i.MX Processors Knowledge Base
Discussions
Sort by:
We are pleased to announce that Config Tools for i.MX 26.09 are now available. Downloads & links To download the installer for all platforms, please login to our download site via:  https://www.nxp.com/design/designs/config-tools-for-i-mx-applications-processors:CONFIG-TOOLS-IMX Please refer to  Documentation  for installation and quick start guides. For further information about DDR config and validation, please go to this  blog post. Release Notes Full details on the release (features, known issues...) Version 26.09 Framework Added support for downloading all boards associated with a processor when downloading the processor. DDR tool Added support for i.MX 937 Added DDR3 support for i.MX 8MP FRDM board Added support for i.MX93W FRDM and EVK boards at 3600 MT/s Enabled PMIC PF9453 support for i.MX 91 Minor improvements, enhancements, and bug fixes SerDes tool Added support for i.MX 952 System Manager Multiple validation ID issues are resolved. DDR tool – NXP-validated memory configurations for multiple vendors is available System Manager – extended CLI support for a headless setting
View full article
Enabling a 2-Channel CAN HAT (MCP2515) on the NXP i.MX93 FRDM Board   This article documents the process of adding hardware support for a 2-Channel CAN HAT from WaveShare using dual Microchip MCP2515 controllers over SPI on the NXP i.MX93 FRDM evaluation board. By default, the board exposes native FlexCAN interfaces, but utilizing a popular Raspberry Pi-compatible CAN HAT requires customizing the Linux device tree and kernel configuration.   Prerequisites   Hardware: NXP i.MX93 FRDM board, 2-Channel CAN HAT. Software: NXP Linux BSP (Tested in 6.18.y). Toolchain: Toolchain obtained from Yocto (Refer to the 4.5.12 How to build U-Boot and Kernel in standalone environment from i.MX Linux User's Guide).   Step 1: Modify the Device Tree   We need to edit the main board device tree file  arch/arm64/boot/dts/freescale/imx93-11x11-frdm.dts  to configure the SPI master, add the dual MCP2515 nodes, assign interrupt pins, and disable conflicting native interfaces. The key changes:   Power Regulators: Ensured the expansion connectors ( VEXP_3V3 and VEXP_5V ) correctly pull up and preserve state using pinctrl-assert-gpios . Fixed Clock: Defined an external 16MHz clock element required by the MCP2515 crystal oscillators. FlexCAN Deactivation: Disabled conflicting native flexcan2 nodes sharing pins. LPSPI3 Configuration: Replaced the default spidev dummy node with two microchip,mcp2515 nodes, adding two distinct Chip Select (CS) pins ( GPIO2_IO08 and GPIO2_IO07 ) and mapping the respective hardware interrupts ( GPIO2_IO23 and GPIO2_IO25 ). Device Tree Git Diff: diff --git a/arch/arm64/boot/dts/freescale/imx93-11x11-frdm.dts b/arch/arm64/boot/dts/freescale/imx93-11x11-frdm.dts index 18afe964e020..7b3af73f144f 100644 --- a/arch/arm64/boot/dts/freescale/imx93-11x11-frdm.dts +++ b/arch/arm64/boot/dts/freescale/imx93-11x11-frdm.dts @@ -134,6 +134,7 @@ reg_vexp_3v3: regulator-vexp-3v3 { compatible = "regulator-fixed"; regulator-name = "VEXP_3V3"; gpio = <&pcal6524 2 GPIO_ACTIVE_HIGH>; + pinctrl-assert-gpios = <&pcal6524 2 GPIO_ACTIVE_HIGH>; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; enable-active-high; @@ -144,6 +145,7 @@ reg_vexp_5v: regulator-vexp-5v { compatible = "regulator-fixed"; regulator-name = "VEXP_5V"; gpio = <&pcal6524 8 GPIO_ACTIVE_HIGH>; + pinctrl-assert-gpios = <&pcal6524 8 GPIO_ACTIVE_HIGH>; regulator-min-microvolt = <5000000>; regulator-max-microvolt = <5000000>; enable-active-high; @@ -269,6 +271,15 @@ K3: user_btn2 { interrupts = <6 IRQ_TYPE_EDGE_FALLING>; }; }; + + clocks { + clk16m: clk16m { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <16000000>; + clock-output-names = "clk16m"; + }; + }; }; &adc1 { @@ -292,7 +303,7 @@ &flexcan2 { pinctrl-0 = <&pinctrl_flexcan2>; pinctrl-1 = <&pinctrl_flexcan2_sleep>; xceiver-supply = <&reg_can2_stby>; - status = "okay"; + status = "disabled"; }; &mu1 { @@ -620,15 +631,29 @@ typec1_dr_sw: endpoint { &lpspi3 { pinctrl-names = "default"; pinctrl-0 = <&pinctrl_lpspi3>; - cs-gpios = <&gpio2 8 GPIO_ACTIVE_LOW>; - pinctrl-assert-gpios = <&pcal6408 0 GPIO_ACTIVE_HIGH>; + cs-gpios = <&gpio2 8 GPIO_ACTIVE_LOW>, <&gpio2 7 GPIO_ACTIVE_LOW>; + pinctrl-assert-gpios = <&pcal6408 0 GPIO_ACTIVE_LOW>; status = "okay"; - spidev0: spi@0 { + can0: can@0 { + compatible = "microchip,mcp2515"; reg = <0>; - compatible = "lwn,bk4"; - spi-max-frequency = <1000000>; + clocks = <&clk16m>; + interrupt-parent = <&gpio2>; + interrupts = <23 IRQ_TYPE_LEVEL_LOW>; + spi-max-frequency = <10000000>; }; + + can1: can@1 { + compatible = "microchip,mcp2515"; + reg = <1>; + clocks = <&clk16m>; + interrupt-parent = <&gpio2>; + interrupts = <25 IRQ_TYPE_LEVEL_LOW>; + spi-max-frequency = <10000000>; + }; + + }; &lpuart1 { /* console */ @@ -894,9 +919,12 @@ MX93_PAD_GPIO_IO29__LPI2C3_SCL 0x40000b9e pinctrl_lpspi3: lpspi3grp { fsl,pins = < MX93_PAD_GPIO_IO08__GPIO2_IO08 0x39e + MX93_PAD_GPIO_IO07__GPIO2_IO07 0x39e MX93_PAD_GPIO_IO09__LPSPI3_SIN 0x39e MX93_PAD_GPIO_IO10__LPSPI3_SOUT 0x39e MX93_PAD_GPIO_IO11__LPSPI3_SCK 0x39e + MX93_PAD_GPIO_IO23__GPIO2_IO23 0x39e + MX93_PAD_GPIO_IO25__GPIO2_IO25 0x39e >; };   After modifying the file, compile your device tree blobs (.dtb) and deploy them to your target boot partition. You can refer to the below post to know the process: How to compile Linux Kernel Image and device tree using Yocto SDK.   Step 2: Enable Kernel Driver Support   The MCP251x driver must be enabled within the Linux kernel configuration framework. Run the configuration tool: user@host:~/linux-imx$ make menuconfig   Navigate through the menu to enable the driver either statically ( [*] ) or as a module ( [M] 😞 [*] Networking support <*> CAN bus subsystem support <*> Raw CAN Protocol (raw access with CAN-ID filtering)   <*> Broadcast Manager CAN Protocol (with content filtering) <*> CAN Gateway/Router (with netlink configuration) And: Device Drivers [*] Network device support <*> CAN Device Drivers CAN SPI interfaces <*> Microchip MCP251x and MCP25625 SPI CAN controllers <*> Microchip MCP251xFD SPI CAN controllers   Save your configuration and compile your kernel/modules.   Step 3: Initialize and Test Interfaces   Once the board boots with the new device tree and kernel, you should see two new network interfaces listed under ip link show ( can0 and can1 ).   Now, you can setup the CAN interfaces: $ sudo ip link set can0 up type can bitrate 1000000 $ sudo ip link set can1 up type can bitrate 1000000 $ sudo ifconfig can0 txqueuelen 65536 $ sudo ifconfig can1 txqueuelen 65536   Connect the HAT in loopback:     From Interface can0: candump can0   From interface can1: cansend can1 000#11.22.33.44         Hope this can be helpful.   Best regards, Salas.
View full article
The purpose of this document is to provide extended guidance for the selection of compatible LPDDR4/4X memory devices that are supported by the i.MX 93 series of processors. In all cases, it is strongly recommended to follow the DRAM layout guidelines outlined in the NXP Hardware Developer's Guides for the specific SoCs. The i.MX 93 series of processors supports different packages, and each have their own maximum supported LPDDR4/4x data rates. Please refer to the respective datasheets. Memory devices with binary densities (e.g., 1 GB, 2 GB, 4 GB) are preferred because they simplify memory management by aligning with system addressing schemes and reducing software complexity. NOTE: Some of the LPDDR4/4X devices may not support operation at low speeds and in addition, DQ ODT may not be active, which can impact signal integrity at these speeds. If low-speed operation is planned in the use case, please consult with the memory vendor about the configuration aspects and possible customization of the memory device so correct functionality is ensured. LPDDR4/4X - Maximum Supported Densities SoC Max Data bus width Maximum density Assumed memory organization Notes i.MX 93 (i.MX 93xx) 16-bit 16 Gb / (2 GB) single rank, single channel device with 17-row addresses (R0 - R16) 1, 2, 3   LPDDR4/4X - List of Validated Memories The validation process is an ongoing effort - regular updates of the table are expected. SoC Density Memory Vendor Validated Memory Part# Notes i.MX 93 16 Gb/ (2 GB) Micron LPDDR4/4x: MT53E1G16D1FW-046 AAT:A  (Z32N) MT53E1G16D1ZW-046 AAT:C (Z42N) 7   4, 8 8 Gb/ (1 GB) Micron LPDDR4/4x: MT53D512M16D1DS-046 AAT (Z11M) 4, 10 16 Gb/ (2 GB) Micron LPDDR4/4x: MT53E1G32D2FW-046 AUT:B (Z42M) 4, 5, 10 8 Gb/ (1 GB) Nanya LPDDR4: NT6AN512M16AV-J1I LPDDR4x: NT6AP512M16BV-J1I 4, 8 4 Gb/ (512 MB) Nanya LPDDR4x: NT6AP256M16AV  4, 8 16 Gb/ (2 GB) Kingston LPDDR4: D1611PM3BDGUI-U 4, 8 16 Gb/ (2 GB) Kingston LPDDR4: C1612PC2WDGTKR-U  7, 9 4 Gb/ (512 MB) ISSI LPDDR4: IS43LQ16256B-062BLI 4, 8 2 Gb / (256 MB) ISSI LPDDR4: IS43LQ16128A-062BSLI 4, 6, 8   8 Gb/ (1 GB) CXMT LPDDR4/4x: CXDB4CBAM-EA-M 4, 9 16 Gb/ (2 GB) JSC LPDDR4x: JSL4BAG167ZAMF  4, 8 8 Gb/ (1 GB) JSC LPDDR4x: JSL4B8G168ZAMF-05x  4, 8 4 Gb/ (512 MB) JSC LPDDR4x: JSL4A4G168ZAMF-05 4, 8 2 Gb / (256 MB) Winbond  LPDDR4x: W66BQ6NBHAGJ 4, 6, 8 8 Gb / (1 GB) IM (Intelligent Memory) LPDDR4x: IM8G16L4JCB-046I 4, 11 16 Gb / (2 GB) IM (Intelligent Memory) LPDDR4/4x: IMAG16L4KBBG 4, 8 4 Gb / (512 MB) Samsung LPDDR4: K4F4E164HD-THCL 4, 8 8Gb / (1 GB) AM (Alliance Memory) LPDDR4X: AS4C512M16MD4V-053BIN 4, 8 4 Gb / (512 MB) ISSI LPDDR4/4X: IS43LQ16256B-053BLI 4, 8 8 Gb / (1 GB) ISSI LPDDR4/4X: IS46LQ16512B-046BLA2 4, 8 32Gb / (4GB) 16 Gb / (2Gb) usable by i.MX 93 ISSI LPDDR4/4X: IS46LQ32K01B-046BLI 4, 8   Note 1: The numbers are based purely on the IP documentation for the DDR Controller and the DDR PHY, on the settings of the implementation parameters chosen for their integration into the SoC, SoC reference manual and on the JEDEC standards JESD209-4B/JESD209-4-1 (LPDDR4/4X). Therefore, they are not backed by validation, unless said otherwise and there is no guarantee that an SoC with the specific density and/or desired internal organization is offered by the memory vendors. Should the customers choose to use the maximum density and assume it in the intended use case, they do it at their own risk. Note 2: Byte-mode LPDDR4/4X devices (x16 channel internally split between two dies, x8 each) of any density are not supported therefore, the numbers are applicable only to devices with x16 internal organization (referred to as "standard" in the JEDEC specification). Note 3: The SoC also supports dual rank single channel devices therefore, 16Gb/2GB density can be also achieved by using a dual rank single channel device with 16-row addresses (R0 - R15). Note 4: The memory part number did not undergo full JEDEC verification however, it passed all functional testing items. Note 5: This is a dual channel x32 device. Since i.MX93 only supports 16-bit LPDDR4/X data bus, it can only interface with one of the channels and therefore, utilize only half of the device's density. As indicated in the table - the device has 32Gb/4GB density however, only 16Gb/2GB can be used. There is no functional problem with using only one channel of a dual channel device as the channels are independent in LPDDR4/4X.  Note 6: This is a new JEDEC 100 ball package, half the size of the standard 200 ball package. This 100 ball package has the same performance and functionality as the 200 ball package, and has the added advantage of being smaller and cheaper than the standard package. Note 7: This device has been EoLed by the manufacturer and has been updated by a new memory part number  Note 8: Part is active. Reviewed Q3 2026 Note 9: Part is obsolete. Note 10: This device will be EoLed in Q2 24 by the manufacturer and will not be updated by a new memory part number Note 11: DQ eye marginalities were identified during TSA analysis. vTSA and stability testing did not identify any issues.
View full article
lspci output on iMX95EVK as PCIe RC Please take a good look at the snippet above. It is taken from the console of iMX95 after executing 'lspci' on a specific PCIe device[iMX8MM as PCIe EP] that gets enumerated as BDF[Bus Device Function] 01:00.0. This blog attempts to debunk the mystery revolving around the "Memory at " info of the lspci output. We will discuss what this address is, why it is used and its relevance in the PCIe world. This blog will focus on the following agendas: - 1. PCIe parent and child relationship in Linux Device Tree 2. What is CPU and PCIe address space and the need for address space translation?  3. Assigning resources to a PCIe device in Linux 4. How is address space translation carried out in Linux PCI Subsystem?   PCIe parent and child relationship in Linux Device Tree In the Linux device tree, PCIe parent and child relationship defines how PCIe Root Complex and Endpoints are positioned in the system. A PCIe parent node in the device tree represents a PCIe controller (Root Complex / Host-Bridge). Taking reference from a PCIe node present in the device tree source of imx95: -   pcie@4c300000 {                         compatible = "fsl,imx95-pcie";                         reg = <0x00 0x4c300000 0x00 0x10000 0x00 0x4c360000 0x00 0x20000 0x00 0x60100000 0x00 0xfe00000>;                         reg-names = "dbi\0atu\0config";                         #address-cells = <0x03>   …  }   pcie@4c300000 represents a Designware PCIe controller Root Complex which is a parent to the devices/bridge that will be connected to it. -- 'compatible' property identifies the specific PCIe controller. Its corresponding driver resides in drivers/pci/controller/dwc/pci-imx6.c -- 'reg' property specifies the memory mapped registers of the PCIe controller. Child nodes under PCIe RC represent devices on the PCIe bus. They can be fixed function devices like Wi-fi, Ethernet, NVMe or they can be PCIe bridges which further can have devices connected to it. Taking reference from 'arch/arm64/boot/dts/freescale/imx95.dtsi'   pcie_4ca00000: pcie@4ca00000 {                         compatible = "pci-host-ecam-generic";                         reg = <0x0 0x4ca00000 0x0 0x100000>;                         /* Must be 3. */              …              …              enetc_port0: ethernet@0,0 {                                 compatible = "fsl,imx95-enetc";                                 reg = <0x000000 0 0 0 0>;                                 clocks = <&scmi_clk IMX95_CLK_ENET>,                                          <&scmi_clk IMX95_CLK_ENETREF>;                                 clock-names = "ipg_clk", "enet_ref_clk";                                 nvmem-cells = <&eth_mac0>;                                 nvmem-cell-names = "mac-address";                                 status = "disabled";                         }; }   ethernet@0,0 is a PCIe device at bus 0, device 0, function 0. It is a child of PCIe RC which is memory mapped at 0x4ca00000   These child devices/bridges can either be dynamically discovered using PCI enumeration or they can be statically described in a device tree as seen in the device-tree snippet above in which "ethernet@0,0" entry statically tells the RC that the ethernet child device is connected to it. These child nodes are nested within a PCI parent node of the device tree as seen in the above example.   What is CPU and PCIe address space and the need for address space translation ? CPU address space is the system's physical memory map as seen by the processor. Example of CPU Physical Address Space viewed by Cortex-A55 on iMX95:-   Start address      End address    Module 0x48000000       0x4812FFFF    GIC Programming registers 0x4AA00000      0x4AAFFFFF    Neutron SRAM 0x4AC10000      0x4AC1FFFF    Camera domain block control 0x4E080000       0x4E08FFFF    DDR Controller This address space is kind of a global system view which is managed by system firmware/OS. These addresses are fixed by hardware-design. On the other hand, PCIe address space is local to PCI bus, managed by PCIe subsystem. The  addresses in this space are dynamically assigned. An example of PCIe address space that could look like the following:- 0x00000000   -    0x0FFFFFFF 0x10000000   -    0x1FFFFFFF 0x20000000   -    0x2FFFFFFF It is evident from the above explanation that CPU and PCIe address space operate in a separate and independent address domains. So the CPU cannot access the space of PCIe device unless a translation mechanism is in place. In one of the upcoming sections we will get to that as well but please spare a few minutes and ponder the question below:- Question : Why do you need separate address spaces for CPU and PCIe? Answer : One of the major reasons is modularity. We have separate spaces so that PCIe devices can be designed independently of the CPU architecture. Same card will work in different system. It will always have the flexibility of CPU remapping the PCIe space as and when needed. Also, different address spaces prevent devices to access arbitrary system memory. Based on the discussion in this section, it is evident that the PCIe address space is inherently different from the CPU address space and truth be told- it has its advantages. Therefore we need an entity to translate to/fro these address spaces. Here comes 'iATU' - Internal Address Translation Unit. On iMX SOCs, these hardware units are responsible for carrying out the address translation. These units are a part of Synopsys DesignWare PCIe Controller, providing programmable address translation windows for inbound and outbound transactions. For the readers who are uninitiated on the inbound and outbound transactions in pcie, please spare some time go through this technical blog - Understanding PCIe Outbound/Inbound windows with a use-case - NXP Community Note: - Address translation simply ensures that the CPU can access a PCIe device's memory and vice-versa.   Up until here, the readers must have got a basic picture of PCIe Address Translation. Before jumping into the nitty-gritty of this translation in the Linux PCI subsystem, let's discuss how the resources are assigned to a PCIe device.   Assigning resources to a PCIe device in Linux PCIe devices do not have a direct CPU instruction interface so they communicate through memory-mapped regions. Devices need memory for DMA operations or for MSI/MSIX interrupts. Different devices have different needs, so resources in PCIe could be MMIO where device registers are mapped or memory regions needed for DMA transfer. In linux, pci_assign_resource function of PCI subsystem is responsible for assigning IO and memory resources to the PCIe devices during system initialisation after PCIe devices are enumerated. It is called for all the devices on a PCI bus and based on the PCI devices' resource requirement, it assigns them. But how does the PCI subsystem in linux figure out what resources does the PCIe devices need ? - Every PCIe device has a configuration space defined by the PCIe specification. This includes   BAR[Base Address Registers] - To indicate what type of resource[IO/Mem] does  the device needs and the size of resource. Capabilities - To broadcast the device capabilities such as MSI Interrupts, ASPM low power states etc. Reading the BARs from the PCIe device will tell us what kind and size of the resources are needed by the device. // To determine the size of resource from the BAR of PCIe device:- Step-1: Write all 1's to the target BAR register. Step-2: Read back the value and clear the lower 4 bits (for a memory BAR) or 2 bits (for an I/O BAR), as these are status bits, not part of the size calculation Step-3 Perform Bitwise NOT on the value and add 1 to it. Step-4: The returned value indicates the size. Taking an example to understand this:- Let's assume that after reading back the value in Step-2 above, the BAR returns 0xFFFFF000. The lower 4 bits are already cleared. Step-3  we perform bitwise NOT on the value -> ~(0xFFFFF000) = 0x00000FFF Adding 1 to it : 0x00000FFF + 1 = 0x00001000 The obtained value 0x1000 = 4096 bytes indicates the size, meaning the BAR requires a 4KB memory region. // To determine the type of resource from the BAR of PCIe device:-   A Base Address Register (BAR) in PCI configuration space: Bit 0 → Resource type: 1 = I/O space 0 = Memory space For memory BARs: 00 = 32-bit 10 = 64-bit Bits 1–2 → Addressing type: Bit 3 → Prefetchable flag   Interpreting the value 0xFFFFF000, we get:-   Bit 0 = 0 → Memory space Bits 1–2 = 00 → 32-bit address Bit 3 = 0 → Prefetchable Upper bits → Base address (after masking)   pci_read_bases [drivers/pci/probe.c] in linux PCI subsystem is responsible to figure out the BAR memory size and type requirement during device enumeration. Needless to say, the above sequence of writing to the Endpoint's BAR and identifying the size and type of resource is executed on the PCIe RC. We have the following setup :- iMX95 <------> iMX8MM [RC]                     [EP] After PCIe RC has the size of the BAR that is required, the pci_assign_resource function allocates a memory range and then sets up translation from this memory range to the PCIe address space. we started this blog with a snippet, that shows the following lspci log:-   Referring to the above, please note that the RC driver has allocated: - 0x910100000 - 0x910110000 as the non-prefetchable memory address range, size=64KB The above memory address range is in the PCIe 1 Outbound space memory mapped on iMX95 SoC: -   The range 0x910100000 - 0x910110000 will be mapped to the PCIe address space of the End-point. This essentially means that if the cpu generates any address in between this range [inclusive of start and end-address], a PCIe TLP will be sent by the PCIe controller on the RC to the End-point on the bus. It could be a read or write to the memory of Endpoint. The address to write/read would be decided based on the address space translation. We shall discuss in-detail how this translation is exercised in the linux kernel in the next section.   How is address space translation carried out in Linux PCI Subsystem?   We start with some important questions: - Where is the range 0x910100000 - 0x910110000 specified ? How does the kernel know that it has to map the PCIe 1 Outbound space and not PCIe2 Outbound space or any other address space for that matter? -- Like all good things in Linux, this also starts with a 'device tree binary'. A dtb is passed by Uboot to the kernel so that it could get the hardware description of our board. Since we are using Torradex 's Verdin iMX95 EVK Board as Root Complex, this is the dtb that we are using - imx95-19x19-verdin-adv7535.dtb I will be attaching a working dtb with this blog so that the readers can use it if needed. This dtb includes - arch/arm64/boot/dts/freescale/imx95.dtsi Let's have a look at a particular pcie node of interest: -   'ranges' property is the answer to the questions that were asked in this section earlier.  - This property defines the address translation rules between the parent's address space and the child PCI address space.   Note:- This blog focuses only on 'ranges' property since it is relevant to our discussion. So the readers are advised to look elsewhere if they want to understand other device-tree properties of the PCIe node.  Let's decode the ranges property : It has the following format:- <PCI address><CPU address> <PCI size>      3 cells               2 cells             2 cells             So one entry will have 7 cells. In our dtsi we have 2 entries. 1st is for IO space translation and the 2nd is for Mem space translation. Referring to the second entry  :-   0x82000000 0x0 0x10000000 0x9 0x10000000 0 0x10000000 |------PCI address---------------| |-CPU address-| |---PCI size---|   The above gives us the following info: - MEM Space prefetchable <   0x82000000 0x00 0x10000000   // PCIe address: 0x10000000   0x09 0x10000000              // CPU/system address: 0x910000000   0x00 0x10000000              // Size: 256MB >;   0x82000000 = 1000 0010 0000 0000 0000 0000 0000 0000   Bits 31–30 (10) → Configuration space type: This indicates memory space. Bit 29 (0) → Non-relocatable Bit 28 (0) → Non-prefetchable  (0 means non-prefetchable) Bits 27–24 (0010) → Address space type = Memory So, 0x82000000 means: PCI memory space Non-prefetchable 32-bit address space   Note:- For those of you wondering why lspci output mentions [size=64K] and dts says 256 MB. This is because 256MB is the maximum address space available for the PCIe devices. It is upto the Endpoint device, how large address space does it require and accordingly it gets allocated.     Similary IO space translation is also created from the 1st entry in 'ranges':- < 0x81000000 0x00 0x00 → PCI I/O address: 0x00000000 0x00 0x6ff00000 → CPU/system address: 0x6ff00000 0x00 0x100000 → Size: 1MB >;   we observe the same in the dmesg output of iMX95 Verdin EVK Linux console:-   So the MEM Space mapping is from CPU Address 0x910000000 - 0x091fffffff translated to PCIe Address 0x10000000 - 0x1fffffff It is only fair that we mention the driver that uses the 'ranges' property. The 'ranges' property get parsed in "pci_parse_request_of_pci_ranges -> devm_of_pci_get_host_bridge_resources" of "drivers/pci/of.c"     devm_of_pci_get_host_bridge_resources, for each range automatically  manages the memory allocated for these resources. It ensures that the resources are freed when the device is detached or the driver is removed. We have got the answer what & why is the cpu and pci address range the way it is. But in the lspci, you see 0x910100000 and not 0x910000000 which is what the intended start range is supposed to be as per the dtb. Why is that ? To answer this - we need to go back to the PCIe device enumeration. During PCIe enumeration, in the linux PCI driver the bar resources were determined like we had discussed earlier and then the PCI core driver may assign addresses keeping alignment requirements in mind that is why EP's BAR0 was assigned a PCI bus address as 0x10100000 with a 1MB[0x100000] offset from 0x10000000. And keeping the device tree pci translation window in mind:- 0x10100000 translates to 0x910100000 This translation doesn't happen on its own. Device tree binary just mentions the translation window specifics such as the CPU address space to translate to and the PCI address space to translate from. The actual translation is done via iATU. This is done in the dw_pcie_iatu_setup function of drivers/pci/controller/dwc/pcie-designware-host.c by creating the outbound window using dw_pcie_prog_outbound_atu function. Translation is configured on the RC successfully but there is still something missing. .. .. Inbound window !! Without an inbound window on the Endpoint i.e iMX8MM, the writes/reads to 0x910100000 would be meaningless. On iMX8MM we are using PCI Endpoint test driver which is quite popular in linux community and I would urge the readers to visit this page if they want more info - 9. PCI Endpoint Framework — The Linux Kernel documentation pci_epc_map_addr function in drivers/pci/endpoint/pci-epc-core.c creates inbound window by mapping PCI address [0x10100000] to physical address in EP's memory. That's how the reads and writes go through. If there's no Inbound window configured, something like this unfolds in case of read:-   So now everything is set up. Translation windows are configured in the PCI drivers and you are at linux console. The following sequence unfolds when the CPU issues a memory read:-   In case of memory writes:- The following happens on the Endpoint: - The beauty is that this entire translation happens transparently in hardware - your driver just reads/writes to the CPU address, and the PCI host controller handles all the translation automatically! -- How do we test the Address Translation ?   To test reads and writes, either we can make some changes in the driver itself or use devmem5 user-space binary. We are going to make minor driver side changes on iMX8MM and use devmem5 on the RC. iMX8MM is the PCIe Endpoint and we are using end-point test driver to configure it as such. If  you want to do the same, please follow this blog - Enabling PCIe End-point framework on iMX95 torradex board and iMX8MM EVK - NXP Community On the contrary if you want to make iMX95 as RC and iMX8MM Endpoint, feel free to follow this blog - How to configure iMX95EVK as PCIe Endpoint and test it using PCIe Endpoint Test Framework - NXP Community Two things we are going to do next: - 1. On iMX8MM EP, we are going to write some random values  in the drivers/pci/endpoint/pci-epf-core.c, make the following changes in pci_epf_alloc_space function: -     'space' is the virtual address and 'phys_addr' is the physical address that is contiguous. Please note that it is a crude way to test this translation. There are better ways to do it. Build the kernel after the changes and boot the board with it. Make iMX8MM an Endpoint using PCI Endpoint Test Framework. 2. On iMX95 Verdin EVK [PCIe RC], we are going to read the address 0x910100000 using devmem5 to verify that we can observe the same data on the RC.   That's it for today. This was a long blog and if you feel overwhelmed by the details, please feel free to drop in the DMs or comments so that I can try to make it easier. Until next time! Gaurav Sharma
View full article
The purpose of this document is to provide extended guidance for selection of compatible LPDDR5 and LPDDR4x memory devices that are supported by the i.MX 95 and i.MX 952 processors. In all cases, it is strongly recommended to follow the DRAM layout guidelines outlined in the NXP Hardware Developer's Guides for the specific SoCs. Please note that some of the LPDDR4x devices may not support operation at low speeds and in addition, DQ ODT may not be active, which can impact signal integrity at these speeds. If low speed operation is planned in the use case, please consult with the memory vendor the configuration aspects and possible customization of the memory device so correct functionality is ensured. LPDDR5 - maximum supported densities SoC Max Data bus width Maximum density Assumed memory organization Notes i.MX 95 32-bit 128Gb/16GB dual rank, dual channel device with 17-row addresses and x8 (byte mode) organization 1, 3, 7 i.MX 952 32-bit 128Gb/16GB dual rank, dual channel device with 17-row addresses and x8 (byte mode) organization 1, 3, 7, 9   LPDDR5 - list of validated memories Note: The memory vendors often list their devices as LPDDR5x in their high-level product information while in fact, they are in most cases backward compatible with the LPDDR5 mode. This may lead to the false impression that there are not so many LPDDR5 devices on the market. In such cases, it is strongly recommended to check the full datasheet to confirm if the device is in fact LPDDR5/LPDDR5x or LPDDR5x only. The SoC cannot be used with devices that only support the LPDDR5X mode. The validation process is an ongoing effort - regular updates of the table are expected. SoC Density Memory Vendor  Validated Memory Part#  Notes i.MX 95 128Gb/16GB Micron MT62F4G32D8DV-023 FAAT:C - 64Gb/8GB  Samsung K3KL9L90QM-MHCT - 32Gb/4GB  Samsung K3KL8L80QM-MHCT 2 32Gb/4GB  Samsung K3KL8L80EM-MUCV 2        64Gb/8GB  SK HYNIX H58G66DK9VX067N 2 64Gb/8GB Micron MT62F2G32D4DS-023 FAAT:C 2, 6 32Gb/4GB Micron MT62F1G32D2DS-020 WT:D 2 16Gb/2GB Micron MT62F1G16D1DS-023 IT:B 2 64Gb / 8GB Rayson RS2G32LO5D24DB-31BT 2 32Gb/4GB Rayson ATL5X4G32M7E-31IT 2 64Gb / 8GB CXMT CXDB6CCBM-MA-A 2 i.MX 952 128Gb/16GB Micron MT62F4G32D8DV-023 FAAT:C 9 32Gb/4GB Micron MT62F1G32D2DS-020 WT:D 2   LPDDR5 - list of incompatible devices The SoC cannot be used with memory devices that only support the LPDDR5x mode. LPDDR4x - maximum supported densities SoC Max Data bus width Maximum density Assumed memory organization Notes i.MX 95 32-bit 128Gb/16GB dual rank, dual channel device with 17-row addresses 1 i.MX 952 32-bit 128Gb/16GB dual rank, dual channel device with 17-row addresses 1, 9   LPDDR4x - list of validated memories   The validation process is an ongoing effort - regular updates of the table are expected. SoC Density Memory Vendor Validated Memory Part# Notes i.MX 95 64Gb/8GB Micron   MT53E2G32D4DE-046 AUT:C  5 8Gb/1GB Micron MT53E256M32D1KS-046 IT:L 2 128Gb/16GB Micron MT53E4G32D8GS-046 2 64Gb/8GB SK Hynix H54G66BYYVPX104 2 32Gb/4GB Intelligent Memory IMBG32L4KBB_V10 2 48Gb/6GB Micron MT53E1536M32D4DT-046 WT:A 3, 8 24Gb/3GB Micron MT53E768M32D4DT-053 AIT:E 3, 8 8Gb/1GB Samsung K4U8E3S4ADGHCL  2 32Gb/4GB Intelligent Memory IMBG32LK4BBG-046I 2 32Gb/4GB Alliance Memory AS4C1G32MD4V-046BIN 2 64Gb/8GB Rayson ATL4X8G32M2D-46IT 2 64Gb/8GB Rayson ATL4X8G32M2D-46AIT 2 64Gb/8GB DW DWCTB36HLC0 2 8Gb/1GB Alliance Memory AS4C256M32MD4V-062BAN 2 32Gb/4GB ISSI IS46LQ32K01S2A-046BLA2 2 32Gb/4GB Nanya NT6AT1024T32AV-J1 2 64Gb/8GB Nanya NT6AT2048F32AV-J1 2 i.MX 952 64Gb/8GB Micron   MT53E2G32D4DE-046 AUT:C  9   LPDDR4/4X - list of incompatible devices Note: This SoC supports LPDDR4x memory devices. This SoC is not compatible with memories that only support LPDDR4. Combo Devices that support both LPDDR4x and LPDDR4 are compatible with the SoC. Note 1: The numbers are based purely on the IP documentation for the DDR Controller and the DDR PHY, on the settings of the implementation parameters chosen for their integration into the SoC, SoC reference manual and on the JEDEC standards JESD209-5 (LPDDR5) and JESD209-4C/JESD209-4-1 (LPDDR4/4X). Therefore, they are not backed by validation, unless said otherwise and there is no guarantee that an SoC with the specific density and/or desired internal organization is offered by the memory vendors. Should the customers choose to use the maximum density and assume it in the intended use case, they do it at their own risk. Note 2: The memory part number did not undergo full JEDEC verification however, it passed all functional testing items. Note 3: Memory devices with binary densities (e.g., 1 GB, 2 GB, 4 GB) are preferred because they simplify memory management by aligning with system addressing schemes and reducing software complexity. Note 4: All memory parts are available at vendors unless stated otherwise. Checked Q2 2026 Note 5: Memory device supports both LPDDR4x and LPDDR4, however can only be used in LPDDR4x mode Note 6: Not validated by NXP but confirmed working on a non NXP Board Note 7: The maximum density supported may change in the future when DRAM vendors make higher density options available Note 8: This DRAM part number is not recommended for new designs Note 9: This SoC is in Pre-Production
View full article
This article describes a Full-Bridge PCIe reference design that connects an NXP i.MX95 SoC (acting as PCIe Root Complex) to a Lattice CertusPro-NX / Certus-NX FPGA endpoint, together with a Linux kernel driver. Updating the FPGA bitstream over PCIe is demonstrated as the reference use case, built on top of a general-purpose PCIe data-transfer, register-access and MSI-completion interface. Hardware Host / Root Complex: NXP i.MX95 SoC running Linux (DesignWare PCIe controller) FPGA target / endpoint: Lattice CertusPro-NX PCIe Bridge board (Device ID  0x9C25 ) or Certus-NX (Device ID  0x9C1D ) — Lattice Vendor ID  0x1204 PCIe link: 1-lane (x1), single BAR (BAR1) design Interrupt: 1 MSI vector, EP→Host completion signalling   Board Connection Architecture The host application talks to the FPGA through the  kernel driver. The driver exposes BAR1 as a character device and manages two host-side DMA-coherent buffers. Because the design is a full bridge, both sides can initiate PCIe transactions: the host issues MWr/MRd to BAR1, and the FPGA (as bus master) issues its own MWr/MRd back into host memory. Driver Architecture Block Role Application (userspace) Issues IOCTLs; supplies payload and DMA target addresses Driver  lattice_nxp_pcie_ep.c BAR1 MMIO window, SRC/DST DMA buffers, MSI completion, char device  /dev/lattice_nxp_pcie_bar1 FPGA (CertusPro-NX / Certus-NX) PCIe endpoint; executes command, performs MRd/MWr, raises MSI on completion Host memory DMA-coherent SRC and DST buffers   What the driver covers The kernel module is a general-purpose PCIe endpoint transport, not a bitstream-specific driver. It contains no bitstream or image parsing — bitstream update is simply the reference application layered on top of these primitives. It provides three planes: FPGA→Host DMA path (EP-initiated bulk transfer): two host DMA-coherent buffers (SRC/DST, default 4 KB, tunable up to 1 MB). The host fills SRC, programs the FPGA SRC/DST mailbox registers and rings a doorbell; the FPGA (bus master) then moves data via its own MRd/MWr and writes results into the host DST buffer. Usable for any payload. Host↔FPGA BAR1 MMIO window: the char-device  read() / write()  path exposes the whole BAR1 aperture as an 8-byte-granular, byte-addressable window ( readq / writeq , or paired  readl / writel  on 32-bit) for register/RAM access and MWr+MRd readback tests. Control + completion plane: arbitrary 32-bit BAR1 register read/write by offset (the "command" and "doorbell" registers are conventions the application chooses), plus MSI-based completion notification (atomic counter + wait/poll IOCTLs). In short, it is a generic data-transfer + register-access + interrupt-notification interface. Bitstream loading is one application built on it; any host↔FPGA bulk transfer or register-control workflow uses the same primitives.   Driver overview —  Probe & init: enable the PCIe device and set bus master → configure the DMA mask (32-bit default, 64-bit fallback) → map BAR1 MMIO → allocate SRC + DST coherent DMA buffers → allocate 1 MSI vector → register  /dev/lattice_nxp_pcie_bar1 . IOCTL interface (9 commands): Command Di r  Description IOCTL_GET_INFO R Return BAR1 size, SRC/DST DMA handles, MSI IRQ number IOCTL_FILL_SRC W Copy userspace buffer into the SRC DMA buffer IOCTL_CLEAR_DMA – Zero the DST DMA buffer before a transfer IOCTL_READ_DMA R Read back bytes from the DST DMA buffer after the FPGA copy IOCTL_WAIT_MSI W Block until the next MSI fires (with  timeout_ms ) IOCTL_WAIT_MSI_SINCE W Block until  msi_count  exceeds a given baseline (race-free) IOCTL_GET_MSI_COUNT R Read the current MSI interrupt counter (atomic u64) IOCTL_WRITE_REG W Write one 32-bit MMIO register in BAR1 by offset IOCTL_READ_REG R Read one 32-bit MMIO register from BAR1 by offset   Driver internals BAR1 read/write paths:  pcie_read()  /  pcie_write()  expose BAR1 as a char device. Accesses must be 8-byte aligned; 64-bit uses  readq / writeq , 32-bit uses paired  readl / writel . MSI ISR:  pcie_isr()  atomically increments  msi_count  and wakes the wait-queue, unblocking  WAIT_MSI  /  WAIT_MSI_SINCE  callers. Verbosity level 2 logs each interrupt with its running count. iATU resync workaround ( FORCE_SYNC_IATU  on probe, the driver clears and then restores the root-port Memory Base/Limit registers to force the DesignWare PCIe block to rebuild its inbound iATU translation table. This is required after an FPGA reconfiguration + PCIe remove + rescan cycle. The macro can be commented out if the workaround is not needed. Note that this alters the upstream port and can affect other PCIe devices on the same bus. Vendor ID:  0x1204   |  Device IDs:  0x9C25  (CertusPro-NX),  0x9C1D  (Certus-NX). Module parameters Parameter Type / default / perm Description verbose int / 1 / 0644 0 = minimal (critical errors only); 1 = info (probe steps, DMA sizes, MSI events); 2 = chatty (all IOCTL calls, read/write rejections, MSI interrupts) dma_bits int / 32 / 0644 DMA address width for coherent-buffer allocation. 32 = default (most platforms); 64 = use if probe fails with  -ENOMEM  (-12) on a 32-bit mask dma_buf_bytes uint / 4096 / 0644 Size (bytes) of each DMA coherent buffer (SRC and DST). Min 256, default 4096 All three parameters are adjustable at load time;  verbose  and  dma_bits  can also be changed at runtime via sysfs.   Known limitations — unsupported PCIe transaction types Configuration Read (CfgRd0 / CfgRd1) — PCIe TLP Type 0/1 config reads are not supported Configuration Write (CfgWr0 / CfgWr1) — PCIe TLP Type 0/1 config writes are not supported Legacy I/O Read (IORd) — x86-style I/O reads are not supported; no I/O BARs are mapped Legacy I/O Write (IOWr) — x86-style I/O writes are not supported; all access goes through BAR1 MMIO Supported: Memory Read (MRd), Memory Write (MWr), and MSI interrupt signalling via the BAR1 mailbox. Reference lattice_nxp_pcie_ep.c  — Linux kernel PCIe EP driver
View full article
This document analyzes IMX95 supported TSN protocols such as 802.1Qav, 802.1Qbv, 802.1Qbu and 802.1Qci, and introduces use cases design to implement these protocols on I.MX95 platform.
View full article
Market Demand: Due to the inclusion of the Linux Kernel, Android Framework, Vehicle HAL, CarService, and numerous IVI applications, the traditional cold start time of the Android Automotive system is typically long, making it difficult to meet the user experience requirements of "power on and ready to use" in automobiles. Proposed Solution: The Hibernate (Suspend-to-Disk) solution significantly shortens startup time by saving a snapshot of the system's runtime and restoring it to its running state upon the next power-on, while preserving the state of applications such as navigation,music, and Bluetooth. Hardware and software platforms for implementing Hibernate : HW: i.MX95 B0 19*19 EVK SW: Android auto imx-automotive-15.0.0_2.1.0 Lunch device : lunch evk_95_car2-nxp_stable-userdebug
View full article
The purpose of this document is to provide supportive information for selection of suitable LPDDR4, DDR4 and DDR3L devices that are supported by i.MX 8M family of processors to aid project feasibility assessment capabilities of customers that are evaluating the SoCs for usage in their products.  It is strongly recommended to consult with NXP and the memory vendor the final choice of the memory part number to ensure that the device meets all the compatibility, availability, longevity and pricing requirements. Please note that some of the LPDDR4 devices may not support operation at low speeds and in addition, DQ ODT may not be active, which can impact signal integrity at these speeds. If low speed operation is planned in the use case, please consult with the memory vendor the configuration aspects and possible customization of the memory device so correct functionality is ensured. In all cases, it is strongly recommended to follow the DRAM layout guidelines outlined in the NXP Hardware Developer's Guides for the specific SoCs available on NXP.com Memory devices with binary densities (e.g., 1 GB, 2 GB, 4 GB) are preferred because they simplify memory management by aligning with system addressing schemes and reducing software complexity. For any questions related to specific DRAM part numbers please contact the respective DRAM vendor. For any questions regarding the i.MX SoC please contact your support representative or enter a support ticket.  LPDDR4 - maximum supported densities Please note that the SoCs only support memory devices that support either the LPDDR4 mode or support both LPDDR4 and LPDDR4X modes. Memory devices that support only the LPDDR4X mode are not supported. SoC Max data bus width Maximum density Assumed memory organization Notes i.MX 8M Quad 32-bit 32Gb/4GB dual rank, dual-channel  device with 16-row addresses (R0-R15) 1, 2, 4 i.MX 8M Mini  32-bit 64Gb/8GB dual rank, dual-channel  device with 17-row addresses (R0-R16) 1, 2 i.MX 8M Nano  16-bit 32Gb/4GB dual rank, single-channel  device with 17-row addresses (R0-R16) 1, 2, 3, 12 i.MX 8M Plus  32-bit 64Gb/8GB dual rank, dual-channel  device with 17-row addresses (R0-R16)  1, 2   LPDDR4 - list of validated memories Please note that the validation process is an ongoing effort - regular updates of the table are expected. Please contact NXP if a specific vendor or configuration is required. SoC Density Memory Vendor Validated Memory Part#  Notes i.MX 8M Quad  24Gb/3GB    Micron MT53B768M32D4NQ-062 WT:B  15 32Gb/4GB Micron MT53D1024M32D4DT-046 AAT:D  14 4Gb/512MB ISSI IS43LQ16256B-062BLI  5, 14 8Gb/1GB ISSI IS43LQ32256B-062BLI  5, 14 i.MX 8M Mini 16Gb/2GB Micron MT53D512M32D2DS-053 WT:D  15 16Gb/2GB    ESMT M56Z16G32512A-SMBIG 5, 14 32Gb/4GB Micron MT53E1G32D2FW-046 WT:A  5, 14 64Gb/8GB Micron MT53E2G32D4DT-046 AIT:A  5, 14 64Gb/8GB Micron MT53E2G32D4DE-046 AUT:C 5, 14 32Gb/4GB Intelligent Memory IMBG32L4KBB 5,14 32Gb/4GB Kingston B3221PM3BDGUI -U 5 16Gb/2GB Kingston D1621PM4CDGVIW-U related PNs also covered by the test: D1621PM4CDGUI-U D1621PM4CDGUIW-U D1621PM4CDGVI-U 5 i.MX 8M Nano  16Gb / 2GB  Kingston C1612PC2WDGTKR-U  15 16Gb / 2GB  Kingston  D1611PM3BDGUI-U 5,14 32Gb / 4GB Micron MT53E2G32D4DT-046 AIT:A  5, 13, 15 16Gb / 2GB Intelligent Memory  IMAG16L4KBB 5,14 4Gb / 512MB Nanya NT6AN256M16AV-J2 5,14 4Gb / 512MB  Winbond W66CP6RBQAHJ 5,14 8Gb / 1GB ISSI IS43LQ16512A-053BLI 5,14 8Gb / 1GB  Micron MT53D512M32D2DS-053 WT:D 13, 15   i.MX 8M Plus       48Gb/6GB  Micron MT53E1536M32D4DT-046 WT:A  15 64Gb/8GB  Micron MT53E2G32D4DE-046 AUT:C  5, 14 32Gb/4GB Samsung K4FBE3D4HB-KHCL  5, 14 32Gb/4GB Kingston B3221PM3BDGVIW-U 5, 14 64Gb/8GB Kingston Q6422PM3BDGVK-U  5, 14 8Gb/1GB Winbond W66DP2RQQAHJ  5, 14 32Gb/4GB ISSI IS46LQ32K01S2A-046BLA2 5, 14 16Gb/2GB ISSI IS46LQ32512A-046BLA3 5 32Gb/4GB ISSI IS43LQ32K01S2A-046BLI 5, 14 32Gb/4GB IM IMBG32LK4BBG-046I 5, 14 32Gb/4GB Nanya NT6AN1024F32AV-J2 5, 14 32Gb/4GB Nanya NT6AT1024T32AV-J1 5   LPDDR4 - list of incompatible devices Given the limitations mentioned in this document, the following memory devices were identified as incompatible with the particular SoCs as detailed in the following table:   Memory Vendor Memory Part# Density Incompatible SoCs Incompatibility reason Samsung K4FHE3S4HA-KU(H/F)CL 24Gb/3Gb i.MX 8M Quad  The memory device requires 17th row address bit to function. Samsung K4UHE3S4AA-KU(H/F)CL K4UJE3D4AA-KU(H/F)CL 24Gb/3Gb 48Gb/6GB i.MX 8M Quad i.MX 8M Mini i.MX 8M Nano i.MX 8M Plus The memory device only supports the LPDDR4X mode. Samsung K4FCE3Q4HB-KU(H/F)CL K4UCE3Q4AB-KU(H/F)CL 64Gb/8GB i.MX 8M Quad i.MX 8M Mini i.MX 8M Nano i.MX 8M Plus A byte mode memory device. The memory device only supports the LPDDR4X mode.    DDR4 - maximum supported densities SoC Max data bus width Maximum density Assumed memory organization Notes i.MX 8M Quad  32-bit 32Gb/4GB x16, 16Gb device with 1 bank group address, 17-row addresses and 10 column addresses 1, 6 i.MX 8M Mini  32-bit 64Gb/8GB x16, 16Gb device with 1 bank group address, 17-row addresses and 10 column addresses 1, 7 i.MX 8M Nano  16-bit 64Gb/8GB x8, 16Gb device with 2 bank group addresses, 17-row addresses and 10 column addresses 1, 8 i.MX 8M Plus  32-bit 64Gb/8GB x16, 16Gb device with 1 bank group address, 17-row addresses and 10 column addresses 1, 7   DDR4 - list of validated memories Please note that the validation process is an ongoing effort - regular updates of the table are expected. Please contact NXP if a specific vendor or configuration is required.   SoC Density Memory Vendor Validated Memory Part#  Notes i.MX 8M Quad 32Gb/4GB Micron 4x MT40A512M16JY-083EAAT  15 i.MX 8M Mini  16Gb/2GB Micron 2x MT40A512M16LY-075:E  15 i.MX 8M Nano 16Gb/2GB Micron 1x MT40A1G16RC-062E:B  15 8Gb/1GB Rayson 1x RS512M16Z2DD-62DT 14 8Gb/1GB UniIC SCB12Q8G160BF-06SI 14 i.MX 8M Plus 64Gb/8GB Micron 4x MT40A1G16RC-062E:B  15 16Gb/2GB Nanya NT5AD512M16C4-JRI  14   DDR3L - maximum supported densities SoC Max data bus width Maximum density Assumed memory organization Notes i.MX 8M Quad  32-bit 32Gb/4GB x16, 8Gb device with 16-row addresses and 10 column addresses 1, 9 i.MX 8M Mini  32-bit 64Gb/8GB x8, 8Gb device with 16-row addresses and 11 column addresses 1, 10 i.MX 8M Nano  16-bit 32Gb/4GB x8, 8Gb device with 16-row addresses and 11 column addresses 1, 11 i.MX 8M Plus  i.MX 8M Plus does not support DDR3L   DDR3L - list of validated memories Please note that the validation process is an ongoing effort - regular updates of the table are expected. Please contact NXP if a specific vendor or configuration is required. SoC Density Vendor Validated Memory Part#  Notes i.MX 8M Quad  16Gb/2GB Micron 4x MT41K256M16TW-107 AAT  14 i.MX 8M Mini  16Gb/2GB Micron 4x MT41K256M16TW-107 AAT  14              i.MX 8M Nano 8Gb/1GB Micron MT41K512M16VRN-107  15   Note 1: The numbers are based purely on the IP vendor documentation for the DDR Controller and the DDR PHY, on the settings of the implementation parameters chosen for their integration into the SoC, and on the JEDEC standards JESD209-4/JESD209-4A (LPDDR4), JESD279-4/JESD279-4A (DDR4), and JESD79-3E/JESD79-3F/JESD79-3-1A (DDR3/DDR3L). Therefore, they are not backed by validation, unless said otherwise and there is no guarantee that an SoC with the specific density and/or desired internal organization is offered by the memory vendors. Should the customers choose to use the maximum density and assume it in the intended use case, they do it at their own risk. Note 2: Byte-mode LPDDR4 devices (x16 channel internally split between two dies, x8 each) of any density are not supported therefore, the numbers are applicable only to devices with x16 internal organization (referred to as "standard" in the JEDEC specification). Note 3: The memory vendors often do not offer so many variants of single-channel memory devices. As an alternative, a dual-channel device with only one channel connected may be used. For example: A dual-rank, single-channel device with 16-row address bits has a density of 16Gb. If such a device is not available at the chosen supplier, a dual-rank, dual-channel device with 16-row address bits can be used instead. This device has a density of 32 Gb however since only one channel can be connected to the SoC, only half of the density is available (16 Gb). Usage of more than one discrete memory chips to overcome market constraints is not supported since only point-to-point connections are assumed for LPDDR4. Note 4: Devices with 17-row addresses (R0-R16) are not supported by the DDR Controller Note 5: The memory part number did not undergo full JEDEC verification however, it passed all functional testing items. Note 6: The density can be achieved by connecting 2 single-rank discrete devices with one 16Gb die each. Since the SoC supports x8 devices and also has connectivity for a second rank, usage of more discrete devices is possible. However, this advantage cannot be used to get higher density since this SoC has only 32Gb/4GB of address space dedicated for the DDR. Two x16 16Gb devices giving 32Gb/4GB in total is, therefore, the optimal choice that balances the maximum density aspects, the signal integrity aspects (only two discrete devices used), and bandwidth aspects (full data bus width used). Note 7: The density can be achieved by connecting 4 single rank discrete devices with one 16Gb die each, 2 devices connected to each chip select. Since the SoC supports x8 devices, the usage of more discrete devices is possible. However, this advantage cannot be used to get higher density since this SoC has only 64Gb/8GB of address space dedicated for the DDR. Four x16 16Gb devices giving 64Gb/8GB in total is the optimal choice that balances the maximum density aspects, the signal integrity aspects (only four discrete devices used), and the bandwidth aspects (full data bus width used). Note 8: The density can be achieved by connecting 4 single rank discrete devices with one 16Gb die each, 2 devices connected to each chip select.  Note 9: The density can be achieved by connecting 4 single rank discrete devices with one 8Gb die each, 2 devices connected to each chip select, or by connecting 2 dual rank discrete devices with two 8Gb dies each. Since the SoC supports x8 devices, the usage of more discrete devices is possible. However, this advantage cannot be used to get higher density since this SoC has only 32Gb/4GB of address space dedicated for the DDR. Four x16 8Gb devices giving 32Gb/4GB in total is, therefore, the optimal choice that balances the maximum density aspects, the signal integrity aspects (four discrete devices used), and bandwidth aspects (full data bus width used). Note 10: The density can be achieved by connecting 8 single rank discrete devices with one 8Gb die each, 4 devices connected to each chip select or by connecting 4 dual rank discrete devices with two 8Gb dies each. Note that the first option significantly exceeds the number of devices used on the validation board (4 discrete devices) therefore, it is not guaranteed that the i.MX would be able to drive the signals with margin to the required voltage levels due to increased loading on the traces. A significant effort would be required in terms of PCB layout and signal integrity analysis. Practically, it is not recommended to use more than 4 discrete DDR3L devices. This corresponds to the maximum density of 32Gb/4GB in the case of the single rank devices containing one 8Gb die or 64Gb/8GB in case of the dual-rank devices, each containing two 8Gb dies. Note 11: The density can be achieved by connecting 4 single rank discrete devices with one 8Gb die each, 2 devices connected to each chip select or by connecting 2 dual rank discrete devices with two 8Gb dies each. Note 12: For single-channel (x16) memory devices, the current maximum available density in the market is 16Gb/2GB (Q1 2022). Note 13: Only one channel of the device (and hence, half of its density) was utilized due to the reduced data bus width (x16) of the SoC. Note 14: Part is active. Reviewed Jan 2026 Note 15: Part will either EoL or is not recommended for new designs by the respective vendor.   Additional Links https://community.nxp.com/t5/iMX-and-Vybrid-Support/i-MX-8-8X-8XL-maximum-supported-LPDDR4-and-DDR3L-densities/ta-p/1152715
View full article
Background: The i.MX95 introduces a system manager firmware, which is responsible for power, clock, resource isolation, security management, and system-level control between kernels, essentially acting as the "backend manager" for the entire SoC. Switching between different driver modes is necessary to change the VDD_SOC voltage of the i.MX 95. But, Unlike the i.MX 93, the i.MX 95 does not support DVFS and the i.MX 95 has only one fixed DDR frequency point., it is not possible to switch between OD, ND, and LD modes under userspace. This article will explain how to switch from OD to ND mode.   1. Test environment HW: i.MX95 EVK board SW: imx-oei, imx-sm 2. Voltage and frequency of i.MX 95 series processors in different modes The voltage VDD_SOC varies in different modes. Maximum frequency of i.MX 95 series processor modules in different modes. 3. Code change(Switching to ND mode as an example) 3.1. imx-sm https://github.com/nxp-imx/imx-sm/blob/master/boards/mcimx95evk/sm/brd_sm.c#L107 index 077fa06..023a580 100755 --- a/boards/mcimx95evk/sm/brd_sm.c +++ b/boards/mcimx95evk/sm/brd_sm.c @@ -104,7 +104,7 @@      BRD_SM_REC_VLD_MASK)  /* Performance parameters */ -#define BOARD_PERF_LEVEL  DEV_SM_PERF_LVL_ODV  /* Target perf level */ +#define BOARD_PERF_LEVEL  DEV_SM_PERF_LVL_NOM  /* Target perf level */  #if BOARD_VOLT_SOC >= ES_ODV_UV_VDD_SOC  #define BOARD_BOOT_LEVEL  DEV_SM_PERF_LVL_ODV  /* Boot perf overdrive */  #elif BOARD_VOLT_SOC >= ES_NOM_UV_VDD_SOC diff --git a/configs/mx95evk.cfg b/configs/mx95evk.cfg index 8ac5392..5f19d42 100755 --- a/configs/mx95evk.cfg +++ b/configs/mx95evk.cfg @@ -459,7 +459,7 @@ PD_A55C2            stop=5  PD_A55C3            stop=4  PD_A55C4            stop=3  PD_A55C5            stop=2 -PERF_A55            start=3|3 +PERF_A55            start=3|2  CPU_A55C0           start=4  CPU_A55P            stop=1 @@ -473,7 +473,7 @@ PD_A55C2            msel=1, stop=5  PD_A55C3            msel=1, stop=4  PD_A55C4            msel=1, stop=3  PD_A55C5            msel=1, stop=2 -PERF_A55            msel=1, start=3|3 +PERF_A55            msel=1, start=3|2  CPU_A55C0           msel=1, start=4  CPU_A55P            msel=1, stop=1 @@ -487,7 +487,7 @@ PD_A55C2            msel=2, stop=5  PD_A55C3            msel=2, stop=4  PD_A55C4            msel=2, stop=3  PD_A55C5            msel=2, stop=2 -PERF_A55            msel=2, start=3|3 +PERF_A55            msel=2, start=3|2  CPU_A55C0           msel=2, start=4  CPU_A55P            msel=2, stop=1 diff --git a/configs/mx95evk/config_lmm.h b/configs/mx95evk/config_lmm.h index 3e3f508..999a4a1 100755 --- a/configs/mx95evk/config_lmm.h +++ b/configs/mx95evk/config_lmm.h @@ -152,11 +152,11 @@      {.lmId = 2U, .mSel = 1U, .ss = LMM_SS_PD, .rsrc=DEV_SM_PD_A55P}, \      {.lmId = 2U, .mSel = 2U, .ss = LMM_SS_PD, .rsrc=DEV_SM_PD_A55P}, \      {.lmId = 2U, .mSel = 0U, .ss = LMM_SS_PERF, .rsrc=DEV_SM_PERF_A55, \ -     .numArg = 1, .arg[0] = 3U, }, \ +     .numArg = 1, .arg[0] = 2U, }, \      {.lmId = 2U, .mSel = 1U, .ss = LMM_SS_PERF, .rsrc=DEV_SM_PERF_A55, \ -     .numArg = 1, .arg[0] = 3U, }, \ +     .numArg = 1, .arg[0] = 2U, }, \      {.lmId = 2U, .mSel = 2U, .ss = LMM_SS_PERF, .rsrc=DEV_SM_PERF_A55, \ -     .numArg = 1, .arg[0] = 3U, }, \ +     .numArg = 1, .arg[0] = 2U, }, \      {.lmId = 2U, .mSel = 0U, .ss = LMM_SS_CPU, .rsrc=DEV_SM_CPU_A55C0}, \      {.lmId = 2U, .mSel = 1U, .ss = LMM_SS_CPU, .rsrc=DEV_SM_CPU_A55C0}, \      {.lmId = 2U, .mSel = 2U, .ss = LMM_SS_CPU, .rsrc=DEV_SM_CPU_A55C0}, 3.2. imx-oei Add the timing.c file for different DRAM frequencies under different modes to the following file, and then recompile imx-oei: https://github.com/nxp-imx/imx-oei/tree/master/boards/mx952lp5-19/ddr 4. Boot log: The boot log shows that the CPU frequency had dropped to 1404MHz at this point. Note: Ensure that you are using the DRAM timing.c file corresponding to the specified mode and that the compilation is error-free. To guarantee a complete error-free compilation, it is recommended to create a new timing.c file in the directory corresponding to imx-oei, complete the configuration in the Makefile, and then compile. Do not completely overwrite the contents of the current timing.c file. For instructions on how to use Config Tool and how to update the timing.c file, please refer to the Config Tool User Guide.
View full article
In this post, we will review the YOLO model export process for three popular NXP families: i.MX8MP, i.MX93, and i.MX95. These processors are increasingly used in edge AI applications such as smart vision, industrial automation, robotics, and intelligent HMI systems. Although they all support machine learning deployment, the export path, supported runtimes, and hardware acceleration options may differ depending on the device. The purpose of this guide is to provide a clearer starting point for developers who want to take a trained YOLO model and prepare it for execution on these i.MX platforms. Whether your workflow targets CPU, NPU. YOLO Model Export Workflow for i.MX Processors 1) Install Ultralytics Install or upgrade the Ultralytics package from PyPI: pip install -U ultralytics   2) Export the YOLO Model (TFLite INT8) Export your trained YOLO model to TensorFlow Lite (TFLite) format with INT8 quantization: yolo export model=<your_model>.pt format=saved_model quantize=8 Example: yolo export model=yolov8n.pt format=saved_model quantize=8   Notes: The model must be exported in TFLite format and fully INT8 quantized. After the export process, a directory named "<your_model>_saved_model" Inside this directory, you should use the following file as the input for the converter called "<your_model>_full_integer_quant.tflite"  This is the fully quantized INT8 model required for NPU deployment. Using any other file from the export directory may result in compatibility issues or prevent proper NPU acceleration. After obtaining the *_full_integer_quant.tflite file, you can proceed with the needed conversion workflow to generate the final model optimized for execution on the NPU. For additional valid export options, please refer to the official Ultralytics documentation: https://docs.ultralytics.com/modes/export/ At this stage: The model can run on CPU for: i.MX8MP i.MX93 i.MX95 On i.MX8MP, this TFLite model can also be deployed to the NPU using the appropriate delegate. 3) i.MX93  Compile for Ethos-U NPU (Vela) For i.MX93, an additional compilation step is required to use the Ethos-U NPU. Run the Vela compiler to convert the TFLite model into an optimized format: vela <model>.tflite --output-dir <output_folder> Notes: This step generates a model optimized for the Ethos-U NPU. The resulting output files are required for deployment using the NPU delegate on the i.MX93 platform. Please ensure that the model complies with the Ethos-U operator constraints, as only supported operations can be accelerated by the NPU. This command can be executed directly on the i.MX93 target, or alternatively by using the eIQ Toolkit (please refer to the eIQ Converter documentation for more details). 4)  i.MX95 Convert Model Using Neutron SDK For i.MX95, the model must be converted using the Neutron Converter, depending on the BSP version installed on your board. .\neutron-converter.exe ` --input "<model>.tflite" ` --target imx95 ` --output "<model_neutron>.tflite" ` --optimization-level OOpt Notes: The Neutron toolchain prepares the model for i.MX95 NPU acceleration. Supported formats and flags may vary depending on the Neutron SDK version. Always verify compatibility with your BSP release. You can check the compatibility details of the Neutron SDK in the "docs" folder of your downloaded Neutron SDK package.   5) Benchmark the Model After exporting and converting the model, you can validate performance using benchmarking tools. Typical options include: TFLite benchmark tool (CPU / delegate): benchmark_model --graph=<model>.tflite --num_threads=X 6) Results iMX8MP CPU root@imx8mpevk:~# /usr/bin/tensorflow-lite-2.19.0/examples/benchmark_model --graph=yolov8n_full_integer_quant.tflite --mum_threads=4 INFO: STARTING! WARN: Unconsumed cmdline flags: --mum_threads=4 INFO: Log parameter values verbosely: [0] INFO: Graph: [yolov8n_full_integer_quant.tflite] INFO: Signature to run: [] INFO: Loaded model yolov8n_full_integer_quant.tflite INFO: Created TensorFlow Lite XNNPACK delegate for CPU. INFO: The input model file size (MB): 3.42652 INFO: Initialized session in 86.368ms. INFO: Running benchmark for at least 1 iterations and at least 0.5 seconds but terminate if exceeding 150 seconds. INFO: count=1 curr=1029584 p5=1029584 median=1029584 p95=1029584 INFO: Running benchmark for at least 50 iterations and at least 1 seconds but terminate if exceeding 150 seconds. INFO: count=50 first=986237 curr=985536 min=983921 max=993982 avg=985863 std=1497 p5=984152 median=985947 p95=986715 INFO: Inference timings in us: Init: 86368, First inference: 1029584, Warmup (avg): 1.02958e+06, Inference (avg): 985863 INFO: Note: as the benchmark tool itself affects memory footprint, the following is only APPROXIMATE to the actual memory footprint of the model at runtime. Take the information at your discretion. INFO: Memory footprint delta from the start of the tool (MB): init=11.207 overall=40.918 root@imx8mpevk:~#   NPU root@imx8mpevk:~# /usr/bin/tensorflow-lite-2.19.0/examples/benchmark_model --graph=yolov8n_full_integer_quant.tflite --num_threads=4 --external_delegate_path=/usr/lib/libvx_delegate.so INFO: STARTING! INFO: Log parameter values verbosely: [0] INFO: Num threads: [4] INFO: Graph: [yolov8n_full_integer_quant.tflite] INFO: Signature to run: [] INFO: #threads used for CPU inference: [4] INFO: #threads used for CPU inference: [4] INFO: External delegate path: [/usr/lib/libvx_delegate.so] INFO: Loaded model yolov8n_full_integer_quant.tflite INFO: Vx delegate: allowed_cache_mode set to 0. INFO: Vx delegate: device num set to 0. INFO: Vx delegate: allowed_builtin_code set to 0. INFO: Vx delegate: error_during_init set to 0. INFO: Vx delegate: error_during_prepare set to 0. INFO: Vx delegate: error_during_invoke set to 0. INFO: EXTERNAL delegate created. INFO: Explicitly applied EXTERNAL delegate, and the model graph will be completely executed by the delegate. INFO: The input model file size (MB): 3.42652 INFO: Initialized session in 39.515ms. INFO: Running benchmark for at least 1 iterations and at least 0.5 seconds but terminate if exceeding 150 seconds. INFO: count=1 curr=16831746 p5=16831746 median=16831746 p95=16831746 INFO: Running benchmark for at least 50 iterations and at least 1 seconds but terminate if exceeding 150 seconds. INFO: count=50 first=67167 curr=67190 min=67048 max=67366 avg=67187 std=64 p5=67094 median=67184 p95=67295 INFO: Inference timings in us: Init: 39515, First inference: 16831746, Warmup (avg): 1.68317e+07, Inference (avg): 67187 INFO: Note: as the benchmark tool itself affects memory footprint, the following is only APPROXIMATE to the actual memory footprint of the model at runtime. Take the information at your discretion. INFO: Memory footprint delta from the start of the tool (MB): init=9.47266 overall=224.398 root@imx8mpevk:~# iMX93 CPU root@imx93evk:~# /usr/bin/tensorflow-lite-2.19.0/examples/benchmark_model --graph=yolov8n_full_integer_quant.tflite --num_threads=2 INFO: STARTING! INFO: Log parameter values verbosely: [0] INFO: Num threads: [2] INFO: Graph: [yolov8n_full_integer_quant.tflite] INFO: Signature to run: [] INFO: #threads used for CPU inference: [2] INFO: #threads used for CPU inference: [2] INFO: Loaded model yolov8n_full_integer_quant.tflite INFO: Created TensorFlow Lite XNNPACK delegate for CPU. INFO: The input model file size (MB): 3.42652 INFO: Initialized session in 57.963ms. INFO: Running benchmark for at least 1 iterations and at least 0.5 seconds but terminate if exceeding 150 seconds. INFO: count=3 first=247896 curr=198973 min=198973 max=247896 avg=215381 std=22991 p5=198973 median=199275 p95=247896 INFO: Running benchmark for at least 50 iterations and at least 1 seconds but terminate if exceeding 150 seconds. INFO: count=50 first=199533 curr=198880 min=197719 max=205262 avg=199032 std=1005 p5=198344 median=198886 p95=199961 INFO: Inference timings in us: Init: 57963, First inference: 247896, Warmup (avg): 215381, Inference (avg): 199032 INFO: Note: as the benchmark tool itself affects memory footprint, the following is only APPROXIMATE to the actual memory footprint of the model at runtime. Take the information at your discretion. INFO: Memory footprint delta from the start of the tool (MB): init=11.2539 overall=40.9961 root@imx93evk:~#   NPU root@imx93evk:~# /usr/bin/tensorflow-lite-2.19.0/examples/benchmark_model --graph=yolov8n_full_integer_quant_vela.tflite --num_threads=2 --external_delegate_path=/usr/lib/libethosu_delegate.so INFO: STARTING! INFO: Log parameter values verbosely: [0] INFO: Num threads: [2] INFO: Graph: [yolov8n_full_integer_quant_vela.tflite] INFO: Signature to run: [] INFO: #threads used for CPU inference: [2] INFO: #threads used for CPU inference: [2] INFO: External delegate path: [/usr/lib/libethosu_delegate.so] INFO: Loaded model yolov8n_full_integer_quant_vela.tflite INFO: Ethosu delegate: device_name set to /dev/ethosu0. INFO: Ethosu delegate: cache_file_path set to . INFO: Ethosu delegate: timeout set to 60000000000. INFO: Ethosu delegate: enable_cycle_counter set to 0. INFO: Ethosu delegate: enable_profiling set to 0. INFO: Ethosu delegate: profiling_buffer_size set to 2048. INFO: Ethosu delegate: pmu_event0 set to 0. INFO: Ethosu delegate: pmu_event1 set to 0. INFO: Ethosu delegate: pmu_event2 set to 0. INFO: Ethosu delegate: pmu_event3 set to 0. INFO: EXTERNAL delegate created. INFO: EthosuDelegate: 8 nodes delegated out of 15 nodes with 8 partitions. INFO: Explicitly applied EXTERNAL delegate, and the model graph will be partially executed by the delegate w/ 8 delegate kernels. INFO: Created TensorFlow Lite XNNPACK delegate for CPU. INFO: The input model file size (MB): 2.9511 INFO: Initialized session in 638.148ms. INFO: Running benchmark for at least 1 iterations and at least 0.5 seconds but terminate if exceeding 150 seconds. INFO: count=7 first=87215 curr=81264 min=81079 max=87215 avg=82056.4 std=2107 p5=81079 median=81187 p95=87215 INFO: Running benchmark for at least 50 iterations and at least 1 seconds but terminate if exceeding 150 seconds. INFO: count=50 first=81497 curr=81232 min=80887 max=81783 avg=81153.1 std=178 p5=80921 median=81148 p95=81497 INFO: Inference timings in us: Init: 638148, First inference: 87215, Warmup (avg): 82056.4, Inference (avg): 81153.1 INFO: Note: as the benchmark tool itself affects memory footprint, the following is only APPROXIMATE to the actual memory footprint of the model at runtime. Take the information at your discretion. INFO: Memory footprint delta from the start of the tool (MB): init=7.36328 overall=8.73828 root@imx93evk:~# iMX95 CPU root@imx95evk:~# /usr/bin/tensorflow-lite-2.19.0/examples/benchmark_model --graph=yolov8n_full_integer_quant.tflite --num_threads=6 INFO: STARTING! INFO: Log parameter values verbosely: [0] INFO: Num threads: [6] INFO: Graph: [yolov8n_full_integer_quant.tflite] INFO: Signature to run: [] INFO: #threads used for CPU inference: [6] INFO: #threads used for CPU inference: [6] INFO: Loaded model yolov8n_full_integer_quant.tflite INFO: Created TensorFlow Lite XNNPACK delegate for CPU. INFO: The input model file size (MB): 3.42652 INFO: Initialized session in 35.268ms. INFO: Running benchmark for at least 1 iterations and at least 0.5 seconds but terminate if exceeding 150 seconds. INFO: count=7 first=115073 curr=74468 min=74170 max=115073 avg=80310.4 std=14192 p5=74170 median=74581 p95=115073 INFO: Running benchmark for at least 50 iterations and at least 1 seconds but terminate if exceeding 150 seconds. INFO: count=50 first=74143 curr=74135 min=73657 max=76392 avg=74346.9 std=447 p5=73829 median=74307 p95=75020 INFO: Inference timings in us: Init: 35268, First inference: 115073, Warmup (avg): 80310.4, Inference (avg): 74346.9 INFO: Note: as the benchmark tool itself affects memory footprint, the following is only APPROXIMATE to the actual memory footprint of the model at runtime. Take the information at your discretion. INFO: Memory footprint delta from the start of the tool (MB): init=11.5195 overall=40.8867 root@imx95evk:~# NPU: root@imx95evk:~# /usr/bin/tensorflow-lite-2.19.0/examples/benchmark_model --graph=yolov8n_full_integer_quant_neutron.tflite --num_threads=6 --external_delegate_path=/usr/lib/libneutron_delegate.so INFO: STARTING! INFO: Log parameter values verbosely: [0] INFO: Num threads: [6] INFO: Graph: [yolov8n_full_integer_quant_neutron.tflite] INFO: Signature to run: [] INFO: #threads used for CPU inference: [6] INFO: #threads used for CPU inference: [6] INFO: External delegate path: [/usr/lib/libneutron_delegate.so] INFO: Loaded model yolov8n_full_integer_quant_neutron.tflite INFO: EXTERNAL delegate created. INFO: NeutronDelegate delegate: 1 nodes delegated out of 33 nodes with 1 partitions. INFO: Neutron delegate version: v1.0.0-7399a58e, zerocp enabled. INFO: Explicitly applied EXTERNAL delegate, and the model graph will be partially executed by the delegate w/ 1 delegate kernels. INFO: Created TensorFlow Lite XNNPACK delegate for CPU. INFO: The input model file size (MB): 3.20989 INFO: Initialized session in 12.756ms. INFO: Running benchmark for at least 1 iterations and at least 0.5 seconds but terminate if exceeding 150 seconds. INFO: count=17 first=31509 curr=27588 min=27555 max=31509 avg=29101.2 std=1166 p5=27555 median=29071 p95=31509 INFO: Running benchmark for at least 50 iterations and at least 1 seconds but terminate if exceeding 150 seconds. INFO: count=50 first=28068 curr=29081 min=26573 max=31340 avg=29104.1 std=1204 p5=27306 median=29141 p95=31171 INFO: Inference timings in us: Init: 12756, First inference: 31509, Warmup (avg): 29101.2, Inference (avg): 29104.1 INFO: Note: as the benchmark tool itself affects memory footprint, the following is only APPROXIMATE to the actual memory footprint of the model at runtime. Take the information at your discretion. INFO: Memory footprint delta from the start of the tool (MB): init=6.98438 overall=12.2344 root@imx95evk:~ Disclaimer: Ultralytics YOLO models have not been officially validated/supported by NXP. Therefore, compatibility with i.MX processors and their corresponding NPUs cannot be guaranteed. Some models or configurations may not work as expected depending on operator support and hardware limitations.
View full article
Updates i.MX 93 Reference Manual Rev. 7.
View full article
Introduction.  USB is a highly efficient interface for transporting audio and voice data, offering sufficient bandwidth for applications from voice telephony to high-quality audio playback and recording. To ensure compatibility between devices, the USB Audio Class specification defines standardized mechanisms for audio transport and control, allowing audio peripherals to operate with generic drivers and minimizing platform software requirements.    For i.MX processors, this article describes how an i.MX board can function as a standard USB audio device, enabling audio data to be streamed through the USB port to a host computer. This capability is important for applications such as USB microphones, speakers, audio gateways, and voice-processing systems.   As a result, developers can efficiently implement real time audio transfer between i.MX boards and host systems using standard USB audio drivers without requiring additional proprietary interfaces.   Required equipment. i.MX95 FRDM board (this is the selected board for this post, it works for others). Debug USB-C cable. Data USB-C cable. USB-C power supply. Ethernet cable. Speakers or headphones with 3.5mm input plug. Personal computer. To start, we need to flash our Linux BSP into the board. You can build it by yourself or use the pre-built BSP to facilitate the process. This post was tested with Linux 6.18.20_2.0.0, if you have issues to flash the board, please refer to this article: Flashing Linux BSP using UUU This is how my hardware setup looks: USB gadget setup. The following script configures the board to work as an USB audio gadget in Linux. This setup allows the board to be detected as a standard audio device, enabling audio streaming over the USB connection without requiring a custom USB protocol on the host side. The script creates the USB gadget configuration, assigns the required USB descriptors, with predefined audio parameters such as 16 kHz sample rate, 32-bit sample size, and single-channel capture/playback support. This example is useful for applications such as voice capture, audio processing, USB microphones, or embedded audio demos. #!/bin/sh # USB gadget ConfigFS paths CONFIGFS=/sys/kernel/config/usb_gadget GADGET=$CONFIGFS/g1 CONFIG=$GADGET/configs/c.1 FUNCTIONS=$GADGET/functions # USB device descriptors and audio configuration VID="0x1fc9" PID="0x0330" SERIALNUMBER="0123456789" MANUFACTURER="NXP Semiconductors" PRODUCT="i.MX USB Audio Gadget" SAMPLE_RATE=16000 SAMPLE_SIZE=4 # 32-bit audio samples echo "Setting up USB gadget with the following parameters:" echo " Vendor ID: $VID" echo " Product ID: $PID" echo " Serial Number: $SERIALNUMBER" echo " Manufacturer: $MANUFACTURER" echo " Product: $PRODUCT" echo " Sample Rate: $SAMPLE_RATE Hz" function add_uac2_function() { # Create a USB Audio Class function instance mkdir $FUNCTIONS/uac2.$1 echo "$PRODUCT $1" > $FUNCTIONS/uac2.$1/function_name # c_* parameters configure USB Capture # p_* parameters configure USB Playback # Audio sample rate configuration echo $SAMPLE_RATE > $FUNCTIONS/uac2.$1/c_srate echo $SAMPLE_RATE > $FUNCTIONS/uac2.$1/p_srate # Audio sample size in bytes echo $SAMPLE_SIZE > $FUNCTIONS/uac2.$1/c_ssize echo $SAMPLE_SIZE > $FUNCTIONS/uac2.$1/p_ssize echo $2 > $FUNCTIONS/uac2.$1/c_chmask echo $3 > $FUNCTIONS/uac2.$1/p_chmask # Enable mute and volume controls visible to the USB host echo 0x1 > $FUNCTIONS/uac2.$1/c_mute_present echo 0x1 > $FUNCTIONS/uac2.$1/c_volume_present echo 0x1 > $FUNCTIONS/uac2.$1/p_mute_present echo 0x1 > $FUNCTIONS/uac2.$1/p_volume_present # Add the UAC2 function to the active USB configuration ln -s $FUNCTIONS/uac2.$1 $CONFIG } function create_config() { # Create the USB gadget device mkdir $GADGET # Set USB Vendor ID and Product ID echo $VID > $GADGET/idVendor echo $PID > $GADGET/idProduct # Standard USB string descriptors mkdir $GADGET/strings/0x409 echo $SERIALNUMBER > $GADGET/strings/0x409/serialnumber echo $MANUFACTURER > $GADGET/strings/0x409/manufacturer echo $PRODUCT > $GADGET/strings/0x409/product # Create USB configuration description mkdir -p $CONFIG/strings/0x409 echo $1 > $CONFIG/strings/0x409/configuration } # Create a UAC2 audio gadget with mono capture and mono playback create_config "UAC2" add_uac2_function "Active" 0x1 0x1 echo "Done" Clean USB gadget. If you need to free up the USB port, it is necessary to run the following script. #!/bin/sh # USB gadget ConfigFS paths CONFIGFS=/sys/kernel/config/usb_gadget GADGET=$CONFIGFS/g1 CONFIG=$GADGET/configs/c.1 FUNCTIONS=$GADGET/functions # Verify that the gadget exists before attempting cleanup if [ ! -d "$GADGET" ]; then echo "Gadget does not exist" exit 0 fi # Disconnects the gadget from the host before removal. echo "" > $GADGET/UDC 2>/dev/null # Remove UAC2 function links from the configuration rm -f $CONFIG/uac2.* 2>/dev/null # Remove UAC2 function instances rmdir $FUNCTIONS/uac2.* 2>/dev/null # Remove configuration strings and configuration directory rmdir $CONFIG/strings/0x409 2>/dev/null rmdir $CONFIG/strings 2>/dev/null rmdir $CONFIG 2>/dev/null # Remove gadget string descriptors rmdir $GADGET/strings/0x409 2>/dev/null rmdir $GADGET/strings 2>/dev/null # Remove the gadget itself rmdir $GADGET 2>/dev/null echo "Cleanup completed" Testing. Both scripts can be created into the board using nano or a similar text editor through the console but is easier to do it in your host machine and send it for example using SCP. After you created both scripts you can send them with the next command: scp <file_to_transfer> <user>@<ip_address>:<destination_path> Once you connected the Ethernet cable in any of the available RJ45 connectors in your board, you can get the IP address with the next command: ifconfig Now, in your host machine, you can go to the path where are your USB scripts and send them: scp cleanup_usb_gadget.sh root@<frdm_board_ip>:~/ scp setup_usb_gadget.sh root@<frdm_board_ip>:~/ After transfer the scripts to the board, you need to change file permissions to execute the scripts with chmod and run USB gadget setup script to configure the board as a USB audio interface. chmod u+x *_usb_gadget.sh Once this script have been executed you can see the USB port in ALSA as a sink/source device: Then, you need to connect the USB port to a host computer and will be recognized as an USB interface: You can validate that the device is working according to the configuration defined in setup script: I will use Audacity to test audio transfer from on board microphones, in Edit -> Preferences -> Audio settings select i.MX Active as recording device: Note: Use the same sample rate of setup_usb_gadget.sh configuration to avoid errors with the DAW. In the board, I will start the recording by running the following GStreamer pipeline, which captures audio from the onboard microphones and streams it through the USB port: gst-launch-1.0 alsasrc device=hw:micfilaudio,0 ! queue ! audioconvert ! audio/x-raw,channels=1,rate=16000,format=F32LE ! audioconvert ! alsasink device=hw:UAC2Gadget,0 After this configuration, add an audio track and now, is possible to get the audio and record it directly in the DAW: If you want to play audio from host PC trough the i.MX board, you need to run the next command before start the audio playback in host. Make sure that the audio card selected is not busy: gst-launch-1.0 -v alsasrc device=hw:UAC2Gadget,0 ! audio/x-raw,format=S32LE,rate=16000,channels=1 ! audioconvert ! audioresample ! audio/x-raw,format=S16LE,rate=48000,channels=2 ! audioconvert ! alsasink device=plughw:mqsaudio,0 In this case, I selected the MQS output in 3.5mm output jack, you can connect the speakers or headphones with this connector. After run the clean USB gadget script, the USB audio device is not longer detected in host PC and the board output is the next: References. USB Implementers Forum. (1998, March 18). Universal Serial Bus device class definition for audio devices (Release 1.0) [PDF]. USB-IF. https://www.usb.org/sites/default/files/audio10.pdf
View full article
Some customer wants to know how to enable the SOD for MIMX9596DVZXQAC, commercial qualification in 19mm. They want to test the SOD mode which is A55 running at 2.0GHz, there is no any documentation in our NXP side explaining how to do that. Here this article give the describe and enable the Super Overdrive mode on the i.MX95. 1\Introduction the i.MX95 Voltage Operating Modes The i.MX power architecture is designed with the expectation that a dedicated PMIC supplies all required power rails, ensuring compliance with stringent power-up and power-down sequencing requirements. Majority of the digital logic is supplied with two supplies: VDD_ARM and VDD_SOC. VDD_ARM is for the CORTEXAMIX. VDD_SOC is for the rest of the modules in SoC. The VDD_SOC has following modes: Overdrive mode Nominal mode Underdrive mode Suspend mode The VDD_ARM has following modes: Super Overdrive mode Overdrive mode Nominal mode Underdrive mode Suspend mode The i.MX95 power management architecture is based on multiple performance setpoints controlled by the System Manager (SM). These setpoints control: Cortex-A55 operating frequency VDD_ARM voltage Power consumption Thermal dissipation The available performance modes are:PRK,LOW,NOM,ODV,SOD Where SOD (Super Overdrive) is available only on qualified 2.0 GHz capable devices such as MIMX9596DVZXQAC. In our datasheet we can see that for the part number only MIMX9596DVZXQAC A core support the 2.0 GHz.     Details in the naming rules:   For the operating ranges in our datasheet can see the details:   Only the Cortex-A55 support the super overdrive mode, and for the typical voltage is 1.0V. In our reference design the VDD_ARM and VDD_SOC from different PMIC. And for the frequency of modules can also see in the datasheet, for the default setting is 1.8GHz, the maximum is 2004MHz.   2\ Enable Super Overdrive (SOD) Mode (2.0 GHz) on MIMX9596DVZXQAC Understanding about SOD mode:  The default NXP BSP SM (System Manager) code will automatically detect if the iMX 95 device it is running on is a 2.0 GHz capable device, and then the code will enable operation at 2.0 GHz with Super Overdrive voltage mode.  Linux on the iMX 95 only needs to request 2.0 GHz from the System Manager to enable it. Default BSP support code: In the download source code path : /imx95BSP/tmp/work/imx95_19x19_lpddr5_evk-poky-linux/imx-system-manager/2025q4/git/devices/MIMX95/sm/dev_sm_perf.c Or in our github source can see the code: imx-sm/devices/MIMX95/sm/dev_sm_perf.c at master · nxp-imx/imx-sm · GitHub The NXP BSP already contains logic to detect whether the device supports 2.0 GHz operation   /* Check for 2+GHz device */ if (speedGrade >= 2000000000U) { /* 2+GHz devices support PRK, LOW, NOM, ODV, SOD setpoints */ s_perfNumLevels[PS_VDD_ARM] = DEV_SM_NUM_PERF_LVL_ARM; }  When the System Manager reads: speedGrade >= 2000000000 the BSP automatically: Enables the SOD performance level Enables 2.0 GHz OPP Manages required ARM voltage transitions The above code will enable the SOD without changing anything. Then in Linux you can use performance to run at 2.0GHz. Using the following command: echo performance > /sys/devices/system/cpu/cpufreq/policy0/scaling_governor Then we can check the frequency and voltage of the VDD_ARM.  3\ Enabling SOD on a Non-2.0 GHz EVK (Evaluation Only) For evaluation on the EVK with the 1.8 GHz i.MX95, the process to enable 2.0 GHz and Super Overdrive voltage mode is to modify a single line of SM (System Manager) code so that 2 GHz is enabled even if the iMX 95 does not report 2 GHz operation is possible. Change this file: /MIMX95/sm/dev_sm_perf.c else { /* All other devices support PRK, LOW, NOM, ODV setpoints */ s_perfNumLevels[PS_VDD_ARM] = DEV_SM_NUM_PERF_LVL_ARM - 1U; }// This the the default running code for the 1.8GHz for the i.MX95 FROM: s_perfNumLevels[PS_VDD_ARM] = DEV_SM_NUM_PERF_LVL_ARM - 1U; TO: s_perfNumLevels[PS_VDD_ARM] = DEV_SM_NUM_PERF_LVL_ARM;//Force to work on the SOD mode.  Then rebuild the imx-system-manager and generate a new image. Write the images to the i.MX95 19x19 lpddr5 EVK board. Run the board and boot up. root@imx95-19x19-lpddr5-evk:~# cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_available_frequencies 500000 900000 1404000 1800000 2004000 root@imx95-19x19-lpddr5-evk:~# cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_max_freq 2004000 BCU tool show that VDD_ARM is 1.0v when "running" at 2.0GHz and VDD_ARM is 0.9v when running at 1.8GHz, so the SOD is working. I did the the above change and tested on NXP imx95 1.8GHz 19x19 lpddr5 EVK board and the SOD worked 4\Summary So For the MIMX9596DVZXQAC the BSP is expected to automatically detect 2.0 GHz capability and enable SOD mode without source code modifications. EVK Modification The forced SM modification described above: DEV_SM_NUM_PERF_LVL_ARM is intended only for evaluation and debug purposes. It bypasses the normal speed-grade detection mechanism and should not be considered a production configuration for non-qualified devices. For the customer's MIMX9596DVZXQAC device: No BSP modification should be required. System Manager automatically checks the speed grade. If the device reports 2.0 GHz capability, SOD is enabled automatically. Linux only needs to request the highest CPU frequency. SOD operation can be verified by: Availability of 2004000 kHz CPU running at 2.0 GHz VDD_ARM increasing from ~0.9 V to ~1.0 V This confirms successful operation in Super Overdrive (SOD) Mode.
View full article
We are pleased to announce that Config Tools for i.MX 26.06 are now available. Downloads & links To download the installer for all platforms, please login to our download site via:  https://www.nxp.com/design/designs/config-tools-for-i-mx-applications-processors:CONFIG-TOOLS-IMX Please refer to  Documentation  for installation and quick start guides. For further information about DDR config and validation, please go to this  blog post. Release Notes Full details on the release (features, known issues...) Version 26.06 DDR tool – NXP-validated memory configurations for multiple vendors is available System Manager – extended CLI support for a headless setting
View full article
The layer attached to this article is obsolete. Please use the meta-imx-fastboot GitHub repo instead.   The purpose of this article is to show how to reduce the boot time on i.MX 8QXP using U-Boot Falcon Mode. The general technique is presented in the AN14093. This article was tested on LF-6.6.23-2.0.0 BSP. How to do it 1. Follow the steps in the i.MX Yocto Project User's Guide and prepare your Yocto building environment. We will further assume that the BSP is in the ~/imx-yocto-bsp directory and the build directory is ~/imx-yocto-bsp/build. 2. Unpack the attached archive in ~/imx-yocto-bsp/sources. This should create the ~/imx-yocto-bsp/sources/meta-imx-fastboot directory.  3. Add the meta-imx-fastboot layer to your build using the following command: bitbake-layers add-layer ~/imx-yocto-bsp/sources/meta-imx-fastboot 4. If you've previously built an image in the same tree, clean the u-boot-imx and imx-boot packages using the following command: bitbake -c clean u-boot-imx imx-boot 5. Build the new image. Out of the box, this package is configured for core-image-minimal. We will show you below how to adapt it for other images: bitbake core-image-minimal 6. Write the resulted image on eMMC/SD using your preferred method and boot the board. 7. By default, the board will boot normally. To enable fast boot, stop the board in U-Boot, and run the following command: u-boot => run prepare_fdt 8. Reboot the board. From this point on, the board should boot in fast mode. Far less messages will be printed by the kernel or systemd during boot. You may further optimize the boot time by removing unnecessary features from the kernel and/or removing unnecessary services started by systemd. Please refer to AN14093. 9. If you ever want to re-enter U-Boot, please keep the 'c' key pressed in the serial console during board power-on. It's easiest if you press and keep the 'c' key pressed before powering on/pressing the reset button. How it works The layer we've added contains patches for U-Boot, ATF and imx-mkimage. In addition, it modifies the core-image-minimal recipe. In U-Boot, the necessary options for Falcon Mode are added in a new configuration file, named imx8qxp_mek_falcon_defconfig, as well as an implementation of the spl_start_uboot() function. In ATF, the device tree load address is added in the correct parameter. In mkimage, two new targets are created: kernel-atf-container.img (to be deployed in the boot partition) and uImage (to be deployed in the rootfs). The change in the core-image-minimal recipe ensures that the new files are copied in the resulting image. If you want to build a different image, you need to copy the content of core-image-minimal.bbappend in a new file, named according to the image you want to build. For example, if you want to build imx-image-full, you could use the following command: cp ~/imx-yocto-bsp/sources/meta-imx-fastboot/recipes-fsl/images/core-image-minimal.bbappend ~/imx-yocto-bsp/sources/meta-imx-fastboot/recipes-fsl/images/imx-image-full.bbappend       *** DISCLAIMER *** Any support, information, and technology (“Materials”) provided by NXP are provided AS IS, without any warranty express or implied, and NXP disclaims all direct and indirect liability and damages in connection with the Material to the maximum extent permitted by the applicable law. NXP accepts no liability for any assistance with applications or product design. Materials may only be used in connection with NXP products. Any feedback provided to NXP regarding the Materials may be used by NXP without restriction.
View full article
This page serves as a hub to gather the links to all the currently available ISP supported camera lists for the i.MX Applications processors.  Camera Compatibility Guides Processor/Family Link to Guide i.MX 8M Plus i.MX 8M Plus ISP Camera Compatibility Guide i.MX 95 i.MX 95 ISP Camera Compatibility Guide   Additional Resources i.MX Camera Software Pack AN AN14376: i.MX Camera Software Pack | NXP Semiconductors
View full article
The purpose of this document is to provide extended guidance for selection of compatible Non-Volatile Memory (NVM) devices that are supported by the Ara240 (aka Ara-2) processors. In all cases, it is strongly recommended to follow the memory layout guidelines outlined in the specific SoC requirement documents.   Manufacturer Memory Part Number Capacity Renesas NOR SPI FLASH AT25SL321-UUE-T 32Mbit (4MB) ISSI NOR SPI FLASH IS25WJ032F-JTLE-TR 32Mbit (4MB) ISSI NOR SPI FLASH IS25WP032D-JBLE 32Mbit (4MB) Winbond NOR SPI FLASH W25Q16JVSNIQ 16Mbit (2MB) Winbond NOR SPI FLASH W25Q32JWUUIQ 32Mbit (4MB) Winbond NOR SPI FLASH W25Q64JWSSIQ 64Mbit (8MB) XMC NOR SPI FLASH XM25LU64CVIQT 64Mbit (8MB)   Note 1: All memory parts are in production unless stated otherwise. Checked June 2026
View full article
The purpose of this document is to provide extended guidance for selection of compatible LPDDR4 memory devices that are supported by the Ara240 (aka Ara-2) processors. In all cases, it is strongly recommended to follow the DRAM layout guidelines outlined in the specific SoC requirement documents. LPDDR4 - maximum supported densities SoC Max Data bus width Maximum density Number of Interfaces Assumed memory organization Notes Ara240 64-bit 128Gb/16GB 2 Dual rank, Dual channel device with 17-row addresses 1   LPDDR4 - list of validated memories The validation process is an ongoing effort - regular updates of the table are expected. SoC Density Memory Vendor Validated Memory Part# Notes Ara240 64Gb/(8GB) Total 128Gb/(16GB) (2 x 64Gb/8GB) Micron   MT53E2G32D4DE-046 AUT:C  MT53E2G32D4DE-046 WT:C - 64Gb/(8GB) Total 128Gb/(16GB) (2 x 64Gb/8GB)   FORESEE FLXC4008G-30  2 16Gb/(2GB) Total: 32Gb/(4GB) (2 x 16Gb/2GB) Micron MT53E512M32D1ZW-046BAUT:B     - 32Gb/(4GB) Total 64Gb/8GB (2 x 32Gb/4GB)   Micron MT53E1G32D2NP-046 WT:B - 16Gb/(2GB) Total: 32Gb/(4GB) (2 x 16Gb/2GB) SK Hynix H54G46CYRQX053N - 32Gb/(4GB) Total 64Gb/8GB (2 x 32Gb/4GB) SK Hynix H54G56CYRB-X247 421Y H54G56CYRB-X247 316A - 4Gb/(512MB) Total 8Gb/1GB (2 x 4Gb/1GB) SK Hynix H54G26AYRBX256 - 16Gb/(2GB) Total: 32Gb/(4GB) (2 x 16Gb/2GB) Samsung K4F6E3S4HB-KHCL      - 32Gb/(4GB) Total 64Gb/8GB (2 x 32Gb/4GB) ISSI IS43LQ32K01B 2 32Gb/(4GB) Total 64Gb/8GB (2 x 32Gb/4GB) Samsung K4UBE3D4AB-MGCL - 8Gb/(1GB) Total 16Gb/2GB (2 x 8Gb/1GB)   Winbond W66DP2RQQAHJ 2   Note: This device supports operation with LPDDR4 memories only. LPDDR4x operation is not supported. Dual‑mode memories that support both LPDDR4 and LPDDR4x are allowed as long as the device can operate in LPDDR4 mode, including using LPDDR4 I/O voltage levels and initialization sequences.   Note 1: The numbers are based purely on the IP documentation for the DDR Controller and the DDR PHY, on the settings of the implementation parameters chosen for their integration into the SoC, SoC reference manual and on the JEDEC standards JESD209-4C (LPDDR4). Therefore, they are not backed by validation, unless said otherwise and there is no guarantee that an SoC with the specific density and/or desired internal organization is offered by the memory vendors. Should the customers choose to use the maximum density and assume it in the intended use case, they do it at their own risk. Note 2: The memory part number did not undergo full JEDEC verification however, it passed all functional testing items. Note 3: Memory devices with binary densities (e.g., 1 GB, 2 GB, 4 GB) are preferred because they simplify memory management by aligning with system addressing schemes and reducing software complexity. Note 4: All memory parts are in production unless stated otherwise. Checked June 2026 Note 5: The processor does not support BYTE Mode (x8) memories.
View full article
