MDIO on GPIOs
MDIO on GPIOs
MDIO on GPIOs
In some cases, due to the limited resources allocated by imx pins, gpio has to be used as mdio/mdc.
This article is a simple guide on how to use MDIO on GPIOs.
The demo code is for network fec interface.
1. Add CONFIG_MDIO_GPIO=y and rebuild kernel
2. Modify fec device tree to use MDIO ON GPIO
FEC test result:
root@imx93evk:~# ethtool eth0
Settings for eth0:
        Supported ports: [ TP    MII ]
        Supported link modes:   10baseT/Half 10baseT/Full
                                100baseT/Half 100baseT/Full
                                1000baseT/Full
        Supported pause frame use: Symmetric
        Supports auto-negotiation: Yes
        Supported FEC modes: Not reported
        Advertised link modes:  10baseT/Half 10baseT/Full
                                1000baseT/Full
        Advertised pause frame use: Symmetric
        Advertised auto-negotiation: Yes
        Advertised FEC modes: Not reported
        Link partner advertised link modes:  10baseT/Half 10baseT/Full
                                             1000baseT/Full
        Link partner advertised pause frame use: No
        Link partner advertised auto-negotiation: Yes
        Link partner advertised FEC modes: Not reported
        Speed: 1000Mb/s
        Duplex: Full
        Auto-negotiation: on
        master-slave cfg: preferred slave
        master-slave status: slave
        Port: Twisted Pair
        PHYAD: 2
        Transceiver: external
        MDI-X: Unknown
        Supports Wake-on: g
        Wake-on: d
        Link detected: yes
root@imx93evk:~# ifconfig
eth0: flags=-28605<UP,BROADCAST,RUNNING,MULTICAST,DYNAMIC>  mtu 1500
        inet 10.192.246.129  netmask 255.255.255.0  broadcast 10.192.246.255
        inet6 fe80::885a:aeff:fea3:7dcf  prefixlen 64  scopeid 0x20<link>
        ether 8a:5a:ae:a3:7d:cf  txqueuelen 1000  (Ethernet)
        RX packets 13  bytes 2294 (2.2 KiB)
        RX errors 0  dropped 3  overruns 0  frame 0
        TX packets 25  bytes 4691 (4.5 KiB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
eth1: flags=-28669<UP,BROADCAST,MULTICAST,DYNAMIC>  mtu 1500
        ether a2:5e:45:17:72:79  txqueuelen 1000
eQOS test result
imx93evk login: root
eth0: flags=-28669<UP,BROADCAST,MULTICAST,DYNAMIC> mtu 1500
ether 00:04:9f:08:7f:d0 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
eth1: flags=-28605<UP,BROADCAST,RUNNING,MULTICAST,DYNAMIC> mtu 1500
inet 10.192.246.112 netmask 255.255.255.0 broadcast 10.192.246.255
inet6 fe80::204:9fff:fe08:7fcf prefixlen 64 scopeid 0x20<link>
ether 00:04:9f:08:7f:cf txqueuelen 1000 (Ethernet)
RX packets 12 bytes 3020 (2.9 KiB)
TX packets 31 bytes 5355 (5.2 KiB)
device interrupt 104
root@imx93evk:~# ethtool eth1
Settings for eth1:
1000baseT/Full
Supported pause frame use: Symmetric Receive-only
1000baseT/Full
Advertised pause frame use: Symmetric Receive-only
1000baseT/Full
Speed: 1000Mb/s
Duplex: Full
Port: Twisted Pair
PHYAD: 1
MDI-X: Unknown
Supports Wake-on: ug
Wake-on: d
Current message level: 0x0000003f (63)
drv probe l
附件
%3CLINGO-SUB%20id%3D%22lingo-sub-2030380%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EGPIO%20%E4%B8%8A%E7%9A%84%20MDIO%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2030380%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%0A%3CP%3E%E6%9F%90%E4%BA%9B%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8C%E7%94%B1%E4%BA%8Eimx%E5%BC%95%E8%84%9A%E5%88%86%E9%85%8D%E7%9A%84%E8%B5%84%E6%BA%90%E6%9C%89%E9%99%90%EF%BC%8C%E4%B8%8D%E5%BE%97%E4%B8%8D%E5%B0%86gpio%E7%94%A8%E4%BD%9Cmdio%2Fmdc%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%9C%AC%E6%96%87%E6%98%AF%E5%85%B3%E4%BA%8E%E5%A6%82%E4%BD%95%E5%9C%A8%20GPIO%20%E4%B8%8A%E4%BD%BF%E7%94%A8%20MDIO%20%E7%9A%84%E7%AE%80%E5%8D%95%E6%8C%87%E5%8D%97%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%AF%A5%E6%BC%94%E7%A4%BA%E4%BB%A3%E7%A0%81%E7%94%A8%E4%BA%8E%E7%BD%91%E7%BB%9C%20fec%20%E6%8E%A5%E5%8F%A3%E3%80%82%3C%2FP%3E%0A%3CP%3E1.%20%E6%B7%BB%E5%8A%A0%20CONFIG_MDIO_GPIO%3Dy%20%E5%B9%B6%E9%87%8D%E5%BB%BA%E5%86%85%E6%A0%B8%3C%2FP%3E%0A%3CP%3E2.%20%E4%BF%AE%E6%94%B9%20fec%20%E8%AE%BE%E5%A4%87%E6%A0%91%E4%BB%A5%E4%BD%BF%E7%94%A8%20MDIO%20ON%20GPIO%3C%2FP%3E%0A%3CP%3EFEC%E6%B5%8B%E8%AF%95%E7%BB%93%E6%9E%9C%EF%BC%9A%3C%2FP%3E%0A%3CP%3Eroot%40imx93evk%3A~%23%20ethtool%20eth0%3C%2FP%3E%0A%3CP%3Eeth0%20%E7%9A%84%E8%AE%BE%E7%BD%AE%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%E6%94%AF%E6%8C%81%E7%9A%84%E7%AB%AF%E5%8F%A3%EF%BC%9A%5B%20TP%20MII%20%5D%3C%2FP%3E%0A%3CP%3E%E6%94%AF%E6%8C%81%E7%9A%84%E9%93%BE%E6%8E%A5%E6%A8%A1%E5%BC%8F%EF%BC%9A10baseT%2FHalf%2010baseT%2FFull%3C%2FP%3E%0A%3CP%3E100baseT%2F%E5%8D%8A%E5%8F%8C%E5%B7%A5%20100baseT%2F%E5%85%A8%E5%8F%8C%E5%B7%A5%3C%2FP%3E%0A%3CP%3E1000baseT%2F%E5%85%A8%3C%2FP%3E%0A%3CP%3E%E6%94%AF%E6%8C%81%E7%9A%84%E6%9A%82%E5%81%9C%E5%B8%A7%E4%BD%BF%E7%94%A8%EF%BC%9A%E5%AF%B9%E7%A7%B0%3C%2FP%3E%0A%3CP%3E%E6%94%AF%E6%8C%81%E8%87%AA%E5%8A%A8%E5%8D%8F%E5%95%86%EF%BC%9A%E6%98%AF%3C%2FP%3E%0A%3CP%3E%E6%94%AF%E6%8C%81%E7%9A%84%20FEC%20%E6%A8%A1%E5%BC%8F%EF%BC%9A%E6%9C%AA%E6%8A%A5%E5%91%8A%3C%2FP%3E%0A%3CP%3E%E5%85%AC%E5%B8%83%E7%9A%84%E9%93%BE%E6%8E%A5%E6%A8%A1%E5%BC%8F%EF%BC%9A10baseT%2FHalf%2010baseT%2FFull%3C%2FP%3E%0A%3CP%3E100baseT%2F%E5%8D%8A%E5%8F%8C%E5%B7%A5%20100baseT%2F%E5%85%A8%E5%8F%8C%E5%B7%A5%3C%2FP%3E%0A%3CP%3E1000baseT%2F%E5%85%A8%3C%2FP%3E%0A%3CP%3E%E5%85%AC%E5%B8%83%E7%9A%84%E6%9A%82%E5%81%9C%E5%B8%A7%E4%BD%BF%E7%94%A8%EF%BC%9A%E5%AF%B9%E7%A7%B0%3C%2FP%3E%0A%3CP%3E%E5%85%AC%E5%91%8A%E8%87%AA%E5%8A%A8%E5%8D%8F%E5%95%86%EF%BC%9A%E6%98%AF%3C%2FP%3E%0A%3CP%3E%E5%85%AC%E5%B8%83%E7%9A%84%20FEC%20%E6%A8%A1%E5%BC%8F%EF%BC%9A%E6%9C%AA%E6%8A%A5%E5%91%8A%3C%2FP%3E%0A%3CP%3E%E9%93%BE%E8%B7%AF%E4%BC%99%E4%BC%B4%E5%85%AC%E5%B8%83%E7%9A%84%E9%93%BE%E8%B7%AF%E6%A8%A1%E5%BC%8F%EF%BC%9A10baseT%2FHalf%2010baseT%2FFull%3C%2FP%3E%0A%3CP%3E100baseT%2F%E5%8D%8A%E5%8F%8C%E5%B7%A5%20100baseT%2F%E5%85%A8%E5%8F%8C%E5%B7%A5%3C%2FP%3E%0A%3CP%3E1000baseT%2F%E5%85%A8%3C%2FP%3E%0A%3CP%3E%E9%93%BE%E6%8E%A5%E5%90%88%E4%BD%9C%E4%BC%99%E4%BC%B4%E5%AE%A3%E4%BC%A0%E6%9A%82%E5%81%9C%E5%B8%A7%E7%9A%84%E4%BD%BF%E7%94%A8%EF%BC%9A%E5%90%A6%3C%2FP%3E%0A%3CP%3E%E9%93%BE%E6%8E%A5%E4%BC%99%E4%BC%B4%E9%80%9A%E5%91%8A%E8%87%AA%E5%8A%A8%E5%8D%8F%E5%95%86%EF%BC%9A%E6%98%AF%3C%2FP%3E%0A%3CP%3E%E9%93%BE%E8%B7%AF%E4%BC%99%E4%BC%B4%E9%80%9A%E5%91%8A%E7%9A%84%20FEC%20%E6%A8%A1%E5%BC%8F%EF%BC%9A%E6%9C%AA%E6%8A%A5%E5%91%8A%3C%2FP%3E%0A%3CP%3E%E9%80%9F%E5%BA%A6%EF%BC%9A1000Mb%2Fs%3C%2FP%3E%0A%3CP%3E%E5%8F%8C%E5%B7%A5%EF%BC%9A%E5%85%A8%E5%8F%8C%E5%B7%A5%3C%2FP%3E%0A%3CP%3E%E8%87%AA%E5%8A%A8%E5%8D%8F%E5%95%86%EF%BC%9A%E5%BC%80%E5%90%AF%3C%2FP%3E%0A%3CP%3E%E4%B8%BB%E4%BB%8E%E9%85%8D%E7%BD%AE%EF%BC%9A%E9%A6%96%E9%80%89%E4%BB%8E%E5%B1%9E%3C%2FP%3E%0A%3CP%3E%E4%B8%BB%E4%BB%8E%E7%8A%B6%E6%80%81%EF%BC%9A%E4%BB%8E%3C%2FP%3E%0A%3CP%3E%E7%AB%AF%E5%8F%A3%EF%BC%9A%E5%8F%8C%E7%BB%9E%E7%BA%BF%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%3CFONT%20color%3D%22%23FF0000%22%3E%E7%89%A9%E7%90%86AD%EF%BC%9A2%3C%2FFONT%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%E6%94%B6%E5%8F%91%E5%99%A8%EF%BC%9A%E5%A4%96%E9%83%A8%3C%2FP%3E%0A%3CP%3EMDI-X%EF%BC%9A%E6%9C%AA%E7%9F%A5%3C%2FP%3E%0A%3CP%3E%E6%94%AF%E6%8C%81%E5%94%A4%E9%86%92%EF%BC%9Ag%3C%2FP%3E%0A%3CP%3E%E5%94%A4%E9%86%92%EF%BC%9Ad%3C%2FP%3E%0A%3CP%3E%E6%A3%80%E6%B5%8B%E5%88%B0%E9%93%BE%E6%8E%A5%EF%BC%9A%E6%98%AF%3C%2FP%3E%0A%3CP%3Eroot%40imx93evk%3A~%23%20ifconfig%3C%2FP%3E%0A%3CP%3Eeth0%3A%20flags%3D-28605%3CUP%3E%26nbsp%3B%20mtu%201500%3C%2FUP%3E%3C%2FP%3E%0A%3CP%3Einet%20%3CSTRONG%3E%3CFONT%20color%3D%22%23FF0000%22%3E10.192.246.129%3C%2FFONT%3E%3C%2FSTRONG%3E%E7%BD%91%E7%BB%9C%E6%8E%A9%E7%A0%81%20255.255.255.0%E5%B9%BF%E6%92%AD%2010.192.246.255%3C%2FP%3E%0A%3CP%3Einet6%20fe80%3A%3A885a%3Aaeff%3Afea3%3A7dcf%20prefixlen%2064%20scopeid%200x20%3CLINK%20%2F%3E%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ether%208a%3A5a%3Aae%3Aa3%3A7d%3Acf%26nbsp%3B%20txqueuelen%201000%26nbsp%3B%20(Ethernet)%3C%2FP%3E%0A%3CP%3ERX%20%E6%95%B0%E6%8D%AE%E5%8C%85%2013%20%E5%AD%97%E8%8A%82%202294%EF%BC%882.2%20KiB%EF%BC%89%3C%2FP%3E%0A%3CP%3ERX%20%E9%94%99%E8%AF%AF%200%20%E4%B8%A2%E5%A4%B1%203%20%E8%B6%85%E9%99%90%200%20%E5%B8%A7%200%3C%2FP%3E%0A%3CP%3ETX%20%E6%95%B0%E6%8D%AE%E5%8C%85%2025%20%E5%AD%97%E8%8A%82%204691%EF%BC%884.5%20KiB%EF%BC%89%3C%2FP%3E%0A%3CP%3ETX%20%E9%94%99%E8%AF%AF%200%20%E4%B8%A2%E5%A4%B1%200%20%E8%B6%85%E9%99%90%200%20%E8%BD%BD%E6%B3%A2%200%20%E5%86%B2%E7%AA%81%200%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3Eeth1%3A%20flags%3D-28669%3CUP%3E%26nbsp%3B%20mtu%201500%3C%2FUP%3E%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ether%20a2%3A5e%3A45%3A17%3A72%3A79%26nbsp%3B%20txqueuelen%201000%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EeQOS%E6%B5%8B%E8%AF%95%E7%BB%93%E6%9E%9C%3C%2FP%3E%0A%3CP%3Eimx93evk%E7%99%BB%E5%BD%95%EF%BC%9Aroot%3CBR%20%2F%3E%20root%40imx93evk%3A~%23%20ifconfig%3CBR%20%2F%3E%20eth0%EF%BC%9A%E6%A0%87%E5%BF%97%3D-28669%20%20mtu%201500%3CBR%20%2F%3E%E4%BB%A5%E5%A4%AA%2000%3A04%3A9f%3A08%3A7f%3Ad0%20txqueuelen%201000%EF%BC%88%E4%BB%A5%E5%A4%AA%E7%BD%91%EF%BC%89%3CBR%20%2F%3E%20RX%20%E6%95%B0%E6%8D%AE%E5%8C%85%200%20%E5%AD%97%E8%8A%82%200%EF%BC%880.0%20B%EF%BC%89%3CBR%20%2F%3E%20RX%20%E9%94%99%E8%AF%AF%200%20%E4%B8%A2%E5%A4%B1%200%20%E8%B6%85%E9%99%90%200%20%E5%B8%A7%200%3CBR%20%2F%3E%20TX%20%E6%95%B0%E6%8D%AE%E5%8C%85%200%20%E5%AD%97%E8%8A%82%200%EF%BC%880.0%20B%EF%BC%89%3CBR%20%2F%3E%20TX%20%E9%94%99%E8%AF%AF%200%20%E4%B8%A2%E5%A4%B1%200%20%E8%B6%85%E9%99%90%200%20%E8%BD%BD%E6%B3%A2%200%20%E5%86%B2%E7%AA%81%200%3C%2FP%3E%0A%3CP%3Eeth1%EF%BC%9A%E6%A0%87%E5%BF%97%3D-28605%20%3CUP%3E%20mtu%201500%3CBR%20%2F%3E%20inet%20%3CSTRONG%3E%3CFONT%20color%3D%22%23FF0000%22%3E10.192.246.112%3C%2FFONT%3E%3C%2FSTRONG%3E%E7%BD%91%E7%BB%9C%E6%8E%A9%E7%A0%81%20255.255.255.0%20%E5%B9%BF%E6%92%AD%2010.192.246.255%3CBR%20%2F%3Einet6%20fe80%3A%3A204%3A9fff%3Afe08%3A7fcf%20prefixlen%2064%20scopeid%200x20%3CLINK%20%2F%3E%3CBR%20%2F%3E%20ether%2000%3A04%3A9f%3A08%3A7f%3Acf%20txqueuelen%201000%EF%BC%88%E4%BB%A5%E5%A4%AA%E7%BD%91%EF%BC%89%3CBR%20%2F%3E%20RX%20%E6%95%B0%E6%8D%AE%E5%8C%85%2012%20%E5%AD%97%E8%8A%82%203020%EF%BC%882.9%20KiB%EF%BC%89%3CBR%20%2F%3E%20RX%20%E9%94%99%E8%AF%AF%200%20%E4%B8%A2%E5%A4%B1%203%20%E8%B6%85%E9%99%90%200%20%E5%B8%A7%200%3CBR%20%2F%3E%20TX%20%E6%95%B0%E6%8D%AE%E5%8C%85%2031%20%E5%AD%97%E8%8A%82%205355%EF%BC%885.2%20KiB%EF%BC%89%3CBR%20%2F%3E%20TX%20%E9%94%99%E8%AF%AF%200%20%E4%B8%A2%E5%A4%B1%200%20%E8%B6%85%E9%99%90%200%20%E8%BD%BD%E6%B3%A2%200%20%E5%86%B2%E7%AA%81%200%3CBR%20%2F%3E%E8%AE%BE%E5%A4%87%E4%B8%AD%E6%96%AD%20104%3C%2FUP%3E%3C%2FP%3E%0A%3CP%3Eroot%40imx93evk%3A~%23%20ethtool%20eth1%3CBR%20%2F%3E%20eth1%20%E7%9A%84%E8%AE%BE%E7%BD%AE%EF%BC%9A%3CBR%20%2F%3E%E6%94%AF%E6%8C%81%E7%9A%84%E7%AB%AF%E5%8F%A3%EF%BC%9A%5B%20TP%20MII%20%5D%3CBR%20%2F%3E%E6%94%AF%E6%8C%81%E7%9A%84%E9%93%BE%E6%8E%A5%E6%A8%A1%E5%BC%8F%EF%BC%9A10baseT%2FHalf%2010baseT%2FFull%3CBR%20%2F%3E%20100baseT%2F%E5%8D%8A%E5%8F%8C%E5%B7%A5%20100baseT%2F%E5%85%A8%E5%8F%8C%E5%B7%A5%3CBR%20%2F%3E1000baseT%2F%E5%85%A8%3CBR%20%2F%3E%E6%94%AF%E6%8C%81%E7%9A%84%E6%9A%82%E5%81%9C%E5%B8%A7%E4%BD%BF%E7%94%A8%EF%BC%9A%E4%BB%85%E5%AF%B9%E7%A7%B0%E6%8E%A5%E6%94%B6%3CBR%20%2F%3E%E6%94%AF%E6%8C%81%E8%87%AA%E5%8A%A8%E5%8D%8F%E5%95%86%EF%BC%9A%E6%98%AF%3CBR%20%2F%3E%E6%94%AF%E6%8C%81%E7%9A%84%20FEC%20%E6%A8%A1%E5%BC%8F%EF%BC%9A%E6%9C%AA%E6%8A%A5%E5%91%8A%3CBR%20%2F%3E%E5%85%AC%E5%B8%83%E7%9A%84%E9%93%BE%E6%8E%A5%E6%A8%A1%E5%BC%8F%EF%BC%9A10baseT%2FHalf%2010baseT%2FFull%3CBR%20%2F%3E%20100baseT%2F%E5%8D%8A%E5%8F%8C%E5%B7%A5%20100baseT%2F%E5%85%A8%E5%8F%8C%E5%B7%A5%3CBR%20%2F%3E1000baseT%2F%E5%85%A8%3CBR%20%2F%3E%E9%80%9A%E5%91%8A%E6%9A%82%E5%81%9C%E5%B8%A7%E4%BD%BF%E7%94%A8%EF%BC%9A%E4%BB%85%E5%AF%B9%E7%A7%B0%E6%8E%A5%E6%94%B6%3CBR%20%2F%3E%E5%85%AC%E5%91%8A%E8%87%AA%E5%8A%A8%E5%8D%8F%E5%95%86%EF%BC%9A%E6%98%AF%3CBR%20%2F%3E%E5%85%AC%E5%B8%83%E7%9A%84%20FEC%20%E6%A8%A1%E5%BC%8F%EF%BC%9A%E6%9C%AA%E6%8A%A5%E5%91%8A%3CBR%20%2F%3E%E9%93%BE%E8%B7%AF%E4%BC%99%E4%BC%B4%E5%85%AC%E5%B8%83%E7%9A%84%E9%93%BE%E8%B7%AF%E6%A8%A1%E5%BC%8F%EF%BC%9A10baseT%2FHalf%2010baseT%2FFull%3CBR%20%2F%3E%20100baseT%2F%E5%8D%8A%E5%8F%8C%E5%B7%A5%20100baseT%2F%E5%85%A8%E5%8F%8C%E5%B7%A5%3CBR%20%2F%3E1000baseT%2F%E5%85%A8%3CBR%20%2F%3E%E9%93%BE%E6%8E%A5%E5%90%88%E4%BD%9C%E4%BC%99%E4%BC%B4%E5%AE%A3%E4%BC%A0%E6%9A%82%E5%81%9C%E5%B8%A7%E7%9A%84%E4%BD%BF%E7%94%A8%EF%BC%9A%E5%90%A6%3CBR%20%2F%3E%E9%93%BE%E6%8E%A5%E4%BC%99%E4%BC%B4%E9%80%9A%E5%91%8A%E8%87%AA%E5%8A%A8%E5%8D%8F%E5%95%86%EF%BC%9A%E6%98%AF%3CBR%20%2F%3E%E9%93%BE%E8%B7%AF%E4%BC%99%E4%BC%B4%E9%80%9A%E5%91%8A%E7%9A%84%20FEC%20%E6%A8%A1%E5%BC%8F%EF%BC%9A%E6%9C%AA%E6%8A%A5%E5%91%8A%3CBR%20%2F%3E%E9%80%9F%E5%BA%A6%EF%BC%9A1000Mb%2Fs%3CBR%20%2F%3E%E5%8F%8C%E5%B7%A5%EF%BC%9A%E5%85%A8%E5%8F%8C%E5%B7%A5%3CBR%20%2F%3E%E8%87%AA%E5%8A%A8%E5%8D%8F%E5%95%86%EF%BC%9A%E5%BC%80%E5%90%AF%3CBR%20%2F%3E%E4%B8%BB%E4%BB%8E%E9%85%8D%E7%BD%AE%EF%BC%9A%E9%A6%96%E9%80%89%E4%BB%8E%E5%B1%9E%3CBR%20%2F%3E%E4%B8%BB%E4%BB%8E%E7%8A%B6%E6%80%81%EF%BC%9A%E4%BB%8E%3CBR%20%2F%3E%E7%AB%AF%E5%8F%A3%EF%BC%9A%E5%8F%8C%E7%BB%9E%E7%BA%BF%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF0000%22%3E%3CSTRONG%3E%E7%89%A9%E7%90%86AD%EF%BC%9A1%3C%2FSTRONG%3E%3C%2FFONT%3E%3CBR%20%2F%3E%E6%94%B6%E5%8F%91%E5%99%A8%EF%BC%9A%E5%A4%96%E9%83%A8%3CBR%20%2F%3EMDI-X%EF%BC%9A%E6%9C%AA%E7%9F%A5%3CBR%20%2F%3E%E6%94%AF%E6%8C%81%E5%94%A4%E9%86%92%EF%BC%9Aug%3CBR%20%2F%3E%E5%94%A4%E9%86%92%EF%BC%9Ad%3CBR%20%2F%3E%E5%BD%93%E5%89%8D%E6%B6%88%E6%81%AF%E7%BA%A7%E5%88%AB%EF%BC%9A0x0000003f%EF%BC%8863%EF%BC%89%3CBR%20%2F%3E%E9%A9%B1%E5%8A%A8%E6%8E%A2%E5%A4%B4%20l%3C%2FP%3E%0A%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎01-22-2025 11:28 PM
更新人:
