00-0x00%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A0%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82spi%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF0x00-0x00-0x00-0x00AT%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C1OK%3CBR%20%2F%3E%20rx_word-0xbc00AT%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C0OK%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A14%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E9%80%81%E4%BF%A1%E3%80%81spi%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E6%88%90%E5%8A%9F%E3%80%81%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF0x00-0x00-0x00-0x00%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A26%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%20spi%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF%200xbc-0x00-0x00-0x00AT%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C1OK%3CBR%20%2F%3E%20rx_word-0xbc%3CBR%20%2F%3E%20YL%20AXIS%20-%20188AT%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C0OK%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E9%80%81%E4%BF%A1%E3%80%81spi%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E6%88%90%E5%8A%9F%E3%80%81%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF0xe6-0x00-0x00-0x00%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A0%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82spi%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF0xe6-0x00-0x00-0x00AT%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C1OK%3CBR%20%2F%3E%20rx_word-0xe6e6AT%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C0OK%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A10%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E9%80%81%E4%BF%A1%E3%80%81spi%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E6%88%90%E5%8A%9F%E3%80%81%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF0x00-0x00-0x00-0x00%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A27%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%20spi%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF%200xbc-0x00-0x00-0x00AT%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C1OK%3CBR%20%2F%3E%20rx_word-0xbc%3CBR%20%2F%3E%20YH%20AXIS%20-%20188AT%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C0OK%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E9%80%81%E4%BF%A1%E3%80%81spi%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E6%88%90%E5%8A%9F%E3%80%81%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF0xff-0x00-0x00-0x00%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A0%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82spi%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF0x00-0x00-0x00-0x00AT%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20AT%23V24%3D2%2C1OK%3CBR%20%2F%3E%20rx_word-0xff00%3CBR%20%2F%3E%20X%E8%BB%B8%20-%200%3CBR%20%2F%3E%20Y%E8%BB%B8%20-%2058880%3CBR%20%2F%3E%20X%E8%BB%B8%20-%2058880-230%3CBR%20%2F%3E%20Y%E8%BB%B8%20-%20188-188%3CBR%20%2F%3E%20mma6900-%26gt%3Bw_regs%20-%200%3CBR%20%2F%3E%E6%9C%80%E7%B5%82%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%20-%200%3CBR%20%2F%3E%20X%E8%BB%B8%20-%200%3CBR%20%2F%3E%20Y%E8%BB%B8%20-%2058880%3CBR%20%2F%3E%20X%E8%BB%B8%20-%2058880-230%3CBR%20%2F%3E%20Y%E8%BB%B8%20-%20188-188%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-815633%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MMA690xKQ%20interface%20sample%20codes%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-815633%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%82%B8%E3%83%A3%E3%83%A4%E3%81%95%E3%82%93%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%E7%A7%81%E3%81%8C%E7%9F%A5%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E5%94%AF%E4%B8%80%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%20%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%20Web%20%E3%82%B5%E3%82%A4%E3%83%88%E3%81%8B%E3%82%89%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%A7%E3%81%8D%E3%82%8B%20TWR_SENSOR_AUTO_FW%20%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%AE%E4%B8%80%E9%83%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fsupport%2Fdeveloper-resources%2Fevaluation-and-development-boards%2Ftower-development-boards%2Fplug-in-modules%2Fautomotive-low-g-accelerometer-tower-system-plug-in%3ATWRPI-MMA6900%3Ftab%3DDesign_Tools_Tab%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fsupport%2Fdeveloper-resources%2Fevaluation-and-development-boards%2Ftower-development-boards%2Fplug-in-modules%2Fautomotive-low-g-accelerometer-tower-system-plug-in%3ATWRPI-MMA6900%3Ftab%3DDesign_Tools_Tab%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E3%82%AA%E3%83%BC%E3%83%88%E3%83%A2%E3%83%BC%E3%83%86%E3%82%A3%E3%83%96%E4%BD%8EG%E5%8A%A0%E9%80%9F%E5%BA%A6%E3%82%BB%E3%83%B3%E3%82%B5%20Tower%20%C2%AE%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%7CNXP%3C%2FA%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%E3%83%9A%E3%83%BC%E3%82%B8%E3%81%AE%E4%B8%80%E7%95%AA%E4%B8%8B%E3%81%BE%E3%81%A7%E3%82%B9%E3%82%AF%E3%83%AD%E3%83%BC%E3%83%AB%E3%81%97%E3%81%A6%E3%80%81TWR_SENSOR_AUTO_FW.zip%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%E3%81%8A%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A6%E3%82%8C%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%EF%BC%81%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%E3%83%88%E3%83%BC%E3%83%9E%E3%82%B9%3C%2FP%3E%3C%2FLINGO-BODY%3E
