NFCナレッジベース
NFC Knowledge Base
ディスカッション
ソート順:
General recommendations for NFC (connected) Tags antennas    Track width -> 0.3 mm  Track spacing -> 0.15 mm / 0.2 mm (Dependent on the manufacturing process.) Copper thickness -> 35 µm Number of turns  Typically, the antenna inductance shall be lower than the maximum value determined by the IC's internal input capacitance. For example, with an internal capacitance of 50 pF, the maximum allowable inductance at 13.56 MHz is approximately 2.7 µH. If a 4-turn antenna results in 2 µH and a 5-turn antenna results in 3 µH, the 4-turn design should be selected. The antenna can then be accurately tuned to resonance using an external capacitor, providing sufficient tuning margin and compensating for component and manufacturing tolerances. Note: Based on practical experience, distributing the antenna turns across multiple PCB layers can increase the effective antenna area. For example, a 4-turn antenna may be implemented as 2 turns on the top layer and 2 turns on the bottom layer, which can improve coupling performance while maintaining the target inductance.    See the impact of the number of turns on the antenna Q factor:    General recommendations for NFC Controllers/Frontends    Track width -> 0.5 mm  Track spacing -> 0.15 mm / 0.2 mm (Dependent on the manufacturing process.) Copper thickness -> 35 µm Number of turns NXP typically recommends selecting the number of turns to achieve an antenna inductance of approximately 1 µH to 1.5 µH. Together with the trace geometry, the inductance determines the antenna Q factor. However, the exact Q factor is generally not critical, as it is typically adjusted using damping resistors during the matching process to achieve the required bandwidth Note: Distributing NFC Reader antenna turns across multiple PCB layers typically offers only marginal performance benefits, except in highly space-constrained designs such as miniature NFC or wireless charging antennas.
記事全体を表示
This article describes how to evaluate ULPCD feature together with PN7642 EVK (OM27642EVK) and NFC Cockpit.  1// Disable DC-DC in EEPROM  OM27642EVK does not required any HW changes for ULPCD (**). User is only required to change the following settings in EEPROM  (disable DC-DC converter). Address: 0x0000 (Secure_Lib_Config) Value: 0x21  Reset the board after writing the value.  **Note: To ensure an accurate and reliable ULPCD evaluation—particularly for ULPCD current measurements. We strongly recommend implementing the following hardware modifications on the OM27642EVK. Note: New revision of the board already have R4=DNP, R8=0Ω. Kindly check this on your board. 2//Set required ULPCD settings in EEPROM  ULPCD VDDPA -> Typically 1.5V. If the HF attenuator is 0x00, increase e.g. to 1.8V. Since the detection range does not significantly depend on the power level, there is no need to set VDDPA above 2 V. Higher VDDPA results in increased current consumption in ULPCD, but does not significantly improve detection performance. RF On Guard time -> This value can be reduced to the minimum -> 5.2 us RSSI Guard time -> Recommended value is 20-25 Try different RSSI Guard Time settings and evaluate the RSSI jitter as described here. The objective is to identify the Guard Time that minimizes RSSI jitter, ideally achieving a variation of only 1 to 2 RSSI units. RSSI Threshold -> Typically 4~6 Number of RSSI samples -> Typically -> 0 (4 rounds) Important note: If VDDPA is set to a value other than 1.5 V, special consideration is required.   See an example bellow:    3// Perform "Reads HF Attenuator"  Once the required ULPCD settings is set (Guard times, Threshold....). Then User has to perform "Reads HF Attenuator". Make sure that the "HF Attenuator" option is checked.  As written above, the value must not be 0x00. If so, increase VDDPA. 4// Perform ULPCD Calibration and check RSSI Value  For OM27642EVK, the RSSI value for unloaded antenna is typically around 1400dec - 1600dec. 5//Enter ULPCD mode  User can enter the ULPCD mode. The board will again be connected once the load change is detected (e.g. NFC card or smartphone in the antenna proximity). 6// Typical detection performance for 65 mm x 65 mm Antenna tuned to 35Ω.   MIFARE DESFire EV3: Class 1 Antenna  ICODE SLIX: Class 1 Antenna  ICODE 3: Class 6 Antenna
記事全体を表示
Introduction This document provides a guide on how to integrate the FRDM-MCXA156 as a host for the PN7160 using the examples provided in the “PN7160 NXP-NCI MCUXpresso Example Project” package. The hardware required to follow this guide is: FRDM-MCXA156 development board as host MCU. OM27160A1/OM27160B1 (PN7160 EVK) as the NFC controller. MCUxpresso for VS code extension Software setup. PN7160 NXP-NCI MCUXpresso Example Project version: 1.2 MCXN947 SDK version: 26.06 PN7160 version: 12.50.11. Hardware connections. When using OM27160B1 (SPI Host Interface): The FRDM-MCXA156 schematic document is available on this page. In the case of SPI connections, to use PN7160 directly with the Arduino headers a rework is needed for the FRDM because SDO(MOSI) and SS (Chip select) are not connected as default (as shown in the next figure). You should move R59 and R60 from pad 2 to pad 3 to enable these connections.   Note: You can connect the SPI pins available in Mikro bus header with jumpers, but in this example, the signals are routed through the pins enabled by the rework configuration. Once clarified this, these are the pins used in this example. Name PORT I2C0_SDA P0_16 I2C0_SCL P0_17 LPSPI1_SDI P2_16 LPSPI1_SDO P2_13 LPSPI1_SCK P2_12 LPSPI1_SS P2_6 IRQ P1_15 VEN P1_14 REQ P3_16   Software Changes   This section describes the software changes required to run an “NXP-NCI2.0” example with the MCXA156, which consists in a detection loop that displays in a terminal information (like UID, SAK, and Product Type for MIFARE product-based cards) about any tag detected by the PN7160. To begin the integration, we first need to import a hello_world project from the FRDM-MCXA156 SDK (v26.06.00) into MCUXpresso IDE for VS Code. For this purpose, download and install the FRDM-MCXA156 repository (version 26.06) using the extension available in the Quickstart panel by selecting Import Repository. For more information about this process, you can consult the corresponding guide. Importing NCI2.0 examples   Download the “PN7160 NXP-NCI MCUXpresso Example Project” zip from the product page and extract in a known folder. This will be useful for later use.  Importing base project   1. In the Quick Start panel click on “Import Example from Repository” in VS code. 2. Select “FRDM-MCXA156” in board setting.   3. In the template will search for the “hello_world” example, select Freestanding Applications, chose the location and click on “import”.   Importing SDK drivers   Once the project is added to the workspace we will need to add the required drivers, which are the SPI driver in case the OM27160B1HN is being used, or the I2C driver if the OM27160A1HN is being used. For this we need to add the following code in the prj.cfg file.   CONFIG_MCUX_COMPONENT_driver.lpi2c=y CONFIG_MCUX_COMPONENT_driver.lpspi=y Add the example source code to the newly created MCXA156 project Delete the hello_world.c of the project files folder of the MCXA156 project. From the “NXP-NCI2.0_iMXRT1170_examples” extracted just drag and drop in the project files folder the following files and folders.     When you drag and drop a file into VS code a window will appear asking whether you want to link the file or copy it. Please select “Copy files.”   The project folder should look like this:   After dragging and dropping all the files, the CMakeLists.txt file is automatically updated to include all the copied .c files. An example of this is shown below:   However, .h files are not automatically linked, so they must be added manually. Please copy and paste the following includes into the CMakeLists.txt file: mcux_add_include( BASE_PATH ${CMAKE_CURRENT_LIST_DIR} INCLUDES tool TML NfcLibrary/inc NfcLibrary/NdefLibrary/inc INCLUDES NfcLibrary/NxpNci20/inc . ) Preprocessor Interface macro Depending on the interface to be used to communicate with the PN7160, a preprocessor macro must be defined in the CMakelist.txt BOARD_NXPNCI_INTERFACE_SPI (For using SPI with OM27160B1) BOARD_NXPNCI_INTERFACE_I2C (For using I2C with OM27160A1) Additionally, it is necessary to add the macro called REMOVE_P2P_SUPPORT. Please make sure that this Macro is included. mcux_add_macro( CC "BOARD_NXPNCI_INTERFACE_I2C=1\ REMOVE_P2P_SUPPORT=1") Note: The following sections are exemplified using the SPI interface (BOARD_NXPNCI_INTERFACE_SPI macro).   After making the modifications described below, the interface used by the example can be changed simply by setting the macro to BOARD_NXPNCI_INTERFACE_I2C. Board definitions In the board.h file we will add the following definitions in order to refer to the different peripherals and clocks to be used, you can find this file in the following path: {PrjRootDirPath}\ frdmmcxa156\frdmmcxa156\board.h #ifdef BOARD_NXPNCI_INTERFACE_I2C #define BOARD_NXPNCI_I2C_CLOCK (CLOCK_GetLpi2cClkFreq(0U)) #define BOARD_NXPNCI_I2C_INSTANCE (LPI2C0) #define BOARD_NXPNCI_I2C_BAUDRATE (100000) #define BOARD_NXPNCI_I2C_ADDR (0x28) #endif #ifdef BOARD_NXPNCI_INTERFACE_SPI #define BOARD_NXPNCI_SPI_CLOCK (CLOCK_GetLpspiClkFreq(1U)) #define BOARD_NXPNCI_SPI_INSTANCE (LPSPI1) #define BOARD_NXPNCI_SPI_BAUDRATE (400000) #endif #define BOARD_NXPNCI_IRQ_PORT (GPIO1) #define BOARD_NXPNCI_VEN_PORT (GPIO1) #define BOARD_NXPNCI_DWL_PORT (GPIO3) #define BOARD_NXPNCI_IRQ_PIN (15U) #define BOARD_NXPNCI_VEN_PIN (14U) #define BOARD_NXPNCI_DWL_PIN (16U) Code modifications to the TML component In the source tml.c source file the following modifications are made, you can find this file in the following path: {{PrjRootDirPath }>frdmmcxa156_hello_world\TML static Status tml_Reset(void) { /* Set DWL_REQ low for NCI protocol */ GPIO_PortClear(BOARD_NXPNCI_DWL_PORT, 1U << BOARD_NXPNCI_DWL_PIN); GPIO_PortClear(BOARD_NXPNCI_VEN_PORT, 1U << BOARD_NXPNCI_VEN_PIN); Sleep(10); GPIO_PortSet(BOARD_NXPNCI_VEN_PORT, 1U << BOARD_NXPNCI_VEN_PIN); Sleep(10); return SUCCESS; } static void INTF_INIT(void) { lpspi_master_config_t masterConfig; LPSPI_MasterGetDefaultConfig(&masterConfig); masterConfig.baudRate = BOARD_NXPNCI_SPI_BAUDRATE; masterConfig.whichPcs = (lpspi_which_pcs_t) kLPSPI_Pcs1; masterXfer.configFlags = kLPSPI_MasterPcs1 | kLPSPI_MasterPcsContinuous | kLPSPI_MasterByteSwap; LPSPI_MasterInit(BOARD_NXPNCI_SPI_INSTANCE, &masterConfig, BOARD_NXPNCI_SPI_CLOCK); } static Status tml_Init(void) { gpio_pin_config_t in_config = {kGPIO_DigitalInput, 0}; gpio_pin_config_t out_config = {kGPIO_DigitalOutput, 0}; GPIO_PinInit(BOARD_NXPNCI_IRQ_PORT, BOARD_NXPNCI_IRQ_PIN, &in_config); GPIO_PinInit(BOARD_NXPNCI_VEN_PORT, BOARD_NXPNCI_VEN_PIN, &out_config); GPIO_PinInit(BOARD_NXPNCI_DWL_PORT, BOARD_NXPNCI_DWL_PIN, &out_config); INTF_INIT(); return SUCCESS; } static Status tml_DeInit(void) { GPIO_PortClear(BOARD_NXPNCI_VEN_PORT, 1U << BOARD_NXPNCI_VEN_PIN); return SUCCESS; } Code modifications for ports, pins and clocks initialization In the file “hardware_init.c” in the board folder of the project, write the following function as shown, in order to add port and clock peripheral initializations. /* * Copyright 2024 NXP * * SPDX-License-Identifier: BSD-3-Clause */ /*${header:start}*/ #include "pin_mux.h" #include "fsl_clock.h" #include "fsl_reset.h" #include "board.h" #include <stdbool.h> /*${header:end}*/ /*${function:start}*/ void BOARD_InitHardware(void) { CLOCK_SetClockDiv(kCLOCK_DivLPI2C0, 1u); CLOCK_AttachClk(kFRO12M_to_LPI2C0); CLOCK_SetClockDiv(kCLOCK_DivLPSPI1, 1u); CLOCK_AttachClk(kFRO12M_to_LPSPI1); BOARD_InitPins(); BOARD_InitBootClocks(); BOARD_InitDebugConsole(); } /*${function:end}*/ In the pin_mux.c file modifies the function called BOARD_InitPins(); accordingly, this file can be seen in the following path: {PrjRootDirPath}\ frdmmcxa156\hello_world \pin_mux.c   void BOARD_InitPins(void) { CLOCK_EnableClock(kCLOCK_GateGPIO1); /* GPIO3: Peripheral clock is enabled */ CLOCK_EnableClock(kCLOCK_GateGPIO3); /* PORT0: Peripheral clock is enabled */ CLOCK_EnableClock(kCLOCK_GatePORT0); CLOCK_EnableClock(kCLOCK_GatePORT1); CLOCK_EnableClock(kCLOCK_GatePORT2); CLOCK_EnableClock(kCLOCK_GatePORT3); /* GPIO1 peripheral is released from reset */ RESET_ReleasePeripheralReset(kGPIO1_RST_SHIFT_RSTn); /* GPIO3 peripheral is released from reset */ RESET_ReleasePeripheralReset(kGPIO3_RST_SHIFT_RSTn); RESET_ReleasePeripheralReset(kLPUART0_RST_SHIFT_RSTn); RESET_ReleasePeripheralReset(kPORT0_RST_SHIFT_RSTn); RESET_ReleasePeripheralReset(kLPSPI0_RST_SHIFT_RSTn); RESET_ReleasePeripheralReset(kPORT1_RST_SHIFT_RSTn); RESET_ReleasePeripheralReset(kLPSPI1_RST_SHIFT_RSTn); RESET_ReleasePeripheralReset(kPORT3_RST_SHIFT_RSTn); RESET_ReleasePeripheralReset(kPORT2_RST_SHIFT_RSTn); const port_pin_config_t port0_2_pin78_config = {/* Internal pull-up resistor is enabled */ kPORT_PullUp, /* Low internal pull resistor value is selected. */ kPORT_LowPullResistor, /* Fast slew rate is configured */ kPORT_FastSlewRate, /* Passive input filter is disabled */ kPORT_PassiveFilterDisable, /* Open drain output is disabled */ kPORT_OpenDrainDisable, /* Low drive strength is configured */ kPORT_LowDriveStrength, /* Normal drive strength is configured */ kPORT_NormalDriveStrength, /* Pin is configured as LPUART0_RXD */ kPORT_MuxAlt2, /* Digital input enabled */ kPORT_InputBufferEnable, /* Digital input is not inverted */ kPORT_InputNormal, /* Pin Control Register fields [15:0] are not locked */ kPORT_UnlockRegister}; /* PORT0_2 (pin 78) is configured as LPUART0_RXD */ PORT_SetPinConfig(PORT0, 2U, &port0_2_pin78_config); const port_pin_config_t port0_3_pin79_config = {/* Internal pull-up resistor is enabled */ kPORT_PullUp, /* Low internal pull resistor value is selected. */ kPORT_LowPullResistor, /* Fast slew rate is configured */ kPORT_FastSlewRate, /* Passive input filter is disabled */ kPORT_PassiveFilterDisable, /* Open drain output is disabled */ kPORT_OpenDrainDisable, /* Low drive strength is configured */ kPORT_LowDriveStrength, /* Normal drive strength is configured */ kPORT_NormalDriveStrength, /* Pin is configured as LPUART0_TXD */ kPORT_MuxAlt2, /* Digital input enabled */ kPORT_InputBufferEnable, /* Digital input is not inverted */ kPORT_InputNormal, /* Pin Control Register fields [15:0] are not locked */ kPORT_UnlockRegister}; /* PORT0_3 (pin 79) is configured as LPUART0_TXD */ PORT_SetPinConfig(PORT0, 3U, &port0_3_pin79_config); const port_pin_config_t port2_13_pin35_config = { kPORT_PullDisable, kPORT_LowPullResistor, kPORT_FastSlewRate, kPORT_PassiveFilterDisable, kPORT_OpenDrainDisable, kPORT_LowDriveStrength, kPORT_NormalDriveStrength, /* Pin is configured as LPSPI1_SDO */ kPORT_MuxAlt2, kPORT_InputBufferEnable, kPORT_InputNormal, kPORT_UnlockRegister}; PORT_SetPinConfig(PORT2, 13U, &port2_13_pin35_config); const port_pin_config_t port2_12_pin34_config = { kPORT_PullDisable, kPORT_LowPullResistor, kPORT_FastSlewRate, kPORT_PassiveFilterDisable, kPORT_OpenDrainDisable, kPORT_LowDriveStrength, kPORT_NormalDriveStrength, /* Pin is configured as LPSPI1_SCK */ kPORT_MuxAlt2, kPORT_InputBufferEnable, kPORT_InputNormal, kPORT_UnlockRegister}; PORT_SetPinConfig(PORT2, 12U, &port2_12_pin34_config); const port_pin_config_t port2_16_pin37_config = { kPORT_PullDisable, kPORT_LowPullResistor, kPORT_FastSlewRate, kPORT_PassiveFilterDisable, kPORT_OpenDrainDisable, kPORT_LowDriveStrength, kPORT_NormalDriveStrength, /* Pin is configured as LPSPI1_SDI */ kPORT_MuxAlt2, kPORT_InputBufferEnable, kPORT_InputNormal, kPORT_UnlockRegister}; PORT_SetPinConfig(PORT2, 16U, &port2_16_pin37_config); const port_pin_config_t port2_6_pin28_config = { kPORT_PullDisable, kPORT_LowPullResistor, kPORT_FastSlewRate, kPORT_PassiveFilterDisable, kPORT_OpenDrainDisable, kPORT_LowDriveStrength, kPORT_NormalDriveStrength, /* Pin is configured as LPSPI1_PCS0 */ kPORT_MuxAlt2, kPORT_InputBufferEnable, kPORT_InputNormal, kPORT_UnlockRegister}; PORT_SetPinConfig(PORT2, 6U, &port2_6_pin28_config); const port_pin_config_t port1_15_pin8_config = { kPORT_PullDisable, kPORT_LowPullResistor, kPORT_FastSlewRate, kPORT_PassiveFilterDisable, kPORT_OpenDrainDisable, kPORT_LowDriveStrength, kPORT_NormalDriveStrength, /* Pin is configured as GPIO1 15 */ kPORT_MuxAlt0, kPORT_InputBufferEnable, kPORT_InputNormal, kPORT_UnlockRegister}; PORT_SetPinConfig(PORT1, 15U, &port1_15_pin8_config); const port_pin_config_t port1_14_pin7_config = { kPORT_PullUp, kPORT_LowPullResistor, kPORT_FastSlewRate, kPORT_PassiveFilterDisable, kPORT_OpenDrainDisable, kPORT_LowDriveStrength, kPORT_NormalDriveStrength, /* Pin is configured as GPIO1 14 */ kPORT_MuxAlt0, kPORT_InputBufferEnable, kPORT_InputNormal, kPORT_UnlockRegister}; PORT_SetPinConfig(PORT1, 14U, &port1_14_pin7_config); const port_pin_config_t port3_16_pin59_config = { kPORT_PullUp, kPORT_LowPullResistor, kPORT_FastSlewRate, kPORT_PassiveFilterDisable, kPORT_OpenDrainDisable, kPORT_LowDriveStrength, kPORT_NormalDriveStrength, /* Pin is configured as GPIO3 16 */ kPORT_MuxAlt0, kPORT_InputBufferEnable, kPORT_InputNormal, kPORT_UnlockRegister}; PORT_SetPinConfig(PORT3, 16U, &port3_16_pin59_config); const port_pin_config_t port0_16_pin83_config = { kPORT_PullDisable, kPORT_LowPullResistor, kPORT_FastSlewRate, kPORT_PassiveFilterDisable, kPORT_OpenDrainDisable, kPORT_LowDriveStrength, kPORT_NormalDriveStrength, /* Pin is configured as LPI2C0 SDA */ kPORT_MuxAlt2, kPORT_InputBufferEnable, kPORT_InputNormal, kPORT_UnlockRegister}; PORT_SetPinConfig(PORT0, 16U, &port0_16_pin83_config); const port_pin_config_t port0_17_pin84_config = { kPORT_PullDisable, kPORT_LowPullResistor, kPORT_FastSlewRate, kPORT_PassiveFilterDisable, kPORT_OpenDrainDisable, kPORT_LowDriveStrength, kPORT_NormalDriveStrength, /* Pin is configured as LPI2C0 SCL */ kPORT_MuxAlt2, kPORT_InputBufferEnable, kPORT_InputNormal, kPORT_UnlockRegister}; PORT_SetPinConfig(PORT0, 17U, &port0_17_pin84_config); } Configure the main.c as follows: #include <stdio.h> #include <string.h> #include "board.h" #include "app.h" #include "pin_mux.h" #include "fsl_debug_console.h" extern void nfc_example (void); int main(void) { BOARD_InitHardware(); #ifdef BOARD_NXPNCI_INTERFACE_I2C PRINTF("\nRunning the NXP-NCI2.0 example (I2C interface)\n"); #else PRINTF("\nRunning the NXP-NCI2.0 example (SPI interface)\n"); #endif nfc_example(); } Building and Debugging the example For building the example, please click on this button and if you followed this guide accordingly the project should compile without errors:   Open a serial terminal such as Teraterm with the following settings:  Start a debug session by clicking this button: Once running, the example should look as follows:  When tapping a card on the antenna, the card information will be shown:
記事全体を表示
Introduction. This document provides a guide for using the PN5190 NFC frontend with the FRDM-MCXN947 development board and the NFC Reader Library in the MCUxpresso for VS code extension. The hardware required to follow this guide is: FRDM-MCXN947 development board as host MCU. PNEV5190BP (based on PN5190) as the NFC transceiver Software Setup. MCXN947 SDK version: 26.06.00 NFCReaderLibrary version: 07.16.00 PN5190 FW version: 0x20D Hardware connections. The PNEV5190 comes with a Kinetis K82F as a host MCU to drive the PN5190 To enable SPI communication between the MCXN947 and the PN5190, the PNEV5190 board must be prepared as follows: Power up board correctly Enable external SPI pins Disable K82F interface with PN5190 Power up and jumper configuration To correctly power up the board.: – Powering it up over USB does not provide enough current. It will be powered with an external power supply of 7.5V over connector J17. Put jumper on following pins: – J9 2-3: External power supply – J8: VBATPWR supplied with VBAT=3.3 V – J12: VBAT supplied with 3.3 V Remove jumpers on following pins: – J22, J23: open SDA signals for K82F – J19: RTS push-button bypass for K82F – J3, J4, J5, J6: pull down jumpers for NFC module signals Set GPIO and SPI voltage to 3.3 V: supplying 3.3 V to VDDIO and the μC supply: – Remove short circuit on R19 – Place short circuit on R20 For any additional configuration, please see PNEV5190B evaluation board quick start guide. Location of the changes mentioned above can be seen in the following image:   Routing NFC module communication pins to JP1 To enable the pins on JP1 for communication, we must enable bus switch U10 and disable bus switch U12 in the NFC Host Interface. These switches enable or disable the connections from K82 to PN5190 SPI pins, and expose the SPI interface to an external host. Remove short on R5 to disable communication routing to K82F. Place short on R7 to enable communication routing to JP1 pins.   For FRDM-MCXN947 side, no modifications are necessary.  The pins used are available in Header J1 and J2. Which are shown in the following table.     Name MCXN947 PN5190 SCK J2.12 JP1.1 MOSI J2.8 JP1.2 MISO J2.10 JP1.3 SSEL J2.6 JP1.4 IRQ J1.16 JP1.5 RESET J2.2 JP6.1 GND J2.14 JP1.10 SUCCESS J2.17*   FAIL J2.15*   DWL J2.13*   * Pins that need to be configured for library compatibility but are not used and do not need to be connected.     Software Changes   This section describes the software changes required to run the NfcrdlibEx1_DiscoveryLoop example from the NFC Reader Library. This example implements a detection loop that displays information about any tag detected by the PN5190 in a terminal, such as the UID, SAK, and Product Type for MIFARE-based cards. Please download the NFC Reader Library for the PN5190 from NFC Reader Library | NXP Semiconductors. To begin the integration, we first need to import a hello_world project from the FRDM-MCXN947 SDK (v26.06.00) into MCUXpresso IDE for VS Code. For this purpose, download and install the FRDM-MCXN947 repository (version 26.06) using the extension available in the Quickstart panel by selecting Import Repository. For more information about this process, please refer to the corresponding user guide. Importing NFC Reader library.   Download the “NFC Reader Library” zip from the product page and extract in a known folder. This will be useful for later use.  If available, please use the latest version of the NFC Reader Library. Importing base project   1. In the Quick Start panel click on “Import Example from Repository” in VS code.   2. Select “FRDM-MCXN947” in board setting. 3. In the template will search for the “freertos_hello_cm33_core0” example, select Freestanding Application, chose the location and click on “import”. Importing SDK drivers   Once the project is added to the workspace we will need to add the required drivers, which are SPI, CTIMER and CMSIS drivers. For this we need to add the following code in the prj.cfg file.   CONFIG_MCUX_COMPONENT_driver.lpflexcomm_lpspi=y CONFIG_MCUX_COMPONENT_driver.ctimer=y CONFIG_MCUX_COMPONENT_driver.CMSIS=y Add the source code Discovery Loop Example   Firstly, delete the file freertos_hello.c created by the project. From the “NxpNfcRdLib_PN5190_v07.16.00_PUB” extracted, find and drag and drop the following files on in the project files folder: NfcrdlibEx1_EmvcoProfile.c, phApp_Helper.c, phApp_Init.c, phApp_PN5190_Init.c. You can find these files in the following path: {NxpNfcRdLibRoot} \Examples\NfcrdlibEx1_DiscoveryLoop\src   When you drag and drop a file into VS code a window will appear asking whether you want to link the file or copy it. Please select “Copy files.”   After dragging and dropping any file, the CMakeLists.txt file is automatically updated to include all the copied .c files. If you selected all these files, the generated code will appear as follows:   Additionally, we need to add the file “NfcrdlibEx1_DiscoveryLoop.c” which is the main source file of the project, to achieve this also please drag and drop in the project files folder. At this point, the project should look like this:        Add the example source code to the newly created MCXN947 project   From the “NxpNfcRdLib_PN5190_v07.14.00_PUB” extracted just drag and drop in the project files folder the following folders.     Once these folders are added the project should look like this:   Define FRDM-MCXN947 SDK preprocessor symbol   We need to make some changes to the compiler preprocessor configuration related to the NFC reader library, to do this we need to modify the Cmakelist.txt PH_OSAL_FREERTOS PHDRIVER_FRDMMCXN947_PN5190_BOARD NXPBUILD_CUSTOMER_HEADER_INCLUDED PHDRIVER_MCXN947_SPI_POLLING   mcux_add_macro( CC"NXPBUILD_CUSTOMER_HEADER_INCLUDED\ PHDRIVER_FRDMMCXN947_PN5190_BOARD\ PH_OSAL_FREERTOS\ PHDRIVER_MCXN947_SPI_POLLING" ) These symbols are added so the preprocessor knows which header files to include at build time. PHDRIVER_FRDMMCXN947_PN5190_BOARD will help include the BoardSelection.h header, the file that is going to define addresses for registers and peripherals of MCXN947. PH_OSAL_FREERTOS will include headers related to OS operation, meaning that the project will work with operative system (at the end of this guide you will find the steps to add NULLOS support). NXPBUILD_CUSTOMER_HEADER_INCLUDED will add headers to add and select the NFC reader and host that will be used in the project. PHDRIVER_MCXN947_SPI_POLLING: if is defined the example will perform SPI communication by polling method, and if not, will be perform through non-blocking transfers. Modifying the Driver Abstraction Layer (DAL)   The added folder DAL will contain the important changes to be able to use the MCXN947 as host device since it will contain all the changes regarding SPI, timer and GPIO configurations required by the library to work properly. Board_FRDM_MCXN947_PN5190.h We need to create a header file that will contain important macros used by the library that are related to the host specific SPI, timer and GPIO peripherals, as well as interrupt vectors and priorities, clock sources and addresses. This file is required to be inside the “boards” folder which is inside DAL. 1. Go to explorer window and select “add file” on the boards folder:   2. Write the file’s name as follows (Board_FRDM_MCXN947_PN5190.h) and click enter:   A window like the one shown in the following figure will appear. However, it can be discarded. This window is intended to add the newly created file to the CMakeLists.txt file, but we will instead include the entire folder later.   Inside this file, some important macros related to the SPI peripheral and the important pins to be handled (IRQ, Chip Select, Reset) are defined.   #ifndef DAL_BOARDS_BOARD_FRDM_MCXN947_PN5190_H_ #define DAL_BOARDS_BOARD_FRDM_MCXN947_PN5190_H_ #define GPIO_PORT 0 #define GPIO_PORT1 1 /****************************************************************** * LPSPI clock configuration ******************************************************************/ /*Clock Frequency for SPI Flexcomm 1*/ #define SPI_CLOCK_FREQ (CLOCK_GetLPFlexCommClkFreq(1u)) #define SPI_MASTER_CLOCK_FREQ SPI_CLOCK_FREQ /****************************************************************** * Board Pin/Gpio configurations ******************************************************************/ #define PHDRIVER_PIN_RESET ((GPIO_PORT << 8) | 28) /**< Reset pin, Pin28, PIO0_28 */ #define PHDRIVER_PIN_IRQ ((GPIO_PORT << 8) | 31) /**< IRQ pin, Pin10, PIO0_10 */ /* For 5190 busy is same as IRQ */ #define PHDRIVER_PIN_BUSY ((GPIO_PORT << 8) | 31) /**< IRQ pin, Pin31, PIO0_31 */ #define PHDRIVER_PIN_DWL ((GPIO_PORT << 8) | 19) /**< Download pin, Pin19, PIO0_19*/ /* These pins are used for EMVCo Interoperability test status indication, * not for the generic Reader Library implementation. */ #define PHDRIVER_PIN_SUCCESS ((GPIO_PORT1 << 8) | 0) /**< GPIO, Port 1, Pin0 */ #define PHDRIVER_PIN_FAIL ((GPIO_PORT1 << 8) | 1) /**< GPIO, Port 1, Pin1 */ /****************************************************************** * PIN Pull-Up/Pull-Down configurations. ******************************************************************/ #define PHDRIVER_PIN_RESET_PULL_CFG PH_DRIVER_PULL_UP #define PHDRIVER_PIN_IRQ_PULL_CFG PH_DRIVER_PULL_DOWN #define PHDRIVER_PIN_WKUP_PULL_CFG PH_DRIVER_PULL_UP #define PHDRIVER_PIN_CLK_PULL_CFG PH_DRIVER_PULL_UP #define PHDRIVER_PIN_DWL_PULL_CFG PH_DRIVER_PULL_UP #define PHDRIVER_PIN_NSS_PULL_CFG PH_DRIVER_PULL_UP #define PHDRIVER_PIN_BUSY_PULL_CFG PH_DRIVER_PULL_UP We define the macros as well for the interrupt vector of MCXN947, its priority, handler and trigger type.   /****************************************************************** * IRQ PIN NVIC settings ******************************************************************/ #define EINT_IRQn GPIO00_IRQn /*Adding interrupt vector A of GPIO*/ #define EINT_PRIORITY 7 /*Default interrupt priority for GPIO*/ #define CLIF_IRQHandler GPIO00_IRQHandler /*Interrupt handler for vector A*/ #define PIN_IRQ_TRIGGER_TYPE PH_DRIVER_INTERRUPT_RISINGEDGE /*Rising edge Trigger*/ As well as some macros for pin logic levels. /***************************************************************** * Front End Reset logic level settings ****************************************************************/ #define PH_DRIVER_SET_HIGH 1 /**< Logic High. */ #define PH_DRIVER_SET_LOW 0 /**< Logic Low. */ #define RESET_POWERDOWN_LEVEL PH_DRIVER_SET_LOW #define RESET_POWERUP_LEVEL PH_DRIVER_SET_HIGH Finally, we define macros for the base address of CTIMER and SPI peripherals, clock frequencies, interrupt vectors and related pins.   /***************************************************************** * SPI Configuration ****************************************************************/ #define PHDRIVER_MCXN947_SPI_MASTER LPSPI1 #define PHDRIVER_MCXN947_SPI_DATA_RATE 5000000U #define PHDRIVER_MCXN947_SPI_CLK_SRC SPI_MASTER_CLOCK_FREQ #define PHDRIVER_MCXN947_SPI_IRQ LP_FLEXCOMM1_IRQn #define SPI_IRQ_PRIORITY 6 /*SPI interrupt priority*/ #define PHDRIVER_PIN_SSEL 27U/* Chip Select, Pin6, SPI */ #define PHDRIVER_PIN_SCK 25U/* SPI clock, Pin7, SPI */ #define PHDRIVER_PIN_MISO 26U/* MISO, Pin8, SPI */ #define PHDRIVER_PIN_MOSI 24U/* MOSI, Pin9, SPI */ #define PHDRIVER_FC1_SPI_DIV kCLOCK_DivFlexcom1Clk #define PHDRIVER_FC1_SPI_CLK kFRO12M_to_FLEXCOMM1 /*Clock to attach to Flexcomm1*/ /***************************************************************** * Timer Configuration ****************************************************************/ #define PH_DRIVER_SDK_CTIMER CTIMER0 /*CTIMER0 base*/ #define PH_DRIVER_SDK_CTIMER_CLK kCLOCK_DivCtimer0Clk/*CTIMER0 clock*/ #define PH_DRIVER_SDK_CTIMER_NVIC CTIMER0_IRQn /*Interrupt vector*/ #define PH_DRIVER_SDK_CTIMER_PRIORITY 4 #define PH_DRIVER_SDK_CTIMER_CLK_FREQ CLOCK_GetCTimerClkFreq(0U) /*CTIMER0 Clock frequency*/ #endif /* DAL_BOARDS_BOARD_FRDM_MCXN947_PN5190_H_ */ MCXN947 SPI and SDK files  Now, inside DAL > src folder we will create a folder named “MCXN947” that will contain 2 source files: phbalReg_Mcxn947Spi.c phDriver_Mcxn947SDK.c 1. Firstly, we will need to delete the “KinetisSDK” folder located in the src folder to avoid multiple definition issues. Please right-click on src/KinetisSDK and click on “Delete”:   2. A window as the following figure will appear, please click on “Move to Recycle Bin”:   3. In the same folder please right-click and click on “New folder…”:   4. Write the folder’s name as follows (MCXN947) and click enter:   5. Add both files following the same steps mentioned in the section Board_FRDM_MCXN947_PN5190.h but with those files (phbalReg_Mcxn947Spi.c and phDriver_Mcxn947SDK.c). We will add these source files in the CMake_List.txt on the next step. Once these files are added the src folder should look like this: 6. Finally, we will add both files to the CMakeLists.txt file so they are included in the compilation process. Please add the following code in the CMake_list.txt file:   mcux_add_source(BASE_PATH ${CMAKE_CURRENT_LIST_DIR} SOURCES "DAL/src/MCXN947/phbalReg_Mcxn947Spi.c" "DAL/src/MCXN947/phDriver_Mcxn947SDK.c") Although the Kinetis SDK folder has been deleted, it is still referenced in the CMakeLists.txt file. Please remove those includes from this file. Now, we will return to the MCUXpresso extension. Within these source files, we will modify the functions inherited from other board host implementations, replacing them with configurations specific to the MCXN947 peripheral drivers, including SPI, timers, GPIOs, and interrupt handlers. These modifications are based on SDK examples such as ctimer_match_interrupt_example_cm33_core0 and lpspi_polling_b2b_transfer_master_cm33_core0. phbalReg_Mcxn947Spi.c: In this file we first need to include the necessary files and include the headers and callbacks to ensure the correct functionality: #include "phDriver.h" #include <board.h> #include "BoardSelection.h" #include <fsl_lpspi.h> #include <fsl_clock.h> #include <fsl_port.h> #define PHBAL_REG_MCXN947_SPI_ID 0x0FU /**< ID for MCXN947 SPI BAL component */ #define RX_BUFFER_SIZE_MAX 272U /* Receive Buffer size while exchange */ #ifndef PHDRIVER_MCXN947_SPI_POLLING lpspi_master_handle_t g_masterHandle; /* LPSPI user callback */ void LPSPI_MasterUserCallback(LPSPI_Type *base, lpspi_master_handle_t *handle, status_t status, void *userData); #endif static void phbalReg_Mcxn947SpiConfig(void); #ifndef PHDRIVER_MCXN947_SPI_POLLING volatile bool isTransferCompleted = false; void LPSPI_MasterUserCallback(LPSPI_Type *base, lpspi_master_handle_t *handle, status_t status, void *userData) { if (status == kStatus_Success) { __NOP(); } isTransferCompleted = true; } #endif After, we will define the phbalReg_Init function, which will be used by the library to initialize the SPI peripheral in this case, and it is defined as follows:   /** * \brief Initialize the Rw612 SPI BAL layer. * * \return Status code * \retval #PH_DRIVER_SUCCESS Operation successful. * \retval #PH_ERR_INVALID_DATA_PARAMS Parameter structure size is invalid. */ phStatus_t phbalReg_Init( void * pDataParams, uint16_t wSizeOfDataParams) { lpspi_master_config_t userConfig; uint32_t srcFreq = 0; if((pDataParams == NULL) || (sizeof(phbalReg_Type_t) != wSizeOfDataParams)) { return (PH_DRIVER_ERROR | PH_COMP_DRIVER); } ((phbalReg_Type_t *)pDataParams)->wId = PH_COMP_DRIVER | PHBAL_REG_MCXN947_SPI_ID; ((phbalReg_Type_t *)pDataParams)->bBalType = PHBAL_REG_TYPE_SPI; /*Initialize Flexcomm1 clock*/ /* attach FRO 12M to FLEXCOMM1 */ CLOCK_SetClkDiv(PHDRIVER_FC1_SPI_DIV, 1u); CLOCK_AttachClk(PHDRIVER_FC1_SPI_CLK); /*Configure SPI pins*/ phbalReg_Mcxn947SpiConfig(); /*SPI configuration*/ LPSPI_MasterGetDefaultConfig(&userConfig); userConfig.baudRate = PHDRIVER_MCXN947_SPI_DATA_RATE; srcFreq = SPI_MASTER_CLOCK_FREQ; userConfig.whichPcs = (lpspi_which_pcs_t)kLPSPI_Pcs0; userConfig.pcsActiveHighOrLow = (lpspi_pcs_polarity_config_t)kLPSPI_PcsActiveLow; userConfig.pcsToSckDelayInNanoSec = 1000000000U / (userConfig.baudRate * 1U); userConfig.lastSckToPcsDelayInNanoSec = 1000000000U / (userConfig.baudRate * 1U); userConfig.betweenTransferDelayInNanoSec = 1000000000U / (userConfig.baudRate * 1U); /*Initialize SPI*/ #ifdef PHDRIVER_MCXN947_SPI_POLLING LPSPI_MasterInit(PHDRIVER_MCXN947_SPI_MASTER, &userConfig, srcFreq); #else LPSPI_MasterInit(PHDRIVER_MCXN947_SPI_MASTER, &userConfig, srcFreq); LPSPI_MasterTransferCreateHandle(PHDRIVER_MCXN947_SPI_MASTER, &g_masterHandle, LPSPI_MasterUserCallback, NULL); #endif return PH_DRIVER_SUCCESS; } We have to define the phbalReg_Exchange function as well, which is used for communicating via SPI with the PN5190.   phStatus_t phbalReg_Exchange( void * pDataParams, uint16_t wOption, uint8_t * pTxBuffer, uint16_t wTxLength, uint16_t wRxBufSize, uint8_t * pRxBuffer, uint16_t * pRxLength ) { phStatus_t status = PH_DRIVER_SUCCESS; uint8_t * pRxBuf; status_t lpspiStatus; lpspi_transfer_t g_masterXfer; uint8_t g_dummyBuffer[RX_BUFFER_SIZE_MAX]; if(pRxBuffer == NULL) { pRxBuf = g_dummyBuffer; } else { pRxBuf = pRxBuffer; } if(pTxBuffer == NULL) { wTxLength = wRxBufSize; g_dummyBuffer[0] = 0xFF; pTxBuffer = g_dummyBuffer; } memset(&g_masterXfer, 0, sizeof(lpspi_transfer_t)); /* Set up the transfer */ g_masterXfer.txData = pTxBuffer; g_masterXfer.rxData = pRxBuf; g_masterXfer.dataSize = wTxLength; g_masterXfer.configFlags = kLPSPI_MasterPcs0 | kLPSPI_MasterPcsContinuous | kLPSPI_MasterByteSwap; /* Start transfer */ #ifdef PHDRIVER_MCXN947_SPI_POLLING lpspiStatus = LPSPI_MasterTransferBlocking(PHDRIVER_MCXN947_SPI_MASTER, &g_masterXfer); #else lpspiStatus = LPSPI_MasterTransferNonBlocking(PHDRIVER_MCXN947_SPI_MASTER, &g_masterHandle, &g_masterXfer); /* Wait transfer complete */ while (!isTransferCompleted) { } #endif if (lpspiStatus != kStatus_Success) { return (PH_DRIVER_FAILURE | PH_COMP_DRIVER); } if (pRxLength != NULL) { *pRxLength = wTxLength; } #ifndef PHDRIVER_MCXN947_SPI_POLLING SDK_DelayAtLeastUs(300U, BOARD_BOOTCLOCKPLL150M_CORE_CLOCK); #endif return status; } Finally, we will define the phbalReg_Mcxn947SpiConfig function, which is called by phbalReg_Init to configure the SPI pins on the MCXN947:   static void phbalReg_Mcxn947SpiConfig(void) { const port_pin_config_t port0_24_pinB6_config = { kPORT_PullUp, kPORT_LowPullResistor, kPORT_SlowSlewRate, kPORT_PassiveFilterDisable, kPORT_OpenDrainDisable, kPORT_LowDriveStrength, /* Pin is configured as FC1_P0 */ kPORT_MuxAlt2, kPORT_InputBufferEnable, kPORT_InputNormal, kPORT_UnlockRegister}; /* PORT0_24 (pin B6) is configured as SPI_MOSI */ PORT_SetPinConfig(PORT0, 24U, &port0_24_pinB6_config); const port_pin_config_t port0_25_pinA6_config = { kPORT_PullUp, kPORT_LowPullResistor, kPORT_SlowSlewRate, kPORT_PassiveFilterDisable, kPORT_OpenDrainDisable, kPORT_LowDriveStrength, /* Pin is configured as FC1_P1 */ kPORT_MuxAlt2, kPORT_InputBufferEnable, kPORT_InputNormal, kPORT_UnlockRegister}; /* PORT0_25 (pin A6) is configured as SPI_SCK */ PORT_SetPinConfig(PORT0, 25U, &port0_25_pinA6_config); const port_pin_config_t port0_26_pinF10_config = { kPORT_PullUp, kPORT_LowPullResistor, kPORT_SlowSlewRate, kPORT_PassiveFilterDisable, kPORT_OpenDrainDisable, kPORT_LowDriveStrength, /* Pin is configured as FC1_P2 */ kPORT_MuxAlt2, kPORT_InputBufferEnable, kPORT_InputNormal, kPORT_UnlockRegister}; /* PORT0_26 (pin F10) is configured as SPI_MISO */ PORT_SetPinConfig(PORT0, 26U, &port0_26_pinF10_config); const port_pin_config_t port0_27_pinE10_config = { kPORT_PullUp, kPORT_LowPullResistor, kPORT_SlowSlewRate, kPORT_PassiveFilterDisable, kPORT_OpenDrainDisable, kPORT_LowDriveStrength, /* Pin is configured as FC1_P3 */ kPORT_MuxAlt2, kPORT_InputBufferEnable, kPORT_InputNormal, kPORT_UnlockRegister}; /* PORT0_27 (pin E10) is configured as SPI_CS */ PORT_SetPinConfig(PORT0, 27U, &port0_27_pinE10_config); } phDriver_Mcxn947SDK.c: In this file we will have the following definitions and includes that describe relevant characteristics of the ctimer (configuration structures, interrupt handlers and maximum count value), and of the GPIO port:   #include "phDriver.h" #include "BoardSelection.h" #include "fsl_device_registers.h" #include <fsl_gpio.h> #include <fsl_ctimer.h> /* *********************************************************************************************************** * Internal Definitions * ********************************************************************************************************** */ #define MCXN947_TIMER_MAX_32BIT 0xFFFFFFFFU #define CTIMER_HANDLER CTIMER0_IRQHandler /* *********************************************************************************************************** * * Type Definitions *********************************************************************************************************** */ volatile bool ctimerIsrFlag = false; /* *********************************************************************************************************** * Global and Static Variables * * Match Configuration for CTIMER Channel 0*/ static ctimer_match_config_t matchConfig0; /* Total Size: NNNbytes * ********************************************************************************************************** */ /* Array initializer of GPIO peripheral base pointers */ static const GPIO_Type *pGpiosBaseAddr[] = GPIO_BASE_PTRS; static pphDriver_TimerCallBck_t pCTimerCallBack; static volatile uint8_t dwTimerExp; static const gpio_interrupt_config_t aInterruptTypes[] = {kGPIO_InterruptLogicZero, /* Unused. */ kGPIO_InterruptLogicZero, kGPIO_InterruptLogicOne, kGPIO_InterruptRisingEdge, kGPIO_InterruptFallingEdge, kGPIO_InterruptEitherEdge, }; /* *********************************************************************************************************** * Private Functions Prototypes * ********************************************************************************************************** */ static void phDriver_CTimerIsrCallBack(void); We will define the following functions to initialize and stop the timer, and to enable timer interruptions and its callback:   phStatus_t phDriver_TimerStart(phDriver_Timer_Unit_t eTimerUnit, uint32_t dwTimePeriod, pphDriver_TimerCallBck_t pTimerCallBack) { uint64_t qwTimerCnt; uint32_t dwTimerFreq; dwTimerFreq = PH_DRIVER_SDK_CTIMER_CLK_FREQ; qwTimerCnt = dwTimerFreq; qwTimerCnt = (qwTimerCnt / eTimerUnit); qwTimerCnt = (dwTimePeriod * qwTimerCnt); /* 32-bit timers. */ if(qwTimerCnt > (uint64_t)MCXN947_TIMER_MAX_32BIT) { return PH_DRIVER_ERROR | PH_COMP_DRIVER; } if(pTimerCallBack == NULL) /* Timer Start is blocking call. */ { dwTimerExp = 0; pCTimerCallBack = phDriver_CTimerIsrCallBack; } else /* Call the Timer callback. */ { pCTimerCallBack = pTimerCallBack; } /*Configure & start CTIMER*/ /*Ctimer config structure*/ ctimer_config_t config; /*Timer mode, init*/ CTIMER_GetDefaultConfig(&config); CTIMER_Init(PH_DRIVER_SDK_CTIMER, &config); CTIMER_EnableInterrupts(PH_DRIVER_SDK_CTIMER, kCTIMER_Match0InterruptEnable|kCTIMER_Capture0InterruptEnable); /* Configuration match 0 */ matchConfig0.enableCounterReset = true; matchConfig0.enableCounterStop = false; matchConfig0.matchValue = (uint32_t)qwTimerCnt; matchConfig0.outControl = kCTIMER_Output_NoAction; matchConfig0.outPinInitState = false; matchConfig0.enableInterrupt = true; EnableIRQ(PH_DRIVER_SDK_CTIMER_NVIC); NVIC_SetPriority(PH_DRIVER_SDK_CTIMER_NVIC, PH_DRIVER_SDK_CTIMER_PRIORITY); /*Setup Match*/ CTIMER_SetupMatch(PH_DRIVER_SDK_CTIMER, kCTIMER_Match_0, &matchConfig0); /*Start*/ CTIMER_StartTimer(PH_DRIVER_SDK_CTIMER); while (true) { /* Check whether an interrupt occurred */ if (true == ctimerIsrFlag && dwTimerExp) { /* Clear interrupt flag*/ ctimerIsrFlag = false; break; } } return PH_DRIVER_SUCCESS; }   phStatus_t phDriver_TimerStop(void) { /*Stop timer & disable interrupts*/ CTIMER_StopTimer(PH_DRIVER_SDK_CTIMER); CTIMER_DisableInterrupts(PH_DRIVER_SDK_CTIMER, kCTIMER_Match0InterruptEnable|kCTIMER_Capture0InterruptEnable); /* Disable at the NVIC */ DisableIRQ(PH_DRIVER_SDK_CTIMER_NVIC); return PH_DRIVER_SUCCESS; } We will also have definitions for the functions that configure and handle GPIOs of the MCXN947 and enable interruptions. phStatus_t phDriver_PinConfig(uint32_t dwPinNumber, phDriver_Pin_Func_t ePinFunc, phDriver_Pin_Config_t *pPinConfig) { gpio_pin_config_t sGpioConfig; uint8_t bPinNum; if((ePinFunc == PH_DRIVER_PINFUNC_BIDIR) || (pPinConfig == NULL)) { return PH_DRIVER_ERROR | PH_COMP_DRIVER; } /* Extract the Pin, Gpio, Port details from dwPinNumber */ bPinNum = (uint8_t)(dwPinNumber & 0xFF); sGpioConfig.pinDirection = (ePinFunc == PH_DRIVER_PINFUNC_OUTPUT) ? kGPIO_DigitalOutput:kGPIO_DigitalInput; sGpioConfig.outputLogic = pPinConfig->bOutputLogic; if(ePinFunc == PH_DRIVER_PINFUNC_INTERRUPT) { gpio_interrupt_config_t intConfig = aInterruptTypes[(uint8_t)pPinConfig->eInterruptConfig]; GPIO_GpioClearInterruptFlags((GPIO_Type *)pGpiosBaseAddr[GPIO_PORT], bPinNum); GPIO_SetPinInterruptConfig((GPIO_Type *)pGpiosBaseAddr[GPIO_PORT], bPinNum, intConfig); EnableIRQ(EINT_IRQn); GPIO_PinInit((GPIO_Type *)pGpiosBaseAddr[GPIO_PORT],bPinNum,&sGpioConfig); } else { GPIO_PinInit((GPIO_Type *)pGpiosBaseAddr[GPIO_PORT],bPinNum,&sGpioConfig); } return PH_DRIVER_SUCCESS; } uint8_t phDriver_PinRead(uint32_t dwPinNumber, phDriver_Pin_Func_t ePinFunc) { uint8_t bValue; uint32_t intStatus; uint8_t bPinNum; /* Extract the Pin, Gpio details from dwPinNumber */ bPinNum = (uint8_t)(dwPinNumber & 0xFF); if(ePinFunc == PH_DRIVER_PINFUNC_INTERRUPT) { /*Get value of pin interrupt status*/ intStatus = GPIO_PinGetInterruptFlag((GPIO_Type *)pGpiosBaseAddr[GPIO_PORT], bPinNum); bValue = intStatus ? 1:0; } else { /*Read pin value*/ bValue = (uint8_t)GPIO_PinRead((GPIO_Type *)pGpiosBaseAddr[GPIO_PORT], bPinNum); } return bValue; } void phDriver_PinWrite(uint32_t dwPinNumber, uint8_t bValue) { uint8_t bPinNum; /* Extract the Pin, Gpio details from dwPinNumber */ bPinNum = (uint8_t)(dwPinNumber & 0xFF); GPIO_PinWrite((GPIO_Type *)pGpiosBaseAddr[GPIO_PORT], bPinNum, bValue); } void phDriver_PinClearIntStatus(uint32_t dwPinNumber) { uint8_t bPinNum; /* Extract the Pin, Gpio details from dwPinNumber */ bPinNum = (uint8_t)(dwPinNumber & 0xFF); /*Clear interrupt flag*/ GPIO_GpioClearInterruptFlags((GPIO_Type *)pGpiosBaseAddr[GPIO_PORT], (1U << bPinNum)); } It is also necessary to add functions required for the library to function correctly.   void phDriver_EnterCriticalSection(void) { NVIC_DisableIRQ(EINT_IRQn); } void phDriver_ExitCriticalSection(void) { NVIC_EnableIRQ(EINT_IRQn); } phStatus_t phDriver_IRQPinRead(uint32_t dwPinNumber) { phStatus_t bGpioVal = false; bGpioVal = phDriver_PinRead(dwPinNumber, PH_DRIVER_PINFUNC_INPUT); return bGpioVal; } phStatus_t phDriver_IRQPinPoll(uint32_t dwPinNumber, phDriver_Pin_Func_t ePinFunc, phDriver_Interrupt_Config_t eInterruptType) { uint8_t bGpioState = 0; if ((eInterruptType != PH_DRIVER_INTERRUPT_RISINGEDGE) && (eInterruptType != PH_DRIVER_INTERRUPT_FALLINGEDGE)) { return PH_DRIVER_ERROR | PH_COMP_DRIVER; } if (eInterruptType == PH_DRIVER_INTERRUPT_FALLINGEDGE) { bGpioState = 1; } while(phDriver_PinRead(dwPinNumber, ePinFunc) == bGpioState); return PH_DRIVER_SUCCESS; } Finally, here, we will have the definition of the timer interrupt handler and ISR callback.   void CTIMER0_IRQHandler(void) { /* Clear interrupt flag.*/ CTIMER_ClearStatusFlags(PH_DRIVER_SDK_CTIMER, kCTIMER_Match0Flag|kCTIMER_Capture0Flag); /* Single shot timer. Stop it. */ CTIMER_StopTimer(PH_DRIVER_SDK_CTIMER); CTIMER_DisableInterrupts(PH_DRIVER_SDK_CTIMER, kCTIMER_Match0InterruptEnable|kCTIMER_Capture0InterruptEnable); pCTimerCallBack(); ctimerIsrFlag = true; } static void phDriver_CTimerIsrCallBack(void) { dwTimerExp = 1; } With these additions, we have all the functions needed (based on the FRDM-MCXN947 SDK) by the library to communicate with the PN5190. BoardSelection.h   In this header file, which is found at “DAL > cfg” we will add the definition set in the preprocessor settings to use the FRDM-MCXN947 board as host by adding the following lines to the file:   #ifdef PHDRIVER_FRDMMCXN947_PN5190_BOARD # include <Board_FRDM_MCXN947_PN5190.h> #endif ph_NxpBuild_App.h   In this header found at “intfs” folder, we will add our board support to use it with the PN5190 by adding the following change: #if defined(PHDRIVER_LPC1769PN5190_BOARD) \ || defined(PHDRIVER_K82F_PNEV5190B_BOARD)\ || defined(PHDRIVER_FRDMMCXN947_PN5190_BOARD) # define NXPBUILD__PHHAL_HW_PN5190 #endif phApp_Init.h   In this header located at “intfs” folder we will add the required include files for the initialization of our board and enable the correct debug interface. /*Check for MCXN controller based boards*/ #if defined (PHDRIVER_FRDMMCXN947_PN5190_BOARD) #define PHDRIVER_FRDM_MCXN947 #endif #ifdef PHDRIVER_FRDM_MCXN947 #include <fsl_debug_console.h> #include <stdio.h> #include <fsl_gpio.h> #include <fsl_ctimer.h> #include <fsl_clock.h> #include <fsl_lpspi.h> #endif #if defined(PHDRIVER_KINETIS_K82)|| defined(PHDRIVER_FRDM_MCXN947) phApp_Init.c   Finally, in this source file we will add the initialization code for the MCXN947 to complement the initialization macros defined in the previous phApp_Init.h file modification. Here we will call functions to initialize clocks and UART pins. #ifdef PHDRIVER_FRDM_MCXN947 #include "fsl_common.h" #include "pin_mux.h" #include "clock_config.h" #include "board.h" static void phApp_MCXN947_Init(void){ BOARD_InitBootPins(); BOARD_InitBootClocks(); BOARD_InitDebugConsole(); } #endif #elif defined(PHDRIVER_FRDM_MCXN947) phApp_MCXN947_Init(); These functions are used to initialize the correspondent clocks of each peripheral such as CTIMER, the input pins multiplexor for selecting GPIO functionality and FLEXCOMM for SPI. In here we also set the GPIO functionality for pins P0_31 and P0_28 (IRQ and RESET), as well as UART3 for printing the tag information on the serial port connected to the computer. Additionally, we need to set the NVIC priority to ensure that interrupts can occur. Add the NVIC_SetPriority() function to phApp_Configure_IRQ().   #ifdef PH_PLATFORM_HAS_ICFRONTEND #if !(defined(PH_OSAL_LINUX) && defined(NXPBUILD__PHHAL_HW_PN5190)) phDriver_Pin_Config_t pinCfg; NVIC_SetPriority(EINT_IRQn, EINT_PRIORITY); pinCfg.bOutputLogic = PH_DRIVER_SET_LOW; pinCfg.bPullSelect = PHDRIVER_PIN_IRQ_PULL_CFG; pinCfg.eInterruptConfig = PIN_IRQ_TRIGGER_TYPE; phDriver_PinConfig(PHDRIVER_PIN_IRQ, PH_DRIVER_PINFUNC_INTERRUPT, &pinCfg); #endif pin_mux.c   Inside the function “BOARD_InitBootPins()” which is defined in pin_mux.c file, the following initializations need to be added, you can find this file in the following path: {PrjRootDirPath}\frdmmcxn947_Discovery_Loop\frdmmcxn947_cm33_core0\cm33_core0   void BOARD_InitBootPins(void) { /* Use FRO HF clock for some of the Ctimers */ CLOCK_SetClkDiv(kCLOCK_DivCtimer0Clk, 1u); CLOCK_AttachClk(kFRO_HF_to_CTIMER0); CLOCK_EnableClock(kCLOCK_Gpio0); CLOCK_EnableClock(kCLOCK_Gpio1); BOARD_InitPins(); } Additionally, within the “BOARD_InitPins()” function available in the same file, we will replace the function to add initializations of the GPIO and UART pins.     void BOARD_InitPins(void) { /* Enables the clock for PORT0 controller: Enables clock */ CLOCK_EnableClock(kCLOCK_Port0); /* Enables the clock for PORT1: Enables clock */ CLOCK_EnableClock(kCLOCK_Port1); const port_pin_config_t port0_19_config = {/* Internal pull-up/down resistor is disabled */ kPORT_PullDisable, /* Low internal pull resistor value is selected. */ kPORT_LowPullResistor, /* Fast slew rate is configured */ kPORT_FastSlewRate, /* Passive input filter is disabled */ kPORT_PassiveFilterDisable, /* Open drain output is disabled */ kPORT_OpenDrainDisable, /* Low drive strength is configured */ kPORT_LowDriveStrength, /* Pin is configured as PIO0_10 */ kPORT_MuxAlt0, /* Digital input enabled */ kPORT_InputBufferEnable, /* Digital input is not inverted */ kPORT_InputNormal, /* Pin Control Register fields [15:0] are not locked */ kPORT_UnlockRegister}; /* PORT0_10 (pin B12) is configured as PIO0_10 */ PORT_SetPinConfig(PORT0, 19U, &port0_19_config); const port_pin_config_t port1_0_config = { kPORT_PullDisable, kPORT_LowPullResistor, kPORT_FastSlewRate, kPORT_PassiveFilterDisable, kPORT_OpenDrainDisable, kPORT_LowDriveStrength, /* Pin is configured as PIO0_10 */ kPORT_MuxAlt0, kPORT_InputBufferEnable, kPORT_InputNormal, kPORT_UnlockRegister}; /* PORT0_10 (pin B12) is configured as PIO0_10 */ PORT_SetPinConfig(PORT1, 0U, &port1_0_config); const port_pin_config_t port1_1_config = { kPORT_PullDisable, kPORT_LowPullResistor, kPORT_FastSlewRate, kPORT_PassiveFilterDisable, kPORT_OpenDrainDisable, kPORT_LowDriveStrength, /* Pin is configured as PIO0_10 */ kPORT_MuxAlt0, kPORT_InputBufferEnable, kPORT_InputNormal, kPORT_UnlockRegister}; /* PORT0_10 (pin B12) is configured as PIO0_10 */ PORT_SetPinConfig(PORT1, 1U, &port1_1_config); const port_pin_config_t port0_31_pinB12_config = { kPORT_PullDown, kPORT_LowPullResistor, kPORT_FastSlewRate, kPORT_PassiveFilterDisable, kPORT_OpenDrainDisable, kPORT_LowDriveStrength, /* Pin is configured as PIO0_10 */ kPORT_MuxAlt0, kPORT_InputBufferEnable, kPORT_InputNormal, kPORT_UnlockRegister}; /* PORT0_10 (pin B12) is configured as PIO0_10 */ PORT_SetPinConfig(PORT0, 31U, &port0_31_pinB12_config); const port_pin_config_t port0_28_config = { kPORT_PullDisable, kPORT_LowPullResistor, kPORT_FastSlewRate, kPORT_PassiveFilterDisable, kPORT_OpenDrainDisable, kPORT_LowDriveStrength, /* Pin is configured as PIO0_6 */ kPORT_MuxAlt0, kPORT_InputBufferEnable, kPORT_InputNormal, kPORT_UnlockRegister}; /* PORT0_6 (pin C14) is configured as PIO0_6 */ PORT_SetPinConfig(PORT0, 28U, &port0_28_config); const port_pin_config_t port0_2_pinB16_config = { .pullSelect = kPORT_PullDisable, .pullValueSelect = kPORT_LowPullResistor, .slewRate = kPORT_FastSlewRate, .passiveFilterEnable = kPORT_PassiveFilterDisable, .openDrainEnable = kPORT_OpenDrainDisable, .driveStrength = kPORT_HighDriveStrength, /* Pin is configured as SWO */ .mux = kPORT_MuxAlt1, .inputBuffer = kPORT_InputBufferEnable, .invertInput = kPORT_InputNormal, .lockRegister = kPORT_UnlockRegister}; /* PORT0_2 (pin B16) is configured as SWO */ PORT_SetPinConfig(PORT0, 2U, &port0_2_pinB16_config); const port_pin_config_t port1_8_pinA1_config = { .pullSelect = kPORT_PullUp, .pullValueSelect = kPORT_LowPullResistor, .slewRate = kPORT_FastSlewRate, .passiveFilterEnable = kPORT_PassiveFilterDisable, .openDrainEnable = kPORT_OpenDrainDisable, .driveStrength = kPORT_LowDriveStrength, /* Pin is configured as FC4_P0 */ .mux = kPORT_MuxAlt2, .inputBuffer = kPORT_InputBufferEnable, .invertInput = kPORT_InputNormal, .lockRegister = kPORT_UnlockRegister}; /* PORT1_8 (pin A1) is configured as FC4_P0 */ PORT_SetPinConfig(PORT1, 8U, &port1_8_pinA1_config); const port_pin_config_t port1_9_pinB1_config = { .pullSelect = kPORT_PullDisable, .pullValueSelect = kPORT_LowPullResistor, .slewRate = kPORT_FastSlewRate, .passiveFilterEnable = kPORT_PassiveFilterDisable, .openDrainEnable = kPORT_OpenDrainDisable, .driveStrength = kPORT_LowDriveStrength, /* Pin is configured as FC4_P1 */ .mux = kPORT_MuxAlt2, .inputBuffer = kPORT_InputBufferEnable, .invertInput = kPORT_InputNormal, .lockRegister = kPORT_UnlockRegister}; /* PORT1_9 (pin B1) is configured as FC4_P1 */ PORT_SetPinConfig(PORT1, 9U, &port1_9_pinB1_config); } At the same time, add the following includes to the file: #include "fsl_common.h" #include "fsl_port.h" #include "board.h" #include "clock_config.h" #include "pin_mux.h" Delete phOsal files   We must delete from the path “phOsal > src > NullOs > portable” the files: “phOsal_Port_CM3.c”,“phOsal_Port_PN76xx.c” and “phOsal_Port_PN74xxxx.c”. This has the purpose of avoiding any multiple definition errors when compiling the final project. Although these files have been deleted, they are still referenced in the CMakeLists.txt file. Please remove those includes from this file. Add all header files in CMakeList.txt   As mentioned previously, the CMakeList.txt is automatically updated when you copy a .c file. However, .h files are not automatically linked, so they must be added manually. Please copy and paste the following includes into the CMakeLists.txt file: mcux_add_include( BASE_PATH ${CMAKE_CURRENT_LIST_DIR} INCLUDES NxpNfcRdLib/intfs NxpNfcRdLib/types NxpNfcRdLib/comps/phacDiscLoop/src/Sw intfs DAL/boards DAL/cfg DAL/inc phOsal/inc . ) Add _DSB and _ISB support   As final modification step, please include in {PrjRootDirPath}\NxpNfcRdLib\comps\phhalHw\src\Pn5190\phhalHw_Pn5190_Int.c the “cmsis_gcc.h” to support of _DSB and _ISB functions.   Testing Final Project with FreeRTOS   After making all the previous changes and modifications, the migration is now complete, and we can proceed to compile and flash the example to MCXN947. Please “clean” the project before building by right clicking on the project as follows: To run the project, we will need a serial terminal like Tera Term with the following settings: - 115200 baud rate. - 8 data bits. - No parity. - One stop bit, - No flow control. Once the program is flashed and the serial terminal configured, we can reset the board and power the PNEV5190BP. You should see an output similar to the following: Now if any NFC tag is close to the PNEV5190BP’s antenna, you should see the information displayed as shown in the image below: Changing OS preprocessor macro   This section presents the steps to follow to add the possibility of easily choosing whether to have OS support or not.  This guide is based as default with FREERTOS, but the NFC reader library offers the possibility to run without OS, firstly, we need to change the preprocessor macro PH_OSAL_FREERTOS to PH_OSAL_NULLOS in the CMakeList.txt, as shown the following image: Finally, to avoid multiple definition issues when we change between NULLOS and FREERTOS, we will discard the SysTickHandler for FREERTOS side located in port.c when the NULLOS macro is defined, to achieve this we need to add a replacement of the file port.c since the included FreeRTOS is shared with all projects of the repository, and if we modify this file, it will be modified in all projects. 1. Go to the explorer window, right-click on the project and click on “New File…”. 2. Write the file’s name as follows (port.c) and click enter: 3. Add this file into the CMakeList.txt file to include port.c into the compilation process:   mcux_add_source(BASE_PATH ${CMAKE_CURRENT_LIST_DIR} SOURCES "port.c") 4. Please copy and paste all the content form of the port.c located on the following path to the port.c we created: {SdkRootDirPath}/rtos/freertos/freertos-kernel-upstream/portable/GCC/ARM_CM33_NTZ/non_secure 5. Replace the SysTick_Handler() of the port.c we created to the following function: #ifndef PH_OSAL_NULLOS void SysTick_Handler( void ) /* PRIVILEGED_FUNCTION */ { uint32_t ulPreviousMask; ulPreviousMask = portSET_INTERRUPT_MASK_FROM_ISR(); traceISR_ENTER(); { /* Increment the RTOS tick. */ if( xTaskIncrementTick() != pdFALSE ) { traceISR_EXIT_TO_SCHEDULER(); /* Pend a context switch. */ portNVIC_INT_CTRL_REG = portNVIC_PENDSVSET_BIT; } else { traceISR_EXIT(); } } portCLEAR_INTERRUPT_MASK_FROM_ISR( ulPreviousMask ); } #endif 6. Finally, we will ignore the port.c of the FreeRTOS folder, please add the following code to the CMakeList.txt: mcux_project_remove_source( BASE_PATH ${SdkRootDirPath}/rtos/freertos/freertos-kernel-upstream/portable/GCC/ARM_CM33_NTZ/non_secure SOURCES port.c ) Please rebuild and test as the steps mentioned in the section Testing Final Project with FreeRTOS.
記事全体を表示
Introduction  Based on ES_PN7642 , the PN7642 operating in ULPCD mode may, in very rare cases, enter an unresponsive state. This is caused by very strong distortion of the power supplies or GND of the IC during this boot-up time can cause a loss of the internal reset state and the boot-up sequence gets stuck. This article describes method for evaluating whether a design is sensitive to this phenomenon and provides guidance on how to monitor it.    The primary indicator is the LFO (Low-Frequency Oscillator). In particular, instability of the LFO during the ULPCD "Active" period may indicate an increased risk of the device entering the ULPCD Freeze (unresponsive) state.   This LFO instability may be caused by external events, such as ESD (Electrostatic Discharge), or by interference from other electronic circuits integrated on the PCB.    LFO instability is characterized by deviations in the oscillator's duty cycle and/or the occurrence of missing LFO cycles.   1// Where to measure the LFO ?  The measurement is done during the ULPCD "Active" phase    Time window where to measure the LFO stability      Detail of the "LFO" Start. Please start the measurement when the LFO frequency gets stable.    At the end of the ULPCD active phase, the last LFO clock cycle typically exhibits a slight deviation. This behavior is expected and should not be interpreted as an indication of LFO instability.     2// How to enable LFO observability   The LFO can be routed with the help of ULPCD test buses on GPIO2.  For firmware versions up to PN7642 FW v03.01. -> AN14518 (5.4 How to use test signals for PN7642) Write xx before entering ULPCD mode  For firmware versions from PN7642 FW v03.01 onward -> PN7642 Datasheet (9.14.3.17.12 ULPCD_TESTBUS_MUX_SETTINGS (0702)) Write xx before entering ULPDC mode
記事全体を表示
Introduction The secure firmware download example "DownloadLibEx1" from LPC55S16 Host Software demonstrates how the user can update the PN7642 NXP secure firmware via the Host Interface. This post describes how to enable the download via UART. Resources needed to follow this guide LPC55S16 Host Software Version 02.02.00 LPCXpresso55S16 Development Board OM27642: Development Kit for PN7642 Secure Compact NFC Controller Hardware Connections On the PN7642 there are various shifters and multiplexers in between the host and the actual PN7642 inputs. In order to bypass them quickly, we will interconnect the boards as follows. UART Tx and Rx: Locate J68 on the PNEV7642A board. These 4 jumpers are the host interface connectors (ATX_A, ATX_B, ATX_C, ATX_D). Take the jumpers off as we are going to directly connect to this pin-header. LPC55S16-EVK   PNEV7642A Eval Board Pin Signal (LPC)   Pin Signal (PNEV) J12-14 UART Tx → J68-2 UART Rx J12-16 UART Rx ← J68-8 UART Tx JP12-17 GND ↔ J47-6 GND IRQ, VEN and DWL_REQ connection Note: In this case, please do not remove the jumpers of J45 and J20 on the PNEV7642A, we are going to attach the jumpers directly onto those headers. Also, please remove the jumper on J25.   IRQ VEN DWL_REQ LPC55S16-EVK J13-1 J12-12 J13-3 PNEV7642A J45 J20 J25-2 In order to select the UART Host Interface in the PNEV7642A, we need to set the HIF switches (SW5-SW7) as indicated: Software Prior to the following steps, please follow section 8 of the PN76 family evaluation board quick start guide. To run the example in UART mode, first we need to compile the following libraries: Please compile the main example the exact same way after this. Code Modifications: In lpc55S16Board.c (LPC55S16_Lib/source) In the “lpc55S16Board_Init” function we need to add the following lines in order to enable one the ports and the clock for the USART of the Flexcomm2 peripheral. GPIO_PortInit(GPIO, 1); CLOCK_AttachClk(kFRO12M_to_FLEXCOMM2); In pin_mux.c (LPC55S16_Lib/board) In the “BOARD_InitPins” functions we need to add the following line to enable GPIO 1’s clock. CLOCK_EnableClock(kCLOCK_Gpio1); In phHdll_Lib.c (Hdll_Lib/comps/phHdllLib/src) In this file we are going to include the following library: #include "fsl_usart.h" In the “phHdll_Lib_HalHwExchange” function we are going to add the following lines right after performing the UART transmission of the command. while(USART2->FIFOSTAT & 0x40) { USART_ReadByte(USART2); } This is done to empty the RX FIFO of the UART before performing a reception, in order to prevent reading errors. In fsl_usart.c (LPC55S16_Lib/drivers) In the “USART_ReadBlocking” function please copy the line 625 and paste it again after clearing the reception flags. This is done in order to avoid erroneous interpretation of the RX frame. In DownloadLibEx1.c Lastly, we need to change the path of the ESFWU files to the local path where the files will be located. Please visit PN7642 Product Page, Software section to download the Firmware file. Final Build: Now we need to rebuild the main example, and we should be able to flash and debug after this.
記事全体を表示
Introduction. This document provides a guide on how to use the NFC frontend PN5190 with the FRDM-MCXN947 and using the latest existing version of the NFC Reader Library. The hardware required to follow this guide is: FRDM-MCXN947 development board as host MCU. PNEV5190BP (based on PN5190) as the NFC transceiver Software Setup. MCXN947 SDK version: 26.06.00 NFCReaderLibrary version: 07.16.00 PN5190 FW version: 0x20D MCUxpresso IDE version: 25.6 Hardware connections. The PNEV5190 comes with a Kinetis K82F as a host MCU to drive the PN5190 Since the goal is to drive PN5190 from the MCXN947 via SPI, we need to prepare the PNEV5190 for it: Power up board correctly Enable external SPI pins Disable K82F interface with PN5190 Power up and jumper configuration   To power up the board correctly: – Powering it up over USB does not provide enough current. It will be powered with an external power supply of 7.5V over connector J17. Put jumper on following pins: – J9 2-3: External power supply – J8: VBATPWR supplied with VBAT=3.3 V – J12: VBAT supplied with 3.3 V Remove jumpers on following pins: – J22, J23: open SDA signals for K82F – J19: RTS push-button bypass for K82F – J3, J4, J5, J6: pull down jumpers for NFC module signals Set GPIO and SPI voltage to 3.3 V: supplying 3.3 V to VDDIO and the μC supply: – Remove short circuit on R19 – Place short circuit on R20 For any additional configuration, please see PNEV5190B evaluation board quick start guide. Location of the changes mentioned above can be seen in the following image: Routing NFC module communication pins to JP1   To enable the pins on JP1 for communication, we must enable bus switch U10 and disable bus switch U12 in the NFC Host Interface. These switches enable or disable the connections from K82 to PN5190 SPI pins, and expose the SPI interface to an external host. Remove short on R5 to disable communication routing to K82F. Place short on R7 to enable communication routing to JP1 pins. For FRDM-MCXN947 side, no modifications are necessary.  The pins used are available in Header J1 and J2. Which are shown in the following table.   Name MCXN947 PN5190 SCK J2.12 JP1.1 MOSI J2.8 JP1.2 MISO J2.10 JP1.3 SSEL J2.6 JP1.4 IRQ J1.16 JP1.5 RESET J2.2 JP6.1 GND J2.14 JP1.10 SUCCESS J2.17*   FAIL J2.15*   DWL J2.13*   * Pins that need to be configured for library compatibility but are not used and do not need to be connected. Software Changes   This section describes the software changes required to run the “NfcrdlibEx1_DiscoveryLoop” example from the NFC Reader Library which consists in a detection loop that displays in a terminal information (like UID, SAK, and Product Type for MIFARE product-based cards) about any tag detected by the PN5190. Please download the NFC Reader Library for PN5190 from NFC Reader Library | NXP Semiconductors. To begin with the migration, we first need to create a project with the FRDM-MCXN947 SDK (v26.06.00), for this purpose download and install the FRDM-MCXN947 SDK from the SDK Builder. Importing NFC Reader Library Click on “File” from upper tab menu and “Import…”. In the Import wizard, select “Existing Projects into Workspace”. In the “Select root directory” search the directory where the downloaded library is located and click on Finish (do not check the “Copy projects into workspace” option). Note: If the K82 SDK is not installed an error message will appear, please click on cancel.   Creating base project   1. In the Quick Start panel click on “import SDK example(s)…” in the MCUXpresso IDE. 2. Select “frdmmcxn947” and click on next. 3. Select the SDK example “hello_world_cm33_core0” and click on finish. 4.Now we will add the required drivers for migration, which are SPI and CTIMER drivers. . Click on properties-> SDK Management-> Manage SDK Components. 5. Search in the filter bar “ctimer” and “lpspi” and check their boxes to add them and click on OK. Add the source code Discovery Loop Example   From the imported example NfcrdlibEx1_DiscoveryLoop_mcux of the NFC Reader Library, find and copy the following files (included in src folder): NfcrdlibEx1_EmvcoProfile.c, phApp_Helper.c, phApp_Init.c, phApp_PN5190_Init.c; and paste them into the source folder inside the created base project. Additionally, delete the file hello_world .c created by the project.              Additionally, we need to add the file “NfcrdlibEx1_DiscoveryLoop.c” which is the main source file of the project, to do this right-click on the “source” folder of our project and then put the cursor on “New” and select “File”. In the tab that will open, write the name of the file (NfcrdlibEx1_DiscoveryLoop.c) and then, click on “Finish”. Finally, in the created file copy and paste all the code inside the original source file located in the library example. Link the NFC Reader Library elements   To make the required software changes, we need to link the DAL, NxpNfcRdLib, phOsal and intfs folders into the base project, to do this: 1. In the Project Explorer, right click on the project and place your cursor on New and click on Folder. 2. In the New Folder tab, click on “Advanced >>” and select “Link to alternate location (Linked Folder)” and on “Browse…”. 3. Browse into the path where the library was extracted, choose the NxpNfcRdLib folder and click on Finish. 4. Do the same procedure for “Platform/DAL”, “Examples/NfcrdlibEx1_DiscoveryLoop/intfs” and “RTOS/phOsal” folders. If you have the folder in the same project explorer, the included folder will not appear, but you can see it when you open the window to add another folder, as shown in the following figure. But if the included folders are not in the Project Explorer, the Project should look like this: Once this is done, we will need to delete the “KinetisSDK” folder located in “DAL > src” to avoid multiple definition issues. Define FRDM-MCXN947 SDK preprocessor symbol   We need to do some changes to the compiler preprocessor configuration. 1. Right click on the project in the Project Explorer and click on “Properties… 2. In the properties tab, go to “C/C++ Build > Settings > MCU C Compiler > Preprocessor”. The symbols are related with the FRDM board, but we need to add the following symbols related with the NFC Reader Library: PH_OSAL_NULLOS PHDRIVER_FRDMMCXN947_PN5190_BOARD NXPBUILD_CUSTOMER_HEADER_INCLUDED PHDRIVER_MCXN947_SPI_POLLING Click on the “Add...” button at the top right corner of the “Defined symbols (-D)” menu and enter each symbol mentioned before.   These symbols are added so the preprocessor knows which header files to include at build time. PHDRIVER_FRDMMCXN947_PN5190_BOARD will help include the BoardSelection.h header, the file that is going to define addresses for registers and peripherals of MCXN947. PH_OSAL_NULLOS will include headers related to non-OS operation, meaning that the project will work without any operative system (at the end of this guide you will find the steps to add FreeRTOS support). NXPBUILD_CUSTOMER_HEADER_INCLUDED will add headers to add and select the NFC reader and host that will be used in the project. PHDRIVER_MCXN947_SPI_POLLING if is defined the example will perform SPI communication by polling method, and if not, will be perform through non-blocking transfers. 3. Once added, click on “Apply and Close”, "Rebuild Index" and then to “Yes” to save the changes. Modifying the Driver Abstraction Layer (DAL)   The added linked folder DAL will contain the important changes to be able to use the MCXN947 as host device since it will contain all the changes regarding SPI, timer and GPIO configurations required by the library to work properly. Board_FRDM_MCXN947_PN5190.h   We need to create a header file that will contain important macros used by the library that are related to the host specific SPI, timer and GPIO peripherals, as well as interrupt vectors and priorities, clock sources and addresses. This file is required to be inside the “boards” folder which is inside DAL. Please add the header file as the file created NfcrdlibEx1_DiscoveryLoop.c but replacing .c to .h:   The file should be named as shown in the picture above. Inside this file, some important macros related to the SPI peripheral and the important pins to be handled (IRQ, Chip Select, Reset) are defined. #ifndef DAL_BOARDS_BOARD_FRDM_MCXN947_PN5190_H_ #define DAL_BOARDS_BOARD_FRDM_MCXN947_PN5190_H_ #define GPIO_PORT 0 #define GPIO_PORT1 1 /****************************************************************** * LPSPI clock configuration ******************************************************************/ /*Clock Frequency for SPI Flexcomm 1*/ #define SPI_CLOCK_FREQ (CLOCK_GetLPFlexCommClkFreq(1u)) #define SPI_MASTER_CLOCK_FREQ SPI_CLOCK_FREQ /****************************************************************** * Board Pin/Gpio configurations ******************************************************************/ #define PHDRIVER_PIN_RESET ((GPIO_PORT << 8) | 28) /**< Reset pin, Pin28, PIO0_28 */ #define PHDRIVER_PIN_IRQ ((GPIO_PORT << 8) | 31) /**< IRQ pin, Pin10, PIO0_10 */ /* For 5190 busy is same as IRQ */ #define PHDRIVER_PIN_BUSY ((GPIO_PORT << 8) | 31) /**< IRQ pin, Pin31, PIO0_31 */ #define PHDRIVER_PIN_DWL ((GPIO_PORT << 8) | 19) /**< Download pin, Pin19, PIO0_19*/ /* These pins are used for EMVCo Interoperability test status indication, * not for the generic Reader Library implementation. */ #define PHDRIVER_PIN_SUCCESS ((GPIO_PORT1 << 8) | 0) /**< GPIO, Port 1, Pin0 */ #define PHDRIVER_PIN_FAIL ((GPIO_PORT1 << 8) | 1) /**< GPIO, Port 1, Pin1 */ /****************************************************************** * PIN Pull-Up/Pull-Down configurations. ******************************************************************/ #define PHDRIVER_PIN_RESET_PULL_CFG PH_DRIVER_PULL_UP #define PHDRIVER_PIN_IRQ_PULL_CFG PH_DRIVER_PULL_DOWN #define PHDRIVER_PIN_WKUP_PULL_CFG PH_DRIVER_PULL_UP #define PHDRIVER_PIN_CLK_PULL_CFG PH_DRIVER_PULL_UP #define PHDRIVER_PIN_DWL_PULL_CFG PH_DRIVER_PULL_UP #define PHDRIVER_PIN_NSS_PULL_CFG PH_DRIVER_PULL_UP #define PHDRIVER_PIN_BUSY_PULL_CFG PH_DRIVER_PULL_UP We define the macros as well for the interrupt vector of MCXN947, its priority, handler and trigger type. /****************************************************************** * IRQ PIN NVIC settings ******************************************************************/ #define EINT_IRQn GPIO00_IRQn /*Adding interrupt vector A of GPIO*/ #define EINT_PRIORITY 7 /*Default interrupt priority for GPIO*/ #define CLIF_IRQHandler GPIO00_IRQHandler /*Interrupt handler for vector A*/ #define PIN_IRQ_TRIGGER_TYPE PH_DRIVER_INTERRUPT_RISINGEDGE /*Rising edge Trigger*/ As well as some macros for pin logic levels. /***************************************************************** * Front End Reset logic level settings ****************************************************************/ #define PH_DRIVER_SET_HIGH 1 /**< Logic High. */ #define PH_DRIVER_SET_LOW 0 /**< Logic Low. */ #define RESET_POWERDOWN_LEVEL PH_DRIVER_SET_LOW #define RESET_POWERUP_LEVEL PH_DRIVER_SET_HIGH Finally, we define macros for the base address of CTIMER and SPI peripherals, clock frequencies, interrupt vectors and related pins. /***************************************************************** * SPI Configuration ****************************************************************/ #define PHDRIVER_MCXN947_SPI_MASTER LPSPI1 #define PHDRIVER_MCXN947_SPI_DATA_RATE 5000000U #define PHDRIVER_MCXN947_SPI_CLK_SRC SPI_MASTER_CLOCK_FREQ #define PHDRIVER_MCXN947_SPI_IRQ LP_FLEXCOMM1_IRQn #define SPI_IRQ_PRIORITY 6 /*SPI interrupt priority*/ #define PHDRIVER_PIN_SSEL 27U/* Chip Select, Pin6, SPI */ #define PHDRIVER_PIN_SCK 25U/* SPI clock, Pin7, SPI */ #define PHDRIVER_PIN_MISO 26U/* MISO, Pin8, SPI */ #define PHDRIVER_PIN_MOSI 24U/* MOSI, Pin9, SPI */ #define PHDRIVER_FC1_SPI_DIV kCLOCK_DivFlexcom1Clk #define PHDRIVER_FC1_SPI_CLK kFRO12M_to_FLEXCOMM1 /*Clock to attach to Flexcomm1*/ /***************************************************************** * Timer Configuration ****************************************************************/ #define PH_DRIVER_SDK_CTIMER CTIMER0 /*CTIMER0 base*/ #define PH_DRIVER_SDK_CTIMER_CLK kCLOCK_DivCtimer0Clk/*CTIMER0 clock*/ #define PH_DRIVER_SDK_CTIMER_NVIC CTIMER0_IRQn /*Interrupt vector*/ #define PH_DRIVER_SDK_CTIMER_PRIORITY 4 #define PH_DRIVER_SDK_CTIMER_CLK_FREQ CLOCK_GetCTimerClkFreq(0U) /*CTIMER0 Clock frequency*/ #endif /* DAL_BOARDS_BOARD_FRDM_MCXN947_PN5190_H_ */ MCXN947 SPI and SDK files   Now, inside DAL > src folder we will create a folder named “MCXN947” that will contain 2 source files: phbalReg_Mcxn947Spi.c phDriver_Mcxn947SDK.c Inside these source files we will modify the functions from the source files of other board hosts with the specific configurations of MCXN947 peripheral drivers, such as SPI, timers, GPIOs and interrupt handlers. This is done based on SDK examples such as “ctimer_match_interrupt_example_cm33_core0” and “lpspi_polling_b2b_transfer_master_cm33_core0”. phbalReg_Mcxn947Spi.c:   In this file we first need to include the necessary files and include the headers and callbacks to ensure the correct functionality: #include "phDriver.h" #include <board.h> #include "BoardSelection.h" #include <fsl_lpspi.h> #include <fsl_clock.h> #include <fsl_port.h> #define PHBAL_REG_MCXN947_SPI_ID 0x0FU /**< ID for MCXN947 SPI BAL component */ #define RX_BUFFER_SIZE_MAX 272U /* Receive Buffer size while exchange */ #ifndef PHDRIVER_MCXN947_SPI_POLLING lpspi_master_handle_t g_masterHandle; /* LPSPI user callback */ void LPSPI_MasterUserCallback(LPSPI_Type *base, lpspi_master_handle_t *handle, status_t status, void *userData); #endif static void phbalReg_Mcxn947SpiConfig(void); #ifndef PHDRIVER_MCXN947_SPI_POLLING volatile bool isTransferCompleted = false; void LPSPI_MasterUserCallback(LPSPI_Type *base, lpspi_master_handle_t *handle, status_t status, void *userData) { if (status == kStatus_Success) { __NOP(); } isTransferCompleted = true; } #endif After, we will define the phbalReg_Init function, which will be used by the library to initialize the SPI peripheral in this case, and it is defined as follows: phStatus_t phbalReg_Init( void * pDataParams, uint16_t wSizeOfDataParams) { lpspi_master_config_t userConfig; uint32_t srcFreq = 0; if((pDataParams == NULL) || (sizeof(phbalReg_Type_t) != wSizeOfDataParams)) { return (PH_DRIVER_ERROR | PH_COMP_DRIVER); } ((phbalReg_Type_t *)pDataParams)->wId = PH_COMP_DRIVER | PHBAL_REG_MCXN947_SPI_ID; ((phbalReg_Type_t *)pDataParams)->bBalType = PHBAL_REG_TYPE_SPI; /*Initialize Flexcomm1 clock*/ /* attach FRO 12M to FLEXCOMM1 */ CLOCK_SetClkDiv(PHDRIVER_FC1_SPI_DIV, 1u); CLOCK_AttachClk(PHDRIVER_FC1_SPI_CLK); /*Configure SPI pins*/ phbalReg_Mcxn947SpiConfig(); /*SPI configuration*/ LPSPI_MasterGetDefaultConfig(&userConfig); userConfig.baudRate = PHDRIVER_MCXN947_SPI_DATA_RATE; srcFreq = SPI_MASTER_CLOCK_FREQ; userConfig.whichPcs = (lpspi_which_pcs_t)kLPSPI_Pcs0; userConfig.pcsActiveHighOrLow = (lpspi_pcs_polarity_config_t)kLPSPI_PcsActiveLow; userConfig.pcsToSckDelayInNanoSec = 1000000000U / (userConfig.baudRate * 1U); userConfig.lastSckToPcsDelayInNanoSec = 1000000000U / (userConfig.baudRate * 1U); userConfig.betweenTransferDelayInNanoSec = 1000000000U / (userConfig.baudRate * 1U); /*Initialize SPI*/ #ifdef PHDRIVER_MCXN947_SPI_POLLING LPSPI_MasterInit(PHDRIVER_MCXN947_SPI_MASTER, &userConfig, srcFreq); #else LPSPI_MasterInit(PHDRIVER_MCXN947_SPI_MASTER, &userConfig, srcFreq); LPSPI_MasterTransferCreateHandle(PHDRIVER_MCXN947_SPI_MASTER, &g_masterHandle, LPSPI_MasterUserCallback, NULL); #endif return PH_DRIVER_SUCCESS; } We have to define the phbalReg_Exchange function as well, which is used for communicating via SPI with the PN5190. phStatus_t phbalReg_Exchange( void * pDataParams, uint16_t wOption, uint8_t * pTxBuffer, uint16_t wTxLength, uint16_t wRxBufSize, uint8_t * pRxBuffer, uint16_t * pRxLength ) { phStatus_t status = PH_DRIVER_SUCCESS; uint8_t * pRxBuf; status_t lpspiStatus; lpspi_transfer_t g_masterXfer; uint8_t g_dummyBuffer[RX_BUFFER_SIZE_MAX]; if(pRxBuffer == NULL) { pRxBuf = g_dummyBuffer; } else { pRxBuf = pRxBuffer; } if(pTxBuffer == NULL) { wTxLength = wRxBufSize; g_dummyBuffer[0] = 0xFF; pTxBuffer = g_dummyBuffer; } memset(&g_masterXfer, 0, sizeof(lpspi_transfer_t)); /* Set up the transfer */ g_masterXfer.txData = pTxBuffer; g_masterXfer.rxData = pRxBuf; g_masterXfer.dataSize = wTxLength; g_masterXfer.configFlags = kLPSPI_MasterPcs0 | kLPSPI_MasterPcsContinuous | kLPSPI_MasterByteSwap; /* Start transfer */ #ifdef PHDRIVER_MCXN947_SPI_POLLING lpspiStatus = LPSPI_MasterTransferBlocking(PHDRIVER_MCXN947_SPI_MASTER, &g_masterXfer); #else lpspiStatus = LPSPI_MasterTransferNonBlocking(PHDRIVER_MCXN947_SPI_MASTER, &g_masterHandle, &g_masterXfer); /* Wait transfer complete */ while (!isTransferCompleted) { } #endif if (lpspiStatus != kStatus_Success) { return (PH_DRIVER_FAILURE | PH_COMP_DRIVER); } if (pRxLength != NULL) { *pRxLength = wTxLength; } #ifndef PHDRIVER_MCXN947_SPI_POLLING SDK_DelayAtLeastUs(300U, BOARD_BOOTCLOCKPLL150M_CORE_CLOCK); #endif return status; } Finally, we will define the phbalReg_Mcxn947SpiConfig function, which is called by phbalReg_Init to configure the SPI pins on the MCXN947: static void phbalReg_Mcxn947SpiConfig(void) { const port_pin_config_t port0_24_pinB6_config = { kPORT_PullUp, kPORT_LowPullResistor, kPORT_SlowSlewRate, kPORT_PassiveFilterDisable, kPORT_OpenDrainDisable, kPORT_LowDriveStrength, /* Pin is configured as FC1_P0 */ kPORT_MuxAlt2, kPORT_InputBufferEnable, kPORT_InputNormal, kPORT_UnlockRegister}; /* PORT0_24 (pin B6) is configured as SPI_MOSI */ PORT_SetPinConfig(PORT0, 24U, &port0_24_pinB6_config); const port_pin_config_t port0_25_pinA6_config = {kPORT_PullUp, kPORT_LowPullResistor, kPORT_SlowSlewRate, kPORT_PassiveFilterDisable, kPORT_OpenDrainDisable, kPORT_LowDriveStrength, /* Pin is configured as FC1_P1 */ kPORT_MuxAlt2, kPORT_InputBufferEnable, kPORT_InputNormal, kPORT_UnlockRegister}; /* PORT0_25 (pin A6) is configured as SPI_SCK */ PORT_SetPinConfig(PORT0, 25U, &port0_25_pinA6_config); const port_pin_config_t port0_26_pinF10_config = {kPORT_PullUp, kPORT_LowPullResistor, kPORT_SlowSlewRate, kPORT_PassiveFilterDisable, kPORT_OpenDrainDisable, kPORT_LowDriveStrength, /* Pin is configured as FC1_P2 */ kPORT_MuxAlt2, kPORT_InputBufferEnable, kPORT_InputNormal, kPORT_UnlockRegister}; /* PORT0_26 (pin F10) is configured as SPI_MISO */ PORT_SetPinConfig(PORT0, 26U, &port0_26_pinF10_config); const port_pin_config_t port0_27_pinE10_config = {kPORT_PullUp, kPORT_LowPullResistor, kPORT_SlowSlewRate, kPORT_PassiveFilterDisable, kPORT_OpenDrainDisable, kPORT_LowDriveStrength, /* Pin is configured as FC1_P3 */ kPORT_MuxAlt2, kPORT_InputBufferEnable, kPORT_InputNormal, kPORT_UnlockRegister}; /* PORT0_27 (pin E10) is configured as SPI_CS */ PORT_SetPinConfig(PORT0, 27U, &port0_27_pinE10_config); } phDriver_Mcxn947SDK.c:   In this file we will have the following definitions and includes that describe relevant characteristics of the ctimer (configuration structures, interrupt handlers and maximum count value), and of the GPIO port:   #include "phDriver.h" #include "BoardSelection.h" #include "fsl_device_registers.h" #include <fsl_gpio.h> #include <fsl_ctimer.h> /* *********************************************************************************************************** * Internal Definitions * ********************************************************************************************************** */ #define MCXN947_TIMER_MAX_32BIT 0xFFFFFFFFU #define CTIMER_HANDLER CTIMER0_IRQHandler /* *********************************************************************************************************** * * Type Definitions *********************************************************************************************************** */ volatile bool ctimerIsrFlag = false; /* *********************************************************************************************************** * Global and Static Variables * * Match Configuration for CTIMER Channel 0*/ static ctimer_match_config_t matchConfig0; /* Total Size: NNNbytes * ********************************************************************************************************** */ /* Array initializer of GPIO peripheral base pointers */ static const GPIO_Type *pGpiosBaseAddr[] = GPIO_BASE_PTRS; static pphDriver_TimerCallBck_t pCTimerCallBack; static volatile uint8_t dwTimerExp; static const gpio_interrupt_config_t aInterruptTypes[] = {kGPIO_InterruptLogicZero, /* Unused. */ kGPIO_InterruptLogicZero, kGPIO_InterruptLogicOne, kGPIO_InterruptRisingEdge, kGPIO_InterruptFallingEdge, kGPIO_InterruptEitherEdge, }; /* *********************************************************************************************************** * Private Functions Prototypes * ********************************************************************************************************** */ static void phDriver_CTimerIsrCallBack(void); We will define the following functions to initialize and stop the timer, and to enable timer interruptions and its callback:   phStatus_t phDriver_TimerStart(phDriver_Timer_Unit_t eTimerUnit, uint32_t dwTimePeriod, pphDriver_TimerCallBck_t pTimerCallBack) { uint64_t qwTimerCnt; uint32_t dwTimerFreq; dwTimerFreq = PH_DRIVER_SDK_CTIMER_CLK_FREQ; qwTimerCnt = dwTimerFreq; qwTimerCnt = (qwTimerCnt / eTimerUnit); qwTimerCnt = (dwTimePeriod * qwTimerCnt); /* 32-bit timers. */ if(qwTimerCnt > (uint64_t)MCXN947_TIMER_MAX_32BIT) { return PH_DRIVER_ERROR | PH_COMP_DRIVER; } if(pTimerCallBack == NULL) /* Timer Start is blocking call. */ { dwTimerExp = 0; pCTimerCallBack = phDriver_CTimerIsrCallBack; } else /* Call the Timer callback. */ { pCTimerCallBack = pTimerCallBack; } /*Configure & start CTIMER*/ /*Ctimer config structure*/ ctimer_config_t config; /*Timer mode, init*/ CTIMER_GetDefaultConfig(&config); CTIMER_Init(PH_DRIVER_SDK_CTIMER, &config); CTIMER_EnableInterrupts(PH_DRIVER_SDK_CTIMER, kCTIMER_Match0InterruptEnable|kCTIMER_Capture0InterruptEnable); /* Configuration match 0 */ matchConfig0.enableCounterReset = true; matchConfig0.enableCounterStop = false; matchConfig0.matchValue = (uint32_t)qwTimerCnt; matchConfig0.outControl = kCTIMER_Output_NoAction; matchConfig0.outPinInitState = false; matchConfig0.enableInterrupt = true; EnableIRQ(PH_DRIVER_SDK_CTIMER_NVIC); NVIC_SetPriority(PH_DRIVER_SDK_CTIMER_NVIC, PH_DRIVER_SDK_CTIMER_PRIORITY); /*Setup Match*/ CTIMER_SetupMatch(PH_DRIVER_SDK_CTIMER, kCTIMER_Match_0, &matchConfig0); /*Start*/ CTIMER_StartTimer(PH_DRIVER_SDK_CTIMER); while (true) { /* Check whether an interrupt occurred */ if (true == ctimerIsrFlag && dwTimerExp) { /* Clear interrupt flag*/ ctimerIsrFlag = false; break; } } return PH_DRIVER_SUCCESS; } phStatus_t phDriver_TimerStop(void) { /*Stop timer & disable interrupts*/ CTIMER_StopTimer(PH_DRIVER_SDK_CTIMER); CTIMER_DisableInterrupts(PH_DRIVER_SDK_CTIMER, kCTIMER_Match0InterruptEnable|kCTIMER_Capture0InterruptEnable); /* Disable at the NVIC */ DisableIRQ(PH_DRIVER_SDK_CTIMER_NVIC); return PH_DRIVER_SUCCESS; } We will also have definitions for the functions that configure and handle GPIOs of the MCXN947 and enable interruptions. phStatus_t phDriver_PinConfig(uint32_t dwPinNumber, phDriver_Pin_Func_t ePinFunc, phDriver_Pin_Config_t *pPinConfig) { gpio_pin_config_t sGpioConfig; uint8_t bPinNum; uint8_t bPortGpio; if((ePinFunc == PH_DRIVER_PINFUNC_BIDIR) || (pPinConfig == NULL)) { return PH_DRIVER_ERROR | PH_COMP_DRIVER; } /* Extract the Pin, Gpio, Port details from dwPinNumber */ bPinNum = (uint8_t)(dwPinNumber & 0xFF); bPortGpio = (uint8_t)((dwPinNumber & 0xFF00)>>8); sGpioConfig.pinDirection = (ePinFunc == PH_DRIVER_PINFUNC_OUTPUT) ? kGPIO_DigitalOutput:kGPIO_DigitalInput; sGpioConfig.outputLogic = pPinConfig->bOutputLogic; if(ePinFunc == PH_DRIVER_PINFUNC_INTERRUPT) { gpio_interrupt_config_t intConfig = aInterruptTypes[(uint8_t)pPinConfig->eInterruptConfig]; GPIO_GpioClearInterruptFlags((GPIO_Type *)pGpiosBaseAddr[GPIO_PORT], bPinNum); GPIO_SetPinInterruptConfig((GPIO_Type *)pGpiosBaseAddr[GPIO_PORT], bPinNum, intConfig); EnableIRQ(EINT_IRQn); GPIO_PinInit((GPIO_Type *)pGpiosBaseAddr[GPIO_PORT],bPinNum,&sGpioConfig); } else { GPIO_PinInit((GPIO_Type *)pGpiosBaseAddr[GPIO_PORT],bPinNum,&sGpioConfig); } return PH_DRIVER_SUCCESS; } uint8_t phDriver_PinRead(uint32_t dwPinNumber, phDriver_Pin_Func_t ePinFunc) { uint8_t bValue; uint32_t intStatus; uint8_t bGpioNum; uint8_t bPinNum; /* Extract the Pin, Gpio details from dwPinNumber */ bPinNum = (uint8_t)(dwPinNumber & 0xFF); bGpioNum = (uint8_t)((dwPinNumber & 0xFF00)>>8); if(ePinFunc == PH_DRIVER_PINFUNC_INTERRUPT) { /*Get value of pin interrupt status*/ intStatus = GPIO_PinGetInterruptFlag((GPIO_Type *)pGpiosBaseAddr[GPIO_PORT], bPinNum); bValue = intStatus ? 1:0; } else { /*Read pin value*/ bValue = (uint8_t)GPIO_PinRead((GPIO_Type *)pGpiosBaseAddr[GPIO_PORT], bPinNum); } return bValue; }   void phDriver_PinWrite(uint32_t dwPinNumber, uint8_t bValue) { uint8_t bGpioNum; uint8_t bPinNum; /* Extract the Pin, Gpio details from dwPinNumber */ bPinNum = (uint8_t)(dwPinNumber & 0xFF); bGpioNum = (uint8_t)((dwPinNumber & 0xFF00)>>8); GPIO_PinWrite((GPIO_Type *)pGpiosBaseAddr[GPIO_PORT], bPinNum, bValue); } void phDriver_PinClearIntStatus(uint32_t dwPinNumber) { uint8_t bGpioNum; uint8_t bPinNum; /* Extract the Pin, Gpio details from dwPinNumber */ bPinNum = (uint8_t)(dwPinNumber & 0xFF); bGpioNum = (uint8_t)((dwPinNumber & 0xFF00)>>8); /*Clear interrupt flag*/ GPIO_GpioClearInterruptFlags((GPIO_Type *)pGpiosBaseAddr[GPIO_PORT], (1U << bPinNum)); } It is also necessary to add functions required for the library to function correctly. void phDriver_EnterCriticalSection(void) { NVIC_DisableIRQ(EINT_IRQn); } void phDriver_ExitCriticalSection(void) { NVIC_EnableIRQ(EINT_IRQn); } phStatus_t phDriver_IRQPinRead(uint32_t dwPinNumber) { phStatus_t bGpioVal = false; bGpioVal = phDriver_PinRead(dwPinNumber, PH_DRIVER_PINFUNC_INPUT); return bGpioVal; } phStatus_t phDriver_IRQPinPoll(uint32_t dwPinNumber, phDriver_Pin_Func_t ePinFunc, phDriver_Interrupt_Config_t eInterruptType) { uint8_t bGpioState = 0; if ((eInterruptType != PH_DRIVER_INTERRUPT_RISINGEDGE) && (eInterruptType != PH_DRIVER_INTERRUPT_FALLINGEDGE)) { return PH_DRIVER_ERROR | PH_COMP_DRIVER; } if (eInterruptType == PH_DRIVER_INTERRUPT_FALLINGEDGE) { bGpioState = 1; } while(phDriver_PinRead(dwPinNumber, ePinFunc) == bGpioState); return PH_DRIVER_SUCCESS; } Finally, here, we will have the definition of the timer interrupt handler and ISR callback. void CTIMER0_IRQHandler(void) { /* Clear interrupt flag.*/ CTIMER_ClearStatusFlags(PH_DRIVER_SDK_CTIMER, kCTIMER_Match0Flag|kCTIMER_Capture0Flag); /* Single shot timer. Stop it. */ CTIMER_StopTimer(PH_DRIVER_SDK_CTIMER); CTIMER_DisableInterrupts(PH_DRIVER_SDK_CTIMER, kCTIMER_Match0InterruptEnable|kCTIMER_Capture0InterruptEnable); pCTimerCallBack(); ctimerIsrFlag = true; } static void phDriver_CTimerIsrCallBack(void) { dwTimerExp = 1; } With these additions, we have all the functions needed (based on the FRDM-MCXN947 SDK) by the library to communicate with the PN5190. BoardSelection.h   In this header file, which is found at “DAL > cfg” we will add the definition set in the preprocessor settings to use the FRDM-MCXN947 board as host by adding the following lines to the file: #ifdef PHDRIVER_FRDMMCXN947_PN5190_BOARD # include <Board_FRDM_MCXN947_PN5190.h> #endif ph_NxpBuild_App.h   In this header found at “intfs” folder, we will add our board support to use it with the PN5190 by adding the following change: #if defined(PHDRIVER_LPC1769PN5190_BOARD) \ || defined(PHDRIVER_K82F_PNEV5190B_BOARD)\ || defined(PHDRIVER_FRDMMCXN947_PN5190_BOARD) # define NXPBUILD__PHHAL_HW_PN5190 #endif phApp_Init.h   In this header located at “intfs” folder we will add the required include files for the initialization of our board and enable the correct debug interface. /*Check for MCXN controller based boards*/ #if defined (PHDRIVER_FRDMMCXN947_PN5190_BOARD) #define PHDRIVER_FRDM_MCXN947 #endif #ifdef PHDRIVER_FRDM_MCXN947 #include <fsl_debug_console.h> #include <stdio.h> #include <fsl_gpio.h> #include <fsl_ctimer.h> #include <fsl_clock.h> #include <fsl_lpspi.h> #endif Please replace this line.   #if defined(PHDRIVER_KINETIS_K82)|| defined(PHDRIVER_FRDM_MCXN947) phApp_Init.c   Finally, in this source file we will add the initialization code for the MCXN947 to complement the initialization macros defined in the previous phApp_Init.h file modification. Here we will call functions to initialize clocks and UART pins.   #ifdef PHDRIVER_FRDM_MCXN947 #include "fsl_common.h" #include "pin_mux.h" #include "clock_config.h" #include "board.h" static void phApp_MCXN947_Init(void){ BOARD_InitBootPins(); BOARD_InitBootClocks(); BOARD_InitDebugConsole(); } #endif   #elif defined(PHDRIVER_FRDM_MCXN947) phApp_MCXN947_Init(); These functions are used to initialize the correspondent clocks of each peripheral such as CTIMER, the input pins multiplexor for selecting GPIO functionality and FLEXCOMM for SPI. In here we also set the GPIO functionality for pins P0_31 and P0_28 (IRQ and RESET), as well as UART3 for printing the tag information on the serial port connected to the computer. Additionally, we need to set the NVIC priority to ensure that interrupts can occur. Add the NVIC_SetPriority() function to phApp_Configure_IRQ(). #ifdef PH_PLATFORM_HAS_ICFRONTEND #if !(defined(PH_OSAL_LINUX) && defined(NXPBUILD__PHHAL_HW_PN5190)) phDriver_Pin_Config_t pinCfg; NVIC_SetPriority(EINT_IRQn, EINT_PRIORITY); pinCfg.bOutputLogic = PH_DRIVER_SET_LOW; pinCfg.bPullSelect = PHDRIVER_PIN_IRQ_PULL_CFG; pinCfg.eInterruptConfig = PIN_IRQ_TRIGGER_TYPE; phDriver_PinConfig(PHDRIVER_PIN_IRQ, PH_DRIVER_PINFUNC_INTERRUPT, &pinCfg); #endif pin_mux.c   Inside the function “BOARD_InitBootPins()” which is defined in board -> pin_mux.c file, the following initializations need to be added: void BOARD_InitBootPins(void) { /* Use FRO HF clock for some of the Ctimers */ CLOCK_SetClkDiv(kCLOCK_DivCtimer0Clk, 1u); CLOCK_AttachClk(kFRO_HF_to_CTIMER0); CLOCK_EnableClock(kCLOCK_Gpio0); CLOCK_EnableClock(kCLOCK_Gpio1); BOARD_InitPins(); } Additionally, within the “BOARD_InitPins()” function available in the same file, we will replace the initializations of the GPIO and UART pins. void BOARD_InitPins(void) { /* Enables the clock for PORT0 controller: Enables clock */ CLOCK_EnableClock(kCLOCK_Port0); /* Enables the clock for PORT1: Enables clock */ CLOCK_EnableClock(kCLOCK_Port1); const port_pin_config_t port0_19_config = {/* Internal pull-up/down resistor is disabled */ kPORT_PullDisable, /* Low internal pull resistor value is selected. */ kPORT_LowPullResistor, /* Fast slew rate is configured */ kPORT_FastSlewRate, /* Passive input filter is disabled */ kPORT_PassiveFilterDisable, /* Open drain output is disabled */ kPORT_OpenDrainDisable, /* Low drive strength is configured */ kPORT_LowDriveStrength, /* Pin is configured as PIO0_10 */ kPORT_MuxAlt0, /* Digital input enabled */ kPORT_InputBufferEnable, /* Digital input is not inverted */ kPORT_InputNormal, /* Pin Control Register fields [15:0] are not locked */ kPORT_UnlockRegister}; /* PORT0_10 (pin B12) is configured as PIO0_10 */ PORT_SetPinConfig(PORT0, 19U, &port0_19_config); const port_pin_config_t port1_0_config = { kPORT_PullDisable, kPORT_LowPullResistor, kPORT_FastSlewRate, kPORT_PassiveFilterDisable, kPORT_OpenDrainDisable, kPORT_LowDriveStrength, /* Pin is configured as PIO0_10 */ kPORT_MuxAlt0, kPORT_InputBufferEnable, kPORT_InputNormal, kPORT_UnlockRegister}; /* PORT0_10 (pin B12) is configured as PIO0_10 */ PORT_SetPinConfig(PORT1, 0U, &port1_0_config); const port_pin_config_t port1_1_config = { kPORT_PullDisable, kPORT_LowPullResistor, kPORT_FastSlewRate, kPORT_PassiveFilterDisable, kPORT_OpenDrainDisable, kPORT_LowDriveStrength, /* Pin is configured as PIO0_10 */ kPORT_MuxAlt0, kPORT_InputBufferEnable, kPORT_InputNormal, kPORT_UnlockRegister}; /* PORT0_10 (pin B12) is configured as PIO0_10 */ PORT_SetPinConfig(PORT1, 1U, &port1_1_config); const port_pin_config_t port0_31_pinB12_config = { kPORT_PullDown, kPORT_LowPullResistor, kPORT_FastSlewRate, kPORT_PassiveFilterDisable, kPORT_OpenDrainDisable, kPORT_LowDriveStrength, /* Pin is configured as PIO0_10 */ kPORT_MuxAlt0, kPORT_InputBufferEnable, kPORT_InputNormal, kPORT_UnlockRegister}; /* PORT0_10 (pin B12) is configured as PIO0_10 */ PORT_SetPinConfig(PORT0, 31U, &port0_31_pinB12_config); const port_pin_config_t port0_28_config = { kPORT_PullDisable, kPORT_LowPullResistor, kPORT_FastSlewRate, kPORT_PassiveFilterDisable, kPORT_OpenDrainDisable, kPORT_LowDriveStrength, /* Pin is configured as PIO0_6 */ kPORT_MuxAlt0, kPORT_InputBufferEnable, kPORT_InputNormal, kPORT_UnlockRegister}; /* PORT0_6 (pin C14) is configured as PIO0_6 */ PORT_SetPinConfig(PORT0, 28U, &port0_28_config); const port_pin_config_t port0_2_pinB16_config = { .pullSelect = kPORT_PullDisable, .pullValueSelect = kPORT_LowPullResistor, .slewRate = kPORT_FastSlewRate, .passiveFilterEnable = kPORT_PassiveFilterDisable, .openDrainEnable = kPORT_OpenDrainDisable, .driveStrength = kPORT_HighDriveStrength, /* Pin is configured as SWO */ .mux = kPORT_MuxAlt1, .inputBuffer = kPORT_InputBufferEnable, .invertInput = kPORT_InputNormal, .lockRegister = kPORT_UnlockRegister}; /* PORT0_2 (pin B16) is configured as SWO */ PORT_SetPinConfig(PORT0, 2U, &port0_2_pinB16_config); const port_pin_config_t port1_8_pinA1_config = { .pullSelect = kPORT_PullUp, .pullValueSelect = kPORT_LowPullResistor, .slewRate = kPORT_FastSlewRate, .passiveFilterEnable = kPORT_PassiveFilterDisable, .openDrainEnable = kPORT_OpenDrainDisable, .driveStrength = kPORT_LowDriveStrength, /* Pin is configured as FC4_P0 */ .mux = kPORT_MuxAlt2, .inputBuffer = kPORT_InputBufferEnable, .invertInput = kPORT_InputNormal, .lockRegister = kPORT_UnlockRegister}; /* PORT1_8 (pin A1) is configured as FC4_P0 */ PORT_SetPinConfig(PORT1, 8U, &port1_8_pinA1_config); const port_pin_config_t port1_9_pinB1_config = { .pullSelect = kPORT_PullDisable, .pullValueSelect = kPORT_LowPullResistor, .slewRate = kPORT_FastSlewRate, .passiveFilterEnable = kPORT_PassiveFilterDisable, .openDrainEnable = kPORT_OpenDrainDisable, .driveStrength = kPORT_LowDriveStrength, /* Pin is configured as FC4_P1 */ .mux = kPORT_MuxAlt2, .inputBuffer = kPORT_InputBufferEnable, .invertInput = kPORT_InputNormal, .lockRegister = kPORT_UnlockRegister}; /* PORT1_9 (pin B1) is configured as FC4_P1 */ PORT_SetPinConfig(PORT1, 9U, &port1_9_pinB1_config); } At the same time, add the following includes to the file: #include "fsl_common.h" #include "fsl_port.h" #include "board.h" #include "clock_config.h" #include "pin_mux.h" Adding include paths   Since we are including header files into the project, we must specify which directories to search in order to find the required files. To do this: 1. Open project properties (right-click on project > Properties). 2.Click on the drop menu “C/C++ Build”, then “Settings”. 3.Click on “Includes” option. 4.Click on the “Add..” button at the top right corner of the “Include paths (-l)” menu. 5. Click on “Workspace…” 6. Add the following highlighted directories from FRDM-MCXN project: 7. Accept the changes and click on “Apply and Close”. Add “root folder” to source location   1.Open project properties. 2. Click on the drop menu “C/C++ General”, then “Paths and Symbols”. 3. Click on the “Source Location” tab. 4.Click on “Add Folder…” and add the “<root folder>”. Delete phOsal files   We must delete from the path “phOsal > src > NullOs > portable” the files: “phOsal_Port_CM3.c”,“phOsal_Port_PN76xx.c” and “phOsal_Port_PN74xxxx.c”. This has the purpose of avoiding any multiple definition errors when compiling the final project. Add _DSB and _ISB support   As final modification step, please include in NxpNfcRdLib->comps->phhalHw->src->PN5190-> phhalHw_Pn5190_Int.c the  “cmsis_gcc.h” to support of _DSB and _ISB functions. Testing Final Project Without OS   After making all the previous changes and modifications, the migration is now complete, and we can proceed to compile and flash the example to MCXN947. Please “clean” the project before building by right clicking on the project as follows: To run the project, we will need a serial terminal like Tera Term with the following settings: - 115200 baud rate. - 8 data bits. - No parity. - One stop bit, - No flow control. Once the program is flashed and the serial terminal configured, we can reset the board and power the PNEV5190BP. You should see an output similar to the following: Now if any NFC tag is close to the PNEV5190BP’s antenna, you should see the information displayed as shown in the image below: Adding FreeRTOS support   This section presents the steps to follow to add FreeRTOS support to the current project with the possibility of easily choosing either to have OS support or not. 1. Open the “Manage SDK Components” in properties->SDK Management. 2. Search the FreeRTOS kernel component (NXP integration layer), heap 4 and add it to your project.   Note: If this option does not appear, you will have to download the SDK with the FreeRTOS stack included. Adding porting-specific files to FreeRTOS folder   We need to set the core-specific files which define core register addresses and the assembly instructions that integrate the FreeRTOS kernel functions. The core integrating the MCXN947 IC is the Cortex M33 with Trust Zone, therefore, the folder that we will use to add the port files will be from the folder “ARM_CM33_NTZ” as explained below: 1. Import the SDK example called “freertos_hello_cm33_core0”: 2. Inside this example, you will see the folder “GCC” from the path freertos>freertoskernel>portable>GCC, please copy and paste this folder into the same path of the project.     Adding port-specific created folder to include path.   Now we need to tell the compiler where to find the port-specific files we just added to the project, to accomplish this: 1. Open the project properties (right-click on project > Properties) and click on “C/C++ General” and on “Paths and symbols”. 2. Here we will click on “Add…” and then “Workspace”. In the new tab we will search the last folder of the path we created (freertos/freertoskernel/portable/GCC/ARM_CM33_NTZ/non-secure), select it and click on “OK”   3. Repeat this step in project > Properties > “C/C++ Build” >Settings >“Includes”. Changing OS preprocessor macro   Finally, we just need to tell the compiler that we want to run the example with FreeRTOS, to do this: 1. Open the project properties (right-click on project > Properties) and click on “C/C++ Build”, then on “Settings” and on “Preprocessor”. 2. Now find the previous macro named “PH_OSAL_NULLOS”, double click on it and change it to “PH_OSAL_FREERTOS” 3. Click on “Apply and Close” and click on “Rebuild Index”. 4. To avoid multiple definition issues when we change between NULLOS and FREERTOS, we will discard the SysTickHandler for FREERTOS side located in port.c when the NULLOS macro is defined, as shown the following image: #ifndef PH_OSAL_NULLOS void SysTick_Handler( void ) /* PRIVILEGED_FUNCTION */ { uint32_t ulPreviousMask; ulPreviousMask = portSET_INTERRUPT_MASK_FROM_ISR(); traceISR_ENTER(); { /* Increment the RTOS tick. */ if( xTaskIncrementTick() != pdFALSE ) { traceISR_EXIT_TO_SCHEDULER(); /* Pend a context switch. */ portNVIC_INT_CTRL_REG = portNVIC_PENDSVSET_BIT; } else { traceISR_EXIT(); } } portCLEAR_INTERRUPT_MASK_FROM_ISR( ulPreviousMask ); } #endif 5. Finally, copy and paste the FreeRTOSConfig_Gen.h, FreeRTOSConfig.h and freertos_tasks_c_additions.h files from the freertos_hello example as shown the following image:     Now you are able to build and debug following the chapter Testing Final Project Without OS but now with FreeRTOS.
記事全体を表示
Introduction Many customers are using PN7220 + Android 16 recently. In this document, I will show you how to porting the PN7220 to Android 16. I use the i.MX95 FRDM board as a reference target board.   NOTE :  All the modifications are just for reference. They are NOT a NXP official patches for the newer release of AOSP porting. So the modifications may not be the best solution. Customer please base on their needs to modify the AOSP source code. This is not for production. Customer still need to perform full testing after the porting.    Hardware boards: i.MX95 FRDM Board (FRDM i.MX 95 Development Board | NXP Semiconductors)   PN7220 EVK -- PNEV7220BP1 (PNEV7220BP1 Development Board for PN7220 NFC Controller | NXP Semiconductors)   There is a 40pins connector on both PN7220 EVK and i.MX95 FRDM board. So PN7220 + i.MX95 FRDM connecting together is like this:   Build the Android BSP for i.MX95 FRDM board: The i.MX Android BSP that I used is Android 16.0.0_1.4.0 (L6.12.49_2.2.0 BSP). It could be downloaded from here: Android OS for i.MX Applications Processors | NXP Semiconductors   1. Download the "Documentation" and the "Install Source Package".  2. Follow the steps in Android User's Guide to build the Android BSP for "evk_95" first.  $ export MY_ANDROID=`pwd` $ source build/envsetup.sh $ lunch evk_95-nxp_stable-userdebug $ export TARGET_RELEASE=nxp_stable $ build_build_var_cache $ ./imx-make.sh -j4 2>&1 | tee build-log.txt   According to the android_build/.repo/manifests/aosp-android-16.0.0_1.4.0.xml, you will see the AOSP version is android-16.0.0_r4. According to the PN7220 Android 16 porting guide (PN7160/PN7220 – Android 16 porting guide), the patches is for AOSP release android-16.0.0_r2. So fortunately, the AOSP release version between them is not big different.    Now, we start the porting: 1. Kernel Driver To establish connection with the PN7220, the Android stack uses the nxpnfc kernel driver.  You could download the driver from github below: nfcandroid_platform_drivers/drivers at br_ar_16_comm_infra_dev · nxp-nfc-infra/nfcandroid_platform_drivers · GitHub   The command is : git clone "https://github.com/nxp-nfc-infra/nfcandroid_platform_drivers.git" -b br_ar_16_comm_infra_dev There is driver for Kernel 6.6 and 6.12. So, please download the correct one for your porting. For example, the kernel in i.MX Android BSP Android 16.0.0_1.4.0 is 6.12. So I will use the 6.12 driver for my porting.   In your porting, make sure the PATH in Makefile and Kconfig files are setting properly.  For example in my porting: android_build/vendor/nxp-opensource/kernel_imx/drivers/nfc/pn7220$ tree . ├── common.c ├── common.h ├── i2c_drv.c ├── i2c_drv.h ├── Kbuild ├── Kconfig └── Makefile 0 directories, 7 files   For simplifying everything, we will only add a support for I2C and not SPI. Replace drivers/nfc/pn7220/Makefile default code with following code (for easier understanding) nxpnfc-i2c-objs = i2c_drv.o common.o obj-$(CONFIG_NXP_NFC_I2C) += nxpnfc_i2c.o   The contents of drivers/nfc/Makefile. Add the PN7220 like below: # SPDX-License-Identifier: GPL-2.0 # # Makefile for nfc devices # obj-$(CONFIG_NXP_NFC_I2C) += pn7220/ obj-$(CONFIG_NFC_FDP) += fdp/ obj-$(CONFIG_NFC_PN544) += pn544/ obj-$(CONFIG_NFC_MICROREAD) += microread/ obj-$(CONFIG_NFC_PN533) += pn533/ obj-$(CONFIG_NFC_MEI_PHY) += mei_phy.o obj-$(CONFIG_NFC_SIM) += nfcsim.o obj-$(CONFIG_NFC_PORT100) += port100.o obj-$(CONFIG_NFC_MRVL) += nfcmrvl/ obj-$(CONFIG_NFC_TRF7970A) += trf7970a.o obj-$(CONFIG_NFC_ST21NFCA) += st21nfca/ obj-$(CONFIG_NFC_ST_NCI) += st-nci/ obj-$(CONFIG_NFC_NXP_NCI) += nxp-nci/ obj-$(CONFIG_NFC_S3FWRN5) += s3fwrn5/ obj-$(CONFIG_NFC_ST95HF) += st95hf/ obj-$(CONFIG_NFC_VIRTUAL_NCI) += virtual_ncidev.o   The contents of drivers/nfc/Kconfig. Add the PN7220 like below: source "drivers/nfc/microread/Kconfig" source "drivers/nfc/nfcmrvl/Kconfig" source "drivers/nfc/st21nfca/Kconfig" source "drivers/nfc/st-nci/Kconfig" source "drivers/nfc/nxp-nci/Kconfig" source "drivers/nfc/s3fwrn5/Kconfig" source "drivers/nfc/st95hf/Kconfig" source "drivers/nfc/pn7220/Kconfig" endmenu   2. Adding the "nxpnfc" to the i.MX95 FRDM board device tree file android_build/vendor/nxp-opensource/kernel_imx/arch/arm64/boot/dts/freescale/imx95-15x15-frdm.dts   We need to check the connection between two boards and then to decide which pins to use in the device tree file. Here is the 40 pins connector on the PN7220: Here is the 40 pins connector on the i.MX95 FRDM board. According to the 40 pins connection between PN7220 EVK and the i.MX95 FRDM board, I decided to use the I2C6 and the GPIO2_20, GPIO2_21 and GPIO2_26. So, in the imx95-15x15-frdm.dts, I added: &lpi2c6 { clock-frequency = <400000>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_lpi2c6>; status = "okay"; nxpnfc@28{ compatible = "nxp,nxpnfc"; reg = <0x28>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_nfc>; nxp,nxpnfc-irq = <&gpio2 26 0>; nxp,nxpnfc-ven = <&gpio2 21 0>; nxp,nxpnfc-mode_sw = <&gpio2 20 0>; }; }; And the IOMUX settings in the imx95-15x15-frdm.dts. pinctrl_nfc: nfcgrp { fsl,pins = < IMX95_PAD_GPIO_IO26__GPIO2_IO_BIT26 0x39e // IRQ IMX95_PAD_GPIO_IO21__GPIO2_IO_BIT21 0x39e // VEN IMX95_PAD_GPIO_IO20__GPIO2_IO_BIT20 0x39e // MODE_SW >; }; pinctrl_lpi2c6: lpi2c6grp { fsl,pins = < IMX95_PAD_GPIO_IO02__LPI2C6_SDA 0x40000b9e IMX95_PAD_GPIO_IO03__LPI2C6_SCL 0x40000b9e >; };   3. Modify the imx95_gki.fragment File:  android_build/vendor/nxp-opensource/kernel_imx/arch/arm64/configs/imx95_gki.fragment Add the "CONFIG_NXP_NFC_I2C=m" into the imx95_gki.fragment   4. Add the settings in your corresponding board configuration files in Android - Go to the android_build/device/nxp/imx9/evk_95/  - Modify the BoardConfig.mk. # Add KVM support BOARD_BOOTCONFIG += androidboot.hypervisor.vm.supported=true + # ---- selinux permissive ---- + BOARD_KERNEL_CMDLINE += androidboot.selinux=permissive # -------@block_sepolicy------- BOARD_SEPOLICY_DIRS := \ $(CONFIG_REPO_PATH)/imx9/sepolicy \ $(IMX_DEVICE_PATH)/sepolicy \ + vendor/nxp/nfc/sepolicy \ + vendor/nxp/nfc/sepolicy/nfc \ + vendor/nxp/emvco/sepolicy +include vendor/nxp/nfc/BoardConfigNfc.mk    - Add the "nxpnfc_i2c.ko" to the ShareBoardConfig.mk. Make sure the path and the filename are correct. ifeq ($(LOADABLE_KERNEL_MODULE),true) IMX_ANDROID_FIRST_STAGE_MODULES += \ $(KERNEL_OUT)/drivers/hwmon/hwmon.ko \ $(KERNEL_OUT)/drivers/hwmon/scmi-hwmon.ko \ .... .... .... $(KERNEL_OUT)/drivers/soc/imx/soc-imx9.ko \ $(KERNEL_OUT)/drivers/gpio/gpio-adp5585.ko \ $(KERNEL_OUT)/drivers/gpio/gpio-pca953x.ko \ $(KERNEL_OUT)/drivers/gpio/gpio-vf610.ko \ + $(KERNEL_OUT)/drivers/nfc/pn7220/nxpnfc_i2c.ko .... .... BOARD_VENDOR_KERNEL_MODULES += \ $(KERNEL_OUT)/drivers/media/i2c/ap1302.ko \ $(KERNEL_OUT)/drivers/media/i2c/ox03c10.ko \ $(KERNEL_OUT)/drivers/media/i2c/max96717_lib.ko \ .... .... $(KERNEL_OUT)/drivers/net/ethernet/freescale/enetc/fsl-enetc-vf.ko \ $(KERNEL_OUT)/drivers/net/ethernet/freescale/enetc/fsl-enetc4.ko \ $(KERNEL_OUT)/drivers/net/phy/realtek.ko \ $(KERNEL_OUT)/drivers/hwmon/pwm-fan.ko \ + $(KERNEL_OUT)/drivers/nfc/pn7220/nxpnfc_i2c.ko   - Add the INxpNfc and INxpEmvco to the device_framework_matrix.xml <compatibility-matrix version="1.0" type="framework"> <hal format="aidl" optional="true"> <name>nxp.hardware.secureime</name> <version>1</version> <interface> <name>ISecureIME</name> <instance>default</instance> </interface> </hal> <hal format="aidl" optional="true"> <name>nxp.hardware.ele</name> <version>1</version> <interface> <name>ISecureEnclave</name> <instance>default</instance> </interface> </hal> <hal format="aidl" optional="true"> <name>nxp.hardware.imx_dek_extractor</name> <version>1</version> <interface> <name>IDek_Extractor</name> <instance>default</instance> </interface> </hal> <hal format="aidl" optional="true"> <name>vendor.nxp.nxpnfc_aidl</name> <version>2</version> <interface> <name>INxpNfc</name> <instance>default</instance> </interface> </hal> <hal format="aidl" optional="true"> <name>vendor.nxp.emvco</name> <version>1</version> <interface> <name>INxpEmvco</name> <instance>default</instance> </interface> </hal> </compatibility-matrix>    - Add the following to the evk_95.mk # ------nfc------- $(call inherit-product, vendor/nxp/nfc/device-nfc.mk) $(call inherit-product, vendor/nxp/emvco/device-emvco.mk) PRODUCT_PACKAGES += \ android.hardware.nfc2-service.nxp PRODUCT_PACKAGES += \ com.nxp.emvco \ com.nxp.nfc \ nfc_nci_nxp_pn72xx   - Add the nxpnfc_i2c in init.rc exec u:r:vendor_modprobe:s0 -- /vendor/bin/modprobe -a -d \ /vendor/lib/modules nxpnfc_i2c write /sys/power/wake_lock nosleep   - Add nxpnfc to ueventd.nxp.rc /dev/ttymxc1 0666 nfc nfc /dev/ttymxc2 0666 nfc nfc /dev/nxpnfc 0666 nfc nfc   5. Apply the NXP AOSP patches I write a script to download the patches from the github. The script file and the android_build folder is on the same directory. Run the AOSP_adaptation.sh.  AOSP_adaptation.sh # nfcandroid_nfc_modules git clone "https://github.com/nxp-nfc-infra/nfcandroid_modules_nfc.git" cd nfcandroid_modules_nfc git checkout br_ar_16_comm_infra_dev cp -rf * ../android_build/packages/modules/Nfc cd .. # nfcandroid_nfc_hidlimpl git clone "https://github.com/nxp-nfc-infra/nfcandroid_nfc_hidlimpl.git" cd nfcandroid_nfc_hidlimpl git checkout br_ar_16_comm_infra_dev cp -rf * ../android_build/hardware/nxp/nfc cd .. # nfcandroid_frameworks git clone "https://github.com/nxp-nfc-infra/nfcandroid_frameworks.git" cd nfcandroid_frameworks git checkout br_ar_16_comm_infra_dev mkdir ../android_build/packages/modules/Nfc/framework cp -rf * ../android_build/packages/modules/Nfc/framework cd .. # nfcandroid_emvco_aidlimpl git clone "https://github.com/nxp-nfc-infra/nfcandroid_emvco_aidlimpl.git" cd nfcandroid_emvco_aidlimpl git checkout br_ar_16_comm_infra_dev mkdir ../android_build/hardware/nxp/emvco cp -rf * ../android_build/hardware/nxp/emvco cd .. # nfcandroid_platform_reference git clone "https://github.com/nxp-nfc-infra/nfcandroid_platform_reference.git" cd nfcandroid_platform_reference git checkout br_ar_16_comm_infra_dev cp -rf vendor/nxp/* ../android_build/vendor/nxp/ cd ..   Apply a patch. $ cd android_build/system/logging $ patch -p1 < ../../../nfcandroid_platform_reference/build_cfg/build_pf_patches/AROOT_system_logging.patch   Add TDA Test support: # Clone repositories for test applications and TDA support # nfcandroid_infra_test_apps git clone https://github.com/nxp-nfc-infra/nfcandroid_infra_test_apps.git cd nfcandroid_infra_test_apps/ git checkout br_ar_16_comm_infra_dev cd test_apps/ cp -rf SMCU_Switch/ ../../android_build/packages/apps/ cp -rf EMVCoModeSwitchApp/ ../../android_build/packages/apps/ cd ../.. # nfcandroid_infra_comm_libs git clone "https://github.com/nxp-nfc-infra/nfcandroid_infra_comm_libs.git" cd nfcandroid_infra_comm_libs git checkout br_ar_16_comm_infra_dev cp -rf nfc_tda/ ../android_build/packages/modules/Nfc/libnfc-nci/ cp -rf emvco_tda/ emvco_tda_test/ ../android_build/hardware/nxp/emvco/ cp -rf NfcTdaTestApp/ ../android_build/packages/apps/ cd ..   6. Put changes into hardwatre/interfaces/compatibility_matrices  File: hardware/interfaces/compatibility_matrices/compatibility_matrix.202504.xml <hal format="aidl"> <name>android.hardware.audio.effect</name> <version>1-3</version> <interface> <name>IFactory</name> <instance>default</instance> </interface> </hal> <hal format="aidl" optional="true"> <name>nxp.hardware.imx_dek_extractor</name> <version>1</version> <interface> <name>IDek_Extractor</name> <instance>default</instance> </interface> </hal> <hal format="aidl" optional="true"> <name>nxp.hardware.ele</name> <version>1</version> <interface> <name>ISecureEnclave</name> <instance>default</instance> </interface> </hal> <hal format="aidl" optional="true"> <name>vendor.nxp.nxpnfc_aidl</name> <version>2</version> <interface> <name>INxpNfc</name> <instance>default</instance> </interface> </hal> <hal format="aidl" optional="true"> <name>vendor.nxp.emvco</name> <version>1</version> <interface> <name>INxpEmvco</name> <instance>default</instance> </interface> </hal> <hal format="aidl" updatable-via-apex="true"> <name>android.hardware.authsecret</name> <version>1</version> <interface> <name>IAuthSecret</name> <instance>default</instance> </interface> </hal>   7. Add the firmware $ git clone https://github.com/NXP/nfc-NXPNFCC_FW.git $ cp -r nfc-NXPNFCC_FW/InfraFW/pn7220/64-bit-2.5/pn7220_64bits.so android_build/vendor/nxp/pn7220/firmware/lib64/libpn72xx_fw.so   8. Add the NXPAndroidDTA $git clone https://github.com/NXPNFCProject/NXPAndroidDTA.git $cd NXPAndroidDTA $git checkout br_ar_new_dta_arch cp -r NXPAndroidDTA android_build/vendor/nxp/   9. Some fixes before build: $ cd android_build $ mv hardware/nxp/nfc/snxxx/Android.bp hardware/nxp/nfc/snxxx/_Android.bp $ mv hardware/nxp/nfc/snxxx/halimpl/power-tracker/Android.bp hardware/nxp/nfc/snxxx/halimpl/power-tracker/_Android.bp $ mv hardware/nxp/secure_element/snxxx/aidl/Android.bp hardware/nxp/secure_element/snxxx/aidl/_Android.bp $ cd hardware/nxp/nfc $ rm pn8x -rf   Now, build the Android BSP again. Use "mm" to build the Android source code. After fixed all the errors of the AOSP build, use "imx-make.sh" to build the whole i.MX Android image.    When building the Android, there may have some errors during the build. I listed some errors and the workaround below for your reference.   Error: error: packages/modules/Nfc/tests/cts/tests/Android.bp:20:1: "CtsNfcTestCases" depends on undefined module "CtsAppTestStubsShared". Workaround : Comment out "CtsAppTestStubsShared" in packages/modules/Nfc/tests/cts/tests/Android.bp     Error: error: hardware/nxp/nfc/snxxx/halimpl_v2/power-tracker/Android.bp:17:1: "power_tracker_v2" depends on undefined module "nfc_nci_nxp_snxxx_headers_v2". Workaround: mv hardware/nxp/nfc/snxxx/halimpl_v2/power-tracker/Android.bp hardware/nxp/nfc/snxxx/halimpl_v2/power-tracker/_Android.bp     Error: error: platform_testing/Android.bp:255:1: module "continuous_native_tests" variant "android_common": depends on //packages/modules/Nfc/NfcNci/nci/jni:libnfc-nci-jni-tests which is not visible to this module You may need to add "//platform_testing" to its visibility error: platform_testing/Android.bp:255:1: module "continuous_native_tests" variant "android_common": depends on //packages/modules/Nfc/libnfc-nci/tests:libnfc-nci-tests which is not visible to this module You may need to add "//platform_testing" to its visibility Workaround: nano packages/modules/Nfc/NfcNci/nci/jni/Android.bp In cc_test {     name: "libnfc-nci-jni-tests", .. ..     visibility: [         "//platform_testing:__subpackages__",     ], Same in packages/modules/Nfc/libnfc-nci/tests/Android.bp     Error: FAILED: out/soong/.intermediates/packages/modules/Nfc/framework/framework-nfc.stubs.source.system/android_common/exportable/framework-nfc.stubs.source.system-stubs.srcjar out/soong/.intermediates/packages/modules/Nfc/framework/framework-nfc.stubs.source.system/android_common/exportable/framework-nfc.stubs.source.system_annotations.zip out/soong/.intermediates/packages/modules/Nfc/framework/framework-nfc.stubs.source.system/android_common/exportable/framework-nfc.stubs.source.system_api.txt out/soong/.intermediates/packages/modules/Nfc/framework/framework-nfc.stubs.source.system/android_common/exportable/framework-nfc.stubs.source.system_removed.txt out/soong/.intermediates/prebuilts/sdk/framework-nfc.api.system.latest/gen/framework-nfc.api.system.latest:52: error: Binary breaking change: Removed method android.nfc.NfcOemExtension.emulateNfcTechnologyATag(boolean,byte,byte,byte,byte[],byte,byte[]) [RemovedMethod] out/soong/.intermediates/prebuilts/sdk/framework-nfc.api.system.latest/gen/framework-nfc.api.system.latest:64: error: Binary breaking change: Removed method android.nfc.NfcOemExtension.overwriteRoutingTable(int,int,int,int,int) [RemovedMethod] out/soong/.intermediates/prebuilts/sdk/framework-nfc.api.system.latest/gen/framework-nfc.api.system.latest:77: error: Binary breaking change: Removed field android.nfc.NfcOemExtension.EMULATE_NFC_A_TAG_STATUS_FAILED_INTERNAL [RemovedField] out/soong/.intermediates/prebuilts/sdk/framework-nfc.api.system.latest/gen/framework-nfc.api.system.latest:78: error: Binary breaking change: Removed field android.nfc.NfcOemExtension.EMULATE_NFC_A_TAG_STATUS_FAILED_NFC_NOT_ENABLED [RemovedField] out/soong/.intermediates/prebuilts/sdk/framework-nfc.api.system.latest/gen/framework-nfc.api.system.latest:79: error: Binary breaking change: Removed field android.nfc.NfcOemExtension.EMULATE_NFC_A_TAG_STATUS_OK [RemovedField] out/soong/.intermediates/prebuilts/sdk/framework-nfc.api.system.latest/gen/framework-nfc.api.system.latest:120: error: Binary breaking change: Removed method android.nfc.NfcOemExtension.Callback.onRoutingChangeCompleted() [RemovedMethod] out/soong/.intermediates/prebuilts/sdk/framework-nfc.api.system.latest/gen/framework-nfc.api.system.latest:160: error: Binary breaking change: Removed method android.nfc.RoutingStatus.getDefaultFelicaRoute() [RemovedMethod] Aborting: Found compatibility problems checking the public API (/home/nxa08017/android16_1.4.0/android_build/out/soong/.temp/sbox/d1717a17fe92a8b2da806db0f1cb87830019487b/packages/modules/Nfc/framework/java) against the API in /home/nxa08017/android16_1.4.0/android_build/out/soong/.temp/sbox/d1717a17fe92a8b2da806db0f1cb87830019487b/./out/soong/.intermediates/prebuilts/sdk/framework-nfc.api.public.latest/gen/framework-nfc.api.public.latest exit status 255 Workaround: Comment out the lines 52,64,77,78,79,120,160 in out/soong/.intermediates/prebuilts/sdk/framework-nfc.api.system.latest/gen/framework-nfc.api.system.latest     Error: out/soong/.intermediates/prebuilts/sdk/framework-nfc.api.public.latest/gen/framework-nfc.api.public.latest:77: error: Binary breaking change: Removed method android.nfc.NfcAdapter.isExitFramesSupported() [RemovedMethod] out/soong/.intermediates/prebuilts/sdk/framework-nfc.api.public.latest/gen/framework-nfc.api.public.latest:80: error: Binary breaking change: Removed method android.nfc.NfcAdapter.isPowerSavingModeEnabled() [RemovedMethod] out/soong/.intermediates/prebuilts/sdk/framework-nfc.api.public.latest/gen/framework-nfc.api.public.latest:81: error: Binary breaking change: Removed method android.nfc.NfcAdapter.isPowerSavingModeSupported() [RemovedMethod] out/soong/.intermediates/prebuilts/sdk/framework-nfc.api.public.latest/gen/framework-nfc.api.public.latest:91: error: Binary breaking change: Removed method android.nfc.NfcAdapter.setPowerSavingMode(boolean) [RemovedMethod] out/soong/.intermediates/prebuilts/sdk/framework-nfc.api.public.latest/gen/framework-nfc.api.public.latest:196: error: Binary breaking change: Removed method android.nfc.cardemulation.CardEmulation.getPollingLoopFiltersForService(android.content.ComponentName) [RemovedMethod] out/soong/.intermediates/prebuilts/sdk/framework-nfc.api.public.latest/gen/framework-nfc.api.public.latest:197: error: Binary breaking change: Removed method android.nfc.cardemulation.CardEmulation.getPollingLoopPatternFiltersForService(android.content.ComponentName) [RemovedMethod] out/soong/.intermediates/prebuilts/sdk/framework-nfc.api.public.latest/gen/framework-nfc.api.public.latest:202: error: Binary breaking change: Removed method android.nfc.cardemulation.CardEmulation.isDeviceScreenOnRequiredForService(android.content.ComponentName) [RemovedMethod] out/soong/.intermediates/prebuilts/sdk/framework-nfc.api.public.latest/gen/framework-nfc.api.public.latest:203: error: Binary breaking change: Removed method android.nfc.cardemulation.CardEmulation.isDeviceUnlockRequiredForService(android.content.ComponentName) [RemovedMethod] out/soong/.intermediates/prebuilts/sdk/framework-nfc.api.public.latest/gen/framework-nfc.api.public.latest:214: error: Binary breaking change: Removed method android.nfc.cardemulation.CardEmulation.setRequireDeviceScreenOnForService(android.content.ComponentName,boolean) [RemovedMethod] out/soong/.intermediates/prebuilts/sdk/framework-nfc.api.public.latest/gen/framework-nfc.api.public.latest:215: error: Binary breaking change: Removed method android.nfc.cardemulation.CardEmulation.setRequireDeviceUnlockForService(android.content.ComponentName,boolean) [RemovedMethod] out/soong/.intermediates/prebuilts/sdk/framework-nfc.api.public.latest/gen/framework-nfc.api.public.latest:248: error: Binary breaking change: Removed method android.nfc.cardemulation.CardEmulation.NfcEventCallback.onOffHostAidSelected(String,String) [RemovedMethod] Aborting: Found compatibility problems checking the public API (/home/nxa08017/android16_1.4.0/android_build/out/soong/.temp/sbox/6245059c063e0ae76fa4356a9b840b923ddb8764/packages/modules/Nfc/framework/java) against the API in /home/nxa08017/android16_1.4.0/android_build/out/soong/.temp/sbox/6245059c063e0ae76fa4356a9b840b923ddb8764/./out/soong/.intermediates/prebuilts/sdk/framework-nfc.api.public.latest/gen/framework-nfc.api.public.latest exit status 255 Workaround: Same as the previous workaround. Comment out the lines (line number shown in error) in out/soong/.intermediates/prebuilts/sdk/framework-nfc.api.public.latest/gen/framework-nfc.api.public.latest.     Error: FAILED: out/soong/.intermediates/system/sepolicy/vendor_sepolicy.cil.raw/android_common/evk_95/vendor_sepolicy.cil.raw out/host/linux-x86/bin/checkpolicy -C -M -L -c 30 -o out/soong/.intermediates/system/sepolicy/vendor_sepolicy.cil.raw/android_common/evk_95/vendor_sepolicy.cil.raw out/soong/.intermediates/system/sepolicy/vendor_sepolicy.conf/android_common/evk_95/vendor_sepolicy.conf && out/host/linux-x86/bin/build_sepolicy filter_out -f out/soong/.intermediates/system/sepolicy/reqd_policy_mask.cil/android_common/reqd_policy_mask.cil -t out/soong/.intermediates/system/sepolicy/vendor_sepolicy.cil.raw/android_common/evk_95/vendor_sepolicy.cil.raw # hash of input list: 7a5f97fdfa590e2ec5a2c6b745c65293680d0202c9b5869c1425905c209b9bf1 vendor/nxp/emvco/sepolicy/service.te:1:ERROR 'Duplicate declaration of type' at token ';' on line 21764: type hal_emvco_service, hal_service_type, service_manager_type; #line 1 "vendor/nxp/emvco/sepolicy/service.te" checkpolicy:  error(s) encountered while parsing configuration 11:50:27 ninja failed with: exit status 1 Workaround: nano vendor/nxp/emvco/sepolicy/hwservice.te Change the hal_emvco_service to hal_emvco_hwservice like this: type hal_emvco_hwservice, hwservice_manager_type;   nano vendor/nxp/emvco/sepolicy/hwservice_contexts vendor.nxp.emvco::INxpEmvco                             u:object_r:hal_emvco_hwservice:s0   nano vendor/nxp/emvco/sepolicy/hal_emvco_default.te + allow hal_emvco_default hal_emvco_hwservice:hwservice_manager { add find };   Error: FAILED: out/soong/.intermediates/hardware/nxp/nfc/intf/nxpnfc/aidl/vendor.nxp.nxpnfc_aidl_interface/checkhash_2.timestamp if [ $(cd 'hardware/nxp/nfc/intf/nxpnfc/aidl/aidl_api/vendor.nxp.nxpnfc_aidl/2' && { find ./ -name "*.aidl" -print0 | LC_ALL=C sort -z | xargs -0 sha1sum && echo 1; } | sha1sum | cut -d " " -f 1) = $(tail -1 'hardware/nxp/nfc/intf/nxpnfc/aidl/aidl_api/vendor.nxp.nxpnfc_aidl/2/.hash') ]; then touch out/soong/.intermediates/hardware/nxp/nfc/intf/nxpnfc/aidl/vendor.nxp.nxpnfc_aidl_interface/checkhash_2.timestamp; else cat 'system/tools/aidl/build/message_check_integrity.txt' && exit 1; fi ############################################################################### # ERROR: Modification detected of stable AIDL API file                        # ############################################################################### Above AIDL file(s) has changed, resulting in a different hash. Hash values may be checked at runtime to verify interface stability. If a device is shipped with this change by ignoring this message, it has a high risk of breaking later when a module using the interface is updated, e.g., Mainline modules. Workaround: echo $(cd 'hardware/nxp/nfc/intf/nxpnfc/aidl/aidl_api/vendor.nxp.nxpnfc_aidl/2' && { find ./ -name "*.aidl" -print0 | LC_ALL=C sort -z | xargs -0 sha1sum && echo 1; } | sha1sum | cut -d " " -f 1) d9e99a62ff5ebed44083a79577ec7ed32d264775 Then,  nano hardware/nxp/nfc/intf/nxpnfc/aidl/aidl_api/vendor.nxp.nxpnfc_aidl/2/.hash replace the value to d9e99a62ff5ebed44083a79577ec7ed32d264775   A runtime error: Problem: You will find the following failed about the permission in the log. java.lang.IllegalStateException: Signature|privileged permissions not in privileged permission allowlist: {com.android.nfc (/apex/com.android.nfcservices/priv-app/[email protected]😞 android.permission.OBSERVE_ROLE_HOLDERS}   Workaround: Add :     <privapp-permissions package="com.android.nfc">         <permission name="android.permission.OBSERVE_ROLE_HOLDERS"/>     </privapp-permissions> To the file : out/target/product/evk_95/system/etc/permissions/privapp-permissions-platform.xml     10. Download the image to the target board: - We use the tool UUU to download the image to the i.MX boards. Download the UUU from here : Releases · nxp-imx/mfgtools - Download the Android 16 BSP i.MX95 EVK demo image from the Android i.MX BSP web page first. There are UUU script and necessary image files already in the demo image package.  - Put the UUU executable file into the demo image folder. uuu_imx_android_flash.bat is the script also in the same folder. - After your Android BSP building is completed and succeed, copy the images to the demo image folder. The image files are located in android_build/out/target/product/evk_95/. - Switch the boot mode to "Download" mode on the i.MX95 FRDM board. - Run the UUU script to download the images to the FRDM board. uuu_imx_android_flash.bat -f imx95 -a -e -u 15x15-frdm -d 15x15-frdm     Run the "TagInfo" on the board: - Download the TagInfo apk file from the NXP TagInfo App web page . - Use the "adb install" command to install the TagInfo to the FRDM board. C:\>adb install com.nxp.taginfo-6.2.0-play-release-protected.apk * daemon not running; starting now at tcp:5037 * daemon started successfully Performing Streamed Install Success   After TagInfo installed, the TagInfo icon will be available on the GUI.   Run the TagInfo, and then put a card on the board. The information of the card will be show on the TagInfo App.     Reference: PN7160/PN7220 – Android 16 porting guide PN7220 NFC Frontend IC with Integrated Power Management | NXP Semiconductors Android OS for i.MX Applications Processors | NXP Semiconductors nxp-nfc-infra · GitHub
記事全体を表示
The TDAEV8035 evaluation board is inserted into the connector slot located on the top side of the PN7642 EVK, as shown in the figure below.     Dedicated jumper settings are required to ensure proper connection and operation of the TDAEV8035 extension board.   J23 - Position 2-3 J65, J63, J64 - Closed  J59 - Closed (Positions 1-2, 3-4, 5-6) Once the jumpers are configured correctly, users can run the example applications provided in the PN7642 MCUXpresso SDK.     After building the example project, select the right card slot (TDA8035) on the board. By default, the SIM card slot (Slot 1) is used. To use the contact card slot instead, modify the slot selection in the following section of the code.     E_AUX_SLOT1 - SIM slot (default)  E_AUX_SLOT2 - Contact card slot  The selected card slot is indicated by a red LED. D1 - SIM slot  D2 - Contact Card slot Once all required settings have been applied, the example application can be started and a contact card can be inserted into the selected card slot.    The results can be viewed in the console.
記事全体を表示
Prerequisites:  CLRC663 plus Low Power Card Detection   1// Antenna Size  The stronger the coupling between reader and card, the better the detection range.  Ideally, the NFC reader antenna should have a size and form factor similar to that of the target NFC tag antenna. In practice, the reader antenna is typically designed to be slightly larger—by approximately 10% to 20%—to ensure reliable coupling and performance.   2// Antenna Q-factor  Higher Q-factor typically serves higher detection range. The Q-factor should be selected in accordance with the target communication bit rate.(e.g. Q≈30 for 106 kbit/s).  The antenna Q factor is mainly defined by the mechanical design of the antenna itself, as well as by external damping resistors. However, for LPCD-insensitive systems, a zero-ohm damping resistor can be used, and the system should then be evaluated through testing.  3// Target tuning  The CLRC663 should typically be used with the asymmetrical tuning as there is no internal power regulation implemented.  However, in some cases, symmetrical tuning may be beneficial, as it can improve detection range and sensitivity. Care must be taken to ensure that, under varying conditions—such as antenna loading by different NFC tags or the presence of nearby metal, the TVDD current does not exceed the specified maximum limits.   In CLRC663 LPCD operation, detection performance improves with higher TX power. However, this also increases current consumption, so an appropriate trade-off must be determined.   As a starting point, an antenna impedance of approximately Z≈ 50 Ω can be used.   4// Receiver setting (external Rx resistors) Based on the AN11019 (chapter 4.4.1), the peak voltage between RxN and GND (or RxP and GND) shall be in the range of 1.2Vp - 1.7Vp. Generally, higher Rx voltage levels improve detection range. To increase LPCD sensitivity and range, it can be advantageous to operate close to the upper limit of the allowed Rx voltage.   Please note that excessively high RX voltage may lead to immediate false wake-ups.   5//LPCD Settings As a starting point, we recommend using the following settings:   These settings provide robust immunity against false wake-ups and are highly efficient in terms of current consumption. The typical detection range for standard NFC tags is approximately 10 mm to 20 mm or even less in an application where the antenna is placed near a metal environment. Detection performance can be further improved by lowering the threshold settings +0 and -0. If this settings is used, we strongly advice using LPCD_FILTER feature as well. Alternatively, the user can use "high detection range option" + LPCD_FILTER. After using these settings, we recommend running "Endless LPCD" for a while and checking for any false wake-up rates. Note: The LPCD filter feature helps prevent false wake-ups. This is especially important when the threshold is set to +0 and -0. When using thresholds of +0 and −0 it is also recommended to set the "CWMAX" parameter (address 0x2A) to 1b. 5.1// LPCD RF ON time  If the RF on-time is shorter than approximately 20 µs - 30 µs , the primary detuning effect is dominated by the physical design of the NFC tag. For longer RF on-times, the NFC tag becomes energized, and its electrical parameters begin to contribute significantly to the overall detuning. Based on this understanding, a longer RF on-time can help increase LPCD detection range. However, this comes at the cost of higher current consumption. Therefore, it is recommended to compensate by adjusting the RF off-time. See an example below.   5.2// LPCD Charge pump  This function allows the TX power to be increased exclusively during the LPCD RF On time.   This can be beneficial if you want to avoid increasing the power in active mode (e.g., by reducing the tuning impedance) but only increase it during LPCD operation.   By activating the LPCD charge pump, detection performance can be improved, but at the cost of increased current consumption.   If this feature is enabled, it is recommended to verify the LPCD RF ping using an oscilloscope. It may be necessary to increase the RF On time to allow the amplitude to properly settle. Especially for TVDD= 3.3V or lower. 6// Summary   Mode  Tuning function Target impedance Q-factor Receiver voltage LPCD Threshold LPCD Filter LPCD Charge -pump RF On time  Standard Asymmetrical  20 Ω - 80 Ω  10 - 30 1.5 Vp +1 and -1 disable disable 10 us High detection range  Asymmetrical /Symmetrical (1) 20 Ω - 50 Ω >25 (2) 1.7 Vp +0 and -0 enable enable/ disable (3)  20 us-100 us   Note (1): Symmetrical tuning can only be applied if the TVDD current does not exceed the maximum allowable value after antenna loading caused by a card or metal object. Please ensure that this condition is met. Note (2): If high detection performance is required, the external antenna damping resistors are typically replaced with 0 Ω resistors, resulting in a higher antenna Q-factor. In this case, the user must verify that NFC communication continues to operate reliably. Due to the increased Q-factor, this configuration is typically limited to communication speeds of 106 kbit/s Note (3): Once the charge pump is enabled, the RF On time should be verified and adjusted if necessary. Please also note that the relationship between TX power and detection distance is not linear or unlimited. Beyond a certain point, enabling the charge pump provides only marginal improvements in detection distance.     Please note that the High Detection mode is generally more susceptible to false wake-ups and results in higher current consumption than the standard mode.
記事全体を表示
Introduction We have an official PN7160/PN7220 Android 15 porting guide (PN7160/PN7220 – Android 15 porting guide). But the patches only for Android 15 AOSP r1 (android-15.0.0_r1). If customer want to porting to the newer release of AOSP, there will have many errors during the source code compiling. This document is for customer reference to solve the error one by one.    NOTE :  All the modifications are just for reference. They are NOT a NXP official patches for the newer release of AOSP porting. So the modifications may not be the best solution. Customer please base on their needs to modify the AOSP source code. This is not for production. Customer still need to perform full testing after the porting.    Hardware boards: i.MX8MN EVK (i.MX 8M Nano Evaluation Kit | NXP Semiconductors)   PN7160 EVK (OM27160| Development Kits for PN7160 Plug'n Play NFC Controller | NXP Semiconductors)     The connection between i.MX8MN EVK and PN7160 OM29110ARD-B i.MX8M Nano EVK pin PN7160 pin 3.3V J1003-1 VDD(3.3v) J1-4 5V J1003-2 VBAT (5v) J1-5  I2C3 SDA J1003-3 SDA J2-2 I2C3 SCL J1003-5 SCL J2-1 GPIO3_22 J1003-37 IRQ J2-10 GPIO3_21 J1003-38 REQ J4-2 GND J1003-39 GND J1-6 GPIO3_20 J1003-40 VEN J4-1     Build the Android for i.MX8MN EVK The i.MX Android BSP that I used is Android 15.0.0_2.0.0 (L6.12.20_2.0.0 BSP). It could be downloaded from here: Android OS for i.MX Applications Processors | NXP Semiconductors 1. Download the "Documentation" and the "Install Source Package".  2. Follow the steps in Android User's Guide to build the Android BSP for i.MX8MN EVK first.    According to the android_build/.repo/manifests/aosp-android-15.0.0_2.0.0.xml, you will see the AOSP version is android-15.0.0_r32.   Reference documents for porting: PN7160/PN7220 – Android 15 porting guide  Porting PN7160 to Android 14 on i.MX8M Nano board   Now, we start the porting:  1. Kernel Driver To establish connection with the PN7220 or PN7160, the Android stack uses the nxpnfc kernel driver.  You could download the driver from github below: nfcandroid_platform_drivers/drivers at br_ar_16_comm_infra_dev · nxp-nfc-infra/nfcandroid_platform_d...   The command is : git clone "https://github.com/nxp-nfc-infra/nfcandroid_platform_drivers.git" -b br_ar_16_comm_infra_dev   There is driver for Kernel 6.6 and 6.12. So, please download the correct one for your porting. For example, the kernel in i.MX Android BSP Android 15.0.0_2.0.0 is 6.12. So I will use the 6.12 driver for my porting.   In your porting, make sure the PATH in Makefile and Kconfig files are setting properly.  For example in my porting: . ├── Kconfig ├── Makefile └── pn7160 ├── common.c ├── common.h ├── i2c_drv.c ├── i2c_drv.h ├── Kbuild ├── Kconfig ├── Makefile ├── spi_drv.c └── spi_drv.h   For simplifying everything, we will only add a support for I2C and not SPI. Replace drivers/nfc/pn7160/Makefile default code with following code (for easier understanding) nxpnfc-i2c-objs = i2c_drv.o common.o obj-$(CONFIG_NXP_NFC_I2C) += nxpnfc_i2c.o   The contents of drivers/nfc/Kconfig. Add the PN7160 like below: source "drivers/nfc/pn7160/Kconfig" source "drivers/nfc/fdp/Kconfig" source "drivers/nfc/pn544/Kconfig" source "drivers/nfc/pn533/Kconfig" source "drivers/nfc/microread/Kconfig" source "drivers/nfc/nfcmrvl/Kconfig" source "drivers/nfc/st21nfca/Kconfig" source "drivers/nfc/st-nci/Kconfig" source "drivers/nfc/nxp-nci/Kconfig" source "drivers/nfc/s3fwrn5/Kconfig" source "drivers/nfc/st95hf/Kconfig" endmenu   The contents of drivers/nfc/Makefile. Add the PN7160 like below: # SPDX-License-Identifier: GPL-2.0 # # Makefile for nfc devices # obj-$(CONFIG_NXP_NFC_I2C) += pn7160/ obj-$(CONFIG_NFC_FDP) += fdp/ obj-$(CONFIG_NFC_PN544) += pn544/ obj-$(CONFIG_NFC_MICROREAD) += microread/ obj-$(CONFIG_NFC_PN533) += pn533/ obj-$(CONFIG_NFC_MEI_PHY) += mei_phy.o obj-$(CONFIG_NFC_SIM) += nfcsim.o obj-$(CONFIG_NFC_PORT100) += port100.o obj-$(CONFIG_NFC_MRVL) += nfcmrvl/ obj-$(CONFIG_NFC_TRF7970A) += trf7970a.o obj-$(CONFIG_NFC_ST21NFCA) += st21nfca/ obj-$(CONFIG_NFC_ST_NCI) += st-nci/ obj-$(CONFIG_NFC_NXP_NCI) += nxp-nci/ obj-$(CONFIG_NFC_S3FWRN5) += s3fwrn5/ obj-$(CONFIG_NFC_ST95HF) += st95hf/ obj-$(CONFIG_NFC_VIRTUAL_NCI) += virtual_ncidev.o   2. Adding the "nxpnfc" to the i.MX8MN EVK device tree file &i2c3 { clock-frequency = <100000>; pinctrl-names = "default", "gpio"; pinctrl-0 = <&pinctrl_i2c3>; pinctrl-1 = <&pinctrl_i2c3_gpio>; scl-gpios = <&gpio5 18 GPIO_ACTIVE_HIGH>; sda-gpios = <&gpio5 19 GPIO_ACTIVE_HIGH>; status = "okay"; nxpnfc@28{ compatible = "nxp,nxpnfc"; reg = <0x28>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_nfc>; nxp,nxpnfc-irq = <&gpio3 22 0>; nxp,nxpnfc-ven = <&gpio3 20 0>; nxp,nxpnfc-fw-dwnld = <&gpio3 21 0>; }; The GPIO settings in the IOMUXC: &iomuxc { pinctrl_nfc: nfcgrp { fsl,pins = < MX8MN_IOMUXC_SAI5_RXC_GPIO3_IO20 0X19 // VEN MX8MN_IOMUXC_SAI5_RXD0_GPIO3_IO21 0X19 // FW-DWNLD MX8MN_IOMUXC_SAI5_RXD1_GPIO3_IO22 0X19 // IRQ >; };   3. Modify the imx8mn_gki.fragment File:  android_build/vendor/nxp-opensource/kernel_imx/arch/arm64/configs/imx8mn_gki.fragment Add the "CONFIG_NXP_NFC_I2C=m" into the imx8mn_gki.fragment   4. Add the settings in your corresponding board configuration files in Android - Go to the android_build/device/nxp/imx8m/evk_8mn/  - Modify the BoardConfig.mk. # selinux permissive + BOARD_KERNEL_CMDLINE += androidboot.selinux=permissive BOARD_SEPOLICY_DIRS := \ $(CONFIG_REPO_PATH)/imx8m/sepolicy \ $(IMX_DEVICE_PATH)/sepolicy \ + vendor/nxp/nfc/sepolicy \ + vendor/nxp/nfc/sepolicy/nfc + include vendor/nxp/nfc/BoardConfigNfc.mk   - Add the "nxpnfc_i2c.ko" to the ShareBoardConfig.mk. Make sure the path and the filename are correct. $(KERNEL_OUT)/drivers/net/phy/realtek.ko \ $(KERNEL_OUT)/drivers/pps/pps_core.ko \ $(KERNEL_OUT)/drivers/ptp/ptp.ko \ $(KERNEL_OUT)/drivers/net/ethernet/freescale/fec.ko + $(KERNEL_OUT)/drivers/nfc/pn7160/nxpnfc_i2c.ko endif $(KERNEL_OUT)/drivers/trusty/trusty-core.ko \ $(KERNEL_OUT)/drivers/trusty/trusty-log.ko \ $(KERNEL_OUT)/drivers/trusty/trusty-ipc.ko \ $(KERNEL_OUT)/drivers/trusty/trusty-virtio.ko \ + $(KERNEL_OUT)/drivers/nfc/pn7160/nxpnfc_i2c.ko else BOARD_VENDOR_RAMDISK_KERNEL_MODULES += \ $(KERNEL_OUT)/drivers/input/touchscreen/goodix_ts.ko \ $(KERNEL_OUT)/drivers/input/touchscreen/synaptics_dsx/synaptics_dsx_i2c.ko Endif   - Add the following to the Compatibility_matrix.xml <compatibility-matrix version="1.0" type="device"> <hal format="native" optional="false"> <name>netutils-wrapper</name> <version>1.0</version> </hal> <hal format="aidl" optional="true"> <name>android.hardware.emvco</name> <version>1</version> <interface> <name>IEmvco</name> <instance>default</instance> </interface> </hal> </compatibility-matrix>   - Add the following to the device_framework_matrix.xml <compatibility-matrix version="1.0" type="framework"> <hal format="aidl" optional="true"> <name>nxp.hardware.secureime</name> <version>1</version> <interface> <name>ISecureIME</name> <instance>default</instance> </interface> </hal> <hal format="aidl" optional="true"> <name>nxp.hardware.imx_dek_extractor</name> <version>1</version> <interface> <name>IDek_Extractor</name> <instance>default</instance> </interface> </hal> <hal format="aidl" optional="true"> <name>vendor.nxp.nxpnfc</name> <version>2</version> <interface> <name>INxpNfc</name> <instance>default</instance> </interface> </hal> <hal format="aidl" optional="true"> <name>android.hardware.emvco</name> <version>1</version> <interface> <name>IEmvco</name> <instance>default</instance> </interface> </hal> </compatibility-matrix>   - Add the following to the evk_8mn.mk # ------nfc------- $(call inherit-product, vendor/nxp/nfc/device-nfc.mk) $(call inherit-product, vendor/nxp/emvco/device-emvco.mk) PRODUCT_PACKAGES += \ android.hardware.nfc-service.nxp PRODUCT_PACKAGES += \ com.nxp.emvco \ com.nxp.nfc \ nfc_nci_nxp_pn72xx   - Add the nxpnfc_i2c in init.rc # Grant permission for fetching available_pages info of statsd chown system system /proc/pagetypeinfo chmod 0440 /proc/pagetypeinfo exec u:r:vendor_modprobe:s0 -- /vendor/bin/modprobe -a -d \ /vendor/lib/modules nxpnfc_i2c write /sys/power/wake_lock nosleep on post-fs-data && property:vendor.skip.charger_not_need=0 setprop vold.post_fs_data_done 1   - Add nxpnfc to ueventd.nxp.rc /sys/devices/virtual/thermal/thermal_zone* trip_point_0_hyst 0660 system system /sys/devices/virtual/thermal/thermal_zone* trip_point_1_hyst 0660 system system /dev/dmabuf_imx 0664 system system /sys/class/backlight/* brightness 0660 system system /dev/ttymxc1 0666 nfc nfc /dev/ttymxc2 0666 nfc nfc /dev/nxpnfc 0666 nfc nfc # for libcamera /dev/media* 0660 system camera /dev/v4l-subdev* 0660 system camera   5. Apply the NXP AOSP patches As the official NXP NFC patches is only for AOSP android-15.0.0_r1, and there are big different between android-15.0.0_r1 and android-15.0.0_r32. So, before apply the patches, I copy the nfc folders from android-15.0.0_r1 to replace the nfc folders in android-15.0.0_r32.   First, download the AOSP android-15.0.0_r1 from github. $ mkdir android-15.0.0_r1 $ cd android-15.0.0_r1 $ repo init -u https://android.googlesource.com/platform/manifest -b android-15.0.0_r1 $ repo sync   Then, remove the following folders from android-15.0.0_r32. And then copy the following nfc folders from android-15.0.0_r1 to replace the same folders in android-15.0.0_r32. packages/apps/Nfc frameworks/base/nfc frameworks/base/nfc-extras system/nfc   for example: $ rm -rf android_build/packages/apps/Nfc $ cp -ra android-15.0.0_r1/packages/apps/Nfc android_build/packages/apps/   I write a script to download the patches from the github. Customer could put the following scripts on the same directory with android_build. AOSP_adaptation.sh # nxp_nci_hal_nfc git clone "https://github.com/nxp-nfc-infra/nxp_nci_hal_nfc.git" cd nxp_nci_hal_nfc git checkout br_ar_15_comm_infra_dev cp -rf * ../android_build/packages/apps/Nfc/ cd .. # nxp_nci_hal_libnfc-nci git clone "https://github.com/nxp-nfc-infra/nxp_nci_hal_libnfc-nci.git" cd nxp_nci_hal_libnfc-nci git checkout br_ar_15_comm_infra_dev cp -rf * ../android_build/system/nfc/ cd .. # nfcandroid_nfc_hidlimpl git clone "https://github.com/nxp-nfc-infra/nfcandroid_nfc_hidlimpl.git" cd nfcandroid_nfc_hidlimpl git checkout br_ar_15_comm_infra_dev cp -rf * ../android_build/hardware/nxp/nfc cd .. # nfcandroid_frameworks git clone "https://github.com/nxp-nfc-infra/nfcandroid_frameworks.git" cd nfcandroid_frameworks git checkout br_ar_15_comm_infra_dev mkdir ../android_build/vendor/nxp/frameworks cp -rf * ../android_build/vendor/nxp/frameworks cd .. # nfcandroid_emvco_aidlimpl git clone "https://github.com/nxp-nfc-infra/nfcandroid_emvco_aidlimpl.git" cd nfcandroid_emvco_aidlimpl git checkout br_ar_15_comm_infra_dev mkdir ../android_build/hardware/nxp/emvco cp -rf * ../android_build/hardware/nxp/emvco cd .. # nfcandroid_platform_reference git clone "https://github.com/nxp-nfc-infra/nfcandroid_platform_reference.git" cd nfcandroid_platform_reference git checkout br_ar_15_comm_infra_dev cp -rf vendor/nxp/* ../android_build/vendor/nxp/ cd .. # nfcandroid_infra_test_apps git clone https://github.com/nxp-nfc-infra/nfcandroid_infra_test_apps.git cd nfcandroid_infra_test_apps/ git checkout br_ar_15_comm_infra_dev cd test_apps/ cp -rf SMCU_Switch/ ../../android_build/packages/apps/ cp -rf EMVCoModeSwitchApp/ ../../android_build/packages/apps/Nfc/ cp -rf load_unload/ ../../android_build/hardware/nxp/nfc/ cp -rf SelfTestAidl/ ../../android_build/hardware/nxp/nfc/ cd ../.. # nfcandroid_infra_comm_libs git clone "https://github.com/nxp-nfc-infra/nfcandroid_infra_comm_libs.git" cd nfcandroid_infra_comm_libs git checkout br_ar_15_comm_infra_dev cp -rf nfc_tda/ ../android_build/system/ cp -rf emvco_tda/ emvco_tda_test/ ../android_build/hardware/nxp/emvco/ cp -rf NfcTdaTestApp/ ../android_build/packages/apps/Nfc/ cd ..   Apply_patches.sh cd android_build/build/bazel/ patch -p1 < ../../../nfcandroid_platform_reference/build_cfg/build_pf_patches/AROOT_build_bazel.patch cd ../release patch -p1 < ../../../nfcandroid_platform_reference/build_cfg/build_pf_patches/AROOT_build_release.patch cd ../../external/libchrome patch -p1 < ../../../nfcandroid_platform_reference/build_cfg/build_pf_patches/AROOT_external_libchrome.patch cd ../../frameworks/base patch -p1 < ../../../nfcandroid_platform_reference/build_cfg/build_pf_patches/AROOT_frameworks_base.patch cd ../../system/logging patch -p1 < ../../../nfcandroid_platform_reference/build_cfg/build_pf_patches/AROOT_system_logging.patch   So, run the AOSP_adaptation.sh first, then run the Apply_patches.sh.   6. Put changes into hardwatre/interfaces/compatibility_matrices Different compatibility matrix for different Android versions. File: android_build/hardware/interfaces/compatibility_matrices/compatibility_matrix.202404.xml <hal format="aidl"> <name>android.hardware.audio.effect</name> <version>1-2</version> <interface> <name>IFactory</name> <instance>default</instance> </interface> </hal> + <hal format="aidl" optional="true"> + <name>nxp.hardware.imx_dek_extractor</name> + <version>1</version> + <interface> + <name>IDek_Extractor</name> + <instance>default</instance> + </interface> + </hal> + <hal format="aidl" optional="true"> + <name>vendor.nxp.nxpnfc</name> + <version>2</version> + <interface> + <name>INxpNfc</name> + <instance>default</instance> + </interface> + </hal> + <hal format="aidl" optional="true"> + <name>vendor.nxp.emvco</name> + <version>1</version> + <interface> + <name>INxpEmvco</name> + <instance>default</instance> + </interface> + </hal> <hal format="aidl"> <name>android.hardware.audio.sounddose</name> <version>1-3</version>   7. Change the device specific .mk For pn7160, NXP_NFC_HW should equal to pn7160. For pn7220, NXP_NFC_HW should equal to pn7220_i2cs.   File : android_build/vendor/nxp/nfc/device-nfc.mk ##### ##### NXP NFC Device Configuration makefile ###### NXP_NFC_HOST := $(TARGET_PRODUCT) ifndef TARGET_NXP_NFC_HW NXP_NFC_HW := pn7160 else NXP_NFC_HW := $(TARGET_NXP_NFC_HW) endif NXP_NFC_PLATFORM := pn54x NXP_VENDOR_DIR := nxp NXP_I2CM_S := $(TARGET_NXP_I2C_M_S)   File: android_build/vendor/nxp/emvco/device-emvco.mk NXP_VENDOR_DIR := nxp NXP_NFC_HW := $(TARGET_NXP_NFC_HW) ifeq ($(strip $(TARGET_NXP_NFC_HW)),) NXP_NFC_HW := pn7160 endif # Nfc service has dependency with EMVCo JAR PRODUCT_PACKAGES += \ com.nxp.emvco   8. Now, you can start to build the Android BSP For i.MX8MN EVK,  $ source build/envsetup.sh $ lunch evk_8mn-nxp_stable-userdebug $ export TARGET_RELEASE=nxp_stable $ build_build_var_cache $ ./imx-make.sh -j4 2>&1 | tee build-log.txt   When building the BSP, there will have many errors during the build. I list some errors and the reference solution below for customer reference.  Error :  Complain about the nfc_aconifg_flags.   Workaround : packages/apps/Nfc/flags/Android.bp aconfig_declarations { // name: "nfc_aconfig_flags", name: "com.android.nfc.flags-aconfig", package: "com.android.nfc.flags", container: "system", srcs: ["nfc_flags.aconfig"], } java_aconfig_library { // name: "nfc_aconfig_flags_lib", // aconfig_declarations: "nfc_aconfig_flags", name: "com.android.nfc.flags-aconfig-java", aconfig_declarations: "com.android.nfc.flags-aconfig", min_sdk_version: "33", apex_available: [ "//apex_available:platform", "com.android.nfcservices", ], } java_library { name: "nfc_flags_lib", sdk_version: "system_current", min_sdk_version: "33", srcs: [ "lib/**/*.java", ], static_libs: [ "com.android.nfc.flags-aconfig-java", ],   Error: platform_testing/build/tasks/tests/native_test_list.mk: error: continuous_native_tests: Unknown installed file for module 'libnfc-nci-jni-tests'   Workaround: remove 'libnfc-nci-jni-tests' in  native_test_list.mk   Error: error: packages/apps/Nfc/tests/instrumentation/Android.bp:6:1: module "NfcNciInstrumentationTests" variant "android_common": cannot depend directly on java_sdk_library "android.test.runner"; try depending on "android.test.runner.stubs", "android.test.runner.stubs.system", "android.test.runner.stubs.test", or "android.test.runner.impl" instead   Workaround:  The hints are gave in the error message.. Change the "android.test.runner" to "android.test.runner.stubs", "android.test.runner.stubs.system", "android.test.runner.stubs.test", or "android.test.runner.impl".   Error: error: vendor/nxp/frameworks/nfc/Android.bp:12:1: module "com.nxp.nfc" variant "android_common": depends on //frameworks/base/nfc:framework-nfc.impl which is not visible to this module You may need to add "//vendor/nxp/frameworks/nfc" to its visibility   Workaround: File : frameworks/base/nfc/Android.bp permitted_packages: [ "android.nfc", "com.android.nfc", ], impl_library_visibility: [ "//frameworks/base:__subpackages__", "//cts/hostsidetests/multidevices/nfc:__subpackages__", "//cts/tests/tests/nfc", "//vendor:__subpackages__", "//packages/apps/Nfc:__subpackages__", ],     Error: packages/apps/Nfc/nci/src/com/android/nfc/dhimpl/NativeT4tNfceeManager.java:20: error: duplicate class: com.android.nfc.dhimpl.NativeT4tNfceeManager   Workaround: Edit the file packages/apps/Nfc/nci/src/com/android/nfc/dhimpl/NativeT4tNfceeManager.java then comment out the duplicated class.   Error: android/R.java:12483: error: could not resolve field FLAG_NFC_ASSOCIATED_ROLE_SERVICES     .annotation.FlaggedApi(android.nfc.Flags.FLAG_NFC_ASSOCIATED_ROLE_SERVICES)   Workaround: Edit the file frameworks/base/nfc/java/android/nfc/flags.aconfig Add the below flag. flag { name: "nfc_associated_role_services" is_exported: true namespace: "nfc" description: "Share wallet role routing priority with associated services" bug: "366243361" }   Error: FAILED: platform_testing/build/tasks/tests/native_test_list.mk: error: continuous_native_tests: Unknown installed file for module 'libnfc-nci-tests'   Workaround: Remove the libnfc-nci-tests in native_test_list.mk.   Error: prebuilts/clang/host/linux-x86/clang-r536225/include/c++/v1/string:780:43: error: implicit instantiation of undefined template 'std::char_traits<unsigned char>'   780 |   static_assert((is_same<_CharT, typename traits_type::char_type>::value),       |                                           ^ packages/apps/Nfc/nci/jni/NativeNfcTda.cpp:32:35: note: in instantiation of template class 'std::basic_string<unsigned char>' requested here    32 | static std::basic_string<uint8_t> sRxTdaDataBuff;       |                                   ^   Workaround: Edit the packages/apps/Nfc/nci/jni/NativeNfcTda.cpp using android::base::StringPrintf; extern bool nfc_debug_enabled; SyncEvent sCtLibSyncEvt; //static std::basic_string<uint8_t> sRxTdaDataBuff; static std::basic_string<char> sRxTdaDataBuff;   Error: packages/apps/Nfc/nci/jni/NativeT4tNfcee.cpp:493:21: error: no matching member function for call to 'append'   493 |       sRxDataBuffer.append(data.p_data, data.len);       |       ~~~~~~~~~~~~~~^~~~~~   Workaround:  Edit the packages/apps/Nfc/nci/jni/NativeT4tNfcee.cpp void NativeT4tNfcee::t4tReadComplete(tNFA_STATUS status, tNFA_RX_DATA data) { mT4tOpStatus = status; if (status == NFA_STATUS_OK) { if (data.len > 0) { sRxDataBuffer.insert(sRxDataBuffer.end(), data.p_data, data.p_data + data.len); LOG(DEBUG) << StringPrintf("%s: Read Data len new: %d ", __func__, data.len); } } SyncEventGuard g(mT4tNfcEeRWCEvent); mT4tNfcEeRWCEvent.notifyOne(); }   Error: frameworks/base/core/java/android/provider/Settings.java:2351: error: could not resolve field FLAG_NFC_ACTION_MANAGE_SERVICES_SETTINGS     @FlaggedApi(android.nfc.Flags.FLAG_NFC_ACTION_MANAGE_SERVICES_SETTINGS)   Workaround:  File: frameworks/base/nfc/java/android/nfc/flags.aconfig Add the following to the flags.aconfig flag { name: "nfc_action_manage_services_settings" is_exported: true namespace: "nfc" description: "Add Settings.ACTION_MANAGE_OTHER_NFC_SERVICES_SETTINGS" bug: "358129872" }   There are some errors are not listed in the table because there will have some hints to correct the error in the error message. Customer could follow the hints and base on the needs to modify the source code. Sometime, customer could compare the source code between r1 and r32. Here is the AOSP source code android-15.0.0_r32  and the android-15.0.0_r1.   9. Download the image to the i.MX8MN EVK board - Switch to download mode on the 8MN EVK board - Download the Android 15 BSP i.MX8MN EVK demo image from the Android BSP web page first. Because there are UUU script and necessary image files already in the demo image package.  - Download the UUU from here : Releases · nxp-imx/mfgtools - Put the UUU executable file into the demo image folder. uuu_imx_android_flash.bat is the script also in the same folder. - After your building is succeed, Copy the images to the demo image folder. The images are located in android_build/out/target/product/evk_8mn/ - Run the UUU script to download the images to the EVK board.     Reference: i.MX6ULL EVK running Yocto Linux + PN7160 Porting PN7160 to Android 14 on i.MX8M Nano board Android OS for i.MX Applications Processors | NXP Semiconductors PN7160/PN7220 – Android 15 porting guide Plug-n-Play NFC Frontend with Integrated Firmware | NXP Semiconductors
記事全体を表示
RF power regulation is a critical factor in the development of NFC devices, as it directly influences performance, reliability, and compliance with industry standards. There are three main reasons for this:  If the PN7642 VUP current exceeds the limit given by the product Data sheet, the PN7642 can be damaged. If too high RF power is radiated from the antenna, there exists a risk for NFC Cards. Too high RF power might lead to exceeding a given RF limit (NFC Forum, ISO, EMVCo). NXP provides comprehensive documentation on Dynamic Power Control for the PN7642 and PN5190. Designers are expected to adhere to these guidelines, especially when aiming for compliance with standards such as EMVCo. PN5190 Dynamic Power Control Quick Calibration and TxShaping Demo Automatic DPC Calibration for PN7642 and PN5190 However, if the user's design is intended for infrastructure applications, such as a smart lock. At a minimum, Dynamic Power Control (DPC) should be enabled to serve as a current limiter. The evaluation can be done with the help of NFC Cockpit.  1// Start DPC Calibration  "Press" Start DPC Calibration  "Press" Load protocol  Make sure that the DPC is "Enabled" 2// Adjust current reduction table  Set all entries to "0" Write into EEPROM   3// Set the "Target" current Use approx. the same current as "TxLDO Values"  The limit may be set higher, e.g., to 300 mA, if the purpose is solely to provide overcurrent protection for the IC. Save to EEPROM Restart the board (Close port -> Press VEN->Open port)   4// Check the power regulation  Start DPC Calibration  Place a card or any metal object in the antenna's proximity  Observe VDDPA and "TxLDO" current  The current should stay around the given target  The VDDPA will drop once the antenna is loaded  5// Set a minimum VDDPA in DPC  In the case that the current is still too high, a user can define a minimum VDDPA that is used for the DPC regulation. By default, this value is set to 2.2V. The user can decrease it up to 1.5V.  In that case, NXP also recommends disabling the RDOn control.  Note: The User has to consider the "DPC_TXLDO_MAX_DROPOUT" parameter, which defines the maximum voltage drop on TXLDO. By default, it is set to 3.6 V. That means if the user wants to use the minimum VDDPA 1.5 V, then the maximum TXLDO input shall not exceed 5.1 V. This feature protects the TXLDO from overheating.    Once the evaluation is done, the customer shall program the following EEPROM entries in their application. For more info, see PN7642 Product Data sheet.  DPC_CONFIG (Address: 0x0068) -> example: enabled -> 0x01 DPC_TARGET_CURRENT (Address: 0x0069) -> example: 229 mA -> 0xE5 DPC_TXLDO_MAX_DROPOUT (Addresses: 0x0073 - 0x0074) -> example: 3.6 V -> 0x10,0x0E DPC_TXLDOVDDPALow (Address: 0x006F) -> example: 1.5 V -> 0x00 DPC_HYSTERESIS_LOADING (Address: 0x006B) -> example: 20 mA -> 0x14 DPC_HYSTERESIS_UNLOADING (Address: 0x006E) -> example: 10 mA - 0x0A DPC lookup table entries (Addresses: 0x007D - 0x0125) -> example: for current limitation only -> all 0x00 If a user does not want to use a maximum range of VDDPA during DPC (5.7V), e.g., their system uses a 3.3V supply domain. Then, the maximum VDDPA in DPC can be limited by the following EEPROM settings:  TXLDO_VDDPA_MAX_RDR (Address: 0x0007)-> example: 3.0 V -> 0x0F Note: TXLDO has approx. 0.3V voltage drop. Always set this parameter 0.3V lower. Once this is done, the user has to check the "TxLDO" current and adjust the target current accordingly. In this case, to approximately 150 mA. If you don´t change it, the DPC starts to limit the power around 229 mA, as has been set in a previous step.
記事全体を表示
Prerequities:  PN7642 design-in recommendations   1// Impedance tuning  PN76 family antenna design guide The target impedance is chosen based on the target application. If full power is required (e.g., POS terminals). The target impedance of 15-17 Ω is recommended. For lower power applications using ULPCD, the higher impedance is typically preferred, 30-50 Ω (symmetrical tuning).   2// Dynamic power control  PN7642 - Basic RF power limitation using DPC   3// H-Field check  There are given limits, especially for the maximum H-field radiated by the reader. Exceeding these limits might lead to destroying the NFC Card/NFC Tag.   The H-Field can be measured with the help of test equipment, as  ISO 10373-6 Test PICC EMVCo 3.0 Test PICC  For indication only, the customers can use "smart" Field Strength Probes as shown below :        Note: The most critical position occurs when the card is placed directly on the NFC antenna . In this case, if the H-field exceeds the maximum allowed level, the output power must be reduced using DPC settings. 4// HF Attenuator value  Turn on the RF Field with the DPC set and enabled from the previous step  Read the CLIF_RXCTRL_STATUS register and check the HF_ATT_VAL as shown below.    The value for the "unloaded" condition with full power shall be approximately 35-45dec.  If the value is out of this range, the customer is required to adjust the Rx resistors to reach this value.  5// Receiver settings  Check the "Power" range and Communication Range with the default settings provided by NXP.  Power Range -> The distance at which the NFC Tag can still generate its answer, but the NFC Reader does not see it  Communication Range -> The distance at which the NFC Tag can still communitate with the NFC Reader  Ideally, Power Range ≈ Communication Range Also, the NFC Reader should not generate any false communications as e.g., "HAL COLLISION ERROR".  The optimisation of the receiver can be done in the following way:  Enter DPC Calibration  Go to the "ARC" menu and "disable" the ARC algorithm     This will force the IC to use the RX settings from the following Register/EEPROM SIGPRO_RM_TECH_REG DGRM_RSSI_REG   5.1// SIGPRO_RM_TECH_REG (RM_MF_GAIN parameter) This parameter basically defines the gain of the input amplifier.  Select SIGPRO_RM_TECH_REG  Switch "operation" to EEPROM and choose the required technology  Increase the RM_MF_GAIN to 0x02 (it depends on the setup).     5.2// DGRM_RSSI_REG (DGRM_SIGNAL_DETECT_TH_OVR_VAL parameter) This parameter defines a threshold from which the internal logic starts to decode the incoming signal.  If the threshold is too low or very close to the noise floor, the system can detect the noise as an NFC Communication.  It is therefore,  Threshold + margin > noise floor The best routine is to perform "Signal Detection Threshold" analysis. This can be done with the help of the NFC Cockpit (described in PN7642 design-in recommendations) As a result, the user can obtain the mean value of the "Noise," and suggested "DGRM_SIGNAL_DETECT_TH_OVR_VAL" threshold based on the inserted "Margin."  Maring (m) + Noise mean value (μ) = Threshold  6+16=23 Then this value shall be written in "DGRM_RSSI_REG" EEPROM as shown below.      6// ULPCD Settings  We recommend the following ULPCD Settings as a starting point.  ULPCD VDDPA should be chosen in such a way that the HF Attenuator value is not 0x00! The typical value for HF Attenuator in ULPCD is around 0x05-0x0B.   6.1// RSSI Threshold evaluation  For a proper RSSI Threshold selection, it is recommended to perform the ULPCD Calibration, e.g., 20 times, and check the "jitter" of the RSSI signal for your device.    If you see that the RSSI value is jittering, e.g., 1 unit as shown above. The absolute minimum threshold for this case is 2. However, it is always recommended to include adequate margin (To prevent false wake-ups).   Generally, the margin of 2 units is sufficient. So in this case, the optimum threshold will be 4.
記事全体を表示
A user can evaluate the current consumption of PN7642 in low power modes with the help of the PN7642 Evaluation Board (OM27642) and:  MCUXpresso SKD example (LPCD)  NFC Cockpit or MCUXpresso SKD example (ULPCD) NXP defines the current consumption in ULPCD/LPCD as VBAT current + VDDIO current for the LPCD/ULPCD cycle time of 330 ms. Make sure that DC/DC is disabled (for ULPCD).  Where:  VBAT current = VBAT_Current + VBATPWR_Current + VUP_Current See the snapshot from the PN7642 Datasheet below:    See where to measure the currents on PN7642 EVK: J63 and J64 are used for enabling/disabling the LEDs that are connected to PN7642 GPIOs. They must be disabled for a proper VDDIO current measurement.  A modification of R69 and R70 is necessary to perform the current measurement on VDDIO in LPCD mode.   1. ULPCD current consumption evaluation For the ULPCD evaluation, the NFC Cockpit or SDK example can be used. In this article, we will focus on evaluation using the NFC Cockpit.  See the used ULPCD configuration:  Note: The current should be measured as an average over, e.g., 30 seconds.  1.1 Overall ULPCD current measurement  To measure all currents together on PN7642 EVK, a user can create a measurement fixture as shown below:  Real setup :  Then the overall results look as follows: Note: The Antenna is tuned to approx. 35 Ohms  In this case, the ULPCD current is approximately 21 μA. This current can be further optimized, for more details, see -> AN14518(Start-up optimization in ULPCD (PN5190/PN7642/PN76AC)) 2. LPCD current consumption evaluation The user has to import the example (pnev7642fama_nfc_low_power_mode_Pub) from the PN7642 SDK.  Before building it, the following change in the code has to be made:  -> Comment line 84   A user can adjust the LPCD cycle time as shown below:   1.1 VBAT Current measurement    In this case, the VBAT current is approximately 123 μA. 1.2 VBATPWR current measurement  In this case, the VBAT_PWR current is approximately 91,8 μA. 1.3 VUP Current measurement  In this case, the VBAT_PWR current is approximately 32,8 μA.  Note: This current depends on the LPCD VDPPA settings + Antenna Impedance tuning  1.4 VDDIO Current measurement Note: Before VDDIO measurement, place jumpers J63 and J64 on PN7642 EVK. This will disable LEDs that are connected to PN7642 GPIOs.  The VDDIO current measurement requires the following steps:  Run the "pnev7642fama_nfc_low_power_mode_Pub" example  Once the example is running, disconnect the debugger (J-link, LPC-Link...) from J21 (NFC Debug connector)    Remove R70  Populate a 10K resistor on the R69 position (it disables the SWD interface) Once the measurement is done, change it back to the default state (R70=0R, R69=Open). Note: It is recommended to prepare the board with the option to easily populate or remove R70 and R69 when the LPCD example is running. E.g., with the help of jumpers/pin headers as shown below.   Only then will the correct VDDIO be measured on PN7642 EVK.  See the VDDIO current measurement below:    In this case, the VDDIO current is approximately 5,48 μA.  Then the overall current comsumption in LPCD is I_VBAT + I_VDDIO= (123 + 91,8 + 32,8 + 5,48) = 253,08 μA Note: For this measurement, the NFC Cockpit is not suitable because the IC does not go into standby mode between LPCD RF pings. Meaning LPCD works normally, but a user can measure higher current consumption. Used Ampere meter -> Power Profiler Kit II Measurement has been performed with FW 2.6  Board supply (jumpers J1, J2 and J4) -> 3.3V Please note that this measurement is indication only!
記事全体を表示
This post provides guidance on how to port the example projects from the NXP NCI 2.0 NFC library to the MCXW71 Wireless MCU using SPI interface to communicate with PN7160 SPI EVK. To follow this guide, please use the following environment: MCUXpresso IDE 25.06.136. FRDM-MCXW71 SDK v25.12.00 (last available for MCUXpresso IDE). FRDM-MCXW71. OM27160B1 (PN7160 SPI EVK). Hardware Setup. The MCXW71 complies with the Arduino header standard as the OM27160B1 board, therefore you can connect directly the shield over the FRDM-MCXW71 as the pin connection match among both, allowing an easy connection between the devices. Take into consideration that this setup forces us to use the LPSPI1 instance of the MCXW71, it is possible to use another instance, but we would not be able to connect the boards directly, rather we would need to do the connections with jumpers. Downloading base projects and adapting for MCXW71 port. To start with the porting work, download the NXP-NCI example project from this page. This compressed file contains the base project for different boards that will allow us to do the required modifications to add support for the MCXW71. Once downloaded, extract the SW6705 file into a known path (e.g. the Downloads folder) to later import the project to the IDE. The extracted folder should contain a .zip file with the examples that we will later import to the IDE. Download the FRDM-MCXW71's SDK from the SDK Builder page, make sure to select the 25.12.00 version, as it is the latest SDK available to use along the MCUXpresso IDE. Now we have to import the NXP-NCI2.0_MCUXpresso_examples.zip file we previously extracted to the IDE's workspace, to do so, click on the Import project(s) from file system and in the Project archive (zip) tab, browse for the extracted file of step 1 (NXP-NCI2.0_MCUXpresso_examples.zip) and click on Next >. NOTE: Don’t worry if the IDE shows an error message for not having the SDKs of the default boards (iMXRT1170, LPC55S6x, LPC82x) or having a different version, close the warning message, we only need these examples to copy the NCI library and example files. Your workspace should now look like the following image: Import the hello_world example from the FRDM-MCXW71 SDK: Add the SPI drivers to the imported project by right clicking over the project, hover the cursor over the SDK Management option and select the option Manage SDK Components: Select the driver, click Ok and if you are asked to refresh files accept it, after this you should be able to see the driver in the "drivers" folder of the project. Copy the contents of the source folder of the iMXRT1170 project, as well as the NfcLibrary folder and paste them into the imported hello_world project:          Make sure to delete the hello_world.c and hello_word.mex files as we won't need it again.             After this process your project should look like the following image: To avoid compiling issues, exclude from the build the files nfc_example_P2P.c and nfc_example_RW.c, to do so right click on the file, go to Resource Configurations and select Exclude from Build… and select for all configurations. Do this for each file. Add the preprocessor macro: BOARD_NXPNCI_INTERFACE_SPI, as this is used by the example to select the interface with the board. To do this, right-click on the project and select Properties, then drop-down the C/C++ Build option and go to the Settings tab. Here, add the macro in the Preprocessor option, click on Apply and accept the index rebuild. Add the root folder in C/C++ General > Paths and Symbols > Source Location tab, click on Ok and then Apply: Still in Paths and Symbols, go to the Includes tab and add the source, TML and tool folders from workspace, click Ok and Apply. Make sure to add them one by one. Now, go to C/C++ Build > Settings > Includes and add the following folders from Workspace. You can select all of them and add them at the same time or also do it one by one. Once done, click on Apply and Apply and Close. If you are asked to rebuild the index, do it. "${workspace_loc:/${ProjName}/source/TML}" "${workspace_loc:/${ProjName}/source/tool}" "${workspace_loc:/${ProjName}/NfcLibrary}" "${workspace_loc:/${ProjName}/NfcLibrary/inc}" "${workspace_loc:/${ProjName}/NfcLibrary/NdefLibrary}" "${workspace_loc:/${ProjName}/NfcLibrary/NdefLibrary/inc}" "${workspace_loc:/${ProjName}/NfcLibrary/NdefLibrary/src}" "${workspace_loc:/${ProjName}/NfcLibrary/NxpNci20}" "${workspace_loc:/${ProjName}/NfcLibrary/NxpNci20/inc}" "${workspace_loc:/${ProjName}/NfcLibrary/NxpNci20/src}" Source Code Changes. In the board folder, open the board.h file and add the following definitions to refer to the peripherals and clocks to be used. Please notice that you may change the LPSPI instance, however you would need to connect jumpers instead of connecting directly the shield over the FRDM. #ifdef BOARD_NXPNCI_INTERFACE_SPI #define BOARD_NXPNCI_SPI_CLOCK (CLOCK_GetIpFreq(kCLOCK_Lpspi1)) #define BOARD_NXPNCI_SPI_INSTANCE (LPSPI1) #define BOARD_NXPNCI_SPI_BAUDRATE (400000) #endif #define BOARD_NXPNCI_IRQ_PORT (GPIOC) // J2.10 - GPIO0 [PN7160] - IRQ -> J2.10 GPIOC0 [MCXW71] #define BOARD_NXPNCI_VEN_PORT (GPIOA) // J4.1 - GPIO1 [PN7160] - VEN -> J1.8 GPIOA21 [MCXW71] #define BOARD_NXPNCI_DWL_PORT (GPIOA) // J4.2 - GPIO2 [PN7160] - REQ -> J1.7 GPIOA20 [MCXW71] #define BOARD_NXPNCI_IRQ_PIN (0U) #define BOARD_NXPNCI_VEN_PIN (21U) #define BOARD_NXPNCI_DWL_PIN (20U)   Now we need to add the required clock, peripheral and pin initialization for our board. To do this, go to the hardware_init.c file inside the board folder, and overwrite the BOARD_InitHardware function with the following: void BOARD_InitHardware(void) { BOARD_InitPins(); BOARD_BootClockRUN(); BOARD_InitDebugConsole(); CLOCK_SetIpSrc(kCLOCK_Lpspi1, kCLOCK_IpSrcFro192M); CLOCK_SetIpSrcDiv(kCLOCK_Lpspi1, kSCG_SysClkDivBy16); }   To add the correct pin multiplexing and configuration for our SPI and GPIO pins, go to the pin_mux.c file (also in the board folder) and overwrite the BOARD_InitPins function with the following: void BOARD_InitPins(void) { /* Clock Configuration: Peripheral clocks are enabled; module does not stall low power mode entry */ CLOCK_EnableClock(kCLOCK_GpioA); CLOCK_EnableClock(kCLOCK_GpioC); CLOCK_EnableClock(kCLOCK_PortA); CLOCK_EnableClock(kCLOCK_PortB); CLOCK_EnableClock(kCLOCK_PortC); /*IF SHORTING SH11, SH12, SH13, SH14 needed for LPSPI1*/ const port_pin_config_t portb0_pin46_config = {/* Internal pull-up resistor is enabled */ (uint16_t)kPORT_PullUp, /* Low internal pull resistor value is selected. */ (uint16_t)kPORT_LowPullResistor, /* Fast slew rate is configured */ (uint16_t)kPORT_FastSlewRate, /* Passive input filter is disabled */ (uint16_t)kPORT_PassiveFilterDisable, /* Open drain output is disabled */ (uint16_t)kPORT_OpenDrainDisable, /* Low drive strength is configured */ (uint16_t)kPORT_LowDriveStrength, /* Normal drive strength is configured */ (uint16_t)kPORT_NormalDriveStrength, /* Pin is configured as LPSPI0_PCS0 */ (uint16_t)kPORT_MuxAlt2, /* Pin Control Register fields [15:0] are not locked */ (uint16_t)kPORT_UnlockRegister}; /* PORTB0 (pin 46) is configured as LPSPI1_PCS0 */ PORT_SetPinConfig(PORTB, 0U, &portb0_pin46_config); const port_pin_config_t portb1_pin47_config = {/* Internal pull-up resistor is enabled */ (uint16_t)kPORT_PullUp, /* Low internal pull resistor value is selected. */ (uint16_t)kPORT_LowPullResistor, /* Fast slew rate is configured */ (uint16_t)kPORT_FastSlewRate, /* Passive input filter is disabled */ (uint16_t)kPORT_PassiveFilterDisable, /* Open drain output is disabled */ (uint16_t)kPORT_OpenDrainDisable, /* Low drive strength is configured */ (uint16_t)kPORT_LowDriveStrength, /* Normal drive strength is configured */ (uint16_t)kPORT_NormalDriveStrength, /* Pin is configured as LPSPI0_SIN */ (uint16_t)kPORT_MuxAlt2, /* Pin Control Register fields [15:0] are not locked */ (uint16_t)kPORT_UnlockRegister}; /* PORTB1 (pin 47) is configured as LPSPI1_SIN */ PORT_SetPinConfig(PORTB, 1U, &portb1_pin47_config); const port_pin_config_t portb3_pin1_config = {/* Internal pull-up resistor is enabled */ (uint16_t)kPORT_PullUp, /* Low internal pull resistor value is selected. */ (uint16_t)kPORT_LowPullResistor, /* Fast slew rate is configured */ (uint16_t)kPORT_FastSlewRate, /* Passive input filter is disabled */ (uint16_t)kPORT_PassiveFilterDisable, /* Open drain output is disabled */ (uint16_t)kPORT_OpenDrainDisable, /* Low drive strength is configured */ (uint16_t)kPORT_LowDriveStrength, /* Normal drive strength is configured */ (uint16_t)kPORT_NormalDriveStrength, /* Pin is configured as LPSPI0_SOUT */ (uint16_t)kPORT_MuxAlt2, /* Pin Control Register fields [15:0] are not locked */ (uint16_t)kPORT_UnlockRegister}; /* PORTB3 (pin 1) is configured as LPSPI1_SOUT */ PORT_SetPinConfig(PORTB, 3U, &portb3_pin1_config); const port_pin_config_t portb2_pin48_config = {/* Internal pull-up resistor is enabled */ (uint16_t)kPORT_PullUp, /* Low internal pull resistor value is selected. */ (uint16_t)kPORT_LowPullResistor, /* Fast slew rate is configured */ (uint16_t)kPORT_FastSlewRate, /* Passive input filter is disabled */ (uint16_t)kPORT_PassiveFilterDisable, /* Open drain output is disabled */ (uint16_t)kPORT_OpenDrainDisable, /* Low drive strength is configured */ (uint16_t)kPORT_LowDriveStrength, /* Normal drive strength is configured */ (uint16_t)kPORT_NormalDriveStrength, /* Pin is configured as LPSPI0_SCK */ (uint16_t)kPORT_MuxAlt2, /* Pin Control Register fields [15:0] are not locked */ (uint16_t)kPORT_UnlockRegister}; /* PORTA19 (pin 14) is configured as LPSPI1_SCK */ PORT_SetPinConfig(PORTB, 2U, &portb2_pin48_config); /*IF SHORTING SH11, SH12, SH13, SH14 needed for LPSPI1*/ const port_pin_config_t irq_pin = {/* Internal pull-up/down resistor is disabled */ (uint16_t)kPORT_PullUp, /* Low internal pull resistor value is selected. */ (uint16_t)kPORT_LowPullResistor, /* Fast slew rate is configured */ (uint16_t)kPORT_FastSlewRate, /* Passive input filter is disabled */ (uint16_t)kPORT_PassiveFilterDisable, /* Open drain output is disabled */ (uint16_t)kPORT_OpenDrainDisable, /* Low drive strength is configured */ (uint16_t)kPORT_LowDriveStrength, /* Normal drive strength is configured */ (uint16_t)kPORT_NormalDriveStrength, /* Pin is configured as PTC0 */ (uint16_t)kPORT_MuxAsGpio, /* Pin Control Register fields [15:0] are not locked */ (uint16_t)kPORT_UnlockRegister}; /* PORTC0 (pin 37) is configured as PTC0 */ PORT_SetPinConfig(PORTC, 0U, &irq_pin); const port_pin_config_t ven_pin = {/* Internal pull-up/down resistor is disabled */ (uint16_t)kPORT_PullDisable, /* Low internal pull resistor value is selected. */ (uint16_t)kPORT_LowPullResistor, /* Fast slew rate is configured */ (uint16_t)kPORT_FastSlewRate, /* Passive input filter is disabled */ (uint16_t)kPORT_PassiveFilterDisable, /* Open drain output is disabled */ (uint16_t)kPORT_OpenDrainDisable, /* Low drive strength is configured */ (uint16_t)kPORT_LowDriveStrength, /* Normal drive strength is configured */ (uint16_t)kPORT_NormalDriveStrength, /* Pin is configured as PTA20 */ (uint16_t)kPORT_MuxAsGpio, /* Pin Control Register fields [15:0] are not locked */ (uint16_t)kPORT_UnlockRegister}; /* PORTA20 (pin 17) is configured as PTA20 */ PORT_SetPinConfig(PORTA, 20U, &ven_pin); const port_pin_config_t req_pin = {/* Internal pull-up/down resistor is disabled */ (uint16_t)kPORT_PullDisable, /* Low internal pull resistor value is selected. */ (uint16_t)kPORT_LowPullResistor, /* Fast slew rate is configured */ (uint16_t)kPORT_FastSlewRate, /* Passive input filter is disabled */ (uint16_t)kPORT_PassiveFilterDisable, /* Open drain output is disabled */ (uint16_t)kPORT_OpenDrainDisable, /* Low drive strength is configured */ (uint16_t)kPORT_LowDriveStrength, /* Normal drive strength is configured */ (uint16_t)kPORT_NormalDriveStrength, /* Pin is configured as PTA21 */ (uint16_t)kPORT_MuxAsGpio, /* Pin Control Register fields [15:0] are not locked */ (uint16_t)kPORT_UnlockRegister}; /* PORTA21 (pin 18) is configured as PTA21 */ PORT_SetPinConfig(PORTA, 21U, &req_pin); const port_pin_config_t portc2_pin39_config = {/* Internal pull-up/down resistor is disabled */ (uint16_t)kPORT_PullDisable, /* Low internal pull resistor value is selected. */ (uint16_t)kPORT_LowPullResistor, /* Fast slew rate is configured */ (uint16_t)kPORT_FastSlewRate, /* Passive input filter is disabled */ (uint16_t)kPORT_PassiveFilterDisable, /* Open drain output is disabled */ (uint16_t)kPORT_OpenDrainDisable, /* Low drive strength is configured */ (uint16_t)kPORT_LowDriveStrength, /* Normal drive strength is configured */ (uint16_t)kPORT_NormalDriveStrength, /* Pin is configured as LPUART1_RX */ (uint16_t)kPORT_MuxAlt3, /* Pin Control Register fields [15:0] are not locked */ (uint16_t)kPORT_UnlockRegister}; /* PORTC2 (pin 39) is configured as LPUART1_RX */ PORT_SetPinConfig(PORTC, 2U, &portc2_pin39_config); const port_pin_config_t portc3_pin40_config = {/* Internal pull-up/down resistor is disabled */ (uint16_t)kPORT_PullDisable, /* Low internal pull resistor value is selected. */ (uint16_t)kPORT_LowPullResistor, /* Fast slew rate is configured */ (uint16_t)kPORT_FastSlewRate, /* Passive input filter is disabled */ (uint16_t)kPORT_PassiveFilterDisable, /* Open drain output is disabled */ (uint16_t)kPORT_OpenDrainDisable, /* Low drive strength is configured */ (uint16_t)kPORT_LowDriveStrength, /* Normal drive strength is configured */ (uint16_t)kPORT_NormalDriveStrength, /* Pin is configured as LPUART1_TX */ (uint16_t)kPORT_MuxAlt3, /* Pin Control Register fields [15:0] are not locked */ (uint16_t)kPORT_UnlockRegister}; /* PORTC3 (pin 40) is configured as LPUART1_TX */ PORT_SetPinConfig(PORTC, 3U, &portc3_pin40_config); }   To add the required interfacing APIs specific of our chip, we need to modify the tml.c file from the TML folder, in this file overwrite the functions: INTF_INIT, INTF_WRITE and INTF_READ with the following: static void INTF_INIT(void) { lpspi_master_config_t userConfig; uint32_t srcFreq = 0; /*SPI configuration*/ LPSPI_MasterGetDefaultConfig(&userConfig); userConfig.baudRate = BOARD_NXPNCI_SPI_BAUDRATE; srcFreq = BOARD_NXPNCI_SPI_CLOCK; userConfig.whichPcs = (lpspi_which_pcs_t)kLPSPI_Pcs0; userConfig.pcsActiveHighOrLow = (lpspi_pcs_polarity_config_t)kLPSPI_PcsActiveLow; /*Initialize SPI*/ LPSPI_MasterInit(BOARD_NXPNCI_SPI_INSTANCE, &userConfig, srcFreq); } static status_t INTF_WRITE(uint8_t *pBuff, uint16_t buffLen) { uint8_t temp[1000]; temp[0] = 0x7F; memcpy(temp+1, pBuff, buffLen); masterXfer.txData = temp; masterXfer.rxData = NULL; masterXfer.dataSize = buffLen+1; masterXfer.configFlags = kLPSPI_MasterPcs0 | kLPSPI_MasterPcsContinuous | kLPSPI_MasterByteSwap;; return LPSPI_MasterTransferBlocking(BOARD_NXPNCI_SPI_INSTANCE, &masterXfer); } static status_t INTF_READ(uint8_t *pBuff, uint16_t buffLen) { status_t status; uint8_t temp[257]; temp[0] = 0xFF; masterXfer.txData = temp; masterXfer.rxData = temp; masterXfer.dataSize = buffLen+1; masterXfer.configFlags = kLPSPI_MasterPcs0 | kLPSPI_MasterPcsContinuous | kLPSPI_MasterByteSwap;; status = LPSPI_MasterTransferBlocking(BOARD_NXPNCI_SPI_INSTANCE, &masterXfer); if(status == kStatus_Success) memcpy(pBuff, temp+1, buffLen); SDK_DelayAtLeastUs(10, SDK_DEVICE_MAXIMUM_CPU_CLOCK_FREQUENCY); return status; } #endif   We also need to overwrite the functions: tml_Init, tml_DeInit and tml_Reset to adapt them to use the specific APIs for the GPIOs of our board. static Status tml_Init(void) { gpio_pin_config_t in_config = {kGPIO_DigitalInput, 0}; gpio_pin_config_t out_config = {kGPIO_DigitalOutput, 0}; GPIO_PinInit(BOARD_NXPNCI_IRQ_PORT, BOARD_NXPNCI_IRQ_PIN, &in_config); GPIO_PinInit(BOARD_NXPNCI_VEN_PORT, BOARD_NXPNCI_VEN_PIN, &out_config); GPIO_PinInit(BOARD_NXPNCI_DWL_PORT, BOARD_NXPNCI_DWL_PIN, &out_config); INTF_INIT(); return SUCCESS; } static Status tml_DeInit(void) { GPIO_PortClear(BOARD_NXPNCI_VEN_PORT, 1U << BOARD_NXPNCI_VEN_PIN); return SUCCESS; } static Status tml_Reset(void) { /* Set DWL_REQ low for NCI protocol */ GPIO_PortClear(BOARD_NXPNCI_DWL_PORT, 1U << BOARD_NXPNCI_DWL_PIN); GPIO_PortClear(BOARD_NXPNCI_VEN_PORT, 1U << BOARD_NXPNCI_VEN_PIN); Sleep(10); GPIO_PortSet(BOARD_NXPNCI_VEN_PORT, 1U << BOARD_NXPNCI_VEN_PIN); Sleep(10); return SUCCESS; }   Finally, modify the main file so it uses the APIs to initialize our board clocks and pins: #include <stdio.h> #include <string.h> #include "app.h" #include "board.h" #include "pin_mux.h" #include "fsl_debug_console.h" extern void nfc_example (void); int main(void) { BOARD_InitHardware(); #ifdef BOARD_NXPNCI_INTERFACE_I2C PRINTF("\nRunning the NXP-NCI2.0 example (I2C interface)\n"); #else PRINTF("\nRunning the NXP-NCI2.0 example (SPI interface)\n"); #endif nfc_example(); } Testing the example. At this point we have everything set to build and flash our example with SPI interface, you may proceed to build and debug/flash the example by pressing the blue beetle button: Once the example is flashed, open a serial terminal such as Teraterm with the following settings: Baudrate: 115200. Data: 8 bits. Parity: None. Stop bits: 1 bit. No flow control. While running, the example should output the following logs to the terminal: When a tag is placed near the antenna, the example should print the tag information in the terminal as shown:
記事全体を表示
The PN7642/PN5190/PN7220 requires a calibration before the RF field is switched on for the first time with unloaded condition. "Unloaded" means: Without any additional metal in proximity of the antenna, except for the NFC reader components itself. During development of new readers, this calibration shall be done each time the antenna design, antenna matching, or EMC filter is modified. See a workflow of the Initial calibration for PN7642 done in NFC Cockpit.  During this procedure, the RF Field is switched on for approx. 11 ms, and the calibration data is saved in the memory. Note: Please note that the registers and EEPROM addresses might differ for a different products. Always check the Datasheet for the used product.
記事全体を表示
DISCLAIMER APPLICABLE TO THIS DOCUMENT CONTENTS:   PN5190-NTAG 5 boost High Speed Communication Demo This article describes the unique feature of these two chips when interacting with each other at contactless interface: Passthrough demonstrator at high bit rates for ISO 15693 between PN5190 and NTAG5 Boost. Scope of demonstrator: ▪ Demonstrating a unique feature of NXP Semiconductors. High bit rates for ISO15693 communication (212 kbps) between a PN5190 reader IC and an NTAG5 boost connected to LPC55S69 host MCU, when implementing passthrough mode using the SRAM of the NTAG 5 boost. ▪ Through MCUXpresso console, the user can configure the contactless bit rate (26.4kbps or 212kbps options) as well as the amount of data to exchange using passthrough mode. ▪ Passthrough mode is implemented from NFC reader to LPC side only. ▪ The PN5190 prints on the MCUXpresso console the outcome of the transaction and baud rate achieved. ▪ In order to handle passthrough communication, we are using GPIO interrupt handlers on the NTAG 5 boost + LPC55S69 side and hard coded timeout on the PN5190 + MCU side. Required hardware and software material: Hardware ▪ PNEV5190BP development board ▪ LPCXpresso55S69 Development Board ▪ OM2NTA5332 - NTAG5 boost development kit ▪ 3 x USB micro cables Software ▪ Firmware Source Code for PN5190 is attached to this article, containing keywork pn5190: HIGHSPEED_PN5190_NTAG5boost1.zip ▪ SDK_2.x_FRDM-K82F is already included in bundle mentioned above. ▪ Firmware Source Code for LPCXpresso55S69 is attached to this article, containing keyword lpc55s69: NTAG5boost_LPC55S69.zip ▪ MCUXpresso IDE recent version (v24.12.148 or newer) Demonstrator bring up: Hardware assembly for LPCXpresso55S69: • Connect NTAG5 Boost board to LPCXpresso55S69 • Make sure SW6 is on position 2-3 to enable 5V power on tag side (it will also work at 3.3V but maybe with less readrange). • Connect LPCXpresso55S69 board to your computer (Debug Link Input). • No additional power source is needed. Hardware assembly for PNEV5190BP: • Connect two USB micro cables to PNEV5190B board for power and flashing firmware via UART connection (alternatively, you may change jumper J9 to position 2-3 and connect an external power supply, Vin > 7 Volts) • Red LED indicates power is enabled • Green LED debugging/UART status Software loading on LPC55S69: Import “lpcxpresso55s69_ntag5_passthrough_nolib” project (included in NTAG5boost_LPC55S69.zip) into MCUXpresso IDE. • Install SDK_2_12_0_LPCXpresso55S69. This SDK can be downloaded from • https://www.nxp.com/security/login?service=https%3A%2F%2Fmcuxpresso.nxp.com%2Flogin%2F  • Build project and flash a binary file using GUI Flash Tool. After flashing, reboot your board. Blue LED must be enabled which means tag is waiting for field to be detected. Under MCUXpresso: 1. Import project from file system 2. Select lpcxpresso55s69 project 3. Uncheck copy projects into workspace Software loading on PNEV5190B: • Unzip the “HIGHSPEED_PN5190_NTAG5boost1.zip” in a folder. • Import all projects inside “HIGHSPEED_PN5190_NTAG5boost1” project to MCUXpresso IDE • Install SDK_2.x_FRDM-K82F. Such SDK is included in project file tree: • nxp-connected-tags-pn5190\Platform\SDK_2.x_FRDM-K82F • Build project and flash a binary file using GUI Flash Tool. After flashing, reboot your board. Blue LED must be enabled which means reader is waiting for NTAG5 to be detected. • Start Debug session to see available bitrate options on the console. Under MCUXpresso: 1. Import project from file system 2. Select all the projects 3. Uncheck copy projects into workspace LED User Interface Specifications (same for LPCXpresso55S69 an PNEV5190B) • Steady blue - waiting for Tag - discovery loop, • Blinking green - passthrough transfer ongoing • Steady green - all data transferred successfully. • Steady red - error - tag lost during transfer. Menu options when two boards have NFC antennas facing each other: Two options of bitrate are available for transfer amount of data from host to NTAG5 Boost: ▪  standard 26.4 kbps or ▪  highest bit rate 212 kbps It is possible to configure amount of data to be exchanged between PN5190 and NTAG 5 boost (check option 3, and then choose among following file dimensions): ▪1KByte ▪2KBytes ▪10KBytes ▪512KBytes Demonstration flow: Once one of these options is selected, reader is ready to detect a tag. ▪ When tag is detected, reader configures selected bitrate and starts data exchange. ▪ Blinking green LED indicates transfer ongoing and the console shows a progress. Here are some results of transaction at the different bit rates and data sizes offered by this demonstrator: Data Size (Bytes) Selected bitrate (kbps) Result Bitrate (kbps) Transfer time (ms) 1024 26.4 2.8 357 1024 212 12.35 81 2048 26.4 2.8 714 2048 212 12.42 161 10240 26.4 2.7 3569 10240 212 12.41 806 512000 26.4 2.8 177739 512000 212 12.63 39576   High speed demo user manual can be also find attached to this article: 22-10-11 NXP - Connected Tags demonstrator User Manual.pdf Conclusions: This demonstrator HW & SW can show that high speed interaction can be achieved between PN5190 (NFC Front end) and NTAG 5 boost, making use of available commands described in product support package. Disclaimer: All SW available here is aimed only for evaluation purposes and NXP disclaims any direct or indirect liability damages, since referred SW bundles are not official part of PN5190/NTAG 5 boost standard product support packages available in nxp.com.
記事全体を表示
PN5190-NTAG X DNA High Speed Communication Demo: This article describes important feature of these two chips when interacting with each other at contactless interface: Passthrough demonstrator at high bit rates for ISO/IEC14443-A between PN5190 and NTAG X DNA Scope of demonstrator: ▪ Demonstrating a unique feature of NXP Semiconductors. High bit rates for ISO14443 communication (up to 848 kbps) between a PN5190 reader IC and an NTAG X DNA when connected to MCXA153 host MCU, when simulating the transmission of a dummy file as big as 101 kbytes. ▪ Through MCUXpresso console, the user can configure the contactless bit rate: 106 kbps 212 kbps 424 kbps or 848 kbps The amount of data is fixed in this demo. ▪ transmission mode is implemented from NFC reader library at K82 MCU built in the PNEV5190BP evaluation kit. On the other side, NTAG X DNA + Level shifter (represented by evaluation kit NTAG-X-DNA-EVAL) is connected to a Freedom Board, equipped with MCXA153 - FRDM-MCXA153). ▪ The PN5190 prints on the MCUXpresso console (debug mode) the outcome of the transaction and average baud rate achieved. ▪ In order to handle full file transmission from K82 to MCXA153 (MCU <-> MCU communication), we are using NTAG X DNA GPIO wires as well as proper settings on the NTAG X DNA <-> MCXA153 side and hard coded timeout on the PN5190 + MCU side. For more details, please open attached file PN5190_NTAGXDNA_MCXA153_DualInterface_HBR_Demo_SetupInstructions_Q32025.pdf. Required hardware and software enablement: Hardware ▪ PNEV5190BP Development Board ▪ FRDM-MCXA153 Development Board ▪ NTAG X DNA Development Board ▪ 2 x USB micro cables (for PNEV5190BP dev. br., one for DC power, other for Jlink debug on MCUxpresso IDE) ▪ 1 x USB-C cable (for FRDM-MCXA153 dev. br., only for DC power) Software ▪ MCUxpresso project (firmware Source Code) for PNEV5190BP is attached to this article, containing keywork pn5190: pn5190-ntagxdna-highspeed-demo1.zip. Instructions will be given in from future release of NFC Reader Library public v07.14.00 (NxpNfcRdLib_PN5190_v07.14.00_Pub.zip). ▪ SDK_2.x_FRDM-K82F is already included in bundle mentioned above. ▪ Firmware Source Code for FRDM-MCXA153 is attached to this article, containing keyword MCXA153: MCXA153.zip ▪ MCUXpresso IDE recent version, for instance v24.12.148 or above. Demonstrator bring up: Hardware assembly for FRDM-MCXA153: • Connect NTAG X DNA to level shifter (see Fig. 1) • Connect bundle NTAG X DNA+ level shifter bundle to flat cable (contained in demokit box) to FRDM-MCXA153 according to Fig. 2. • Make sure each wire is connected to proper position in Arduino socket: - black wire IO2 goes to J1-14 - white wire IO1 goes to J1-16 - gray wire SCL goes to J2-20 - violet wire SDA goes to J2-18 - blue wire GND goes to J3-14 - green wire VCC goes to J3-8 • Connect FRDM-MCXA153 via J15 (MCU-Link) to your computer (Debug Link Input), for the first time that you have to flash binary in it. Then after storing binary, you may just connect USB-C cable from a power supply to J6 port (named Ext-debugger). • No additional power source is needed. Hardware assembly for PNEV5190B: • Connect two USB micro cables to PNEV5190B board for power, flashing firmware and UART connection (see Fig. 3): • microUSB on J7 is necessary for DC power. Check that jumper J9 is in the position USB dc supply • microUSB on J20 is the Jlink debug port, and it will be connected to your Windows computer, where MCUxpresso has been installed. • Red LED indicates power is enabled • Green LED debugging/UART status Alternatively, if you have a DC power supply (voltage above 7 V), you may change Jumper J9 to Ext power supply, and avoid using second microUSB cable. Software loading on FRDM-MCXA153: 1. Create a new workspace for MCXA153 MCUxpresso example: 2. Make sure you have installed MCXA153 SDK: - install MCXA153 SDK which can be downloaded from: https://mcuxpresso.nxp.com/  3. Unzip "MCXA153.zip" file in local C: directory, with reasonable path length. 4. Import existing projects from file system, into MCUXpresso IDE: 5. Select proper root directory (keyword is MCXA153): 6. Click "Finish" 7. If you get this warning, simply click "OK": 8. Highlight project, click "build", and check that there are no errors: Finished building target: MCXA153_NTAGXDNA_DualInterface_DataRead_Demo.axf Performing post-build steps arm-none-eabi-size "MCXA153_NTAGXDNA_DualInterface_DataRead_Demo.axf"; # arm-none-eabi-objcopy -v -O binary "MCXA153_NTAGXDNA_DualInterface_DataRead_Demo.axf" "MCXA153_NTAGXDNA_DualInterface_DataRead_Demo.bin" ; # checksum -p MCXA153 -d "MCXA153_NTAGXDNA_DualInterface_DataRead_Demo.bin";    text        data         bss         dec         hex     filename   23524          20        3684       27228        6a5c      MCXA153_NTAGXDNA_DualInterface_DataRead_Demo.axf 16:27:26 Build Finished. 0 errors, 0 warnings. (took 5s.787ms) 9. Now, flash the binary into MCXA153 MCU using GUI Flash tool; select suitable  MCUxpresso probe (CMSIS-DAP). Make sure USB-c cable is connected to J15 in Freedom board (MCU-link port for flashing FW). 10. Select binary file *.axf as indicated below: It may happen that your MCXA153 has outdated FW on CMSIS-DAP, but you can continue, it will make no harm; click then Ok to flash. 11. After flashing, reboot your board. Following LEDs should be on: - D15 RGB led should be "white" lit. - D7 should be blinking "red" - D8 and D4 should be "green" lit. D15 will blink "white" only during file transmission. You may disconnect USB-c from J15 (the one used with MCUxpresso for flah and connect it to J8. Then, plug the other cable tip to any USB  5 volt battery charger. Now your Freedom board FRDM-MCXA153 is ready to receive data from PNEV5190 board, once project will be imported too in MCUxpresso. Software loading on PNEV5190BP: 1. Unzip *.zip file in directory with reasonable path length. 2. Import existing projects from file system 3. Select Example 12 "NfcrdlibEx12_NTAGXDNA" 4. Uncheck the choice "copy projects into workspace" 5. Install SDK_2.x_FRDM-K82F if not yet done. Such SDK is included in project file tree: • ...Examples\Platform\SDK_2.x_FRDM-K82F • This specific SDK can be obtained from https://mcuxpresso.nxp.com/ by selecting following K82F tab related "PN5180" : • FRDM-K82F-PN5180 (MK82FN256xxx15) • SDK 2.0 is no longer officially available, but SDK 2.2 and newer are backward compatible and recommended by NXP • Build project and check that there are no errors ("warnings" are allowed). • Start Debug session to see available bitrate options on the console. Hardware combination of PNEV5190B and NTAG X DNA connected to FRDM-MCXA153: Under MCUXpresso: 1. Click "Debug" icon on quick access left panel. Accept agreement in case of J-Link tool: 2. Click on icon "Run" on top side of MCUxpresso, and observe the following on "Console" tab: [MCUXpresso Semihosting Telnet console for 'NfcrdlibEx12_NTAGXDNA_mcux JLink DebugFRDMK82F' started on port 59973 @ 127.0.0.1] SEGGER J-Link GDB Server V8.12a - Terminal output channel *** NTAG X DNA Example *** Please place NTAG X DNA Card and Select Demo option. 1 : Perform Data Read Write using AES128 Key Authentication 2 : Perform Data Read Write using ECC Sigma-I Authentication Host as Initiator with NIST P-256 Curve, session key AES128 3 : Perform Data Read Write using ECC Sigma-I Authentication Host as Responder with NIST P-256 Curve, session key AES128 4 : Perform HBR transfer to Microcontroller through NTAG X DNA. 5 : Configure NTAG X DNA for HBR transfer Enter your option : Menu options when two boards have NFC antennas facing each other: There are 5 options in console menu as soon as you "Run" the debug. 1 - options from 1 until and including 3 are related to crypto functionality (symmetric and asymmetric) and are out of the scope of this article. 2 - Then option 5 is used for the first time that you are configuring your NTAG X DNA product. It will set registers and GPIO properly for High bit rate transfer. Once you have run option 5, then go to option 4: 3 - Four options of bitrate are available for transfer a fixed amount of data from host (K82) to NTAG X DNA MCU (MCXA153) using PN5190 as tunnel: Please configure the required baud rate 1 : 106 Kbps 2 : 212 Kbps 3 : 424 Kbps 4 : 848 Kbps Enter your option : Demonstration flow: Once one of these option is selected, reader is ready to detect a tag. ▪ When tag is detected, reader configures selected bitrate and starts data exchange. ▪ Blinking RGB LED D15 indicates transfer ongoing and the console shows a progress. Here are some results of transaction at the different bit rates and data sizes offered by this demonstrator: 1 - 106 Kbps - Baud rate 7.6 kBytes/s - elapsed time: 13.99 s Type A Tag is discovered. ***** Perform Transfer sequence ******* Select Application Successful Select File Successful Data transferring NFC -> NTAG X DNA -> Microcontroller... Amount of data exchanged 101200 Bytes, Baudrate (total) = 7.6 kB/s, Time = 13.99 s Please Remove the Card   After removing the card, K82 firmware starts again prompting for a new selection, in the previous menu. First select 4 again and then chose again another new baud rate: 2 - 212 Kbps - Baud rate 10.51 kBytes/s - elapsed time: 9.39 s 3 - 424 Kbps - Baud rate 13.92 kBytes/s - elapsed time: 7.90 s 4 - 848 Kbps - Baud rate 16.60 kBytes/s - elapse time: 5.95 s   Using Example 12 of NFC Reader Library v.07.14.00 to prepare High Speed demo on PNEV5190BP and NTAG X DNA: 1. Go to https://nxp.com web site and type "NFC Reader Library" in Search tab. Follow the instructions until you get to this screenshot: 2. Start by downloading NFC Reader library V.07.14.00 from NXP website; agree with Terms and Conditions. Then download the bundle to your local C: drive: 3. Click on “down arrow” to download version 07.14.00. Once zip file is received, unzip previous bundle to a local drive directory.   4. Start a new workspace, then choose "Import from Existing Projects into Workspace": 5. De-select all useless Examples and keep only example 12; please including all other essential items; click "Finish": 6. If you find this error, it means you need to install K82F SDK: 7. Click install, then MCUxpresso SDKs pages will open. Select K82F from Processor tab: Click “Install” button; after installation is completed, you will get a screen showing all installed sdk's. Afterwards you may get the prompt "Make SDK persistent"; just click ok. 8. Highlight project NfcrdlibEx12_NTAGXDNA_mcux and click build; check if there are errors: Finished building target: NfcrdlibEx12_NTAGXDNA_mcux.axf Performing post-build steps arm-none-eabi-size "NfcrdlibEx12_NTAGXDNA_mcux.axf" ; arm-none-eabi-objcopy -O binary "NfcrdlibEx12_NTAGXDNA_mcux.axf" "NfcrdlibEx12_NTAGXDNA_mcux.bin" ; #checksum -p MK82FN256xxx15 -d "NfcrdlibEx12_NTAGXDNA_mcux.bin"    text        data         bss         dec         hex     filename  222400          92       86816     309308       4b83c      NfcrdlibEx12_NTAGXDNA_mcux.axf 17:32:59 Build Finished. 0 errors, 3 warnings. (took 33s.718ms) 9. Now, check in MCUxpresso the tab Windows > Preferences > Run/Debug. Untick the box related to General Options Build (if required) before launching; it will save you much time! Then, click button “Apply and Close”. 10. Using this Example 12 as it is given by NXP in this library, when you will debug it, you will realize that there are only 3 Menu options related to NTAG X DNA cryptography (and no high speed options). In order to “unlock” the high-speed demo option, please do the following. 11. Go to Quick Settings → Defined Symbols and open it in a new window: Now add after last symbol, the following line: "PH_EX12_ENABLE_DUALINTERFACE_HBR", by clicking on “add button” ("+" shown in green) on top right side of above window; add it manually then click OK two times. Now, build Ex12 again and check that there are no errors. 12. Debug Example 12, then press Run button and check if Console has 5 options in its Menu: Please place NTAG X DNA Card and Select Demo option. 1 : Perform Data Read Write using AES128 Key Authentication 2 : Perform Data Read Write using ECC Sigma-I Authentication Host as Initiator     with NIST P-256 Curve, session key AES128 3 : Perform Data Read Write using ECC Sigma-I Authentication Host as Responder     with NIST P-256 Curve, session key AES128 4 : Perform HBR transfer to Microcontroller through NTAG X DNA. 5 : Configure NTAG X DNA for HBR transfer Enter your option : 13. Let's focus on the last two options: 4 – perform HBR (high bit rate) transfer, and 5 – Configure your NTAG X DNA for HBR. 14. If this is the first time you are using this NTAG X DNA connected to MCXA153, then choose option 5 so that PN5190 will write proper configuration data to NTAG X DNA next to it. For this reason, turn on NTAG X DNA connected to FRDM-MCXA153 board (after powering it up with a simple 5V-USB source), and place NTAG X DNA antenna over PNEV5190BP board antenna (connected to MCUxpresso), as in picture shown above. Enter your option : 5 Ready to detect Type A Tag is discovered.       Select NDEF Application Successful       Authenticate Application Successful       SetConfig Successful       StdDataFile with File ID 0xE106 already exists. Please Remove the Card 15. Remove NTAG X DNA antenna from PN5190 antenna, until you get back to initial menu. Then, choose option 4 on previous menu: 4 : Perform HBR transfer to Microcontroller through NTAG X DNA. 5 : Configure NTAG X DNA for HBR transfer Enter your option : 4  Please configure the required baud rate 1 : 106 Kbps 2 : 212 Kbps 3 : 424 Kbps 4 : 848 Kbps Enter your option : 16. Now, choose the lowest speed "1"; check final result: Ready to detect Type A Tag is discovered. ***** Perform Transfer sequence *******       Select Application Successful       Select File Successful       Data transferring NFC -> NTAG X DNA -> Microcontroller...       Amount of data exchanged 101200 Bytes, Baudrate (total) = 5.72 kB/s, Time = 17.25 s Please Remove the Card 17. Separate both antennas, and then, choose option "2"; check final result: Enter your option : 2 Ready to detect Type A Tag is discovered. ***** Perform Transfer sequence *******       Select Application Successful       Select File Successful       Data transferring NFC -> NTAG X DNA -> Microcontroller… Amount of data exchanged 101200 Bytes, Baudrate (total) = 10.49 kB/s, Time = 9.41 s 18. Separate both antennas, and then, choose option "3"; check final result: Enter your option : 3 Ready to detect Type A Tag is discovered. ***** Perform Transfer sequence *******       Select Application Successful       Select File Successful       Data transferring NFC -> NTAG X DNA -> Microcontroller...       Amount of data exchanged 101200 Bytes, Baudrate (total) = 13.89 kB/s, Time = 7.11 s Please Remove the Card 19. Separate both antennas, and then, choose option "4"; check final result:  Enter your option : 4 Ready to detect Type A Tag is discovered. ***** Perform Transfer sequence *******       Select Application Successful       Select File Successful       Data transferring NFC -> NTAG X DNA -> Microcontroller...       Amount of data exchanged 101200 Bytes, Baudrate (total) = 16.57 kB/s, Time = 5.96 s Please Remove the Card Conclusions: This demonstrator HW & SW can show that high speed interaction can be achieved between PN5190 (NFC Front end) and NTAG X DNA (NFC connected tag), making use of available commands described in its product support package (https://www.nxp.com/products/NTAG-X-DNA). Disclaimer:All SW available here is aimed only for evaluation purposes and NXP disclaims any direct or indirect liability damages, since referred SW bundles are not yet official part of PN5190/NTAG X DNA standard product support packages currently available at nxp.com.
記事全体を表示
Step 1:  Disable the DCDC in settings (Valid for PNEV5190B and OM27642EVK) Write 0x21 into EEPROM PWR_CONFIG (address: 0x0000) This disables the DCDC. & selects that the VUP must be supplied with the same supply voltage as VBAT = VBATPWR. Do not enable RF afterwards, before the hardware is modified properly! Enabling the RF without supplying the VUP might kill the PN5190/PN7642! Step 2: Supply VUP = VBATPWR  Connect jumper J13 positions: 1-2: This supplies the VUP with VBATPWR = 3.3V PN5190 EVK: Please note that for a final application using ULPCD, the "DC-DC" inductor (L2) has to be replaced by a zero resistor/short.    PN7642 EVK:  The OM27642EVK does not require any jumper settings (DC-DC is not used by default), the User must only disable DC-DC in EEPROM (address 0x0000, value 0x21) Then you can turn-on RF and perform ULPCD   Please note that for a final application using ULPCD, the "DC-DC" inductor (L2) has to be replaced by a zero resistor/short.  Also, R8 shall be placed
記事全体を表示
LPCD (Low Power Card Detection) works on the principle that the I and Q values are extracted from the RF signal captured on the RX pins. These values are then compared with the I and Q data obtained using LPCD calibration. If the difference is greater than the chosen I and Q threshold, the load is detected and the IC wakes up.  1// LPCD Way of working  Run LPCD Calibration  It is recommended to use an external power supply to supply the EVK board. If the USB supply is used, the value can fluctuate because of the transition effects.  Run "Single LPCD" and check the performance  Adjust the I and Q thresholds  Low value -> Better detection range, more false wake-ups  High value -> Worse detection range, fewer false wake-ups  The number of samples, RSSI, and VDDPA parameters typically remain at their default values.  2// Auto LPCD  When the "Auto LPCD" is used, the LPCD algorithm always performs LPCD Calibration before entering the LPCD. 3//Semi-autonomous LPCD mode (PN5190 only)   The user can evaluate the I and Q values behaviour under loaded/unloaded conditions. Based on that, the LPCD threshold can be properly selected.  Use the same "Register" RSSI Target and Hysteresis as for "EEPROM" Calibrate LPCD Run "Endless I/Q read"  Check how the I and Q values change With no card/object in the antenna proximity  with a NFC card/object in the antenna proximity
記事全体を表示
