Quick Guide on Booting i.MX95 with ND/LD Mode
EsaHuang
On i.MX95, OD, ND, and LD represent different system operating modes used to balance performance and power consumption. OD (OverDrive) mode targets the highest performance, allowing higher clock frequencies with a higher SoC supply voltage. ND (Nominal Drive) mode provides the standard operating point for normal performance and power efficiency. LD (Low Drive) mode is intended for lower-power operation, reducing voltage and limiting clock frequencies to save energy. In practice, switching between these modes involves coordinated changes of VDD_SOC, system clocks, and DDR operating frequency so that the device can move between high-performance and low-power states safely and efficiently.
Here is a table about the Maximum frequency of modules of different modes.
OverDrive Mode
Nominal Mode
LowDrive Mode
VDD_SOC (typical)
0.9 V
0.85 V
0.8 V
VDD_ARM (typical)
0.9 V
0.85 V
0.8 V
A55 frequency
1800 MHz
1400 MHz
900 MHz
NPU frequency
1000 MHz
800 MHz
500 MHz
ISI frequency
667 MHz
500 MHz
333 MHz
GPU frequency
500 MHz
500 MHz
500 MHz
Display frequency
800 MHz
666 MHz
400 MHz
VPU frequency
666 MHz
500 MHz
333 MHz
To achieve the corresponding status in different modes, three actions needed to be taken
  • Change SoC driving mode in system manager
  • Set ddr rate in OEI image
  • Compile bootloader in mkimage
1.1 Change the SoC driving mode in system manager
1. First, clone the repository to your local machine and build the m33_image.bin. Refer to the README.md file in the repository for detailed build instructions and additional information.
git clone https://github.com/nxp-imx/imx-sm.git
export TOOLS=~/tools  # toolchain download link here, export your own path:
make config=mx95evk cfg​
make config=mx95evk all​
2.Here are the code changes for ND mode​ and LD mode in system manager
ND:
Diff --git a/boards/mcimx95evk/sm/brd_sm.c b/boards/mcimx95evk/sm/brd_sm.c​
--- a/boards/mcimx95evk/sm/brd_sm.c​
+++ b/boards/mcimx95evk/sm/brd_sm.c​
@@ -104,7 +104,7 @@​
BRD_SM_REC_VLD_MASK)​
/* Performance parameters */​
-#define BOARD_PERF_LEVEL DEV_SM_PERF_LVL_ODV /* Target perf level */​
+#define BOARD_PERF_LEVEL DEV_SM_PERF_LVL_NOM /* Target perf level */​
diff --git a/devices/MIMX95/sm/dev_sm_perf.c b/devices/MIMX95/sm/dev_sm_perf.c
index 8aafdce9..26d6da11 100644
--- a/devices/MIMX95/sm/dev_sm_perf.c
+++ b/devices/MIMX95/sm/dev_sm_perf.c
@@ -2704,7 +2704,8 @@ static void DEV_SM_PerfCfgInit(void)
     else
         /* All other devices support PRK, LOW, NOM, ODV setpoints */
-        s_perfNumLevels[PS_VDD_ARM] = DEV_SM_NUM_PERF_LVL_ARM - 1U;
+        s_perfNumLevels[PS_VDD_ARM] = DEV_SM_NUM_PERF_LVL_ARM - 2U;
     /* Check for LPDDR4X */
LD:
diff --git a/boards/mcimx95evk/sm/brd_sm.c b/boards/mcimx95evk/sm/brd_sm.c​
+#define BOARD_PERF_LEVEL DEV_SM_PERF_LVL_LOW /* Target perf level */
     else
+        s_perfNumLevels[PS_VDD_ARM] = DEV_SM_NUM_PERF_LVL_ARM - 3U;
Compile the SM binary to generate build/mx95lp5/ddr/m33_image.bin, then copy it to imx-mkimage/iMX95/m33_image.bin.
1.2. Change the SoC driving mode in system manager
1.First, clone the repository to your local machine and build the m33-oei-ddr.bin. Refer to the README.md file in the repository for detailed build instructions and additional information.
git clone https://github.com/nxp-imx/imx-oei.git
make board=mx95lp5 oei=ddr DEBUG=1 r=B0
2. Please replace the a/boards/mx95lp5/ddr/ cMIMX95_LPDDR5_EVK_19X19_6400MTS_FW2024.09_timing.c file with a file corresponding to a different DDR data rate.
For ND mode, the file is lpddr5_4800_timing.c (See in attachment)
For LD mode, the file is lpddr5_3200_timing.c (See in attachment)
Compile the OEI binary to generate build/mx95lp5/ddr/m33_image.bin, then copy it to imx-mkimage/iMX95/m33_image.bin.
1.3. Compile bootloader in mkimage
1.Setup the imx-mkimage​
mkdir imx-mkimage​
cd imx-mkimage/​
git clone https://github.com/nxp-imx/imx-mkimage.git
git checkout <branch_name>
2. Compile flash.bin
Refer to UG10163, section 4.5.13, to compile the files required by mkimage. Copy all the generated files to the imx-mkimage/iMX95 directory. Replace oei-m33-ddr.bin and m33_image.bin, then run the following command to generate flash.bin:
make SOC=iMX95 OEI=YES flash_all ​
​ The table describes the corresponding binaries:
OEI image
System manager (M33_image)
OverDrive Mode
Oei-m33-ddr-6400.bin
M33_image_OD.bin​
Nominal Mode
Oei-m33-ddr-4800.bin
M33_image_ND.bin​
LowDrive Mode
Oei-m33-ddr-3200.bin
M33_image_LD.bin​
3 .Flash the different flash.bin file to board with following command:​
./uuu.exe –b emmc flash.bin​
4. Open the BCU tool to check the VDD_SOC and VDD_ARM voltages. Then run the mhz command, and you will see that the current CPU frequency is being limited.
%3CLINGO-SUB%20id%3D%22lingo-sub-2365932%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3Ei.MX95%E3%82%92ND%2FLD%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%82%AF%E3%82%A4%E3%83%83%E3%82%AF%E3%82%AC%E3%82%A4%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2365932%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3Ei.MX95%E3%81%A7%E3%81%AF%E3%80%81OD%E3%80%81ND%E3%80%81LD%E3%81%AF%E3%80%81%E3%83%91%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%B9%E3%81%A8%E6%B6%88%E8%B2%BB%E9%9B%BB%E5%8A%9B%E3%81%AE%E3%83%90%E3%83%A9%E3%83%B3%E3%82%B9%E3%82%92%E5%8F%96%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%E7%95%B0%E3%81%AA%E3%82%8B%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E5%8B%95%E4%BD%9C%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E8%A1%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82OD%EF%BC%88%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%89%E3%83%A9%E3%82%A4%E3%83%96%EF%BC%89%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AF%E6%9C%80%E9%AB%98%E3%81%AE%E3%83%91%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%B9%E3%82%92%E7%9B%AE%E6%8C%87%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%82%88%E3%82%8A%E9%AB%98%E3%81%84SoC%E4%BE%9B%E7%B5%A6%E9%9B%BB%E5%9C%A7%E3%81%A7%E3%82%88%E3%82%8A%E9%AB%98%E3%81%84%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E5%91%A8%E6%B3%A2%E6%95%B0%E3%82%92%E5%8F%AF%E8%83%BD%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82ND%EF%BC%88%E5%85%AC%E7%A7%B0%E9%A7%86%E5%8B%95%EF%BC%89%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AF%E3%80%81%E9%80%9A%E5%B8%B8%E3%81%AE%E6%80%A7%E8%83%BD%E3%81%A8%E9%9B%BB%E5%8A%9B%E5%8A%B9%E7%8E%87%E3%82%92%E5%AE%9F%E7%8F%BE%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E6%A8%99%E6%BA%96%E5%8B%95%E4%BD%9C%E7%82%B9%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82LD%EF%BC%88%E4%BD%8E%E9%A7%86%E5%8B%95%EF%BC%89%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AF%E3%80%81%E4%BD%8E%E6%B6%88%E8%B2%BB%E9%9B%BB%E5%8A%9B%E5%8B%95%E4%BD%9C%E3%82%92%E7%9B%AE%E7%9A%84%E3%81%A8%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E9%9B%BB%E5%9C%A7%E3%82%92%E4%B8%8B%E3%81%92%E3%80%81%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E5%91%A8%E6%B3%A2%E6%95%B0%E3%82%92%E5%88%B6%E9%99%90%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%82%A8%E3%83%8D%E3%83%AB%E3%82%AE%E3%83%BC%E3%82%92%E7%AF%80%E7%B4%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E5%AE%9F%E9%9A%9B%E3%81%AB%E3%81%AF%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81VDD_SOC%E3%80%81%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%80%81DDR%E5%8B%95%E4%BD%9C%E5%91%A8%E6%B3%A2%E6%95%B0%E3%81%AE%E5%8D%94%E8%AA%BF%E7%9A%84%E3%81%AA%E5%A4%89%E6%9B%B4%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A8%E3%81%AA%E3%82%8A%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C%E9%AB%98%E6%80%A7%E8%83%BD%E7%8A%B6%E6%85%8B%E3%81%A8%E4%BD%8E%E6%B6%88%E8%B2%BB%E9%9B%BB%E5%8A%9B%E7%8A%B6%E6%85%8B%E3%81%AE%E9%96%93%E3%82%92%E5%AE%89%E5%85%A8%E3%81%8B%E3%81%A4%E5%8A%B9%E7%8E%87%E7%9A%84%E3%81%AB%E7%A7%BB%E8%A1%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AF%E3%80%81%E7%95%B0%E3%81%AA%E3%82%8B%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AE%E6%9C%80%E5%A4%A7%E5%91%A8%E6%B3%A2%E6%95%B0%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E8%A1%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CTABLE%20width%3D%22664px%22%3E%0A%3CTBODY%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22221.656px%22%3E%0A%3CBR%20%2F%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22149.438px%22%3E%0A%3CP%3E%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%89%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A2%E3%83%BC%E3%83%89%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22144.422px%22%3E%0A%3CP%3E%E5%85%AC%E7%A7%B0%E3%83%A2%E3%83%BC%E3%83%89%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22147.484px%22%3E%0A%3CP%3E%E3%83%AD%E3%83%BC%E3%83%89%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A2%E3%83%BC%E3%83%89%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22221.656px%22%3E%0A%3CP%3EVDD_SOC%EF%BC%88%E6%A8%99%E6%BA%96%E5%80%A4%EF%BC%89%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22149.438px%22%3E%0A%3CP%3E0.9V%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22144.422px%22%3E%0A%3CP%3E0.85V%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22147.484px%22%3E%0A%3CP%3E0.8V%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22221.656px%22%3E%0A%3CP%3EVDD_ARM%EF%BC%88%E6%A8%99%E6%BA%96%E5%80%A4%EF%BC%89%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22149.438px%22%3E%0A%3CP%3E0.9V%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22144.422px%22%3E%0A%3CP%3E0.85V%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22147.484px%22%3E%0A%3CP%3E0.8V%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22221.656px%22%3E%0A%3CP%3EA55%E5%91%A8%E6%B3%A2%E6%95%B0%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22149.438px%22%3E%0A%3CP%3E1800MHz%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22144.422px%22%3E%0A%3CP%3E1400MHz%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22147.484px%22%3E%0A%3CP%3E900MHz%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22221.656px%22%3E%0A%3CP%3ENPU%E5%91%A8%E6%B3%A2%E6%95%B0%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22149.438px%22%3E%0A%3CP%3E1000MHz%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22144.422px%22%3E%0A%3CP%3E800MHz%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22147.484px%22%3E%0A%3CP%3E500MHz%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22221.656px%22%3E%0A%3CP%3EISI%E5%91%A8%E6%B3%A2%E6%95%B0%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22149.438px%22%3E%0A%3CP%3E667MHz%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22144.422px%22%3E%0A%3CP%3E500MHz%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22147.484px%22%3E%0A%3CP%3E333MHz%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22221.656px%22%3E%0A%3CP%3EGPU%E5%91%A8%E6%B3%A2%E6%95%B0%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22149.438px%22%3E%0A%3CP%3E500MHz%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22144.422px%22%3E%0A%3CP%3E500MHz%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22147.484px%22%3E%0A%3CP%3E500MHz%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22221.656px%22%3E%0A%3CP%3E%E8%A1%A8%E7%A4%BA%E5%91%A8%E6%B3%A2%E6%95%B0%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22149.438px%22%3E%0A%3CP%3E800MHz%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22144.422px%22%3E%0A%3CP%3E666MHz%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22147.484px%22%3E%0A%3CP%3E400MHz%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22221.656px%22%3E%0A%3CP%3EVPU%E5%91%A8%E6%B3%A2%E6%95%B0%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22149.438px%22%3E%0A%3CP%3E666MHz%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22144.422px%22%3E%0A%3CP%3E500MHz%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22147.484px%22%3E%0A%3CP%3E333MHz%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%95%B0%E3%81%AA%E3%82%8B%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E5%AF%BE%E5%BF%9C%E3%81%99%E3%82%8B%E7%8A%B6%E6%85%8B%E3%82%92%E9%81%94%E6%88%90%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%813%E3%81%A4%E3%81%AE%E8%A1%8C%E5%8B%95%E3%82%92%E5%8F%96%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%81%A3%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A3%E3%81%A7SoC%E3%81%AE%E9%A7%86%E5%8B%95%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%3C%2FLI%3E%0A%3CLI%3EOEI%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%A7DDR%E3%83%AC%E3%83%BC%E3%83%88%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%3C%2FLI%3E%0A%3CLI%3Emkimage%E3%81%A7%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CH3%20id%3D%22toc-hId-2032010361%22%20id%3D%22toc-hId-2032927247%22%3E%3CSPAN%3E1.1%3C%2FSPAN%3E%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A3%E3%81%A7%3CSPAN%3ESoC%E3%81%AE%E9%A7%86%E5%8B%95%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3C%2FH3%3E%0A%3CP%3E1.%20%E3%81%BE%E3%81%9A%E3%80%81%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%82%92%E3%83%AD%E3%83%BC%E3%82%AB%E3%83%AB%E3%83%9E%E3%82%B7%E3%83%B3%E3%81%AB%E3%82%AF%E3%83%AD%E3%83%BC%E3%83%B3%E3%81%97%E3%80%81m33_image.bin%20%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E8%A9%B3%E7%B4%B0%E3%81%AA%E3%83%93%E3%83%AB%E3%83%89%E6%89%8B%E9%A0%86%E3%81%8A%E3%82%88%E3%81%B3%E8%BF%BD%E5%8A%A0%E6%83%85%E5%A0%B1%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E5%86%85%E3%81%AEREADME.md%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CPRE%20translate%3D%22no%22%3Egit%20clone%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Fimx-sm.git%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx%2Fimx-sm.git%3C%2FA%3E%3CBR%20%2F%3Eexport%20TOOLS%3D~%2Ftools%20%26nbsp%3B%23%20toolchain%20download%20link%20%3CSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fdeveloper.arm.com%2Fdownloads%2F-%2Farm-gnu-toolchain-downloads%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehere%3C%2FA%3E%3C%2FSPAN%3E%2C%20export%20your%20own%20path%3A%3CBR%20%2F%3Emake%20config%3Dmx95evk%20cfg%E2%80%8B%3CBR%20%2F%3Emake%20config%3Dmx95evk%20all%E2%80%8B%3C%2FPRE%3E%0A%3CP%3E2.%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A3%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8BND%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A8LD%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E5%A4%89%E6%9B%B4%E7%82%B9%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3END%3A%3C%2FP%3E%0A%3CPRE%20translate%3D%22no%22%3EDiff%20--git%20a%2Fboards%2Fmcimx95evk%2Fsm%2Fbrd_sm.c%20b%2Fboards%2Fmcimx95evk%2Fsm%2Fbrd_sm.c%E2%80%8B%3CBR%20%2F%3E---%20a%2Fboards%2Fmcimx95evk%2Fsm%2Fbrd_sm.c%E2%80%8B%3CBR%20%2F%3E%2B%2B%2B%20b%2Fboards%2Fmcimx95evk%2Fsm%2Fbrd_sm.c%E2%80%8B%3CBR%20%2F%3E%40%40%20-104%2C7%20%2B104%2C7%20%40%40%E2%80%8B%3CBR%20%2F%3EBRD_SM_REC_VLD_MASK)%E2%80%8B%3CBR%20%2F%3E%3CBR%20%2F%3E%2F*%20Performance%20parameters%20*%2F%E2%80%8B%3CBR%20%2F%3E-%23define%20BOARD_PERF_LEVEL%20DEV_SM_PERF_LVL_ODV%20%2F*%20Target%20perf%20level%20*%2F%E2%80%8B%3CBR%20%2F%3E%2B%23define%20BOARD_PERF_LEVEL%20DEV_SM_PERF_LVL_NOM%20%2F*%20Target%20perf%20level%20*%2F%E2%80%8B%3CBR%20%2F%3E%3CBR%20%2F%3Ediff%20--git%20a%2Fdevices%2FMIMX95%2Fsm%2Fdev_sm_perf.c%20b%2Fdevices%2FMIMX95%2Fsm%2Fdev_sm_perf.c%3CBR%20%2F%3Eindex%208aafdce9..26d6da11%20100644%3CBR%20%2F%3E---%20a%2Fdevices%2FMIMX95%2Fsm%2Fdev_sm_perf.c%3CBR%20%2F%3E%2B%2B%2B%20b%2Fdevices%2FMIMX95%2Fsm%2Fdev_sm_perf.c%3CBR%20%2F%3E%40%40%20-2704%2C7%20%2B2704%2C8%20%40%40%20static%20void%20DEV_SM_PerfCfgInit(void)%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20else%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7B%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F*%20All%20other%20devices%20support%20PRK%2C%20LOW%2C%20NOM%2C%20ODV%20setpoints%20*%2F%3CBR%20%2F%3E-%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20s_perfNumLevels%5BPS_VDD_ARM%5D%20%3D%20DEV_SM_NUM_PERF_LVL_ARM%20-%201U%3B%3CBR%20%2F%3E%2B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20s_perfNumLevels%5BPS_VDD_ARM%5D%20%3D%20DEV_SM_NUM_PERF_LVL_ARM%20-%202U%3B%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3CBR%20%2F%3E%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F*%20Check%20for%20LPDDR4X%20*%2F%3C%2FPRE%3E%0A%3CP%3ELD%3A%3C%2FP%3E%0A%3CPRE%20translate%3D%22no%22%3Ediff%20--git%20a%2Fboards%2Fmcimx95evk%2Fsm%2Fbrd_sm.c%20b%2Fboards%2Fmcimx95evk%2Fsm%2Fbrd_sm.c%E2%80%8B%3CBR%20%2F%3E---%20a%2Fboards%2Fmcimx95evk%2Fsm%2Fbrd_sm.c%E2%80%8B%3CBR%20%2F%3E%2B%2B%2B%20b%2Fboards%2Fmcimx95evk%2Fsm%2Fbrd_sm.c%E2%80%8B%3CBR%20%2F%3E%40%40%20-104%2C7%20%2B104%2C7%20%40%40%E2%80%8B%3CBR%20%2F%3EBRD_SM_REC_VLD_MASK)%E2%80%8B%3CBR%20%2F%3E%3CBR%20%2F%3E%2F*%20Performance%20parameters%20*%2F%E2%80%8B%3CBR%20%2F%3E-%23define%20BOARD_PERF_LEVEL%20DEV_SM_PERF_LVL_ODV%20%2F*%20Target%20perf%20level%20*%2F%E2%80%8B%3CBR%20%2F%3E%2B%23define%20BOARD_PERF_LEVEL%20DEV_SM_PERF_LVL_LOW%20%2F*%20Target%20perf%20level%20*%2F%3CBR%20%2F%3E%3CBR%20%2F%3Ediff%20--git%20a%2Fdevices%2FMIMX95%2Fsm%2Fdev_sm_perf.c%20b%2Fdevices%2FMIMX95%2Fsm%2Fdev_sm_perf.c%3CBR%20%2F%3Eindex%208aafdce9..26d6da11%20100644%3CBR%20%2F%3E---%20a%2Fdevices%2FMIMX95%2Fsm%2Fdev_sm_perf.c%3CBR%20%2F%3E%2B%2B%2B%20b%2Fdevices%2FMIMX95%2Fsm%2Fdev_sm_perf.c%3CBR%20%2F%3E%40%40%20-2704%2C7%20%2B2704%2C8%20%40%40%20static%20void%20DEV_SM_PerfCfgInit(void)%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20else%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7B%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F*%20All%20other%20devices%20support%20PRK%2C%20LOW%2C%20NOM%2C%20ODV%20setpoints%20*%2F%3CBR%20%2F%3E-%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20s_perfNumLevels%5BPS_VDD_ARM%5D%20%3D%20DEV_SM_NUM_PERF_LVL_ARM%20-%201U%3B%3CBR%20%2F%3E%2B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20s_perfNumLevels%5BPS_VDD_ARM%5D%20%3D%20DEV_SM_NUM_PERF_LVL_ARM%20-%203U%3B%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3CBR%20%2F%3E%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F*%20Check%20for%20LPDDR4X%20*%2F%3C%2FPRE%3E%0A%3CP%3ESM%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%97%E3%81%A6build%2Fmx95lp5%2Fddr%2Fm33_image.bin%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%80%81%E3%81%9D%E3%82%8C%E3%82%92imx-mkimage%2FiMX95%2Fm33_image.bin%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CH3%20id%3D%22toc-hId-224555898%22%20id%3D%22toc-hId-225472784%22%3E%3CSPAN%3E1.%3C%2FSPAN%3E%202%20%3CSPAN%3E.%3C%2FSPAN%3E%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A3%E3%81%A7%3CSPAN%3ESoC%E3%81%AE%E9%A7%86%E5%8B%95%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3C%2FH3%3E%0A%3CP%3E1.%E3%81%BE%E3%81%9A%E3%80%81%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%82%92%E3%83%AD%E3%83%BC%E3%82%AB%E3%83%AB%E3%83%9E%E3%82%B7%E3%83%B3%E3%81%AB%E3%82%AF%E3%83%AD%E3%83%BC%E3%83%B3%E3%81%97%E3%80%81m33-oei-ddr.bin%20%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E8%A9%B3%E7%B4%B0%E3%81%AA%E3%83%93%E3%83%AB%E3%83%89%E6%89%8B%E9%A0%86%E3%81%8A%E3%82%88%E3%81%B3%E8%BF%BD%E5%8A%A0%E6%83%85%E5%A0%B1%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E5%86%85%E3%81%AEREADME.md%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CPRE%20translate%3D%22no%22%3Egit%20clone%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Fimx-oei.git%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx%2Fimx-oei.git%3C%2FA%3E%3CBR%20%2F%3Eexport%20TOOLS%3D~%2Ftools%3CBR%20%2F%3Emake%20board%3Dmx95lp5%20oei%3Dddr%20DEBUG%3D1%20r%3DB0%3C%2FPRE%3E%0A%3CP%3E2.%20%3CEM%3Ea%2Fboards%2Fmx95lp5%2Fddr%2F%20cMIMX95_LPDDR5_EVK_19X19_6400MTS_FW2024.09_timing.c%3C%2FEM%3E%E3%82%92%E7%BD%AE%E3%81%8D%E6%8F%9B%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E7%95%B0%E3%81%AA%E3%82%8BDDR%E3%83%87%E3%83%BC%E3%82%BF%E3%83%AC%E3%83%BC%E3%83%88%E3%81%AB%E5%AF%BE%E5%BF%9C%E3%81%99%E3%82%8B%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%90%AB%E3%82%80%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%82%3C%2FP%3E%0A%3CP%3END%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%3CSPAN%3Elpddr5_4800_timing.c%E3%81%A7%E3%81%99%EF%BC%88%E6%B7%BB%E4%BB%98%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%8F%82%E7%85%A7%EF%BC%89%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3ELD%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%3CSPAN%3Elpddr5_3200_timing.c%E3%81%A7%E3%81%99%EF%BC%88%E6%B7%BB%E4%BB%98%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%8F%82%E7%85%A7%EF%BC%89%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EOEI%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%97%E3%81%A6build%2Fmx95lp5%2Fddr%2Fm33_image.bin%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%80%81%E3%81%9D%E3%82%8C%E3%82%92imx-mkimage%2FiMX95%2Fm33_image.bin%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CH3%20id%3D%22toc-hId--1582898565%22%20id%3D%22toc-hId--1581981679%22%3E%3CSPAN%3E1.%3C%2FSPAN%3E%203.%20%3CSPAN%3Emkimag%20e%E3%81%A7%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3C%2FH3%3E%0A%3CP%3E1.%20imx-mkimage%20%E3%82%92%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%0A%3CPRE%20translate%3D%22no%22%3Emkdir%20imx-mkimage%E2%80%8B%3CBR%20%2F%3Ecd%20imx-mkimage%2F%E2%80%8B%3CBR%20%2F%3Egit%20clone%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Fimx-mkimage.git%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx%2Fimx-mkimage.git%3C%2FA%3E%3CBR%20%2F%3Egit%20checkout%20%3CBRANCH_NAME%3E%3C%2FBRANCH_NAME%3E%3C%2FPRE%3E%0A%3CP%3E2.%20flash.bin%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%99%E3%82%8B%3C%2FP%3E%0A%3CP%3Emkimage%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%20%3CSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fuser-guide%2FUG10163.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EUG10163%3C%2FA%3E%3C%2FSPAN%3E%E3%81%AE%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B34.5.13%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92imx-mkimage%2FiMX95%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82oei-m33-ddr.bin%20%E3%81%A8%20m33_image.bin%20%E3%82%92%E7%BD%AE%E3%81%8D%E6%8F%9B%E3%81%88%E3%81%BE%E3%81%99%E3%80%82%E6%AC%A1%E3%81%AB%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%20flash.bin%20%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3Emake%20SOC%3DiMX95%20OEI%3DYES%20flash_all%3C%2FP%3E%0A%3CP%3E%E8%A1%A8%E3%81%AB%E3%81%AF%E3%80%81%E5%AF%BE%E5%BF%9C%E3%81%99%E3%82%8B%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%81%8C%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CTABLE%20width%3D%22624px%22%3E%0A%3CTBODY%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22148.781px%22%3E%0A%3CBR%20%2F%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22203.562px%22%3E%0A%3CP%3EOEI%E7%94%BB%E5%83%8F%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22270.656px%22%3E%0A%3CP%3E%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A3%EF%BC%88M33_image%EF%BC%89%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22148.781px%22%3E%0A%3CP%3E%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%89%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A2%E3%83%BC%E3%83%89%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22203.562px%22%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fnxp1-my.sharepoint.com%2Fpersonal%2Fesa_huang_nxp_com%2FDocuments%2FOei%2520and%2520m33_image%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EOei-m33-ddr-6400.bin%3C%2FA%3E%3C%2FSPAN%3E%E2%80%8B%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22270.656px%22%3E%0A%3CP%3EM33_image_OD.bin%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22148.781px%22%3E%0A%3CP%3E%E5%85%AC%E7%A7%B0%E3%83%A2%E3%83%BC%E3%83%89%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22203.562px%22%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fnxp1-my.sharepoint.com%2F%3Au%3A%2Fg%2Fpersonal%2Fesa_huang_nxp_com%2FEakMAjB0stZBkjQSg_aCfAsB2CdbSY_ns4mkz89HD0YXwg%3Fe%3Dagqyz4%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EOei-m33-ddr-4800.bin%3C%2FA%3E%3C%2FSPAN%3E%E2%80%8B%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22270.656px%22%3E%0A%3CP%3EM33_image_ND.bin%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22148.781px%22%3E%0A%3CP%3E%E3%83%AD%E3%83%BC%E3%83%89%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A2%E3%83%BC%E3%83%89%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22203.562px%22%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fnxp1-my.sharepoint.com%2F%3Au%3A%2Fg%2Fpersonal%2Fesa_huang_nxp_com%2FEZFXhvIPYxNDm-4A03WGDHYB3pNkGvK2IUp8FWfuLZKI9g%3Fe%3DVGOgrj%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EOei-m33-ddr-3200.bin%3C%2FA%3E%3C%2FSPAN%3E%E2%80%8B%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22270.656px%22%3E%0A%3CP%3EM33_image_LD.bin%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CP%3E3%EF%BC%8E%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E7%95%B0%E3%81%AA%E3%82%8Bflash.bin%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CPRE%20translate%3D%22no%22%3E.%2Fuuu.exe%20%E2%80%93b%20emmc%20flash.bin%E2%80%8B%3C%2FPRE%3E%0A%3CP%3E4.%20%3CSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Fmfgtools%2Freleases%2F%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EBCU%3C%2FA%3E%3C%2FSPAN%3E%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E9%96%8B%E3%81%84%E3%81%A6%E3%80%81%20%3CSTRONG%3EVDD_SOC%3C%2FSTRONG%3E%E3%81%A8%3CSTRONG%3EVDD_ARM%E3%81%AE%3C%2FSTRONG%3E%E9%9B%BB%E5%9C%A7%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E6%AC%A1%E3%81%AB%3CEM%3Emhz%3C%2FEM%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E7%8F%BE%E5%9C%A8%E3%81%AECPU%E5%91%A8%E6%B3%A2%E6%95%B0%E3%81%8C%E5%88%B6%E9%99%90%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-TEASER%20id%3D%22lingo-teaser-2365932%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3Ei.MX95%E3%81%A7%E3%81%AF%E3%80%81OD%E3%80%81ND%E3%80%81LD%E3%81%AF%E3%80%81%E3%83%91%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%B9%E3%81%A8%E6%B6%88%E8%B2%BB%E9%9B%BB%E5%8A%9B%E3%81%AE%E3%83%90%E3%83%A9%E3%83%B3%E3%82%B9%E3%82%92%E5%8F%96%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%E7%95%B0%E3%81%AA%E3%82%8B%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E5%8B%95%E4%BD%9C%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E8%A1%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82OD%EF%BC%88%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%89%E3%83%A9%E3%82%A4%E3%83%96%EF%BC%89%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AF%E6%9C%80%E9%AB%98%E3%81%AE%E3%83%91%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%B9%E3%82%92%E7%9B%AE%E6%8C%87%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%82%88%E3%82%8A%E9%AB%98%E3%81%84SoC%E4%BE%9B%E7%B5%A6%E9%9B%BB%E5%9C%A7%E3%81%A7%E3%82%88%E3%82%8A%E9%AB%98%E3%81%84%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E5%91%A8%E6%B3%A2%E6%95%B0%E3%82%92%E5%8F%AF%E8%83%BD%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82ND%EF%BC%88%E5%85%AC%E7%A7%B0%E9%A7%86%E5%8B%95%EF%BC%89%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AF%E3%80%81%E9%80%9A%E5%B8%B8%E3%81%AE%E6%80%A7%E8%83%BD%E3%81%A8%E9%9B%BB%E5%8A%9B%E5%8A%B9%E7%8E%87%E3%82%92%E5%AE%9F%E7%8F%BE%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E6%A8%99%E6%BA%96%E5%8B%95%E4%BD%9C%E7%82%B9%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82LD%EF%BC%88%E4%BD%8E%E9%A7%86%E5%8B%95%EF%BC%89%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AF%E3%80%81%E4%BD%8E%E6%B6%88%E8%B2%BB%E9%9B%BB%E5%8A%9B%E5%8B%95%E4%BD%9C%E3%82%92%E7%9B%AE%E7%9A%84%E3%81%A8%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E9%9B%BB%E5%9C%A7%E3%82%92%E4%B8%8B%E3%81%92%E3%80%81%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E5%91%A8%E6%B3%A2%E6%95%B0%E3%82%92%E5%88%B6%E9%99%90%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%82%A8%E3%83%8D%E3%83%AB%E3%82%AE%E3%83%BC%E3%82%92%E7%AF%80%E7%B4%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E5%AE%9F%E9%9A%9B%E3%81%AB%E3%81%AF%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81VDD_SOC%E3%80%81%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%80%81DDR%E5%8B%95%E4%BD%9C%E5%91%A8%E6%B3%A2%E6%95%B0%E3%81%AE%E5%8D%94%E8%AA%BF%E7%9A%84%E3%81%AA%E5%A4%89%E6%9B%B4%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A8%E3%81%AA%E3%82%8A%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C%E9%AB%98%E6%80%A7%E8%83%BD%E7%8A%B6%E6%85%8B%E3%81%A8%E4%BD%8E%E6%B6%88%E8%B2%BB%E9%9B%BB%E5%8A%9B%E7%8A%B6%E6%85%8B%E3%81%AE%E9%96%93%E3%82%92%E5%AE%89%E5%85%A8%E3%81%8B%E3%81%A4%E5%8A%B9%E7%8E%87%E7%9A%84%E3%81%AB%E7%A7%BB%E8%A1%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AF%E3%80%81%E7%95%B0%E3%81%AA%E3%82%8B%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AE%E6%9C%80%E5%A4%A7%E5%91%A8%E6%B3%A2%E6%95%B0%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E8%A1%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CTABLE%3E%0A%3CTBODY%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22142%22%3E%0A%3CBR%20%2F%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22142%22%3E%0A%3CP%3E%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%89%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A2%E3%83%BC%E3%83%89%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22142%22%3E%0A%3CP%3E%E5%85%AC%E7%A7%B0%E3%83%A2%E3%83%BC%E3%83%89%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22142%22%3E%0A%3CP%3E%E3%83%AD%E3%83%BC%E3%83%89%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A2%E3%83%BC%E3%83%89%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22142%22%3E%0A%3CP%3EVDD_SOC%EF%BC%88%E6%A8%99%E6%BA%96%E5%80%A4%EF%BC%89%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22142%22%3E%0A%3CP%3E0.9V%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22142%22%3E%0A%3CP%3E0.85V%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22142%22%3E%0A%3CP%3E0.8V%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22142%22%3E%0A%3CP%3EVDD_ARM%EF%BC%88%E6%A8%99%E6%BA%96%E5%80%A4%EF%BC%89%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22142%22%3E%0A%3CP%3E0.9V%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22142%22%3E%0A%3CP%3E0.85V%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22142%22%3E%0A%3CP%3E0.8V%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22142%22%3E%0A%3CP%3EA55%E5%91%A8%E6%B3%A2%E6%95%B0%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22142%22%3E%0A%3CP%3E1800MHz%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22142%22%3E%0A%3CP%3E1400MHz%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22142%22%3E%0A%3CP%3E900MHz%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22142%22%3E%0A%3CP%3ENPU%E5%91%A8%E6%B3%A2%E6%95%B0%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22142%22%3E%0A%3CP%3E1000MHz%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22142%22%3E%0A%3CP%3E800MHz%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22142%22%3E%0A%3CP%3E500MHz%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22142%22%3E%0A%3CP%3EISI%E5%91%A8%E6%B3%A2%E6%95%B0%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22142%22%3E%0A%3CP%3E667MHz%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22142%22%3E%0A%3CP%3E500MHz%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22142%22%3E%0A%3CP%3E333MHz%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22142%22%3E%0A%3CP%3EGPU%E5%91%A8%E6%B3%A2%E6%95%B0%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22142%22%3E%0A%3CP%3E500MHz%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22142%22%3E%0A%3CP%3E500MHz%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22142%22%3E%0A%3CP%3E500MHz%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22142%22%3E%0A%3CP%3E%E8%A1%A8%E7%A4%BA%E5%91%A8%E6%B3%A2%E6%95%B0%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22142%22%3E%0A%3CP%3E800MHz%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22142%22%3E%0A%3CP%3E666MHz%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22142%22%3E%0A%3CP%3E400MHz%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22142%22%3E%0A%3CP%3EVPU%E5%91%A8%E6%B3%A2%E6%95%B0%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22142%22%3E%0A%3CP%3E666MHz%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22142%22%3E%0A%3CP%3E500MHz%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22142%22%3E%0A%3CP%3E333MHz%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-TEASER%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2365932%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CLINGO-LABEL%3Ei.MX%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
