Memory validation - MCUX Config tools
addiyi
SEMC - SDRAM validation
  1. Add a SEMC register initialization component. Start with Memory validation EVK preset or tweak the configuration.
  2. Connect the board to PC using COM port and USB HID.
  3. Press on Open Validation View to start testing the configurationaddiyi_1-1710920589057.png
  4. Run available tests
FlexSPI - NOR validation
  1. Add a FlexSPI register initialization component. Start with Memory validation EVK preset or tweak the configuration.
  3. Press on Open Validation View to start testing the configuration.
  4. Run available tests.
FCB - NOR validation
  1. Add a FCB component. Start with Memory validation EVK preset or tweak the configuration.
