i.MX6DL LPDDR2 Register Programming Aid
Document created by Mark Middleton Employee on Jun 24, 2015Last modified by m_j on Jan 24, 2017
Version 5Show Document
  • View in full screen mode
This is a detailed programming aid for the registers associated with MMDC initialization. The last sheet formats the register settings for use with ARM RealView ICE. It can also be used with the windows executable for the DDR Stress Test. This programming aid was used for internal Freescale validation boards.
2 people found this helpful
