Updates to i.MX93 Reference Manual Rev. 7
The table below contains notable updates to the Rev 7 release of the i.MX 93 Applications Processor Reference Manual.
Affected Modules Issue Summary Description Date
Chapter 1 - Introduction
Incorrect TPM channel count
Section 1.1.2 - Features:
States that each TPM instance “Includes 6 channels that can be configured for input capture, output compare, edge-aligned PWM mode, or center-aligned PWM mode.”
Correct information: Includes 4 channels that can be configured for input capture, output compare, edge-aligned PWM mode, or center-aligned PWM mode.
08-03-2026
ラベル(3)
評価なし
バージョン履歴
最終更新日:
‎08-02-2026 11:00 PM
更新者:
