i.MX Yocto Project: What Can I Do if I Run Into a Compilation Error?
1. When reusing the build directory, sometimes compilation errors are seen; to overcome these, a fast solution is to clean the Share State Cache of the particular recipe/package
$ bitbake <name of the recipe> -c cleansstate
2. Re-run the recipe
3. Re-run the bitbake command you were running, before getting into trouble. For example:
$ bitbake fsl-image-gui
In case the problem persists, please send the log into the mailing list or check if this issue has been reported previously.
タグ(2)
コメント
Hello
I have bad luck and I run into a compilation error. The error comes at xserver compilation. How can I know the exact <name of the recipe> for that recipe?
Usually when there is an error, the message is in red and it contains the name of the recipe/package. Can you post your log? What image are you building?
Leo
Hello and thanks Leo
I think I can remember a cuestion about coloring test during installation process. I fear I have difficulty with some obscure letters and I answered 'No colors'. Do you think I can get back the cuestion?
Testing and looking deeper I find that the directory containing the tmp\log.do_compile* files seems to be the recipe name: xserver-xorg-2_1.11.2-r11, in this case. But I did the cleanstate option and not get solved the problem. So I also wrote to the mailing list with the error.
I can not find how to attach the log with the errors. These are the lines where the error comes:
arm-poky-linux-gnueabi-libtool: compile:  arm-poky-linux-gnueabi-gcc -march=armv7-a -mthumb-interwork -mfloat-abi=softfp -mfpu=neon -mtune=cortex-a9 --sysroot=/home/dgg/rootfs_buider/build/tmp/sysroots/imx6qsabrelite -std=gnu99 -DHAVE_CONFIG_H -I. -I../include -I../hw/xfree86/os-support -I../hw/xfree86/os-support/bus -I../hw/xfree86/common -I../hw/xfree86/dri -I../mi -I../hw/xfree86/dri2 -DHAVE_DIX_CONFIG_H -Wall -Wpointer-arith -Wmissing-declarations -Wformat=2 -Wstrict-prototypes -Wmissing-prototypes -Wnested-externs -Wbad-function-cast -Wold-style-definition -Wdeclaration-after-statement -Wunused -Wuninitialized -Wshadow -Wcast-qual -Wmissing-noreturn -Wmissing-format-attribute -Wredundant-decls -Werror=implicit -Werror=nonnull -Werror=init-self -Werror=main -Werror=missing-braces -Werror=sequence-point -Werror=return-type -Werror=trigraphs -Werror=array-bounds -Werror=write-strings -Werror=address -Werror=int-to-pointer-cast -Werror=pointer-to-int-cast -fno-strict-aliasing -D_BSD_SOURCE -DHAS_FCHOWN -DHAS_STICKY_DIR_BIT -I/home/dgg/rootfs_buider/build/tmp/sysroots/imx6qsabrelite/usr/include/pixman-1 -I/home/dgg/rootfs_buider/build/tmp/sysroots/imx6qsabrelite/usr/include/freetype2 -I../include -I../include -I../Xext -I../composite -I../damageext -I../xfixes -I../Xi -I../mi -I../miext/sync -I../miext/shadow -I../miext/damage -I../render -I../randr -I../fb -fvisibility=hidden -I/home/dgg/rootfs_buider/build/tmp/sysroots/imx6qsabrelite/usr/include/libdrm -I/home/dgg/rootfs_buider/build/tmp/sysroots/imx6qsabrelite/usr/include/libdrm -I/home/dgg/rootfs_buider/build/tmp/sysroots/imx6qsabrelite/usr/include/X11/dri -DGLX_USE_TLS -DPTHREADS -O2 -pipe -g -feliminate-unused-debug-types -c glxscreens.c  -fPIC -DPIC -o .libs/glxscreens.o
In file included from ../include/privates.h:145:0,
                 from ../include/pixmapstr.h:53,
                 from ../include/windowstr.h:52,
                 from glxscreens.c:37:
../include/dix.h:532:22: warning: redundant redeclaration of 'ffs' [-Wredundant-decls]
In file included from ../include/dixstruct.h:28:0,
                 from glxserver.h:42,
                 from glxdricommon.c:38:
                 from ../include/cursor.h:54,
                 from ../include/scrnintstr.h:54,
                 from glxdriswrast.c:42:
../include/dix.h:532:22: warning: redundant redeclaration of 'ffs' [-Wredundant-decls]In file included from ../include/privates.h:145:0,
                 from glxdri.c:40:
                 from glxcmds.c:38:
                 from glxdri2.c:39:
glxdricommon.c: In function 'createModeFromConfig':
glxdricommon.c:141:32: error: 'GLX_RGBA_BIT' undeclared (first use in this function)
glxdricommon.c:141:32: note: each undeclared identifier is reported only once for each function it appears in
glxdricommon.c:143:32: error: 'GLX_COLOR_INDEX_BIT' undeclared (first use in this function)
glxdricommon.c:147:33: error: 'GLX_NON_CONFORMANT_CONFIG' undeclared (first use in this function)
glxdricommon.c:149:33: error: 'GLX_SLOW_CONFIG' undeclared (first use in this function)
glxdricommon.c:151:33: error: 'GLX_NONE' undeclared (first use in this function)
glxdricommon.c:156:42: error: 'GLX_TEXTURE_1D_BIT_EXT' undeclared (first use in this function)
glxdricommon.c:158:42: error: 'GLX_TEXTURE_2D_BIT_EXT' undeclared (first use in this function)
glxdricommon.c:160:42: error: 'GLX_TEXTURE_RECTANGLE_BIT_EXT' undeclared (first use in this function)
Thanks again and best regards
if the '-c cleansstate xserver-xorg' did not help, I think the next step is to remove the whole tmp folder (yes, it hurts :smileyhappy:) . Regarding the colour question, somewhere on the setup this question is done, and I do not know who to change this setting.
Again, what image are you building? if this issue happening on dylan branches?
Hello Leonardo
Sorry. I forgot to answer your second question. danny is the branch we are compiling. We got a succesful compilation on a virtual machine but when we do, apparently, the same thing in a real linux, it failed.
Hello
I felt very sad about having to delete tmp directory. So I renamed it to tmp_no instead of deleting it. Then do the bitabke fsl-image-gui. The build process give us this warnings:
WARNING: The recipe is trying to install files into a shared area when those files already exist. Those files are:
   /home/dgg/rootfs_buider/build/tmp/sysroots/imx6qsabrelite/usr/include/GL/glx.h
   /home/dgg/rootfs_buider/build/tmp/sysroots/imx6qsabrelite/usr/include/GL/glext.h
   /home/dgg/rootfs_buider/build/tmp/sysroots/imx6qsabrelite/usr/include/GL/glu.h
   /home/dgg/rootfs_buider/build/tmp/sysroots/imx6qsabrelite/usr/include/GL/gl.h
   /home/dgg/rootfs_buider/build/tmp/sysroots/imx6qsabrelite/usr/include/GL/glxtokens.h
and end the buiild process correctly ... and soon :smileyshocked: .
After it, I understand that rename is not the same that delete. The process must be using yet the tmp_no directory and has been able to do something in the new directory. I am going to delete now the tmp_no directory and see what happens.
Hi Diego,
AFAIK, Danny branches are not updated anymore. In case you want the most update & stable branch, use Dylan branches (there must be a way to jump from branchs A to branches B using the repo command. In case there is no way, you need to 'repo -init -b dylan' again)
Leo
Thanks Leonardo
As a matter of fact, danny is not working on imx6 q sabre lite.  We write on another post saying that the compiled image has errors on start and they said to us that we must use dylan. We create a new directory and it will end compiling in a few miuntes ... I hope :smileyhappy:
08/13 dylan working. thanks
%3CLINGO-SUB%20id%3D%22lingo-sub-1106724%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX%20Yocto%20Project%3A%20%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106724%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E1.%3CA%20href%3D%22http%3A%2F%2Fwww.yoctoproject.org%2Fdocs%2F1.3%2Fdev-manual%2Fdev-manual.html%23build-directory%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E3%83%93%E3%83%AB%E3%83%89%3C%2FA%3E%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%82%92%E5%86%8D%E5%88%A9%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%82%89%E3%82%92%E5%85%8B%E6%9C%8D%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E8%BF%85%E9%80%9F%E3%81%AA%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%81%AF%E3%80%81%E7%89%B9%E5%AE%9A%E3%81%AE%E3%83%AC%E3%82%B7%E3%83%94%2F%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%3CA%20href%3D%22http%3A%2F%2Fwww.yoctoproject.org%2Fdocs%2Fcurrent%2Fpoky-ref-manual%2Fpoky-ref-manual.html%23shared-state-cache%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E3%81%AE%E5%85%B1%E6%9C%89%E7%8A%B6%E6%85%8B%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%3C%2FA%3E%E3%82%92%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%A2%E3%83%83%E3%83%97%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%24%20bitbake%3CNAME%20of%3D%22%22%20the%3D%22%22%20recipe%3D%22%22%3E%20-c%20cleansstate%3C%2FNAME%3E%3C%2FP%3E%0A%0A%0A%0A%0A%0A%0A%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E2.%E3%83%AC%E3%82%B7%E3%83%94%E3%82%92%E5%86%8D%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%24%20bitbake%20%3CNAME%20of%3D%22%22%20the%3D%22%22%20recipe%3D%22%22%3E%3C%2FNAME%3E%3C%2FP%3E%0A%0A%0A%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E3.%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E5%89%8D%E3%81%AB%E3%80%81%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%20%3CEM%3Ebitbake%3C%2FEM%3E%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%86%8D%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E4%BE%8B%E3%81%88%E3%81%B0%EF%BC%9A%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%24%20bitbake%20fsl-image-gui%3C%2FP%3E%0A%0A%0A%0A%0A%0A%0A%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%95%8F%E9%A1%8C%E3%81%8C%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Flists.yoctoproject.org%2Flistinfo%2Fmeta-freescale%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E3%83%AD%E3%82%B0%E3%82%92%E3%83%A1%E3%83%BC%E3%83%AA%E3%83%B3%E3%82%B0%E3%83%AA%E3%82%B9%E3%83%88%3C%2FA%3E%20%E3%81%AB%E9%80%81%E4%BF%A1%E3%81%99%E3%82%8B%E3%81%8B%E3%80%81%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E4%BB%A5%E5%89%8D%E3%81%AB%20%3CA%20href%3D%22https%3A%2F%2Fbugzilla.yoctoproject.org%2Fbuglist.cgi%3Fproduct%3DBSPs%26amp%3Bcomponent%3Dbsps-meta-fsl-arm%26amp%3Bresolution%3D---%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E5%A0%B1%E5%91%8A%3C%2FA%3E%20%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%8B%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1106724%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EYocto%20Project%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106732%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX%20Yocto%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%3A%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106732%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%83%AC%E3%82%AA%E3%83%8A%E3%83%AB%E3%83%89%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%AE%9F%E9%9A%9B%E3%81%AE%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%E3%83%80%E3%83%8B%E3%83%BC%E3%81%AFimx6%20q%20sabre%20lite%E3%81%AB%E3%81%AF%E5%8F%96%E3%82%8A%E7%B5%84%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E5%88%A5%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%A7%E3%80%81%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%95%E3%82%8C%E3%81%9F%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AE%E9%96%8B%E5%A7%8B%E6%99%82%E3%81%AB%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E3%83%87%E3%82%A3%E3%83%A9%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%A8%E8%A8%80%E3%82%8F%E3%82%8C%E3%81%9F%E3%81%A8%E6%9B%B8%E3%81%84%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E6%96%B0%E3%81%97%E3%81%84%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%95%B0%E3%83%9E%E3%82%A4%E3%83%AB%E3%81%A7%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%8C%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%99...%E7%A7%81%E3%81%AF%E9%A1%98%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CIMG%20id%3D%22smileyhappy%22%20class%3D%22emoticon%20emoticon-smileyhappy%22%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fi%2Fsmilies%2F16x16_smiley-happy.png%22%20alt%3D%22Smiley%20Happy%22%20title%3D%22Smiley%20Happy%22%20%2F%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%82%E3%81%86%E4%B8%80%E5%BA%A6%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%81%E3%81%9D%E3%81%97%E3%81%A6%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E08%2F13%20%E3%83%87%E3%82%A3%E3%83%A9%E3%83%B3%E3%81%8C%E5%83%8D%E3%81%84%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E6%84%9F%E8%AC%9D%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106731%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX%20Yocto%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%3A%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106731%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Diego%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EAFAIK%E3%80%81Danny%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81%E3%81%AF%E3%82%82%E3%81%86%E6%9B%B4%E6%96%B0%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E6%9C%80%E3%82%82%E5%A4%9A%E3%81%8F%E3%81%AE%E6%9B%B4%E6%96%B0%E3%81%A8%E5%AE%89%E5%AE%9A%E7%89%88%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AA%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81Dylan%20%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%20(repo%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81%20A%20%E3%81%8B%E3%82%89%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81%20B%20%E3%81%AB%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%97%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%E6%96%B9%E6%B3%95%E3%81%8C%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E5%86%8D%E5%BA%A6%20'repo%20-init%20-b%20dylan'%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99)%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ELeo%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106730%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX%20Yocto%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%3A%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106730%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Etmp%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%AA%E3%81%91%E3%82%8C%E3%81%B0%E3%81%AA%E3%82%89%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%81%AB%E3%81%A8%E3%81%A6%E3%82%82%E6%82%B2%E3%81%97%E3%81%84%E6%80%9D%E3%81%84%E3%82%92%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%9D%E3%81%93%E3%81%A7%E3%80%81%E5%89%8A%E9%99%A4%E3%81%99%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81tmp_no%E3%81%AB%E5%90%8D%E5%89%8D%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%AC%A1%E3%81%AB%E3%80%81bitabke%20fsl-image-gui%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%93%E3%83%AB%E3%83%89%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%81%A7%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E8%AD%A6%E5%91%8A%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%AD%A6%E5%91%8A%3A%20%E3%83%AC%E3%82%B7%E3%83%94%E3%81%AF%E3%80%81%E5%85%B1%E6%9C%89%E9%A0%98%E5%9F%9F%E3%81%AB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%9D%E3%82%8C%E3%82%89%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E3%81%99%E3%81%A7%E3%81%AB%E5%AD%98%E5%9C%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%2Fhome%2Fdgg%2Frootfs_buider%2Fbuild%2Ftmp%2Fsysroots%2Fimx6qsabrelite%2Fusr%2Finclude%2FGL%2Fglx.h%3C%2FP%3E%3CP%3E%2Fhome%2Fdgg%2Frootfs_buider%2Fbuild%2Ftmp%2Fsysroots%2Fimx6qsabrelite%2Fusr%2Finclude%2FGL%2Fglext.h%3C%2FP%3E%3CP%3E%2Fhome%2Fdgg%2Frootfs_buider%2Fbuild%2Ftmp%2Fsysroots%2Fimx6qsabrelite%2Fusr%2Finclude%2FGL%2Fglu.h%3C%2FP%3E%3CP%3E%2Fhome%2Fdgg%2Frootfs_buider%2Fbuild%2Ftmp%2Fsysroots%2Fimx6qsabrelite%2Fusr%2Finclude%2FGL%2Fgl.h%3C%2FP%3E%3CP%3E%E8%AD%A6%E5%91%8A%3A%20%E3%83%AC%E3%82%B7%E3%83%94%E3%81%AF%E3%80%81%E5%85%B1%E6%9C%89%E9%A0%98%E5%9F%9F%E3%81%AB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%9D%E3%82%8C%E3%82%89%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E3%81%99%E3%81%A7%E3%81%AB%E5%AD%98%E5%9C%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%2Fhome%2Fdgg%2Frootfs_buider%2Fbuild%2Ftmp%2Fsysroots%2Fimx6qsabrelite%2Fusr%2Finclude%2FGL%2Fglxtokens.h%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E3%83%93%E3%83%AB%E3%83%89%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%82%92%E6%AD%A3%E3%81%97%E3%81%8F%E7%B5%82%E4%BA%86%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84...%E3%81%9D%E3%81%97%E3%81%A6%E3%81%99%E3%81%90%E3%81%AB%3Asmileyshocked%3A%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81%E5%90%8D%E5%89%8D%E3%81%AE%E5%A4%89%E6%9B%B4%E3%81%AF%E5%89%8A%E9%99%A4%E3%81%A8%E5%90%8C%E3%81%98%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E7%90%86%E8%A7%A3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%81%AF%E3%80%81%E3%81%BE%E3%81%A0tmp_no%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%A7%E4%BD%95%E3%81%8B%E3%82%92%E8%A1%8C%E3%81%86%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%9F%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%93%E3%81%A7tmp_no%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%A6%E3%80%81%E3%81%A9%E3%81%86%E3%81%AA%E3%82%8B%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106729%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX%20Yocto%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%3A%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106729%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%83%AC%E3%82%AA%E3%83%8A%E3%83%AB%E3%83%89%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%99%E3%81%BF%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE2%E7%95%AA%E7%9B%AE%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%AB%E7%AD%94%E3%81%88%E3%82%8B%E3%81%AE%E3%82%92%E5%BF%98%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82Danny%20%E3%81%AF%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%8C%E3%81%BE%E3%81%A8%E3%82%81%E3%81%A6%E3%81%84%E3%82%8B%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81%E3%81%A7%E3%81%99%E3%80%82%E4%BB%AE%E6%83%B3%E3%83%9E%E3%82%B7%E3%83%B3%E3%81%A7%E6%88%90%E5%8A%9F%E3%81%97%E3%81%9F%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E5%AE%9F%E9%9A%9B%E3%81%AELinux%E3%81%A7%E5%90%8C%E3%81%98%E3%81%93%E3%81%A8%E3%82%92%E8%A1%8C%E3%81%86%E3%81%A8%E3%80%81%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106728%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX%20Yocto%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%3A%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106728%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E'-c%20cleansstate%20xserver-xorg'%E3%81%8C%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%9F%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%AFtmp%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E5%85%A8%E4%BD%93%E3%82%92%E5%89%8A%E9%99%A4%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A0%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99(%E3%81%AF%E3%81%84%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AF%E7%97%9B%E3%81%84%E3%81%A7%E3%81%99%3CIMG%20id%3D%22smileyhappy%22%20class%3D%22emoticon%20emoticon-smileyhappy%22%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fi%2Fsmilies%2F16x16_smiley-happy.png%22%20alt%3D%22Smiley%20Happy%22%20title%3D%22Smiley%20Happy%22%20%2F%3E)%E3%80%82%E8%89%B2%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%AB%E9%96%A2%E3%81%97%E3%81%A6%E3%81%AF%E3%80%81%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%AE%E3%81%A9%E3%81%93%E3%81%8B%E3%81%A7%E3%81%93%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%8C%E8%A1%8C%E3%82%8F%E3%82%8C%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%81%93%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E8%AA%B0%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E3%81%8B%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%B9%B0%E3%82%8A%E8%BF%94%E3%81%97%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E3%83%87%E3%82%A3%E3%83%A9%E3%83%B3%E6%94%AF%E5%BA%97%E3%81%A7%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106727%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX%20Yocto%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%3A%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106727%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%83%AC%E3%82%AA%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%A8%AD%E7%BD%AE%E4%BD%9C%E6%A5%AD%E4%B8%AD%E3%81%AE%E7%9D%80%E8%89%B2%E3%83%86%E3%82%B9%E3%83%88%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AE%E8%A9%B1%E3%82%92%E8%A6%9A%E3%81%88%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AF%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E3%81%82%E3%81%84%E3%81%BE%E3%81%84%E3%81%AA%E6%96%87%E5%AD%97%E3%81%8C%E8%8B%A6%E6%89%8B%E3%81%AA%E3%81%AE%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%8B%E3%81%A8%E5%BF%83%E9%85%8D%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%80%8C%E8%89%B2%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%8D%E3%81%A8%E7%AD%94%E3%81%88%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E7%A7%81%E3%81%8C%E3%82%AD%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E5%8F%96%E3%82%8A%E6%88%BB%E3%81%99%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%A6%E6%B7%B1%E3%81%8F%E8%A6%8B%E3%82%8B%E3%81%A8%E3%80%81tmp%5Clog.do_compile*%E3%82%92%E5%90%AB%E3%82%80%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%81%93%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E3%83%AC%E3%82%B7%E3%83%94%E5%90%8D%E3%81%AE%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%3A%20xserver-xorg-2_1.11.2-r11%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E7%A7%81%E3%81%AFcleanstate%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%AF%E8%A7%A3%E6%B1%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E3%81%A0%E3%81%8B%E3%82%89%E3%80%81%E7%A7%81%E3%82%82%E3%83%A1%E3%83%BC%E3%83%AA%E3%83%B3%E3%82%B0%E3%83%AA%E3%82%B9%E3%83%88%E3%81%AB%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E6%9B%B8%E3%81%84%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AE%E3%81%82%E3%82%8B%E3%83%AD%E3%82%B0%E3%82%92%E6%B7%BB%E4%BB%98%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E8%A1%8C%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Earm-poky-linux-gnueabi-libtool%3A%20%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%3A%20arm-poky-linux-gnueabi-gcc%20-march%3Darmv7-a%20-mthumb-interwork%20-mfloat-abi%3Dsoftfp%20-mfpu%3Dneon%20-mtune%3Dcortex-a9%20--sysroot%3D%2Fhome%2Fdgg%2Frootfs_buider%2Fbuild%2Ftmp%2Fsysroots%2Fimx6qsabrelite%20-std%3Dgnu99%20-DHAVE_CONFIG_H%20-I.-%E7%A7%81%E3%80%82%E3%80%82%2Finclude%20-I..%2Fhw%2Fxfree86%2Fos-support%20-I..%2Fhw%2Fxfree86%2Fos-support%2Fbus%20-I..%2Fhw%2Fxfree86%2Fcommon%20-I..%2Fhw%2Fxfree86%2Fdri%20-I..%2Fmi%20-I..%2Fhw%2Fxfree86%2Fdri2%20-DHAVE_DIX_CONFIG_H%20-Wall%20-Wpointer-arith%20-Wmissing-declarations%20-Wformat%3D2%20-Wstrict-prototypes%20-Wmissing-prototypes%20-Wnested-externs%20-Wbad-function-cast%20-would-style-definition%20-Wdeclaration-after-statement%20-Wunused%20-Wuninitialized%20-Wshadow%20-Wcast-qual%20-Wmissing-noreturn%20-Wmissing-format-attribute%20-Wredundant-decls%20-Werror%3Dimplicit%20-Werror%3Dnonnull%20-Werror%3Dinit-self%20-Werror%3Dmain%20-Werror%3Dmissing-braces%20-Werror%3Dsequence-point%20-Werror%3Dreturn-type%20-Werror%3Dtrigraphs%20-Werror%3D%E9%85%8D%E5%88%97%E5%A2%83%E7%95%8C%20-Werror%3D%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E6%96%87%E5%AD%97%E5%88%97%20-Werror%3D%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%20-Werror%3Dint-to-pointer-cast%20-Werror%3Dint-to-pointer%20-cast%20-fno-strict-aliasing%20-D_BSD_SOURCE%20-DHAS_FCHOWN%20-DHAS_STICKY_DIR_BIT%20-I%2Fhome%2Fdgg%2Frootfs_buider%2Fbuild%2Ftmp%2Fsysroots%2Fimx6qsabrelite%2Fusr%2Finclude%2Fpixman-1%20-I%2Fhome%2Fdgg%2Frootfs_buider%2Fbuild%2Ftmp%2Fsysroots%2Fimx6qsabrelite%2Fusr%2Finclude%2Ffreetype2%20-I..%2Finclude%20-I..%2Finclude%20-I..%2Fxext%20-I..%2Fcomposite%20-I..%2Fdamageext%20-I..%2Fxfixes%20-I..%2Fxi%20-i..%2Fmi%20-I..%2Fmiext%2Fsync%20-I..%2Fmiext%2Fshadow%20-I..%2Fmiext%2Fdamage%20-I..%2Frender%20-I..%2Frandr%20-I..%2Ffb%20-fvisibility%3Dhidden%20-I%2Fhome%2Fdgg%2Frootfs_buider%2Fbuild%2Ftmp%2Fsysroots%2Fimx6qsabrelite%2Fusr%2Finclude%2Flibdrm%20-I%2Fhome%2Fdgg%2Frootfs_buider%2Fbuild%2Ftmp%2Fsysroots%2Fimx6qsabrelite%2Fusr%2Finclude%2Flibdrm%20-I%2Fhome%2Fdgg%2Frootfs_buider%2Fbuild%2Ftmp%2Fsysroots%2Fimx6qsabrelite%2Fusr%2Finclude%2FX11%2Fdri%20-DGLX_USE_TLS%20-DPTHREADS%20-O2%20-pipe%20-g%20-feliminate-unused-debug-types%20-c%20glxscreens.c-fPIC%20-DPIC%20-o%20.libs%2Fglxscreens.o%3C%2FP%3E%3CP%3E%E3%81%8B%E3%82%89%E3%82%A4%E3%83%B3%E3%82%AF%E3%83%AB%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%9F%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E3%80%82%2Finclude%2Fprivates.h%3A145%3A0%E3%80%81%3C%2FP%3E%3CP%3E%E5%B7%AE%E5%87%BA%E4%BA%BA%E3%80%82%E3%80%82%2Finclude%2Fpixmapstr.h%3A53%E3%80%81%3C%2FP%3E%3CP%3E%E5%B7%AE%E5%87%BA%E4%BA%BA%E3%80%82%E3%80%82%2Finclude%2Fwindowstr.h%3A52%E3%80%81%3C%2FP%3E%3CP%3Eglxscreens.c%3A37%20%E3%82%88%E3%82%8A%3A%3C%2FP%3E%3CP%3E..%2Finclude%2Fdix.h%3A532%3A22%3A%20%E8%AD%A6%E5%91%8A%3A%20'ffs'%20%E3%81%AE%E5%86%97%E9%95%B7%E3%81%AA%E5%86%8D%E5%AE%A3%E8%A8%80%20%5B-Wredundant-decls%5D%3C%2FP%3E%3CP%3E%E3%81%8B%E3%82%89%E3%82%A4%E3%83%B3%E3%82%AF%E3%83%AB%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%9F%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E3%80%82%2Finclude%2Fdixstruct.h%3A28%3A0%E3%80%81%3C%2FP%3E%3CP%3Eglxserver.h%3A42%20%E3%82%88%E3%82%8A%E3%80%81%3C%2FP%3E%3CP%3Eglxdricommon.c%3A38%20%E3%82%88%E3%82%8A%3A%3C%2FP%3E%3CP%3E..%2Finclude%2Fdix.h%3A532%3A22%3A%20%E8%AD%A6%E5%91%8A%3A%20'ffs'%20%E3%81%AE%E5%86%97%E9%95%B7%E3%81%AA%E5%86%8D%E5%AE%A3%E8%A8%80%20%5B-Wredundant-decls%5D%3C%2FP%3E%3CP%3E%E3%81%8B%E3%82%89%E3%82%A4%E3%83%B3%E3%82%AF%E3%83%AB%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%9F%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E3%80%82%2Finclude%2Fprivates.h%3A145%3A0%E3%80%81%3C%2FP%3E%3CP%3E%E5%B7%AE%E5%87%BA%E4%BA%BA%E3%80%82%E3%80%82%2Finclude%2Fcursor.h%3A54%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E5%B7%AE%E5%87%BA%E4%BA%BA%E3%80%82%E3%80%82%2Finclude%2Fscrnintstr.h%3A54%E3%80%81%3C%2FP%3E%3CP%3Eglxdriswrast.c%3A42%20%E3%82%88%E3%82%8A%3A%3C%2FP%3E%3CP%3E..%2Finclude%2Fdix.h%3A532%3A22%3A%20%E8%AD%A6%E5%91%8A%3A%20..%2Finclude%2Fprivates.h%3A145%3A0%E3%80%81%3C%2FP%3E%3CP%3E%E5%B7%AE%E5%87%BA%E4%BA%BA%E3%80%82%E3%80%82%2Finclude%2Fpixmapstr.h%3A53%E3%80%81%3C%2FP%3E%3CP%3E%E5%B7%AE%E5%87%BA%E4%BA%BA%E3%80%82%E3%80%82%2Finclude%2Fwindowstr.h%3A52%E3%80%81%3C%2FP%3E%3CP%3Eglxdri.c%3A40%20%E3%82%88%E3%82%8A%3A%3C%2FP%3E%3CP%3E..%2Finclude%2Fdix.h%3A532%3A22%3A%20%E8%AD%A6%E5%91%8A%3A%20'ffs'%20%E3%81%AE%E5%86%97%E9%95%B7%E3%81%AA%E5%86%8D%E5%AE%A3%E8%A8%80%20%5B-Wredundant-decls%5D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%8B%E3%82%89%E3%82%A4%E3%83%B3%E3%82%AF%E3%83%AB%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%9F%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E3%80%82%2Finclude%2Fdixstruct.h%3A28%3A0%E3%80%81%3C%2FP%3E%3CP%3Eglxserver.h%3A42%20%E3%82%88%E3%82%8A%E3%80%81%3C%2FP%3E%3CP%3Eglxcmds.c%3A38%20%E3%82%88%E3%82%8A%3A%3C%2FP%3E%3CP%3E..%2Finclude%2Fdix.h%3A532%3A22%3A%20%E8%AD%A6%E5%91%8A%3A%20'ffs'%20%E3%81%AE%E5%86%97%E9%95%B7%E3%81%AA%E5%86%8D%E5%AE%A3%E8%A8%80%20%5B-Wredundant-decls%5D%3C%2FP%3E%3CP%3E%E3%81%8B%E3%82%89%E3%82%A4%E3%83%B3%E3%82%AF%E3%83%AB%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%9F%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E3%80%82%2Finclude%2Fprivates.h%3A145%3A0%E3%80%81%3C%2FP%3E%3CP%3E%E5%B7%AE%E5%87%BA%E4%BA%BA%E3%80%82%E3%80%82%2Finclude%2Fpixmapstr.h%3A53%E3%80%81%3C%2FP%3E%3CP%3E%E5%B7%AE%E5%87%BA%E4%BA%BA%E3%80%82%E3%80%82%2Finclude%2Fwindowstr.h%3A52%E3%80%81%3C%2FP%3E%3CP%3Eglxdri2.c%3A39%20%E3%82%88%E3%82%8A%3A%3C%2FP%3E%3CP%3E..%2Finclude%2Fdix.h%3A532%3A22%3A%20%E8%AD%A6%E5%91%8A%3A%20'ffs'%20%E3%81%AE%E5%86%97%E9%95%B7%E3%81%AA%E5%86%8D%E5%AE%A3%E8%A8%80%20%5B-Wredundant-decls%5D%3C%2FP%3E%3CP%3Eglxdricommon.c%3A%20In%20function%20'createModeFromConfig'%3A%3C%2FP%3E%3CP%3Eglxdricommon.c%3A141%3A32%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%20'GLX_RGBA_BIT'%20%E3%81%8C%E5%AE%A3%E8%A8%80%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%20(%E3%81%93%E3%81%AE%E9%96%A2%E6%95%B0%E3%81%A7%E6%9C%80%E5%88%9D%E3%81%AB%E4%BD%BF%E7%94%A8)%3C%2FP%3E%3CP%3Eglxdricommon.c%3A141%3A32%3A%E6%B3%A8%3A%20%E5%AE%A3%E8%A8%80%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E5%90%84%E8%AD%98%E5%88%A5%E5%AD%90%E3%81%AF%E3%80%81%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%82%8B%E9%96%A2%E6%95%B0%E3%81%94%E3%81%A8%E3%81%AB%201%20%E5%9B%9E%E3%81%A0%E3%81%91%E5%A0%B1%E5%91%8A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Eglxdricommon.c%3A143%3A32%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%20'GLX_COLOR_INDEX_BIT'%20%E3%81%8C%E5%AE%A3%E8%A8%80%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%20(%E3%81%93%E3%81%AE%E9%96%A2%E6%95%B0%E3%81%A7%E6%9C%80%E5%88%9D%E3%81%AB%E4%BD%BF%E7%94%A8)%3C%2FP%3E%3CP%3Eglxdricommon.c%3A147%3A33%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%20'GLX_NON_CONFORMANT_CONFIG'%20%E3%81%8C%E5%AE%A3%E8%A8%80%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%20(%E3%81%93%E3%81%AE%E9%96%A2%E6%95%B0%E3%81%A7%E6%9C%80%E5%88%9D%E3%81%AB%E4%BD%BF%E7%94%A8)%3C%2FP%3E%3CP%3Eglxdricommon.c%3A149%3A33%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%20'GLX_SLOW_CONFIG'%20%E3%81%8C%E5%AE%A3%E8%A8%80%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%20(%E3%81%93%E3%81%AE%E9%96%A2%E6%95%B0%E3%81%A7%E6%9C%80%E5%88%9D%E3%81%AB%E4%BD%BF%E7%94%A8)%3C%2FP%3E%3CP%3Eglxdricommon.c%3A151%3A33%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%20'GLX_NONE'%20%E3%81%8C%E5%AE%A3%E8%A8%80%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%20(%E3%81%93%E3%81%AE%E9%96%A2%E6%95%B0%E3%81%A7%E6%9C%80%E5%88%9D%E3%81%AB%E4%BD%BF%E7%94%A8)%3C%2FP%3E%3CP%3Eglxdricommon.c%3A156%3A42%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%20'GLX_TEXTURE_1D_BIT_EXT'%20%E6%9C%AA%E5%AE%A3%E8%A8%80%20(%E3%81%93%E3%81%AE%E9%96%A2%E6%95%B0%E3%81%A7%E6%9C%80%E5%88%9D%E3%81%AB%E4%BD%BF%E7%94%A8)%3C%2FP%3E%3CP%3Eglxdricommon.c%3A158%3A42%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%20'GLX_TEXTURE_2D_BIT_EXT'%20%E3%81%8C%E5%AE%A3%E8%A8%80%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%20(%E3%81%93%E3%81%AE%E9%96%A2%E6%95%B0%E3%81%A7%E6%9C%80%E5%88%9D%E3%81%AB%E4%BD%BF%E7%94%A8)%3C%2FP%3E%3CP%3Eglxdricommon.c%3A160%3A42%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%20'GLX_TEXTURE_RECTANGLE_BIT_EXT'%20%E3%81%8C%E5%AE%A3%E8%A8%80%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%20(%E3%81%93%E3%81%AE%E9%96%A2%E6%95%B0%E3%81%A7%E6%9C%80%E5%88%9D%E3%81%AB%E4%BD%BF%E7%94%A8)%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%82%E3%81%86%E4%B8%80%E5%BA%A6%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%81%E3%81%9D%E3%81%97%E3%81%A6%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106726%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX%20Yocto%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%3A%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106726%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E9%80%9A%E5%B8%B8%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AF%E8%B5%A4%E3%81%A7%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%80%81%E3%83%AC%E3%82%B7%E3%83%94%2F%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%AE%E5%90%8D%E5%89%8D%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%AD%E3%82%B0%E3%82%92%E6%8A%95%E7%A8%BF%E3%81%97%E3%81%A6%E3%82%82%E3%82%89%E3%81%88%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ELeo%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106725%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX%20Yocto%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%3A%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106725%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%81%8B%E3%81%8C%E6%82%AA%E3%81%8F%E3%80%81%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AB%E9%81%AD%E9%81%87%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AF%E3%80%81xserver%20%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E6%99%82%E3%81%AB%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CNAME%20of%3D%22%22%20the%3D%22%22%20recipe%3D%22%22%3E%E3%81%9D%E3%81%AE%E3%83%AC%E3%82%B7%E3%83%94%E3%81%AE%E6%AD%A3%E7%A2%BA%E3%81%AA%20%E3%82%92%E7%9F%A5%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FNAME%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%20%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎02-08-2013 09:47 AM
更新者:
