MCUXpresso Config Tools v6 Now Available
petrstruzka
We are pleased to announce that MCUXpresso Config Tools v6 are now available.
MCUXpresso Configuration Tools is a product with set of tools that help users of all levels with a Cortex-M-based MCU solution.
Features
  • Available as Web, Desktop application and MCUXpresso IDE plug-ins
  • MCUXpresso SDK v2 support
  • Multicore support
  • GUI localized for English and Simplified Chinese
  • Mostly Connected: On-Demand device data download
  • Integrates with any compiler and IDE
  • Currently there are the following tools available:
Downloads
Overview of Changes - version 6
  • Only 64bit operating systems supported.
  • 'Update Code' now possible without an assigned toolchain project.
  • Removed dialog reporting changes between MEX and YAML in source code. The changes can be reviewed using Update Code DIFF.
  • Added "Help | Processor Information" menu option displays information about currently used processor.
  • Added Device Configuration tool, supports DCD (Device Configuration Data) commands configuration.
  • Added Trusted Execution Environment (TEE) tool.
  • Highlight changes implemented in generated code in Code preview view.
  • (MCUXpresso IDE only): Added Dark theme support
  • (MCUXpresso IDE only): Added SEMC (SDRAM) Validation tool, with RT1020 and RT1050 support.
  • Project Cloner in New Configuration Wizard: Added support for MCUxpresso SDK v2.6.x
  • Clocks tool: Run Mode and MCG Mode selection have been moved to Clocks Diagram and Clocks Table views.
  • Clocks tool: Added support for search by label in Clocks Diagram.
  • Peripherals tool: Added Support for 64bit (and more) values from user.
  • Peripherals tool: User can now migrate settings values from component already added to a configuration to another component, if mutually compatible (component redesigned etc.).
  • Peripherals tool: Documentation view history can now be navigated.
  • (MCUXpresso Config Tools only): Added Overview dialog on opening configuration for the first time
Community
MCUXpresso Config Tools Data
The Data for MCUXpresso Config Tools v6 was successfully deployed on the production system.
What’s new in data
The Data for MCUXpresso Config Tools v6 release provides following updates:
  1. Update of all supported processors data to support new features introduced in MCUXpresso Config Tools v6
  2. Update of Peripherals tool components to support SDK Release 10
  3. Various bug fixes and improvements
Supported processors, boards, kits and components
Processors:
Kinetis Kinetis2 LPC i.MX Other
MK02FN128xxx10 MKE18F256xxx16 LPC51U68 MCIMX7U3xxxxx GenericMQX
MK02FN64xxx10 MKE18F512xxx16 LPC54005 MCIMX7U5xxxxx QN908XC
MK10DN512xxx10 MKL02Z16xxx4 LPC54016 MIMX8MD6xxxHZ
MK10DX128xxx10 MKL02Z32xxx4 LPC54018 MIMX8MD6xxxJZ
MK10DX256xxx10 MKL02Z8xxx4 LPC54101J256 MIMX8MD7xxxHZ
MK11DN512Axxx5 MKL03Z16xxx4 LPC54101J512 MIMX8MD7xxxJZ
MK11DN512xxx5 MKL03Z32xxx4 LPC54102J256 MIMX8MM1xxxKZ
MK11DX128Axxx5 MKL03Z8xxx4 LPC54102J512 MIMX8MM1xxxLZ
MK11DX128xxx5 MKL13Z32xxx4 LPC54113J128 MIMX8MM2xxxKZ
MK11DX256Axxx5 MKL13Z64xxx4 LPC54113J256 MIMX8MM2xxxLZ
MK11DX256xxx5 MKL14Z32xxx4 LPC54114J256 MIMX8MM3xxxKZ
MK12DN512xxx5 MKL14Z64xxx4 LPC54605J256 MIMX8MM3xxxLZ
MK12DX128xxx5 MKL15Z128xxx4 LPC54605J512 MIMX8MM4xxxKZ
MK12DX256xxx5 MKL15Z32xxx4 LPC54606J256 MIMX8MM4xxxLZ
MK20DN512xxx10 MKL15Z64xxx4 LPC54606J512 MIMX8MM5xxxKZ
MK20DX128xxx10 MKL16Z128xxx4 LPC54607J256 MIMX8MM5xxxLZ
MK20DX256xxx10 MKL16Z256xxx4 LPC54607J512 MIMX8MM6xxxKZ
MK21DN512Axxx5 MKL16Z32xxx4 LPC54608J512 MIMX8MM6xxxLZ
MK21DN512xxx5 MKL16Z64xxx4 LPC54616J256 MIMX8MQ5xxxHZ
MK21DX128Axxx5 MKL17Z128xxx4 LPC54616J512 MIMX8MQ5xxxJZ
MK21DX128xxx5 MKL17Z256xxx4 LPC54618J512 MIMX8MQ6xxxHZ
MK21DX256Axxx5 MKL17Z32xxx4 LPC54628J512 MIMX8MQ6xxxJZ
MK21DX256xxx5 MKL17Z64xxx4 LPC54S005 MIMX8MQ7xxxHZ
MK21FN1M0Axxx12 MKL24Z32xxx4 LPC54S016 MIMX8MQ7xxxJZ
MK21FN1M0xxx12 MKL24Z64xxx4 LPC54S018 MIMXRT1015xxxxx
MK21FX512Axxx12 MKL25Z128xxx4 LPC55S66 MIMXRT1021xxxxx
MK21FX512xxx12 MKL25Z32xxx4 LPC55S69 MIMXRT1051xxxxB
MK22DN512xxx5 MKL25Z64xxx4 LPC802 MIMXRT1052xxxxB
MK22DX128xxx5 MKL26Z128xxx4 LPC804 MIMXRT1061xxxxA
MK22DX256xxx5 MKL26Z256xxx4 LPC810 MIMXRT1062xxxxA
MK22FN128xxx10 MKL26Z32xxx4 LPC811 MIMXRT1064xxxxA
MK22FN128xxx12 MKL26Z64xxx4 LPC812
MK22FN1M0Axxx12 MKL27Z128xxx4 LPC822
MK22FN1M0xxx12 MKL27Z256xxx4 LPC824
MK22FN256xxx12 MKL27Z32xxx4 LPC832
MK22FN512xxx12 MKL27Z64xxx4 LPC834
MK22FX512Axxx12 MKL28Z512xxx7 LPC844
MK22FX512xxx12 MKL33Z128xxx4 LPC845
MK24FN1M0xxx12 MKL33Z256xxx4 LPC8N04
MK24FN256xxx12 MKL33Z32xxx4
MK26FN2M0xxx18 MKL33Z64xxx4
MK27FN2M0Axxx15 MKL34Z64xxx4
MK27FN2M0xxx15 MKL36Z128xxx4
MK28FN2M0Axxx15 MKL36Z256xxx4
MK28FN2M0xxx15 MKL36Z64xxx4
MK30DN512xxx10 MKL43Z128xxx4
MK30DX128xxx10 MKL43Z256xxx4
MK30DX256xxx10 MKL46Z128xxx4
MK40DN512xxx10 MKL46Z256xxx4
MK40DX128xxx10 MKL82Z128xxx7
MK40DX256xxx10 MKM34Z256xxx7
MK50DN512xxx10 MKS20FN128xxx12
MK50DX256xxx10 MKS20FN256xxx12
MK51DN256xxx10 MKS22FN128xxx12
MK51DN512xxx10 MKS22FN256xxx12
MK51DX256xxx10 MKV10Z128xxx7
MK52DN512xxx10 MKV10Z16xxx7
MK53DN512xxx10 MKV10Z32xxx7
MK53DX256xxx10 MKV10Z64xxx7
MK60DN256xxx10 MKV11Z128xxx7
MK60DN512xxx10 MKV11Z64xxx7
MK60DX256xxx10 MKV30F128xxx10
MK63FN1M0xxx12 MKV30F64xxx10
MK64FN1M0xxx12 MKV31F128xxx10
MK64FX512xxx12 MKV31F256xxx12
MK65FN2M0xxx18 MKV31F512xxx12
MK65FX1M0xxx18 MKV42F128xxx16
MK66FN2M0xxx18 MKV42F256xxx16
MK66FX1M0xxx18 MKV42F64xxx16
MK80FN256xxx15 MKV44F128xxx16
MK82FN256xxx15 MKV44F256xxx16
MKE02Z16xxx4 MKV44F64xxx16
MKE02Z32xxx4 MKV46F128xxx16
MKE02Z64xxx4 MKV46F256xxx16
MKE04Z128xxx4 MKV56F1M0xxx24
MKE04Z64xxx4 MKV56F512xxx24
MKE04Z8xxx4 MKV58F1M0xxx24
MKE06Z128xxx4 MKV58F512xxx24
MKE06Z64xxx4 MKW21D256xxx5
MKE14F256xxx16 MKW21D512xxx5
MKE14F512xxx16 MKW21Z256xxx4
MKE14Z128xxx7 MKW21Z512xxx4
MKE14Z256xxx7 MKW22D512xxx5
MKE14Z32xxx4 MKW24D512xxx5
MKE14Z64xxx4 MKW31Z256xxx4
MKE15Z128xxx7 MKW31Z512xxx4
MKE15Z256xxx7 MKW35A512xxx4
MKE15Z32xxx4 MKW35Z512xxx4
MKE15Z64xxx4 MKW36A512xxx4
MKE16F256xxx16 MKW36Z512xxx4
MKE16F512xxx16 MKW41Z256xxx4
MKE16Z32xxx4 MKW41Z512xxx4
MKE16Z64xxx4
Boards
FRDM-K22F HVP-KV11Z75M MIMX8QM-MEK-REV-B
FRDM-K28F HVP-KV31F120M MIMX8QX-MEK-REV-B
FRDM-K28FA HVP-KV46F150M MIMXRT1015-EVK
FRDM-K64F HVP-KV58F MIMXRT1020-EVK
FRDM-K66F IMXRT1050-EVKB MIMXRT1060-EVK
FRDM-K82F LPC54018-IoT-Module MIMXRT1064-EVK
FRDM-KE02Z40M LPC54S018-IoT-Module QN908XCDK
FRDM-KE04Z LPC845BREAKOUT TWR-K21D50M
FRDM-KE06Z LPC8N04DevBoard TWR-K21F120M
FRDM-KE15Z LPCXpresso51U68 TWR-K22F120M
FRDM-KE16Z LPCXpresso54018 TWR-K24F120M
FRDM-KL02Z LPCXpresso54102 TWR-K60D100M
FRDM-KL03Z LPCXpresso54114 TWR-K64F120M
FRDM-KL25Z LPCXpresso54608 TWR-K65F180M
FRDM-KL26Z LPCXpresso54618 TWR-K80F150M
FRDM-KL27Z LPCXpresso54628 TWR-KE18F
FRDM-KL28Z LPCXpresso54S018 TWR-KL28Z72M
FRDM-KL43Z LPCXpresso55S69 TWR-KL43Z48M
FRDM-KL46Z LPCXpresso802 TWR-KL82Z72M
FRDM-KL82Z LPCXpresso804 TWR-KM34Z75M
FRDM-KV10Z LPCXpresso812 TWR-KV10Z32
FRDM-KV11Z LPCXpresso824 TWR-KV11Z75M
FRDM-KV31F LPCXpresso845 TWR-KV31F120M
FRDM-KW24 MAPS-KS22 TWR-KV46F150M
FRDM-KW36 MCIMX6ULL-EVK-REV-A-6ULZ TWR-KV58F220M
FRDM-KW41Z MCIMX7ULP-EVK-REV-B TWR-KW24D512
HEXIWEAR MIMX8M-EVK-REV-B USB-KW24D512
HVP-KE18F MIMX8MM-EVK-REV-C USB-KW41Z
Components
adc_12b1msps flexio_i2s pit
adc_etc flexio_spi qtmr
adc12 flexio_uart rit
adc16 ftm rnga
aoi gint rtc
cmp gpio rtwdog
cmt gpt sai
cop i2c sctimer
crc igpio semc
csi kpp sha
ctimer llwu snvs_hp
dac lpadc snvs_lp
dcp lpc_adc spdif
dma lpc_crc spi
dmic lpc_dma system
dspi lpc_gpio tempmon
edma lpc_i2c tpm
eeprom lpc_lcdc trng
elcdif lpc_rtc uart
enc lpi2c usb
ewm lpsci utick
flexbus lpspi vref
flexcan lptmr vspi
flexcomm_i2c lpuart vusart
flexcomm_i2s mcan wdog
flexcomm_spi mrt wdog01
flexcomm_usart pdb wwdt
flexio_i2c pint
