i.MX Yocto Project: How can I compile the kernel manually?
1. To setup the Yocto environment, from the BASE folder run
fsl-community-bsp $ . setup-environment build
2. Build the toolchain
build $ bitbake meta-toolchain
# Other toolchains:
# Qt Embedded toolchain build: bitbake meta-toolchain-qte
# Qt X11 toolchain build: bitbake meta-toolchain-qt
3. Install it on your PC
build $ sudo sh \
  tmp/deploy/sdk/poky-eglibc-x86_64-arm-toolchain-<version>.sh
4. Setup the toolchain environment
build $ source \
  /opt/poky/<version>/environment-setup-armv7a-vfp-neon-poky-linux-gnueabi
5. Get the Linux Kernel's source code.
$ git clone git://git.freescale.com/imx/linux-2.6-imx.git linux-imx
$ cd linux-imx
6. Create a local branch
linux-imx $ BRANCH=imx_3.0.35_4.0.0 # Change to any branch you want,
  # Use 'git branch -a' to list all
linux-imx $ git checkout -b ${BRANCH} origin/${BRANCH}
7. Export ARCH and CROSS_COMPILE
linux-imx $ export ARCH=arm
linux-imx $ export CROSS_COMPILE=arm-poky-linux-gnueabi-
linux-imx $ unset LDFLAGS
8. Choose configuration and compile
linux-imx $ make imx6_defconfig
linux-imx $ make uImage
9. To Test your changes, copy the `uImage` into your SD Card
linux-imx $ sudo cp arch/arm/boot/uImage /media/boot
10. If case you want your changes to be reflected on your Yocto Framework, create the patches following the document i.MX Yocto Project: How can I patch the kernel?
ラベル(2)
コメント
For 3.10.17 Kernel above steps remains same?
make imx6_defconfig gives error
Can't find default configuration "arch/arm/configs/imx6_defconfig"!
You are right saurabh206, the defconfig is indeed different. It is imx_v7_defconfig. You can check all possibles configs either on the folder you mentioned or with 'make help':
$ make help | grep imx
  imx6_ssd_lite_defconfig  - Build for imx6_ssd_lite
  imx6_ssd_net_lite_defconfig - Build for imx6_ssd_net_lite
  imx_v4_v5_defconfig      - Build for imx_v4_v5
  imx_v6_v7_defconfig      - Build for imx_v6_v7
  imx_v7_defconfig         - Build for imx_v7
  imx_v7_mfg_defconfig     - Build for imx_v7_mfg
Hi, I have imx6q sabresd board, compile & run imx yocto(bitbake fsl-image-gui) without any problem. Now i tried kernel branch imx_3.0.35_4.1.0 as shown above step 5 onwards, compile no issue, however, when run, I can't see any gui on the lcd, I already enable devtmpfs.
Please don't base new products in 3.0.35 kernel as the Freescale GA is now the 3.10.17-1.0.1 one. Regarding building the kernel, my advice goes to use the toolchain generated for this so your development process is highly boosted.
You may want to also look at: Embedded Linux Development with Yocto Project book released | Freescale Community
I follow the steps above and compile kernel 3.10.17-1.0.1, and got this error:
  CC  drivers/mxc/gpu-viv/hal/os/linux/kernel/gc_hal_kernel_device.o
drivers/mxc/gpu-viv/hal/os/linux/kernel/gc_hal_kernel_device.c:29:27: fatal error: mach/hardware.h: No such file or directory
#include <mach/hardware.h>
compilation terminated.
make[3]: *** [drivers/mxc/gpu-viv/hal/os/linux/kernel/gc_hal_kernel_device.o] Error 1
I ran also into this problem. Please follow Eric's comment
http://boundarydevices.com/mx6-linux-kernel-3-10-17-beta/#comment-124454
Hi Otavio,
I want to link to the link you mentioned as below for learning how to do kernel related tasks. But it can't be access. May you redirect me?
Unauthorized
Access to this place or content is restricted. If you think this is a mistake, please contact your administrator or the person who directed you here.
Sure, you can link to our blog post about it:
O.S. Systems
Hi Leo,
Which one is suit for i.mx53 I tried with imx_v7_defconfig but kernel panic on my i.mx53 quick start board.
Thanks!
Wenming
The kernel panic may have several causes; without further information it is hard to guess.
In any case you should open a new topic specific for this as this is not related to the original topic context.
%3CLINGO-SUB%20id%3D%22lingo-sub-1101765%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX%20Yocto%20Project%3A%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E6%89%8B%E5%8B%95%E3%81%A7%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%81%84%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1101765%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E1.%20Yocto%E7%92%B0%E5%A2%83%E3%82%92%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81BASE%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%8B%E3%82%89%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3EFSL%20-%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3-BSP%20%24%20%E3%80%82setup-environment%20%E3%83%93%E3%83%AB%E3%83%89%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E2.%20%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%E3%83%93%E3%83%AB%E3%83%89%20%24%20bitbake%20%E3%83%A1%E3%82%BF%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%3C%2FP%3E%0A%3CP%3E%23%20%E3%81%9D%E3%81%AE%E4%BB%96%E3%81%AE%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%3A%3C%2FP%3E%0A%3CP%3E%23%20Qt%20%E7%B5%84%E3%81%BF%E8%BE%BC%E3%81%BF%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%20%E3%83%93%E3%83%AB%E3%83%89%3A%20bitbake%20meta-toolchain-qte%3C%2FP%3E%0A%3CP%3E%23%20Qt%20X11%20%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%83%93%E3%83%AB%E3%83%89%3A%20bitbake%20meta-toolchain-qt%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E3.PC%E3%81%AB%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%E3%83%93%E3%83%AB%E3%83%89%24%20sudo%20sh%20%5C%3C%2FP%3E%0A%3CP%3Etmp%2Fdeploy%2Fsdk%2Fpoky-eglibc-x86_64-arm-toolchain-.sh%3CVERSION%3E%3C%2FVERSION%3E%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E4.%20%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E7%92%B0%E5%A2%83%E3%81%AE%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%E3%83%93%E3%83%AB%E3%83%89%20%24%20%E3%82%BD%E3%83%BC%E3%82%B9%20%5C%3C%2FP%3E%0A%3CP%3E%2Fopt%2Fpoky%2F%3CVERSION%3E%20%2Fenvironment-setup-armv7a-vfp-neon-poky-linux-gnueabi%3C%2FVERSION%3E%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%3CP%3E5.%20Linux%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%24%20git%20clone%20git%3A%2F%2Fgit.freescale.com%2Fimx%2Flinux-2.6-imx.git%20linux-imx%3C%2FP%3E%0A%3CP%3E%24%20cd%20linux-imx%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E6.%20%E3%83%AD%E3%83%BC%E3%82%AB%E3%83%AB%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3Elinux-imx%20%24%20BRANCH%3Dimx_3.0.35_4.0.0%20%23%20%E4%BB%BB%E6%84%8F%E3%81%AE%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%80%81%3C%2FP%3E%0A%3CP%3E%23%20'git%20branch%20-a'%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%99%E3%81%B9%E3%81%A6%E3%82%92%E4%B8%80%E8%A6%A7%E8%A1%A8%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%0A%3CP%3Elinux-imx%20%24%20git%20checkout%20-b%20%24%7BBRANCH%7D%20origin%2F%24%7BBRANCH%7D%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E7.%20ARCH%E3%81%A8CROSS_COMPILE%E3%81%AE%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3Elinux-imx%20%24%20export%20ARCH%3Darm%20%3C%2FP%3E%0A%3CP%3Elinux-imx%20%24%20export%20CROSS_COMPILE%3Darm-poky-linux-gnueabi-%3C%2FP%3E%0A%3CP%3Elinux-imx%20%24%20LDFLAGS%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E8%A7%A3%E9%99%A4%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E8.%20%E6%A7%8B%E6%88%90%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%A6%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3Elinux-imx%20%24%20make%20imx6_defconfig%26nbsp%3B%20%3C%2FP%3E%0A%3CP%3Elinux-imx%20%24%20make%20uImage%20%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E9.%20%E5%A4%89%E6%9B%B4%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%80%8CuImage%E3%80%8D%E3%82%92SD%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3Elinux-imx%20%24%20sudo%20cp%20arch%2Farm%2Fboot%2FuImage%20%2Fmedia%2Fboot%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E10.%E5%A4%89%E6%9B%B4%E3%82%92Yocto%20Framework%E3%81%AB%E5%8F%8D%E6%98%A0%E3%81%95%E3%81%9B%E3%81%9F%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-95252%22%20target%3D%22_blank%22%3EYocto%20Project%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3A%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%20i.MX%20%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E9%81%A9%E7%94%A8%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1101765%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EYocto%20Project%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1101775%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX%20Yocto%20Project%3A%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E6%89%8B%E5%8B%95%E3%81%A7%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%81%84%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1101775%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%91%E3%83%8B%E3%83%83%E3%82%AF%E3%81%AB%E3%81%AF%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E5%8E%9F%E5%9B%A0%E3%81%8C%E8%80%83%E3%81%88%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%82%8C%E4%BB%A5%E4%B8%8A%E3%81%AE%E6%83%85%E5%A0%B1%E3%81%8C%E3%81%AA%E3%81%91%E3%82%8C%E3%81%B0%E3%80%81%E6%8E%A8%E6%B8%AC%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AF%E9%9B%A3%E3%81%97%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%84%E3%81%9A%E3%82%8C%E3%81%AB%E3%81%9B%E3%82%88%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E5%85%83%E3%81%AE%E3%83%88%E3%83%94%E3%83%83%E3%82%AF%E3%82%B3%E3%83%B3%E3%83%86%E3%82%AD%E3%82%B9%E3%83%88%E3%81%AB%E9%96%A2%E9%80%A3%E3%81%97%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E3%81%93%E3%82%8C%E3%81%AB%E5%9B%BA%E6%9C%89%E3%81%AE%E6%96%B0%E3%81%97%E3%81%84%E3%83%88%E3%83%94%E3%83%83%E3%82%AF%E3%82%92%E9%96%8B%E3%81%8F%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1101774%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX%20Yocto%20Project%3A%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E6%89%8B%E5%8B%95%E3%81%A7%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%81%84%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1101774%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Leo%2C%3C%2FP%3E%3CP%3Ei.mx53%E3%81%AB%E9%81%A9%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%AF%E3%81%A9%E3%82%8C%E3%81%A7%E3%81%99%E3%81%8B%E7%A7%81%E3%81%AFimx_v7_defconfig%E3%81%A7%E8%A9%A6%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81i.mx53%E3%82%AF%E3%82%A4%E3%83%83%E3%82%AF%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%88%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%91%E3%83%8B%E3%83%83%E3%82%AF%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%3C%2FP%3E%3CP%3EWenming%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1101773%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX%20Yocto%20Project%3A%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E6%89%8B%E5%8B%95%E3%81%A7%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%81%84%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1101773%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%82%82%E3%81%A1%E3%82%8D%E3%82%93%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AE%E3%83%96%E3%83%AD%E3%82%B0%E8%A8%98%E4%BA%8B%E3%81%AB%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20class%3D%22link-titled%22%20href%3D%22http%3A%2F%2Fbit.ly%2F1neUtSO%22%20title%3D%22http%3A%2F%2Fbit.ly%2F1neUtSO%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EO.S.%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%BA%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1101772%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX%20Yocto%20Project%3A%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E6%89%8B%E5%8B%95%E3%81%A7%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%81%84%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1101772%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Otavio%2C%3C%2FP%3E%3CP%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E9%96%A2%E9%80%A3%E3%81%AE%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%AE%E5%AE%9F%E8%A1%8C%E6%96%B9%E6%B3%95%E3%82%92%E5%AD%A6%E3%81%B6%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%A8%80%E5%8F%8A%E3%81%97%E3%81%9F%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%AB%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%AA%E3%83%80%E3%82%A4%E3%83%AC%E3%82%AF%E3%83%88%E3%81%97%E3%81%A6%E3%82%82%E3%82%88%E3%82%8D%E3%81%97%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20class%3D%22jive-link-external-small%22%20data-content-finding%3D%22Community%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fbit.ly%252F11o0wg9%22%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%23017bba%3B%22%20target%3D%22_blank%22%3EEmbedded%20Linux%20Development%20with%20Yocto%20Project%E3%81%AE%E6%9B%B8%E7%B1%8D%E3%81%8C%E7%99%BA%E5%A3%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%20%7C%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%83%BB%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%3C%2FA%3E%3C%2FP%3E%3CH1%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%201.6667em%3B%20font-family%3A%20inherit%3B%22%20id%3D%22toc-hId-380521712%22%20id%3D%22toc-hId-1304163768%22%3E%E4%B8%8D%E6%AD%A3%3C%2FH1%3E%3CP%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22font-size%3A%2014px%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%3C%2FP%3E%3CDIV%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CDIV%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CBR%20clear%3D%22all%22%20%2F%3E%3CDIV%20class%3D%22jive-error-box%22%20style%3D%22margin%3A%200%200%2020px%3B%20padding%3A%2010px%3B%20font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%20background-color%3A%20%23f3e1dd%3B%22%3E%3CDIV%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CSPAN%20class%3D%22jive-icon-med%20jive-icon-redalert%22%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3C%2FSPAN%3E%E3%81%93%E3%81%AE%E5%A0%B4%E6%89%80%E3%82%84%E3%82%B3%E3%83%B3%E3%83%86%E3%83%B3%E3%83%84%E3%81%B8%E3%81%AE%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%AF%E5%88%B6%E9%99%90%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20font-size%3A%2014px%3B%20background-color%3A%20%23f3e1dd%3B%22%3E%E3%81%93%E3%82%8C%E3%81%8C%E9%96%93%E9%81%95%E3%81%84%E3%81%A7%E3%81%82%E3%82%8B%E3%81%A8%E6%80%9D%E3%82%8F%E3%82%8C%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E7%AE%A1%E7%90%86%E8%80%85%E3%81%BE%E3%81%9F%E3%81%AF%E3%81%93%E3%81%93%E3%81%A7%E3%81%82%E3%81%AA%E3%81%9F%E3%82%92%E6%8C%87%E7%A4%BA%E3%81%97%E3%81%9F%E4%BA%BA%E3%81%AB%E9%80%A3%E7%B5%A1%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1101771%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX%20Yocto%20Project%3A%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E6%89%8B%E5%8B%95%E3%81%A7%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%81%84%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1101771%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%A7%81%E3%82%82%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E9%81%AD%E9%81%87%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%A8%E3%83%AA%E3%83%83%E3%82%AF%E3%81%AE%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fboundarydevices.com%2Fmx6-linux-kernel-3-10-17-beta%2F%23comment-124454%22%20title%3D%22http%3A%2F%2Fboundarydevices.com%2Fmx6-linux-kernel-3-10-17-beta%2F%23comment-124454%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fboundarydevices.com%2Fmx6-linux-kernel-3-10-17-beta%2F%23comment-124454%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1101770%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX%20Yocto%20Project%3A%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E6%89%8B%E5%8B%95%E3%81%A7%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%81%84%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1101770%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%B8%8A%E8%A8%98%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB3.10.17-1.0.1%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CTABLE%3E%3CTBODY%3E%3CTR%3E%3CTD%3E%26nbsp%3B%20CC%26nbsp%3B%20%3C%2FTD%3E%3CTD%3E%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%2Fmxc%2Fgpu-viv%2Fhal%2Fos%2Flinux%2Fkernel%2Fgc_hal_kernel_device.o%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3Edrivers%2Fmxc%2Fgpu-viv%2Fhal%2Fos%2Flinux%2Fkernel%2Fgc_hal_kernel_device.c%3A29%3A27%3A%20%E8%87%B4%E5%91%BD%E7%9A%84%E3%81%AA%E3%82%A8%E3%83%A9%E3%83%BC%3A%20mach%2Fhardware.h%3A%E8%A9%B2%E5%BD%93%E3%81%99%E3%82%8B%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%84%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3E%20%23include%20%26lt%3B%20mach%2Fhardware.h%26gt%3B%3C%2FP%3E%3CTABLE%3E%3CTBODY%3E%3CTR%3E%3CTD%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FTD%3E%3CTD%3E%5E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%8C%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3Emake%5B3%5D%3A%20***%20%5Bdrivers%2Fmxc%2Fgpu-viv%2Fhal%2Fos%2Flinux%2Fkernel%2Fgc_hal_kernel_device.o%5D%E3%82%A8%E3%83%A9%E3%83%BC%201%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1101769%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX%20Yocto%20Project%3A%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E6%89%8B%E5%8B%95%E3%81%A7%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%81%84%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1101769%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%96%B0%E8%A3%BD%E5%93%81%E3%82%923.0.35%E3%82%92%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AB%E3%81%97%E3%81%AA%E3%81%84%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84Freescale%20GA%E3%81%A8%E3%81%97%E3%81%A6%E3%81%AE%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AF%E3%80%813.10.17-1.0.1%E3%81%AE%E3%82%82%E3%81%AE%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E6%A7%8B%E7%AF%89%E3%81%AB%E9%96%A2%E3%81%97%E3%81%A6%E3%81%AF%E3%80%81%E9%96%8B%E7%99%BA%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%81%8C%E5%A4%A7%E5%B9%85%E3%81%AB%E5%BE%8C%E6%8A%BC%E3%81%97%E3%81%95%E3%82%8C%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E3%81%93%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%82%82%E8%A6%8B%E3%81%9F%E3%81%84%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%3A%20%3CA%20href%3D%22http%3A%2F%2Fbit.ly%2F11o0wg9%22%20title%3D%22http%3A%2F%2Fbit.ly%2F11o0wg9%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EEmbedded%20Linux%20Development%20with%20Yocto%20Project%E3%81%AE%E6%9C%AC%E3%81%8C%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%7C%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%83%BB%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1101768%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX%20Yocto%20Project%3A%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E6%89%8B%E5%8B%95%E3%81%A7%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%81%84%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1101768%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E7%A7%81%E3%81%AFimx6q%20sabresd%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%8Fimx%20yocto(bitbake%20fsl-image-gui)%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%97%E3%81%A6%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E4%BB%8A%E3%80%81%E7%A7%81%E3%81%AF%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81imx_3.0.35_4.1.0%E3%82%92%E8%A9%A6%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E4%B8%8A%E8%A8%98%E3%81%AE%E3%82%B9%E3%83%86%E3%83%83%E3%83%975%E4%BB%A5%E9%99%8D%E3%81%A7%E7%A4%BA%E3%81%97%E3%81%9F%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%AF%E5%95%8F%E9%A1%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81LCD%E3%81%ABGUI%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%9A%E3%80%81%E3%81%99%E3%81%A7%E3%81%ABdevtmpfs%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1101767%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX%20Yocto%20Project%3A%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E6%89%8B%E5%8B%95%E3%81%A7%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%81%84%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1101767%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%84%20%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fsaurabh206%22%20target%3D%22_blank%22%3Esaurabh206%3C%2FA%3E%E3%81%A7%E3%81%99%E3%80%81defconfig%E3%81%AF%E7%A2%BA%E3%81%8B%E3%81%AB%E7%95%B0%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82imx_v7_defconfig%E3%81%A7%E3%81%99%E3%80%82%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E5%8F%AF%E8%83%BD%E3%81%AA%E8%A8%AD%E5%AE%9A%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E6%8C%87%E5%AE%9A%E3%81%97%E3%81%9F%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%BE%E3%81%9F%E3%81%AF%E3%80%8Cmake%20help%E3%80%8D%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%24%20make%20help%20%7Cgrep%20imx%3C%2FP%3E%0A%3CP%3Eimx6_ssd_lite_defconfig%20-%20imx6_ssd_lite%E7%94%A8%E3%81%AB%E3%83%93%E3%83%AB%E3%83%89%3C%2FP%3E%0A%3CP%3Eimx6_ssd_net_lite_defconfig%20-%20imx6_ssd_net_lite%E7%94%A8%E3%81%AB%E6%A7%8B%E7%AF%89%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%20imx_v4_v5_defconfig%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20-%20Build%20for%20imx_v4_v5%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%20imx_v6_v7_defconfig%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20-%20Build%20for%20imx_v6_v7%3C%2FP%3E%0A%3CP%3Eimx_v7_defconfig%20-%20imx_v7%E7%94%A8%E3%81%AB%E6%A7%8B%E7%AF%89%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%20imx_v7_mfg_defconfig%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20-%20Build%20for%20imx_v7_mfg%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1101766%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX%20Yocto%20Project%3A%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E6%89%8B%E5%8B%95%E3%81%A7%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%81%84%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1101766%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E3.10.17%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E4%B8%8A%E8%A8%98%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AF%E5%90%8C%E3%81%98%E3%81%BE%E3%81%BE%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Emake%20imx6_defconfig%20%E3%81%A7%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3E%20%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E8%A8%AD%E5%AE%9A%20%22arch%2Farm%2Fconfigs%2Fimx6_defconfig%22%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93!%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎07-30-2013 09:49 AM
更新者:
