i.MX Yocto Project: Frequently Asked Questions
How to Test Yocto for i.MX6
i.MX Yocto Project: How Can I Collaborate on the Freescale Yocto Project?
i.MX Yocto Project: How Can I Build the Freescale Yocto Images using bitbake?
i.MX Yocto Project: How Can I Build the Freescale Yocto Images using hob?
i.MX Yocto Project: What Can I Do if I Run Into a Compilation Error?
i.MX Yocto Project: Are There Prebuilt Images Available?
i.MX Yocto Project: How Can I Quicken the Compilation?
i.MX Yocto Project: how can I conserve disk space during builds?
i.MX Yocto Project: How do I add an existing package to an image?
i.MX Yocto Project: Can I use a virtual machine to build?
i.MX Yocto Project: How can I build an image with (latest) mainline kernel?
i.MX Yocto Project: How can I (quickly) modify a package' source code and test it?
i.MX Yocto Project: How can I find out the packages include on an image?
i.MX Yocto Project: How can I compile the kernel manually?
i.MX Yocto Project: How can I patch the kernel?
i.MX Yocto Proyect: How can I create a new Layer?
i.MX Yocto Project: How can I contribute to the community?
i.MX Yocto Project: Where can I see current  BSP issues?
i.MX Yocto Project: Where are the mainstream repositories hosted?
Tutorials:
Yocto Training - HOME
http://www.slideshare.net/OtavioSalvador/yocto-training-in-english - Great tutorial created by the Community's maintainer (there is also a Portuguese version)
i.MX Yocto Project: Freescale Yocto Project Tutorial - It covers some basic developing tasks
Others:
Useful bitbake commands
i.MX Yocto Project: ltib versus bitbake
コメント
I have a few questions that I haven't seen addressed.
  1. Is there a specific yocto configuration for the kontron board?
  2. Can yocto boot off of usb?
  3. Can yocto be nfs booted?
1. For non-FSL boards, you need to check this layer/folder meta-fsl-arm-extra/conf/machine at master · Freescale/meta-fsl-arm-extra · GitHub
2. You mean booting from the USB OTG? i.MX USB Loader
3. Sure. Just do the proper changes on u-boot. Use the images from tmp/deploy/images
Hi Leonardo,
The link you posted above (DOC-9411) returns "may have been deleted"...
I could not find anything for kontron in the 1st link – I am following up with them.
The second link is a 404.
I will try the images created – although I am not sure what to do with the u-boot image file.
Thank you,
Dominic Amann
Software Developer
Sensors & Software Inc.
1040 Stacey Court, Mississauga ON. L4W 2X8
Toll Free: 1-800-267-6013 ext.
subsurface imaging solutions
Sorry, wrong copy & paste. Now the link is non-404.
Hi Dominic,
Ironically, I was just sending a note to another customer when I saw your question.
I don't know whether Kontron's U-Boot build includes USB support, but in general, U-Boot supports USB storage
devices.
We have some patches in flight to allow booting via USB on our boards, but the USB startup is slow under
U-Boot, so we haven't integrated them into our boot script.
If you want to do this by hand, you can use something like this:
    U-Boot > usb start
    U-Boot > setenv bootargs ... rootwait root=/dev/sda1
    U-Boot > ext2load usb 0 10800000 /boot/uImage
    U-Boot > bootm 10800000
That is, the "usb start" command should initialize the USB driver (and recognize the storage device), and the "fatload" or "ext2load" commands will allow you to read a kernel into RAM.
You'll then need to tell the kernel (via "bootargs") where the root filesystem is located (example above assumes partition 1 of the first drive connected to your system).
What do you mean by 'I am not sure what to do with the u-boot image'?
The image in deploy/images called u-boot.imx is the one I wouldn't know what to do with - perhaps it is for OTG?
In general, the kontron supports usb boot. I did not mean usb OTG I meant usb boot as in boot from a usb memory device (as opposed to SD card).
I have a u-boot configuration that boots from USB for the LTIB distribution successfully . I have tried building yocto (for imx6sabresd) and dd-ing the image to my usb stick - but no success. I also tried a single ext2 partition, copy filesystem, add uImage in /, then run grub-install. That didn't work either. I will try again with Eric Nelson's directions below.
Tried this - hangs at "Starting kernel" (after checksumming and loading ok).
scanning bus 0 for devices... 4 USB Device(s) found
       scanning usb for storage devices... 1 Storage Device(s) found
USB device 0:
    Device 0: Vendor: SanDisk  Rev: 2.01 Prod: Cruzer Glide
            Type: Hard Disk
            Capacity: 30532.5 MB = 29.8 GB (62530624 x 512)
... is now current device
Loading file "/boot/uImage" from usb device 0:1
3872636 bytes read
## Booting kernel from Legacy Image at 10800000 ...
   Image Name:   Linux-3.0.35-1.1.0+yocto+g21304e
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    3872572 Bytes = 3.7 MiB
   Load Address: 10008000
   Entry Point:  10008000
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
OK
Using machid 0x10e9 from environment
Starting kernel ...
Hi Dominic,
Believe it or not, that means things worked...
Now you just need to figure out what the proper value for "bootargs" needs to be. You can probably cut & paste from a successful SD card boot and replace "/dev/mmcblk0p#" with "/dev/sda#" and be up and running.
Sure. Oddly enough, it works on an LTIB image - the only obvious difference is the LTIB has its uImage in / - so I had to change my bootfile variable to make it work. Yocto still doesn't work.
I will try with the uImages in the same place. Although by now this feels more like superstition than science. Is there some way to have the boot give more diagnostic progress information?
The usbboot boots the LTIB usb stick no problem. uImage is in the same place (/boot/uImage) in each case. Root filesystem is in /dev/sda1. The command is the same.
Are you using dora? Kernel 3.0.35 ? BTW, u-boot.imx is the same as old u-boot.bin, just without the padding.
The kernel shows as 3.0.35-1.1.0+yocto+g21304e.
The Yocta build was dylan. Should I use Dora?
I am accustomed to bios boots on linux systems. Is there something I need to do with the uBoot imx file? Does it get copied to the boot device somehow? I thought my kontron board has u-boot on its flash so I can run these commands as above. Is there a u-boot component that goes on the boot device as well?
Yes; Dora is the current stable version and all new products ought to be based on it as it gives you a good base and easier upgrade for future releases.
Kindly help, it is my first build.
bitbake core-image-minimal
NOTE: Your conf/bblayers.conf has been automatically updated.
Parsing recipes: 100% |#############################################################| Time: 0:01:25
Parsing of 1704 .bb files complete (0 cached, 1704 parsed). 2370 targets, 424 skipped, 0 masked, 0 errors.
NOTE: Resolving any missing task queue dependencies
Build Configuration:
BB_VERSION = "1.40.0"
BUILD_SYS = "x86_64-linux"
NATIVELSBSTRING = "ubuntu-18.04"
TARGET_SYS = "arm-fslc-linux-gnueabi"
MACHINE = "imx6qdlsabresd"
DISTRO = "fslc-framebuffer"
DISTRO_VERSION = "2.6"
TUNE_FEATURES = "arm armv7a vfp thumb neon callconvention-hard"
TARGET_FPU = "hard"
meta
meta-poky = "my_local_dev:e6949336479e611a142834b6d9241514cbaeaf80"
meta-oe
meta-multimedia = "my_local_dev:2d088d252624b19df384aecc434d23afb636178f"
meta-freescale = "my_local_dev:8b9a1e19b1983301bbad9f0c61a4d2adc3fdd741"
meta-freescale-3rdparty = "my_local_dev:545e8094a140231e78b9284c3a3d94fcc573ae98"
meta-freescale-distro = "my_local_dev:4a244af3993ae662624c6f615464e6806cc719a2"
NOTE: Fetching uninative binary shim from http://downloads.yoctoproject.org/releases/uninative/2.6/x86_64-nativesdk-libc.tar.xz;sha256sum=1333...
Initialising tasks: 100% |##########################################################| Time: 0:00:01
Sstate summary: Wanted 675 Found 0 Missed 675 Current 0 (0% match, 0% complete)
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
WARNING: libffi-native-3.2.1-r0 do_fetch: Failed to fetch URL ftp://sourceware.org/pub/libffi/libffi-3.2.1.tar.gz, attempting MIRRORS if available
WARNING: alsa-lib-native-1.1.6-r0 do_fetch: Failed to fetch URL ftp://ftp.alsa-project.org/pub/lib/alsa-lib-1.1.6.tar.bz2, attempting MIRRORS if available
WARNING: binutils-cross-arm-2.31.1-r0 do_fetch: Failed to fetch URL git://sourceware.org/git/binutils-gdb.git;branch=binutils-2_31-branch;protocol=git, attempting MIRRORS if available
WARNING: update-rc.d-native-0.8-r0 do_fetch: Failed to fetch URL git://git.yoctoproject.org/update-rc.d, attempting MIRRORS if available
WARNING: linux-fslc-imx-4.9-1.0.x+gitAUTOINC+953c6e30c9-r0 do_fetch: Failed to fetch URL git://github.com/Freescale/linux-fslc.git;branch=4.9-1.0.x-imx, attempting MIRRORS if available
ERROR: linux-fslc-imx-4.9-1.0.x+gitAUTOINC+953c6e30c9-r0 do_fetch: Fetcher failure: Fetch command export PSEUDO_DISABLED=1; export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1000/bus"; export SSH_AGENT_PID="1449"; export SSH_AUTH_SOCK="/run/user/1000/keyring/ssh"; export PATH="/home/amit/Documents/yocto_imx/fsl-community-bsp/build/tmp/sysroots-uninative/x86_64-linux/usr/bin:/home/amit/Documents/yocto_imx/fsl-community-bsp/sources/poky/scripts:/home/amit/Documents/yocto_imx/fsl-community-bsp/build/tmp/work/imx6qdlsabresd-fslc-linux-gnueabi/linux-fslc-imx/4.9-1.0.x+gitAUTOINC+953c6e30c9-r0/recipe-sysroot-native/usr/bin/arm-fslc-linux-gnueabi:/home/amit/Documents/yocto_imx/fsl-community-bsp/build/tmp/work/imx6qdlsabresd-fslc-linux-gnueabi/linux-fslc-imx/4.9-1.0.x+gitAUTOINC+953c6e30c9-r0/recipe-sysroot/usr/bin/crossscripts:/home/amit/Documents/yocto_imx/fsl-community-bsp/build/tmp/work/imx6qdlsabresd-fslc-linux-gnueabi/linux-fslc-imx/4.9-1.0.x+gitAUTOINC+953c6e30c9-r0/recipe-sysroot-native/usr/sbin:/home/amit/Documents/yocto_imx/fsl-community-bsp/build/tmp/work/imx6qdlsabresd-fslc-linux-gnueabi/linux-fslc-imx/4.9-1.0.x+gitAUTOINC+953c6e30c9-r0/recipe-sysroot-native/usr/bin:/home/amit/Documents/yocto_imx/fsl-community-bsp/build/tmp/work/imx6qdlsabresd-fslc-linux-gnueabi/linux-fslc-imx/4.9-1.0.x+gitAUTOINC+953c6e30c9-r0/recipe-sysroot-native/sbin:/home/amit/Documents/yocto_imx/fsl-community-bsp/build/tmp/work/imx6qdlsabresd-fslc-linux-gnueabi/linux-fslc-imx/4.9-1.0.x+gitAUTOINC+953c6e30c9-r0/recipe-sysroot-native/bin:/home/amit/Documents/yocto_imx/fsl-community-bsp/sources/poky/bitbake/bin:/home/amit/Documents/yocto_imx/fsl-community-bsp/build/tmp/hosttools"; export HOME="/home/amit"; LANG=C git -c core.fsyncobjectfiles=0 clone --bare --mirror git://github.com/Freescale/linux-fslc.git /home/amit/Documents/yocto_imx/fsl-community-bsp/downloads//git2/github.com.Freescale.linux-fslc.git --progress failed with exit code 128, output:
Cloning into bare repository '/home/amit/Documents/yocto_imx/fsl-community-bsp/downloads//git2/github.com.Freescale.linux-fslc.git'...
fatal: Unable to look up github.com (port 9418) (Name or service not known)
ERROR: linux-fslc-imx-4.9-1.0.x+gitAUTOINC+953c6e30c9-r0 do_fetch: Fetcher failure for URL: 'git://github.com/Freescale/linux-fslc.git;branch=4.9-1.0.x-imx'. Unable to fetch URL from any source.
ERROR: linux-fslc-imx-4.9-1.0.x+gitAUTOINC+953c6e30c9-r0 do_fetch: Function failed: base_do_fetch
ERROR: Logfile of failure stored in: /home/amit/Documents/yocto_imx/fsl-community-bsp/build/tmp/work/imx6qdlsabresd-fslc-linux-gnueabi/linux-fslc-imx/4.9-1.0.x+gitAUTOINC+953c6e30c9-r0/temp/log.do_fetch.15140
ERROR: Task (/home/amit/Documents/yocto_imx/fsl-community-bsp/sources/meta-freescale/recipes-kernel/linux/linux-fslc-imx_4.9-1.0.x.bb:do_fetch) failed with exit code '1'
WARNING: btrfs-tools-4.17.1-r0 do_fetch: Failed to fetch URL git://git.kernel.org/pub/scm/linux/kernel/git/kdave/btrfs-progs.git, attempting MIRRORS if available
WARNING: u-boot-fslc-v2018.11+gitAUTOINC+6e25ce6f3c-r0 do_fetch: Failed to fetch URL git://github.com/Freescale/u-boot-fslc.git;branch=2018.11+fslc, attempting MIRRORS if available
ERROR: btrfs-tools-4.17.1-r0 do_fetch: Fetcher failure: Fetch command export PSEUDO_DISABLED=1; export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1000/bus"; export SSH_AGENT_PID="1449"; export SSH_AUTH_SOCK="/run/user/1000/keyring/ssh"; export PATH="/home/amit/Documents/yocto_imx/fsl-community-bsp/build/tmp/sysroots-uninative/x86_64-linux/usr/bin:/home/amit/Documents/yocto_imx/fsl-community-bsp/build/tmp/work/armv7at2hf-neon-fslc-linux-gnueabi/btrfs-tools/4.17.1-r0/recipe-sysroot-native/usr/bin/python3-native:/home/amit/Documents/yocto_imx/fsl-community-bsp/sources/poky/scripts:/home/amit/Documents/yocto_imx/fsl-community-bsp/build/tmp/work/armv7at2hf-neon-fslc-linux-gnueabi/btrfs-tools/4.17.1-r0/recipe-sysroot-native/usr/bin/arm-fslc-linux-gnueabi:/home/amit/Documents/yocto_imx/fsl-community-bsp/build/tmp/work/armv7at2hf-neon-fslc-linux-gnueabi/btrfs-tools/4.17.1-r0/recipe-sysroot/usr/bin/crossscripts:/home/amit/Documents/yocto_imx/fsl-community-bsp/build/tmp/work/armv7at2hf-neon-fslc-linux-gnueabi/btrfs-tools/4.17.1-r0/recipe-sysroot-native/usr/sbin:/home/amit/Documents/yocto_imx/fsl-community-bsp/build/tmp/work/armv7at2hf-neon-fslc-linux-gnueabi/btrfs-tools/4.17.1-r0/recipe-sysroot-native/usr/bin:/home/amit/Documents/yocto_imx/fsl-community-bsp/build/tmp/work/armv7at2hf-neon-fslc-linux-gnueabi/btrfs-tools/4.17.1-r0/recipe-sysroot-native/sbin:/home/amit/Documents/yocto_imx/fsl-community-bsp/build/tmp/work/armv7at2hf-neon-fslc-linux-gnueabi/btrfs-tools/4.17.1-r0/recipe-sysroot-native/bin:/home/amit/Documents/yocto_imx/fsl-community-bsp/sources/poky/bitbake/bin:/home/amit/Documents/yocto_imx/fsl-community-bsp/build/tmp/hosttools"; export HOME="/home/amit"; LANG=C git -c core.fsyncobjectfiles=0 clone --bare --mirror git://git.kernel.org/pub/scm/linux/kernel/git/kdave/btrfs-progs.git /home/amit/Documents/yocto_imx/fsl-community-bsp/downloads//git2/git.kernel.org.pub.scm.linux.kernel.git.kdave.btrfs-progs.git --progress failed with exit code 128, output:
Cloning into bare repository '/home/amit/Documents/yocto_imx/fsl-community-bsp/downloads//git2/git.kernel.org.pub.scm.linux.kernel.git.kdave.btrfs-progs.git'...
fatal: Unable to look up git.kernel.org (port 9418) (Name or service not known)
ERROR: btrfs-tools-4.17.1-r0 do_fetch: Fetcher failure for URL: 'git://git.kernel.org/pub/scm/linux/kernel/git/kdave/btrfs-progs.git'. Unable to fetch URL from any source.
ERROR: btrfs-tools-4.17.1-r0 do_fetch: Function failed: base_do_fetch
ERROR: Logfile of failure stored in: /home/amit/Documents/yocto_imx/fsl-community-bsp/build/tmp/work/armv7at2hf-neon-fslc-linux-gnueabi/btrfs-tools/4.17.1-r0/temp/log.do_fetch.31316
ERROR: Task (/home/amit/Documents/yocto_imx/fsl-community-bsp/sources/poky/meta/recipes-devtools/btrfs-tools/btrfs-tools_4.17.1.bb:do_fetch) failed with exit code '1'
ERROR: u-boot-fslc-v2018.11+gitAUTOINC+6e25ce6f3c-r0 do_fetch: Fetcher failure: Fetch command export PSEUDO_DISABLED=1; export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1000/bus"; export SSH_AGENT_PID="1449"; export SSH_AUTH_SOCK="/run/user/1000/keyring/ssh"; export PATH="/home/amit/Documents/yocto_imx/fsl-community-bsp/build/tmp/sysroots-uninative/x86_64-linux/usr/bin:/home/amit/Documents/yocto_imx/fsl-community-bsp/sources/poky/scripts:/home/amit/Documents/yocto_imx/fsl-community-bsp/build/tmp/work/imx6qdlsabresd-fslc-linux-gnueabi/u-boot-fslc/v2018.11+gitAUTOINC+6e25ce6f3c-r0/recipe-sysroot-native/usr/bin/arm-fslc-linux-gnueabi:/home/amit/Documents/yocto_imx/fsl-community-bsp/build/tmp/work/imx6qdlsabresd-fslc-linux-gnueabi/u-boot-fslc/v2018.11+gitAUTOINC+6e25ce6f3c-r0/recipe-sysroot/usr/bin/crossscripts:/home/amit/Documents/yocto_imx/fsl-community-bsp/build/tmp/work/imx6qdlsabresd-fslc-linux-gnueabi/u-boot-fslc/v2018.11+gitAUTOINC+6e25ce6f3c-r0/recipe-sysroot-native/usr/sbin:/home/amit/Documents/yocto_imx/fsl-community-bsp/build/tmp/work/imx6qdlsabresd-fslc-linux-gnueabi/u-boot-fslc/v2018.11+gitAUTOINC+6e25ce6f3c-r0/recipe-sysroot-native/usr/bin:/home/amit/Documents/yocto_imx/fsl-community-bsp/build/tmp/work/imx6qdlsabresd-fslc-linux-gnueabi/u-boot-fslc/v2018.11+gitAUTOINC+6e25ce6f3c-r0/recipe-sysroot-native/sbin:/home/amit/Documents/yocto_imx/fsl-community-bsp/build/tmp/work/imx6qdlsabresd-fslc-linux-gnueabi/u-boot-fslc/v2018.11+gitAUTOINC+6e25ce6f3c-r0/recipe-sysroot-native/bin:/home/amit/Documents/yocto_imx/fsl-community-bsp/sources/poky/bitbake/bin:/home/amit/Documents/yocto_imx/fsl-community-bsp/build/tmp/hosttools"; export HOME="/home/amit"; LANG=C git -c core.fsyncobjectfiles=0 clone --bare --mirror git://github.com/Freescale/u-boot-fslc.git /home/amit/Documents/yocto_imx/fsl-community-bsp/downloads//git2/github.com.Freescale.u-boot-fslc.git --progress failed with exit code 128, output:
Cloning into bare repository '/home/amit/Documents/yocto_imx/fsl-community-bsp/downloads//git2/github.com.Freescale.u-boot-fslc.git'...
ERROR: u-boot-fslc-v2018.11+gitAUTOINC+6e25ce6f3c-r0 do_fetch: Fetcher failure for URL: 'git://github.com/Freescale/u-boot-fslc.git;branch=2018.11+fslc'. Unable to fetch URL from any source.
ERROR: u-boot-fslc-v2018.11+gitAUTOINC+6e25ce6f3c-r0 do_fetch: Function failed: base_do_fetch
ERROR: Logfile of failure stored in: /home/amit/Documents/yocto_imx/fsl-community-bsp/build/tmp/work/imx6qdlsabresd-fslc-linux-gnueabi/u-boot-fslc/v2018.11+gitAUTOINC+6e25ce6f3c-r0/temp/log.do_fetch.14069
ERROR: Task (/home/amit/Documents/yocto_imx/fsl-community-bsp/sources/meta-freescale/recipes-bsp/u-boot/u-boot-fslc_2018.11.bb:do_fetch) failed with exit code '1'
ERROR: binutils-cross-arm-2.31.1-r0 do_fetch: Fetcher failure: Fetch command export PSEUDO_DISABLED=1; export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1000/bus"; export SSH_AGENT_PID="1449"; export SSH_AUTH_SOCK="/run/user/1000/keyring/ssh"; export PATH="/home/amit/Documents/yocto_imx/fsl-community-bsp/build/tmp/work/x86_64-linux/binutils-cross-arm/2.31.1-r0/recipe-sysroot-native/usr/bin/texinfo-dummy-native:/home/amit/Documents/yocto_imx/fsl-community-bsp/build/tmp/sysroots-uninative/x86_64-linux/usr/bin:/home/amit/Documents/yocto_imx/fsl-community-bsp/sources/poky/scripts:/home/amit/Documents/yocto_imx/fsl-community-bsp/build/tmp/work/x86_64-linux/binutils-cross-arm/2.31.1-r0/recipe-sysroot-native/usr/bin/arm-fslc-linux-gnueabi:/home/amit/Documents/yocto_imx/fsl-community-bsp/build/tmp/work/x86_64-linux/binutils-cross-arm/2.31.1-r0/recipe-sysroot-native/home/amit/Documents/yocto_imx/fsl-community-bsp/build/tmp/work/x86_64-linux/binutils-cross-arm/2.31.1-r0/recipe-sysroot-native/usr/bin/arm-fslc-linux-gnueabi/crossscripts:/home/amit/Documents/yocto_imx/fsl-community-bsp/build/tmp/work/x86_64-linux/binutils-cross-arm/2.31.1-r0/recipe-sysroot-native/usr/sbin:/home/amit/Documents/yocto_imx/fsl-community-bsp/build/tmp/work/x86_64-linux/binutils-cross-arm/2.31.1-r0/recipe-sysroot-native/usr/bin:/home/amit/Documents/yocto_imx/fsl-community-bsp/build/tmp/work/x86_64-linux/binutils-cross-arm/2.31.1-r0/recipe-sysroot-native/sbin:/home/amit/Documents/yocto_imx/fsl-community-bsp/build/tmp/work/x86_64-linux/binutils-cross-arm/2.31.1-r0/recipe-sysroot-native/bin:/home/amit/Documents/yocto_imx/fsl-community-bsp/sources/poky/bitbake/bin:/home/amit/Documents/yocto_imx/fsl-community-bsp/build/tmp/hosttools"; export HOME="/home/amit"; LANG=C git -c core.fsyncobjectfiles=0 clone --bare --mirror git://sourceware.org/git/binutils-gdb.git /home/amit/Documents/yocto_imx/fsl-community-bsp/downloads//git2/sourceware.org.git.binutils-gdb.git --progress failed with exit code 128, output:
Cloning into bare repository '/home/amit/Documents/yocto_imx/fsl-community-bsp/downloads//git2/sourceware.org.git.binutils-gdb.git'...
fatal: unable to connect to sourceware.org:
sourceware.org[0: 209.132.180.131]: errno=Connection refused
ERROR: binutils-cross-arm-2.31.1-r0 do_fetch: Fetcher failure for URL: 'git://sourceware.org/git/binutils-gdb.git;branch=binutils-2_31-branch;protocol=git'. Unable to fetch URL from any source.
ERROR: binutils-cross-arm-2.31.1-r0 do_fetch: Function failed: base_do_fetch
ERROR: Logfile of failure stored in: /home/amit/Documents/yocto_imx/fsl-community-bsp/build/tmp/work/x86_64-linux/binutils-cross-arm/2.31.1-r0/temp/log.do_fetch.29828
ERROR: Task (/home/amit/Documents/yocto_imx/fsl-community-bsp/sources/poky/meta/recipes-devtools/binutils/binutils-cross_2.31.bb:do_fetch) failed with exit code '1'
NOTE: Tasks Summary: Attempted 838 tasks of which 0 didn't need to be rerun and 4 failed.
NOTE: Writing buildhistory
Summary: 4 tasks failed:
Summary: There were 7 WARNING messages shown.
%3CLINGO-SUB%20id%3D%22lingo-sub-1117386%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX%20Yocto%20Project%EF%BC%9A%E3%82%88%E3%81%8F%E3%81%82%E3%82%8B%E8%B3%AA%E5%95%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1117386%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-93844%22%20target%3D%22_blank%22%3Ei.MX6%E3%81%AEYocto%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-93990%22%20target%3D%22_blank%22%3EYocto%20Project%20i.MX%3A%20Freescale%20Yocto%20Project%E3%81%A7%E5%8D%94%E5%8A%9B%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%81%84%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-94024%22%20target%3D%22_blank%22%3Ei.MX%20Yocto%20Project%3A%20bitbake%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20Freescale%20Yocto%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-94964%22%20target%3D%22_blank%22%3Ei.MX%20Yocto%20Project%3A%20hob%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20Freescale%20Yocto%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%83%93%E3%83%AB%E3%83%89%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-94055%22%20target%3D%22_blank%22%3Ei.MX%20Yocto%20Project%3A%20%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-94056%22%20target%3D%22_blank%22%3Ei.MX%20Yocto%20Project%3A%20%E4%BA%8B%E5%89%8D%E3%81%AB%E6%A7%8B%E7%AF%89%E3%81%95%E3%82%8C%E3%81%9F%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-94057%22%20target%3D%22_blank%22%3EYocto%20Project%20i.MX%E3%80%81%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%82%92%E9%80%9F%E3%81%8F%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-94966%22%20target%3D%22_blank%22%3Ei.MX%20Yocto%20Project%3A%20%E3%83%93%E3%83%AB%E3%83%89%E4%B8%AD%E3%81%AB%E3%83%87%E3%82%A3%E3%82%B9%E3%82%AF%E5%AE%B9%E9%87%8F%E3%82%92%E7%AF%80%E7%B4%84%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%81%84%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-94967%22%20target%3D%22_blank%22%3Ei.MX%20Yocto%20Project%3A%20%E6%97%A2%E5%AD%98%E3%81%AE%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%92%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%81%84%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-94970%22%20target%3D%22_blank%22%3Ei.MX%20Yocto%20Project%3A%20%E4%BB%AE%E6%83%B3%E3%83%9E%E3%82%B7%E3%83%B3%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E3%83%93%E3%83%AB%E3%83%89%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-94971%22%20target%3D%22_blank%22%3Ei.MX%20Yocto%20Project%3A%20(%E6%9C%80%E6%96%B0%E3%81%AE)%20%E3%83%A1%E3%82%A4%E3%83%B3%E3%83%A9%E3%82%A4%E3%83%B3%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%A7%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-95003%22%20target%3D%22_blank%22%3Ei.MX%20Yocto%20Project%3A%20%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92(%E8%BF%85%E9%80%9F%E3%81%AB)%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%A6%E3%83%86%E3%82%B9%E3%83%88%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%81%84%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-95018%22%20target%3D%22_blank%22%3Ei.MX%20Yocto%20Project%3A%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AB%E5%90%AB%E3%81%BE%E3%82%8C%E3%82%8B%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%81%84%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-95264%22%20target%3D%22_blank%22%3Ei.MX%20Yocto%20Project%3A%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E6%89%8B%E5%8B%95%E3%81%A7%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%81%84%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-95252%22%20target%3D%22_blank%22%3Ei.MX%20Yocto%20Project%3A%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AB%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E5%BD%93%E3%81%A6%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%81%84%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fmessage%2F342494%22%20target%3D%22_blank%22%3Ei.MX%20Yocto%20Proyect%3A%E6%96%B0%E3%81%97%E3%81%84%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-95266%22%20target%3D%22_blank%22%3Ei.MX%20Yocto%20Project%3A%20%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%E3%81%AB%E8%B2%A2%E7%8C%AE%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fbugzilla.yoctoproject.org%2Fbuglist.cgi%3Fproduct%3DBSPs%26amp%3Bcomponent%3Dbsps-meta-fsl-arm%26amp%3Bresolution%3D---%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ei.MX%20Yocto%20Project%3A%20%E7%8F%BE%E5%9C%A8%E3%81%AE%20BSP%20%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AF%E3%81%A9%E3%81%93%E3%81%A7%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FFreescale%2Ffsl-community-bsp-platform%2Fblob%2Fdylan%2Fdefault.xml%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ei.MX%20Yocto%20Project%3A%20%E4%B8%BB%E6%B5%81%E3%81%AE%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%81%AF%E3%81%A9%E3%81%93%E3%81%A7%E3%83%9B%E3%82%B9%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ETutorials%3A%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-94849%22%20target%3D%22_blank%22%3EYocto%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%20-%20HOME%3C%2FA%3E%20%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fwww.slideshare.net%2FOtavioSalvador%2Fyocto-training-in-english%22%20title%3D%22http%3A%2F%2Fwww.slideshare.net%2FOtavioSalvador%2Fyocto-training-in-english%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.slideshare.net%2FOtavioSalvador%2Fyocto-training-in-english%3C%2FA%3E-%20%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%E3%81%AE%E3%83%A1%E3%83%B3%E3%83%86%E3%83%8A%E3%83%BC%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%E7%B4%A0%E6%99%B4%E3%82%89%E3%81%97%E3%81%84%E3%83%81%E3%83%A5%E3%83%BC%E3%83%88%E3%83%AA%E3%82%A2%E3%83%AB(%E3%83%9D%E3%83%AB%E3%83%88%E3%82%AC%E3%83%AB%E8%AA%9E%E7%89%88%E3%82%82%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99)%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-95096%22%20target%3D%22_blank%22%3Ei.MX%20Yocto%20Project%3A%20Freescale%20Yocto%20Project%20Tutorial%3C%2FA%3E%20-%20%E5%9F%BA%E6%9C%AC%E7%9A%84%E3%81%AA%E9%96%8B%E7%99%BA%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%AE%E4%BB%96%EF%BC%9A%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-94953%22%20target%3D%22_blank%22%3E%E4%BE%BF%E5%88%A9%E3%81%AA%20bitbake%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-94874%22%20target%3D%22_blank%22%3Ei.MX%20Yocto%20Project%3A%20ltib%20%E3%81%A8%20bitbake%20%E3%81%AE%E6%AF%94%E8%BC%83%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1117386%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EYocto%20Project%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1117401%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX%20Yocto%20Project%3A%20%E3%82%88%E3%81%8F%E3%81%82%E3%82%8B%E8%B3%AA%E5%95%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1117401%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%A6%AA%E5%88%87%E3%81%AB%E5%8A%A9%E3%81%91%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AF%E7%A7%81%E3%81%AE%E6%9C%80%E5%88%9D%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ebitbake%20core-image-minimal%3CBR%20%2F%3E%E6%B3%A8%3A%20conf%2Fbblayers.conf%20%E3%81%AF%E8%87%AA%E5%8B%95%E7%9A%84%E3%81%AB%E6%9B%B4%E6%96%B0%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E8%A7%A3%E6%9E%90%E3%83%AC%E3%82%B7%E3%83%94%3A100%25%20%7C%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%7C%E5%86%8D%E7%94%9F%E6%99%82%E9%96%93%3A%200%3A01%3A25%3CBR%20%2F%3E1704%20.bb%E3%81%AE%E8%A7%A3%E6%9E%90%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20(0%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%80%811704%20%E8%A7%A3%E6%9E%90)%E3%80%822370%20%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%80%81424%20%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97%E3%80%810%20%E3%83%9E%E3%82%B9%E3%82%AF%E3%80%810%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%80%82%3CBR%20%2F%3E%E6%B3%A8%3A%20%E6%AC%A0%E8%90%BD%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%BF%E3%82%B9%E3%82%AF%E3%82%AD%E3%83%A5%E3%83%BC%E3%81%AE%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%81%AE%E8%A7%A3%E6%B1%BA%3C%2FP%3E%3CP%3E%E3%83%93%E3%83%AB%E3%83%89%E6%A7%8B%E6%88%90%3A%3CBR%20%2F%3EBB_VERSION%20%3D%20%221.40.0%22%3CBR%20%2F%3EBUILD_SYS%20%3D%20%22x86_64-linux%22%3CBR%20%2F%3ENATIVELSBSTRING%20%3D%20%22ubuntu-18.04%22%3CBR%20%2F%3ETARGET_SYS%20%3D%20%22arm-fslc-linux-gnueabi%22%3CBR%20%2F%3E%E3%83%9E%E3%82%B7%E3%83%B3%20%3D%20%22imx6qdlsabresd%22%3CBR%20%2F%3EDISTRO%20%3D%20%22fslc-%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%22%3CBR%20%2F%3EDISTRO_VERSION%20%3D%20%222.6%22%3CBR%20%2F%3ETUNE_FEATURES%20%3D%20%22ARM%20ARMv7A%20VFP%20%E8%A6%AA%E6%8C%87%20%E3%83%8D%E3%82%AA%E3%83%B3%20%E3%82%B3%E3%83%BC%E3%83%ABconvention-hard%22%3CBR%20%2F%3ETARGET_FPU%20%3D%20%E3%80%8C%E7%A1%AC%E3%81%84%E3%80%8D%3CBR%20%2F%3E%E3%83%A1%E3%82%BF%20%3CBR%20%2F%3E%E3%83%A1%E3%82%BF%E3%83%9D%E3%83%83%E3%82%AD%E3%83%BC%20%3D%20%22my_local_dev%3AE6949336479E611A142834B6D9241514CBAEAF80%22%3CBR%20%2F%3E%E3%83%A1%E3%82%BFOE%20%3CBR%20%2F%3E%E3%83%A1%E3%82%BF%E3%83%9E%E3%83%AB%E3%83%81%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%3D%20%22my_local_dev%3A2D088D252624B19DF384AECC434D23AFB636178F%22%3CBR%20%2F%3E%E3%83%A1%E3%82%BF%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%3D%20%22my_local_dev%3A8B9A1E19B1983301bbad9f0c61a4d2ADC3fdd741%22%3CBR%20%2F%3E%E3%83%A1%E3%82%BF%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB3rdparty%20%3D%20%22my_local_dev%3A545e8094a140231e78b9284c3a3d94fcc573ae98%22%3CBR%20%2F%3E%E3%83%A1%E3%82%BF%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB-distro%20%3D%20%22my_local_dev%3A4a244af3993ae662624c6f615464e6806cc719a2%22%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%B3%A8%3A%20%E3%83%A6%E3%83%8B%E3%83%8D%E3%82%A4%E3%83%86%E3%82%A3%E3%83%96%20%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%20shim%20%E3%82%92%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fdownloads.yoctoproject.org%252Freleases%252Funinative%252F2.6%252Fx86_64-nativesdk-libc.tar.xz%253Bsha256sum%253D133387753a9acf3e1b788103c59fac91e968e2ee331d7a4b9498e926ada7be57%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fdownloads.yoctoproject.org%2Freleases%2Funinative%2F2.6%2Fx86_64-nativesdk-libc.tar.xz%3Bsha256sum%3D133387753a9acf3e1b788103c59fac91e968e2ee331d7a4b9498e926ada7be57%3C%2FA%3E%20%E3%81%8B%E3%82%89%E3%83%95%E3%82%A7%E3%83%83%E3%83%81%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%3A%20100%25%20%7C%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%7C%E6%99%82%E5%88%BB%3A%200%3A00%3A01%3CBR%20%2F%3E%20%E7%8A%B6%E6%85%8B%E3%81%AE%E6%A6%82%E8%A6%81%3A%20%E5%8B%9F%E9%9B%86%20675%20%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%200%20%E8%A6%8B%E9%80%83%E3%81%97%20675%20%E7%8F%BE%E5%9C%A8%200%20(%E4%B8%80%E8%87%B4%E7%8E%87%200%25%E3%80%81%E5%AE%8C%E4%BA%86%E7%8E%87%200%25)%3CBR%20%2F%3E%20%E6%B3%A8%3A%20SetScene%20%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%AE%E5%AE%9F%E8%A1%8C%3CBR%20%2F%3E%20%E6%B3%A8%3A%20RunQueue%20%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%AE%E5%AE%9F%E8%A1%8C%3CBR%20%2F%3E%3CSPAN%3E%20%E8%AD%A6%E5%91%8A%3A%20libffi-native-3.2.1-r0%20do_fetch%3A%20URL%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dftp%253A%252F%252Fsourceware.org%252Fpub%252Flibffi%252Flibffi-3.2.1.tar.gz%22%20target%3D%22_blank%22%3E%20ftp%3A%2F%2Fsourceware.org%2Fpub%2Flibffi%2Flibffi-3.2.1.tar.gz%3C%2FA%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%E3%81%AE%E5%8F%96%E5%BE%97%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20%E3%80%82%E5%8F%AF%E8%83%BD%E3%81%AA%E5%A0%B4%E5%90%88%E3%81%AF%20MIRRORS%3C%2FSPAN%3E%3CSPAN%3E%20%E3%82%92%E8%A9%A6%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%20%E8%AD%A6%E5%91%8A%3A%20alsa-lib-native-1.1.6-r0%20do_fetch%3A%20URL%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dftp%253A%252F%252Fftp.alsa-project.org%252Fpub%252Flib%252Falsa-lib-1.1.6.tar.bz2%22%20target%3D%22_blank%22%3E%20ftp%3A%2F%2Fftp.alsa-project.org%2Fpub%2Flib%2Falsa-lib-1.1.6.tar.bz2%20%E3%81%AE%E5%8F%96%E5%BE%97%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FA%3E%3CBR%20%2F%3E%20%E3%80%82%E5%8F%AF%E8%83%BD%E3%81%AA%E5%A0%B4%E5%90%88%E3%81%AF%20MIRRORS%20%E3%82%92%E8%A9%A6%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%20%E8%AD%A6%E5%91%8A%3Abinutils-cross-arm-2.31.1-r0%20do_fetch%3AURL%20git%3A%2F%2Fsourceware.org%2Fgit%2Fbinutils-gdb.git%3Bbranch%3Dbinutils-2_31-branch%3Bprotocol%3Dgit%20%E3%81%AE%E5%8F%96%E5%BE%97%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%8F%AF%E8%83%BD%E3%81%AA%E5%A0%B4%E5%90%88%E3%81%AF%20MIRRORS%20%E3%82%92%E8%A9%A6%E3%81%BF%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E8%AD%A6%E5%91%8A%3A%20update-rc.d-native-0.8-r0do_fetch%3AURL%20git%3A%2F%2Fgit.yoctoproject.org%2Fupdate-rc.d%20%E3%81%AE%E5%8F%96%E5%BE%97%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%8F%AF%E8%83%BD%E3%81%AA%E5%A0%B4%E5%90%88%E3%81%AF%20MIRRORS%20%E3%82%92%E8%A9%A6%E3%81%BF%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E8%AD%A6%E5%91%8A%3Alinux-fslc-imx-4.9-1.0.x%20%2B%20gitAUTOINC%2B953c6e30c9-r0%20do_fetch%3AURL%20git%3A%2F%2Fgithub.com%2FFreescale%2Flinux-fslc.git%3Bbranch%3D4.9-1.0.x-imx%20%E3%81%AE%E5%8F%96%E5%BE%97%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%8F%AF%E8%83%BD%E3%81%AA%E5%A0%B4%E5%90%88%E3%81%AFMIRRORS%E3%82%92%E8%A9%A6%E3%81%BF%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3Alinux-fslc-imx-4.9-1.0.x%20%2B%20gitAUTOINC%2B953c6e30c9-r0%20do_fetch%3A%E3%83%95%E3%82%A7%E3%83%83%E3%83%81%E3%83%A3%E3%83%BC%E3%81%AE%E5%A4%B1%E6%95%97%3A%E3%83%95%E3%82%A7%E3%83%83%E3%83%81%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%20PSEUDO_DISABLED%3D1%3B%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%20DBUS_SESSION_BUS_ADDRESS%3D%22unix%3Apath%3D%2Frun%2Fuser%2F1000%2Fbus%22%3B%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%20SSH_AGENT_PID%3D%221449%22%3B%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%20SSH_AUTH_SOCK%3D%22%2Frun%2Fuser%2F1000%2Fkeyring%2Fssh%22%3Bexport%20PATH%3D%22%2Fhome%2Famit%2FDocuments%2Fyocto_imx%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fsysroots-uninative%2Fx86_64-linux%2Fusr%2Fbin%3A%2Fhome%2Famit%2FDocuments%2Fyocto_imx%2Ffsl-community-bsp%2Fsources%2Fpoky%2Fscripts%3A%2Fhome%2Famit%2FDocuments%2Fyocto_imx%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fwork%2Fimx6qdlsabresd-fslc-linux-gnueabi%2Flinux-fslc-imx%2F4.9-1.0.x%2BgitAUTOINC%2B953c6e30c9-r0%2Frecipe-sysroot-native%2Fusr%2Fbin%2Farm-fslc-linux-gnueabi%3A%2Fhome%2Famit%2FDocuments%2Fyocto_imx%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fwork%2Fimx6qdlsabresd-fslc-linux-gnueabi%2Flinux-fslc-imx%2F4.9-1.0.x%2BgitAUTOINC%2B953c6e30c9-r0%2Frecipe-sysroot%2Fusr%2Fbin%2Fcrossscripts%3A%2Fhome%2Famit%2FDocuments%2Fyocto_imx%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fwork%2Fimx6qdlsabresd-fslc-linux-gnueabi%2Flinux-fslc-imx%2F4.9-1.0.x%2BgitAUTOINC%2B953c6e30c9-r0%2Frecipe-sysroot-native%2Fusr%2Fsbin%3A%2Fhome%2Famit%2FDocuments%2Fyocto_imx%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fwork%2Fimx6qdlsabresd-fslc-linux-gnueabi%2Flinux-fslc-imx%2F4.9-1.0.x%2BgitAUTOINC%2B953c6e30c9-r0%2Frecipe-sysroot-native%2Fusr%2Fbin%3A%2Fhome%2Famit%2FDocuments%2Fyocto_imx%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fwork%2Fimx6qdlsabresd-fslc-linux-gnueabi%2Flinux-fslc-imx%2F4.9-1.0.x%2BgitAUTOINC%2B953c6e30c9-r0%2Frecipe-sysroot-native%2Fsbin%3A%2Fhome%2Famit%2FDocuments%2Fyocto_imx%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fwork%2Fimx6qdlsabresd-fslc-linux-gnueabi%2Flinux-fslc-imx%2F4.9-1.0.x%2BgitAUTOINC%2B953c6e30c9-r0%2Frecipe-sysroot-native%2Fbin%3A%2Fhome%2Famit%2FDocuments%2Fyocto_imx%2Ffsl-community-bsp%2Fsources%2Fpoky%2Fbitbake%2Fbin%3A%2Fhome%2Famit%2FDocuments%2Fyocto_imx%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fhosttools%22%3Bexport%20HOME%3D%22%2Fhome%2Famit%22%3BLANG%3DC%20git%20-c%20core.fsyncobjectfiles%3D0clone%20--bare%20--mirror%20git%3A%2F%2Fgithub.com%2FFreescale%2Flinux-fslc.git%20%2Fhome%2Famit%2FDocuments%2Fyocto_imx%2Ffsl-community-bsp%2Fdownloads%2F%2Fgit2%2Fgithub.com.Freescale.linux-fslc.git%20--progress%20%E3%81%8C%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%20128%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%87%BA%E5%8A%9B%3A%3CBR%20%2F%3E%E3%83%99%E3%82%A2%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%20'%2Fhome%2Famit%2FDocuments%2Fyocto_imx%2Ffsl-community-bsp%2Fdownloads%2F%2Fgit2%2Fgithub.com.Freescale.linux-fslc.git'%E3%81%AB%E3%82%AF%E3%83%AD%E3%83%BC%E3%83%B3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3CBR%20%2F%3Efatal%3A%20github.com%20%E3%82%92%E6%A4%9C%E7%B4%A2%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%20(%E3%83%9D%E3%83%BC%E3%83%88%209418)%20(%E5%90%8D%E5%89%8D%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%81%8C%E4%B8%8D%E6%98%8E)%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20linux-fslc-imx-4.9-1.0.x%2BgitAUTOINC%2B953c6e30c9-r0%20do_fetch%3A%20URL%20%E3%81%AE%E3%83%95%E3%82%A7%E3%83%83%E3%83%81%E3%83%A3%E3%83%BC%E3%81%AE%E5%A4%B1%E6%95%97%3A%20'git%3A%2F%2Fgithub.com%2FFreescale%2Flinux-fslc.git%3Bbranch%3D4.9-1.0.x-imx'%E3%81%A9%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%8B%E3%82%89%E3%82%82%20URL%20%E3%82%92%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3Alinux-fslc-imx-4.9-1.0.x%20%2B%20gitAUTOINC%2B953c6e30c9-r0%20do_fetch%3A%E9%96%A2%E6%95%B0%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3Abase_do_fetch%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%E9%9A%9C%E5%AE%B3%E3%81%AE%E3%83%AD%E3%82%B0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%2Fhome%2Famit%2FDocuments%2Fyocto_imx%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fwork%2Fimx6qdlsabresd-fslc-linux-gnueabi%2Flinux-fslc-imx%2F4.9-1.0.x%2BgitAUTOINC%2B953c6e30c9-r0%2Ftemp%2Flog.do_fetch.15140%E3%81%AB%E4%BF%9D%E5%AD%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%82%BF%E3%82%B9%E3%82%AF(%2Fhome%2Famit%2FDocuments%2Fyocto_imx%2Ffsl-community-bsp%2Fsources%2Fmeta-freescale%2Frecipes-kernel%2Flinux%2Flinux-fslc-imx_4.9-1.0.x.bb%3Ado_fetch)%E3%81%8C%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%E3%80%8C1%E3%80%8D%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E8%AD%A6%E5%91%8A%3A%20btrfs-tools-4.17.1-r0%20do_fetch%3A%20URL%20git%3A%2F%2Fgit.kernel.org%2Fpub%2Fscm%2Flinux%2Fkernel%2Fgit%2Fkdave%2Fbtrfs-progs.git%20%E3%81%AE%E3%83%95%E3%82%A7%E3%83%83%E3%83%81%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%8F%AF%E8%83%BD%E3%81%AA%E5%A0%B4%E5%90%88%E3%81%AF%20MIRRORS%20%E3%82%92%E8%A9%A6%E3%81%BF%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E8%AD%A6%E5%91%8A%3A%20u-boot-fslc-v2018.11%2BgitAUTOINC%2B6e25ce6f3c-r0do_fetch%3A%20URL%20git%3A%2F%2Fgithub.com%2FFreescale%2Fu-boot-fslc.git%3Bbranch%3D2018.11%2Bfslc%20%E3%81%AE%E5%8F%96%E5%BE%97%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%8F%AF%E8%83%BD%E3%81%AA%E5%A0%B4%E5%90%88%E3%81%AF%20MIRRORS%20%E3%82%92%E8%A9%A6%E3%81%BF%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3Abtrfs-tools-4.17.1-r0%20do_fetch%3A%E3%83%95%E3%82%A7%E3%83%83%E3%83%81%E3%83%A3%E3%83%BC%E3%81%AE%E5%A4%B1%E6%95%97%3A%E3%83%95%E3%82%A7%E3%83%83%E3%83%81%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88PSEUDO_DISABLED%20%3D%201%3B%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%20DBUS_SESSION_BUS_ADDRESS%3D%22unix%3Apath%3D%2Frun%2Fuser%2F1000%2Fbus%22%3B%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%20SSH_AGENT_PID%3D%221449%22%3B%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%20SSH_AUTH_SOCK%3D%22%2Frun%2Fuser%2F1000%2Fkeyring%2Fssh%22%3Bexport%20PATH%3D%22%2Fhome%2Famit%2FDocuments%2Fyocto_imx%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fsysroots-uninative%2Fx86_64-linux%2Fusr%2Fbin%3A%2Fhome%2Famit%2FDocuments%2Fyocto_imx%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fwork%2Farmv7at2hf-neon-fslc-linux-gnueabi%2Fbtrfs-tools%2F4.17.1-r0%2Frecipe-sysroot-native%2Fusr%2Fbin%2Fpython3-native%3A%2Fhome%2Famit%2FDocuments%2Fyocto_imx%2Ffsl-community-bsp%2Fsources%2Fpoky%2Fscripts%3A%2Fhome%2Famit%2FDocuments%2Fyocto_imx%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fwork%2Farmv7at2hf-neon-fslc-linux-gnueabi%2Fbtrfs-tools%2F4.17.1-r0%2Frecipe-sysroot-native%2Fusr%2Fbin%2Farm-fslc-linux-gnueabi%3A%2Fhome%2Famit%2FDocuments%2Fyocto_imx%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fwork%2Farmv7at2hf-neon-fslc-linux-gnueabi%2Fbtrfs-tools%2F4.17.1-r0%2Frecipe-sysroot%2Fusr%2Fbin%2Fcrossscripts%3A%2Fhome%2Famit%2FDocuments%2Fyocto_imx%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fwork%2Farmv7at2hf-neon-fslc-linux-gnueabi%2Fbtrfs-tools%2F4.17.1-r0%2Frecipe-sysroot-native%2Fusr%2Fsbin%3A%2Fhome%2Famit%2FDocuments%2Fyocto_imx%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fwork%2Farmv7at2hf-neon-fslc-linux-gnueabi%2Fbtrfs-tools%2F4.17.1-r0%2Frecipe-sysroot-native%2Fusr%2Fbin%3A%2Fhome%2Famit%2FDocuments%2Fyocto_imx%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fwork%2Farmv7at2hf-neon-fslc-linux-gnueabi%2Fbtrfs-tools%2F4.17.1-r0%2Frecipe-sysroot-native%2Fsbin%3A%2Fhome%2Famit%2FDocuments%2Fyocto_imx%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fwork%2Farmv7at2hf-neon-fslc-linux-gnueabi%2Fbtrfs-tools%2F4.17.1-r0%2Frecipe-sysroot-native%2Fbin%3A%2Fhome%2Famit%2FDocuments%2Fyocto_imx%2Ffsl-community-bsp%2Fsources%2Fpoky%2Fbitbake%2Fbin%3A%2Fhome%2Famit%2FDocuments%2Fyocto_imx%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fhosttools%22%3Bexport%20HOME%3D%22%2Fhome%2Famit%22%3BLANG%3DC%20git%20-c%20core.fsyncobjectfiles%3D0clone%20--bare%20--mirror%20git%3A%2F%2Fgit.kernel.org%2Fpub%2Fscm%2Flinux%2Fkernel%2Fgit%2Fkdave%2Fbtrfs-progs.git%20%2Fhome%2Famit%2FDocuments%2Fyocto_imx%2Ffsl-community-bsp%2Fdownloads%2F%2Fgit2%2Fgit.kernel.org.pub.scm.linux.kernel.git.kdave.btrfs-progs.git%20--progress%20%E3%81%8C%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%20128%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E3%83%99%E3%82%A2%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%20'%2Fhome%2Famit%2FDocuments%2Fyocto_imx%2Ffsl-community-bsp%2Fdownloads%2F%2Fgit2%2Fgit.kernel.org.pub.scm.linux.kernel.git.kdave.btrfs-progs.git'%E3%81%AB%E3%82%AF%E3%83%AD%E3%83%BC%E3%83%B3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3CBR%20%2F%3Efatal%3A%20git.kernel.org%20%E3%82%92%E6%A4%9C%E7%B4%A2%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%20(%E3%83%9D%E3%83%BC%E3%83%88%209418)%20(%E5%90%8D%E5%89%8D%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%81%8C%E4%B8%8D%E6%98%8E)%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20btrfs-tools-4.17.1-r0%20do_fetch%3A%20URL%20%E3%81%AE%E3%83%95%E3%82%A7%E3%83%83%E3%83%81%E3%83%A3%E3%83%BC%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%20'git%3A%2F%2Fgit.kernel.org%2Fpub%2Fscm%2Flinux%2Fkernel%2Fgit%2Fkdave%2Fbtrfs-progs.git'%E3%80%82%E3%81%A9%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%8B%E3%82%89%E3%82%82%20URL%20%E3%82%92%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20btrfs-tools-4.17.1-r0%20do_fetch%3A%20%E9%96%A2%E6%95%B0%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%20base_do_fetch%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%E9%9A%9C%E5%AE%B3%E3%81%AE%E3%83%AD%E3%82%B0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%2F%20home%20%2F%20amit%20%2F%20Documents%20%2F%20yocto_imx%20%2F%20fsl-community-bsp%20%2F%20build%20%2F%20tmp%20%2F%20work%20%2F%20armv7at2hf-neon-fslc-linux-gnueabi%20%2F%20btrfs-tools%20%2F%204.17.1-r0%20%2F%20temp%20%2F%20log.do_fetch.31316%E3%81%AB%E4%BF%9D%E5%AD%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%82%BF%E3%82%B9%E3%82%AF%EF%BC%88%2Fhome%2Famit%2FDocuments%2Fyocto_imx%2Ffsl-community-bsp%2Fsources%2Fpoky%2Fmeta%2Frecipes-devtools%2Fbtrfs-tools%2Fbtrfs-tools_4.17.1.bb%3Ado_fetch)%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%20'1'%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20u-boot-fslc-v2018.11%2BgitAUTOINC%2B6e25ce6f3c-r0do_fetch%3A%E3%83%95%E3%82%A7%E3%83%83%E3%83%81%E3%83%A3%E3%83%BC%E3%81%AE%E5%A4%B1%E6%95%97%3A%E3%83%95%E3%82%A7%E3%83%83%E3%83%81%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88PSEUDO_DISABLED%20%3D%201%3B%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%20DBUS_SESSION_BUS_ADDRESS%3D%22unix%3Apath%3D%2Frun%2Fuser%2F1000%2Fbus%22%3B%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%20SSH_AGENT_PID%3D%221449%22%3B%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%20SSH_AUTH_SOCK%3D%22%2Frun%2Fuser%2F1000%2Fkeyring%2Fssh%22%3Bexport%20PATH%3D%22%2Fhome%2Famit%2FDocuments%2Fyocto_imx%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fsysroots-uninative%2Fx86_64-linux%2Fusr%2Fbin%3A%2Fhome%2Famit%2FDocuments%2Fyocto_imx%2Ffsl-community-bsp%2Fsources%2Fpoky%2Fscripts%3A%2Fhome%2Famit%2FDocuments%2Fyocto_imx%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fwork%2Fimx6qdlsabresd-fslc-linux-gnueabi%2Fu-boot-fslc%2Fv2018.11%2BgitAUTOINC%2B6e25ce6f3c-r0%2Frecipe-sysroot-native%2Fusr%2Fbin%2Farm-fslc-linux-gnueabi%3A%2Fhome%2Famit%2FDocuments%2Fyocto_imx%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fwork%2Fimx6qdlsabresd-fslc-linux-gnueabi%2Fu-boot-fslc%2Fv2018.11%2BgitAUTOINC%2B6e25ce6f3c-r0%2Frecipe-sysroot%2Fusr%2Fbin%2Fcrossscripts%3A%2Fhome%2Famit%2FDocuments%2Fyocto_imx%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fwork%2Fimx6qdlsabresd-fslc-linux-gnueabi%2Fu-boot-fslc%2Fv2018.11%2BgitAUTOINC%2B6e25ce6f3c-r0%2Frecipe-sysroot-native%2Fusr%2Fsbin%3A%2Fhome%2Famit%2FDocuments%2Fyocto_imx%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fwork%2Fimx6qdlsabresd-fslc-linux-gnueabi%2Fu-boot-fslc%2Fv2018.11%2BgitAUTOINC%2B6e25ce6f3c-r0%2Frecipe-sysroot-native%2Fusr%2Fbin%3A%2Fhome%2Famit%2FDocuments%2Fyocto_imx%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fwork%2Fimx6qdlsabresd-fslc-linux-gnueabi%2Fu-boot-fslc%2Fv2018.11%2BgitAUTOINC%2B6e25ce6f3c-r0%2Frecipe-sysroot-native%2Fsbin%3A%2Fhome%2Famit%2FDocuments%2Fyocto_imx%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fwork%2Fimx6qdlsabresd-fslc-linux-gnueabi%2Fu-boot-fslc%2Fv2018.11%2BgitAUTOINC%2B6e25ce6f3c-r0%2Frecipe-sysroot-native%2Fbin%3A%2Fhome%2Famit%2FDocuments%2Fyocto_imx%2Ffsl-community-bsp%2Fsources%2Fpoky%2Fbitbake%2Fbin%3A%2Fhome%2Famit%2FDocuments%2Fyocto_imx%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fhosttools%22%3Bexport%20HOME%3D%22%2Fhome%2Famit%22%3BLANG%3DC%20git%20-c%20core.fsyncobjectfiles%3D0clone%20--bare%20--mirror%20git%3A%2F%2Fgithub.com%2FFreescale%2Fu-boot-fslc.git%20%2Fhome%2Famit%2FDocuments%2Fyocto_imx%2Ffsl-community-bsp%2Fdownloads%2F%2Fgit2%2Fgithub.com.Freescale.u-boot-fslc.git%20--progress%20%E3%81%8C%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%20128%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%87%BA%E5%8A%9B%3A%3CBR%20%2F%3E%E3%83%99%E3%82%A2%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%20'%2Fhome%2Famit%2FDocuments%2Fyocto_imx%2Ffsl-community-bsp%2Fdownloads%2F%2Fgit2%2Fgithub.com.Freescale.u-boot-fslc.git'%E3%81%AB%E3%82%AF%E3%83%AD%E3%83%BC%E3%83%B3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3CBR%20%2F%3Efatal%3A%20github.com%20%E3%82%92%E6%A4%9C%E7%B4%A2%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%20(%E3%83%9D%E3%83%BC%E3%83%88%209418)%20(%E5%90%8D%E5%89%8D%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%81%8C%E4%B8%8D%E6%98%8E)%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20u-boot-fslc-v2018.11%2BgitAUTOINC%2B6e25ce6f3c-r0do_fetch%3A%20URL%3A%20'git%3A%2F%2Fgithub.com%2FFreescale%2Fu-boot-fslc.git%3Bbranch%3D2018.11%2Bfslc'%20%E3%81%AE%E3%83%95%E3%82%A7%E3%83%83%E3%83%81%E3%83%A3%E3%83%BC%E3%81%AE%E5%A4%B1%E6%95%97%E3%80%82%E3%81%A9%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%8B%E3%82%89%E3%82%82%20URL%20%E3%82%92%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20u-boot-fslc-v2018.11%2BgitAUTOINC%2B6e25ce6f3c-r0do_fetch%3A%20%E6%A9%9F%E8%83%BD%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%20base_do_fetch%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%E9%9A%9C%E5%AE%B3%E3%81%AE%E3%83%AD%E3%82%B0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%2Fhome%2Famit%2FDocuments%2Fyocto_imx%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fwork%2Fimx6qdlsabresd-fslc-linux-gnueabi%2Fu-boot-fslc%2Fv2018.11%2BgitAUTOINC%2B6e25ce6f3c-r0%2Ftemp%2Flog.do_fetch.14069%E3%81%AB%E4%BF%9D%E5%AD%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%82%BF%E3%82%B9%E3%82%AF(%2Fhome%2Famit%2FDocuments%2Fyocto_imx%2Ffsl-community-bsp%2Fsources%2Fmeta-freescale%2Frecipes-bsp%2Fu-boot%2Fu-boot-fslc_2018.11.bb%3Ado_fetch)%E3%81%8C%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%E3%80%8C1%E3%80%8D%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3Abinutils-cross-arm-2.31.1-r0%20do_fetch%3A%E3%83%95%E3%82%A7%E3%83%83%E3%83%81%E3%83%A3%E3%83%BC%E3%81%AE%E5%A4%B1%E6%95%97%3A%E3%83%95%E3%82%A7%E3%83%83%E3%83%81%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88PSEUDO_DISABLED%20%3D%201%3B%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%20DBUS_SESSION_BUS_ADDRESS%3D%22unix%3Apath%3D%2Frun%2Fuser%2F1000%2Fbus%22%3B%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%20SSH_AGENT_PID%3D%221449%22%3B%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%20SSH_AUTH_SOCK%3D%22%2Frun%2Fuser%2F1000%2Fkeyring%2Fssh%22%3Bexport%20PATH%3D%22%2Fhome%2Famit%2FDocuments%2Fyocto_imx%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Fbinutils-cross-arm%2F2.31.1-r0%2Frecipe-sysroot-native%2Fusr%2Fbin%2Ftexinfo-dummy-native%3A%2Fhome%2Famit%2FDocuments%2Fyocto_imx%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fsysroots-uninative%2Fx86_64-linux%2Fusr%2Fbin%3A%2Fhome%2Famit%2FDocuments%2Fyocto_imx%2Ffsl-community-bsp%2Fsources%2Fpoky%2Fscripts%3A%2Fhome%2Famit%2FDocuments%2Fyocto_imx%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Fbinutils-cross-arm%2F2.31.1-r0%2Frecipe-sysroot-native%2Fusr%2Fbin%2Farm-fslc-linux-gnueabi%3A%2Fhome%2Famit%2FDocuments%2Fyocto_imx%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Fbinutils-cross-arm%2F2.31.1-r0%2Frecipe-sysroot-native%2Fhome%2Famit%2FDocuments%2Fyocto_imx%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Fbinutils-cross-arm%2F2.31.1-r0%2Frecipe-sysroot-native%2Fusr%2Fbin%2Farm-fslc-linux-gnueabi%2Fcrossscripts%3A%2Fhome%2Famit%2FDocuments%2Fyocto_imx%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Fbinutils-cross-arm%2F2.31.1-r0%2Frecipe-sysroot-native%2Fusr%2Fsbin%3A%2Fhome%2Famit%2FDocuments%2Fyocto_imx%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Fbinutils-cross-arm%2F2.31.1-r0%2Frecipe-sysroot-native%2Fusr%2Fbin%3A%2Fhome%2Famit%2FDocuments%2Fyocto_imx%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Fbinutils-cross-arm%2F2.31.1-r0%2Frecipe-sysroot-native%2Fsbin%3A%2Fhome%2Famit%2FDocuments%2Fyocto_imx%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Fbinutils-cross-arm%2F2.31.1-r0%2Frecipe-sysroot-native%2Fbin%3A%2Fhome%2Famit%2FDocuments%2Fyocto_imx%2Ffsl-community-bsp%2Fsources%2Fpoky%2Fbitbake%2Fbin%3A%2Fhome%2Famit%2FDocuments%2Fyocto_imx%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fhosttools%22%3Bexport%20HOME%3D%22%2Fhome%2Famit%22%3BLANG%3DC%20git%20-c%20core.fsyncobjectfiles%3D0clone%20--bare%20--mirror%20git%3A%2F%2Fsourceware.org%2Fgit%2Fbinutils-gdb.git%20%2Fhome%2Famit%2FDocuments%2Fyocto_imx%2Ffsl-community-bsp%2Fdownloads%2F%2Fgit2%2Fsourceware.org.git.binutils-gdb.git%20--progress%20%E3%81%8C%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%20128%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E3%83%99%E3%82%A2%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%20'%2Fhome%2Famit%2FDocuments%2Fyocto_imx%2Ffsl-community-bsp%2Fdownloads%2F%2Fgit2%2Fsourceware.org.git.binutils-gdb.git'%E3%81%AB%E3%82%AF%E3%83%AD%E3%83%BC%E3%83%B3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3CBR%20%2F%3E%E8%87%B4%E5%91%BD%E7%9A%84%3Asourceware.org%20%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3A%3CBR%20%2F%3Esourceware.org%5B0%3A209.132.180.131%5D%3Aerrno%3D%E6%8E%A5%E7%B6%9A%E3%81%8C%E6%8B%92%E5%90%A6%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20binutils-cross-arm-2.31.1-r0%20do_fetch%3A%20URL%20%E3%81%AE%E3%83%95%E3%82%A7%E3%83%83%E3%83%81%E3%83%A3%E3%83%BC%E3%81%AE%E5%A4%B1%E6%95%97%3A%20'git%3A%2F%2Fsourceware.org%2Fgit%2Fbinutils-gdb.git%3Bbranch%3Dbinutils-2_31-branch%3Bprotocol%3Dgit'%E3%80%82%E3%81%A9%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%8B%E3%82%89%E3%82%82%20URL%20%E3%82%92%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3Abinutils-cross-arm-2.31.1-r0%20do_fetch%3A%E9%96%A2%E6%95%B0%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3Abase_do_fetch%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%E9%9A%9C%E5%AE%B3%E3%81%AE%E3%83%AD%E3%82%B0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E4%BF%9D%E5%AD%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3A%2Fhome%2Famit%2FDocuments%2Fyocto_imx%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Fbinutils-cross-arm%2F2.31.1-r0%2Ftemp%2Flog.do_fetch.29828%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%82%BF%E3%82%B9%E3%82%AF(%2F%20home%20%2F%20amit%20%2F%20Documents%20%2F%20yocto_imx%20%2F%20fsl-community-bsp%20%2F%20sources%20%2F%20poky%20%2F%20meta%20%2F%20recipes-devtools%20%2F%20binutils%20%2F%20binutils-cross_2.31.bb%3Ado_fetch)%E3%81%8C%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%E3%80%8C1%E3%80%8D%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E6%B3%A8%3A%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%AE%E6%A6%82%E8%A6%81%3A838%E5%80%8B%E3%81%AE%E3%82%BF%E3%82%B9%E3%82%AF%E3%82%92%E8%A9%A6%E8%A1%8C%E3%81%97%E3%80%81%E3%81%9D%E3%81%AE%E3%81%86%E3%81%A10%E5%80%8B%E3%81%AF%E5%86%8D%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%AA%E3%81%8F%E3%80%814%E5%80%8B%E3%81%AF%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E6%B3%A8%3A%20%E3%83%93%E3%83%AB%E3%83%89%E5%B1%A5%E6%AD%B4%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%3C%2FP%3E%3CP%3E%E6%A6%82%E8%A6%81%3A%204%20%E3%81%A4%E3%81%AE%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20%2Fhome%2Famit%2FDocuments%2Fyocto_imx%2Ffsl-community-bsp%2Fsources%2Fmeta-freescale%2Frecipes-kernel%2Flinux%2Flinux-fslc-imx_4.9-1.0.x.bb%3Ado_fetch%3CBR%20%2F%3E%20%2Fhome%2Famit%2FDocuments%2Fyocto_imx%2Ffsl-community-bsp%2Fsources%2Fpoky%2Fmeta%2Frecipes-devtools%2Fbtrfs-tools%2Fbtrfs-tools_4.17.1.bb%3Ado_fetch%3CBR%20%2F%3E%2Fhome%2Famit%2FDocuments%2Fyocto_imx%2Ffsl-community-bsp%2Fsources%2Fmeta-freescale%2Frecipes-bsp%2Fu-boot%2Fu-boot-fslc_2018.11.bb%3Ado_fetch%3CBR%20%2F%3E%20%2Fhome%2Famit%2FDocuments%2Fyocto_imx%2Ffsl-community-bsp%2Fsources%2Fpoky%2Fmeta%2Frecipes-devtools%2Fbinutils%2Fbinutils-cross_2.31.bb%3Ado_fetch%3CBR%20%2F%3E%E6%A6%82%E8%A6%81%3A7%E3%81%A4%E3%81%AE%E8%AD%A6%E5%91%8A%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1117400%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX%20Yocto%20Project%3A%20%E3%82%88%E3%81%8F%E3%81%82%E3%82%8B%E8%B3%AA%E5%95%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1117400%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%AF%E3%81%84%3BDora%20%E3%81%AF%E7%8F%BE%E5%9C%A8%E3%81%AE%E5%AE%89%E5%AE%9A%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E6%96%B0%E8%A3%BD%E5%93%81%E3%81%AF%E3%81%9D%E3%82%8C%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%81%84%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81%E5%B0%86%E6%9D%A5%E3%81%AE%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%AB%E9%81%A9%E3%81%97%E3%81%9F%E3%83%99%E3%83%BC%E3%82%B9%E3%81%A8%E7%B0%A1%E5%8D%98%E3%81%AA%E3%82%A2%E3%83%83%E3%83%97%E3%82%B0%E3%83%AC%E3%83%BC%E3%83%89%E3%81%8C%E5%8F%AF%E8%83%BD%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1117399%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX%20Yocto%20Project%3A%20%E3%82%88%E3%81%8F%E3%81%82%E3%82%8B%E8%B3%AA%E5%95%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1117399%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AF%203.0.35-1.1.0%2Byocto%2Bg21304e%20%E3%81%A8%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%A8%E3%82%AF%E3%82%BF%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E3%81%AF%E3%83%87%E3%82%A3%E3%83%A9%E3%83%B3%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82Dora%E3%82%92%E4%BD%BF%E3%81%86%E3%81%B9%E3%81%8D%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AFLinux%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%A7%E3%81%AEBIOS%E3%83%96%E3%83%BC%E3%83%88%E3%81%AB%E6%85%A3%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82uBoot%20imx%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E4%BD%95%E3%81%8B%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%A9%E3%81%86%E3%81%84%E3%81%86%E3%82%8F%E3%81%91%E3%81%8B%E3%83%96%E3%83%BC%E3%83%88%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8B%3F%E7%A7%81%E3%81%AEkontron%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AB%E3%81%AFu-boot%E3%81%8C%E3%81%82%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%A3%E3%81%9F%E3%81%AE%E3%81%A7%E3%80%81%E4%B8%8A%E8%A8%98%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%83%96%E3%83%BC%E3%83%88%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AB%E3%82%82u-boot%E3%82%B3%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%8D%E3%83%B3%E3%83%88%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1117398%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX%20Yocto%20Project%3A%20%E3%82%88%E3%81%8F%E3%81%82%E3%82%8B%E8%B3%AA%E5%95%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1117398%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%83%89%E3%83%A9%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%203.0.35%3F%E3%81%A8%E3%81%93%E3%82%8D%E3%81%A7%E3%80%81u-boot.imx%E3%81%AF%E5%8F%A4%E3%81%84u-boot.bin%E3%81%A8%E5%90%8C%E3%81%98%E3%81%A7%E3%81%99%E3%80%81%E3%81%9F%E3%81%A0%E3%80%81%E3%83%91%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%8C%E3%81%AA%E3%81%84%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1117397%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX%20Yocto%20Project%3A%20%E3%82%88%E3%81%8F%E3%81%82%E3%82%8B%E8%B3%AA%E5%95%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1117397%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%82%82%E3%81%A1%E3%82%8D%E3%82%93%E3%80%82%E5%A5%87%E5%A6%99%E3%81%AA%E3%81%93%E3%81%A8%E3%81%AB%E3%80%81LTIB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%20-%20%E5%94%AF%E4%B8%80%E3%81%AE%E6%98%8E%E3%82%89%E3%81%8B%E3%81%AA%E9%81%95%E3%81%84%E3%81%AF%E3%80%81LTIB%E3%81%8C%2F%E3%81%ABuImage%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%20-%20%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81%E3%81%9D%E3%82%8C%E3%82%92%E6%A9%9F%E8%83%BD%E3%81%95%E3%81%9B%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%81%AF%E3%83%96%E3%83%BC%E3%83%88%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E5%A4%89%E6%95%B0%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82Yocto%E3%81%AF%E3%81%BE%E3%81%A0%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%90%8C%E3%81%98%E5%A0%B4%E6%89%80%E3%81%A7uImages%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E4%BB%8A%E3%81%A7%E3%81%AF%E3%81%93%E3%82%8C%E3%81%AF%E7%A7%91%E5%AD%A6%E3%81%A8%E3%81%84%E3%81%86%E3%82%88%E3%82%8A%E3%82%82%E8%BF%B7%E4%BF%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E6%84%9F%E3%81%98%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%83%96%E3%83%BC%E3%83%88%E3%81%A7%E8%A8%BA%E6%96%AD%E3%81%AE%E9%80%B2%E8%A1%8C%E7%8A%B6%E6%B3%81%E6%83%85%E5%A0%B1%E3%82%92%E5%A2%97%E3%82%84%E3%81%99%E6%96%B9%E6%B3%95%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eusbboot%20%E3%81%AF%20LTIB%20USB%20%E3%82%B9%E3%83%86%E3%82%A3%E3%83%83%E3%82%AF%E3%82%92%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%8F%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82uImage%20%E3%81%AF%E3%80%81%E3%81%84%E3%81%9A%E3%82%8C%E3%81%AE%E5%A0%B4%E5%90%88%E3%82%82%E5%90%8C%E3%81%98%E5%A0%B4%E6%89%80%20(%2Fboot%2FuImage)%20%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%83%AB%E3%83%BC%E3%83%88%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AF%20%2Fdev%2Fsda1%20%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AF%E5%90%8C%E3%81%98%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1117396%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX%20Yocto%20Project%3A%20%E3%82%88%E3%81%8F%E3%81%82%E3%82%8B%E8%B3%AA%E5%95%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1117396%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Dominic%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BF%A1%E3%81%98%E3%82%89%E3%82%8C%E3%81%AA%E3%81%84%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AF%E7%89%A9%E4%BA%8B%E3%81%8C%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%A3%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E6%84%8F%E5%91%B3%E3%81%97%E3%81%BE%E3%81%99...%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%81%A8%E3%81%AF%E3%80%81%22bootargs%22%20%E3%81%AE%E9%81%A9%E5%88%87%E3%81%AA%E5%80%A4%E3%81%8C%E4%BD%95%E3%81%A7%E3%81%82%E3%82%8B%E3%81%8B%E3%82%92%E7%90%86%E8%A7%A3%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%8A%E3%81%9D%E3%82%89%E3%81%8F%E3%80%81%E6%88%90%E5%8A%9F%E3%81%97%E3%81%9FSD%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AE%E8%B5%B7%E5%8B%95%E3%81%8B%E3%82%89%E3%82%AB%E3%83%83%E3%83%88%26amp%3B%E3%83%9A%E3%83%BC%E3%82%B9%E3%83%88%E3%81%97%E3%81%A6%E3%80%81%E3%80%8C%2Fdev%2Fmmcblk0p%23%E3%80%8D%E3%82%92%E3%80%8C%2Fdev%2Fsda%23%E3%80%8D%E3%81%AB%E7%BD%AE%E3%81%8D%E6%8F%9B%E3%81%88%E3%81%A6%E3%80%81%E7%A8%BC%E5%83%8D%E3%81%95%E3%81%9B%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1117395%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX%20Yocto%20Project%3A%20%E3%82%88%E3%81%8F%E3%81%82%E3%82%8B%E8%B3%AA%E5%95%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1117395%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%8C%E3%82%92%E8%A9%A6%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F-%E3%80%8C%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E9%96%8B%E5%A7%8B%E3%80%8D%E3%81%A7%E3%83%8F%E3%83%B3%E3%82%B0%E3%81%97%E3%81%BE%E3%81%99(%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%82%B5%E3%83%A0%E3%81%A8%E3%83%AD%E3%83%BC%E3%83%89%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%9F%E5%BE%8C)%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%90%E3%82%B9%200%20%E3%82%92%E3%82%B9%E3%82%AD%E3%83%A3%E3%83%B3%E3%81%97%E3%81%A6%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E6%8E%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...4%20USB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B8%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AEUSB%E3%82%92%E3%82%B9%E3%82%AD%E3%83%A3%E3%83%B3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...1%20%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B8%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EUSB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B90%3A%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B90%3A%E3%83%99%E3%83%B3%E3%83%80%E3%83%BC%3ASanDisk%20Rev%3A2.01%E8%A3%BD%E5%93%81%3ACruzer%20Glide%3C%2FP%3E%3CP%3E%E3%82%BF%E3%82%A4%E3%83%97%3A%E3%83%8F%E3%83%BC%E3%83%89%E3%83%87%E3%82%A3%E3%82%B9%E3%82%AF%3C%2FP%3E%3CP%3E%E5%AE%B9%E9%87%8F%3A%2030532.5%20MB%20%3D%2029.8%E3%82%AE%E3%82%AC%E3%83%90%E3%82%A4%E3%83%88%20(62530624%20x%20512)%3C%2FP%3E%3CP%3E...%E7%8F%BE%E5%9C%A8%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EUSB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8B%E3%82%89%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8C%2Fboot%2FuImage%E3%80%8D%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%990%3A1%3C%2FP%3E%3CP%3E%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%89%E3%82%8C%E3%81%9F3872636%E3%83%90%E3%82%A4%E3%83%88%3C%2FP%3E%3CP%3E%23%23%20%E3%83%AC%E3%82%AC%E3%82%B7%E3%83%BC%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%8B%E3%82%89%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%2010800000%20%E3%81%A7%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20...%3C%2FP%3E%3CP%3E%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E5%90%8D%3A%20Linux-3.0.35-1.1.0%2Byocto%2Bg21304e%3C%2FP%3E%3CP%3E%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%20%E3%82%BF%E3%82%A4%E3%83%97%3A%20ARM%20Linux%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%20(%E9%9D%9E%E5%9C%A7%E7%B8%AE)%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B5%E3%82%A4%E3%82%BA%3A3872572%E3%83%90%E3%82%A4%E3%83%88%3D%203.7MiB%3C%2FP%3E%3CP%3E%E3%83%AD%E3%83%BC%E3%83%89%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A10008000%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%83%BC%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%3A10008000%3C%2FP%3E%3CP%3E%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%82%B5%E3%83%A0%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99...%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EOK%3C%2FP%3E%3CP%3E%E7%92%B0%E5%A2%83%E3%81%8B%E3%82%89%E5%8A%A0%E5%B7%A5%E3%81%95%E3%82%8C%E3%81%9F0x10e9%E3%82%92%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E8%B5%B7%E5%8B%95%E4%B8%AD%E2%80%A6%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1117394%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX%20Yocto%20Project%3A%20%E3%82%88%E3%81%8F%E3%81%82%E3%82%8B%E8%B3%AA%E5%95%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1117394%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Eu-boot.imx%E3%81%A8%E5%91%BC%E3%81%B0%E3%82%8C%E3%82%8Bdeploy%20%2F%20images%E3%81%AE%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AF%E3%80%81%E7%A7%81%E3%81%8C%E4%BD%95%E3%82%92%E3%81%99%E3%81%B9%E3%81%8D%E3%81%8B%E3%82%8F%E3%81%8B%E3%82%89%E3%81%AA%E3%81%84%E3%82%82%E3%81%AE%E3%81%A7%E3%81%99-%E3%81%8A%E3%81%9D%E3%82%89%E3%81%8FOTG%E7%94%A8%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%AB%E3%80%81kontron%E3%81%AFUSB%E3%83%96%E3%83%BC%E3%83%88%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AFUSB%20OTG%E3%82%92%E6%84%8F%E5%91%B3%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%81%E7%A7%81%E3%81%AF(SD%E3%82%AB%E3%83%BC%E3%83%89%E3%81%A8%E3%81%AF%E5%AF%BE%E7%85%A7%E7%9A%84%E3%81%AB)USB%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8B%E3%82%89%E3%81%AE%E8%B5%B7%E5%8B%95%E3%81%AE%E3%82%88%E3%81%86%E3%81%ABUSB%E3%83%96%E3%83%BC%E3%83%88%E3%82%92%E6%84%8F%E5%91%B3%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ELTIB%20%E3%83%87%E3%82%A3%E3%82%B9%E3%83%88%E3%83%AA%E3%83%93%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E6%AD%A3%E5%B8%B8%E3%81%AB%20USB%20%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%20u-boot%20%E6%A7%8B%E6%88%90%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82yocto(imx6sabresd%E7%94%A8)%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%97%E3%80%81%E7%94%BB%E5%83%8F%E3%82%92USB%E3%82%B9%E3%83%86%E3%82%A3%E3%83%83%E3%82%AF%E3%81%ABdd-%E9%80%81%E4%BF%A1%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81%E5%8D%98%E4%B8%80%E3%81%AEext2%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E8%A9%A6%E3%81%97%E3%80%81%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%80%81%2F%E3%81%ABuImage%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%A6%E3%81%8B%E3%82%89%E3%80%81grub-install%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%9D%E3%82%8C%E3%82%82%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%A8%E3%83%AA%E3%83%83%E3%82%AF%E3%83%BB%E3%83%8D%E3%83%AB%E3%82%BD%E3%83%B3%E3%81%AE%E6%8C%87%E7%A4%BA%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%80%81%E3%82%82%E3%81%86%E4%B8%80%E5%BA%A6%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1117393%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX%20Yocto%20Project%3A%20%E3%82%88%E3%81%8F%E3%81%82%E3%82%8B%E8%B3%AA%E5%95%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1117393%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%80%8Cu-boot%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E3%81%A9%E3%81%86%E3%81%97%E3%81%9F%E3%82%89%E3%81%84%E3%81%84%E3%81%AE%E3%81%8B%E3%82%8F%E3%81%8B%E3%82%89%E3%81%AA%E3%81%84%E3%80%8D%E3%81%A8%E3%81%AF%E3%81%A9%E3%81%86%E3%81%84%E3%81%86%E6%84%8F%E5%91%B3%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1117392%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX%20Yocto%20Project%3A%20%E3%82%88%E3%81%8F%E3%81%82%E3%82%8B%E8%B3%AA%E5%95%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1117392%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Dominic%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%9A%AE%E8%82%89%E3%81%AA%E3%81%93%E3%81%A8%E3%81%AB%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E8%B3%AA%E5%95%8F%E3%82%92%E8%A6%8B%E3%81%9F%E3%81%A8%E3%81%8D%E3%80%81%E7%A7%81%E3%81%AF%E3%81%A1%E3%82%87%E3%81%86%E3%81%A9%E5%88%A5%E3%81%AE%E9%A1%A7%E5%AE%A2%E3%81%AB%E3%83%A1%E3%83%A2%E3%82%92%E9%80%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3CBR%20%2F%3EKontron%E3%81%AEU-Boot%E3%83%93%E3%83%AB%E3%83%89%E3%81%ABUSB%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%81%AF%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%ABU-Boot%E3%81%AFUSB%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B8%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%A7%20USB%20%E7%B5%8C%E7%94%B1%E3%81%A7%E8%B5%B7%E5%8B%95%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%8C%E9%80%B2%E8%A1%8C%E4%B8%AD%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81USB%20%E3%81%AE%E8%B5%B7%E5%8B%95%E3%81%8C%E9%81%85%E3%81%8F%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EU-Boot%20%E3%81%AA%E3%81%AE%E3%81%A7%E3%80%81%E3%83%96%E3%83%BC%E3%83%88%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%81%AB%E3%81%AF%E7%B5%B1%E5%90%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%82%92%E6%89%8B%E4%BD%9C%E6%A5%AD%E3%81%A7%E8%A1%8C%E3%81%84%E3%81%9F%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%82%E3%81%AE%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EU-Boot%20%26gt%3B%20usb%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%88%20%3C%2FP%3E%3CP%3EU-Boot%20%26gt%3B%20setenv%20bootargs%20...rootwait%20root%3D%2Fdev%2Fsda1%20%3C%2FP%3E%3CP%3EU-Boot%20%26gt%3B%20ext2load%20usb%200%2010800000%20%2Fboot%2FuImage%20%3C%2FP%3E%3CP%3EU%E3%83%96%E3%83%BC%E3%83%88%26gt%3B%E3%83%96%E3%83%BC%E3%83%84%2010800000%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81%22usb%20start%22%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AF%20USB%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%99%E3%82%8B%20(%E3%81%9D%E3%81%97%E3%81%A6%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B8%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E8%AA%8D%E8%AD%98%E3%81%99%E3%82%8B)%20%E3%81%B9%E3%81%8D%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%20%22fatload%22%20%E3%81%BE%E3%81%9F%E3%81%AF%20%22ext2load%22%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AF%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%20RAM%20%E3%81%AB%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%82%80%E3%81%93%E3%81%A8%E3%82%92%E5%8F%AF%E8%83%BD%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AB%E3%80%81%E3%83%AB%E3%83%BC%E3%83%88%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8C%E3%81%A9%E3%81%93%E3%81%AB%E3%81%82%E3%82%8B%E3%81%8B%E3%82%92%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AB(%E3%80%8Cbootargs%E3%80%8D%E3%82%92%E4%BB%8B%E3%81%97%E3%81%A6)%E4%BC%9D%E3%81%88%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99(%E4%B8%8A%E8%A8%98%E3%81%AE%E4%BE%8B%E3%81%A7%E3%81%AF%E3%80%81%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E6%9C%80%E5%88%9D%E3%81%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%96%E3%81%AE%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B31%E3%82%92%E6%83%B3%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99)%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1117391%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX%20Yocto%20Project%3A%20%E3%82%88%E3%81%8F%E3%81%82%E3%82%8B%E8%B3%AA%E5%95%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1117391%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E3%82%B3%E3%83%94%E3%83%BC%26amp%3B%E3%83%9A%E3%83%BC%E3%82%B9%E3%83%88%E3%81%8C%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%A7%E3%80%81%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%AF%20404%20%E4%BB%A5%E5%A4%96%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1117390%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX%20Yocto%20Project%3A%20%E3%82%88%E3%81%8F%E3%81%82%E3%82%8B%E8%B3%AA%E5%95%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1117390%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%A7%81%E3%81%AF%E6%9C%80%E5%88%9D%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%A7kontron%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AE%E4%BD%95%E3%82%82%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%20-%20%E7%A7%81%E3%81%AF%E5%BD%BC%E3%82%89%E3%82%92%E3%83%95%E3%82%A9%E3%83%AD%E3%83%BC%E3%82%A2%E3%83%83%E3%83%97%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E2%20%E7%95%AA%E7%9B%AE%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%AF%20404%20%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%9C%E6%88%90%E3%81%97%E3%81%9F%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81u-boot%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%81%A9%E3%81%86%E3%81%99%E3%82%8B%E3%81%8B%E3%81%AF%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%89%E3%83%9F%E3%83%8B%E3%82%AF%E3%83%BB%E3%82%A2%E3%83%9E%E3%83%B3%3C%2FP%3E%3CP%3E%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E9%96%8B%E7%99%BA%E8%80%85%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ESensors%20%26amp%3B%20Software%20Inc.%3C%2FP%3E%3CP%3E1040%E3%82%B9%E3%83%86%E3%82%A4%E3%82%B7%E3%83%BC%E3%82%B3%E3%83%BC%E3%83%88%E3%80%81%E3%83%9F%E3%82%B7%E3%82%B5%E3%82%ACON%E3%80%82L4W%202X8%3C%2FP%3E%3CP%3E%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%82%A4%E3%83%A4%E3%83%AB%3A1-800-267-6013%E5%86%85%E7%B7%9A%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9C%B0%E4%B8%8B%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%83%B3%E3%82%B0%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1117389%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX%20Yocto%20Project%3A%20%E3%82%88%E3%81%8F%E3%81%82%E3%82%8B%E8%B3%AA%E5%95%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1117389%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Leonardo%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%B8%8A%E3%81%AB%E6%8A%95%E7%A8%BF%E3%81%97%E3%81%9F%E3%83%AA%E3%83%B3%E3%82%AF(DOC-9411)%E3%81%AF%E3%80%8C%E5%89%8A%E9%99%A4%E3%81%95%E3%82%8C%E3%81%9F%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%8D%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99...%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1117388%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX%20Yocto%20Project%3A%20%E3%82%88%E3%81%8F%E3%81%82%E3%82%8B%E8%B3%AA%E5%95%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1117388%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E1.FSL%E4%BB%A5%E5%A4%96%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%81%93%E3%81%AE%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%2F%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FFreescale%2Fmeta-fsl-arm-extra%2Ftree%2Fmaster%2Fconf%2Fmachine%22%20title%3D%22https%3A%2F%2Fgithub.com%2FFreescale%2Fmeta-fsl-arm-extra%2Ftree%2Fmaster%2Fconf%2Fmachine%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%83%BCmeta-fsl-arm-extra%2Fconf%2Fmachine%E3%82%92%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%BB%E3%83%9E%E3%82%B7%E3%83%B3%E3%81%A7%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%2Fmeta-fsl-arm-extra%20%C2%B7GitHub%E3%81%AE%3C%2FA%3E%3C%2FP%3E%3CP%3E2.%20USB%20OTG%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%81%A8%E3%81%84%E3%81%86%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%81%8B%3F%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-94117%22%20target%3D%22_blank%22%3Ei.MX%20USB%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%3C%2FA%3E%3C%2FP%3E%3CP%3E3.%20%E3%82%82%E3%81%A1%E3%82%8D%E3%82%93%E3%81%A7%E3%81%99%E3%80%82u-boot%E3%81%A7%E9%81%A9%E5%88%87%E3%81%AA%E5%A4%89%E6%9B%B4%E3%82%92%E5%8A%A0%E3%81%88%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%E3%80%82tmp%2Fdeploy%2Fimages%20%E3%81%AE%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1117387%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX%20Yocto%20Project%3A%20%E3%82%88%E3%81%8F%E3%81%82%E3%82%8B%E8%B3%AA%E5%95%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1117387%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%BE%E3%81%A0%E8%A7%A3%E6%B1%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3COL%3E%3CLI%3Ekontron%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E7%89%B9%E5%AE%9A%E3%81%AEyocto%E6%A7%8B%E6%88%90%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FLI%3E%3CLI%3Eyocto%E3%81%AFUSB%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FLI%3E%3CLI%3Eyocto%E3%81%AFnfs%E3%81%A7%E8%B5%B7%E5%8B%95%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FLI%3E%3C%2FOL%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎01-29-2013 04:13 PM
更新者:
