CodeWarrior for MCU document list
The following is a list of our documents in regards to developing MCU on CodeWarrior platform.
If you need to log an issue in Case System,  or obtain a license for your CodeWarrior product, please refer to:  How to log an issue in Case system instead CRM (Service request - not used anymore)?
1.  CodeWarrior Common Feature
1.1 Reversion Release History
CodeWarrior for MCU V10.6 Update 3.0.0 available
New CodeWarrior for MCU v10.6.4 available
CodeWarrior v10.6.4 Update 5 available
1.2 IDE and Installation
How install (or check availability) patch and update under Eclipse ?
How to solve “IDE failed to start …” message - Classic version on Windows OS (most of the time 64 bi...
1.3 Project Management
Convert a Processor Expert project from linked mode to standalone mode
1.4 Build Tool Chain (Assembler, Compiler, Linker)
Linking and compiling with CodeWarrior
Classic - How to use dashboard (Jenkins) to build a CodeWarrior project?
2. CodeWarrior for Kinetis
2.1 Board Bring-up
How to work KV10 with CW10.5
2.2 RTOS
MQX applications...new at this, too?~
2.3 Build Tool Chain (Assembler, Compiler, Linker)
How to fill unused memory for CW for 8/16bit and kinetis Gnu.
Interrupt Vector Redirection Method in Kinetis
Relocating Code and Data Using the CW GCC Linker File for Kinetis
Relocate Code (configuration linker files) - CW10.6 - Kinetis
Extended inline assembly with GCC in CodeWarrior
2.4 Programmer and Debugger
Preserve Memory Ranges In CodeWarrior v10.6
3. CodeWarrior for MPC5xxx
3.1 Build Tool Chain (Assembler, Compiler, Linker)
Generate CRC value for MPC56xx in CodeWarrior for MCU v10.6.4
3.2 Programmer and Debugger
Debug code using CodeWarrior 10.5
Flash two .elf files using CodeWarrior 10.6
4. CodeWarrior for DSC
4.1 Project Management
How to migrate PE project from Classic CodeWarrior to Eclipse CodeWarrior
How to solve PE bean migration for 56F84xxx in CodeWarrior V10.3
4.2 Build Tool Chain (Assembler, Compiler, Linker)
To use 56F800EX new additional 32bit multiplication instructions on CodeWarrior V10.3/V10.5/V10.6.
4.3 Programmer and Debugger
Workaround for programming 56F8323 in CodeWarrior v10.6 debugger
4.4 External Tool Integration
Integrate Quick Start 2.6 for DSC with CodeWarrior 10.6.4
Using TWR-56f8400 board with FreeMASTER via USBTAP interface
5. CodeWarrior for Coldfire
5.1 Build Tool Chain (Assembler, Compiler, Linker)
Relocating code with CodeWarrior
CodeWarrior and ColdFire get optimized!
5.2 Programmer and Debugger
Problem with Multilink Rev C  - not running after MCU V10.6 Update3 installed & CW for MCF V7.2
6. CodeWarrior for 8/16bit MCU
6.1 IDE and Installation
CW MCU v10.5 for 8bit MCU Banked Memory Patch Installation
6.2 Build Tool Chain (Assembler, Compiler, Linker)
Classic - Is it possible (How) to use HCS12 on Eclipse?
%3CLINGO-SUB%20id%3D%22lingo-sub-1109127%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ECodeWarrior%20for%20MCU%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E4%B8%80%E8%A6%A7%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1109127%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20font-size%3A%2012pt%3B%22%3E%E4%BB%A5%E4%B8%8B%E3%81%AF%E3%80%81CodeWarrior%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%81%A7%E3%81%AEMCU%E3%81%AE%E9%96%8B%E7%99%BA%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AE%E3%83%AA%E3%82%B9%E3%83%88%E3%81%A7%E3%81%99%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20font-size%3A%2012pt%3B%22%3ECase%20System%E3%81%A7%E5%95%8F%E9%A1%8C%E3%82%92%E8%A8%98%E9%8C%B2%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AFCodeWarrior%E8%A3%BD%E5%93%81%E3%81%AE%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%82%92%E5%8F%96%E5%BE%97%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%83%9A%E3%83%BC%E3%82%B8%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3A%20%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%222020%22%20data-containertype%3D%2214%22%20data-objectid%3D%22330215%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-330215%22%20target%3D%22_blank%22%3ECRM%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8FCase%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%A7%E5%95%8F%E9%A1%8C%E3%82%92%E8%A8%98%E9%8C%B2%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%EF%BC%88%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%83%AA%E3%82%AF%E3%82%A8%E3%82%B9%E3%83%88%20-%20%E3%82%82%E3%81%86%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%EF%BC%89%3C%2FA%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20font-size%3A%2014pt%3B%22%3E%3CSTRONG%3E1.%20CodeWarrior%E3%81%AE%E5%85%B1%E9%80%9A%E6%A9%9F%E8%83%BD%20%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E1.1%20%E3%83%AA%E3%83%90%E3%83%BC%E3%83%88%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E5%B1%A5%E6%AD%B4%20%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId-380754124%22%20id%3D%22toc-hId-1303201810%22%3E%3C%2FH1%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%222020%22%20data-containertype%3D%2214%22%20data-objectid%3D%22103415%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-103415%22%20target%3D%22_blank%22%3ECodeWarrior%20for%20MCU%20V10.6%20%E3%82%A2%E3%83%83%E3%83%97%E3%83%87%E3%83%BC%E3%83%88%203.0.0%E5%88%A9%E7%94%A8%E3%81%A7%E3%81%8D%E3%82%8B%3C%2FA%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%222028%22%20data-containertype%3D%2214%22%20data-objectid%3D%22104810%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-104810%22%20target%3D%22_blank%22%3E%E6%96%B0%E3%81%97%E3%81%84%20CodeWarrior%20for%20MCU%20v10.6.4%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%3C%2FA%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%222028%22%20data-containertype%3D%2214%22%20data-objectid%3D%22143655%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-143655%22%20target%3D%22_blank%22%3ECodeWarrior%20v10.6.4%E3%82%A2%E3%83%83%E3%83%97%E3%83%87%E3%83%BC%E3%83%88%205%20%E3%81%8C%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%3C%2FA%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%3CSTRONG%3E1.2%20IDE%20%E3%81%A8%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%222028%22%20data-containertype%3D%2214%22%20data-objectid%3D%22105862%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-105862%22%20target%3D%22_blank%22%3EEclipse%E3%81%A7%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB(%E3%81%BE%E3%81%9F%E3%81%AF%E5%8F%AF%E7%94%A8%E6%80%A7%E3%82%92%E7%A2%BA%E8%AA%8D)%E3%81%97%E3%81%A6%E6%9B%B4%E6%96%B0%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%222031%22%20data-containertype%3D%2214%22%20data-objectid%3D%22105603%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-105603%22%20target%3D%22_blank%22%3E%E3%80%8CIDE%E3%81%AE%E8%B5%B7%E5%8B%95%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F...%E3%80%8D%E3%81%AE%E8%A7%A3%E6%B1%BA%E6%96%B9%E6%B3%95%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%20-%20Windows%20OS%E3%81%AE%E3%82%AF%E3%83%A9%E3%82%B7%E3%83%83%E3%82%AF%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3(%E3%81%BB%E3%81%A8%E3%82%93%E3%81%A9%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81Win%207%E3%81%BE%E3%81%9F%E3%81%AFWin%208.1%E3%81%A8%E3%81%97%E3%81%A664%E3%83%93%E3%83%83%E3%83%88)%3C%2FA%3E%20%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20font-size%3A%2012pt%3B%22%3E%3CSTRONG%3E1.3%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E7%AE%A1%E7%90%86%20%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%222020%22%20data-containertype%3D%2214%22%20data-objectid%3D%22102109%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-102109%22%20target%3D%22_blank%22%3EProcessor%20Expert%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E3%83%AA%E3%83%B3%E3%82%AF%E3%83%A2%E3%83%BC%E3%83%89%E3%81%8B%E3%82%89%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%89%E3%82%A2%E3%83%AD%E3%83%B3%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E5%A4%89%E6%8F%9B%E3%81%99%E3%82%8B%3C%2FA%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSTRONG%3E1.4%20%E3%83%93%E3%83%AB%E3%83%89%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3(%E3%82%A2%E3%82%BB%E3%83%B3%E3%83%96%E3%83%A9%E3%80%81%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%80%81%E3%83%AA%E3%83%B3%E3%82%AB)%20%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%222020%22%20data-containertype%3D%2214%22%20data-objectid%3D%2293315%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-93315%22%20target%3D%22_blank%22%3ECodeWarrior%E3%81%A8%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%A8%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%222031%22%20data-containertype%3D%2214%22%20data-objectid%3D%22328274%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-328274%22%20target%3D%22_blank%22%3E%20%E3%82%AF%E3%83%A9%E3%82%B7%E3%83%83%E3%82%AF%20-%20%E3%83%80%E3%83%83%E3%82%B7%E3%83%A5%E3%83%9C%E3%83%BC%E3%83%89(Jenkins)%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6CodeWarrior%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AF%3F%3C%2FA%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%3CSTRONG%3E2.%20Kinetis%E3%81%AECodeWarrior%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20font-size%3A%2012pt%3B%22%3E%3CSTRONG%3E2.1%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E8%82%B2%E6%88%90%20%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%222020%22%20data-containertype%3D%2214%22%20data-objectid%3D%22100175%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-100175%22%20target%3D%22_blank%22%3ECW10.5%E3%81%A7KV10%E3%82%92%E6%93%8D%E4%BD%9C%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FA%3E%20%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20font-size%3A%2012pt%3B%22%3E%3CSTRONG%3E2.2%20RTOS%26nbsp%3B%20%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%222028%22%20data-containertype%3D%2214%22%20data-objectid%3D%2293606%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-93606%22%20target%3D%22_blank%22%3EMQX%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3...%E3%81%93%E3%82%8C%E3%82%82%E5%88%9D%E3%82%81%E3%81%A6%E3%81%A7%E3%81%99%E3%81%8B~%3C%2FA%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20font-size%3A%2012pt%3B%22%3E%3CSTRONG%3E2.3%20%E3%83%93%E3%83%AB%E3%83%89%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3(%E3%82%A2%E3%82%BB%E3%83%B3%E3%83%96%E3%83%A9%E3%80%81%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%80%81%E3%83%AA%E3%83%B3%E3%82%AB)%20%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%222020%22%20data-containertype%3D%2214%22%20data-objectid%3D%22101437%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-101437%22%20target%3D%22_blank%22%3ECW%E3%81%AE8%2F16bit%E3%81%8A%E3%82%88%E3%81%B3kinetis%20Gnu%E3%81%AE%E6%9C%AA%E4%BD%BF%E7%94%A8%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92%E5%9F%8B%E3%82%81%E3%82%8B%E6%96%B9%E6%B3%95%E3%80%82%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%222020%22%20data-containertype%3D%2214%22%20data-objectid%3D%22103961%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-103961%22%20target%3D%22_blank%22%3EKinetis%E3%81%AE%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%83%99%E3%82%AF%E3%83%88%E3%83%AB%E3%83%BB%E3%83%AA%E3%83%80%E3%82%A4%E3%83%AC%E3%82%AF%E3%83%88%E6%96%B9%E5%BC%8F%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%222020%22%20data-containertype%3D%2214%22%20data-objectid%3D%22101433%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-101433%22%20target%3D%22_blank%22%3EKinetis%E3%81%AECW%20GCC%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A8%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AE%E5%86%8D%E9%85%8D%E7%BD%AE%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%222028%22%20data-containertype%3D%2214%22%20data-objectid%3D%22103533%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-103533%22%20target%3D%22_blank%22%3E%E5%86%8D%E9%85%8D%E7%BD%AE%E3%82%B3%E3%83%BC%E3%83%89%20(%E3%82%B3%E3%83%B3%E3%83%95%E3%82%A3%E3%82%B0%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%BB%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB)%20-%20CW10.6%20-%20Kinetis%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%222028%22%20data-containertype%3D%2214%22%20data-objectid%3D%22102460%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-102460%22%20target%3D%22_blank%22%3ECodeWarrior%E3%81%AEGCC%E3%81%AB%E3%82%88%E3%82%8B%E3%82%A4%E3%83%B3%E3%83%A9%E3%82%A4%E3%83%B3%E3%83%BB%E3%82%A2%E3%82%BB%E3%83%B3%E3%83%96%E3%83%AA%E3%81%AE%E6%8B%A1%E5%BC%B5%3C%2FA%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20font-size%3A%2012pt%3B%22%3E%3CSTRONG%3E2.4%20%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9E%E3%83%BC%E3%81%A8%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%83%BC%20%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%222020%22%20data-containertype%3D%2214%22%20data-objectid%3D%22102167%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-102167%22%20target%3D%22_blank%22%3ECodeWarrior%20v10.6%E3%81%A7%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%E7%AF%84%E5%9B%B2%E3%81%AE%E4%BF%9D%E6%8C%81%3C%2FA%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20font-size%3A%2014pt%3B%22%3E%3CSTRONG%3E3.%20MPC5xxx%E3%81%AECodeWarrior%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%3CSTRONG%3E3.1%20%E3%83%93%E3%83%AB%E3%83%89%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3(%E3%82%A2%E3%82%BB%E3%83%B3%E3%83%96%E3%83%A9%E3%80%81%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%80%81%E3%83%AA%E3%83%B3%E3%82%AB)%20%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%222028%22%20data-containertype%3D%2214%22%20data-objectid%3D%22329541%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-329541%22%20target%3D%22_blank%22%3ECodeWarrior%20for%20MCU%20v10.6.4%20%E3%81%A7%E3%81%AE%20MPC56xx%20%E3%81%AE%20CRC%20%E5%80%A4%E3%81%AE%E7%94%9F%E6%88%90%3C%2FA%3E%20%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20font-size%3A%2012pt%3B%22%3E%3CSTRONG%3E3.2%20%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9E%E3%81%A8%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%20%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%222028%22%20data-containertype%3D%2214%22%20data-objectid%3D%22329937%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-329937%22%20target%3D%22_blank%22%3ECodeWarrior%2010.5%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%222028%22%20data-containertype%3D%2214%22%20data-objectid%3D%22329754%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-329754%22%20target%3D%22_blank%22%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A52%20.elfCodeWarrior%2010.6%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3C%2FA%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%3CSTRONG%3E4.%20DSC%E7%94%A8%E3%81%AECodeWarrior%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20font-size%3A%2012pt%3B%22%3E%3CSTRONG%3E4.1%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E7%AE%A1%E7%90%86%20%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%222020%22%20data-containertype%3D%2214%22%20data-objectid%3D%2297317%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-97317%22%20target%3D%22_blank%22%3EPE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92Classic%20CodeWarrior%E3%81%8B%E3%82%89Eclipse%20CodeWarrior%E3%81%AB%E7%A7%BB%E8%A1%8C%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%222028%22%20data-containertype%3D%2214%22%20data-objectid%3D%2297318%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-97318%22%20target%3D%22_blank%22%3ECodeWarrior%20V10.3%E3%81%A756F84xxx%E3%81%AEPE%20Bean%E7%A7%BB%E8%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FA%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20font-size%3A%2012pt%3B%22%3E%3CSTRONG%3E4.2%20%E3%83%93%E3%83%AB%E3%83%89%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3(%E3%82%A2%E3%82%BB%E3%83%B3%E3%83%96%E3%83%A9%E3%80%81%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%80%81%E3%83%AA%E3%83%B3%E3%82%AB)%20%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%222020%22%20data-containertype%3D%2214%22%20data-objectid%3D%22101347%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-101347%22%20target%3D%22_blank%22%3ECodeWarrior%20V10.3%2FV10.5%2FV10.6%E3%81%A756F800EX%E3%81%AE%E6%96%B0%E3%81%97%E3%81%84%E8%BF%BD%E5%8A%A0%E3%81%AE32%E3%83%93%E3%83%83%E3%83%88%E4%B9%97%E7%AE%97%E5%91%BD%E4%BB%A4%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%82%3C%2FA%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20font-size%3A%2012pt%3B%22%3E%3CSTRONG%3E4.3%20%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9E%E3%81%A8%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%20%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%20auto%3B%20margin-bottom%3A%20auto%3B%22%3E%3CSTRONG%3E%20%3C%2FSTRONG%3E%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%222020%22%20data-containertype%3D%2214%22%20data-objectid%3D%22105548%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-105548%22%20target%3D%22_blank%22%3ECodeWarrior%20v10.6%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%81%A756F8323%E3%82%92%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E5%9B%9E%E9%81%BF%E7%AD%96%3C%2FA%3E%20%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20font-size%3A%2012pt%3B%22%3E%3CSTRONG%3E4.4%20%E5%A4%96%E9%83%A8%E3%83%84%E3%83%BC%E3%83%AB%E3%81%AE%E7%B5%B1%E5%90%88%20%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%222028%22%20data-containertype%3D%2214%22%20data-objectid%3D%22330273%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-330273%22%20target%3D%22_blank%22%3EDSC%20%E3%81%AE%E3%82%AF%E3%82%A4%E3%83%83%E3%82%AF%20%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%88%202.6%20%E3%81%A8%20CodeWarrior%2010.6.4%20%E3%81%AE%E7%B5%B1%E5%90%88%3C%2FA%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%20auto%3B%20margin-bottom%3A%20auto%3B%22%3E%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%222020%22%20data-containertype%3D%2214%22%20data-objectid%3D%22106024%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-106024%22%20target%3D%22_blank%22%3ETWR-56f8400%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A8FreeMASTER%E3%82%92USBTAP%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%82%A4%E3%82%B9%E7%B5%8C%E7%94%B1%E3%81%A7%E4%BD%BF%E7%94%A8%3C%2FA%3E%20%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%20%3CSTRONG%3E5.%E3%82%B3%E3%83%BC%E3%83%AB%E3%83%89%E3%83%95%E3%82%A1%E3%82%A4%E3%82%A2%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A9%E3%83%AA%E3%82%A2%E3%83%BC%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20font-size%3A%2012pt%3B%22%3E%3CSTRONG%3E%20%3C%2FSTRONG%3E%3CSTRONG%3E5.1%20%E3%83%93%E3%83%AB%E3%83%89%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3(%E3%82%A2%E3%82%BB%E3%83%B3%E3%83%96%E3%83%A9%E3%80%81%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%80%81%E3%83%AA%E3%83%B3%E3%82%AB)%20%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%222020%22%20data-containertype%3D%2214%22%20data-objectid%3D%2293302%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-93302%22%20target%3D%22_blank%22%3ECodeWarrior%20%E3%81%AB%E3%82%88%E3%82%8B%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E5%86%8D%E9%85%8D%E7%BD%AE%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%222020%22%20data-containertype%3D%2214%22%20data-objectid%3D%2293301%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-93301%22%20target%3D%22_blank%22%3ECodeWarrior%20%E3%81%A8%20ColdFire%20%E3%81%8C%E6%9C%80%E9%81%A9%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99!%3C%2FA%3E%20%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%3CSTRONG%3E5.2%20%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9E%E3%81%A8%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%20%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%222028%22%20data-containertype%3D%2214%22%20data-objectid%3D%22105610%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-105610%22%20target%3D%22_blank%22%3EMultilink%20Rev%20C%20%E3%81%AE%E5%95%8F%E9%A1%8C%20-%20MCU%20V10.6%20Update3%20%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E5%BE%8C%E3%81%8A%E3%82%88%E3%81%B3%20MCF%20V7.2%20%E3%81%AE%20CW%20%E5%BE%8C%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%AA%E3%81%84%3C%2FA%3E%20%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20font-size%3A%2014pt%3B%22%3E%3CSTRONG%3E6.%208%2F16%E3%83%93%E3%83%83%E3%83%88MCU%E7%94%A8CodeWarrior%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%3CSTRONG%3E6.1%20IDE%20%E3%81%A8%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%20auto%3B%20margin-bottom%3A%20auto%3B%22%3E%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%222028%22%20data-containertype%3D%2214%22%20data-objectid%3D%22100012%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-100012%22%20target%3D%22_blank%22%3ECW%20MCU%20v10.5%20for%208bit%20MCU%20Banked%20Memory%20Patch%20Patch%20%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FA%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20font-size%3A%2012pt%3B%22%3E%3CSTRONG%3E6.2%20%E3%83%93%E3%83%AB%E3%83%89%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3(%E3%82%A2%E3%82%BB%E3%83%B3%E3%83%96%E3%83%A9%E3%80%81%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%80%81%E3%83%AA%E3%83%B3%E3%82%AB)%20%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%20auto%3B%20margin-bottom%3A%20auto%3B%22%3E%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%222031%22%20data-containertype%3D%2214%22%20data-objectid%3D%22329670%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-329670%22%20target%3D%22_blank%22%3E%E3%82%AF%E3%83%A9%E3%82%B7%E3%83%83%E3%82%AF%20-%20Eclipse%E3%81%A7HCS12%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FA%3E%20%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%20auto%3B%20margin-bottom%3A%20auto%3B%22%3E%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%222020%22%20data-containertype%3D%2214%22%20data-objectid%3D%22101437%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-101437%22%20target%3D%22_blank%22%3ECW%E3%81%AE8%2F16bit%E3%81%8A%E3%82%88%E3%81%B3kinetis%20Gnu%E3%81%AE%E6%9C%AA%E4%BD%BF%E7%94%A8%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92%E5%9F%8B%E3%82%81%E3%82%8B%E6%96%B9%E6%B3%95%E3%80%82%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1109127%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E5%85%A8%E8%88%AC%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
評価なし
バージョン履歴
最終更新日:
‎03-25-2016 02:25 AM
更新者:
