Useful documents and threads of i.MX Processors
The following document contains a list of document, questions and discussions that are relevant in the community based on amount of views. If you are having a problem, doubt or getting started in i.MX processors, you should check the following links to see if your doubt is in there.
Yocto Project
Freescale Yocto Project main page
Yocto Training - HOME
i.MX Yocto Project: Frequently Asked Questions
Useful bitbake commands
Yocto Project Package Management - smart
How to add a new layer and a new recipe in Yocto
Setting up the Eclipse IDE for Yocto Application Development
Guide to the .sdcard format
Yocto NFS & TFTP boot
YOCTO project clean
Yocto with a package manager (ex: apt-get)
Yocto Setting the Default Ethernet address and disable DHCP on boot.
i.MX x
Building QT for i.MX6
i.MX6/7 DDR Stress Test Tool V3.00
i.MX6DQSDL DDR3 Script Aid
Installing Ubuntu Rootfs on NXP i.MX6 boards
iMX6DQ MAX9286 MIPI CSI2 720P camera surround view solution for Linux BSP
i.MX Design&Tool Lists
Simple GPIO Example - quandry
i.MX6 GStreamer-imx Plugins - Tutorial & Example Pipelines
Streaming USB Webcam over Network
Step-by-step: How to setup TI Wilink (WL18xx) with iMX6 Linux 3.10.53
Linux / Kernel
Copying Files Between Windows and Linux using PuTTY
Building Linux Kernel
Patch to support uboot logo keep from uboot to kernel for NXP Linux and Android BSP (HDMI, LCD and L...
load kernel from SD card in U-boot
Changing the Kernel configuration for i.MX6 SABRE
Android
The Android Booting process
What is inside the init.rc and what is it used for.
Others
How to use qtmultimedia(QML) with Gstreamer 1.0
%3CLINGO-SUB%20id%3D%22lingo-sub-1108116%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EUseful%20documents%20and%20threads%20of%20i.MX%20Processors%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108116%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThe%20following%20document%20contains%20a%20list%20of%20document%2C%20questions%20and%20discussions%20that%20are%20relevant%20in%20the%20community%20based%20on%20amount%20of%20views.%20If%20you%20are%20having%20a%20problem%2C%20doubt%20or%20getting%20started%20in%20i.MX%20processors%2C%20you%20should%20check%20the%20following%20links%20to%20see%20if%20your%20doubt%20is%20in%20there.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH3%20id%3D%22toc-hId-1081788879%22%20id%3D%22toc-hId-1998643639%22%3EYocto%20Project%3C%2FH3%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-1616%22%20target%3D%22_blank%22%3EFreescale%20Yocto%20Project%20main%20page%3C%2FA%3E%E2%80%8C%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-94849%22%20target%3D%22_blank%22%3EYocto%20Training%20-%20HOME%3C%2FA%3E%E2%80%8C%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-94023%22%20target%3D%22_blank%22%3Ei.MX%20Yocto%20Project%3A%20Frequently%20Asked%20Questions%3C%2FA%3E%E2%80%8C%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-94953%22%20target%3D%22_blank%22%3EUseful%20bitbake%20commands%3C%2FA%3E%E2%80%8C%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-328199%22%20target%3D%22_blank%22%3EYocto%20Project%20Package%20Management%20-%20smart%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-331917%22%20target%3D%22_blank%22%3EHow%20to%20add%20a%20new%20layer%20and%20a%20new%20recipe%20in%20Yocto%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-172840%22%20target%3D%22_blank%22%3ESetting%20up%20the%20Eclipse%20IDE%20for%20Yocto%20Application%20Development%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-105521%22%20target%3D%22_blank%22%3EGuide%20to%20the%20.sdcard%20format%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-103717%22%20target%3D%22_blank%22%3EYocto%20NFS%20%26amp%3B%20TFTP%20boot%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fthread%2F353311%22%20target%3D%22_blank%22%3EYOCTO%20project%20clean%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fthread%2F325384%22%20target%3D%22_blank%22%3EYocto%20with%20a%20package%20manager%20(ex%3A%20apt-get)%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fthread%2F341117%22%20target%3D%22_blank%22%3EYocto%20Setting%20the%20Default%20Ethernet%20address%20and%20disable%20DHCP%20on%20boot.%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH3%20id%3D%22toc-hId--725665584%22%20id%3D%22toc-hId-191189176%22%3Ei.MX%20x%3C%2FH3%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-94066%22%20target%3D%22_blank%22%3EBuilding%20QT%20for%20i.MX6%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-105652%22%20target%3D%22_blank%22%3Ei.MX6%2F7%20DDR%20Stress%20Test%20Tool%20V3.00%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-94917%22%20target%3D%22_blank%22%3Ei.MX6DQSDL%20DDR3%20Script%20Aid%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-330147%22%20target%3D%22_blank%22%3EInstalling%20Ubuntu%20Rootfs%20on%20NXP%20i.MX6%20boards%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-328548%22%20target%3D%22_blank%22%3EiMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20camera%20surround%20view%20solution%20for%20Linux%20BSP%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-102005%22%20target%3D%22_blank%22%3Ei.MX%20Design%26amp%3BTool%20Lists%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fthread%2F381277%22%20target%3D%22_blank%22%3ESimple%20GPIO%20Example%20-%20quandry%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fthread%2F376271%22%20target%3D%22_blank%22%3Ei.MX6%20GStreamer-imx%20Plugins%20-%20Tutorial%20%26amp%3B%20Example%20Pipelines%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fthread%2F331804%22%20target%3D%22_blank%22%3EStreaming%20USB%20Webcam%20over%20Network%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fthread%2F358671%22%20target%3D%22_blank%22%3EStep-by-step%3A%20How%20to%20setup%20TI%20Wilink%20(WL18xx)%20with%20iMX6%20Linux%203.10.53%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH3%20id%3D%22toc-hId-1761847249%22%20id%3D%22toc-hId--1616265287%22%3ELinux%20%2F%20Kernel%3C%2FH3%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fthread%2F220596%22%20target%3D%22_blank%22%3ECopying%20Files%20Between%20Windows%20and%20Linux%20using%20PuTTY%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-100847%22%20target%3D%22_blank%22%3EBuilding%20Linux%20Kernel%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-98109%22%20target%3D%22_blank%22%3EPatch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fthread%2F380527%22%20target%3D%22_blank%22%3Eload%20kernel%20from%20SD%20card%20in%20U-boot%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fthread%2F376369%22%20target%3D%22_blank%22%3EChanging%20the%20Kernel%20configuration%20for%20i.MX6%20SABRE%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH3%20id%3D%22toc-hId--45607214%22%20id%3D%22toc-hId-871247546%22%3EAndroid%26nbsp%3B%3C%2FH3%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-102546%22%20target%3D%22_blank%22%3EThe%20Android%20Booting%20process%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-102537%22%20target%3D%22_blank%22%3EWhat%20is%20inside%20the%20init.rc%20and%20what%20is%20it%20used%20for.%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH3%20id%3D%22toc-hId--1853061677%22%20id%3D%22toc-hId--936206917%22%3EOthers%3C%2FH3%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-330047%22%20target%3D%22_blank%22%3EHow%20to%20use%20qtmultimedia(QML)%20with%20Gstreamer%201.0%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1108116%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EAndroid%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX%208%20Family%20%7C%20i.MX%208QuadMax%20(8QM)%20%7C%208QuadPlus%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX%208M%20%7C%20i.MX%208M%20Mini%20%7C%20i.MX%208M%20Nano%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX2x%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX50%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX51%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX53%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6_All%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6DL%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6Dual%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6DualPlus6QuadPlus%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6Quad%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6S%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6SL%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6SoloX%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6UL%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX7Dual%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX7Solo%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX7ULP%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EMultimedia%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EYocto%20Project%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
No ratings
Version history
Last update:
‎04-29-2019 09:32 AM
Updated by:
