iMX6 TW686x Surround view patch
We use PCIe to connect Intersil TW6865 chip for the surround view solution.
This is the block diagram of the connection:
This is the 4 camera surround view:5173_5173.JPG4.JPG
Code base is L3.0.35_12.10.02 release. You can merge the patch file to the latest Freescale release.
Please check the attach file for the patch code.
Note:  It is only a test version.
The last code for L3.0.35 BSP: L3.0.35_GA4.1.0 Patches.7z
The last code for L3.10.53 BSP: L3.10.53_TW686x_patch.7z
Patch for L4.1.15 1.1.0 GA BSP: TW6865 driver for Linux L4.1.15_1.1.0-ga.7z
Labels (4)
Comments
Hi, is your intended video device enumerated ? i.e. what v4l2-ctl -d /dev/videox --all give you ?
and try exactly this :
gst-launch-1.0 -v v4l2src device=/dev/video0 ! video/x-raw,width=720,height=480,pixelformat=UYVY ! imxipuvideotransform ! imxeglvivsink
Note, for me pci MSI had to be disabled in order to get video frames !!!
Thanks!
Now it's working with " gst-launch-1.0 v4l2src device=/dev/video2 ! imxv4l2sink overlay-width=512 overlay-height=300 overlay-top=300 overlay-left=0 "
I don't know why imxv4l2src doesn't work.
"v4l2-ctl -d /dev/videox --all" outputs is here:
Driver Info (not using libv4l2):
Driver name : tw686x
Card type : tw6869
Bus info : PCI:0000:01:00.0
Driver version: 4.1.15
Capabilities : 0x85200001
Video Capture
Read/Write
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x05200001
Video Capture
Read/Write
Streaming
Extended Pix Format
Priority: 2
Video input : 0 (Composite0: ok)
Video Standard = 0x0000b000
NTSC-M/M-JP/M-KR
Format Video Capture:
Width/Height : 360/240
Pixel Format : 'YUYV'
Field : Interlaced
Bytes per Line: 720
Size Image : 172800
Colorspace : Broadcast NTSC/PAL (SMPTE170M/ITU601)
Flags :
Streaming Parameters Video Capture:
Capabilities : timeperframe
Frames per second: 30.000 (30/1)
Read buffers : 3
User Controls
brightness (int) : min=-128 max=127 step=1 default=0 value=0 flags=slider
contrast (int) : min=0 max=255 step=1 default=100 value=100 flags=slider
saturation (int) : min=0 max=255 step=1 default=128 value=128 flags=slider
hue (int) : min=-128 max=127 step=1 default=0 value=0 flags=slider
If I use imxv4l2src, it will say "could not link imxv4l2src0 to imxv4l2sink0".
Hi, now can you get the video stream without any latency as expected ? Do you have a git link to the driver you use with sabresd ? Or are you using a different board ?
Anuradha
1. For now, I'm using only one camera, if I run two or more camera there will be some error message:
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data flow error.
Additional debug info:
../../../../gstreamer-1.8.1/libs/gst/base/gstbasesrc.c(2948): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
streaming task paused, reason error (-5)
command is below:
gst-launch-1.0 v4l2src device=/dev/video0 ! imxv4l2sink overlay-width=512 overlay-height=300 overlay-top=0 overlay-left=0 &
gst-launch-1.0 v4l2src device=/dev/video1 ! imxv4l2sink overlay-width=512 overlay-height=300 overlay-top=0 overlay-left=512 &
For one camera, there is no latency.
2.  I use the driver you provided is another post, linux-imx6/drivers/media/pci/tw686x at boundary-imx_4.1.15_2.0.0_ga · boundarydevices/linux-imx6 · G... , I also try this one GitHub - sasamy/tw6869: tw6869/65 media bridge driver , same result.
I'm using a customed board.
I remember I had 'unexpected p-b buffer' issue while running the camera, but I was experimenting this on one of the Boundary Devices boards. Which board and distro are you using ? Can you also show the current memory map in kernel log?
i.e :-
Memory: 3551600K/3932156K available (8196K kernel code, 314K rwdata, 2448K rodata, 1024K init, 444K bss, 52876K reserved, 327680K cma-reserved, 2260988K highmem)
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
    vmalloc : 0xe6800000 - 0xff000000   ( 392 MB)
    lowmem  : 0x80000000 - 0xe6000000   (1632 MB)
    pkmap   : 0x7fe00000 - 0x80000000   (   2 MB)
    modules : 0x7f000000 - 0x7fe00000   (  14 MB)
      .text : 0x80008000 - 0x80b650ac   (11637 kB)
      .init : 0x80c00000 - 0x80d00000   (1024 kB)
      .data : 0x80d00000 - 0x80d4ea40   ( 315 kB)
       .bss : 0x80d51000 - 0x80dc0320   ( 445 kB)
Anuradha
My board is not belong to boundary boards.
yocto distro: "4.1.15-2.0.1", "fsl-imx-x11"
memory map:
Memory: 698176K/1048576K available (8364K kernel code, 432K rwdata, 3000K rodata, 432K init, 450K bss, 22720K reserved, 327680K cma-reserved, 0K highmem)
[ 0.000000] Virtual kernel memory layout:
vmalloc : 0xc0800000 - 0xff000000 (1000 MB)
lowmem : 0x80000000 - 0xc0000000 (1024 MB)
.text : 0x80008000 - 0x80b215e0 (11366 kB)
.init : 0x80b22000 - 0x80b8e000 ( 432 kB)
.data : 0x80b8e000 - 0x80bfa160 ( 433 kB)
.bss : 0x80bfd000 - 0x80c6d8c0 ( 451 kB)
I use the official kernel and use the boundary kernel's tw686x driver, I have also edited the quirk.c file.
Hi, have you got the issue resolved ? I can't see any issue in your logs. I also have the imxv4l2src video issue. I cannot even run a single camera consistently, the system freezes at a point and I am receiving 'unexpected p-b buffer issue' from the driver. I used Ubuntu for this. If there are any updates, please share with me !
I have not solved the imxv4l2src video issue.
The first thing is to make sure weather it is kernel's issue or gstreamer. Can you try nfs root? If so, it will be much convenient to try this rootfs:
rootfs.tar.bz2 - Google Drive , note it's for my linux 3.0.5, but it's also working for my linux 4.1.15 with device tree.
And then use
gst-launch-0.10 v4l2src device=/dev/video0 ! 'video/x-raw-yuv, format=(fourcc)UYVY' ! mfw_isink disp-width=512 disp-height=300 axis-left=0 axis-top=0
test it.
Btw how can I add mfw_isink ? I have no such element in gst-inspect !
The command above only suitable to the gst-launch-0.10 in the rootfs I provide.
Hi Lei Ma,
Have you got the camera issue resolved with boundary devices driver ? I still have this latency and freezing issue. I am strictly following the data sheet schematic of tw6865 chip !
Sorry, I'm not familiar with linux device driver, for now I'm focus on image process with opengl es and opencv.
Boundary devices driver has two drivers for tw6865, one is tw6869 from GitHub - sasamy/tw6869: tw6869/65 media bridge driver  another is tw686x from upstream kernel, I use the upstream one.
Hi, that's right. I am referring to the upstream kernel driver. Since you got it working without any problem I was wondering whether you have made a change to HW or Driver. In my case, for the upstream kernel driver, the video starts and frame rate becomes very low and then system hangs. I also see the 'unexpected p-b buffer' error in dmesg. Did you have to disable audio support or anything like that ? I had to disable pcie interrupt as well to get it work.... If you don't mind can you kindly share your linux .conf file ? I want to see kernel configurations under pcie.
Here is my kernel config file, .config - Google Drive , I also disabled pcie interrupt.
Thanks very much Lei, this is very helpful. Btw do you see 'unexpected p-b buffer' error appears in dmesg when running the camera ?
Anuradha
No, there is no such error in my device.
Hi, thanks alot for the prompt repose. That confirms one thing to me, there is a problem in the driver or my hardware !
Anuradha
Hi, one last thing to confirm Lei, are you aware of following patch for dma allocation ?
https://git.congatec.com/arm/qmx6_kernel/commit/f4857b5482c67dcc9757d50cf57cb32728af788b?w=1
https://community.nxp.com/thread/304368
If you don't mind, can you kindly check or share videobuf-dma-contig.c or mxc_vpu.c files of your running kernel ? I saw in several posts, these changes are required. If you're not aware, I'd like to point this for your attention too.....
I don't know that, my kernel version is 4.1.15, and these two files is bit different.
videobuf-dma-contig.c - Google Drive
mxc_vpu.c - Google Drive
Hi Lei Ma,
I got to know from the original author of the driver that, imxv4l2videosrc only works for csi cameras. Not with this pci stuffs. So correct source is v4l2src !
Btw is your single camera working well for gst-launch-1.0 with imxv4l2sink as well ? Without any latency ? can you also show me your pci/quirks.c file ?
Kindly confirm me it .........
Anuradha
Sorry I forget this. Is "latency" means delay? If is there is no latency with my camera.
quirks.c - Google Drive
Dear, Liqiang
Qiang_FSL
We are using your patch( TW6865 driver for Linux L4.1.15_1.1.0-ga.7z)and trying to develop 4 camera surroundview application base on imx6d chip and PCIE\TW68x\ CVBS camera , but meet a problem!
The application always freeze at the following codes:
    if (ioctl(m_ifd, IPU_CHECK_TASK, &m_sTask) != IPU_CHECK_OK) {
        printf("IPU_CHECK_TASK failed.\r\n");
        return -1;
Do you know the reason? thanks a lot!
我们的目标是想做到程序的zerocopy,但从现象上看好像是在做VDI的时候程序freeze了。
Qiang_FSL
补充:
我们分配内存使用的接口是glTexDirectVIV, 而没有使用例子代码中的g2d_alloc;
是这个原因导致IPU在做VDI失败吗?
我们确认下来,只有使用g2d_alloc分配内存才能正常的进行VDI;如果使用malloc分配内存,程序会freeze!
是不是可以理解成这个patch( TW6865 driver for Linux L4.1.15_1.1.0-ga.7)中只支持VDI到g2d_alloc的空间,不支持VDI到malloc空间?
如果需要支持到malloc,应该怎么处理?谢谢!~~~
IPU task's input.paddr and output.paddr should be physical address of the input buffer and output buffer, if you use wrong address, it will fail to work.
谢谢你的回答!
1.)VDI到g2d,
2.)再通过gl映射内存。
硬件DMA操作需要使用物理连续内存,malloc分配的内存不符合要求。
Hi Qiang Li:
I use the IMX6Q core board. Now when using both GC2000 and GC320, there are occasional image tears on the screen display.
The specific implementation is like this:
   Get the real-time video data of the 4-way camera, display it on the GPU and display it in real time on the lvds screen. At the same time, the 4 channels of video are called by g2d to call the g2g_blit function for resize. The image of each frame is 720P resize to 640*480, and then synthesized into one frame. Image so that 4 channels of video can be displayed in one frame.the spliced video is not display on the screen and saved directly into the video,but now it is found that the video displayed by the GPU rendering in real time will be torn. Playback of the saved video also found that the image has a tearing problem, affecting the viewing effect.
   If you test the GPU rendering display separately, or the video of 4 channels of video is saved by G2D synthesis, there will be no image tearing problem.
But as long as these two functions are combined into one project, the problem of image tearing will occur when displaying and the saving  video.
1. Can I use the GC2000 of IMX6 and GC320 at the same time? Is there a problem with GPU resource preemption?
2. Is there a problem with data conflicts in the GPU? I have already made the GC2000 and GC320 get data that cannot be bufed, but after the two functions are integrated, there will still be a problem of video tearing.
I think you need check the delay for each processing step, before next processing, maybe the pre-step is not finished.
Hi,liqiang
麻烦确认一下:
我这样应用在那里用到了DMA?
你的意思是说g2d_alloc 分配的不是连续物理内存吗?g2d_alloc 是如何分配内存的?
谢谢!
g2d_allo分配的就是物理连续内存,而malloc分配的就不是。
camera抓取图像,IPU task操作和G2D操作的源buffer和目标buffer都要求是物理连续内存。
了解了,谢谢!
顺便再问下:
glTexDirectVIVMap映射的内存,必须是物理连续的吗?谢谢!
另外,glTexDirectVIV 分配的内存是物理连续内存吗?谢谢
glTexDirectVIVMap()也可以得到物理连续内存,它的最后一个参数Physical可以用作IPU task操作和G2D操作的目标buffer。
According to what you mean, is the GC2000 and GC320 taking up the GPU in sequence? After the GC2000 has finished performing the on-screen rendering, can the GC320 take up GPU resources for 4-way image synthesis? Or first GC320 execution, then GC2000 re-execution? For different data buffers, can the two modules GC2000 and GC320 not run at the same time?
GC2000 and GC320 can run at the same time.
Hi,liqiang
我使用IMX6Q平台,现在有四路视频需要分别保存每个通道的视频数据,四路视频流是怎么进入VPU中进行编码的?单路的编码比较好实现,
4路视频需要串行的经过VPU,这个逻辑我实现起来毫无头绪,可否提供类似的资料链接或demo啊?
谢谢
4路编码和1路编是一样的,只要开4个任务就好了,但是VPU硬件不能支持4路720P编码
VPU可以同时编码分辨率时多少的4路视频?4个任务 同时使用VPU进行编码,不会有冲突吗?都会去抢占VPU的资源吧? 因为我使用IPU的时候可以创建4个任务,2个IPU,每个IPU内核中创建2个ipu_task,但是VPU也是有类似IPU的机制吗?不是很明确VPU的机制
VPU的软件架构支持多任务,当然,实际在VPU硬件上编码的时候,还是排队进行的。
我使用gstreamer进行4路视频编码为h264格式,使用让这个命令:srcapp->imxvideoconvert_ipu->vpuenc_h264->filesink, 我直接创建4 个pipeline就可以4路编码吗?系统会再VPU编码时自动处理每一路的编码顺序?
%3CLINGO-SUB%20id%3D%22lingo-sub-1110182%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EiMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110182%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EWe%20use%20PCIe%20to%20connect%20Intersil%20TW6865%20chip%20for%20the%20surround%20view%20solution.%3C%2FP%3E%3CP%3EThis%20is%20the%20connection%20of%20PCIe%20to%20iMX6Q%20SabreSD%20board.%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%225171_5171.JPG%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%225171_5171.JPG%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%225171_5171.JPG%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%225171_5171.JPG%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%225171_5171.JPG%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%225171_5171.JPG%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%225171_5171.JPG%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%225171_5171.JPG%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%225171_5171.JPG%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%225171_5171.JPG%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%225171_5171.JPG%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%225171_5171.JPG%22%20style%3D%22width%3A%20749px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%225171_5171.JPG%22%20style%3D%22width%3A%20749px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117155iEE182166EA73B7BF%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%225171_5171.JPG%22%20alt%3D%225171_5171.JPG%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E5171_5171.JPG%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.JPG%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.JPG%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.JPG%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.JPG%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.JPG%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.JPG%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.JPG%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.JPG%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.JPG%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.JPG%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.JPG%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.JPG%22%20style%3D%22width%3A%20749px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.JPG%22%20style%3D%22width%3A%20749px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F63252i97BFB8670817C82C%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%221.JPG%22%20alt%3D%221.JPG%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E1.JPG%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3EThis%20is%20the%20block%20diagram%20of%20the%20connection%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%225172_5172.JPG%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%225172_5172.JPG%22%20style%3D%22width%3A%20766px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%225172_5172.JPG%22%20style%3D%22width%3A%20766px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%225172_5172.JPG%22%20style%3D%22width%3A%20766px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%225172_5172.JPG%22%20style%3D%22width%3A%20766px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%225172_5172.JPG%22%20style%3D%22width%3A%20766px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%225172_5172.JPG%22%20style%3D%22width%3A%20766px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%225172_5172.JPG%22%20style%3D%22width%3A%20766px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%225172_5172.JPG%22%20style%3D%22width%3A%20766px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%225172_5172.JPG%22%20style%3D%22width%3A%20766px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%225172_5172.JPG%22%20style%3D%22width%3A%20766px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%225172_5172.JPG%22%20style%3D%22width%3A%20766px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%225172_5172.JPG%22%20style%3D%22width%3A%20766px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117156iD8AB5729CD358005%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%225172_5172.JPG%22%20alt%3D%225172_5172.JPG%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E5172_5172.JPG%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%223.JPG%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%223.JPG%22%20style%3D%22width%3A%20766px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%223.JPG%22%20style%3D%22width%3A%20766px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%223.JPG%22%20style%3D%22width%3A%20766px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%223.JPG%22%20style%3D%22width%3A%20766px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%223.JPG%22%20style%3D%22width%3A%20766px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%223.JPG%22%20style%3D%22width%3A%20766px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%223.JPG%22%20style%3D%22width%3A%20766px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%223.JPG%22%20style%3D%22width%3A%20766px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%223.JPG%22%20style%3D%22width%3A%20766px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%223.JPG%22%20style%3D%22width%3A%20766px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%223.JPG%22%20style%3D%22width%3A%20766px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%223.JPG%22%20style%3D%22width%3A%20766px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F110925i5BE7069E73C283AF%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%223.JPG%22%20alt%3D%223.JPG%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E3.JPG%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EThis%20is%20the%204%20camera%20surround%20view%3A%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%225173_5173.JPG%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%225173_5173.JPG%22%20style%3D%22width%3A%20779px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%225173_5173.JPG%22%20style%3D%22width%3A%20779px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%225173_5173.JPG%22%20style%3D%22width%3A%20779px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%225173_5173.JPG%22%20style%3D%22width%3A%20779px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%225173_5173.JPG%22%20style%3D%22width%3A%20779px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%225173_5173.JPG%22%20style%3D%22width%3A%20779px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%225173_5173.JPG%22%20style%3D%22width%3A%20779px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%225173_5173.JPG%22%20style%3D%22width%3A%20779px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%225173_5173.JPG%22%20style%3D%22width%3A%20779px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%225173_5173.JPG%22%20style%3D%22width%3A%20779px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%225173_5173.JPG%22%20style%3D%22width%3A%20779px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%225173_5173.JPG%22%20style%3D%22width%3A%20779px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117157i93B54CB8E51A864A%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%225173_5173.JPG%22%20alt%3D%225173_5173.JPG%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E5173_5173.JPG%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%224.JPG%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%224.JPG%22%20style%3D%22width%3A%20779px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%224.JPG%22%20style%3D%22width%3A%20779px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%224.JPG%22%20style%3D%22width%3A%20779px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%224.JPG%22%20style%3D%22width%3A%20779px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%224.JPG%22%20style%3D%22width%3A%20779px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%224.JPG%22%20style%3D%22width%3A%20779px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%224.JPG%22%20style%3D%22width%3A%20779px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%224.JPG%22%20style%3D%22width%3A%20779px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%224.JPG%22%20style%3D%22width%3A%20779px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%224.JPG%22%20style%3D%22width%3A%20779px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%224.JPG%22%20style%3D%22width%3A%20779px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%224.JPG%22%20style%3D%22width%3A%20779px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F110924iD64E303E5B9048E7%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%224.JPG%22%20alt%3D%224.JPG%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E4.JPG%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3ECode%20base%20is%20L3.0.35_12.10.02%20release.%20You%20can%20merge%20the%20patch%20file%20to%20the%20latest%20Freescale%20release.%3C%2FP%3E%3CP%3EPlease%20check%20the%20attach%20file%20for%20the%20patch%20code.%3C%2FP%3E%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3ENote%3A%26nbsp%3B%20It%20is%20only%20a%20test%20version.%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3EThe%20last%20code%20for%20L3.0.35%20BSP%3A%20L3.0.35_GA4.1.0%20Patches.7z%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3EThe%20last%20code%20for%20L3.10.53%20BSP%3A%20L3.10.53_TW686x_patch.7z%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3EPatch%20for%20L4.1.15%201.1.0%20GA%20BSP%3A%20TW6865%20driver%20for%20Linux%20L4.1.15_1.1.0-ga.7z%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1110182%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX6DL%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6Dual%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6Quad%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110269%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110269%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EGC2000%20and%20GC320%20can%20run%20at%20the%20same%20time.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110268%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110268%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EAccording%20to%20what%20you%20mean%2C%20is%20the%20GC2000%20and%20GC320%20taking%20up%20the%20GPU%20in%20sequence%3F%20After%20the%20GC2000%20has%20finished%20performing%20the%20on-screen%20rendering%2C%20can%20the%20GC320%20take%20up%20GPU%20resources%20for%204-way%20image%20synthesis%3F%20Or%20first%20GC320%20execution%2C%20then%20GC2000%20re-execution%3F%20For%20different%20data%20buffers%2C%20can%20the%20two%20modules%20GC2000%20and%20GC320%20not%20run%20at%20the%20same%20time%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110261%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110261%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20think%20you%20need%20check%20the%20delay%20for%20each%20processing%20step%2C%20before%20next%20processing%2C%20maybe%20the%20pre-step%20is%20not%20finished.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110260%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110260%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20style%3D%22background-color%3A%20transparent%3B%20border-image-outset%3A%200%3B%20border-image-repeat%3A%20stretch%3B%20border-image-slice%3A%20100%25%3B%20border-image-source%3A%20none%3B%20border-image-width%3A%201%3B%20color%3A%20%2351626f%3B%20font-family%3A%20arial%2Chelvetica%2C%22%20helvetica%3D%22%22%20neue%3D%22%22%3EHi%20Qiang%20Li%EF%BC%9A%3C%2FP%3E%3CDIV%20style%3D%22background-color%3A%20transparent%3B%20border-image-outset%3A%200%3B%20border-image-repeat%3A%20stretch%3B%20border-image-slice%3A%20100%25%3B%20border-image-source%3A%20none%3B%20border-image-width%3A%201%3B%20color%3A%20%2351626f%3B%20font-family%3A%20arial%2Chelvetica%2C%22%20helvetica%3D%22%22%20neue%3D%22%22%3EI%20use%20the%20IMX6Q%20core%20board.%20Now%20when%20using%20both%20GC2000%20and%20GC320%2C%20there%20are%20occasional%20image%20tears%20on%20the%20screen%20display.%3CBR%20style%3D%22border-image-outset%3A%200%3B%20border-image-repeat%3A%20stretch%3B%20border-image-slice%3A%20100%25%3B%20border-image-source%3A%20none%3B%20border-image-width%3A%201%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-weight%3A%20400%3B%20vertical-align%3A%20baseline%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%20border%3A%200px%20none%20%2351626f%3B%22%20%2F%3EThe%20specific%20implementation%20is%20like%20this%3A%3CBR%20style%3D%22border-image-outset%3A%200%3B%20border-image-repeat%3A%20stretch%3B%20border-image-slice%3A%20100%25%3B%20border-image-source%3A%20none%3B%20border-image-width%3A%201%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-weight%3A%20400%3B%20vertical-align%3A%20baseline%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%20border%3A%200px%20none%20%2351626f%3B%22%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3BGet%20the%20real-time%20video%20data%20of%20the%204-way%20camera%2C%20display%20it%20on%20the%20GPU%20and%20display%20it%20in%20real%20time%20on%20the%20lvds%20screen.%20At%20the%20same%20time%2C%20the%204%20channels%20of%20video%20are%20called%20by%20g2d%20to%20call%20the%20g2g_blit%20function%20for%20resize.%20The%20image%20of%20each%20frame%20is%20720P%20resize%20to%20640*480%2C%20and%20then%20synthesized%20into%20one%20frame.%20Image%20so%20that%204%20channels%20of%20video%20can%20be%20displayed%20in%20one%20frame.the%20spliced%20video%20is%20not%20display%20on%20the%20screen%20and%20saved%20directly%20into%20the%20video%2Cbut%20now%20it%20is%20found%20that%20the%20video%20displayed%20by%20the%20GPU%20rendering%20in%20real%20time%20will%20be%20torn.%20Playback%20of%20the%20saved%20video%20also%20found%20that%20the%20image%20has%20a%20tearing%20problem%2C%20affecting%20the%20viewing%20effect.%3C%2FDIV%3E%3CDIV%20style%3D%22background-color%3A%20transparent%3B%20border-image-outset%3A%200%3B%20border-image-repeat%3A%20stretch%3B%20border-image-slice%3A%20100%25%3B%20border-image-source%3A%20none%3B%20border-image-width%3A%201%3B%20color%3A%20%2351626f%3B%20font-family%3A%20arial%2Chelvetica%2C%22%20helvetica%3D%22%22%20neue%3D%22%22%3E%20%3C%2FDIV%3E%3CDIV%20style%3D%22background-color%3A%20transparent%3B%20border-image-outset%3A%200%3B%20border-image-repeat%3A%20stretch%3B%20border-image-slice%3A%20100%25%3B%20border-image-source%3A%20none%3B%20border-image-width%3A%201%3B%20color%3A%20%2351626f%3B%20font-family%3A%20arial%2Chelvetica%2C%22%20helvetica%3D%22%22%20neue%3D%22%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3BIf%20you%20test%20the%20GPU%20rendering%20display%20separately%2C%20or%20the%20video%20of%204%20channels%20of%20video%20is%20saved%20by%20G2D%20synthesis%2C%20there%20will%20be%20no%20image%20tearing%20problem.%3CBR%20style%3D%22border-image-outset%3A%200%3B%20border-image-repeat%3A%20stretch%3B%20border-image-slice%3A%20100%25%3B%20border-image-source%3A%20none%3B%20border-image-width%3A%201%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-weight%3A%20400%3B%20vertical-align%3A%20baseline%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%20border%3A%200px%20none%20%2351626f%3B%22%20%2F%3EBut%20as%20long%20as%20these%20two%20functions%20are%20combined%20into%20one%20project%2C%20the%20problem%20of%20image%20tearing%20will%20occur%20when%20displaying%20and%20the%20saving%26nbsp%3B%20video.%3C%2FDIV%3E%3CDIV%20style%3D%22background-color%3A%20transparent%3B%20border-image-outset%3A%200%3B%20border-image-repeat%3A%20stretch%3B%20border-image-slice%3A%20100%25%3B%20border-image-source%3A%20none%3B%20border-image-width%3A%201%3B%20color%3A%20%2351626f%3B%20font-family%3A%20arial%2Chelvetica%2C%22%20helvetica%3D%22%22%20neue%3D%22%22%3E%20%3C%2FDIV%3E%3CDIV%20style%3D%22background-color%3A%20transparent%3B%20border-image-outset%3A%200%3B%20border-image-repeat%3A%20stretch%3B%20border-image-slice%3A%20100%25%3B%20border-image-source%3A%20none%3B%20border-image-width%3A%201%3B%20color%3A%20%2351626f%3B%20font-family%3A%20arial%2Chelvetica%2C%22%20helvetica%3D%22%22%20neue%3D%22%22%3E1.%20Can%20I%20use%20the%20GC2000%20of%20IMX6%20and%20GC320%20at%20the%20same%20time%3F%20Is%20there%20a%20problem%20with%20GPU%20resource%20preemption%3F%3CBR%20style%3D%22border-image-outset%3A%200%3B%20border-image-repeat%3A%20stretch%3B%20border-image-slice%3A%20100%25%3B%20border-image-source%3A%20none%3B%20border-image-width%3A%201%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-weight%3A%20400%3B%20vertical-align%3A%20baseline%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%20border%3A%200px%20none%20%2351626f%3B%22%20%2F%3E2.%20Is%20there%20a%20problem%20with%20data%20conflicts%20in%20the%20GPU%3F%20I%20have%20already%20made%20the%20GC2000%20and%20GC320%20get%20data%20that%20cannot%20be%20bufed%2C%20but%20after%20the%20two%20functions%20are%20integrated%2C%20there%20will%20still%20be%20a%20problem%20of%20video%20tearing.%3C%2FDIV%3E%3CDIV%20style%3D%22background-color%3A%20transparent%3B%20border-image-outset%3A%200%3B%20border-image-repeat%3A%20stretch%3B%20border-image-slice%3A%20100%25%3B%20border-image-source%3A%20none%3B%20border-image-width%3A%201%3B%20color%3A%20%2351626f%3B%20font-family%3A%20arial%2Chelvetica%2C%22%20helvetica%3D%22%22%20neue%3D%22%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%BE%AE%E4%BF%A1%E5%9B%BE%E7%89%87_20190105150729.png%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%BE%AE%E4%BF%A1%E5%9B%BE%E7%89%87_20190105150729.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%BE%AE%E4%BF%A1%E5%9B%BE%E7%89%87_20190105150729.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%BE%AE%E4%BF%A1%E5%9B%BE%E7%89%87_20190105150729.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%BE%AE%E4%BF%A1%E5%9B%BE%E7%89%87_20190105150729.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%BE%AE%E4%BF%A1%E5%9B%BE%E7%89%87_20190105150729.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%BE%AE%E4%BF%A1%E5%9B%BE%E7%89%87_20190105150729.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%BE%AE%E4%BF%A1%E5%9B%BE%E7%89%87_20190105150729.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%BE%AE%E4%BF%A1%E5%9B%BE%E7%89%87_20190105150729.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%BE%AE%E4%BF%A1%E5%9B%BE%E7%89%87_20190105150729.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%BE%AE%E4%BF%A1%E5%9B%BE%E7%89%87_20190105150729.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%BE%AE%E4%BF%A1%E5%9B%BE%E7%89%87_20190105150729.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%BE%AE%E4%BF%A1%E5%9B%BE%E7%89%87_20190105150729.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F71446i32E371FA8C04993D%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22%E5%BE%AE%E4%BF%A1%E5%9B%BE%E7%89%87_20190105150729.png%22%20alt%3D%22%E5%BE%AE%E4%BF%A1%E5%9B%BE%E7%89%87_20190105150729.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E%E5%BE%AE%E4%BF%A1%E5%9B%BE%E7%89%87_20190105150729.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110257%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110257%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EIPU%20task's%20input.paddr%20and%20output.paddr%20should%20be%20physical%20address%20of%20the%20input%20buffer%20and%20output%20buffer%2C%20if%20you%20use%20wrong%20address%2C%20it%20will%20fail%20to%20work.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110254%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110254%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDear%2C%20Liqiang%3C%2FP%3E%3CP%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FQiang_FSL%22%20target%3D%22_blank%22%3EQiang_FSL%3C%2FA%3E%E2%80%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EWe%20are%20using%20your%20patch%EF%BC%88%20%3CSTRONG%3ETW6865%20driver%20for%20Linux%20L4.1.15_1.1.0-ga.7z%3C%2FSTRONG%3E%EF%BC%89and%20trying%20to%20develop%204%20camera%20surroundview%20application%20base%20on%20imx6d%20chip%20and%20PCIE%5CTW68x%5C%20CVBS%20camera%20%EF%BC%8C%20but%20meet%20a%20problem!%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThe%20application%20always%20freeze%20at%20the%20following%20codes%3A%3C%2FP%3E%3CP%3E--------------%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20if%20(ioctl(m_ifd%2C%20IPU_CHECK_TASK%2C%20%26amp%3Bm_sTask)%20!%3D%20IPU_CHECK_OK)%20%7B%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26nbsp%3Bprintf(%22IPU_CHECK_TASK%20failed.%5Cr%5Cn%22)%3B%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26nbsp%3Breturn%20-1%3B%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%20%26nbsp%3B%7D%3C%2FP%3E%3CP%3E-------------%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EDo%20you%20know%20the%20reason%3F%20thanks%20a%20lot!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110253%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110253%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ESorry%20I%20forget%20this.%20Is%20%22%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3Elatency%22%20means%20delay%3F%20If%20is%20there%20is%20no%20latency%20with%20my%20camera.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fdrive.google.com%2Ffile%2Fd%2F0B81cVqIF9a8LY1lEZ0RvOV9JVlk%2Fview%3Fusp%3Dsharing%22%20title%3D%22https%3A%2F%2Fdrive.google.com%2Ffile%2Fd%2F0B81cVqIF9a8LY1lEZ0RvOV9JVlk%2Fview%3Fusp%3Dsharing%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Equirks.c%20-%20Google%20Drive%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110252%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110252%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Lei%20Ma%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20got%20to%20know%20from%20the%20original%20author%20of%20the%20driver%20that%2C%20imxv4l2videosrc%20only%20works%20for%20csi%20cameras.%20Not%20with%20this%20pci%20stuffs.%20So%20correct%20source%20is%20v4l2src%20!%26nbsp%3B%3C%2FP%3E%3CP%3EBtw%20is%20your%20single%20camera%20working%20well%20for%20gst-launch-1.0%20with%20imxv4l2sink%20as%20well%20%3F%20Without%20any%20latency%20%3F%20can%20you%20also%20show%20me%20your%20pci%2Fquirks.c%20file%20%3F%3C%2FP%3E%3CP%3EKindly%20confirm%20me%20it%20.........%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EAnuradha%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110251%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110251%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20don't%20know%20that%2C%20my%20kernel%20version%20is%204.1.15%2C%20and%20these%20two%20files%20is%20bit%20different.%3C%2FP%3E%3CP%3E%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fdrive.google.com%2Fopen%3Fid%3D0B81cVqIF9a8LTEtTY2FncWRqWTg%22%20title%3D%22https%3A%2F%2Fdrive.google.com%2Fopen%3Fid%3D0B81cVqIF9a8LTEtTY2FncWRqWTg%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Evideobuf-dma-contig.c%20-%20Google%20Drive%3C%2FA%3E%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%3E%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fdrive.google.com%2Fopen%3Fid%3D0B81cVqIF9a8LUTZhU05RZTltbnc%22%20title%3D%22https%3A%2F%2Fdrive.google.com%2Fopen%3Fid%3D0B81cVqIF9a8LUTZhU05RZTltbnc%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Emxc_vpu.c%20-%20Google%20Drive%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110250%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110250%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%20one%20last%20thing%20to%20confirm%20Lei%2C%20are%20you%20aware%20of%20following%20patch%20for%20dma%20allocation%20%3F%3C%2FP%3E%3CP%3E%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fgit.congatec.com%2Farm%2Fqmx6_kernel%2Fcommit%2Ff4857b5482c67dcc9757d50cf57cb32728af788b%3Fw%3D1%22%20title%3D%22https%3A%2F%2Fgit.congatec.com%2Farm%2Fqmx6_kernel%2Fcommit%2Ff4857b5482c67dcc9757d50cf57cb32728af788b%3Fw%3D1%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fgit.congatec.com%2Farm%2Fqmx6_kernel%2Fcommit%2Ff4857b5482c67dcc9757d50cf57cb32728af788b%3Fw%3D1%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fthread%2F304368%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Fthread%2F304368%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3EIf%20you%20don't%20mind%2C%20can%20you%20kindly%20check%20or%20share%26nbsp%3B%3CSTRONG%20class%3D%22%22%20data-container%3D%22body%22%20data-original-title%3D%22%22%20data-title%3D%22drivers%2Fmedia%2Fvideo%2Fvideobuf-dma-contig.c%22%20style%3D%22font-weight%3A%20bold%3B%22%20title%3D%22%22%3E%3CA%20href%3D%22https%3A%2F%2Fgit.congatec.com%2Farm%2Fqmx6_kernel%2Fcommit%2Ff4857b5482c67dcc9757d50cf57cb32728af788b%3Fw%3D1%2372c7b9a29bc9022040264a978b1fe3f84d904f0b%22%20style%3D%22color%3A%20rgba(0%2C%200%2C%200%2C%200.85098)%3B%20background-color%3A%20transparent%3B%20text-decoration%3A%20none%3B%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Evideobuf-dma-contig.c%3C%2FA%3E%26nbsp%3B%3C%2FSTRONG%3Eor%26nbsp%3B%3CSTRONG%20class%3D%22%22%20data-container%3D%22body%22%20data-original-title%3D%22%22%20data-title%3D%22drivers%2Fmedia%2Fvideo%2Fvideobuf-dma-contig.c%22%20style%3D%22font-weight%3A%20bold%3B%22%20title%3D%22%22%3E%3CSTRONG%20class%3D%22%22%20data-container%3D%22body%22%20data-original-title%3D%22%22%20data-title%3D%22drivers%2Fmxc%2Fvpu%2Fmxc_vpu.c%22%20style%3D%22background-color%3A%20transparent%3B%20font-weight%3A%20normal%3B%20text-decoration%3A%20none%3B%22%20title%3D%22%22%3E%3CA%20href%3D%22https%3A%2F%2Fgit.congatec.com%2Farm%2Fqmx6_kernel%2Fcommit%2Ff4857b5482c67dcc9757d50cf57cb32728af788b%3Fw%3D1%23781434b5bd33ff7769a3a0f794ec3fa38152daab%22%20style%3D%22background-color%3A%20transparent%3B%20font-weight%3A%20normal%3B%20text-decoration%3A%20none%3B%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Emxc_vpu.c%3C%2FA%3E%26nbsp%3Bfiles%20of%20your%20running%20kernel%20%3F%20I%20saw%20in%20several%20posts%2C%20these%20changes%20are%20required.%20If%20you're%20not%20aware%2C%20I'd%20like%20to%20point%20this%20for%20your%20attention%20too.....%3C%2FSTRONG%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%20class%3D%22%22%20data-container%3D%22body%22%20data-original-title%3D%22%22%20data-title%3D%22drivers%2Fmedia%2Fvideo%2Fvideobuf-dma-contig.c%22%20style%3D%22font-weight%3A%20bold%3B%22%20title%3D%22%22%3E%3CSTRONG%20class%3D%22%22%20data-container%3D%22body%22%20data-original-title%3D%22%22%20data-title%3D%22drivers%2Fmxc%2Fvpu%2Fmxc_vpu.c%22%20style%3D%22background-color%3A%20transparent%3B%20font-weight%3A%20normal%3B%20text-decoration%3A%20none%3B%22%20title%3D%22%22%3E%3C%2FSTRONG%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%20class%3D%22%22%20data-container%3D%22body%22%20data-original-title%3D%22%22%20data-title%3D%22drivers%2Fmedia%2Fvideo%2Fvideobuf-dma-contig.c%22%20style%3D%22font-weight%3A%20bold%3B%22%20title%3D%22%22%3E%3CSTRONG%20class%3D%22%22%20data-container%3D%22body%22%20data-original-title%3D%22%22%20data-title%3D%22drivers%2Fmxc%2Fvpu%2Fmxc_vpu.c%22%20style%3D%22background-color%3A%20transparent%3B%20font-weight%3A%20normal%3B%20text-decoration%3A%20none%3B%22%20title%3D%22%22%3EThanks%3C%2FSTRONG%3E%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110249%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110249%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%20thanks%20alot%20for%20the%20prompt%20repose.%20That%20confirms%20one%20thing%20to%20me%2C%20there%20is%20a%20problem%20in%20the%20driver%20or%20my%20hardware%20!%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EAnuradha%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110248%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110248%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ENo%2C%20there%20is%20no%20such%20error%20in%20my%20device.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110247%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110247%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThanks%20very%20much%20Lei%2C%20this%20is%20very%20helpful.%20Btw%20do%20you%20see%20'%3CSTRONG%3Eunexpected%20p-b%20buffer%3C%2FSTRONG%3E'%20error%20appears%20in%20dmesg%20when%20running%20the%20camera%20%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EAnuradha%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110246%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110246%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%EF%BC%8C%3C%2FP%3E%3CP%3EHere%20is%20my%20kernel%20config%20file%2C%20%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fdrive.google.com%2Fopen%3Fid%3D0B81cVqIF9a8Ld0ttby1lLTIwdEk%22%20title%3D%22https%3A%2F%2Fdrive.google.com%2Fopen%3Fid%3D0B81cVqIF9a8Ld0ttby1lLTIwdEk%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E.config%20-%20Google%20Drive%3C%2FA%3E%26nbsp%3B%2C%20I%20also%20disabled%20pcie%20interrupt.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110245%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110245%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%20that's%20right.%20I%20am%20referring%20to%20the%20upstream%20kernel%20driver.%20Since%20you%20got%20it%20working%20without%20any%20problem%20I%20was%20wondering%20whether%20you%20have%20made%20a%20change%20to%20HW%20or%20Driver.%20In%20my%20case%2C%20for%20the%20upstream%20kernel%20driver%2C%20the%20video%20starts%20and%20frame%20rate%20becomes%20very%20low%20and%20then%20system%20hangs.%20I%20also%20see%20the%20'unexpected%20p-b%20buffer'%20error%20in%20dmesg.%20Did%20you%20have%20to%20disable%20audio%20support%20or%20anything%20like%20that%20%3F%20I%20had%20to%20disable%20pcie%20interrupt%20as%20well%20to%20get%20it%20work....%20If%20you%20don't%20mind%20can%20you%20kindly%20share%20your%20linux%20.conf%20file%20%3F%20I%20want%20to%20see%20kernel%20configurations%20under%20pcie.%26nbsp%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThanks%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110244%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110244%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ESorry%2C%20I'm%20not%20familiar%20with%20linux%20device%20driver%2C%20for%20now%20I'm%20focus%20on%20image%20process%20with%20opengl%20es%20and%20opencv.%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3EBoundary%20devices%20driver%20has%20two%20drivers%20for%20tw6865%2C%20one%20is%20tw6869%20from%26nbsp%3B%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fgithub.com%2Fsasamy%2Ftw6869%22%20title%3D%22https%3A%2F%2Fgithub.com%2Fsasamy%2Ftw6869%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EGitHub%20-%20sasamy%2Ftw6869%3A%20tw6869%2F65%20media%20bridge%20driver%3C%2FA%3E%26nbsp%3B%20another%20is%20tw686x%20from%20upstream%20kernel%2C%20I%20use%20the%20upstream%20one.%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110243%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110243%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Lei%20Ma%2C%3C%2FP%3E%3CP%3EHave%20you%20got%20the%20camera%20issue%20resolved%20with%20boundary%20devices%20driver%20%3F%20I%20still%20have%20this%20latency%20and%20freezing%20issue.%20I%20am%20strictly%20following%20the%20data%20sheet%20schematic%20of%26nbsp%3Btw6865%20chip%20!%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThanks%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110242%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110242%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThe%20command%20above%20only%20suitable%20to%20the%20gst-launch-0.10%20in%20the%20rootfs%20I%20provide.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110241%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110241%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EBtw%20how%20can%20I%20add%20mfw_isink%20%3F%20I%20have%20no%20such%20element%20in%20gst-inspect%20!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110240%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110240%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3EI%20have%20not%20solved%20the%20imxv4l2src%20video%20issue.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3EThe%20first%20thing%20is%20to%20make%20sure%20weather%20it%20is%20kernel's%20issue%20or%20gstreamer.%20Can%20you%20try%20nfs%20root%3F%20If%20so%2C%20it%20will%20be%20much%20convenient%20to%20try%20this%20rootfs%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fdrive.google.com%2Ffile%2Fd%2F0B81cVqIF9a8LampYTFE2NzdzUWc%2Fview%3Fusp%3Dsharing%22%20title%3D%22https%3A%2F%2Fdrive.google.com%2Ffile%2Fd%2F0B81cVqIF9a8LampYTFE2NzdzUWc%2Fview%3Fusp%3Dsharing%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Erootfs.tar.bz2%20-%20Google%20Drive%3C%2FA%3E%26nbsp%3B%2C%20note%20it's%20for%20my%20linux%203.0.5%2C%20but%20it's%20also%20working%20for%20my%20linux%204.1.15%20with%20device%20tree.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3EAnd%20then%20use%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%23000080%3B%22%3Egst-launch-0.10%20v4l2src%20device%3D%2Fdev%2Fvideo0%20!%20'video%2Fx-raw-yuv%2C%20format%3D(fourcc)UYVY'%20!%20mfw_isink%20disp-width%3D512%20disp-height%3D300%20axis-left%3D0%20axis-top%3D0%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%23000080%3B%22%3Etest%20it.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110239%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110239%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%20have%20you%20got%20the%20issue%20resolved%20%3F%20I%20can't%20see%20any%20issue%20in%20your%20logs.%20I%20also%20have%20the%20imxv4l2src%20video%20issue.%20I%20cannot%20even%20run%20a%20single%20camera%20consistently%2C%20the%20system%20freezes%20at%20a%20point%20and%20I%20am%20receiving%20'unexpected%20p-b%20buffer%20issue'%20from%20the%20driver.%20I%20used%20Ubuntu%20for%20this.%20If%20there%20are%20any%20updates%2C%20please%20share%20with%20me%20!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110238%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110238%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EMy%20board%20is%20not%20belong%20to%20boundary%20boards.%3C%2FP%3E%3CP%3Eyocto%20distro%3A%26nbsp%3B%224.1.15-2.0.1%22%2C%20%22fsl-imx-x11%22%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ememory%20map%3A%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3EMemory%3A%20698176K%2F1048576K%20available%20(8364K%20kernel%20code%2C%20432K%20rwdata%2C%203000K%20rodata%2C%20432K%20init%2C%20450K%20bss%2C%2022720K%20reserved%2C%20327680K%20cma-reserved%2C%200K%20highmem)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%5B%200.000000%5D%20Virtual%20kernel%20memory%20layout%3A%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%20vector%20%3A%200xffff0000%20-%200xffff1000%20(%204%20kB)%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%20fixmap%20%3A%200xffc00000%20-%200xfff00000%20(3072%20kB)%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%20vmalloc%20%3A%200xc0800000%20-%200xff000000%20(1000%20MB)%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%20lowmem%20%3A%200x80000000%20-%200xc0000000%20(1024%20MB)%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%20pkmap%20%3A%200x7fe00000%20-%200x80000000%20(%202%20MB)%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%20modules%20%3A%200x7f000000%20-%200x7fe00000%20(%2014%20MB)%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%20.text%20%3A%200x80008000%20-%200x80b215e0%20(11366%20kB)%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%20.init%20%3A%200x80b22000%20-%200x80b8e000%20(%20432%20kB)%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%20.data%20%3A%200x80b8e000%20-%200x80bfa160%20(%20433%20kB)%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%20.bss%20%3A%200x80bfd000%20-%200x80c6d8c0%20(%20451%20kB)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20use%20the%20official%20kernel%20and%20use%20the%26nbsp%3B%3CSPAN%3Eboundary%20kernel's%20tw686x%20driver%2C%20I%20have%20also%20edited%20the%20quirk.c%20file.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110237%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110237%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20remember%20I%20had%20'unexpected%20p-b%20buffer'%20issue%20while%20running%20the%20camera%2C%20but%20I%20was%20experimenting%20this%20on%20one%20of%20the%20Boundary%20Devices%20boards.%20Which%20board%20and%20distro%20are%20you%20using%20%3F%26nbsp%3BCan%20you%20also%20show%20the%26nbsp%3Bcurrent%20memory%20map%20in%20kernel%20log%3F%3C%2FP%3E%3CP%3Ei.e%20%3A-%26nbsp%3B%3C%2FP%3E%3CDIV%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3EMemory%3A%203551600K%2F3932156K%20available%20(8196K%20%3CSPAN%20class%3D%22%22%3Ekernel%3C%2FSPAN%3E%20code%2C%20314K%20rwdata%2C%202448K%20rodata%2C%201024K%20init%2C%20444K%20bss%2C%2052876K%20reserved%2C%20327680K%20cma-reserved%2C%202260988K%20highmem)%3C%2FDIV%3E%3CDIV%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3EVirtual%20%3CSPAN%20class%3D%22%22%3Ekernel%3C%2FSPAN%3E%20memory%20layout%3A%3C%2FDIV%3E%3CDIV%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3E%26nbsp%3B%20%26nbsp%3B%20vector%20%26nbsp%3B%3A%200xffff0000%20-%200xffff1000%20%26nbsp%3B%20(%20%26nbsp%3B%204%20kB)%3C%2FDIV%3E%3CDIV%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3E%26nbsp%3B%20%26nbsp%3B%20fixmap%20%26nbsp%3B%3A%200xffc00000%20-%200xfff00000%20%26nbsp%3B%20(3072%20kB)%3C%2FDIV%3E%3CDIV%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3E%26nbsp%3B%20%26nbsp%3B%20vmalloc%20%3A%200xe6800000%20-%200xff000000%20%26nbsp%3B%20(%20392%20MB)%3C%2FDIV%3E%3CDIV%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3E%26nbsp%3B%20%26nbsp%3B%20lowmem%20%26nbsp%3B%3A%200x80000000%20-%200xe6000000%20%26nbsp%3B%20(1632%20MB)%3C%2FDIV%3E%3CDIV%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3E%26nbsp%3B%20%26nbsp%3B%20pkmap%20%26nbsp%3B%20%3A%200x7fe00000%20-%200x80000000%20%26nbsp%3B%20(%20%26nbsp%3B%202%20MB)%3C%2FDIV%3E%3CDIV%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3E%26nbsp%3B%20%26nbsp%3B%20modules%20%3A%200x7f000000%20-%200x7fe00000%20%26nbsp%3B%20(%20%26nbsp%3B14%20MB)%3C%2FDIV%3E%3CDIV%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20.text%20%3A%200x80008000%20-%200x80b650ac%20%26nbsp%3B%20(11637%20kB)%3C%2FDIV%3E%3CDIV%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20.init%20%3A%200x80c00000%20-%200x80d00000%20%26nbsp%3B%20(1024%20kB)%3C%2FDIV%3E%3CDIV%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20.data%20%3A%200x80d00000%20-%200x80d4ea40%20%26nbsp%3B%20(%20315%20kB)%3C%2FDIV%3E%3CDIV%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B.bss%20%3A%200x80d51000%20-%200x80dc0320%20%26nbsp%3B%20(%20445%20kB)%3C%2FDIV%3E%3CDIV%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3E%20%3C%2FDIV%3E%3CP%3EBR%3C%2FP%3E%3CP%3EAnuradha%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110236%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110236%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E1.%20For%20now%2C%20I'm%20using%20only%20one%20camera%2C%20if%20I%20run%20two%20or%20more%20camera%20there%20will%20be%20some%20error%20message%3A%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23ff6600%3B%22%3EERROR%3A%20from%20element%20%2FGstPipeline%3Apipeline0%2FGstV4l2Src%3Av4l2src0%3A%20Internal%20data%20flow%20error.%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23ff6600%3B%22%3EAdditional%20debug%20info%3A%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23ff6600%3B%22%3E..%2F..%2F..%2F..%2Fgstreamer-1.8.1%2Flibs%2Fgst%2Fbase%2Fgstbasesrc.c(2948)%3A%20gst_base_src_loop%20()%3A%20%2FGstPipeline%3Apipeline0%2FGstV4l2Src%3Av4l2src0%3A%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23ff6600%3B%22%3Estreaming%20task%20paused%2C%20reason%20error%20(-5)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3Ecommand%20is%20below%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3Egst-launch-1.0%20v4l2src%20device%3D%2Fdev%2Fvideo0%20!%20imxv4l2sink%20overlay-width%3D512%20overlay-height%3D300%20overlay-top%3D0%20overlay-left%3D0%20%26amp%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3Egst-launch-1.0%20v4l2src%20device%3D%2Fdev%2Fvideo1%20!%20imxv4l2sink%20overlay-width%3D512%20overlay-height%3D300%20overlay-top%3D0%20overlay-left%3D512%20%26amp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3EFor%20one%20camera%2C%20there%20is%20no%20latency.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E2.%20%26nbsp%3BI%20use%20the%20driver%20you%20provided%20is%20another%20post%2C%26nbsp%3B%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fgithub.com%2Fboundarydevices%2Flinux-imx6%2Ftree%2Fboundary-imx_4.1.15_2.0.0_ga%2Fdrivers%2Fmedia%2Fpci%2Ftw686x%22%20title%3D%22https%3A%2F%2Fgithub.com%2Fboundarydevices%2Flinux-imx6%2Ftree%2Fboundary-imx_4.1.15_2.0.0_ga%2Fdrivers%2Fmedia%2Fpci%2Ftw686x%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Elinux-imx6%2Fdrivers%2Fmedia%2Fpci%2Ftw686x%20at%20boundary-imx_4.1.15_2.0.0_ga%20%C2%B7%20boundarydevices%2Flinux-imx6%20%C2%B7%20GitHub%3C%2FA%3E%26nbsp%3B%2C%20I%20also%20try%20this%20one%26nbsp%3B%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fgithub.com%2Fsasamy%2Ftw6869%22%20title%3D%22https%3A%2F%2Fgithub.com%2Fsasamy%2Ftw6869%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EGitHub%20-%20sasamy%2Ftw6869%3A%20tw6869%2F65%20media%20bridge%20driver%3C%2FA%3E%26nbsp%3B%2C%20same%20result.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3EI'm%20using%20a%20customed%20board.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110235%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110235%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%20now%20can%20you%20get%20the%20video%20stream%20without%20any%20latency%20as%20expected%20%3F%20Do%20you%20have%20a%20git%20link%20to%20the%20driver%20you%20use%26nbsp%3Bwith%20sabresd%20%3F%20Or%20are%20you%20using%20a%20different%20board%20%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EAnuradha%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110234%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110234%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThanks!%3C%2FP%3E%3CP%3ENow%20it's%20working%20with%20%22%26nbsp%3Bgst-launch-1.0%20v4l2src%20device%3D%2Fdev%2Fvideo2%20!%20imxv4l2sink%20overlay-width%3D512%20overlay-height%3D300%20overlay-top%3D300%20overlay-left%3D0%20%22%3C%2FP%3E%3CP%3EI%20don't%20know%20why%26nbsp%3Bimxv4l2src%20doesn't%20work.%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%22v4l2-ctl%20-d%20%2Fdev%2Fvideox%20--all%22%20outputs%20is%20here%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3EDriver%20Info%20(not%20using%20libv4l2)%3A%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%20Driver%20name%20%3A%20tw686x%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%20Card%20type%20%3A%20tw6869%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%20Bus%20info%20%3A%20PCI%3A0000%3A01%3A00.0%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%20Driver%20version%3A%204.1.15%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%20Capabilities%20%3A%200x85200001%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%20Video%20Capture%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%20Read%2FWrite%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%20Streaming%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%20Extended%20Pix%20Format%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%20Device%20Capabilities%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%20Device%20Caps%20%3A%200x05200001%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%20Video%20Capture%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%20Read%2FWrite%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%20Streaming%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%20Extended%20Pix%20Format%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3EPriority%3A%202%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3EVideo%20input%20%3A%200%20(Composite0%3A%20ok)%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3EVideo%20Standard%20%3D%200x0000b000%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%20NTSC-M%2FM-JP%2FM-KR%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3EFormat%20Video%20Capture%3A%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%20Width%2FHeight%20%3A%20360%2F240%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%20Pixel%20Format%20%3A%20'YUYV'%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%20Field%20%3A%20Interlaced%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%20Bytes%20per%20Line%3A%20720%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%20Size%20Image%20%3A%20172800%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%20Colorspace%20%3A%20Broadcast%20NTSC%2FPAL%20(SMPTE170M%2FITU601)%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%20Flags%20%3A%20%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3EStreaming%20Parameters%20Video%20Capture%3A%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%20Capabilities%20%3A%20timeperframe%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%20Frames%20per%20second%3A%2030.000%20(30%2F1)%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%20Read%20buffers%20%3A%203%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3EUser%20Controls%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3Ebrightness%20(int)%20%3A%20min%3D-128%20max%3D127%20step%3D1%20default%3D0%20value%3D0%20flags%3Dslider%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%20contrast%20(int)%20%3A%20min%3D0%20max%3D255%20step%3D1%20default%3D100%20value%3D100%20flags%3Dslider%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%20saturation%20(int)%20%3A%20min%3D0%20max%3D255%20step%3D1%20default%3D128%20value%3D128%20flags%3Dslider%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%20hue%20(int)%20%3A%20min%3D-128%20max%3D127%20step%3D1%20default%3D0%20value%3D0%20flags%3Dslider%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%20brightness%20(int)%20%3A%20min%3D-128%20max%3D127%20step%3D1%20default%3D0%20value%3D0%20flags%3Dslider%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%20contrast%20(int)%20%3A%20min%3D0%20max%3D255%20step%3D1%20default%3D100%20value%3D100%20flags%3Dslider%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%20saturation%20(int)%20%3A%20min%3D0%20max%3D255%20step%3D1%20default%3D128%20value%3D128%20flags%3Dslider%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%20hue%20(int)%20%3A%20min%3D-128%20max%3D127%20step%3D1%20default%3D0%20value%3D0%20flags%3Dslider%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3EIf%20I%20use%26nbsp%3Bimxv4l2src%2C%20it%20will%20say%20%22could%20not%20link%20imxv4l2src0%20to%20imxv4l2sink0%22.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110233%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110233%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%20is%20your%20intended%20video%20device%20enumerated%20%3F%20i.e.%20what%20v4l2-ctl%20-d%20%2Fdev%2Fvideox%20--all%20give%20you%20%3F%26nbsp%3B%3C%2FP%3E%3CP%3Eand%20try%20exactly%20this%20%3A%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20bold%3B%20font-size%3A%2012.8px%3B%22%3Egst-launch-1.0%20-v%20v4l2src%20device%3D%2Fdev%2Fvideo0%20!%20video%2Fx-raw%2Cwidth%3D720%2Cheight%3D480%2Cpixelformat%3DUYVY%20!%20imxipuvideotransform%20!%26nbsp%3Bimxeglvivsink%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ENote%2C%20for%20me%20pci%20MSI%20had%20to%20be%20disabled%20in%20order%20to%20get%20video%20frames%20!!!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110232%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110232%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EI'm%20using%20the%20tw686x%20driver%2C%20but%20the%20gst-lanuch-1.0%20doesn't%20work%2C%20I%20try%20the%3C%2FP%3E%3CP%3E%3CSTRONG%3E%22gst-launch-1.0%20imxv4l2src%20device%3D%2Fdev%2Fvideo2%22%20%2C%20output%3A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%3D%3D%3D%3D%3D%3D%20IMXV4L2SRC%3A%204.1.4%20build%20on%20Jan%2031%202017%2020%3A15%3A40.%20%3D%3D%3D%3D%3D%3D%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3ESetting%20pipeline%20to%20PAUSED%20...%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3EPipeline%20is%20live%20and%20does%20not%20need%20PREROLL%20...%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E(gst-launch-1.0%3A990)%3A%20GStreamer-CRITICAL%20**%3A%20gst_mini_object_ref%3A%20assertion%20'mini_object%20!%3D%20NULL'%20failed%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E**%20(gst-launch-1.0%3A990)%3A%20CRITICAL%20**%3A%20gst_video_info_from_caps%3A%20assertion%20'caps%20!%3D%20NULL'%20failed%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E(gst-launch-1.0%3A990)%3A%20GStreamer-CRITICAL%20**%3A%20gst_caps_get_structure%3A%20assertion%20'GST_IS_CAPS%20(caps)'%20failed%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E**%20(gst-launch-1.0%3A990)%3A%20CRITICAL%20**%3A%20gst_video_info_from_caps%3A%20assertion%20'caps%20!%3D%20NULL'%20failed%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3EERROR%3A%20from%20element%20%2FGstPipeline%3Apipeline0%2FGstImxV4l2Src%3Aimxv4l2src0%3A%20Internal%20data%20flow%20error.%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3EAdditional%20debug%20info%3A%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E..%2F..%2F..%2F..%2Fgstreamer-1.8.1%2Flibs%2Fgst%2Fbase%2Fgstbasesrc.c(2948)%3A%20gst_base_src_loop%20()%3A%20%2FGstPipeline%3Apipeline0%2FGstImxV4l2Src%3Aimxv4l2src0%3A%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3Estreaming%20task%20paused%2C%20reason%20not-negotiated%20(-4)%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3EERROR%3A%20pipeline%20doesn't%20want%20to%20preroll.%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3ESetting%20pipeline%20to%20PAUSED%20...%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3ESetting%20pipeline%20to%20READY%20...%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3ESetting%20pipeline%20to%20NULL%20...%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3EFreeing%20pipeline%20...%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%22dmesg%22%20outputs%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3EERROR%3A%20v4l2%20capture%3A%20slave%20not%20found!%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EIf%20I%20use%26nbsp%3B%3CSPAN%3E%22imxv4l2videosrc%22%2C%20it'll%20output%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3EERROR%3A%20pipeline%20could%20not%20be%20constructed%3A%26nbsp%3Bno%20element%20%22imxv4l2videosrc%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3Eversion%3A%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3Egst-launch-1.0%20version%201.8.1%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3EGStreamer%201.8.1%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3EIf%20I%20use%20the%20old%20rootfs%20for%20L3.0.5%2C%20but%20with%20the%20same%20kernel%20used%20above%2C%204.1.15%2C%20the%20output%20is%20correct%2C%20command%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3Egst-launch%20v4l2src%20device%3D%2Fdev%2Fvideo0%20!%20'video%2Fx-raw-yuv%2C%20format%3D(fourcc)UYVY'%20!%20mfw_isink%20disp-width%3D512%20disp-height%3D300%20axis-left%3D0%20axis-top%3D0%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3Egst-launch%20version%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3Egst-launch-0.10%20version%200.10.35%3CBR%20%2F%3EGStreamer%200.10.35%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110231%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110231%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHI%E3%80%82%3C%2FP%3E%3CP%3ECan%20it%20working%20on%20Android4.4.2%2C%20if%20it%20can%20%26nbsp%3B%2Cis%20there%20any%20docs%3F%3C%2FP%3E%3CP%3Ethanks!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110230%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110230%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Lei%20Ma%2C%3C%2FP%3E%3CP%3Etry%20dmesg%20%7C%20grep%20tw68%20and%20see%20whether%20you%20have%20a%20dma%20memory%20allocation%20error%20message.%20If%20yes%2C%20try%20passing%20coherent_pool%20%3D%20128M%20(or%20a%20reasonable%20memory%20size)%20as%20a%20kernel%20parameter.%20i.e.%20setenv%20bootargs%20%3D%20%22%24%7Bbootargs%7D%26nbsp%3B%3CSPAN%3Ecoherent_pool%20%3D%20128M%22%20in%20uboot%20or%206x_bootscript.%20This%20will%20enumerate%20your%20video%20device%20if%20the%20issue%20was%20with%20memory%20allocation.%20The%20mainline%20tw686x%20linux%20driver%20should%20work%20for%20your%20case%20!%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ERgs%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EAnuradha%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110229%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110229%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThank%20you%20for%20your%20reply!%3C%2FP%3E%3CP%3EThere%20are%20%22tw68-core.c%22%20%22tw68-video.c%22...%20files%20in%20the%20linux%204.1.15%20source%20tree%2C%20I'm%20not%20sure%20whether%20they%20are%20working%20for%20tw6865%2C%20I%20have%20enabled%20the%20tw68%20in%20kernel%2C%20but%20there%20is%20no%20corresponding%20%2Fdev%2FvideoX%20for%20the%20tw6865.%20So%20I%20want%20confirm%20that%20is%20this%20the%20driver%20for%20tw6865.%3C%2FP%3E%3CP%3EThe%20source%20code%20is%20under%20%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%22%2Fdrivers%2Fmedia%2Fpci%2Ftw68%2F%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%22%20directory%20in%20the%20linux%204.1.15%20source%20tree.%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E--------------------------------------------------%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3EI%20ask%20the%20tw68%20driver%20author%2C%20it's%20not%20for%20the%20tw6865.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3ETw6865%20driver%20is%20here%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fgithub.com%2Fsasamy%2Ftw6869%22%20title%3D%22https%3A%2F%2Fgithub.com%2Fsasamy%2Ftw6869%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EGitHub%20-%20sasamy%2Ftw6869%3A%20tw6869%2F65%20media%20bridge%20driver%3C%2FA%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110228%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110228%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20don't%20know%20your%20display%20resolution%2C%20you%20need%20change%20it%20according%20your%20LVDS%20display%20resolution.%20Like%201024x768%20in%20our%20SDP%20board%2C%20change%20it%20to%20below%3A%3C%2FP%3E%3CP%3Egst-launch%20v4l2src%20device%3D%2Fdev%2Fvideo0%20%26nbsp%3B!%20'video%2Fx-raw-yuv%2C%20format%3D(fourcc)UYVY'%20!%20mfw_isink%20disp-width%3D512%20disp-height%3D384%20%26amp%3B%3C%2FP%3E%3CP%3Egst-launch%20v4l2src%20device%3D%2Fdev%2Fvideo1%20%26nbsp%3B!%20'video%2Fx-raw-yuv%2C%20format%3D(fourcc)UYVY'%20!%20mfw_isink%20disp-width%3D%3CSPAN%3E512%20%3C%2FSPAN%3Edisp-height%3D%3CSPAN%3E384%20%3C%2FSPAN%3Eaxis-left%3D%3CSPAN%3E512%20%3C%2FSPAN%3E%26amp%3B%3C%2FP%3E%3CP%3Egst-launch%20v4l2src%20device%3D%2Fdev%2Fvideo2%20%26nbsp%3B!%20'video%2Fx-raw-yuv%2C%20format%3D(fourcc)UYVY'%20!%20mfw_isink%20disp-width%3D%3CSPAN%3E512%20%3C%2FSPAN%3Edisp-height%3D%3CSPAN%3E384%20%3C%2FSPAN%3Eaxis-top%3D%3CSPAN%3E384%20%3C%2FSPAN%3E%26amp%3B%3C%2FP%3E%3CP%3Egst-launch%20v4l2src%20device%3D%2Fdev%2Fvideo3%20%26nbsp%3B!%20'video%2Fx-raw-yuv%2C%20format%3D(fourcc)UYVY'%20!%20mfw_isink%20disp-width%3D%3CSPAN%3E512%20%3C%2FSPAN%3Edisp-height%3D%3CSPAN%3E384%20%3C%2FSPAN%3Eaxis-top%3D%3CSPAN%3E384%20%3C%2FSPAN%3Eaxis-left%3D%3CSPAN%3E512%20%3C%2FSPAN%3E%26amp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110227%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110227%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%22-1%22%20data-containertype%3D%22-1%22%20data-content-finding%3D%22Community%22%20data-objectid%3D%22203567%22%20data-objecttype%3D%223%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FJiangJustin%22%20style%3D%22color%3A%20%235e89c1%3B%20background-color%3A%20transparent%3B%20border%3A%200px%3B%20font-weight%3A%20600%3B%20font-size%3A%2011.9994px%3B%20padding%3A%201px%200px%201px%20calc(12px%20%2B%200.35ex)%3B%22%20target%3D%22_blank%22%3EJustin%20Jiang%3C%2FA%3E%3CSPAN%20style%3D%22color%3A%20%23646464%3B%20border%3A%200px%3B%20font-size%3A%2014px%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EMy%20board%20has%20a%20lvds%20lcd%2C%20now%20it%20is%20able%20to%20display%20the%20qt%20demo%2C%20I%20have%20also%20attached%20the%20tw68%20to%20the%20board.%20The%20%22lspci%22%20command%20output%20is%20below%3A%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E00%3A00.0%20PCI%20bridge%3A%20Synopsys%2C%20Inc.%20Device%20abcd%20(rev%2001)%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E01%3A00.0%20Non-VGA%20unclassified%20device%3A%20Intersil%20Techwell%20Device%206869%20(rev%2001)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3ESo%2C%20is%20the%20command%20below%20able%20to%20display%20the%20video%20on%20the%20lvds%20lcd%3F%20If%20not%2C%20how%20to%20change%20it.%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3Egst-launch%20v4l2src%20device%3D%2Fdev%2Fvideo0%26nbsp%3B%20!%20'video%2Fx-raw-yuv%2C%20format%3D(fourcc)UYVY'%20!%20mfw_isink%20disp-width%3D960%20disp-height%3D540%20%26amp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3Egst-launch%20v4l2src%20device%3D%2Fdev%2Fvideo1%26nbsp%3B%20!%20'video%2Fx-raw-yuv%2C%20format%3D(fourcc)UYVY'%20!%20mfw_isink%20disp-width%3D960%20disp-height%3D540%20axis-left%3D960%20%26amp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3Egst-launch%20v4l2src%20device%3D%2Fdev%2Fvideo2%26nbsp%3B%20!%20'video%2Fx-raw-yuv%2C%20format%3D(fourcc)UYVY'%20!%20mfw_isink%20disp-width%3D960%20disp-height%3D540%20axis-top%3D540%26nbsp%3B%20%26amp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3Egst-launch%20v4l2src%20device%3D%2Fdev%2Fvideo3%26nbsp%3B%20!%20'video%2Fx-raw-yuv%2C%20format%3D(fourcc)UYVY'%20!%20mfw_isink%20disp-width%3D960%20disp-height%3D540%20axis-top%3D540%20axis-left%3D960%20%26amp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3EBTW%2C%20my%20kernel%20version%20is%204.1.15.%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3EThanks!%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110226%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110226%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EOur%20i.MX6%20doesn't%20support%20OpenCV%20HW%20acceleration.%3CSPAN%3EOpenGL%20ES%2C%20OpenVG%2C%20OpengCL%20are%20supported.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EWe%20have%20less%20experience%20about%20the%20surround%20view%20stitching%20implementation.%20I%20think%20you%20can%20try%20to%20use%20it%2C%20but%20it%20rely%26nbsp%3Bon%20CPU's%26nbsp%3Bcompute%20capability.%20I'm%20not%20sure%20if%20the%20performance%20is%20good%20enough.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110225%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110225%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-size%3A%2014px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2014px%3B%22%3EHi%2C%20%3CA%20_jive_internal%3D%22true%22%20class%3D%22%22%20data-content-finding%3D%22Community%22%20data-userid%3D%22203567%22%20data-username%3D%22JiangJustin%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FJiangJustin%22%20style%3D%22color%3A%20%235e89c1%3B%20border%3A%200px%3B%20font-weight%3A%20600%3B%20font-size%3A%2011.9994px%3B%22%20target%3D%22_blank%22%3EJustin%20Jiang%3C%2FA%3E%3CSPAN%20style%3D%22color%3A%20%23646464%3B%22%3E%20%3C%2FSPAN%3E.%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-size%3A%2014px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2014px%3B%22%3EIs%20it%20possible%20to%20use%20opencv%20to%20make%20surround%20view%26nbsp%3Bcome%20true%3F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110224%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110224%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDear%26nbsp%3B%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FJiangJustin%22%20target%3D%22_blank%22%3EJiangJustin%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EWe%20have%20developed%20a%20camera%20board%20using%20Intersil%20TW6865%20chip%20(As%20same%20as%20Freescale%20TW6865%20miniPCIe%20Daughter%20Board)%20which%20can%20input%20two%20analog%20cameras%20to%20iMAX6Q%20Sabre%20Lite%20Development%20board%20using%20PCIe%20interface.%26nbsp%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3EI%20need%20to%20clarify%20following%20%26gt%3B%26gt%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EIn%20iMAX6Q%20Sabre%20Lite%20for%20PCIe%20port%20there%20are%207%20pin%20connections%20as%20follows.%20%2B3.3V%2C%20PCIE_RXM%2C%20PCIE_RXP%2C%20PCIE_TXM%2C%20PCIE_TXP%2C%20GND%2C%20GND.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20220px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20220px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20220px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20220px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20220px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20220px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20220px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20220px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20220px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20220px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20220px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20220px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F2825i7095A79C98737FBA%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_1.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EIntersil%20TW6865%20chip%20has%20REFCLK-%2C%20REFCLK%2B%20pin%20connections%20for%20differential%20reference%20clock%20inputs.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_5.png%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_5.png%22%20style%3D%22width%3A%20395px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_5.png%22%20style%3D%22width%3A%20395px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_5.png%22%20style%3D%22width%3A%20395px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_5.png%22%20style%3D%22width%3A%20395px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_5.png%22%20style%3D%22width%3A%20395px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_5.png%22%20style%3D%22width%3A%20395px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_5.png%22%20style%3D%22width%3A%20395px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_5.png%22%20style%3D%22width%3A%20395px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_5.png%22%20style%3D%22width%3A%20395px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_5.png%22%20style%3D%22width%3A%20395px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_5.png%22%20style%3D%22width%3A%20395px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_5.png%22%20style%3D%22width%3A%20395px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F2860i444D114E1763B679%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_5.png%22%20alt%3D%22pastedImage_5.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_5.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3EDon't%20we%20need%20to%20connect%20this%20pins%20with%20iMAX6Q%20board%20if%20we%20want%20to%20interface%20with%20PCIe%20interface%20%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThank%20You%2C%3C%2FP%3E%3CP%3EPeter%20Amond.imx6_pcie_msi_handler%3C%2FP%3E%3CP%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110223%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110223%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3EWe%20made%20TW6865%20test%20board%2C%20and%20we%20can%20see%204ch%20image%20on%20HDMI%20with%20MX6Q-SABRESDP.%3C%2FSPAN%3E%3CBR%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3EBut%20we%20can%20see%20%3CSPAN%20style%3D%22color%3A%20%23333333%3B%20font-size%3A%2013px%3B%22%3E%20%3C%2FSPAN%3E%3CEM%20class%3D%22%22%20style%3D%22color%3A%20%23cc0000%3B%20font-size%3A%2013px%3B%22%3Eraster%3C%2FEM%3E%3CSPAN%20style%3D%22color%3A%20%23333333%3B%20font-size%3A%2013px%3B%22%3E%20%3C%2FSPAN%3E%3CEM%20class%3D%22%22%20style%3D%22color%3A%20%23333333%3B%20font-size%3A%2013px%3B%22%3Eimages%26nbsp%3B%3C%2FEM%3Ewhen%20I%20move%20my%20hand%20fast%20in%20front%20of%20Camera.%20%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110222%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110222%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ecan%20you%20check%20with%20our%20Korea%20FAE.%20They%20should%20have%20some%20patches%20for%20it.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110221%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110221%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDear%20%3CA%20_jive_internal%3D%22true%22%20data-content-finding%3D%22Community%22%20data-userid%3D%22203567%22%20data-username%3D%22JiangJustin%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FJiangJustin%22%20style%3D%22font-weight%3A%20600%3B%20font-size%3A%2011.9994010925293px%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%238ca9cd%3B%22%20target%3D%22_blank%22%3EQingrong%20Jiang%3C%2FA%3E%E2%80%8B%3A%3C%2FP%3E%3CP%3EHi%3C%2FP%3E%3CP%3EWhen%20I%20use%20this%20methord%20to%20get%20the%20data%20of%20images%20by%20the%20v4l2%20capture.c%2C%3C%2FP%3E%3CP%3EI%20meet%20like%20this%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22tw.png%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22tw.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22tw.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22tw.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22tw.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22tw.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22tw.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22tw.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22tw.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22tw.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22tw.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22tw.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22tw.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F59796i38955AE3EC02F138%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22tw.png%22%20alt%3D%22tw.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Etw.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fbbs.21ic.com%2Ficview-1205710-1-2.html%22%20title%3D%22http%3A%2F%2Fbbs.21ic.com%2Ficview-1205710-1-2.html%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ei.MX6Q%20%2BPCIE%2BTW68%20%E9%A9%B1%E5%8A%A8%E6%98%BE%E7%A4%BA%E7%AD%89%E9%97%AE%E9%A2%98-%E6%81%A9%E6%99%BA%E6%B5%A6MCU%E8%AE%BA%E5%9D%9B%E8%AE%BA%E5%9D%9B%20-%2021ic%E7%94%B5%E5%AD%90%E6%8A%80%E6%9C%AF%E8%AE%BA%E5%9D%9B%3C%2FA%3E%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110220%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110220%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%20Qingrong%20Jiang!%3C%2FP%3E%3CP%3EI'm%20a%20FAE%20from%20STC%2C%20one%20of%20the%20NXP%20distributors%20in%20Korea.%20%3CBR%20%2F%3EWe%20made%20TW6865%20test%20board%2C%20and%20we%20can%20see%204ch%20image%20on%20HDMI%20with%20MX6Q-SABRESDP.%3CBR%20%2F%3EBut%20we%20can%20see%20afterimage%20when%20I%20move%20my%20hand%20fast%20in%20front%20of%20Camera.%20(Please%20see%20attached%20video%20clip.)%3C%2FP%3E%3CP%3E(BSP%20version%20%3A%20L3.0.35_4.1.0)%3CBR%20%2F%3EI%20met%20intersil%20FAE%2C%20and%20he%20said%20it%20is%20the%20problem%20of%20deinterlacing.%20%3CBR%20%2F%3EDo%20you%20have%20any%20guide%20or%20solution%20to%20solve%20this%20issue%3F%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SVM.jpg%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SVM.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SVM.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SVM.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SVM.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SVM.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SVM.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SVM.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SVM.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SVM.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SVM.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SVM.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SVM.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F59691i79D40C74EF3D8096%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22SVM.jpg%22%20alt%3D%22SVM.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESVM.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110219%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110219%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20hu%20bing%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20What%20about%20your%20problem%20of%20capture%20%3F%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20It%20is%20kind%20that%20help%20me%20a%20demo%20about%20V4L2%20code.There%20is%20my%20email%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-email-small%22%20href%3D%22mailto%3A1058477863%40qq.com%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E1058477863%40qq.com%3C%2FA%3E%3CSPAN%3E.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Thanks!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110218%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110218%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%EF%BC%8C%3C%2FP%3E%3CP%3ECould%20you%20teach%20me%20that%20how%20to%20save%20the%20data%20captured%20by%20the%20lens%3F%3C%2FP%3E%3CP%3EHave%20a%20good%20day!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110217%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110217%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi~Dear%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Now%20I%20encounted%20some%20problems%20when%20i%20use%20the%20patch%20in%20IMX6%20Community.%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20My%20Applitcatin%20is%20mxc_v4l2_tvin.out.%20But%20It%20can't%20use%20%3CSPAN%20style%3D%22color%3A%20%23444444%3B%20font-family%3A%20Tahoma%2C%20'Microsoft%20Yahei'%2C%20Simsun%3B%20background-color%3A%20%23eff5f9%3B%22%3EV4L2_MEMORY_USERPTR%20mode%20to%20capture%20video%20stream%2Cand%20it%20often%20displayed%20that%20%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22background-color%3A%20%23eff5f9%3B%20color%3A%20%23444444%3B%20font-size%3A%2012px%3B%20font-family%3A%20Tahoma%2C%20'Microsoft%20Yahei'%2C%20Simsun%3B%20line-height%3A%201.5%3B%22%3EUSERPTR%20is%20currently%20not%20supported%20%2Cbuffer_prepare%26nbsp%3B%20OOPS%22.And%20it%20burn%20down.But%20when%20i%20use%20%3CSPAN%20style%3D%22color%3A%20%23444444%3B%20font-family%3A%20Tahoma%2C%20'Microsoft%20Yahei'%2C%20Simsun%3B%20background-color%3A%20%23eff5f9%3B%22%3EV4L2_MEMORY_MMAPED%2Cit%20can%20normally%20capture%20video%20stream.%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23eff5f9%3B%20color%3A%20%23444444%3B%20font-size%3A%2012px%3B%20font-family%3A%20Tahoma%2C%20'Microsoft%20Yahei'%2C%20Simsun%3B%20line-height%3A%201.5%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23eff5f9%3B%20color%3A%20%23444444%3B%20font-size%3A%2012px%3B%20font-family%3A%20Tahoma%2C%20'Microsoft%20Yahei'%2C%20Simsun%3B%20line-height%3A%201.5%3B%22%3EThe%20command%20is%20%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20sans-serif%3B%22%3Ehdmi%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20sans-serif%3B%22%3E.%2Fmxc_v4l2_tvin.out%20-x%200%20-ot%200%20-ol%200%20-ow%20960%20-oh%20540%20-m%202%20%26amp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20sans-serif%3B%22%3E.%2Fmxc_v4l2_tvin.out%20-x%201%20-ot%200%20-ol%20960%20-ow%20960%20-oh%20540%20-m%202%20%26amp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20sans-serif%3B%22%3E.%2Fmxc_v4l2_tvin.out%20-x%202%20-ot%20540%20-ol%200%20-ow%20960%20-oh%20540%20-m%202%20%26amp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20sans-serif%3B%22%3E.%2Fmxc_v4l2_tvin.out%20-x%203%20-ot%20540%20-ol%20960%20-ow%20960%20-oh%20540%20-m%202%20%26amp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ehardware%20platform%3A%20IMX6Q-SABRESED%20%2B%20PCIE%20%2B%20TW6865%3C%2FP%3E%3CP%3ELTIB%3A%20L3.0.35_4.1.0_130816_source.tar.gz%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110216%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110216%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi!%40%3C%2FP%3E%3CP%3EI%20am%20doing%20the%20same%20thing!%20I%20use%20the%20tw6865%20and%26nbsp%3B%20I%20can%20read%20the%20picture%20from%20the%20cameras.what%20confuse%20me%20is%20that%20I%20can%20not%20change%20the%20resolution%20of%20the%20caption.%3C%2FP%3E%3CP%3EI%20use%20V4L2%20lib%20to%20config%20the%20camera%2C%3CSTRONG%3Ewhen%20it%20is%20configed%20with%20720*576%2C%20i%20will%20get%20a%20full%20picture%2Cjust%20like%20this%3A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20151113_180740.jpg%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20151113_180740.jpg%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20151113_180740.jpg%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20151113_180740.jpg%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20151113_180740.jpg%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20151113_180740.jpg%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20151113_180740.jpg%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20151113_180740.jpg%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20151113_180740.jpg%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20151113_180740.jpg%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20151113_180740.jpg%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20151113_180740.jpg%22%20style%3D%22width%3A%20749px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20151113_180740.jpg%22%20style%3D%22width%3A%20749px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F29787i44548654668FDCBD%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22IMG_20151113_180740.jpg%22%20alt%3D%22IMG_20151113_180740.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EIMG_20151113_180740.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Ewhen%20it%20is%20configed%20with%20other%20resolution%2Csuch%20as%20360*288%2C640*480%20and%20320*240%2C%20i%20will%20get%20a%20Incomplete%20picture%20%2Cjust%20like%20this%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20151113_175032.jpg%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20151113_175032.jpg%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20151113_175032.jpg%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20151113_175032.jpg%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20151113_175032.jpg%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20151113_175032.jpg%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20151113_175032.jpg%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20151113_175032.jpg%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20151113_175032.jpg%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20151113_175032.jpg%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20151113_175032.jpg%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20151113_175032.jpg%22%20style%3D%22width%3A%20749px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20151113_175032.jpg%22%20style%3D%22width%3A%20749px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F29788i90A261F52B069AD4%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22IMG_20151113_175032.jpg%22%20alt%3D%22IMG_20151113_175032.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EIMG_20151113_175032.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EI%20use%20a%20definition%20to%20define%20the%20resolution%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E%23define%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3EIMAGEWIDTH%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E720%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E%23define%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3EIMAGEHEIGHT%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E576%3C%2FSPAN%3E%3C%2FPRE%3E%3CP%3Ehere%20is%20the%20configuration%20code%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3Eint%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800080%3B%22%3ECamera_type%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3A%3A%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3Einit_v4l2%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E()%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3Eif%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E((%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efd%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3Eopen%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Edevice_add%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3EO_RDWR%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3EO_NONBLOCK%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E0%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E))%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E-%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E1%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22Error%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3Eopening%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3EV4L%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3Einterface%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3Ereturn%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3Efalse%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%2F%2Fquery%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3Ecap%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3Eif%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3Eioctl%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efd%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3EVIDIOC_QUERYCAP%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecap%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E-%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E1%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%2F*%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%E8%8E%B7%E5%8F%96%E8%AE%BE%E5%A4%87%E6%94%AF%E6%8C%81%E7%9A%84%E6%93%8D%E4%BD%9C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E*%2F%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22Error%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3Eopening%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3Edevice%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%25s%3A%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3Eunable%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3Eto%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3Equery%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3Edevice.%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Edevice_add%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3Ereturn%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3Efalse%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3Eelse%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22driver%3A%5Ct%5Ct%25s%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecap%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Edriver%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22card%3A%5Ct%5Ct%25s%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecap%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecard%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22bus_info%3A%5Ct%25s%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecap%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ebus_info%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22version%3A%5Ct%25d%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecap%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Eversion%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22capabilities%3A%5Ct%25x%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecap%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecapabilities%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3Eif%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E((%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecap%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecapabilities%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3EV4L2_CAP_VIDEO_CAPTURE%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3EV4L2_CAP_VIDEO_CAPTURE%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22Device%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%25s%3A%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3Esupports%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3Ecapture.%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Edevice_add%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3Eif%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E((%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecap%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecapabilities%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3EV4L2_CAP_STREAMING%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3EV4L2_CAP_STREAMING%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22Device%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%25s%3A%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3Esupports%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3Estreaming.%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Edevice_add%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%2F%2Femu%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3Eall%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3Esupport%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3Efmt%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmtdesc%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Eindex%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E0%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmtdesc%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Etype%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800080%3B%22%3EV4L2_BUF_TYPE_VIDEO_CAPTURE%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22Support%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3Eformat%3A%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3Ewhile%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3Eioctl%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efd%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3EVIDIOC_ENUM_FMT%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%26amp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmtdesc%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)!%3D-%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E1%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%2F*%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%E8%8E%B7%E5%8F%96%E8%AE%BE%E7%BD%AE%E6%94%AF%E6%8C%81%E7%9A%84%E8%A7%86%E9%A2%91%E6%A0%BC%E5%BC%8F%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E*%2F%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22%5Ct%25d.%25s%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmtdesc%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Eindex%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E1%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmtdesc%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Edescription%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmtdesc%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Eindex%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2B%2B%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%2F%2Fset%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3Efmt%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Etype%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800080%3B%22%3EV4L2_BUF_TYPE_VIDEO_CAPTURE%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Epix%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Epixelformat%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3EV4L2_PIX_FMT_YUYV%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Epix%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Eheight%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3EIMAGEHEIGHT%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Epix%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ewidth%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3EIMAGEWIDTH%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Epix%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efield%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800080%3B%22%3EV4L2_FIELD_INTERLACED%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3Eif%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3Eioctl%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efd%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3EVIDIOC_S_FMT%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E-%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E1%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%2F*%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%E8%AE%BE%E7%BD%AE%E6%8D%95%E8%8E%B7%E8%A7%86%E9%A2%91%E7%9A%84%E6%A0%BC%E5%BC%8F%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E*%2F%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22Unable%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3Eto%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3Eset%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3Eformat%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3Ereturn%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3Efalse%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3Eif%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3Eioctl%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efd%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3EVIDIOC_G_FMT%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E-%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E1%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%2F*%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%E8%8E%B7%E5%8F%96%E8%AE%BE%E7%BD%AE%E7%9A%84%E8%A7%86%E9%A2%91%E6%A0%BC%E5%BC%8F%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E*%2F%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22Unable%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3Eto%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3Eget%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3Eformat%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3Ereturn%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3Efalse%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22fmt.type%3A%5Ct%5Ct%25d%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Etype%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22pix.pixelformat%3A%5Ct%25c%25c%25c%25c%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Epix%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Epixelformat%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E0xFF%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Epix%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Epixelformat%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%26gt%3B%26gt%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E8%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E0xFF%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Epix%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Epixelformat%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%26gt%3B%26gt%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E16%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E0xFF%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Epix%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Epixelformat%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%26gt%3B%26gt%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E24%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E0xFF%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22pix.height%3A%5Ct%5Ct%25d%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Epix%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Eheight%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22pix.width%3A%5Ct%5Ct%25d%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Epix%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ewidth%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22pix.field%3A%5Ct%5Ct%25d%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Epix%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efield%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%2F%2Fset%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3Efps%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22init%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%25s%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%5Ct%5BOK%5D%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Edevice_add%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3Ereturn%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3Etrue%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FPRE%3E%3CP%3Ecould%20you%20please%20tell%20me%20where%20i%20am%20wrong%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110215%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110215%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20am%20doing%20the%20same%20thing!%20I%20use%20the%20tw6865%20and%26nbsp%3B%20I%20can%20read%20the%20picture%20from%20the%20cameras.what%20confuse%20me%20is%20that%20I%20can%20not%20change%20the%20resolution%20of%20the%20caption.%3C%2FP%3E%3CP%3EI%20use%20V4L2%20lib%20to%20config%20the%20camera%2C%3CSTRONG%3Ewhen%20it%20is%20configed%20with%20720*576%2C%20i%20will%20get%20a%20full%20picture%2Cjust%20like%20this%3A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20151113_180740.jpg%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20151113_180740.jpg%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20151113_180740.jpg%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20151113_180740.jpg%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20151113_180740.jpg%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20151113_180740.jpg%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20151113_180740.jpg%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20151113_180740.jpg%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20151113_180740.jpg%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20151113_180740.jpg%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20151113_180740.jpg%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20151113_180740.jpg%22%20style%3D%22width%3A%20749px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20151113_180740.jpg%22%20style%3D%22width%3A%20749px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F29787i44548654668FDCBD%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22IMG_20151113_180740.jpg%22%20alt%3D%22IMG_20151113_180740.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EIMG_20151113_180740.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Ewhen%20it%20is%20configed%20with%20other%20resolution%2Csuch%20as%20360*288%2C640*480%20and%20320*240%2C%20i%20will%20get%20a%20Incomplete%20picture%20%2Cjust%20like%20this%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20151113_175032.jpg%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20151113_175032.jpg%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20151113_175032.jpg%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20151113_175032.jpg%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20151113_175032.jpg%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20151113_175032.jpg%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20151113_175032.jpg%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20151113_175032.jpg%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20151113_175032.jpg%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20151113_175032.jpg%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20151113_175032.jpg%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20151113_175032.jpg%22%20style%3D%22width%3A%20749px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20151113_175032.jpg%22%20style%3D%22width%3A%20749px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F29788i90A261F52B069AD4%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22IMG_20151113_175032.jpg%22%20alt%3D%22IMG_20151113_175032.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EIMG_20151113_175032.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EI%20use%20a%20definition%20to%20define%20the%20resolution%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E%23define%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3EIMAGEWIDTH%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E720%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E%23define%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3EIMAGEHEIGHT%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E576%3C%2FSPAN%3E%3C%2FPRE%3E%3CP%3Ehere%20is%20the%20configuration%20code%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3Eint%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800080%3B%22%3ECamera_type%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3A%3A%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3Einit_v4l2%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E()%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3Eif%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E((%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efd%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3Eopen%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Edevice_add%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3EO_RDWR%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3EO_NONBLOCK%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E0%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E))%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E-%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E1%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22Error%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3Eopening%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3EV4L%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3Einterface%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3Ereturn%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3Efalse%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%2F%2Fquery%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3Ecap%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3Eif%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3Eioctl%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efd%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3EVIDIOC_QUERYCAP%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecap%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E-%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E1%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%2F*%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%E8%8E%B7%E5%8F%96%E8%AE%BE%E5%A4%87%E6%94%AF%E6%8C%81%E7%9A%84%E6%93%8D%E4%BD%9C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E*%2F%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22Error%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3Eopening%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3Edevice%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%25s%3A%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3Eunable%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3Eto%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3Equery%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3Edevice.%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Edevice_add%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3Ereturn%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3Efalse%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3Eelse%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22driver%3A%5Ct%5Ct%25s%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecap%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Edriver%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22card%3A%5Ct%5Ct%25s%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecap%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecard%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22bus_info%3A%5Ct%25s%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecap%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ebus_info%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22version%3A%5Ct%25d%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecap%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Eversion%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22capabilities%3A%5Ct%25x%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecap%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecapabilities%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3Eif%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E((%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecap%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecapabilities%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3EV4L2_CAP_VIDEO_CAPTURE%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3EV4L2_CAP_VIDEO_CAPTURE%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22Device%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%25s%3A%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3Esupports%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3Ecapture.%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Edevice_add%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3Eif%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E((%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecap%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecapabilities%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3EV4L2_CAP_STREAMING%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3EV4L2_CAP_STREAMING%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22Device%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%25s%3A%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3Esupports%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3Estreaming.%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Edevice_add%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%2F%2Femu%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3Eall%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3Esupport%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3Efmt%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmtdesc%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Eindex%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E0%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmtdesc%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Etype%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800080%3B%22%3EV4L2_BUF_TYPE_VIDEO_CAPTURE%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22Support%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3Eformat%3A%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3Ewhile%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3Eioctl%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efd%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3EVIDIOC_ENUM_FMT%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%26amp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmtdesc%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)!%3D-%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E1%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%2F*%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%E8%8E%B7%E5%8F%96%E8%AE%BE%E7%BD%AE%E6%94%AF%E6%8C%81%E7%9A%84%E8%A7%86%E9%A2%91%E6%A0%BC%E5%BC%8F%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E*%2F%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22%5Ct%25d.%25s%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmtdesc%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Eindex%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E1%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmtdesc%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Edescription%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmtdesc%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Eindex%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2B%2B%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%2F%2Fset%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3Efmt%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Etype%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800080%3B%22%3EV4L2_BUF_TYPE_VIDEO_CAPTURE%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Epix%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Epixelformat%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3EV4L2_PIX_FMT_YUYV%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Epix%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Eheight%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3EIMAGEHEIGHT%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Epix%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ewidth%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3EIMAGEWIDTH%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Epix%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efield%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800080%3B%22%3EV4L2_FIELD_INTERLACED%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3Eif%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3Eioctl%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efd%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3EVIDIOC_S_FMT%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E-%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E1%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%2F*%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%E8%AE%BE%E7%BD%AE%E6%8D%95%E8%8E%B7%E8%A7%86%E9%A2%91%E7%9A%84%E6%A0%BC%E5%BC%8F%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E*%2F%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22Unable%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3Eto%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3Eset%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3Eformat%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3Ereturn%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3Efalse%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3Eif%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3Eioctl%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efd%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3EVIDIOC_G_FMT%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E-%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E1%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%2F*%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%E8%8E%B7%E5%8F%96%E8%AE%BE%E7%BD%AE%E7%9A%84%E8%A7%86%E9%A2%91%E6%A0%BC%E5%BC%8F%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E*%2F%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22Unable%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3Eto%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3Eget%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3Eformat%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3Ereturn%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3Efalse%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22fmt.type%3A%5Ct%5Ct%25d%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Etype%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22pix.pixelformat%3A%5Ct%25c%25c%25c%25c%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Epix%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Epixelformat%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E0xFF%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Epix%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Epixelformat%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%26gt%3B%26gt%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E8%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E0xFF%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Epix%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Epixelformat%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%26gt%3B%26gt%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E16%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E0xFF%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Epix%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Epixelformat%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%26gt%3B%26gt%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E24%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E0xFF%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22pix.height%3A%5Ct%5Ct%25d%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Epix%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Eheight%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22pix.width%3A%5Ct%5Ct%25d%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Epix%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ewidth%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22pix.field%3A%5Ct%5Ct%25d%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Epix%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efield%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%2F%2Fset%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3Efps%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22init%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%25s%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%5Ct%5BOK%5D%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Edevice_add%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3Ereturn%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3Etrue%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FPRE%3E%3CP%3Ecould%20you%20please%20tell%20me%20where%20i%20am%20wrong%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110214%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110214%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ESorry%2C%20I%20didn%E2%80%99t%20fixed%20this%20problem.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20finally%20changed%20my%20way%20to%20create%20my%20own%20board.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBest%20regards..%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110213%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110213%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ehi%20%3A%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%EF%BC%A9%20used%20the%20same%20devices%20with%20you%2Cand%20the%20devices%20can%20not%20be%20recongnized%20by%20the%20board(iMX6Q%20SabreSD%20board).%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Have%20you%20fixed%20the%20problem%3Fif%20so%2Chow%20did%20you%20do%20it%20%3F%20or%20can%20you%20send%20the%20images%20to%20my%20email%20lxl2988%EF%BC%A0163.com.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThank%20you%20very%20much.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110212%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110212%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHI%20Yuan%20Zhao%2C%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20do%20you%20support%20this%20demo%20now%3F%20could%20you%20send%20me%20your%20email%20address%20to%20my%20email%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-email-small%22%20href%3D%22mailto%3Alisim51%40126.com%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Elisim51%40126.com%3C%2FA%3E%3CSPAN%3E%3F%26nbsp%3B%20I%20have%20some%20question%20for%20you.thanks.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110211%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110211%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%20everyone%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Now%2C%20we%20are%20designing%20the%20surrounding%20view%20hardware%20base%20on%20I.MX6%20and%26nbsp%3B%20%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3ETW68xx.%20This%20hardware%20platform%20is%20Integrated%20into%20one%20PCB%20and%20support%206%20camera%20most.%20Now%2C%20we%20are%20developing%20the%20software%20and%20Image%20processing%20algorithm%E3%80%82%20So%20anyone%20want%20to%20Cooperate%20with%20us%3F%20we%20can%20share%20this%20PCB%20platform%2C%20and%20you%20can%20share%20me%20your%20%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%3CSPAN%3Esoftware%20and%20Image%20processing%20algorithm%3F%20If%20possible%2C%20please%20contact%20me.%20email%3A%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-email-small%22%20href%3D%22mailto%3Alisim51%40126.com%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Elisim51%40126.com%3C%2FA%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110210%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110210%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EAs%20I%20know%20before%2C%20the%20daughter%20card%20should%20be%20just%20for%20internal%20use.%20I%20do%20not%20know%20the%20flow%20how%20the%20customer%20to%20get%20it.%20I%20think%20you%20can%20contact%20your%20FAE%20for%20the%20information.%20Thanks!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110209%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110209%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDear%20Mr.%20Zhao%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CIMG%20id%3D%22smileyhappy%22%20class%3D%22emoticon%20emoticon-smileyhappy%22%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fi%2Fsmilies%2F16x16_smiley-happy.png%22%20alt%3D%22Smiley%20Happy%22%20title%3D%22Smiley%20Happy%22%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThanks%20for%20your%20info.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ERegards%3B%3C%2FP%3E%3CP%3ESubrata%3C%2FP%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110208%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110208%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EBased%20on%20my%20previous%20experience%2C%204%20cameras%20can%20work%20together%2C%20and%20the%20application's%20preview%20speed%20of%20each%20camera%20can%20meet%2030fps.%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110207%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110207%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20our%20Query%20is%20for%20Intersil%20TW6865%3C%2FP%3E%3CP%3EData%20sheet%20says%204%20realtime%20D1%20video.%20Now%26nbsp%3B%20Real%20time%20video%20is%20~%2030fps.%3C%2FP%3E%3CP%3ENo%20where%20in%20datasheet%20it%20speaks%20about%20frame%20rate%20of%20simultaneous%204%20channel%20with%20D1%20resolution.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EPlease%20some%20body%20help%20us%20to%20know%20what%20will%20be%20the%20frame%20rate%20of%20simultaneous%20(fps)%20of%20each%20channel%2C%20when%26nbsp%3B%204%20channel%20is%20running%20simultaneously.%3C%2FP%3E%3CP%3EThank%20You%20in%20Advance!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110206%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110206%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fb47504%22%20target%3D%22_blank%22%3Eb47504%3C%2FA%3E%2C%3C%2FP%3E%3CP%3EI%20got%20TW68xx%20driver%20form%20my%20FAE.%20Working%20properly.%20Thanks%20you%20!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110205%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110205%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%20simon%20yeh%2C%3C%2FP%3E%3CP%3EWe%20should%20have%20created%20the%20patches%20for%203.10.17%2C%20so%26nbsp%3B%20I%20think%20you%20can%20contact%20your%20FAE%20to%20get%20it.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110204%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110204%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20%3CSPAN%20style%3D%22color%3A%20%238b8b8b%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%20%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FJiangJustin%22%20target%3D%22_blank%22%3EJiangJustin%3C%2FA%3E%20%2C%3C%2FP%3E%3CP%3ENow%20I%20use%20Yocto%20project%20%22fsl-yocto-3.10.17_1.0.0%22%20%26amp%3B%20%22fsl-community-bsp%22%20with%20Sabre%20SD%20board%20and%2CI%20want%20to%20add%20%22TW68%22%20Patch%20file%20to%20linux-imx%20kernel(3.10.17-r0).%3C%2FP%3E%3CP%3EBut%20I%20only%20have%20the%20patch%20file%20%22%3CSPAN%20style%3D%22color%3A%20%233778c7%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2012px%3B%20background-color%3A%20%23fdfdfd%3B%22%3Epcie_cap_patch.patch.zip%22%20from%20you%2C%20It's%20can't%20support%20Yocto%20linux%20kernal.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EWould%20you%20please%20help%20me%20to%20make%20Patch%20file%20for%20Yocto%20project%20on%20linux%20kernel%203.10.17.%3C%2FP%3E%3CP%3EThank%20you%20very%20much%20!!%20%3CIMG%20id%3D%22smileyhappy%22%20class%3D%22emoticon%20emoticon-smileyhappy%22%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fi%2Fsmilies%2F16x16_smiley-happy.png%22%20alt%3D%22Smiley%20Happy%22%20title%3D%22Smiley%20Happy%22%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110203%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110203%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EFor%20resolution%20of%20eache%20cameras%2C%20you%20can%20check%20tw68xx%20spec%2C%20I%20think.%3C%2FP%3E%3CP%3EWe%20have%20tried%20with%206%20cameras%20of%20D1%2C%20it%20can%20work%20well%20on%20imx6%20platform.%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110202%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110202%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello!%20Thanks%20a%20lot%20for%20the%20post.%3C%2FP%3E%3CP%3EWhat%20was%20the%20maximum%20resolution%20you%20got%20on%20each%20of%20the%20cameras%20(relative%20to%20the%20CPU%20performance%20required%20to%20manage%20those%20image%20streams).%3C%2FP%3E%3CP%3EThanks!%3C%2FP%3E%3CP%3EBruno%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110201%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110201%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EOK%2C%20I%20got%20it.%3C%2FP%3E%3CP%3EThank%20you%20very%20much.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110200%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110200%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThe%20information%20from%20hardware%20team%2C%20we%20bought%20at%20the%20beginning%20period.%3C%2FP%3E%3CP%3EBut%20I%20am%20not%20sure%20if%20all%20of%20their%20devices%20can%20work%2C%20as%20you%20know%20~~.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110199%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110199%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDid%20you%20mean%20that%2C%20the%20switch%20board%20you%20buied%20from%20bellow%20link%20is%20tested%20%3C%2FP%3E%3CP%3Eok%20with%20the%20tw6865%20pci%20board%3F%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fitem.taobao.com%2Fitem.htm%3Fspm%3Da1z10.1.w4004-5299295193.32.YwybCE%26amp%3Bid%3D22108840583%22%20target%3D%22test_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttp%3A%2F%2Fitem.taobao.com%2Fitem.htm%3Fspm%3Da1z10.1.w4004-5299295193.32.YwybCE%26amp%3Bid%3D22108840583%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThank%20you%20very%20much.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110198%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110198%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20checked%20the%20information%20we%20bought%20from%20the%20following%20link%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E1.%20%20%20%20%20%20%3CA%20href%3D%22http%3A%2F%2Fitem.taobao.com%2Fitem.htm%3Fspm%3Da1z10.1.w4004-5299295193.32.YwybCE%26amp%3Bid%3D22108840583%22%20target%3D%22test_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttp%3A%2F%2Fitem.taobao.com%2Fitem.htm%3Fspm%3Da1z10.1.w4004-5299295193.32.YwybCE%26amp%3Bid%3D22108840583%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E2.%20%20%20%20%20%20%20The%20daughter%20card%20num%20is%20limited%2C%20I%20have%20not%20found%20one%20more%20available.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110197%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110197%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThank%20you.%3C%2FP%3E%3CP%3EI%20tried%20another%20case.%3C%2FP%3E%3CP%3EI%20put%20the%20tw6865%20card%20and%20the%20minipcie2pcie%20switch%20to%20the%20notepc's%20mini-pcie%20slot%2C%3C%2FP%3E%3CP%3EAnd%20it%20can%20be%20linked%20up.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EIf%20there%20is%20no%20other%20way%2C%20i%20plan%20to%20create%20the%20daughter%20board%20use%20your%20board%20data.%3C%2FP%3E%3CP%3Ebut%20it%20will%20take%20a%20long%20time.%3C%2FP%3E%3CP%3EIf%20that%20is%20ok%2C%20may%20i%20borrow%20your%20daughter%20board%3F%20or%20i%20wish%20to%20buy%20one.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThank%20you%20very%20much.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110195%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110195%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThe%20devices%20i%20am%20using%20are%20as%20bellow%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E1.%3CA%20href%3D%22http%3A%2F%2Fitem.taobao.com%2Fitem.htm%3Fspm%3Da230r.1.14.36.DrGbFa%26amp%3Bid%3D35526656445%26amp%3Bns%3D1%23detail%22%20title%3D%22http%3A%2F%2Fitem.taobao.com%2Fitem.htm%3Fspm%3Da230r.1.14.36.DrGbFa%26amp%3Bid%3D35526656445%26amp%3Bns%3D1%23detail%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%5BIdeaTrust%E5%87%BA%E5%93%81%5D%20MINI%20PCI-E%E8%BD%ACPCI-E%201X%20minipcie%E8%BD%ACpcie%20%E8%BD%AC%E6%8E%A5%E5%8D%A1-%E6%B7%98%E5%AE%9D%E7%BD%91%3C%2FA%3E%3C%2FP%3E%3CP%3E2.%3CA%20href%3D%22http%3A%2F%2Fitem.taobao.com%2Fitem.htm%3Fspm%3Da230r.1.14.1.gzXu6T%26amp%3Bid%3D21941676978%26amp%3Bns%3D1%23detail%22%20title%3D%22http%3A%2F%2Fitem.taobao.com%2Fitem.htm%3Fspm%3Da230r.1.14.1.gzXu6T%26amp%3Bid%3D21941676978%26amp%3Bns%3D1%23detail%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fitem.taobao.com%2Fitem.htm%3Fspm%3Da230r.1.14.1.gzXu6T%26amp%3Bid%3D21941676978%26amp%3Bns%3D1%23detail%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110194%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110194%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThank%20you%2C%20could%20you%20confirm%20the%20pcie%20clock's%20enable%20mentioned%20at%20bellow%20message%20in%20another%20discussion.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%26gt%3BHongxing%2C%20thank%20you%20for%20your%20response.%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%26gt%3BI%20use%20L3.0.35_4.1.0_130816_source.tar.gz%20downloaded%20from%20freescale's%20IMX6QSD%20platform%20resource%20website.%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%26gt%3BNow%2C%20the%20problem%20has%20been%20solved.%20The%20PCIe%20clock%20output%20was%20not%20enabled%20in%20the%20code%20when%20IMX6%20worked%20as%20RC.%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fmessage%2F365363%22%20target%3D%22_blank%22%3EPCIE%20link%20up%20failed%20when%20booting%20the%20kernel%20on%20IMX6QSD%20board%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EAnd%20when%20you%20did%20this%20things%20at%20begin%2C%20before%20use%20the%20daughter%20card%2C%3C%2FP%3E%3CP%3Ewhich%20switch%20card%20you%20used%3F%E3%80%80Can%20you%20give%20me%20an%20url%20of%20it%20where%20i%20can%20buy%20it%20from.%3C%2FP%3E%3CP%3EThank%20you.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EOr%20can%20i%20borrow%20the%20daughter%20card%2C%20%3C%2FP%3E%3CP%3Eor%20borrow(buy)%20your%20old%20environment%20(mini-pcie2pcie%20switch%20card%20%26amp%3B%20tw6865%20pcie%20card)%3C%2FP%3E%3CP%3EThank%20you%20very%20much.%26nbsp%3B%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110193%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110193%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20am%20not%20sure%20if%20there%20is%20one%20compliance%20issue%20involved%20in%20you%20side.%20I%20would%20suggest%20you%20can%20try%20one%20more%20switch%20about%20it.%26nbsp%3B%20%3C%2FP%3E%3CP%3EI%20checked%20about%20the%20daughter%20card%2C%20it%20is%20just%20for%20internal%20use.%26nbsp%3B%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110192%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110192%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20buied%20the%20mini-pcie-%26gt%3Bpciex1%20switch%20card%20from%20%3CA%20href%3D%22http%3A%2F%2Fwww.taobao.com%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ewww.taobao.com%3C%2FA%3E.%3C%2FP%3E%3CP%3Eand%20confirm%20it%20works%20with%20an%20intel%20gigabit%20ethernet%20card%20.%3C%2FP%3E%3CP%3Eethernet%20card%20can%20be%20recongnized%20by%20the%20board.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBy%20the%20way%2Cwhere%20can%20i%20buy%20the%20tw6865%20daughter%20board%20you%20said%3F%3C%2FP%3E%3CP%3EThank%20you%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110191%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110191%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Calibri'%2C'sans-serif'%3B%20font-size%3A%2011pt%3B%22%3EWhere%20you%20get%20the%20pcie%20switch%20to%20connect%20tw6865.%20It%20seems%20that%20not%20all%20of%20pcie%20switch%20can%20work%26nbsp%3B%20friendly.%20You%20can%20try%20some%20other%20pcie%20device%20to%20test.%20Actually%2C%20now%20we%20have%20mini-pcie%20interface%20daughter%20card%20for%20tw6865.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110190%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110190%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EMy%20configuration%20is%20same%20with%20yours.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110189%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110189%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ENo%2C%20I%20have%20not%20seen%20your%20config%20file.%20Maybe%20it%20will%20need%20some%20time%20for%20community%20administer%E2%80%99%20s%20examination%20to%20attachment.%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EPlease%20make%20sure%20you%20config%20file%20about%20pcie%20aligned%20to%20the%20following%3A%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20red%3B%22%3E%23%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20red%3B%22%3E%23%20MX6%20Options%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20red%3B%22%3E%23%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20red%3B%22%3ECONFIG_IMX_PCIE%3Dy%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20red%3B%22%3E%23%20CONFIG_IMX_PCIE_EP_MODE_IN_EP_RC_SYS%20is%20not%20set%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20red%3B%22%3E%23%20CONFIG_IMX_PCIE_RC_MODE_IN_EP_RC_SYS%20is%20not%20set%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110188%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110188%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EDid%20you%20get%20my%20configure%20file%3F%3C%2FP%3E%3CP%3EI%20found%20that%20there%20is%20nothing%20on%20this%20page.%3C%2FP%3E%3CP%3EHow%20can%20i%20send%20you%20the%20attach%20file%3F%20e-mail%20is%20ok%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110187%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110187%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThank%20you%20very%20much.%3C%2FP%3E%3CP%3Ei%20send%20my%20config%20file%3C%2FP%3E%3CP%3Eand%20the%20pictures%20of%20my%20device%20i%20am%20using.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110186%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110186%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ECould%20you%20please%20share%20you%20.config%20file%20to%20us%3F%20We%20can%20check%20config%20file%20firstly.%20And%20please%20make%20sure%20the%20pcie%20card%20have%20been%20tightly%20inserted.%20Thanks.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110185%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110185%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FJiangJustin%22%20target%3D%22_blank%22%3EJiangJustin%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20am%20doing%20the%20same%20thing%20as%20you%20did%20above.%3C%2FP%3E%3CP%3EBut%20my%20tw6865%20card%20can't%20be%20identified.%20Bellow%20is%20what%20i%20have%20done.%3C%2FP%3E%3CP%3E1%20.%26nbsp%3B%20I%20add%20the%20patch%20file%20to%20the%20kernel%2C%20version%20is%20L3.0.35_4.1.0_130816%3C%2FP%3E%3CP%3E2.%26nbsp%3B%26nbsp%3B%20Change%20the%20kernel%20configure%20within%20make%20menuconfig%20to%20enable%20tw6865.%3C%2FP%3E%3CP%3E3.%26nbsp%3B%26nbsp%3B%20Build%20the%20kernel%20and%20write%20it%20to%20my%20SD%20card.%20I%20am%20using%20i.mx6q%20sabreSDB%20board.%3C%2FP%3E%3CP%3E4.%26nbsp%3B%26nbsp%3B%20Attach%20the%20mini-pcie%3D%26gt%3BPCIe%20adaptor%20and%20attch%20TW6865%20card%20to%20adaptor's%20pcie%20slot.%3C%2FP%3E%3CP%3E5.%26nbsp%3B%26nbsp%3B%20Boot%20the%20board%2C%20when%20system%20is%20up.%20use%20%22lspci%22%20to%20display%20the%20device.%20But%20there%20is%20nothing.%3C%2FP%3E%3CP%3E6.%26nbsp%3B%26nbsp%3B%20Check%20the%20kernel%20boot%20message%20with%20%22dmesg%22%2C%20there%20are%20errors%20as%20bellow%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EiMX6%20PCIe%20PCIe%20RC%20mode%20imx_pcie_pltfm_probe%20entering.%3C%2FP%3E%3CP%3EPCIE%3A%20imx_pcie_pltfm_probe%20start%20link%20up.%3C%2FP%3E%3CP%3Elink%20up%20failed%2C%20DB_R0%3A0x004abc43%2C%20DB_R1%3A0x08000000!%3C%2FP%3E%3CP%3EIMX%20PCIe%20port%3A%20link%20down!%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EIt%20seems%20like%20that%20link%20up%20was%20failed.%3C%2FP%3E%3CP%3Ecould%20you%20give%20me%20some%20advices%20to%20slove%20this%3F%3C%2FP%3E%3CP%3EThank%20you%20very%20much.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110184%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110184%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ETested%20on%20my%20local%20side%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ETest%20with%20Top%26nbsp%3B%20command%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EMem%3A%20109772K%20used%2C%20787076K%20free%2C%200K%20shrd%2C%203520K%20buff%2C%2024616K%20cached%3C%2FP%3E%3CP%3ECPU%3A%2012.2%25%20usr%2015.3%25%20sys%26nbsp%3B%200.0%25%20nic%2063.7%25%20idle%26nbsp%3B%200.0%25%20io%26nbsp%3B%200.0%25%20irq%26nbsp%3B%208.6%25%20sirq%3C%2FP%3E%3CP%3ELoad%20average%3A%207.02%205.16%202.56%204%2F94%203535%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ETest%20with%20MMDC%20tool%3A%3C%2FP%3E%3CP%3Eroot%40freescale%20~%24%20.%2Fmmdc_prof%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EMMDC%20new%20Profiling%20results%3A%3C%2FP%3E%3CP%3E***********************%3C%2FP%3E%3CP%3ETotal%20cycles%20count%3A%20528091007%3C%2FP%3E%3CP%3EBusy%20cycles%20count%3A%20385370313%3C%2FP%3E%3CP%3ERead%20accesses%20count%3A%209834967%3C%2FP%3E%3CP%3EWrite%20accesses%20count%3A%2010137409%3C%2FP%3E%3CP%3ERead%20bytes%20count%3A%20466175272%3C%2FP%3E%3CP%3EWrite%20bytes%20count%3A%20379222896%3C%2FP%3E%3COL%20style%3D%22list-style-type%3A%20upper-alpha%3B%22%3E%3CLI%3ERead%20burst%20size%3A%2047%3C%2FLI%3E%3CLI%3EWrite%20burst%20size%3A%2037%3C%2FLI%3E%3C%2FOL%3E%3CP%3ERead%3A%20444.58%20MB%2Fs%20%2F%26nbsp%3B%20Write%3A%20361.66%20MB%2Fs%26nbsp%3B%20Total%3A%20806.23%20MB%2Fs%3C%2FP%3E%3CP%3EUtilization%3A%2013%25%3C%2FP%3E%3CP%3EBus%20Load%3A%2072%25%3C%2FP%3E%3CP%3EBytes%20Access%3A%2042%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110183%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110183%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EWhat's%20the%20CPU%20occupancy%20when%20run%20the%20application%3F%20Thanks.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110265%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110265%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EBy%20the%20way%2C%20let%20me%20ask%3A%3C%2FP%3E%3CP%3EDoes%20the%20memory%20mapped%20by%20glTexDirectVIVMap%20have%20to%20be%20physically%20continuous%3F%20Thank%20you!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110267%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110267%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EglTexDirectVIVMap()%20can%20also%20get%20physical%20continuous%20memory.%20Its%20last%20parameter%20Physical%20can%20be%20used%20as%20the%20target%20buffer%20for%20IPU%20task%20operations%20and%20G2D%20operations.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110272%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110272%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHow%20many%204-channel%20videos%20can%20VPU%20encode%20at%20the%20same%20time%3F%20Will%20there%20be%20conflicts%20when%204%20tasks%20are%20encoded%20using%20VPU%20at%20the%20same%20time%3F%20Will%20they%20all%20try%20to%20occupy%20VPU%20resources%3F%20Because%20when%20I%20use%20IPU%2C%20I%20can%20create%204%20tasks%2C%202%20IPUs%2C%20and%202%20ipu_tasks%20in%20each%20IPU%20core%2C%20but%20does%20VPU%20also%20have%20a%20mechanism%20similar%20to%20IPU%3F%20I%20am%20not%20very%20clear%20about%20the%20mechanism%20of%20VPU%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110262%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110262%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%EF%BC%8Cliqiang%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26gt%3B%20%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3EHardware%20DMA%20operations%20require%20the%20use%20of%20physically%20continuous%20memory%2C%20and%20the%20memory%20allocated%20by%20malloc%20does%20not%20meet%20this%20requirement.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%2351626f%3B%22%3EPlease%20confirm%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%2351626f%3B%22%3EWhere%20does%20my%20application%20use%20DMA%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%2351626f%3B%22%3E%3CSPAN%3EDo%20you%20mean%20that%20g2d_alloc%20allocates%20non-contiguous%20physical%20memory%3F%20How%20does%20g2d_alloc%20allocate%20memory%3F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%2351626f%3B%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%2351626f%3B%22%3E%3CSPAN%3EThanks!%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%2351626f%3B%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%2351626f%3B%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%2351626f%3B%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110258%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110258%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EThanks%20for%20your%20answers!%3C%2FP%3E%3CP%3E1.%EF%BC%89VDI%E5%88%B0g2d%EF%BC%8C%3C%2FP%3E%3CP%3E2.)%20Then%20map%20the%20memory%20through%20gl.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110255%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110255%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EOur%20goal%20is%20to%20achieve%20zero%20copy%20of%20the%20program%2C%20but%20from%20the%20phenomenon%20it%20seems%20that%20the%20program%20is%20frozen%20when%20doing%20VDI.%3C%2FP%3E%3CP%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FQiang_FSL%22%20target%3D%22_blank%22%3EQiang_FSL%3C%2FA%3E%E2%80%8C%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110196%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110196%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EIf%20we%20enable%20%3CSPAN%20lang%3D%22EN%22%20style%3D%22font-family%3A%20'Helvetica'%2C'sans-serif'%3B%20color%3A%20red%3B%20font-size%3A%2010pt%3B%22%3ECONFIG_IMX_PCIE_EP_MODE_IN_EP_RC_SYS%20%3C%2FSPAN%3Eitem%2C%20the%20pice%20reference%20clock%20will%20not%20output%20by%20default%20%2C%20and%20it%20will%20work%20in%20separate%20clock%20mode.%20So%20we%20checked%20the%20.config%20file%20firstly.%20%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Calibri'%2C'sans-serif'%3B%20font-size%3A%2011pt%3B%22%3EIf%20you%20can%20recognize%20other%20pcie%20device%2C%26nbsp%3B%20I%20think%20your%20issue%26nbsp%3B%20is%20not%20same%20with%20this.%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110256%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110256%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EReplenish%3A%3C%2FP%3E%3CP%3EThe%20interface%20we%20use%20to%20allocate%20memory%20is%20glTexDirectVIV%2C%20instead%20of%20g2d_alloc%20in%20the%20sample%20code%3B%3C%2FP%3E%3CP%3EIs%20this%20the%20reason%20why%20IPU%20fails%20in%20VDI%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EWe%20have%20confirmed%20that%20VDI%20can%20only%20be%20performed%20normally%20if%20memory%20is%20allocated%20using%20g2d_alloc%3B%20if%20memory%20is%20allocated%20using%20malloc%2C%20the%20program%20will%20freeze!%3C%2FP%3E%3CP%3ECan%20it%20be%20understood%20that%20this%20patch%20(%20%3CSTRONG%3ETW6865%20driver%20for%20Linux%20L4.1.15_1.1.0-ga.7%3C%2FSTRONG%3E%20)%20only%20supports%20VDI%20to%20g2d_alloc%20space%2C%20but%20not%20VDI%20to%20malloc%20space%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EIf%20malloc%20support%20is%20needed%2C%20how%20should%20it%20be%20handled%3F%20Thank%20you!%EF%BD%9E%EF%BD%9E%EF%BD%9E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110263%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110263%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Eg2d_allo%20allocates%20physically%20continuous%20memory%2C%20while%20malloc%20does%20not.%3C%2FP%3E%3CP%3EThe%20source%20and%20destination%20buffers%20of%20camera%20image%20capture%2C%20IPU%20task%20operations%2C%20and%20G2D%20operations%20are%20required%20to%20be%20physically%20continuous%20memory.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110273%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110273%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EThe%20software%20architecture%20of%20VPU%20supports%20multi-tasking.%20Of%20course%2C%20when%20actually%20encoding%20on%20the%20VPU%20hardware%2C%20it%20is%20still%20done%20in%20a%20queue.%3C%2FP%3E%3C%2FLINGO-BODY%3E
No ratings
Version history
Last update:
‎07-17-2013 01:19 AM
Updated by:
