i.MX Yocto Project: Can I use a virtual machine to build?
Document created by Leonardo Sandoval Gonzalez Employee on Jun 13, 2013
Version 1Show Document
  • View in full screen mode
You can but building times will take much longer (approximately 2 times longer for the core-image-minimal) compared to a build done on a native machine. In case you can not do the build on a native machine, make sure your virtual has enough hard-disk room (at least 50GB). For example, these are the build folders sizes after baking core-image-minimal:
build$ du -h --max-depth=1
1.3G    ./sstate-cache
3.2M    ./cache
12K    ./.hob
32K    ./conf
22G    ./tmp
23G    .
The tmp folder is by far the largest (containing building statistics, source code, deployed images, etc.)
build/tmp$ tree -L 2 -d
├── buildstats
│   ├── cogl-imx6qsabresd
│   ├── fsl-image-gui-imx6qsabresd
│   ├── fsl-image-gui-sdk-imx6qsabresd
│   ├── mesa-dri-imx6qsabresd
│   ├── mesa-imx6qsabresd
│   └── pseudo-native-imx6qsabresd
├── cache
│   └── default-eglibc
├── deploy
│   ├── images
│   ├── licenses
│   └── rpm
├── log
│   ├── cleanlogs
│   └── cooker
├── pkgdata
│   ├── all-poky-linux
│   ├── all-poky-linux-gnueabi
│   ├── armv7a-vfp-neon-poky-linux-gnueabi
│   ├── imx6qsabresd-poky-linux
│   └── imx6qsabresd-poky-linux-gnueabi
├── sstate-control
├── stamps
│   ├── imx6qsabresd-poky-linux-gnueabi
│   ├── work-shared
│   └── x86_64-linux
├── sysroots
│   ├── imx6qsabresd
│   ├── imx6qsabresd-tcbootstrap
│   └── x86_64-linux
├── work
│   └── x86_64-linux
└── work-shared
    └── gcc-4.7.2-r13
    Outcomes
