i.MX 93 Memory Compatibility Guide
The purpose of this document is to provide extended guidance for the selection of compatible LPDDR4/4X memory devices that are supported by the i.MX 93 series of processors. In all cases, it is strongly recommended to follow the DRAM layout guidelines outlined in the NXP Hardware Developer's Guides for the specific SoCs.
The i.MX 93 series of processors supports different packages, and each have their own maximum supported LPDDR4/4x data rates. Please refer to the respective datasheets.
Memory devices with binary densities (e.g., 1 GB, 2 GB, 4 GB) are preferred because they simplify memory management by aligning with system addressing schemes and reducing software complexity.
NOTE: Some of the LPDDR4/4X devices may not support operation at low speeds and in addition, DQ ODT may not be active, which can impact signal integrity at these speeds. If low-speed operation is planned in the use case, please consult with the memory vendor about the configuration aspects and possible customization of the memory device so correct functionality is ensured.
LPDDR4/4X - Maximum Supported Densities
SoC Max Data bus width Maximum density Assumed memory organization Notes
i.MX 93
(i.MX 93xx)
16-bit 16 Gb / (2 GB) single rank, single channel device with 17-row addresses (R0 - R16) 1, 2, 3
LPDDR4/4X - List of Validated Memories
The validation process is an ongoing effort - regular updates of the table are expected.
SoC Density Memory Vendor Validated Memory Part# Notes
i.MX 93
16 Gb/ (2 GB) Micron
LPDDR4/4x:
MT53E1G16D1FW-046 AAT:A
(Z32N)
MT53E1G16D1ZW-046 AAT:C (Z42N)
7
4, 8
8 Gb/ (1 GB) Micron
LPDDR4/4x:
MT53D512M16D1DS-046 AAT (Z11M)
4, 10
LPDDR4/4x:
MT53E1G32D2FW-046 AUT:B (Z42M)
4, 5, 10
8 Gb/ (1 GB)
Nanya
LPDDR4:
NT6AN512M16AV-J1I
LPDDR4x:
NT6AP512M16BV-J1I
4, 8
4 Gb/ (512 MB)
Nanya
LPDDR4x:
NT6AP256M16AV
4, 8
16 Gb/ (2 GB)
Kingston
LPDDR4:
D1611PM3BDGUI-U
4, 8
16 Gb/ (2 GB)
Kingston
LPDDR4:
C1612PC2WDGTKR-U
7, 9
4 Gb/ (512 MB)
ISSI
LPDDR4:
IS43LQ16256B-062BLI
4, 8
2 Gb / (256 MB)
ISSI
LPDDR4:
IS43LQ16128A-062BSLI
4, 6, 8
  8 Gb/ (1 GB)
CXMT
LPDDR4/4x:
CXDB4CBAM-EA-M
4, 9
16 Gb/ (2 GB)
JSC
LPDDR4x:
JSL4BAG167ZAMF
4, 8
8 Gb/ (1 GB)
JSC
LPDDR4x:
JSL4B8G168ZAMF-05x
4, 8
4 Gb/ (512 MB)
JSC
LPDDR4x:
JSL4A4G168ZAMF-05
4, 8
2 Gb / (256 MB)
Winbond
 LPDDR4x:
W66BQ6NBHAGJ
4, 6, 8
8 Gb / (1 GB)
IM
(Intelligent Memory)
LPDDR4x:
IM8G16L4JCB-046I
4, 11
16 Gb / (2 GB)
IM
LPDDR4/4x:
IMAG16L4KBBG
4, 8
4 Gb / (512 MB)
Samsung
LPDDR4:
K4F4E164HD-THCL
4, 8
8Gb / (1 GB)
AM
(Alliance Memory)
LPDDR4X:
AS4C512M16MD4V-053BIN
4, 8
4 Gb / (512 MB)
ISSI
LPDDR4/4X:
IS43LQ16256B-053BLI
4, 8
8 Gb / (1 GB)
ISSI
LPDDR4/4X:
IS46LQ16512B-046BLA2
4, 8
32Gb / (4GB)
16 Gb / (2Gb) usable by i.MX 93
ISSI
LPDDR4/4X:
IS46LQ32K01B-046BLI
4, 8
Note 1:
The numbers are based purely on the IP documentation for the DDR Controller and the DDR PHY, on the settings of the implementation parameters chosen for their integration into the SoC, SoC reference manual and on the JEDEC standards JESD209-4B/JESD209-4-1 (LPDDR4/4X). Therefore, they are not backed by validation, unless said otherwise and there is no guarantee that an SoC with the specific density and/or desired internal organization is offered by the memory vendors. Should the customers choose to use the maximum density and assume it in the intended use case, they do it at their own risk.
Note 2:
Byte-mode LPDDR4/4X devices (x16 channel internally split between two dies, x8 each) of any density are not supported therefore, the numbers are applicable only to devices with x16 internal organization (referred to as "standard" in the JEDEC specification).
Note 3:
The SoC also supports dual rank single channel devices therefore, 16Gb/2GB density can be also achieved by using a dual rank single channel device with 16-row addresses (R0 - R15).
Note 4:
The memory part number did not undergo full JEDEC verification however, it passed all functional testing items.
Note 5:
This is a dual channel x32 device. Since i.MX93 only supports 16-bit LPDDR4/X data bus, it can only interface with one of the channels and therefore, utilize only half of the device's density. As indicated in the table - the device has 32Gb/4GB density however, only 16Gb/2GB can be used. There is no functional problem with using only one channel of a dual channel device as the channels are independent in LPDDR4/4X.
Note 6:
This is a new JEDEC 100 ball package, half the size of the standard 200 ball package. This 100 ball package has the same performance and functionality as the 200 ball package, and has the added advantage of being smaller and cheaper than the standard package.
Note 7:
This device has been EoLed by the manufacturer and has been updated by a new memory part number
Note 8:
Part is active. Reviewed Q3 2026
Note 9:
Part is obsolete.
Note 10:
This device will be EoLed in Q2 24 by the manufacturer and will not be updated by a new memory part number
Note 11:
DQ eye marginalities were identified during TSA analysis. vTSA and stability testing did not identify any issues.
%3CLINGO-SUB%20id%3D%22lingo-sub-1725656%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX%2093%E3%83%A1%E3%83%A2%E3%83%AA%E4%BA%92%E6%8F%9B%E6%80%A7%E3%82%AC%E3%82%A4%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1725656%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%0A%3CP%3E%3CSPAN%3E%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AE%E7%9B%AE%E7%9A%84%E3%81%AF%E3%80%81i.MX%2093%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%81%AE%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%A7%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%80%81%E4%BA%92%E6%8F%9B%E6%80%A7%E3%81%AE%E3%81%82%E3%82%8BLPDDR4%2F4X%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%BB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E5%B9%85%E5%BA%83%E3%81%84%E6%8C%87%E9%87%9D%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%84%E3%81%9A%E3%82%8C%E3%81%AE%E5%A0%B4%E5%90%88%E3%82%82%E3%80%81%E7%89%B9%E5%AE%9A%E3%81%AESoC%E3%81%AE%E3%80%8CNXP%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E9%96%8B%E7%99%BA%E8%80%85%E3%82%AC%E3%82%A4%E3%83%89%E3%80%8D%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8BDRAM%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%E3%83%BB%E3%82%AC%E3%82%A4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AB%E5%8F%AF%E8%83%BD%E3%81%AA%E9%99%90%E3%82%8A%E5%BE%93%E3%81%86%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3Ei.MX%2093%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%81%AE%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%AF%E3%81%95%E3%81%BE%E3%81%96%E3%81%BE%E3%81%AA%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%82%8B%E6%9C%80%E5%A4%A7LPDDR4%2F4x%E3%83%87%E3%83%BC%E3%82%BF%E3%83%BB%E3%83%AC%E3%83%BC%E3%83%88%E3%81%AF%E3%81%9D%E3%82%8C%E3%81%9E%E3%82%8C%E7%95%B0%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E8%A9%B3%E7%B4%B0%E3%81%AF%E3%80%81%E5%90%84%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3E%3CSTRONG%3E%E6%B3%A8%EF%BC%9A%3C%2FSTRONG%3E%3CFONT%20color%3D%22%230000FF%22%3E%E4%B8%80%E9%83%A8%E3%81%AELPDDR4%2F4X%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AF%E4%BD%8E%E9%80%9F%E3%81%A7%E3%81%AE%E5%8B%95%E4%BD%9C%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81DQ%20ODT%E3%81%8C%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E3%81%A7%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81%E4%BD%8E%E9%80%9F%E6%99%82%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8B%E4%BF%A1%E5%8F%B7%E3%81%AE%E6%95%B4%E5%90%88%E6%80%A7%E3%81%AB%E5%BD%B1%E9%9F%BF%E3%81%99%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E4%BD%8E%E9%80%9F%E5%8B%95%E4%BD%9C%E3%81%A7%E3%81%AE%E4%BD%BF%E7%94%A8%E3%82%92%E8%A8%88%E7%94%BB%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%BB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E6%A7%8B%E6%88%90%E3%82%84%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%9E%E3%82%A4%E3%82%BA%E3%81%AE%E5%8F%AF%E5%90%A6%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AE%E3%83%99%E3%83%B3%E3%83%80%E3%83%BC%E3%81%AB%E7%A2%BA%E8%AA%8D%E3%81%97%E3%80%81%E6%AD%A3%E5%B8%B8%E3%81%AA%E6%A9%9F%E8%83%BD%E3%82%92%E7%A2%BA%E4%BF%9D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FFONT%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3CH3%20id%3D%22toc-hId-1255326383%22%20id%3D%22toc-hId-2004178908%22%3ELPDDR4%2F4X%20-%20%E6%9C%80%E5%A4%A7%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E5%AF%86%E5%BA%A6%3C%2FH3%3E%0A%3CTABLE%20border%3D%221%22%20width%3D%22100%25%22%3E%0A%3CTBODY%3E%0A%3CTR%20style%3D%22background-color%3A%20cyan%3B%22%3E%0A%3CTD%20width%3D%2220%25%22%20height%3D%2269px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CSTRONG%3ESoC%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2220%25%22%20height%3D%2269px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CSTRONG%3E%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AE%E6%9C%80%E5%A4%A7%E3%83%90%E3%82%B9%E5%B9%85%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2220%25%22%20height%3D%2269px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CSTRONG%3E%E6%9C%80%E5%A4%A7%E5%AF%86%E5%BA%A6%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2220%25%22%20height%3D%2269px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CSTRONG%3E%E6%83%B3%E5%AE%9A%E3%83%A1%E3%83%A2%E3%83%AA%E6%A7%8B%E6%88%90%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2220%25%22%20height%3D%2269px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CSTRONG%3E%E5%82%99%E8%80%83%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2220%25%22%20height%3D%22113px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%0A%3CP%3E%3CSTRONG%3Ei.MX%2093%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E(i.MX%2093xx)%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2220%25%22%20height%3D%22113px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E16%E3%83%93%E3%83%83%E3%83%88%3C%2FTD%3E%0A%3CTD%20width%3D%2220%25%22%20height%3D%22113px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E16Gb%2F%EF%BC%882GB%EF%BC%89%3C%2FTD%3E%0A%3CTD%20width%3D%2220%25%22%20height%3D%22113px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E17%E8%A1%8C%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%EF%BC%88R0%20-%20R16%EF%BC%89%E3%82%92%E6%8C%81%E3%81%A4%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%E3%83%BB%E3%83%A9%E3%83%B3%E3%82%AF%E3%80%81%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%E3%83%BB%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%83%BB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3C%2FTD%3E%0A%3CTD%20width%3D%2220%25%22%20height%3D%22113px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E1%2C%202%2C%203%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CH3%20id%3D%22toc-hId--552128080%22%20id%3D%22toc-hId-196724445%22%3E%26nbsp%3B%3C%2FH3%3E%0A%3CH3%20id%3D%22toc-hId-1935384753%22%20id%3D%22toc-hId--1610730018%22%3ELPDDR4%2F4X%20-%20%E6%A4%9C%E8%A8%BC%E6%B8%88%E3%81%BF%E3%83%A1%E3%83%A2%E3%83%AA%E4%B8%80%E8%A6%A7%3C%2FH3%3E%0A%3CP%3E%3CSPAN%3E%E6%A4%9C%E8%A8%BC%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%81%AF%E7%B6%99%E7%B6%9A%E7%9A%84%E3%81%AA%E5%8F%96%E3%82%8A%E7%B5%84%E3%81%BF%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%81%AF%E5%AE%9A%E6%9C%9F%E7%9A%84%E3%81%AB%E6%9B%B4%E6%96%B0%E3%81%95%E3%82%8C%E3%82%8B%E4%BA%88%E5%AE%9A%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CTABLE%20style%3D%22width%3A%20100%25%3B%22%20border%3D%221%22%20width%3D%22100%25%22%3E%0A%3CTBODY%3E%0A%3CTR%20style%3D%22background-color%3A%20cyan%3B%20height%3A%2069px%3B%22%3E%0A%3CTD%20width%3D%2211.455331412103748%25%22%20height%3D%2269px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CSTRONG%3ESoC%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2213.32853025936599%25%22%20height%3D%2269px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CSTRONG%3E%E5%AF%86%E5%BA%A6%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2215.760086455331408%25%22%20height%3D%2269px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CSTRONG%3E%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%99%E3%83%B3%E3%83%80%E3%83%BC%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2221.95605187319885%25%22%20height%3D%2269px%22%3E%3CSTRONG%3E%E6%A4%9C%E8%A8%BC%E6%B8%88%E3%81%BF%E3%83%A1%E3%83%A2%E3%83%AA%E9%83%A8%E5%93%81%E7%95%AA%E5%8F%B7%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2212.5%25%22%20height%3D%2269px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CSTRONG%3E%E5%82%99%E8%80%83%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20rowspan%3D%2216%22%20width%3D%2211.455331412103748%25%22%20height%3D%221389px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CSTRONG%3Ei.MX%2093%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2213.32853025936599%25%22%20height%3D%22178px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E16%20Gb%2F%20(2%20GB)%3C%2FTD%3E%0A%3CTD%20width%3D%2215.760086455331408%25%22%20height%3D%22178px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3EMicron%3C%2FTD%3E%0A%3CTD%20width%3D%2221.95605187319885%25%22%20height%3D%22178px%22%3E%0A%3CP%3E%3CSTRONG%3E%3CFONT%20size%3D%222%22%3ELPDDR4%2F4x%3A%20%3C%2FFONT%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3EMT53E1G16D1FW-046%20AAT%3AA%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3E(Z32N)%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3EMT53E1G16D1%3CSTRONG%3EZ%3C%2FSTRONG%3EW-046%20AAT%3AC%20(Z42N)%3C%2FFONT%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2212.5%25%22%20height%3D%22178px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%0A%3CP%3E7%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E4%2C%208%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2213.32853025936599%25%22%20height%3D%22102px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E8%20Gb%2F%20(1%20GB)%3C%2FTD%3E%0A%3CTD%20width%3D%2215.760086455331408%25%22%20height%3D%22102px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3EMicron%3C%2FTD%3E%0A%3CTD%20width%3D%2221.95605187319885%25%22%20height%3D%22102px%22%3E%0A%3CP%3E%3CSTRONG%3E%3CFONT%20size%3D%222%22%3ELPDDR4%2F4x%3A%3C%2FFONT%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3EMT53D512M16D1DS-046%20AAT%20(Z11M)%3C%2FFONT%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2212.5%25%22%20height%3D%22102px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E4%2C%2010%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2213.32853025936599%25%22%20height%3D%22102px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E16%20Gb%2F%20(2%20GB)%3C%2FTD%3E%0A%3CTD%20width%3D%2215.760086455331408%25%22%20height%3D%22102px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3EMicron%3C%2FTD%3E%0A%3CTD%20width%3D%2221.95605187319885%25%22%20height%3D%22102px%22%3E%0A%3CP%3E%3CSTRONG%3E%3CFONT%20size%3D%222%22%3ELPDDR4%2F4x%3A%20%3C%2FFONT%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3EMT53E1G32D2FW-046%20AUT%3AB%20(Z42M)%3C%2FFONT%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2212.5%25%22%20height%3D%22102px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E4%2C%205%2C%2010%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2213.32853025936599%25%22%20height%3D%22155px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E8%20Gb%2F%20(1%20GB)%3C%2FTD%3E%0A%3CTD%20width%3D%2215.760086455331408%25%22%20height%3D%22155px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%0A%3CP%3ENanya%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2221.95605187319885%25%22%20height%3D%22155px%22%3E%0A%3CP%3E%3CSTRONG%3E%3CFONT%20size%3D%222%22%3ELPDDR4%3A%20%3C%2FFONT%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3ENT6AN512M16AV-J1I%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%3CFONT%20size%3D%222%22%3ELPDDR4x%3A%3C%2FFONT%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3ENT6AP512M16BV-J1I%3C%2FFONT%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2212.5%25%22%20height%3D%22155px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E4%2C%208%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2213.32853025936599%25%22%20height%3D%2279px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E4%20Gb%2F%EF%BC%88512%20MB%EF%BC%89%3C%2FTD%3E%0A%3CTD%20width%3D%2215.760086455331408%25%22%20height%3D%2279px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%0A%3CP%3ENanya%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2221.95605187319885%25%22%20height%3D%2279px%22%3E%0A%3CP%3E%3CSTRONG%3E%3CFONT%20size%3D%222%22%3ELPDDR4x%3A%3C%2FFONT%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3ENT6AP256M16AV%26nbsp%3B%3C%2FFONT%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2212.5%25%22%20height%3D%2279px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E4%2C%208%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2213.32853025936599%25%22%20height%3D%2279px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E16%20Gb%2F%20(2%20GB)%3C%2FTD%3E%0A%3CTD%20width%3D%2215.760086455331408%25%22%20height%3D%2279px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%0A%3CP%3EKingston%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2221.95605187319885%25%22%20height%3D%2279px%22%3E%0A%3CP%3E%3CSTRONG%3E%3CFONT%20size%3D%222%22%3ELPDDR4%3A%3C%2FFONT%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3EC1612PC2WDGTKR-U%3C%2FFONT%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2212.5%25%22%20height%3D%2279px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E7%2C%209%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2213.32853025936599%25%22%20height%3D%2279px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E8%20Gb%2F%20(1%20GB)%3C%2FTD%3E%0A%3CTD%20width%3D%2215.760086455331408%25%22%20height%3D%2279px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%0A%3CP%3EISSI%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2221.95605187319885%25%22%20height%3D%2279px%22%3E%0A%3CP%3E%3CSTRONG%3E%3CFONT%20size%3D%222%22%3ELPDDR4%3A%3C%2FFONT%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3EIS43LQ16512A-053BLI%20%3C%2FFONT%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2212.5%25%22%20height%3D%2279px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E4%2C%208%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2213.32853025936599%25%22%20height%3D%2279px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%26nbsp%3B%208%20Gb%2F%20(1%20GB)%3C%2FTD%3E%0A%3CTD%20width%3D%2215.760086455331408%25%22%20height%3D%2279px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%0A%3CP%3ECXMT%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2221.95605187319885%25%22%20height%3D%2279px%22%3E%0A%3CP%3E%3CSTRONG%3E%3CFONT%20size%3D%222%22%3ELPDDR4%2F4x%3A%3C%2FFONT%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3ECXDB4CBAM-EA-M%3C%2FFONT%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2212.5%25%22%20height%3D%2279px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E4%2C%209%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2213.32853025936599%25%22%20height%3D%2279px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E16%20Gb%2F%20(2%20GB)%3C%2FTD%3E%0A%3CTD%20width%3D%2215.760086455331408%25%22%20height%3D%2279px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%0A%3CP%3EJSC%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2221.95605187319885%25%22%20height%3D%2279px%22%3E%0A%3CP%3E%3CSTRONG%3E%3CFONT%20size%3D%222%22%3ELPDDR4x%3A%3C%2FFONT%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3EJSL4BAG167ZAMF%26nbsp%3B%3C%2FFONT%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2212.5%25%22%20height%3D%2279px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E4%2C%208%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2213.32853025936599%25%22%20height%3D%2279px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E8%20Gb%2F%20(1%20GB)%3C%2FTD%3E%0A%3CTD%20width%3D%2215.760086455331408%25%22%20height%3D%2279px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%0A%3CP%3EJSC%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2221.95605187319885%25%22%20height%3D%2279px%22%3E%0A%3CP%3E%3CSTRONG%3E%3CFONT%20size%3D%222%22%3ELPDDR4x%3A%3C%2FFONT%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3EJSL4B8G168ZAMF-05x%26nbsp%3B%3C%2FFONT%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2212.5%25%22%20height%3D%2279px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E4%2C%208%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2213.32853025936599%25%22%20height%3D%2279px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E4%20Gb%2F%EF%BC%88512%20MB%EF%BC%89%3C%2FTD%3E%0A%3CTD%20width%3D%2215.760086455331408%25%22%20height%3D%2279px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%0A%3CP%3EJSC%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2221.95605187319885%25%22%20height%3D%2279px%22%20class%3D%22lia-align-left%22%20style%3D%22text-align%20%3A%20left%3B%22%20style%3D%22text-align%20%3A%20left%3B%22%3E%0A%3CP%3E%3CSTRONG%3E%3CFONT%20size%3D%222%22%3ELPDDR4x%3A%3C%2FFONT%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3EJSL4A4G168ZAMF-05%3C%2FFONT%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2212.5%25%22%20height%3D%2279px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E4%2C%208%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2213.32853025936599%25%22%20height%3D%2279px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E2Gb%2F%EF%BC%88256MB%EF%BC%89%3C%2FTD%3E%0A%3CTD%20width%3D%2215.760086455331408%25%22%20height%3D%2279px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%0A%3CP%3EWinbond%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2221.95605187319885%25%22%20height%3D%2279px%22%20class%3D%22lia-align-left%22%20style%3D%22text-align%20%3A%20left%3B%22%20style%3D%22text-align%20%3A%20left%3B%22%3E%0A%3CP%3E%3CSTRONG%3E%3CFONT%20size%3D%222%22%3E%26nbsp%3BLPDDR4x%3A%3C%2FFONT%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3EW66BQ6NBHAGJ%3C%2FFONT%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2212.5%25%22%20height%3D%2279px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E4%2C%206%2C%208%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2213.32853025936599%25%22%20height%3D%2279px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E8Gb%2F%EF%BC%881GB%EF%BC%89%3C%2FTD%3E%0A%3CTD%20width%3D%2215.760086455331408%25%22%20height%3D%2279px%22%3E%0A%3CP%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3EIM%3C%2FP%3E%0A%3CP%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CFONT%20size%3D%222%22%3E(Intelligent%20Memory)%3C%2FFONT%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2221.95605187319885%25%22%20height%3D%2279px%22%3E%0A%3CP%3E%3CSTRONG%3E%3CFONT%20size%3D%222%22%3ELPDDR4x%3A%3C%2FFONT%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3EIM8G16L4JCB-046I%3C%2FFONT%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2212.5%25%22%20height%3D%2279px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E4%2C%2011%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2213.32853025936599%25%22%20height%3D%2279px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E4Gb%2F%EF%BC%88512MB%EF%BC%89%3C%2FTD%3E%0A%3CTD%20width%3D%2215.760086455331408%25%22%20height%3D%2279px%22%3E%0A%3CP%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3ESamsung%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2221.95605187319885%25%22%20height%3D%2279px%22%3E%0A%3CP%3E%3CSTRONG%3E%3CFONT%20size%3D%222%22%3ELPDDR4%3A%3C%2FFONT%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3EK4F4E164HD-THCL%3C%2FFONT%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2212.5%25%22%20height%3D%2279px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E4%2C%208%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20height%3D%2262px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E8Gb%2F%EF%BC%881GB%EF%BC%89%3C%2FTD%3E%0A%3CTD%20height%3D%2262px%22%3E%0A%3CP%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3EAM%EF%BC%88Alliance%20Memory%EF%BC%89%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20height%3D%2262px%22%3E%0A%3CP%3E%3CSTRONG%3E%3CFONT%20size%3D%222%22%3ELPDDR4X%3A%3C%2FFONT%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3EAS4C512M16MD4V-053BIN%3C%2FFONT%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20height%3D%2262px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E4%2C%208%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E2Gb%2F%EF%BC%88256MB%EF%BC%89%3C%2FTD%3E%0A%3CTD%3E%0A%3CP%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3EISSI%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%3E%0A%3CP%3E%3CSTRONG%3E%3CFONT%20size%3D%222%22%3ELPDDR4%3A%3C%2FFONT%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3EIS46LQ16128A-062BSLI%3C%2FFONT%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E4%2C%206%2C%208%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CH3%20class%3D%22lia-align-center%22%20id%3D%22toc-hId-127930290%22%20style%3D%22text-align%3A%20center%3B%22%20id%3D%22toc-hId-876782815%22%20style%3D%22text-align%3A%20center%3B%22%3E%26nbsp%3B%3C%2FH3%3E%0A%3CP%3E%3CSTRONG%3E%E6%B3%A81%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3E%E5%80%A4%E3%81%AF%E3%80%81IDDR%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%81%A8DDR%20PHY%E3%81%AEIP%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%80%81SoC%E3%81%B8%E3%81%AE%E7%B5%B1%E5%90%88%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E9%81%B8%E6%8A%9E%E3%81%95%E3%82%8C%E3%81%9F%E5%AE%9F%E8%A3%85%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%80%81SoC%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%83%BB%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3JEDEC%E8%A6%8F%E6%A0%BCJESD209-4B%2FJESD209-4-1%EF%BC%88LPDDR4%2F4X%EF%BC%89%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E5%80%A4%E3%81%AF%E3%80%81%E7%89%B9%E3%81%AB%E6%98%8E%E8%A8%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E9%99%90%E3%82%8A%E3%80%81%E6%A4%9C%E8%A8%BC%E3%81%AB%E3%82%88%E3%82%8B%E8%A3%8F%E4%BB%98%E3%81%91%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81%E7%89%B9%E5%AE%9A%E3%81%AE%E5%AF%86%E5%BA%A6%E3%81%8A%E3%82%88%E3%81%B3%2F%E3%81%BE%E3%81%9F%E3%81%AF%E5%B8%8C%E6%9C%9B%E3%81%99%E3%82%8B%E5%86%85%E9%83%A8%E6%A7%8B%E6%88%90%E3%81%AESoC%E3%81%8C%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%BB%E3%83%99%E3%83%B3%E3%83%80%E3%83%BC%E3%81%8B%E3%82%89%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%82%8B%E4%BF%9D%E8%A8%BC%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%81%8C%E6%9C%80%E5%A4%A7%E5%AF%86%E5%BA%A6%E3%81%AE%E4%BD%BF%E7%94%A8%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%80%81%E7%9B%AE%E7%9A%84%E3%81%A8%E3%81%99%E3%82%8B%E3%83%A6%E3%83%BC%E3%82%B9%E3%83%BB%E3%82%B1%E3%83%BC%E3%82%B9%E3%81%A7%E3%81%9D%E3%81%AE%E6%97%A8%E3%82%92%E6%83%B3%E5%AE%9A%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E8%87%AA%E5%B7%B1%E8%B2%AC%E4%BB%BB%E3%81%AE%E4%B8%8B%E3%81%A7%E3%81%9D%E3%81%86%E3%81%99%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%E3%83%A1%E3%83%A2%202%3A%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3E%E3%83%90%E3%82%A4%E3%83%88%E3%83%BB%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AELPDDR4%2F4X%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%EF%BC%88x16%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%81%8C%E5%86%85%E9%83%A8%E3%81%A7%E5%90%84x8%E3%81%AE2%E3%81%A4%E3%81%AE%E3%83%80%E3%82%A4%E3%81%AB%E5%88%86%E5%89%B2%E3%81%95%E3%82%8C%E3%82%8B%EF%BC%89%E3%81%AF%E3%80%81%E3%81%A9%E3%81%AE%E5%AF%86%E5%BA%A6%E3%81%A7%E3%82%82%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81%E6%95%B0%E5%80%A4%E3%81%AFx16%E3%81%AE%E5%86%85%E9%83%A8%E6%A7%8B%E6%88%90%EF%BC%88JEDEC%E4%BB%95%E6%A7%98%E3%81%A7%E3%81%AF%E3%80%8C%E6%A8%99%E6%BA%96%E3%80%8D%E6%A7%8B%E6%88%90%EF%BC%89%E3%82%92%E6%8C%81%E3%81%A4%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AB%E3%81%AE%E3%81%BF%E9%81%A9%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%E6%B3%A83%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3ESoC%E3%81%AF%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB%E3%83%BB%E3%83%A9%E3%83%B3%E3%82%AF%E3%81%AE%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%E3%83%BB%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%83%BB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%82%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%80%8116%E8%A1%8C%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%EF%BC%88R0%20-%20R15%EF%BC%89%E3%81%AE%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB%E3%83%BB%E3%83%A9%E3%83%B3%E3%82%AF%E3%81%AE%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%E3%83%BB%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%83%BB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%825%E5%AF%86%E5%BA%A616Gb%2F2GB%E3%82%92%E9%81%94%E6%88%90%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%E3%83%A1%E3%83%A2%204%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3E%E3%83%A1%E3%83%A2%E3%83%AA%E9%83%A8%E5%93%81%E7%95%AA%E5%8F%B7%E3%81%AF%E5%AE%8C%E5%85%A8%E3%81%AA%20JEDEC%20%E6%A4%9C%E8%A8%BC%E3%82%92%E5%8F%97%E3%81%91%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E6%A9%9F%E8%83%BD%E3%83%86%E3%82%B9%E3%83%88%E9%A0%85%E7%9B%AE%E3%81%AB%E5%90%88%E6%A0%BC%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%E3%83%A1%E3%83%A2%205%3A%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3E%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB%E3%83%BB%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%81%AEx32%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A7%E3%81%99%E3%80%82i.MX93%E3%81%AF16%E3%83%93%E3%83%83%E3%83%88%E3%81%AELPDDR4%2FX%E3%83%87%E3%83%BC%E3%82%BF%E3%83%BB%E3%83%90%E3%82%B9%E3%81%AE%E3%81%BF%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E6%8E%A5%E7%B6%9A%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%AE%E3%81%AF1%E3%81%A4%E3%81%AE%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%81%AE%E3%81%BF%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E5%88%A9%E7%94%A8%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%AE%E3%81%AF%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E5%AF%86%E5%BA%A6%E3%81%AE%E5%8D%8A%E5%88%86%E3%81%AB%E3%81%A8%E3%81%A9%E3%81%BE%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E8%A1%A8%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%82%8B%E3%81%A8%E3%81%8A%E3%82%8A%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E5%AF%86%E5%BA%A6%E3%81%AF32Gb%2F4GB%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%AE%E3%81%AF16Gb%2F2GB%E3%81%AB%E9%99%90%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB%E3%83%BB%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%83%BB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A71%E3%81%A4%E3%81%AE%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%81%AE%E3%81%BF%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%82%E3%80%81LPDDR4%2F4X%E3%81%A7%E3%81%AF%E5%90%84%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%81%8C%E7%8B%AC%E7%AB%8B%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E6%A9%9F%E8%83%BD%E4%B8%8A%E5%95%8F%E9%A1%8C%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FFONT%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%E6%B3%A86%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3E%E6%96%B0%E3%81%97%E3%81%84JEDEC%20100%E3%83%9C%E3%83%BC%E3%83%AB%E3%83%BB%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%A7%E3%80%81%E6%A8%99%E6%BA%96%E3%81%AE200%E3%83%9C%E3%83%BC%E3%83%AB%E3%83%BB%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%AE%E5%8D%8A%E5%88%86%E3%81%AE%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%A7%E3%81%99%E3%80%82200%E3%83%9C%E3%83%BC%E3%83%AB%E3%83%BB%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%A8%E5%90%8C%E3%81%98%E6%80%A7%E8%83%BD%E3%81%A8%E6%A9%9F%E8%83%BD%E3%82%92%E5%82%99%E3%81%88%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E6%A8%99%E6%BA%96%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%88%E3%82%8A%E3%82%82%E5%B0%8F%E5%9E%8B%E3%81%A7%E5%AE%89%E4%BE%A1%E3%81%A7%E3%81%82%E3%82%8B%E3%81%A8%E3%81%84%E3%81%86%E5%88%A9%E7%82%B9%E3%82%82%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%E6%B3%A8%EF%BC%97%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3E%E3%83%A1%E3%83%BC%E3%82%AB%E3%83%BC%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E7%94%9F%E7%94%A3%E7%B5%82%E4%BA%86%E3%81%A8%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%E3%83%A1%E3%83%A2%E3%83%AA%E9%83%A8%E5%93%81%E7%95%AA%E5%8F%B7%E3%81%AB%E6%9B%B4%E6%96%B0%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3E%3CFONT%20size%3D%223%22%3E%3CSTRONG%3E%E6%B3%A88%EF%BC%9A%3C%2FSTRONG%3E%3C%2FFONT%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3E%E9%83%A8%E5%93%81%E3%81%AF%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E3%81%A7%E3%81%82%E3%82%8A%E3%80%812025%E5%B9%B46%E6%9C%88%E3%81%AB%E3%83%AC%E3%83%93%E3%83%A5%E3%83%BC%E6%B8%88%E3%81%BF%E3%81%A7%E3%81%99%E3%80%82%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3E%3CFONT%20size%3D%223%22%3E%3CSTRONG%3E%E6%B3%A89%EF%BC%9A%3C%2FSTRONG%3E%3C%2FFONT%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3E%E6%97%A7%E5%9E%8B%E3%81%AE%E9%83%A8%E5%93%81%E3%81%A7%E3%81%99%E3%80%82%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%E6%B3%A810%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3E%E3%83%A1%E3%83%BC%E3%82%AB%E3%83%BC%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A62024%E5%B9%B4%E7%AC%AC2%E5%9B%9B%E5%8D%8A%E6%9C%9F%E3%81%AB%E7%94%9F%E7%94%A3%E7%B5%82%E4%BA%86%E3%81%A8%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E6%96%B0%E3%81%97%E3%81%84%E3%83%A1%E3%83%A2%E3%83%AA%E9%83%A8%E5%93%81%E7%95%AA%E5%8F%B7%E3%81%AB%E3%81%AF%E6%9B%B4%E6%96%B0%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%E6%B3%A8%2011%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3ETSA%E5%88%86%E6%9E%90%E4%B8%AD%E3%81%ABDQ%E7%9B%AE%E8%A6%96%E3%81%A7%E8%BB%BD%E5%BE%AE%E3%81%AA%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E8%A6%8B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82vTSA%E3%81%A8%E5%AE%89%E5%AE%9A%E6%80%A7%E3%83%86%E3%82%B9%E3%83%88%E3%81%A7%E3%81%AF%E5%95%8F%E9%A1%8C%E3%81%AF%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FFONT%3E%3C%2FP%3E%0A%3C%2FLINGO-BODY%3E
100%が役に立ったと言っています (8/8)
バージョン履歴
最終更新日:
3 週間前
更新者:
