s32k116 hardfault handler
7,641 次查看
Dinesh_Guleria
Hi NXP Application team,
Do we have some sample code where s32k116 hardfault handler is implemeted. So that we can trace from which instruction this hardfault occurred ?
Can i use same process as mentioned in this link :--
https://mcuoneclipse.com/2012/11/24/debugging-hard-faults-on-arm-cortex-m/
Please suggest.
Dinesh
标记 (1)
7,595 次查看
danielmartynek
Hi @Dinesh_Guleria,
There is a lot of useful information in the thread, please read it again.
An example on S32K116:
Read an unimplemented memory (0x80000):
volatile uint32_t read = *((uint32_t*)0x00080000);
void HardFault_Handler(void){
  while(1){
Read the stack from the fault handler
In memory view, SP + 0x18
Find the instruction:
5 回复数
7,633 次查看
danielmartynek
Hi @Dinesh_Guleria,
Unfortunately, we have no such example for S32K1xx (Cortex M0+).
The article you posted is for S32K14x (Cotex M4).
You can follow the steps here:
https://community.arm.com/support-forums/f/embedded-forum/3257/debugging-a-cortex-m0-hard-fault
You can read the stack in the memory view, there is no need to have the stacked PC stored in a variable, if you know how to read the stack.
7,623 次查看
Dinesh_Guleria
@danielmartynek ,
Thanks for your reply.
Link you  shared do not contain any solution how to do this task.
Please can you suggest how to read the stack..?
Dinesh
7,596 次查看
danielmartynek
Hi @Dinesh_Guleria,
  while(1){
7,527 次查看
Dinesh_Guleria
@danielmartynek
Thanks for your reply, it is clear to me.
Where exactly this figure comes from :--
In memory view, SP + 0x18.
Please suggest.
Dinesh
7,518 次查看
danielmartynek
Hello @Dinesh_Guleria,
This is a speudo code from ARM®v6-M Architecture Reference Manual
