Ara-240 - NVM Memory Compatibility Guide
The purpose of this document is to provide extended guidance for selection of compatible Non-Volatile Memory (NVM) devices that are supported by the Ara240 (aka Ara-2) processors. In all cases, it is strongly recommended to follow the memory layout guidelines outlined in the specific SoC requirement documents.
Manufacturer Memory Part Number Capacity
Renesas NOR SPI FLASH AT25SL321-UUE-T 32Mbit (4MB)
ISSI NOR SPI FLASH IS25WJ032F-JTLE-TR 32Mbit (4MB)
ISSI NOR SPI FLASH IS25WP032D-JBLE 32Mbit (4MB)
Winbond NOR SPI FLASH W25Q16JVSNIQ 16Mbit (2MB)
Winbond NOR SPI FLASH W25Q32JWUUIQ 32Mbit (4MB)
Winbond NOR SPI FLASH W25Q64JWSSIQ 64Mbit (8MB)
XMC NOR SPI FLASH XM25LU64CVIQT 64Mbit (8MB)
Note 1:
All memory parts are in production unless stated otherwise. Checked June 2026
评论
无评分
版本历史
最后更新:
‎06-22-2026 04:36 AM
更新人:
