IMX-MIPI-HDMI interface board documentation
1,376 次查看
nsdy
Does the IMX-MIPI-HDMI interface board work both ways, or does it only go MIPI to HDMI? I need a solution for HDMI to MIPI. I can't find a user's manual or datasheet on this part. Is there one available?
Thank you!
1 回复
1,366 次查看
Bio_TICFSL
Hello nsdy,
IT can only use for MIPI - HDMI converter, There is no solution for HDMI-MIPI since not all the iMX has HDMI input, the  proper documentation for iMX-MIPI-HDMI is:
https://www.nxp.com/webapp/Download?colCode=AN12188
