i.MX Development Miscellanea(i.MX 开发杂记)
  Just sharing some experiences during the development and studying.
  Although, it appears some hardwares, it focuses on software to speed up your developing on your  hardware.
  杂记共享一下在开发和学习过程中的经验。
  虽然涉及一些硬件,但其本身关注软件,希望这些能加速您在自己硬件上的开发。
12/16/2025
iMX8MN DDR3 Frequency Shifting
iMX8MN DDR3 Frequency Shifting - NXP Community
3/4/2025
GPIO USB ID
GPIO USB ID - NXP Community
1/20/2025
MDIO on GPIOs
MDIO on GPIOs - NXP Community
12/09/2024
GPIO LEDs
https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/GPIO-LEDs/ta-p/2009743
10/22/2024
iMX93-EVK PWM LED
https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/iMX93-EVK-PWM-LED/ta-p/1978047
07/25/2024
iMX secondary boot collection
https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/iMX-secondary-boot-collection/ta-p/19169...
07/25/2024
HSM Code-Signing Journey
https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/HSM-Code-Signing-Journey/ta-p/1882244
25JUL2024 - add pkcs11 proxy
                        HSM Code-Signing Journey_25JUL2024.pdf
                         HSM Code-Signing Journey_25JUL2024.txt
06/06/2024
02/07/2024
Device Tree Standalone Compile under Windows
https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/Device-Tree-Standalone-Compile-under-Win...
02/07/2024
i.MX8X security overview and AHAB deep dive
i.MX8X security overview and AHAB deep dive - NXP Community
11/23/2023
“Standalone” Compile Device Tree
https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/Standalone-Compile-Device-Tree/ta-p/1762...
10/26/2023
Linux Dynamic Debug
https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/Linux-Dynamic-Debug/ta-p/1746611
08/10/2023
u-boot environment preset for sdcard mirror
u-boot environment preset for sdcard mirror - NXP Community
06/06/2023
all(bootloader, device tree, Linux kernel, rootfs) in spi nor demo imx8qxpc0 mek
all(bootloader, device tree, Linux kernel, rootfs)... - NXP Community
09/26/2022
parseIVT - a script to help i.MX6 Code Signing
parseIVT - a script to help i.MX6 Code Signing - NXP Community
Provide  run under windows
09/16/2022
create sdcard mirror under windows
create sdcard mirror under windows - NXP Community
08/03/2022
i.MX8MM SDCARD Secondary Boot Demo
https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/i-MX8MM-SDCARD-Secondary-Boot-Demo/ta-p/...
02/16/2022
mx8_ddr_stress_test without UI
https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/mx8-ddr-stress-test-without-UI/ta-p/1414...
12/23/2021
i.MX8 i.MX8X Board Reset
https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/i-MX8-i-MX8X-Board-Reset/ta-p/1391130
12/21/2021
regulator userspace-consumer
https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/regulator-userspace-consumer/ta-p/138994...
11/24/2021
crypto af_alg blackkey demo
crypto af_alg blackkey demo - NXP Community
09/28/2021
u-boot runtime modify Linux device tree(dtb)
u-boot runtime modify Linux device tree(dtb) - NXP Community
08/17/2021
gpio-poweroff demo
https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/gpio-poweroff-demo/ta-p/1324306
08/04/2021
How to use gpio-hog demo
https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/How-to-use-gpio-hog-demo/ta-p/1317709
07/14/2021
SWUpdate OTA i.MX8MM EVK / i.MX8QXP MEK
https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/SWUpdate-OTA-i-MX8MM-EVK-i-MX8QXP-MEK/ta...
04/07/2021
i.MX8QXP eMMC Secondary Boot
https://community.nxp.com/t5/i-MX-Community-Articles/i-MX8QXP-eMMC-Secondary-Boot/ba-p/1257704#M45
03/25/2021
sc_misc_board_ioctl to access the M4 partition from A core side
sc_misc_board_ioctl to access the M4 partition fr... - NXP Community
03/17/2021
How to Changei.MX8X MEK+Base Board  Linux Debug UART
https://community.nxp.com/t5/i-MX-Community-Articles/How-to-Change-i-MX8X-MEK-Base-Board-Linux-Debug...
03/16/2021
How to Change i.MX8MM evk Linux Debug UART
https://community.nxp.com/t5/i-MX-Community-Articles/How-to-Change-i-MX8MM-evk-Linux-Debug-UART/ba-p...
05/06/2020
Linux fw_printenv fw_setenv to access U-Boot's environment variables
Linux fw_printenv fw_setenv to access U-Boot's env... - NXP Community
03/30/2020
i.MX6 DDR calibration/stress for Mass Production
https://community.nxp.com/docs/DOC-346065
03/25/2020
https://community.nxp.com/docs/DOC-345998
02/17/2020
Start your machine learning journey from tensorflow playground
01/15/2020
How to add  iMX8QXP PAD(GPIO) Wakeup
01/09/2020
Understand iMX8QX Hardware Partitioning By Making M4 Hello world Running Correctly
https://community.nxp.com/docs/DOC-345359
09/29/2019
Docker On i.MX6UL With Ubuntu16.04
09/25/2019
Docker On i.MX8MM With Ubuntu
https://community.nxp.com/docs/DOC-344473
Docker On i.MX8QXP With Ubuntu
08/28/2019
eMMC5.0 vs eMMC5.1
https://community.nxp.com/docs/DOC-344265
05/24/2019
How to upgrade  Linux Kernel and dtb on eMMC without UUU
04/12/2019
eMMC RPMB Enhance and GP
https://community.nxp.com/docs/DOC-343116
04/04/2019
How to Dump a GPT SDCard Mirror(Android O SDCard Mirror)
https://community.nxp.com/docs/DOC-343079
04/04/2019
i.MX Create Android SDCard Mirror
https://community.nxp.com/docs/DOC-343078
04/02/2019:
i.MX Linux Binary_Demo Files Tips
https://community.nxp.com/docs/DOC-343075
04/02/2019:
      Update Set fast boot
      eMMC_RPMB_Enhance_and_GP.pdf
02/28/2019:
imx_builder --- standalone build without Yocto
https://community.nxp.com/docs/DOC-342702
08/10/2018:
i.MX6SX M4 MPU Settings For RPMSG update
Update slide CMA Arrangement Consideration
i.MX6SX_M4_MPU_Settings_For_RPMSG_08102018.pdf
07/26/2018
Understand ML With Simplest Code
https://community.nxp.com/docs/DOC-341099
04/23/2018:
    i.MX8M Standalone Build
    i.MX8M Standalone Build.pdf
04/13/2018:
    Add slide CMA Arrangement  Consideration
    i.MX6SX_M4_MPU_Settings_For_RPMSG_04132018.pdf
09/05/2017:
      Update eMMC RPMB, Enhance  and GP
09/01/2017:
08/30/2017:
    Dual LVDS for High Resolution Display(For i.MX6DQ/DLS)
    Dual LVDS for High Resolution Display.pdf
08/27/2017:
  • L3.14.28 Ottbox Porting Notes:
        L3.14.28_Ottbox_Porting_Notes-20150805-2.pdf
  • MFGTool Uboot Share With the Normal Run One:
       MFGTool_Uboot_share_with_NormalRun_sourceCode.pdf
  • Mass Production with programmer
       Mass_Production_with_NAND_programmer.pdf
       Mass_Production_with_emmc_programmer.pdf
       L3.10.53_PianoPI_PortingNote_151102.pdf
  • Audio Codec WM8960 Porting L3.10.53 PianoPI
       AudioCodec_WM8960_Porting_L3.10.53_PianoPI_151012.pdf
  • TouchScreen PianoPI Porting Note
        TouchScreen_PianoPI_PortingNote_151103.pdf
  • Accessing GPIO From UserSpace
       Accessing_GPIO_From_UserSpace.pdf
       https://community.nxp.com/docs/DOC-343344
  • FreeRTOS for i.MX6SX
       FreeRTOS for i.MX6SX.pdf
  • i.MX6SX M4 fastup
       i.MX6SX M4 fastup.pdf
  • i.MX6 SDCARD Secondary Boot Demo
       i.MX6_SDCARD_Secondary_Boot_Demo.pdf
  • i.MX6SX M4 MPU Settings For RPMSG
       i.MX6SX_M4_MPU_Settings_For_RPMSG_10082016.pdf
  • Security
       Security03172017.pdf    NOT related to i.MX, only a short memo
コメント
Hi Biyong,
     Your documents are always helpful, thank you for sharing! I checked the latest "Generate Blob Under Linux" document, but it seems the link doesn't work. Can you please check the link again? Thank you!
Frank
I don't know about what happened.
I use another way to  populate the document.
You can check it can link you to the right place.
And Please let me know it works or not.
Hi Biyong,
    It works! Thank you and look forward for your new document.
Frank
Cool! They are so useful.
Thank you for your sharing!
Looking forward to your update :)
Hi @BiyongSUN ,
It is indeed very helpful and thanks for this.
Manish
%3CLINGO-SUB%20id%3D%22lingo-sub-1104265%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX%20%E9%96%8B%E7%99%BA%E9%9B%91%E8%A8%98(i.MX%20%E5%BC%80%E5%8F%91%E6%9D%82%E8%AE%B0)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104265%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%26nbsp%3B%26nbsp%3B%3CEM%3E%3CSTRONG%3E%E9%96%8B%E7%99%BA%E3%81%A8%E5%8B%89%E5%BC%B7%E4%B8%AD%E3%81%AB%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E7%B5%8C%E9%A8%93%E3%82%92%E5%85%B1%E6%9C%89%E3%81%99%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%E3%80%82%20%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3E%3CEM%3E%3CSTRONG%3E%E4%B8%80%E9%83%A8%E3%81%AE%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%A6%8B%E3%81%88%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%A7%E3%81%AE%E9%96%8B%E7%99%BA%E3%82%92%E3%82%B9%E3%83%94%E3%83%BC%E3%83%89%E3%82%A2%E3%83%83%E3%83%97%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AB%E7%84%A6%E7%82%B9%E3%82%92%E5%BD%93%E3%81%A6%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%3CEM%3E%3CSTRONG%3E%E6%9D%82%E8%AE%B0%E5%85%B1%E4%BA%AB%E4%B8%80%E4%B8%8B%E5%9C%A8%E5%BC%80%E5%8F%91%E5%92%8C%E5%AD%A6%E4%B9%A0%E8%BF%87%E7%A8%8B%E4%B8%AD%E7%9A%84%E7%BB%8F%E9%AA%8C%E3%80%82%26nbsp%3B%20%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3E%3CEM%3E%3CSTRONG%3E%26nbsp%3B%20%E8%99%BD%E7%84%B6%E6%B6%89%E5%8F%8A%E4%B8%80%E4%BA%9B%E7%A1%AC%E4%BB%B6%EF%BC%8C%E4%BD%86%E5%85%B6%E6%9C%AC%E8%BA%AB%E5%85%B3%E6%B3%A8%E8%BD%AF%E4%BB%B6%EF%BC%8C%E5%B8%8C%E6%9C%9B%E8%BF%99%E4%BA%9B%E8%83%BD%E5%8A%A0%E9%80%9F%E6%82%A8%E5%9C%A8%E8%87%AA%E5%B7%B1%E7%A1%AC%E4%BB%B6%E4%B8%8A%E7%9A%84%E5%BC%80%E5%8F%91%E3%80%82%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E3%2F4%2F2025%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3EGPIO%E3%81%AEUSB%20ID%E3%81%AE%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FGPIO-USB-ID%2Fta-p%2F2055354%22%20target%3D%22_blank%22%3EGPIO%20USB%20ID%20-%20NXP%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSTRONG%3E1%2F20%2F2025%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3EGPIO%20%E4%B8%8A%E3%81%AE%20MDIO%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FMDIO-on-GPIOs%2Fta-p%2F2030380%22%20target%3D%22_blank%22%3EGPIO%E4%B8%8A%E3%81%AEMDIO%20-%20NXP%20Community%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSTRONG%3E12%2F09%2F2024%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3EGPIO%20LED%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FGPIO-LEDs%2Fta-p%2F2009743%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FGPIO-LEDs%2Fta-p%2F2009743%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSTRONG%3E10%2F22%2F2024%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3EiMX93-EVK%20PWM%20LED%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FiMX93-EVK-PWM-LED%2Fta-p%2F1978047%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FiMX93-EVK-PWM-LED%2Fta-p%2F1978047%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSTRONG%3E07%2F25%2F2024%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3EiMX%E3%82%BB%E3%82%AB%E3%83%B3%E3%83%80%E3%83%AA%E3%83%96%E3%83%BC%E3%83%88%E3%82%B3%E3%83%AC%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FiMX-secondary-boot-collection%2Fta-p%2F1916915%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FiMX-secondary-boot-collection%2Fta-p%2F1916915%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CSTRONG%3E07%2F25%2F2024%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3EHSM%20%E3%82%B3%E3%83%BC%E3%83%89%E7%BD%B2%E5%90%8D%E3%81%AE%E6%97%85%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FHSM-Code-Signing-Journey%2Fta-p%2F1882244%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FHSM-Code-Signing-Journey%2Fta-p%2F1882244%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E25JUL2024%20-%20add%26nbsp%3Bpkcs11%20proxy%3C%2FP%3E%0A%3CP%3EHSM%20%E3%82%B3%E3%83%BC%E3%83%89%E7%BD%B2%E5%90%8D%E3%81%AE%E5%8F%96%E3%82%8A%E7%B5%84%E3%81%BF_2024%20%E5%B9%B4%207%20%E6%9C%88%2025%20%E6%97%A5.pdf%3C%2FP%3E%0A%3CP%3EHSM%20%E3%82%B3%E3%83%BC%E3%83%89%E7%BD%B2%E5%90%8D%E3%81%AE%E5%8F%96%E3%82%8A%E7%B5%84%E3%81%BF_2024%20%E5%B9%B4%207%20%E6%9C%88%2025%20%E6%97%A5.txt%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CSTRONG%3E06%2F06%2F2024%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3EHSM%20%E3%82%B3%E3%83%BC%E3%83%89%E7%BD%B2%E5%90%8D%E3%81%AE%E6%97%85%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FHSM-Code-Signing-Journey%2Fta-p%2F1882244%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FHSM-Code-Signing-Journey%2Fta-p%2F1882244%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CSTRONG%3E02%2F07%2F2024%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3EWindows%E3%81%A7%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%89%E3%82%A2%E3%83%AD%E3%83%B3%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FDevice-Tree-Standalone-Compile-under-Windows%2Fta-p%2F1855271%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FDevice-Tree-Standalone-Compile-under-Windows%2Fta-p%2F1855271%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CSTRONG%3E02%2F07%2F2024%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CSTRONG%3Ei.MX8X%E3%82%BB%E3%82%AD%E3%83%A5%E3%83%AA%E3%83%86%E3%82%A3%E6%A6%82%E8%A6%81%E3%81%A8AHAB%E3%81%AE%E8%A9%B3%E7%B4%B0%E5%88%86%E6%9E%90%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2Fi-MX8X-security-overview-and-AHAB-deep-dive%2Fta-p%2F1803083%22%20target%3D%22_blank%22%3Ei.MX8X%E3%82%BB%E3%82%AD%E3%83%A5%E3%83%AA%E3%83%86%E3%82%A3%E3%81%AE%E6%A6%82%E8%A6%81%E3%81%A8AHAB%E3%81%AE%E8%A9%B3%E7%B4%B0%20-%20NXP%20Community%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CSTRONG%3E11%2F23%2F2023%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CSTRONG%3E%E3%80%8C%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%89%E3%82%A2%E3%83%AD%E3%83%B3%E3%80%8D%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FStandalone-Compile-Device-Tree%2Fta-p%2F1762373%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FStandalone-Compile-Device-Tree%2Fta-p%2F1762373%3C%2FA%3E%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CSPAN%3E%3CSTRONG%3E10%2F26%2F2023%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CSTRONG%3ELinux%E3%83%80%E3%82%A4%E3%83%8A%E3%83%9F%E3%83%83%E3%82%AF%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FLinux-Dynamic-Debug%2Fta-p%2F1746611%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FLinux-Dynamic-Debug%2Fta-p%2F1746611%3C%2FA%3E%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CSPAN%3E%3CSTRONG%3E08%2F10%2F2023%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CSTRONG%3ESD%E3%82%AB%E3%83%BC%E3%83%89%E3%83%9F%E3%83%A9%E3%83%BC%E7%94%A8%E3%81%AEu-boot%E7%92%B0%E5%A2%83%E3%83%97%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2Fu-boot-environment-preset-for-sdcard-mirror%2Fta-p%2F1702549%22%20target%3D%22_blank%22%3ESD%E3%82%AB%E3%83%BC%E3%83%89%E3%83%9F%E3%83%A9%E3%83%BC%E7%94%A8%E3%81%AEu-boot%E7%92%B0%E5%A2%83%E3%83%97%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%20-%20NXP%20Community%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CSPAN%3E%3CSTRONG%3E06%2F06%2F2023%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CSTRONG%3Espi%20nor%20%E3%83%87%E3%83%A2%20imx8qxpc0%20mek%20%E5%86%85%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%20(%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%80%81Linux%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%80%81rootfs)%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2Fall-bootloader-device-tree-Linux-kernel-rootfs-in-spi-nor-demo%2Fta-p%2F1663994%22%20target%3D%22_blank%22%3E%E3%81%99%E3%81%B9%E3%81%A6(%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%80%81Linux%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%80%81rootfs)...%20-%20NXP%20Community%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CSTRONG%3E09%2F26%2F2022%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CSTRONG%3EparseIVT%20-%20i.MX6%20%E3%82%B3%E3%83%BC%E3%83%89%E7%BD%B2%E5%90%8D%E3%82%92%E6%94%AF%E6%8F%B4%E3%81%99%E3%82%8B%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FparseIVT-a-script-to-help-i-MX6-Code-Signing%2Fta-p%2F1128410%22%20target%3D%22_blank%22%3EparseIVT%20-%20i.MX6%E3%82%B3%E3%83%BC%E3%83%89%E7%BD%B2%E5%90%8D%E3%82%92%E6%94%AF%E6%8F%B4%E3%81%99%E3%82%8B%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%20-%20NXP%20Community%3C%2FA%3E%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3EWindows%20%E3%81%A7%E3%81%AE%E5%AE%9F%E8%A1%8C%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%99%E3%82%8B%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CSPAN%3E%3CSTRONG%3E09%2F16%2F2022%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CSTRONG%3EWindows%E3%81%A7SD%E3%82%AB%E3%83%BC%E3%83%89%E3%83%9F%E3%83%A9%E3%83%BC%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2Fcreate-sdcard-mirror-under-windows%2Fta-p%2F1472741%22%20target%3D%22_blank%22%3EWindows%E3%81%A7SD%E3%82%AB%E3%83%BC%E3%83%89%E3%83%9F%E3%83%A9%E3%83%BC%E3%82%92%E4%BD%9C%E6%88%90%20-%20NXP%20Community%3C%2FA%3E%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CSPAN%3E%3CSTRONG%3E08%2F03%2F2022%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CSTRONG%3E%20i.MX8MM%20SDCARD%20%E3%82%BB%E3%82%AB%E3%83%B3%E3%83%80%E3%83%AA%20%E3%83%96%E3%83%BC%E3%83%88%20%E3%83%87%E3%83%A2%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2Fi-MX8MM-SDCARD-Secondary-Boot-Demo%2Fta-p%2F1500011%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2Fi-MX8MM-SDCARD-Secondary-Boot-Demo%2Fta-p%2F1500011%3C%2FA%3E%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CSPAN%3E%3CSTRONG%3E02%2F16%2F2022%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CSPAN%3E%3CSTRONG%3E%3CBR%20%2F%3EUI%20%E3%81%AA%E3%81%97%E3%81%AEmx8_ddr_stress_test%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2Fmx8-ddr-stress-test-without-UI%2Fta-p%2F1414090%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2Fmx8-ddr-stress-test-without-UI%2Fta-p%2F1414090%3C%2FA%3E%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CSPAN%3E%3CSTRONG%3E12%2F23%2F2021%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CSPAN%3E%3CSTRONG%3E%3CBR%20%2F%3Ei.MX8%20i.MX8X%E3%83%9C%E3%83%BC%E3%83%89%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2Fi-MX8-i-MX8X-Board-Reset%2Fta-p%2F1391130%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2Fi-MX8-i-MX8X-Board-Reset%2Fta-p%2F1391130%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CSPAN%3E%3CSTRONG%3E12%2F21%2F2021%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CSPAN%3E%3CSTRONG%3E%3CBR%20%2F%3E%E8%A6%8F%E5%88%B6%E5%BD%93%E5%B1%80%E3%81%AE%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9-%E6%B6%88%E8%B2%BB%E8%80%85%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2Fregulator-userspace-consumer%2Fta-p%2F1389948%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2Fregulator-userspace-consumer%2Fta-p%2F1389948%3C%2FA%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CSPAN%3E%3CSTRONG%3E11%2F24%2F2021%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CSPAN%3E%3CSTRONG%3E%3CBR%20%2F%3E%E6%9A%97%E5%8F%B7af_alg%20Blackkey%E3%81%AE%E3%83%87%E3%83%A2%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2Fcrypto-af-alg-blackkey-demo%2Fta-p%2F1376300%22%20target%3D%22_blank%22%3Ecrypto%20af_alg%20blackkey%E3%83%87%E3%83%A2%20-%20NXP%20Community%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CSPAN%3E%3CSTRONG%3E09%2F28%2F2021%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CSPAN%3E%3CSTRONG%3E%3CBR%20%2F%3Eu-boot%20%E3%83%A9%E3%83%B3%E3%82%BF%E3%82%A4%E3%83%A0%20Linux%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%20(dtb)%20%E3%81%AE%E5%A4%89%E6%9B%B4%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2Fu-boot-runtime-modify-Linux-device-tree-dtb%2Fta-p%2F1347212%22%20target%3D%22_blank%22%3Eu-boot%20runtime%20modify%20Linux%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC(dtb)%20-%20NXP%20Community%3C%2FA%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CSPAN%3E%3CSTRONG%3E08%2F17%2F2021%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CSPAN%3E%3CSTRONG%3E%3CBR%20%2F%3EGPIO-PowerOff%E3%83%87%E3%83%A2%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2Fgpio-poweroff-demo%2Fta-p%2F1324306%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2Fgpio-poweroff-demo%2Fta-p%2F1324306%3C%2FA%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CSPAN%3E%3CSTRONG%3E08%2F04%2F2021%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CSPAN%3E%3CSTRONG%3E%3CBR%20%2F%3Egpio-hog%20demo%E3%81%AE%E4%BD%BF%E3%81%84%E6%96%B9%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FSWUpdate-OTA-i-MX8MM-EVK-i-MX8QXP-MEK%2Fta-p%2F1307416%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FHow-to-use-gpio-hog-demo%2Fta-p%2F1317709%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CSPAN%3E%3CSTRONG%3E07%2F14%2F2021%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CSPAN%3E%3CSTRONG%3E%3CBR%20%2F%3ESWUpdate%20OTA%20i.MX8MM%20EVK%20%2F%20i.MX8QXP%20MEK%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FSWUpdate-OTA-i-MX8MM-EVK-i-MX8QXP-MEK%2Fta-p%2F1307416%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FSWUpdate-OTA-i-MX8MM-EVK-i-MX8QXP-MEK%2Fta-p%2F1307416%3C%2FA%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CSPAN%3E%3CSTRONG%3E04%2F07%2F2021%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CSPAN%3E%3CSTRONG%3Ei.MX8QXP%20eMMC%20%E3%82%BB%E3%82%AB%E3%83%B3%E3%83%80%E3%83%AA%20%E3%83%96%E3%83%BC%E3%83%88%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Community-Articles%2Fi-MX8QXP-eMMC-Secondary-Boot%2Fba-p%2F1257704%23M45%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Community-Articles%2Fi-MX8QXP-eMMC-Secondary-Boot%2Fba-p%2F1257704%23M45%3C%2FA%3E%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CSPAN%3E%3CSTRONG%3E03%2F25%2F2021%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CSPAN%3E%3CSTRONG%3EA%E3%82%B3%E3%82%A2%E5%81%B4%E3%81%8B%E3%82%89M4%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%99%E3%82%8Bsc_misc_board_ioctl%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Community-Articles%2Fsc-misc-board-ioctl-to-access-the-M4-partition-from-A-core-side%2Fba-p%2F1251826%23M44%22%20target%3D%22_blank%22%3EM4%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%99%E3%82%8Bsc_misc_board_ioctl...-%20NXP%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%3C%2FA%3E%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CSPAN%3E%3CSTRONG%3E03%2F17%2F2021%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CSPAN%3E%3CSTRONG%3E%E5%A4%89%E6%9B%B4%E6%96%B9%E6%B3%95i.MX8X%20MEK%2B%E3%83%99%E3%83%BC%E3%82%B9%E3%83%9C%E3%83%BC%E3%83%89Linux%E3%83%87%E3%83%90%E3%83%83%E3%82%B0UART%E3%81%AE%E6%96%B9%E6%B3%95%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Community-Articles%2FHow-to-Change-i-MX8X-MEK-Base-Board-Linux-Debug-UART%2Fba-p%2F1246779%23M43%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Community-Articles%2FHow-to-Change-i-MX8X-MEK-Base-Board-Linux-Debug-UART%2Fba-p%2F1246779%23M43%3C%2FA%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CSPAN%3E%3CSTRONG%3E03%2F16%2F2021%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CSPAN%3E%3CSTRONG%3Ei.MX8MM%20evk%20Linux%E3%83%87%E3%83%90%E3%83%83%E3%82%B0UART%E3%81%AE%E5%A4%89%E6%9B%B4%E6%96%B9%E6%B3%95%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Community-Articles%2FHow-to-Change-i-MX8MM-evk-Linux-Debug-UART%2Fba-p%2F1243938%23M40%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Community-Articles%2FHow-to-Change-i-MX8MM-evk-Linux-Debug-UART%2Fba-p%2F1243938%23M40%3C%2FA%3E%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CSPAN%3E%3CSTRONG%3E05%2F06%2F2020%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CSPAN%3E%3CSTRONG%3ELinux%20%E3%81%AE%20fw_printenv%20%E3%81%A8%20fw_setenv%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20U-Boot%20%E3%81%AE%E7%92%B0%E5%A2%83%E5%A4%89%E6%95%B0%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%99%E3%82%8B%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FLinux-fw-printenv-fw-setenv-to-access-U-Boot-s-environment%2Fta-p%2F1121201%22%20target%3D%22_blank%22%3ELinux%20fw_printenv%20fw_setenv%20to%20access%20U-Boot's%20env...%20-%20NXP%20Community%3C%2FA%3E%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CSPAN%3E%3CSTRONG%3E03%2F30%2F2020%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3Ei.MX6%20%E9%87%8F%E7%94%A3%E3%81%AB%E5%90%91%E3%81%91%E3%81%9FDDR%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%2F%E3%82%B9%E3%83%88%E3%83%AC%E3%82%B9%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CA%20class%3D%22jivelink3%22%20title%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-346065%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-346065%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-346065%3C%2FA%3E%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CSPAN%3E%3CSTRONG%3E03%2F25%2F2020%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CSPAN%3E%3CSTRONG%3EparseIVT%20-%20i.MX6%20%E3%82%B3%E3%83%BC%E3%83%89%E7%BD%B2%E5%90%8D%E3%82%92%E6%94%AF%E6%8F%B4%E3%81%99%E3%82%8B%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%20%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-345998%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-345998%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CSPAN%3E%3CSTRONG%3E02%2F17%2F2020%3CBR%20%2F%3Etensorflow%20%E3%81%AE%E3%83%97%E3%83%AC%E3%82%A4%E3%82%B0%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%81%8B%E3%82%89%E6%A9%9F%E6%A2%B0%E5%AD%A6%E7%BF%92%E3%81%AE%E6%97%85%E3%82%92%E5%A7%8B%E3%82%81%E3%81%BE%E3%81%97%E3%82%87%E3%81%86%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CSPAN%3E%3CSTRONG%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-345629%22%20target%3D%22_blank%22%3Etensorflow%20%E3%81%AE%E3%83%97%E3%83%AC%E3%82%A4%E3%82%B0%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%81%8B%E3%82%89%E6%A9%9F%E6%A2%B0%E5%AD%A6%E7%BF%92%E3%81%AE%E6%97%85%E3%82%92%E5%A7%8B%E3%82%81%E3%81%BE%E3%81%97%E3%82%87%E3%81%86%3C%2FA%3E%26nbsp%3B%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3E%3CSTRONG%3E01%2F15%2F2020%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CBR%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%20%2F%3E%3CSTRONG%3EiMX8QXP%20PAD(GPIO)%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%81%AE%E8%BF%BD%E5%8A%A0%E6%96%B9%E6%B3%95%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-345322%22%20target%3D%22_blank%22%3EiMX8QXP%20PAD(GPIO)%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%81%AE%E8%BF%BD%E5%8A%A0%E6%96%B9%E6%B3%95%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSTRONG%3E01%2F09%2F2020%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3Em4%20Hello%20world%E3%82%92%E6%AD%A3%E3%81%97%E3%81%8F%E5%8B%95%E4%BD%9C%E3%81%95%E3%81%9B%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7iMX8QX%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E5%88%86%E5%89%B2%E3%82%92%E7%90%86%E8%A7%A3%E3%81%99%E3%82%8B%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-345359%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-345359%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSTRONG%3E09%2F29%2F2019%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CDIV%3E%3CSTRONG%3EUbuntu16.04%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9Fi.MX6UL%E4%B8%8A%E3%81%AEDocker%3C%2FSTRONG%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-344462%22%20target%3D%22test_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-344462%3C%2FA%3E%3C%2FDIV%3E%0A%3CBR%20%2F%3E%0A%3CDIV%3E%3CSPAN%3E09%2F25%2F2019%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CSTRONG%3EUbuntu%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9Fi.MX8MM%E4%B8%8A%E3%81%AEDocker%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-344473%22%20target%3D%22test_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-344473%3C%2FA%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CSTRONG%3EUbuntu%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9Fi.MX8QXP%E4%B8%8A%E3%81%AEDocker%3C%2FSTRONG%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-344474%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-344474%3C%2FA%3E%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSTRONG%3E08%2F28%2F2019%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3EeMMC5.0%20%E3%81%A8%20eMMC5.1%20%E3%81%AE%E6%AF%94%E8%BC%83%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-344265%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-344265%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CSPAN%3E%3CSTRONG%3E05%2F24%2F2019%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CSPAN%3EUUU%E3%81%AA%E3%81%97%E3%81%A7eMMC%E3%81%A7Linux%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%A8dtb%E3%82%92%E3%82%A2%E3%83%83%E3%83%97%E3%82%B0%E3%83%AC%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-343518%22%20target%3D%22_blank%22%3EUUU%E3%81%AA%E3%81%97%E3%81%A7eMMC%E3%81%A7Linux%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%A8dtb%E3%82%92%E3%82%A2%E3%83%83%E3%83%97%E3%82%B0%E3%83%AC%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%20%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSTRONG%3E04%2F12%2F2019%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3EeMMC%20RPMB%E3%82%A8%E3%83%B3%E3%83%8F%E3%83%B3%E3%82%B9%E3%81%8A%E3%82%88%E3%81%B3GP%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-343116%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-343116%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSTRONG%3E04%2F04%2F2019%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3EGPT%20SD%E3%82%AB%E3%83%BC%E3%83%89%E3%83%9F%E3%83%A9%E3%83%BC%E3%82%92%E3%83%80%E3%83%B3%E3%83%97%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95(Android%20O%20SD%E3%82%AB%E3%83%BC%E3%83%89%E3%83%9F%E3%83%A9%E3%83%BC)%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-343079%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-343079%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSTRONG%3E04%2F04%2F2019%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3Ei.MX%20Android%20SD%E3%82%AB%E3%83%BC%E3%83%89%E3%83%9F%E3%83%A9%E3%83%BC%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-343078%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-343078%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSTRONG%3E04%2F02%2F2019%3A%20%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3Ei.MX%20Linux%20Binary_Demo%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E3%83%92%E3%83%B3%E3%83%88%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-343075%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-343075%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSTRONG%3E04%2F02%2F2019%3A%20%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Update%20Set%20fast%20boot%26nbsp%3B%3C%2FSTRONG%3E%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20eMMC_RPMB_Enhance_and_GP.pdf%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSTRONG%3E02%2F28%2F2019%3A%20%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3EYocto%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%AA%E3%81%84%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%89%E3%82%A2%E3%83%AD%E3%83%B3%E3%83%93%E3%83%AB%E3%83%89imx_builder%20---%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-342702%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-342702%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSTRONG%3E08%2F10%2F2018%3A%20%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3Ei.MX6SX%20M4%20MPU%20%E3%81%AE%20RPMSG%20%E3%82%A2%E3%83%83%E3%83%97%E3%83%87%E3%83%BC%E3%83%88%E3%81%AE%E8%A8%AD%E5%AE%9A%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%B9%E3%83%A9%E3%82%A4%E3%83%89%E3%81%AE%E6%9B%B4%E6%96%B0%20CMA%E3%81%AE%E9%85%8D%E7%BD%AE%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E8%80%83%E6%85%AE%E4%BA%8B%E9%A0%85%3C%2FP%3E%0A%3CP%3Ei.MX6SX_M4_MPU_Settings_For_RPMSG_08102018.pdf%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSTRONG%3E07%2F26%2F2018%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%E6%9C%80%E3%82%82%E3%82%B7%E3%83%B3%E3%83%97%E3%83%AB%E3%81%AA%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A7%20ML%20%E3%82%92%E7%90%86%E8%A7%A3%E3%81%99%E3%82%8B%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-341099%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-341099%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSTRONG%3E04%2F23%2F2018%3A%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3Ei.MX8M%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%89%E3%82%A2%E3%83%AD%E3%83%B3%E3%83%93%E3%83%AB%E3%83%89%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3Ei.MX8M%20%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%89%E3%82%A2%E3%83%AD%E3%83%B3Build.pdf%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSTRONG%3E04%2F13%2F2018%3A%20%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3Ei.MX6SX%20M4%20MPU%20%E3%81%AE%20RPMSG%20%E3%82%A2%E3%83%83%E3%83%97%E3%83%87%E3%83%BC%E3%83%88%E3%81%AE%E8%A8%AD%E5%AE%9A%20%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%E3%82%B9%E3%83%A9%E3%82%A4%E3%83%89CMA%E9%85%8D%E7%BD%AE%E3%81%AE%E8%80%83%E6%85%AE%E4%BA%8B%E9%A0%85%E3%82%92%E8%BF%BD%E5%8A%A0%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3Bi.MX6SX_M4_MPU_Settings_For_RPMSG_04132018.pdf%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSTRONG%3E09%2F05%2F2017%3A%20%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3EeMMC%20RPMB%E3%80%81Enhanc%E3%80%81GP%E3%81%AE%E3%82%A2%E3%83%83%E3%83%97%E3%83%87%E3%83%BC%E3%83%88%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20eMMC_RPMB_Enhance_and_GP.pdf%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E09%2F01%2F2017%3A%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3EeMMC%20RPMB%E3%80%81Enhance%E3%80%81GP%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FSTRONG%3EeMMC_RPMB_Enhance_and_GP.pdf%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E08%2F30%2F2017%3A%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%E9%AB%98%E8%A7%A3%E5%83%8F%E5%BA%A6%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E7%94%A8%E3%83%87%E3%83%A5%E3%82%A2%E3%83%ABLVDS(i.MX6DQ%2FDLS%E7%94%A8)%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSTRONG%3E%E3%83%87%E3%83%A5%E3%82%A2%E3%83%ABLVDS%E3%81%AB%E3%82%88%E3%82%8B%E9%AB%98%E5%88%86%E8%A7%A3%E8%83%BDDisplay.pdf%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E08%2F27%2F2017%3A%3C%2FSTRONG%3E%26nbsp%3B%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CSTRONG%3EL3.14.28%20Ottbox%20%E7%A7%BB%E6%A4%8D%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E6%B3%A8%E6%84%8F%E4%BA%8B%E9%A0%85%3A%3C%2FSTRONG%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3EL3.14.28_Ottbox_Porting_Notes-20150805-2.pdf%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CSTRONG%3EMFGTool%20uboot%E3%82%92%E9%80%9A%E5%B8%B8%E3%81%AErun%E3%83%96%E3%83%BC%E3%83%88%E3%81%A8%E5%85%B1%E6%9C%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FSTRONG%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%3CSTRONG%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSTRONG%3EMFGTool_Uboot_share_with_NormalRun_sourceCode.pdf%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CSTRONG%3E%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9E%E3%83%BC%E3%81%AB%E3%82%88%E3%82%8B%E5%A4%A7%E9%87%8F%E7%94%9F%E7%94%A3%3C%2FSTRONG%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%3CSTRONG%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSTRONG%3EMass_Production_with_NAND_programmer.pdf%3C%2FP%3E%0A%3CP%3EMass_Production_with_emmc_programmer.pdf%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CSTRONG%3EAndroidSDCARD%E3%83%9F%E3%83%A9%E3%83%BC%E3%82%AF%E3%83%AA%E3%82%A8%E3%83%BC%E3%82%BF%E3%83%BC%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-329596%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-329596%3C%2FA%3E%3C%2FLI%3E%0A%3CLI%3E%3CSTRONG%3EL3.10.53%20PianoPI%E3%83%9D%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%83%8E%E3%83%BC%E3%83%88%3C%2FSTRONG%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3EL3.10.53_PianoPI_PortingNote_151102.pdf%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CSTRONG%3E%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%82%B3%E3%83%BC%E3%83%87%E3%83%83%E3%82%AFWM8960%E7%A7%BB%E6%A4%8DL3.10.53%E3%83%94%E3%82%A2%E3%83%8EPI%3C%2FSTRONG%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3EAudioCodec_WM8960_Porting_L3.10.53_PianoPI_151012.pdf%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CSTRONG%3E%E3%82%BF%E3%83%83%E3%83%81%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3PianoPI%E3%83%9D%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%83%8E%E3%83%BC%E3%83%88%3C%2FSTRONG%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3ETouchScreen_PianoPI_PortingNote_151103.pdf%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CSTRONG%3E%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%81%8B%E3%82%89%E3%81%AEGPIO%E3%81%B8%E3%81%AE%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%3C%2FSTRONG%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3BAccessing_GPIO_From_UserSpace.pdf%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-343344%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-343344%3C%2FA%3E%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CSTRONG%3Ei.MX6SX%E3%81%AEFreeRTOS%3C%2FSTRONG%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3BFreeRTOS%20for%20i.MX6SX.pdf%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CSTRONG%3Ei.MX6SX%20M4%20%E3%83%95%E3%82%A1%E3%82%B9%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%3C%2FSTRONG%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3Ei.MX6SX%20M4%20fastup.pdf%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CSTRONG%3Ei.MX6%20SDCARD%20%E3%82%BB%E3%82%AB%E3%83%B3%E3%83%80%E3%83%AA%20%E3%83%96%E3%83%BC%E3%83%88%20%E3%83%87%E3%83%A2%3C%2FSTRONG%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3Ei.MX6_SDCARD_Secondary_Boot_Demo.pdf%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CSTRONG%3Ei.MX6SX%20M4%20MPU%20%E3%81%AE%20RPMSG%20%E8%A8%AD%E5%AE%9A%3C%2FSTRONG%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3Bi.MX6SX_M4_MPU_Settings_For_RPMSG_10082016.pdf%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CSTRONG%3ESecurity%3C%2FSTRONG%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3ESecurity03172017.pdf%20i.MX%20%E3%81%A8%E3%81%AF%E9%96%A2%E4%BF%82%E3%81%AA%E3%81%8F%E3%80%81%E7%9F%AD%E3%81%84%E3%83%A1%E3%83%A2%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1104265%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EAndroid%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX%208%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%20%7C%20i.MX%208QuadMax%E2%80%AF(8QM)%20%7C%208QuadPlus%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX%208M%20%7C%20i.MX%208M%20Mini%20%7C%20i.MX%208M%20Nano%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6%20%E5%85%A8%E3%81%A6%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EYocto%20Project%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
100%が役に立ったと言っています (1/1)
バージョン履歴
最終更新日:
‎12-15-2025 07:29 PM
更新者:
