PN5190-NTAG 5 boost High Speed Communication Demo
DISCLAIMER APPLICABLE TO THIS DOCUMENT CONTENTS:
This article describes the unique feature of these two chips when interacting with each other at contactless interface: Passthrough demonstrator at high bit rates for ISO 15693 between PN5190 and NTAG5 Boost.
Scope of demonstrator:
▪ Demonstrating a unique feature of NXP Semiconductors. High bit rates for ISO15693 communication (212 kbps) between a PN5190 reader IC and an NTAG5 boost connected to LPC55S69 host MCU, when implementing passthrough mode using the
SRAM of the NTAG 5 boost.
▪ Through MCUXpresso console, the user can configure the contactless bit rate (26.4kbps or 212kbps options) as well as the amount of data to exchange using passthrough mode.
▪ Passthrough mode is implemented from NFC reader to LPC side only.
▪ The PN5190 prints on the MCUXpresso console the outcome of the transaction and baud rate achieved.
▪ In order to handle passthrough communication, we are using GPIO interrupt handlers on the NTAG 5 boost + LPC55S69 side and hard coded timeout on the PN5190 + MCU side.
Required hardware and software material:
Hardware
▪ PNEV5190BP development board
▪ LPCXpresso55S69 Development Board
▪ OM2NTA5332 - NTAG5 boost development kit
▪ 3 x USB micro cables
Software
▪ Firmware Source Code for PN5190 is attached to this article, containing keywork pn5190: HIGHSPEED_PN5190_NTAG5boost1.zip
▪ SDK_2.x_FRDM-K82F is already included in bundle mentioned above.
▪ Firmware Source Code for LPCXpresso55S69 is attached to this article, containing keyword lpc55s69: NTAG5boost_LPC55S69.zip
▪ MCUXpresso IDE recent version (v24.12.148 or newer)
Demonstrator bring up:
Hardware assembly for LPCXpresso55S69:
• Connect NTAG5 Boost board to LPCXpresso55S69
• Make sure SW6 is on position 2-3 to enable 5V power on tag side (it will also work at 3.3V but maybe with less readrange).
• Connect LPCXpresso55S69 board to your computer (Debug Link Input).
• No additional power source is needed.
Hardware assembly for PNEV5190BP:
• Connect two USB micro cables to PNEV5190B board for power and flashing firmware via UART connection (alternatively, you may change jumper J9 to position 2-3 and connect an external power supply, Vin > 7 Volts)
• Red LED indicates power is enabled
• Green LED debugging/UART status
Software loading on LPC55S69:
Import “lpcxpresso55s69_ntag5_passthrough_nolib” project (included in NTAG5boost_LPC55S69.zip) into MCUXpresso IDE.
• Install SDK_2_12_0_LPCXpresso55S69. This SDK can be downloaded from
• https://www.nxp.com/security/login?service=https%3A%2F%2Fmcuxpresso.nxp.com%2Flogin%2F
• Build project and flash a binary file using GUI Flash Tool. After flashing, reboot your board. Blue LED must be enabled which means tag is waiting for field to be detected.
Under MCUXpresso:
1. Import project from file system
2. Select lpcxpresso55s69 project
3. Uncheck copy projects into workspace
Software loading on PNEV5190B:
• Unzip the “HIGHSPEED_PN5190_NTAG5boost1.zip” in a folder.
• Import all projects inside “HIGHSPEED_PN5190_NTAG5boost1” project to MCUXpresso IDE
• Install SDK_2.x_FRDM-K82F. Such SDK is included in project file tree:
• nxp-connected-tags-pn5190\Platform\SDK_2.x_FRDM-K82F
• Build project and flash a binary file using GUI Flash Tool. After flashing, reboot your board. Blue LED must be enabled which means reader is waiting for NTAG5 to be detected.
• Start Debug session to see available bitrate options on the console.
Under MCUXpresso:
2. Select all the projects
LED User Interface Specifications (same for LPCXpresso55S69 an PNEV5190B)
• Steady blue - waiting for Tag - discovery loop,
• Blinking green - passthrough transfer ongoing
• Steady green - all data transferred successfully.
• Steady red - error - tag lost during transfer.
Menu options when two boards have NFC antennas facing each other:
Two options of bitrate are available for transfer amount of data from host to NTAG5 Boost:
▪  standard 26.4 kbps or
▪  highest bit rate 212 kbps
It is possible to configure amount of data to be exchanged between PN5190 and NTAG 5 boost (check option 3, and then choose among following file dimensions):
▪1KByte
▪2KBytes
▪10KBytes
▪512KBytes
Demonstration flow:
Once one of these options is selected, reader is ready to detect a tag.
▪ When tag is detected, reader configures selected bitrate and starts data exchange.
▪ Blinking green LED indicates transfer ongoing and the console shows a progress.
Here are some results of transaction at the different bit rates and data sizes offered by this demonstrator:
Data Size (Bytes) Selected bitrate (kbps) Result Bitrate (kbps) Transfer time (ms)
1024 26.4 2.8 357
1024 212 12.35 81
2048 26.4 2.8 714
2048 212 12.42 161
10240 26.4 2.7 3569
10240 212 12.41 806
512000 26.4 2.8 177739
512000 212 12.63 39576
High speed demo user manual can be also find attached to this article: 22-10-11 NXP - Connected Tags demonstrator User Manual.pdf
Conclusions: This demonstrator HW & SW can show that high speed interaction can be achieved between PN5190 (NFC Front end) and NTAG 5 boost, making use of available commands described in product support package.
Disclaimer: All SW available here is aimed only for evaluation purposes and NXP disclaims any direct or indirect liability damages, since referred SW bundles are not official part of PN5190/NTAG 5 boost standard product support packages available in nxp.com.
添付
%3CLINGO-SUB%20id%3D%22lingo-sub-1651332%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EPN5190-NTAG%205%20boost%E9%AB%98%E9%80%9F%E9%80%9A%E4%BF%A1%E3%83%87%E3%83%A2%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1651332%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%0A%3CP%3E%3CSTRONG%3E%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AE%E5%86%85%E5%AE%B9%E3%81%AB%E9%81%A9%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%E5%85%8D%E8%B2%AC%E4%BA%8B%E9%A0%85%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22rodolfoveltrigo_0-1684251448915.png%22%20style%3D%22width%3A%20652px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22rodolfoveltrigo_0-1684251448915.png%22%20style%3D%22width%3A%20652px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F223407i83958D2D083563D3%2Fimage-dimensions%2F652x44%3Fv%3Dv2%22%20width%3D%22652%22%20height%3D%2244%22%20role%3D%22button%22%20title%3D%22rodolfoveltrigo_0-1684251448915.png%22%20alt%3D%22rodolfoveltrigo_0-1684251448915.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSTRONG%3EPN5190-NTAG%205%20boost%E9%AB%98%E9%80%9F%E9%80%9A%E4%BF%A1%E3%83%87%E3%83%A2%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%81%AE%E8%A8%98%E4%BA%8B%E3%81%A7%E3%81%AF%E3%80%812%E3%81%A4%E3%81%AE%E3%83%81%E3%83%83%E3%83%97%E3%81%8C%E9%9D%9E%E6%8E%A5%E8%A7%A6%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%A7%E7%9B%B8%E4%BA%92%E3%81%AB%E3%82%84%E3%82%8A%E5%8F%96%E3%82%8A%E3%81%99%E3%82%8B%E9%9A%9B%E3%81%AE%E7%89%B9%E5%BE%B4%E7%9A%84%E3%81%AA%E6%A9%9F%E8%83%BD%E3%81%A8%E3%81%97%E3%81%A6%E3%80%81PN5190%E3%81%A8NTAG5%20Boost%E3%81%AE%E9%96%93%E3%81%A7%E9%AB%98%E3%83%93%E3%83%83%E3%83%88%E3%83%AC%E3%83%BC%E3%83%88%E3%81%AEISO%2015693%E9%80%9A%E4%BF%A1%E3%82%92%E8%A1%8C%E3%81%86%E3%83%91%E3%82%B9%E3%82%B9%E3%83%AB%E3%83%BC%E3%81%AE%E3%83%87%E3%83%A2%E3%83%B3%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%BF%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%E3%83%87%E3%83%A2%E3%83%B3%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%BF%E3%81%AE%E7%AF%84%E5%9B%B2%EF%BC%9A%3C%2FSTRONG%3E%3CBR%20%2F%3E%E2%96%AA%20NXP%20Semiconductors%E3%81%AE%E3%83%A6%E3%83%8B%E3%83%BC%E3%82%AF%E3%81%AA%E7%89%B9%E5%BE%B4%E3%82%92%E5%AE%9F%E8%A8%BC%E3%81%97%E3%81%BE%E3%81%99%E3%80%82NTAG5%20boost%E3%81%AESRAM%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%83%91%E3%82%B9%E3%82%B9%E3%83%AB%E3%83%BC%E3%83%BB%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E5%AE%9F%E8%A3%85%E3%81%97%E3%80%81%3CBR%20%2F%3EPN5190%E3%83%AA%E3%83%BC%E3%83%80IC%E3%81%A8NTAG5%20boost%20%2B%20LPC55S69%E3%83%9B%E3%82%B9%E3%83%88MCU%E3%81%AE%E9%96%93%E3%81%A7%E3%80%81%E9%AB%98%E3%83%93%E3%83%83%E3%83%88%E3%83%AC%E3%83%BC%E3%83%88%E3%81%AE%3CBR%20%2F%3EISO15693%E9%80%9A%E4%BF%A1%EF%BC%88212kbps%EF%BC%89%E3%82%92%E8%A1%8C%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E2%96%AA%20%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%81%AFMCUXpresso%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E9%9D%9E%E6%8E%A5%E8%A7%A6%E3%83%93%E3%83%83%E3%83%88%E3%83%AC%E3%83%BC%E3%83%88%EF%BC%8826.4kbps%E3%81%BE%E3%81%9F%E3%81%AF212kbps%E3%82%92%E9%81%B8%E6%8A%9E%EF%BC%89%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%E3%83%91%E3%82%B9%E3%82%B9%E3%83%AB%E3%83%BC%E3%83%BB%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E4%BA%A4%E6%8F%9B%E3%81%99%E3%82%8B%E3%83%87%E3%83%BC%E3%82%BF%E9%87%8F%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E2%96%AA%20%E3%83%91%E3%82%B9%E3%82%B9%E3%83%AB%E3%83%BC%E3%83%BB%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AFNFC%E3%83%AA%E3%83%BC%E3%83%80%E3%81%8B%E3%82%89LPC%E5%81%B4%E3%81%B8%E3%81%AE%E3%81%BF%E5%AE%9F%E8%A3%85%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E2%96%AA%20PN5190%E3%81%AF%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B6%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E7%B5%90%E6%9E%9C%E3%81%A8%E9%81%94%E6%88%90%E3%81%97%E3%81%9F%E3%83%9C%E3%83%BC%E3%83%AC%E3%83%BC%E3%83%88%E3%82%92MCUXpresso%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E2%96%AA%20%E3%83%91%E3%82%B9%E3%82%B9%E3%83%AB%E3%83%BC%E9%80%9A%E4%BF%A1%E3%82%92%E5%87%A6%E7%90%86%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81NTAG%205%20boost%20%2B%20LPC55S69%E5%81%B4%E3%81%A7%E3%81%AFGPIO%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%81PN5190%20%2B%20MCU%E5%81%B4%E3%81%A7%E3%81%AF%E3%83%8F%E3%83%BC%E3%83%89%E3%82%B3%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%9F%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%E5%BF%85%E8%A6%81%E3%81%AA%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%A8%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E8%A6%81%E7%B4%A0%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%3C%2FSTRONG%3E%3CBR%20%2F%3E%E2%96%AA%20PNEV5190BP%E9%96%8B%E7%99%BA%E3%83%9C%E3%83%BC%E3%83%89%3CBR%20%2F%3E%E2%96%AA%20LPCXpresso55S69%E9%96%8B%E7%99%BA%E3%83%9C%E3%83%BC%E3%83%89%3CBR%20%2F%3E%E2%96%AA%20OM2NTA5332%20-%20NTAG5%20%E3%83%96%E3%83%BC%E3%82%B9%E3%83%88%E9%96%8B%E7%99%BA%E3%82%AD%E3%83%83%E3%83%88%3CBR%20%2F%3E%E2%96%AA%203%20x%20USB%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%3C%2FSTRONG%3E%3CBR%20%2F%3E%E2%96%AA%20PN5190%E3%81%AE%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E3%81%93%E3%81%AE%E8%A8%98%E4%BA%8B%E3%81%AB%E6%B7%BB%E4%BB%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%82%AD%E3%83%BC%E3%83%AF%E3%83%BC%E3%83%89pn5190%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CU%3Emobileknowledge-nxp-connected-tags-pn5190-2cfb4c59b56e_v1.0.zip%3C%2FU%3E%3C%2FP%3E%0A%3CP%3E%E2%96%AA%20SDK_2.x_FRDM-K82F%20%E3%81%AF%E4%B8%8A%E8%A8%98%E3%81%AE%E3%83%90%E3%83%B3%E3%83%89%E3%83%AB%E3%81%AB%E3%81%99%E3%81%A7%E3%81%AB%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E2%96%AA%20LPCXpresso55S69%E3%81%AE%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E3%81%93%E3%81%AE%E8%A8%98%E4%BA%8B%E3%81%AB%E6%B7%BB%E4%BB%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%82%AD%E3%83%BC%E3%83%AF%E3%83%BC%E3%83%89lpc55s69%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CU%3Emobileknowledge-nxp-connected-tags-lpc55s69-5f2f9667cc60_v1.1.zip%3C%2FU%3E%3C%2FP%3E%0A%3CP%3E%E2%96%AA%20MCUXpresso%20IDE%20%E6%9C%80%E6%96%B0%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%EF%BC%88v11.6.0%E4%BB%A5%E9%99%8D%EF%BC%89%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%E3%83%87%E3%83%A2%E3%83%B3%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%BF%E3%81%AE%E6%BA%96%E5%82%99%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3ELPCXpresso55S69%E3%81%AE%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E7%B5%84%E3%81%BF%E7%AB%8B%E3%81%A6%3A%3C%2FSTRONG%3E%3CBR%20%2F%3E%E2%80%A2%20NTAG5%E3%83%96%E3%83%BC%E3%82%B9%E3%83%88%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92LPCXpresso55S69%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3CBR%20%2F%3E%E2%80%A2%20SW6%E3%81%8C2-3%E3%81%AE%E4%BD%8D%E7%BD%AE%E3%81%AB%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%80%81%E3%82%BF%E3%82%B0%E5%81%B4%E3%81%A75V%E9%9B%BB%E6%BA%90%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%E2%80%A2%20LPCXpresso55S69%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E3%82%B3%E3%83%B3%E3%83%94%E3%83%A5%E3%83%BC%E3%82%BF%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%EF%BC%88%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%83%AA%E3%83%B3%E3%82%AF%E5%85%A5%E5%8A%9B%EF%BC%89%E3%80%82%3CBR%20%2F%3E%E2%80%A2%20%E8%BF%BD%E5%8A%A0%E3%81%AE%E9%9B%BB%E6%BA%90%E3%81%AF%E5%BF%85%E8%A6%81%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3EPNEV5190B%E3%81%AE%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E7%B5%84%E3%81%BF%E7%AB%8B%E3%81%A6%EF%BC%9A%3C%2FSTRONG%3E%3CBR%20%2F%3E%E2%80%A2%202%E6%9C%AC%E3%81%AEUSB%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%83%BB%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%82%92PNEV5190B%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%80%81%E9%9B%BB%E6%BA%90%E4%BE%9B%E7%B5%A6%E3%80%81%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%80%81UART%E6%8E%A5%E7%B6%9A%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E2%80%A2%20%E8%B5%A4%E8%89%B2LED%E3%81%AF%E9%9B%BB%E6%BA%90%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E2%80%A2%20%E7%B7%91%E8%89%B2LED%E3%81%AF%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%2FUART%E3%81%AE%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%82%92%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3ELPC55S69%E3%81%A7%E3%81%AE%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E3%83%AD%E3%83%BC%E3%83%89%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%E3%80%8Clpcxpresso55s69_ntag5_passthrough_nolib%E3%80%8D%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92MCUXpresso%20IDE%E3%81%AB%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E2%80%A2%20SDK_2_12_0_LPCXpresso55S69%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82SDK%E3%81%AF%E6%AC%A1%E3%81%AE%E5%A0%B4%E6%89%80%E3%81%8B%E3%82%89%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E2%80%A2%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fsecurity%2Flogin%3Fservice%3Dhttps%253A%252F%252Fmcuxpresso.nxp.com%252Flogin%252F%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fsecurity%2Flogin%3Fservice%3Dhttps%253A%252F%252Fmcuxpresso.nxp.com%252Flogin%252F%3C%2FA%3E%26nbsp%3B%3CBR%20%2F%3E%E2%80%A2%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%80%81GUI%20Flash%20Tool%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%83%BB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E5%BE%8C%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E5%86%8D%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E9%9D%92%E8%89%B2LED%E3%81%8C%E3%82%AA%E3%83%B3%E3%81%AB%E3%81%AA%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E3%82%BF%E3%82%B0%E3%81%8C%E3%83%95%E3%82%A3%E3%83%BC%E3%83%AB%E3%83%89%E3%81%AE%E6%A4%9C%E5%87%BA%E3%82%92%E5%BE%85%E6%A9%9F%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E8%A1%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3EMCUXpresso%E3%81%A7%E3%81%AE%E6%93%8D%E4%BD%9C%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E1.%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8B%E3%82%89%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%3CBR%20%2F%3E2.%20lpcxpresso55s69%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E9%81%B8%E6%8A%9E%3CBR%20%2F%3E3.%20%E3%83%AF%E3%83%BC%E3%82%AF%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%81%AB%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%AB%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%82%92%E5%A4%96%E3%81%99%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3EPNEV5190B%E3%81%A7%E3%81%AE%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E3%83%AD%E3%83%BC%E3%83%89%EF%BC%9A%3C%2FSTRONG%3E%3CBR%20%2F%3E%E2%80%A2%20%E3%80%8CPN5190_NTAG5boost_Passthrough.zip%E3%80%8D%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%82%92%E8%A7%A3%E5%87%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E2%80%A2%20%E3%80%8CPN5190_NTAG5boost_Passthrough%E3%80%8D%E5%86%85%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E3%80%81MCUXpresso%20IDE%E3%81%AB%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E2%80%A2%20SDK_2.x_FRDM-K82F%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AESDK%E3%81%AF%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%83%BB%E3%83%84%E3%83%AA%E3%83%BC%E3%81%AE%E6%AC%A1%E3%81%AE%E5%A0%B4%E6%89%80%E3%81%AB%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E2%80%A2%20nxp-connected-tags-pn5190%5CPlatform%5CSDK_2.x_FRDM-K82F%3CBR%20%2F%3E%E2%80%A2%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%80%81GUI%20Flash%20Tool%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%83%BB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E5%BE%8C%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E5%86%8D%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E9%9D%92%E8%89%B2LED%E3%81%8C%E3%82%AA%E3%83%B3%E3%81%AB%E3%81%AA%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E3%83%AA%E3%83%BC%E3%83%80%E3%81%8CNTAG5%E3%81%AE%E6%A4%9C%E5%87%BA%E3%82%92%E5%BE%85%E6%A9%9F%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E8%A1%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E2%80%A2%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%83%BB%E3%82%BB%E3%83%83%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%80%81%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%E3%83%93%E3%83%83%E3%83%88%E3%83%AC%E3%83%BC%E3%83%88%E3%83%BB%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%81%A7%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3EMCUXpresso%E3%81%A7%E3%81%AE%E6%93%8D%E4%BD%9C%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E1.%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8B%E3%82%89%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%3CBR%20%2F%3E2.%20%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E9%81%B8%E6%8A%9E%3CBR%20%2F%3E3.%20%E3%83%AF%E3%83%BC%E3%82%AF%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%81%AB%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%AB%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%82%92%E5%A4%96%E3%81%99%3C%2FP%3E%0A%3CP%3ELED%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%83%BB%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E4%BB%95%E6%A7%98%EF%BC%88LPCXpresso55S69%E3%81%A8PNEV5190B%E3%81%A7%E5%90%8C%E3%81%98%EF%BC%89%3CBR%20%2F%3E%E2%80%A2%20%E9%9D%92%E8%89%B2%E3%81%A7%E7%82%B9%E7%81%AF%20-%20%E3%82%BF%E3%82%B0%E5%BE%85%E6%A9%9F%E4%B8%AD%20-%20%E6%A4%9C%E5%87%BA%E3%83%AB%E3%83%BC%E3%83%97%E3%80%81%3CBR%20%2F%3E%E2%80%A2%20%E7%B7%91%E8%89%B2%E3%81%A7%E7%82%B9%E6%BB%85%20-%20%E3%83%91%E3%82%B9%E3%82%B9%E3%83%AB%E3%83%BC%E8%BB%A2%E9%80%81%E3%81%8C%E9%80%B2%E8%A1%8C%E4%B8%AD%3CBR%20%2F%3E%E2%80%A2%20%E7%B7%91%E8%89%B2%E3%81%A7%E7%82%B9%E7%81%AF%20-%20%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AE%E8%BB%A2%E9%80%81%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%AE%8C%E4%BA%86%3CBR%20%2F%3E%E2%80%A2%20%E8%B5%A4%E8%89%B2%E3%81%A7%E7%82%B9%E7%81%AF%20-%20%E3%82%A8%E3%83%A9%E3%83%BC%20-%20%E8%BB%A2%E9%80%81%E4%B8%AD%E3%81%AB%E3%82%BF%E3%82%B0%E3%81%8C%E6%B6%88%E5%A4%B1%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E2%E3%81%A4%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AENFC%E3%82%A2%E3%83%B3%E3%83%86%E3%83%8A%E3%81%8C%E5%90%91%E3%81%8B%E3%81%84%E5%90%88%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AE%E3%83%A1%E3%83%8B%E3%83%A5%E3%83%BC%E3%83%BB%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%E3%83%9B%E3%82%B9%E3%83%88%E3%81%8B%E3%82%89NTAG5%20Boost%E3%81%B8%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E8%BB%A2%E9%80%81%E9%87%8F%E3%81%AB%E9%96%A2%E3%81%97%E3%81%A6%E3%80%81%E6%AC%A1%E3%81%AE2%E3%81%A4%E3%81%AE%E3%83%93%E3%83%83%E3%83%88%E3%83%AC%E3%83%BC%E3%83%88%E3%83%BB%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E2%96%AA%20%E6%A8%99%E6%BA%96%2026.4%20kbps%20%E3%81%BE%E3%81%9F%E3%81%AF%3C%2FP%3E%0A%3CP%3E%E2%96%AA%20%E6%9C%80%E9%AB%98%E3%83%93%E3%83%83%E3%83%88%E3%83%AC%E3%83%BC%E3%83%88%20212%20kbps%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E%3CSTRONG%3EPN5190%E3%81%A8NTAG%205%20boost%E3%81%AE%E9%96%93%E3%81%A7%E4%BA%A4%E6%8F%9B%E3%81%99%E3%82%8B%E3%83%87%E3%83%BC%E3%82%BF%E9%87%8F%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%8C%E5%8F%AF%E8%83%BD%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%E2%96%AA1KByte%3C%2FP%3E%0A%3CP%3E%E2%96%AA2K%E3%83%90%E3%82%A4%E3%83%88%3C%2FP%3E%0A%3CP%3E%E2%96%AA10K%E3%83%90%E3%82%A4%E3%83%88%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%E3%83%87%E3%83%A2%E3%83%B3%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E3%83%95%E3%83%AD%E3%83%BC%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E3%81%84%E3%81%9A%E3%82%8C%E3%81%8B%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%83%AA%E3%83%BC%E3%83%80%E3%83%BC%E3%81%AF%E3%82%BF%E3%82%B0%E3%82%92%E6%A4%9C%E5%87%BA%E3%81%99%E3%82%8B%E6%BA%96%E5%82%99%E3%81%8C%E6%95%B4%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E2%96%AA%20%E3%82%BF%E3%82%B0%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%82%8B%E3%81%A8%E3%80%81%E3%83%AA%E3%83%BC%E3%83%80%E3%83%BC%E3%81%AF%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%9F%E3%83%93%E3%83%83%E3%83%88%E3%83%AC%E3%83%BC%E3%83%88%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%E4%BA%A4%E6%8F%9B%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E2%96%AA%20%E7%B7%91%E8%89%B2%E3%81%AELED%E3%81%8C%E7%82%B9%E6%BB%85%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E3%80%81%E8%BB%A2%E9%80%81%E3%81%8C%E9%80%B2%E8%A1%8C%E4%B8%AD%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%81%AB%E9%80%B2%E8%A1%8C%E7%8A%B6%E6%B3%81%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%81%AE%E3%83%87%E3%83%A2%E3%83%B3%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%BF%E3%81%8C%E5%AF%BE%E5%BF%9C%E3%81%99%E3%82%8B%E3%81%95%E3%81%BE%E3%81%96%E3%81%BE%E3%81%AA%E3%83%93%E3%83%83%E3%83%88%E3%83%AC%E3%83%BC%E3%83%88%E3%81%A8%E3%83%87%E3%83%BC%E3%82%BF%E3%83%BB%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%A7%E3%81%AE%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B6%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E7%B5%90%E6%9E%9C%E3%82%92%E4%BB%A5%E4%B8%8B%E3%81%AB%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CTABLE%20border%3D%221%22%20width%3D%22100%25%22%3E%0A%3CTBODY%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2225%25%22%20height%3D%2225px%22%3E%E3%83%87%E3%83%BC%E3%82%BF%E3%83%BB%E3%82%B5%E3%82%A4%E3%82%BA%EF%BC%88%E3%83%90%E3%82%A4%E3%83%88%EF%BC%89%3C%2FTD%3E%0A%3CTD%20width%3D%2225%25%22%20height%3D%2225px%22%3E%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%9F%E3%83%93%E3%83%83%E3%83%88%E3%83%AC%E3%83%BC%E3%83%88%EF%BC%88kbps%EF%BC%89%3C%2FTD%3E%0A%3CTD%20width%3D%2225%25%22%20height%3D%2225px%22%3E%E7%B5%90%E6%9E%9C%E3%83%93%E3%83%83%E3%83%88%E3%83%AC%E3%83%BC%E3%83%88%20(kbps)%3C%2FTD%3E%0A%3CTD%20width%3D%2225%25%22%20height%3D%2225px%22%3E%E8%BB%A2%E9%80%81%E6%99%82%E9%96%93%EF%BC%88ms%EF%BC%89%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2225%25%22%20height%3D%2225px%22%3E1024%3C%2FTD%3E%0A%3CTD%20width%3D%2225%25%22%20height%3D%2225px%22%3E26.4%3C%2FTD%3E%0A%3CTD%20width%3D%2225%25%22%20height%3D%2225px%22%3E2.8%3C%2FTD%3E%0A%3CTD%20width%3D%2225%25%22%20height%3D%2225px%22%3E357%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2225%25%22%20height%3D%2225px%22%3E1024%3C%2FTD%3E%0A%3CTD%20width%3D%2225%25%22%20height%3D%2225px%22%3E212%3C%2FTD%3E%0A%3CTD%20width%3D%2225%25%22%20height%3D%2225px%22%3E12.35%3C%2FTD%3E%0A%3CTD%20width%3D%2225%25%22%20height%3D%2225px%22%3E81%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2225%25%22%20height%3D%2225px%22%3E2048%3C%2FTD%3E%0A%3CTD%20width%3D%2225%25%22%20height%3D%2225px%22%3E26.4%3C%2FTD%3E%0A%3CTD%20width%3D%2225%25%22%20height%3D%2225px%22%3E2.8%3C%2FTD%3E%0A%3CTD%20width%3D%2225%25%22%20height%3D%2225px%22%3E714%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2225%25%22%20height%3D%2225px%22%3E2048%3C%2FTD%3E%0A%3CTD%20width%3D%2225%25%22%20height%3D%2225px%22%3E212%3C%2FTD%3E%0A%3CTD%20width%3D%2225%25%22%20height%3D%2225px%22%3E12.42%3C%2FTD%3E%0A%3CTD%20width%3D%2225%25%22%20height%3D%2225px%22%3E161%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2225%25%22%20height%3D%2225px%22%3E10%2C240%3C%2FTD%3E%0A%3CTD%20width%3D%2225%25%22%20height%3D%2225px%22%3E26.4%3C%2FTD%3E%0A%3CTD%20width%3D%2225%25%22%20height%3D%2225px%22%3E2.7%3C%2FTD%3E%0A%3CTD%20width%3D%2225%25%22%20height%3D%2225px%22%3E3569%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2225%25%22%20height%3D%2225px%22%3E10%2C240%3C%2FTD%3E%0A%3CTD%20width%3D%2225%25%22%20height%3D%2225px%22%3E212%3C%2FTD%3E%0A%3CTD%20width%3D%2225%25%22%20height%3D%2225px%22%3E12.41%3C%2FTD%3E%0A%3CTD%20width%3D%2225%25%22%20height%3D%2225px%22%3E806%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E9%AB%98%E9%80%9F%E9%80%9A%E4%BF%A1%E3%83%87%E3%83%A2%E3%81%AE%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%83%BB%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%81%AF%E3%81%93%E3%81%AE%E8%A8%98%E4%BA%8B%E3%81%AB%E6%B7%BB%E4%BB%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CU%3E22-10-11%20NXP%20-%20Connected%20Tags%20demonstrator%20User%20Manual.pdf%3C%2FU%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%E7%B5%90%E8%AB%96%EF%BC%9A%3C%2FSTRONG%3E%E3%81%93%E3%81%AE%E3%83%87%E3%83%A2%E7%94%A8%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%8A%E3%82%88%E3%81%B3%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AF%E3%80%81%E8%A3%BD%E5%93%81%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E6%B4%BB%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%80%81PN5190%EF%BC%88NFC%E3%83%95%E3%83%AD%E3%83%B3%E3%83%88%E3%82%A8%E3%83%B3%E3%83%89%EF%BC%89%E3%81%A8NTAG%205%E3%83%96%E3%83%BC%E3%82%B9%E3%83%88%E3%81%AE%E9%96%93%E3%81%A7%E9%AB%98%E9%80%9F%E3%81%AA%E7%9B%B8%E4%BA%92%E4%BD%9C%E7%94%A8%E3%82%92%E5%AE%9F%E7%8F%BE%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%E5%85%8D%E8%B2%AC%E4%BA%8B%E9%A0%85%EF%BC%9A%3C%2FSTRONG%3E%E3%81%93%E3%81%93%E3%81%A7%E5%85%A5%E6%89%8B%E5%8F%AF%E8%83%BD%E3%81%AA%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AF%E3%80%81%E8%A9%95%E4%BE%A1%E7%9B%AE%E7%9A%84%E3%81%AE%E3%81%BF%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E6%84%8F%E5%9B%B3%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81NXP%E3%81%AF%E7%9B%B4%E6%8E%A5%E7%9A%84%E3%81%BE%E3%81%9F%E3%81%AF%E9%96%93%E6%8E%A5%E7%9A%84%E3%81%AA%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E6%90%8D%E5%AE%B3%E8%B3%A0%E5%84%9F%E8%B2%AC%E4%BB%BB%E3%82%92%E5%90%A6%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%93%E3%81%A7%E8%A8%80%E5%8F%8A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%BB%E3%83%90%E3%83%B3%E3%83%89%E3%83%AB%E3%81%AF%E3%80%81nxp.com%E3%81%A7%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8BPN5190%2FNTAG%205%20boost%E3%81%AE%E6%A8%99%E6%BA%96%E8%A3%BD%E5%93%81%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%83%BB%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%AE%E5%85%AC%E5%BC%8F%E3%81%AA%E4%B8%80%E9%83%A8%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3C%2FLINGO-BODY%3E
0%が役に立ったと言っています (0/1)
バージョン履歴
最終更新日:
‎11-26-2025 08:09 AM
更新者:
