How to fill unused memory for CW for 8/16bit and kinetis Gnu.
In many of user applications we use a CRC/checksum to verify that the code/flash on the target is not modified. For this, not only the code/data in flash counts, but as well all the unused gaps in the memory map. Instead to leave it up to the flasher/debugger (which usually erases it to 0xFF), I want to fill it with my pattern. For example 0xAA.
How to implement?
There may be several ways,  but I think the easiest way is to modify linker file.   the linker file structures are different for different MCUs.   For example, CW for 8bit/16bit and Coldfire V1 uses PRM file;  while CW for kinetis Gnu compiler uses ld file. We will talk about each of the case separately.
1. CW for 8bit/16bit and Coldfire V1.
1.1 .  NO FILL command involved.
We define a segment  in prm file
MYCONST_ROM     =  READ_ONLY    0x0870 TO 0x08FF;
Then allocate MYCONST  into it inside PLACEMENT.
MYCONST    INTO  MYCONST_ROM;
In C code, we only define  my_const_var(0xCCDD) at this range.
#pragma CONST_SEG MYCONST
const unsigned int my_const_var = 0xCCDD;
#pragma CONST_SEG DEFAULT
After build, we will see only 0xCCDD in this area in generated s19 file:
S1050870CCDDD9
1.2  use FILL command to fill unused area of MYCONST_ROM
With FILL command we can fill unused area of a section.  Add “FILL 0xAA” :
MYCONST_ROM       =  READ_ONLY 0x0870 TO 0x08FF FILL 0XAA;
Rebuild the project. we will see the rest of the field of MYCONST_ROM  is filled in  S19 file:
S1230870CCDDAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACF
S1230890AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA04
S12308B0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAE4
S12308D0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAC4
S11308F0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA54
2. CW for kinetis GNU compiler:
2.1 . No fill() command involed.
Define segment in MEMORY section:
my_section    (rx) : ORIGIN = 0X00000800, LENGTH = 0x20
define output  SECTION:
.myData :
    . = ALIGN(4);
         KEEP(*(.myData))
    . = ALIGN(4);
}> my_section
In C code, define const variable “my_const” (0xCCCCDDDD)
const int my_const __attribute__((section(".myData"))) = 0xCCCCDDDD;
After build, we will see only 0xCCCCDDDD in this area in generated s19 file:
S1070800DDDDCCCC9E
2.2 Use FILL(0xaa)  command to fill unused area of my_section with 0xAA.
Here is the modified code in ld file, I highlight the code I add:
.myData :
       . = ALIGN(4);
                 KEEP(*(.myData))
    . = ALIGN(4);
    FILL(0xaa)
    . = ORIGIN(my_section) + LENGTH(my_section) ;
  }> my_section
Rebuild the project. we will see the rest of the field of my_section is filled with 0xAA in  S19 file:
S1130800DDDDCCCCAAAAAAAAAAAAAAAAAAAAAAAA9A
S1130810AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA34
コメント
Helpful document!
useful!!!
Helpfull to ensure full memory is fill correctly when using a flash programmer.
Does anyone know if it is possible to output the codesize leaving out the 'Filled' part?
Hi Peter,
What I use too is using SRecord 1.64  as a postbuild step to fill memory.
That way you can do it independently.
As how this works in general, have a look at CRC Checksum Generation with ‘SRecord’ Tools for GNU and Eclipse | MCU on Eclipse
I hope this helps,
Erich
%3CLINGO-SUB%20id%3D%22lingo-sub-1118902%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ECW%E3%81%AE8%2F16bit%E3%81%8A%E3%82%88%E3%81%B3kinetis%20Gnu%E3%81%AE%E6%9C%AA%E4%BD%BF%E7%94%A8%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92%E5%9F%8B%E3%82%81%E3%82%8B%E6%96%B9%E6%B3%95%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1118902%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%E5%A4%9A%E3%81%8F%E3%81%AE%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%20%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E3%81%AF%E3%80%81CRC%2F%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%82%B5%E3%83%A0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%2F%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%8C%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E5%86%85%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%2F%E3%83%87%E3%83%BC%E3%82%BF%E3%81%A0%E3%81%91%E3%81%A7%E3%81%AA%E3%81%8F%E3%80%81%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%9E%E3%83%83%E3%83%97%E5%86%85%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E6%9C%AA%E4%BD%BF%E7%94%A8%E3%81%AE%E3%82%AE%E3%83%A3%E3%83%83%E3%83%97%E3%82%82%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%E3%80%81%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A3%E3%83%BC%2F%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%83%BC(%E9%80%9A%E5%B8%B8%E3%81%AF0xFF%E3%81%AB%E6%B6%88%E5%8E%BB%E3%81%97%E3%81%BE%E3%81%99)%E3%81%AB%E4%BB%BB%E3%81%9B%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E7%A7%81%E3%81%AF%E3%81%9D%E3%82%8C%E3%82%92%E7%A7%81%E3%81%AE%E3%83%91%E3%82%BF%E3%83%BC%E3%83%B3%E3%81%A7%E5%9F%8B%E3%82%81%E3%81%9F%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%9F%E3%81%A8%E3%81%88%E3%81%B0%E3%80%810xAA%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%E5%AE%9F%E8%A3%85%E6%96%B9%E6%B3%95%E3%81%AF%3F%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E6%96%B9%E6%B3%95%E3%81%8C%E3%81%82%E3%82%8B%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E6%9C%80%E3%82%82%E7%B0%A1%E5%8D%98%E3%81%AA%E6%96%B9%E6%B3%95%E3%81%AF%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A0%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%26nbsp%3B%20%E3%83%AA%E3%83%B3%E3%82%AB%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E6%A7%8B%E9%80%A0%E3%81%AF%E3%80%81MCU%20%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E7%95%B0%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%9F%E3%81%A8%E3%81%88%E3%81%B0%E3%80%818%20%E3%83%93%E3%83%83%E3%83%88%2F16%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%20CW%20%E3%81%A8%20Coldfire%20V1%20%E3%81%AF%20PRM%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%20%E4%B8%80%E6%96%B9%E3%80%81kinetisGnu%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%81%AECW%E3%81%AFld%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%82%8C%E3%81%9E%E3%82%8C%E3%81%AE%E3%82%B1%E3%83%BC%E3%82%B9%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E5%80%8B%E5%88%A5%E3%81%AB%E3%81%8A%E8%A9%B1%E3%81%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2016.0pt%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%3CSTRONG%3E1.%208%E3%83%93%E3%83%83%E3%83%88%2F16%E3%83%93%E3%83%83%E3%83%88%E3%81%8A%E3%82%88%E3%81%B3Coldfire%20V1%E7%94%A8%E3%81%AECW%E3%80%82%20%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%3CSTRONG%3E1.1%20.FILL%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AF%E9%96%A2%E4%BF%82%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%3CSPAN%20style%3D%22color%3A%20red%3B%22%3Eprm%3C%2FSPAN%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E5%AE%9A%E7%BE%A9%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20background%3A%20yellow%3B%22%3EMYCONST_ROM%20%3D%20READ_ONLY%200x0870%20%E3%81%8B%E3%82%89%200x08FF%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%E6%AC%A1%E3%81%AB%E3%80%81PLACEMENT%20%E5%86%85%E3%81%A7%20MYCONST%20%E3%82%92%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20background%3A%20yellow%3B%22%3EMYCONST%20%E3%82%92%20MYCONST_ROM%20%E3%81%AB%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3EC%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AF%E3%80%81%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%20color%3A%20black%3B%22%3E%E3%81%93%E3%81%AE%E7%AF%84%E5%9B%B2%E3%81%A7my_const_var(0xCCDD)%3C%2FSPAN%3E%E3%81%AE%E3%81%BF%E3%82%92%E5%AE%9A%E7%BE%A9%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3E%3CSTRONG%3E%23pragma%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%20color%3A%20black%3B%22%3E%20CONST_SEG%20MYCONST%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3E%3CSTRONG%3Econst%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3E%3CSTRONG%3E%E7%AC%A6%E5%8F%B7%E3%81%AA%E3%81%97%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3E%3CSTRONG%3Eint%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%20color%3A%20black%3B%22%3E%20my_const_var%20%3D%200xCCDD%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3E%3CSTRONG%3E%23pragma%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%20color%3A%20black%3B%22%3E%20CONST_SEG%20DEFAULT%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E3%83%93%E3%83%AB%E3%83%89%E5%BE%8C%E3%80%81%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%20s19%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%E9%A0%98%E5%9F%9F%E3%81%AB%200xCCDD%20%E3%81%AE%E3%81%BF%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background%3A%20%23D9D9D9%3B%22%3ES1050870%3CSPAN%20style%3D%22color%3A%20red%3B%22%3E%3CSTRONG%3ECCDD%3C%2FSTRONG%3E%3C%2FSPAN%3ED9%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%3CSTRONG%3E1.2%20FILL%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81MYCONST_ROM%E3%81%AE%E6%9C%AA%E4%BD%BF%E7%94%A8%E9%A0%98%E5%9F%9F%E3%82%92%E5%9F%8B%E3%82%81%3C%2FSTRONG%3E%E3%82%8B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EFILL%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E6%9C%AA%E4%BD%BF%E7%94%A8%E9%A0%98%E5%9F%9F%E3%82%92%E5%9F%8B%E3%82%81%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%80%8CFILL%200xAA%E3%80%8D%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20background%3A%20yellow%3B%22%3EMYCONST_ROM%20%3D%20%3CSPAN%20style%3D%22color%3A%20red%3B%22%3EREAD_ONLY%200x0870%20%E3%81%8B%E3%82%89%200x08FF%200XAA%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E3%83%AA%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E6%AE%8B%E3%82%8A%E3%81%AE%E3%83%95%E3%82%A3%E3%83%BC%E3%83%AB%E3%83%89%E3%81%8CS19%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E5%85%A5%E5%8A%9B%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3EMYCONST_ROM%3C%2FSPAN%3E%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22background%3A%20%23D9D9D9%3B%22%3ES1230870%3CSPAN%20style%3D%22color%3A%20red%3B%22%3ECCDD%3C%2FSPAN%3EAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22background%3A%20%23D9D9D9%3B%22%3ES1230890AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA04%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22background%3A%20%23D9D9D9%3B%22%3ES12308B0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAE4%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22background%3A%20%23D9D9D9%3B%22%3ES12308D0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAC4%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background%3A%20%23D9D9D9%3B%22%3ES11308F0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA54%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background%3A%20%23D9D9D9%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2016.0pt%3B%22%3E%3CSTRONG%3E2.%20kinetis%20GNU%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%81%AECW%3A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%3CSTRONG%3E2.1%20.fill()%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AF%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%20.25in%3B%22%3EMEMORY%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E5%AE%9A%E7%BE%A9%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%20color%3A%20black%3B%22%3E%20%3CSPAN%20style%3D%22background%3A%20yellow%3B%22%3Emy_section%20(rx)%20%3A%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23006699%3B%20background%3A%20yellow%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3E%3CSTRONG%3E%E5%8E%9F%E7%82%B9%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%20color%3A%20black%3B%20background%3A%20yellow%3B%22%3E%20%3D%200X00000800%E3%80%81%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23006699%3B%20background%3A%20yellow%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3E%3CSTRONG%3E%E9%95%B7%E3%81%95%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%20color%3A%20black%3B%20background%3A%20yellow%3B%22%3E%20%3D%200x20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E5%87%BA%E5%8A%9B%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E5%AE%9A%E7%BE%A9%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%20color%3A%20black%3B%22%3E%20.myData%20%3A%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%20color%3A%20black%3B%22%3E%20%7B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%20color%3A%20black%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.%20%3D%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%230099ff%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3E%3CSTRONG%3EALIGN%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%20color%3A%20black%3B%22%3E(4)%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22color%3A%20%230099ff%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3E%3CSTRONG%3EKEEP(*%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%20color%3A%20black%3B%22%3E(.myData))%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%20color%3A%20black%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.%20%3D%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%230099ff%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3E%3CSTRONG%3EALIGN%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%20color%3A%20black%3B%22%3E(4)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%20color%3A%20black%3B%22%3E%7D%26gt%3B%20my_section%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%20color%3A%20black%3B%22%3EC%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A7%E3%80%81const%E5%A4%89%E6%95%B0%E3%80%8Cmy_const%E3%80%8D(0xCCCCDDDD)%E3%82%92%E5%AE%9A%E7%BE%A9%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3E%3CSTRONG%3Econst%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3E%3CSTRONG%3Eint%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%20color%3A%20black%3B%22%3E%20my_const%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3E%3CSTRONG%3E__attribute__%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%20color%3A%20black%3B%22%3E((section(%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%20color%3A%20%232a00ff%3B%22%3E%22.myData%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%20color%3A%20black%3B%22%3E)))%20%3D%200xCCCCDDDD%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E3%83%93%E3%83%AB%E3%83%89%E5%BE%8C%E3%80%81%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%20s19%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E3%81%93%E3%81%AE%E9%A0%98%E5%9F%9F%E3%81%AB%E3%81%AF%200xCCCCDDDD%20%E3%81%A4%E3%81%A0%E3%81%91%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background%3A%20%23D9D9D9%3B%22%3ES1070800%3CSPAN%20style%3D%22color%3A%20red%3B%22%3EDDDDCCCC%3C%2FSPAN%3E9E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%3CSTRONG%3E2.2%20FILL(0xaa)%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81my_section%E3%81%AE%E6%9C%AA%E4%BD%BF%E7%94%A8%E9%A0%98%E5%9F%9F%E3%82%920xAA%E3%81%A7%E5%9F%8B%E3%82%81%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%20.25in%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%20color%3A%20black%3B%22%3E%E3%81%93%E3%82%8C%E3%81%8Cld%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E5%86%85%E3%81%AE%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%81%9F%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%9F%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E5%BC%B7%E8%AA%BF%E8%A1%A8%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%20.25in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%20color%3A%20black%3B%22%3E%20.myData%20%3A%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%20.25in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%20color%3A%20black%3B%22%3E%20%7B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%20color%3A%20black%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.%20%3D%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%230099ff%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3E%3CSTRONG%3EALIGN%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%20color%3A%20black%3B%22%3E(4)%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22color%3A%20%230099ff%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3E%3CSTRONG%3EKEEP(*%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%20color%3A%20black%3B%22%3E(.myData))%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%20.25in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%20color%3A%20black%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.%20%3D%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%230099ff%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3E%3CSTRONG%3EALIGN%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%20color%3A%20black%3B%22%3E(4)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%20.25in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%20color%3A%20black%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22background%3A%20yellow%3B%22%3EFILL(0xaa)%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%20.25in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%20color%3A%20black%3B%20background%3A%20yellow%3B%22%3E%20.%20%3D%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23006699%3B%20background%3A%20yellow%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3E%3CSTRONG%3E%E5%8E%9F%E7%82%B9%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%20color%3A%20black%3B%20background%3A%20yellow%3B%22%3E(my_section)%20%2B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23006699%3B%20background%3A%20yellow%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3E%3CSTRONG%3E%E9%95%B7%E3%81%95%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%20color%3A%20black%3B%20background%3A%20yellow%3B%22%3E(my_section)%20%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%20.25in%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%20color%3A%20black%3B%22%3E%7D%26gt%3B%20my_section%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E3%83%AA%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%20color%3A%20black%3B%22%3E%E6%AE%8B%E3%82%8A%E3%81%AE%E3%83%95%E3%82%A3%E3%83%BC%E3%83%AB%E3%83%89my_section%3C%2FSPAN%3E%20S19%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A70xAA%E3%81%A7%E5%9F%8B%E3%82%81%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%20background%3A%20%23D9D9D9%3B%22%3E%3CSPAN%20style%3D%22color%3A%20red%3B%22%3EDDDDCCCC%3C%2FSPAN%3EAAAAAAAAAAAAAAAAAAAAAAAA9A%20S1130800%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%20background%3A%20%23D9D9D9%3B%22%3ES1130810AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA34%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background%3A%20%23D9D9D9%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background%3A%20%23D9D9D9%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1118902%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E5%85%A8%E8%88%AC%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1118907%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20CW%20%E3%81%AE%208%2F16bit%20%E3%81%A8%20kinetis%20Gnu%20%E3%81%AE%E6%9C%AA%E4%BD%BF%E7%94%A8%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92%E5%9F%8B%E3%82%81%E3%82%8B%E6%96%B9%E6%B3%95%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1118907%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Peter%2C%3C%2FP%3E%3CP%3E%E7%A7%81%E3%82%82%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%AF%E3%80%81%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92%E5%9F%8B%E3%82%81%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E5%BE%8C%E3%81%AE%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%A8%E3%81%97%E3%81%A6%20%3CA%20class%3D%22link-titled%22%20href%3D%22http%3A%2F%2Fsrecord.sourceforge.net%2F%22%20title%3D%22http%3A%2F%2Fsrecord.sourceforge.net%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3ESRecord%201.64%3C%2FA%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%80%81%E7%8B%AC%E7%AB%8B%E3%81%97%E3%81%A6%E8%A1%8C%E3%81%86%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%8C%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%AB%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E6%A9%9F%E8%83%BD%E3%81%99%E3%82%8B%E3%81%8B%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%20%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fmcuoneclipse.com%2F2015%2F04%2F26%2Fcrc-checksum-generation-with-srecord-tools-for-gnu-and-eclipse%2F%22%20title%3D%22https%3A%2F%2Fmcuoneclipse.com%2F2015%2F04%2F26%2Fcrc-checksum-generation-with-srecord-tools-for-gnu-and-eclipse%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EGNU%E3%81%8A%E3%82%88%E3%81%B3Eclipse%E7%94%A8%E3%81%AE%E3%80%8CSRecord%E3%80%8D%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9FCRC%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%82%B5%E3%83%A0%E7%94%9F%E6%88%90%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%20%7CEclipse%E4%B8%8A%E3%81%AEMCU%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%8A%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A6%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EErich%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1118906%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20CW%20%E3%81%AE%208%2F16bit%20%E3%81%A8%20kinetis%20Gnu%20%E3%81%AE%E6%9C%AA%E4%BD%BF%E7%94%A8%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92%E5%9F%8B%E3%82%81%E3%82%8B%E6%96%B9%E6%B3%95%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1118906%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AB%E3%80%81%E3%83%95%E3%83%AB%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E6%BA%80%E3%81%9F%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AB%E5%BD%B9%E7%AB%8B%E3%81%A1%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E'Filled'%E9%83%A8%E5%88%86%E3%82%92%E9%99%A4%E5%A4%96%E3%81%97%E3%81%A6%E3%82%B3%E3%83%BC%E3%83%89%E3%82%B5%E3%82%A4%E3%82%BA%E3%82%92%E5%87%BA%E5%8A%9B%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%80%81%E8%AA%B0%E3%81%8B%E3%81%8C%E7%9F%A5%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1118905%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20CW%20%E3%81%AE%208%2F16bit%20%E3%81%A8%20kinetis%20Gnu%20%E3%81%AE%E6%9C%AA%E4%BD%BF%E7%94%A8%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92%E5%9F%8B%E3%82%81%E3%82%8B%E6%96%B9%E6%B3%95%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1118905%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EGNU%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92%E5%9F%8B%E3%82%81%E3%82%8B%E3%83%88%E3%83%94%E3%83%83%E3%82%AF%E3%81%AE%E8%A9%B3%E7%B4%B0%3A%20%3CA%20href%3D%22http%3A%2F%2Fmcuoneclipse.com%2F2014%2F06%2F23%2Ffilling-unused-memory-with-the-gnu-linker%2F%22%20title%3D%22http%3A%2F%2Fmcuoneclipse.com%2F2014%2F06%2F23%2Ffilling-unused-memory-with-the-gnu-linker%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EGNU%20Linker%E3%81%A7%E6%9C%AA%E4%BD%BF%E7%94%A8%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92%E5%9F%8B%E3%82%81%E3%82%8B%20%7CEclipse%E4%B8%8A%E3%81%AEMCU%3C%2FA%3E%20%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81CRC%E3%82%92%E8%A8%88%E7%AE%97%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%3A%20%3CA%20href%3D%22http%3A%2F%2Fmcuoneclipse.com%2F2015%2F04%2F26%2Fcrc-checksum-generation-with-srecord-tools-for-gnu-and-eclipse%2F%22%20title%3D%22http%3A%2F%2Fmcuoneclipse.com%2F2015%2F04%2F26%2Fcrc-checksum-generation-with-srecord-tools-for-gnu-and-eclipse%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EGNU%E3%81%8A%E3%82%88%E3%81%B3Eclipse%E7%94%A8%E3%81%AE%E3%80%8CSRecord%E3%80%8D%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9FCRC%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%82%B5%E3%83%A0%E7%94%9F%E6%88%90%7CEclipse%E4%B8%8A%E3%81%AEMCU%3C%2FA%3E%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1118904%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20CW%20%E3%81%AE%208%2F16bit%20%E3%81%A8%20kinetis%20Gnu%20%E3%81%AE%E6%9C%AA%E4%BD%BF%E7%94%A8%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92%E5%9F%8B%E3%82%81%E3%82%8B%E6%96%B9%E6%B3%95%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1118904%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BE%BF%E5%88%A9%EF%BC%81%EF%BC%81%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1118903%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20CW%20%E3%81%AE%208%2F16bit%20%E3%81%A8%20kinetis%20Gnu%20%E3%81%AE%E6%9C%AA%E4%BD%BF%E7%94%A8%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92%E5%9F%8B%E3%82%81%E3%82%8B%E6%96%B9%E6%B3%95%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1118903%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%BD%B9%E7%AB%8B%E3%81%A4%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88!%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎07-03-2014 04:11 AM
更新者:
