ROM bootloader changed to CPU rev 1.3 ?
2,551 次查看
peterbärtsch
We use the imx6sx process with raw NAND Flash. Everything works fine with processor rev 1.2.
Now we produced some modules with CPU rev 1.3. And the CPU dosn't boot form NAND it goes directly in USB boot mode. I can download u-boot over USB (mfg tool) and then it is able to boot the Linux. But the ROM bootloader doesn't work.
I was not able to find out what chaned to rev 1.3 ... wtf..
What should I do?
Peter
2,396 次查看
peterbärtsch
Thx for your response.
I found a patch for kobs-ng.
https://community.nxp.com/docs/DOC-331342
Peter
2,396 次查看
igorpadykov
Hi Peter
please check EB832 i.MX6SoloX Application Processor Silicon Revision 1.2 to 1.3 Comparison
http://www.nxp.com/assets/documents/data/en/engineering-bulletins/EB832.pdf
2,397 次查看
peterbärtsch
Peter
