Hi Vijaybhaskar
i.MX8M Mini has 1.2 V MIPI-CSI levels, though power group of 1.8V.
>2) previously, we have written a mail to NXP technical support. In reply mail
>you have mentioned that iMX8 mini MIPI signal voltage level is 1.8V.
sorry this is not true. In attached answer there are no such words.
Most correct answer can be found in MIPI CSI2, MIPI D-PHY specifications
for example one can look at sect.4.12.12 MIPI D-PHY Timing Parameters
i.MX 6Dual/6Quad Applications Processors for Consumer Products - Data Sheet
