iMX6 TW686x Surround view patch
We use PCIe to connect Intersil TW6865 chip for the surround view solution.
This is the block diagram of the connection:
This is the 4 camera surround view:5173_5173.JPG4.JPG
Code base is L3.0.35_12.10.02 release. You can merge the patch file to the latest Freescale release.
Please check the attach file for the patch code.
Note:  It is only a test version.
The last code for L3.0.35 BSP: L3.0.35_GA4.1.0 Patches.7z
The last code for L3.10.53 BSP: L3.10.53_TW686x_patch.7z
Patch for L4.1.15 1.1.0 GA BSP: TW6865 driver for Linux L4.1.15_1.1.0-ga.7z
ラベル(4)
添付
コメント
Hi, is your intended video device enumerated ? i.e. what v4l2-ctl -d /dev/videox --all give you ?
and try exactly this :
gst-launch-1.0 -v v4l2src device=/dev/video0 ! video/x-raw,width=720,height=480,pixelformat=UYVY ! imxipuvideotransform ! imxeglvivsink
Note, for me pci MSI had to be disabled in order to get video frames !!!
Thanks!
Now it's working with " gst-launch-1.0 v4l2src device=/dev/video2 ! imxv4l2sink overlay-width=512 overlay-height=300 overlay-top=300 overlay-left=0 "
I don't know why imxv4l2src doesn't work.
"v4l2-ctl -d /dev/videox --all" outputs is here:
Driver Info (not using libv4l2):
Driver name : tw686x
Card type : tw6869
Bus info : PCI:0000:01:00.0
Driver version: 4.1.15
Capabilities : 0x85200001
Video Capture
Read/Write
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x05200001
Video Capture
Read/Write
Streaming
Extended Pix Format
Priority: 2
Video input : 0 (Composite0: ok)
Video Standard = 0x0000b000
NTSC-M/M-JP/M-KR
Format Video Capture:
Width/Height : 360/240
Pixel Format : 'YUYV'
Field : Interlaced
Bytes per Line: 720
Size Image : 172800
Colorspace : Broadcast NTSC/PAL (SMPTE170M/ITU601)
Flags :
Streaming Parameters Video Capture:
Capabilities : timeperframe
Frames per second: 30.000 (30/1)
Read buffers : 3
User Controls
brightness (int) : min=-128 max=127 step=1 default=0 value=0 flags=slider
contrast (int) : min=0 max=255 step=1 default=100 value=100 flags=slider
saturation (int) : min=0 max=255 step=1 default=128 value=128 flags=slider
hue (int) : min=-128 max=127 step=1 default=0 value=0 flags=slider
If I use imxv4l2src, it will say "could not link imxv4l2src0 to imxv4l2sink0".
Hi, now can you get the video stream without any latency as expected ? Do you have a git link to the driver you use with sabresd ? Or are you using a different board ?
Anuradha
1. For now, I'm using only one camera, if I run two or more camera there will be some error message:
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data flow error.
Additional debug info:
../../../../gstreamer-1.8.1/libs/gst/base/gstbasesrc.c(2948): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
streaming task paused, reason error (-5)
command is below:
gst-launch-1.0 v4l2src device=/dev/video0 ! imxv4l2sink overlay-width=512 overlay-height=300 overlay-top=0 overlay-left=0 &
gst-launch-1.0 v4l2src device=/dev/video1 ! imxv4l2sink overlay-width=512 overlay-height=300 overlay-top=0 overlay-left=512 &
For one camera, there is no latency.
2.  I use the driver you provided is another post, linux-imx6/drivers/media/pci/tw686x at boundary-imx_4.1.15_2.0.0_ga · boundarydevices/linux-imx6 · G... , I also try this one GitHub - sasamy/tw6869: tw6869/65 media bridge driver , same result.
I'm using a customed board.
I remember I had 'unexpected p-b buffer' issue while running the camera, but I was experimenting this on one of the Boundary Devices boards. Which board and distro are you using ? Can you also show the current memory map in kernel log?
i.e :-
Memory: 3551600K/3932156K available (8196K kernel code, 314K rwdata, 2448K rodata, 1024K init, 444K bss, 52876K reserved, 327680K cma-reserved, 2260988K highmem)
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
    vmalloc : 0xe6800000 - 0xff000000   ( 392 MB)
    lowmem  : 0x80000000 - 0xe6000000   (1632 MB)
    pkmap   : 0x7fe00000 - 0x80000000   (   2 MB)
    modules : 0x7f000000 - 0x7fe00000   (  14 MB)
      .text : 0x80008000 - 0x80b650ac   (11637 kB)
      .init : 0x80c00000 - 0x80d00000   (1024 kB)
      .data : 0x80d00000 - 0x80d4ea40   ( 315 kB)
       .bss : 0x80d51000 - 0x80dc0320   ( 445 kB)
Anuradha
My board is not belong to boundary boards.
yocto distro: "4.1.15-2.0.1", "fsl-imx-x11"
memory map:
Memory: 698176K/1048576K available (8364K kernel code, 432K rwdata, 3000K rodata, 432K init, 450K bss, 22720K reserved, 327680K cma-reserved, 0K highmem)
[ 0.000000] Virtual kernel memory layout:
vmalloc : 0xc0800000 - 0xff000000 (1000 MB)
lowmem : 0x80000000 - 0xc0000000 (1024 MB)
.text : 0x80008000 - 0x80b215e0 (11366 kB)
.init : 0x80b22000 - 0x80b8e000 ( 432 kB)
.data : 0x80b8e000 - 0x80bfa160 ( 433 kB)
.bss : 0x80bfd000 - 0x80c6d8c0 ( 451 kB)
I use the official kernel and use the boundary kernel's tw686x driver, I have also edited the quirk.c file.
Hi, have you got the issue resolved ? I can't see any issue in your logs. I also have the imxv4l2src video issue. I cannot even run a single camera consistently, the system freezes at a point and I am receiving 'unexpected p-b buffer issue' from the driver. I used Ubuntu for this. If there are any updates, please share with me !
I have not solved the imxv4l2src video issue.
The first thing is to make sure weather it is kernel's issue or gstreamer. Can you try nfs root? If so, it will be much convenient to try this rootfs:
rootfs.tar.bz2 - Google Drive , note it's for my linux 3.0.5, but it's also working for my linux 4.1.15 with device tree.
And then use
gst-launch-0.10 v4l2src device=/dev/video0 ! 'video/x-raw-yuv, format=(fourcc)UYVY' ! mfw_isink disp-width=512 disp-height=300 axis-left=0 axis-top=0
test it.
Btw how can I add mfw_isink ? I have no such element in gst-inspect !
The command above only suitable to the gst-launch-0.10 in the rootfs I provide.
Hi Lei Ma,
Have you got the camera issue resolved with boundary devices driver ? I still have this latency and freezing issue. I am strictly following the data sheet schematic of tw6865 chip !
Sorry, I'm not familiar with linux device driver, for now I'm focus on image process with opengl es and opencv.
Boundary devices driver has two drivers for tw6865, one is tw6869 from GitHub - sasamy/tw6869: tw6869/65 media bridge driver  another is tw686x from upstream kernel, I use the upstream one.
Hi, that's right. I am referring to the upstream kernel driver. Since you got it working without any problem I was wondering whether you have made a change to HW or Driver. In my case, for the upstream kernel driver, the video starts and frame rate becomes very low and then system hangs. I also see the 'unexpected p-b buffer' error in dmesg. Did you have to disable audio support or anything like that ? I had to disable pcie interrupt as well to get it work.... If you don't mind can you kindly share your linux .conf file ? I want to see kernel configurations under pcie.
Here is my kernel config file, .config - Google Drive , I also disabled pcie interrupt.
Thanks very much Lei, this is very helpful. Btw do you see 'unexpected p-b buffer' error appears in dmesg when running the camera ?
Anuradha
No, there is no such error in my device.
Hi, thanks alot for the prompt repose. That confirms one thing to me, there is a problem in the driver or my hardware !
Anuradha
Hi, one last thing to confirm Lei, are you aware of following patch for dma allocation ?
https://git.congatec.com/arm/qmx6_kernel/commit/f4857b5482c67dcc9757d50cf57cb32728af788b?w=1
https://community.nxp.com/thread/304368
If you don't mind, can you kindly check or share videobuf-dma-contig.c or mxc_vpu.c files of your running kernel ? I saw in several posts, these changes are required. If you're not aware, I'd like to point this for your attention too.....
I don't know that, my kernel version is 4.1.15, and these two files is bit different.
videobuf-dma-contig.c - Google Drive
mxc_vpu.c - Google Drive
Hi Lei Ma,
I got to know from the original author of the driver that, imxv4l2videosrc only works for csi cameras. Not with this pci stuffs. So correct source is v4l2src !
Btw is your single camera working well for gst-launch-1.0 with imxv4l2sink as well ? Without any latency ? can you also show me your pci/quirks.c file ?
Kindly confirm me it .........
Anuradha
Sorry I forget this. Is "latency" means delay? If is there is no latency with my camera.
quirks.c - Google Drive
Dear, Liqiang
Qiang_FSL‌
We are using your patch( TW6865 driver for Linux L4.1.15_1.1.0-ga.7z)and trying to develop 4 camera surroundview application base on imx6d chip and PCIE\TW68x\ CVBS camera , but meet a problem!
The application always freeze at the following codes:
    if (ioctl(m_ifd, IPU_CHECK_TASK, &m_sTask) != IPU_CHECK_OK) {
        printf("IPU_CHECK_TASK failed.\r\n");
        return -1;
Do you know the reason? thanks a lot!
我们的目标是想做到程序的zerocopy,但从现象上看好像是在做VDI的时候程序freeze了。
Qiang_FSL‌
补充:
我们分配内存使用的接口是glTexDirectVIV, 而没有使用例子代码中的g2d_alloc;
是这个原因导致IPU在做VDI失败吗?
我们确认下来,只有使用g2d_alloc分配内存才能正常的进行VDI;如果使用malloc分配内存,程序会freeze!
是不是可以理解成这个patch( TW6865 driver for Linux L4.1.15_1.1.0-ga.7)中只支持VDI到g2d_alloc的空间,不支持VDI到malloc空间?
如果需要支持到malloc,应该怎么处理?谢谢!~~~
IPU task's input.paddr and output.paddr should be physical address of the input buffer and output buffer, if you use wrong address, it will fail to work.
谢谢你的回答!
1.)VDI到g2d,
2.)再通过gl映射内存。
硬件DMA操作需要使用物理连续内存,malloc分配的内存不符合要求。
Hi Qiang Li:
I use the IMX6Q core board. Now when using both GC2000 and GC320, there are occasional image tears on the screen display.
The specific implementation is like this:
   Get the real-time video data of the 4-way camera, display it on the GPU and display it in real time on the lvds screen. At the same time, the 4 channels of video are called by g2d to call the g2g_blit function for resize. The image of each frame is 720P resize to 640*480, and then synthesized into one frame. Image so that 4 channels of video can be displayed in one frame.the spliced video is not display on the screen and saved directly into the video,but now it is found that the video displayed by the GPU rendering in real time will be torn. Playback of the saved video also found that the image has a tearing problem, affecting the viewing effect.
   If you test the GPU rendering display separately, or the video of 4 channels of video is saved by G2D synthesis, there will be no image tearing problem.
But as long as these two functions are combined into one project, the problem of image tearing will occur when displaying and the saving  video.
1. Can I use the GC2000 of IMX6 and GC320 at the same time? Is there a problem with GPU resource preemption?
2. Is there a problem with data conflicts in the GPU? I have already made the GC2000 and GC320 get data that cannot be bufed, but after the two functions are integrated, there will still be a problem of video tearing.
I think you need check the delay for each processing step, before next processing, maybe the pre-step is not finished.
Hi,liqiang
麻烦确认一下:
我这样应用在那里用到了DMA?
你的意思是说g2d_alloc 分配的不是连续物理内存吗?g2d_alloc 是如何分配内存的?
谢谢!
g2d_allo分配的就是物理连续内存,而malloc分配的就不是。
camera抓取图像,IPU task操作和G2D操作的源buffer和目标buffer都要求是物理连续内存。
了解了,谢谢!
顺便再问下:
glTexDirectVIVMap映射的内存,必须是物理连续的吗?谢谢!
另外,glTexDirectVIV 分配的内存是物理连续内存吗?谢谢
glTexDirectVIVMap()也可以得到物理连续内存,它的最后一个参数Physical可以用作IPU task操作和G2D操作的目标buffer。
According to what you mean, is the GC2000 and GC320 taking up the GPU in sequence? After the GC2000 has finished performing the on-screen rendering, can the GC320 take up GPU resources for 4-way image synthesis? Or first GC320 execution, then GC2000 re-execution? For different data buffers, can the two modules GC2000 and GC320 not run at the same time?
GC2000 and GC320 can run at the same time.
Hi,liqiang
我使用IMX6Q平台,现在有四路视频需要分别保存每个通道的视频数据,四路视频流是怎么进入VPU中进行编码的?单路的编码比较好实现,
4路视频需要串行的经过VPU,这个逻辑我实现起来毫无头绪,可否提供类似的资料链接或demo啊?
谢谢
4路编码和1路编是一样的,只要开4个任务就好了,但是VPU硬件不能支持4路720P编码
VPU可以同时编码分辨率时多少的4路视频?4个任务 同时使用VPU进行编码,不会有冲突吗?都会去抢占VPU的资源吧? 因为我使用IPU的时候可以创建4个任务,2个IPU,每个IPU内核中创建2个ipu_task,但是VPU也是有类似IPU的机制吗?不是很明确VPU的机制
VPU的软件架构支持多任务,当然,实际在VPU硬件上编码的时候,还是排队进行的。
我使用gstreamer进行4路视频编码为h264格式,使用让这个命令:srcapp->imxvideoconvert_ipu->vpuenc_h264->filesink, 我直接创建4 个pipeline就可以4路编码吗?系统会再VPU编码时自动处理每一路的编码顺序?
%3CLINGO-SUB%20id%3D%22lingo-sub-1110182%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EiMX6%20TW686x%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110182%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E3%81%AF%E3%80%81Intersil%20TW6865%E3%83%81%E3%83%83%E3%83%97%E3%81%AE%E6%8E%A5%E7%B6%9A%E3%81%ABPCIe%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81PCIe%E3%81%A8iMX6Q%20SabreSD%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E6%8E%A5%E7%B6%9A%E3%81%A7%E3%81%99%E3%80%82%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%225171_5171.JPG%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%225171_5171.JPG%22%20style%3D%22width%3A%20749px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117155iEE182166EA73B7BF%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%225171_5171.JPG%22%20alt%3D%225171_5171.JPG%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.JPG%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.JPG%22%20style%3D%22width%3A%20749px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F63252i97BFB8670817C82C%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%221.JPG%22%20alt%3D%221.JPG%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E6%8E%A5%E7%B6%9A%E3%81%AE%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E5%9B%B3%E3%82%92%E6%AC%A1%E3%81%AB%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%225172_5172.JPG%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%225172_5172.JPG%22%20style%3D%22width%3A%20766px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117156iD8AB5729CD358005%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%225172_5172.JPG%22%20alt%3D%225172_5172.JPG%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%223.JPG%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%223.JPG%22%20style%3D%22width%3A%20766px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F110925i5BE7069E73C283AF%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%223.JPG%22%20alt%3D%223.JPG%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF4%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%AE%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%81%A7%E3%81%99%E3%80%82%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%225173_5173.JPG%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%225173_5173.JPG%22%20style%3D%22width%3A%20779px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117157i93B54CB8E51A864A%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%225173_5173.JPG%22%20alt%3D%225173_5173.JPG%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%224.JPG%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%224.JPG%22%20style%3D%22width%3A%20779px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F110924iD64E303E5B9048E7%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%224.JPG%22%20alt%3D%224.JPG%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%BC%E3%83%89%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AFL3.0.35_12.10.02%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%A7%E3%81%99%E3%80%82%E3%83%91%E3%83%83%E3%83%81%E3%83%BB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E6%9C%80%E6%96%B0%E3%81%AEFreescale%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%AB%E3%83%9E%E3%83%BC%E3%82%B8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%91%E3%83%83%E3%83%81%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E6%B7%BB%E4%BB%98%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E6%B3%A8%3A%E3%81%93%E3%82%8C%E3%81%AF%E3%83%86%E3%82%B9%E3%83%88%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AE%E3%81%BF%E3%81%A7%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3EL3.0.35%20%E3%81%AE%E6%9C%80%E5%BE%8C%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89BSP%3AL3.0.35_GA4.1.0Patches.7z%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3EL3.10.53%20BSP%E3%81%AE%E6%9C%80%E5%BE%8C%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%3AL3.10.53_TW686x_patch.7z%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3EL4.1.15%20%E3%81%AE%E3%83%91%E3%83%83%E3%83%811.1.0GA%20BSP%3ALinux%20L4.1.15_1.1.0-ga.7z%E7%94%A8%E3%81%AETW6865%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1110182%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX6DL%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6Dual%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6Quad%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110274%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110274%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Egstreamer%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A64%E3%83%81%E3%83%A3%E3%83%B3%E3%83%8D%E3%83%AB%E3%81%AE%E3%83%93%E3%83%87%E3%82%AA%E3%82%92h264%E5%BD%A2%E5%BC%8F%E3%81%AB%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AFsrcapp-%26gt%3Bimxvideoconvert_ipu-%26gt%3Bvpuenc_h264-%26gt%3Bfilesink%E3%81%A7%E3%81%99%E3%80%824%E3%83%81%E3%83%A3%E3%83%B3%E3%83%8D%E3%83%AB%E3%82%92%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB4%E3%81%A4%E3%81%AE%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%92%E7%9B%B4%E6%8E%A5%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9FVPU%E3%81%8C%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E9%9A%9B%E3%81%AB%E3%80%81%E5%90%84%E3%83%81%E3%83%A3%E3%83%B3%E3%83%8D%E3%83%AB%E3%81%AE%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%89%E9%A0%86%E5%BA%8F%E3%81%AF%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E8%87%AA%E5%8B%95%E7%9A%84%E3%81%AB%E5%87%A6%E7%90%86%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110273%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110273%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EVPU%E3%81%AE%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%A2%E3%83%BC%E3%82%AD%E3%83%86%E3%82%AF%E3%83%81%E3%83%A3%E3%81%AF%E3%83%9E%E3%83%AB%E3%83%81%E3%82%BF%E3%82%B9%E3%82%AF%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%82%E3%81%A1%E3%82%8D%E3%82%93%E3%80%81VPU%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E4%B8%8A%E3%81%A7%E5%AE%9F%E9%9A%9B%E3%81%AB%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E8%A1%8C%E3%81%86%E9%9A%9B%E3%81%AF%E3%80%81%E3%82%AD%E3%83%A5%E3%83%BC%E5%86%85%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110272%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110272%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EVPU%E3%81%AF%E5%90%8C%E6%99%82%E3%81%AB%E4%BD%95%E6%9C%AC%E3%81%AE4%E3%83%81%E3%83%A3%E3%83%B3%E3%83%8D%E3%83%AB%E5%8B%95%E7%94%BB%E3%82%92%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F4%E3%81%A4%E3%81%AE%E3%82%BF%E3%82%B9%E3%82%AF%E3%82%92VPU%E3%81%A7%E5%90%8C%E6%99%82%E3%81%AB%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E3%81%A8%E7%AB%B6%E5%90%88%E3%81%AF%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E3%81%9D%E3%82%8C%E3%82%89%E3%81%AF%E3%81%99%E3%81%B9%E3%81%A6VPU%E3%83%AA%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%92%E5%8D%A0%E6%9C%89%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9FIPU%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E5%90%84IPU%E3%82%B3%E3%82%A2%E3%81%AB4%E3%81%A4%E3%81%AE%E3%82%BF%E3%82%B9%E3%82%AF%E3%80%812%E3%81%A4%E3%81%AEIPU%E3%80%812%E3%81%A4%E3%81%AEipu_tasks%E3%82%92%E4%BD%9C%E6%88%90%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81VPU%E3%81%AB%E3%82%82IPU%E3%81%A8%E5%90%8C%E6%A7%98%E3%81%AE%E4%BB%95%E7%B5%84%E3%81%BF%E3%81%8C%E3%81%82%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9FVPU%E3%81%AE%E4%BB%95%E7%B5%84%E3%81%BF%E3%81%8C%E3%82%88%E3%81%8F%E5%88%86%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110271%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110271%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E4%E3%83%81%E3%83%A3%E3%83%B3%E3%83%8D%E3%83%AB%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF1%E3%83%81%E3%83%A3%E3%83%B3%E3%83%8D%E3%83%AB%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A8%E5%90%8C%E3%81%98%E3%81%A7%E3%80%814%E3%81%A4%E3%81%AE%E3%82%BF%E3%82%B9%E3%82%AF%E3%82%92%E9%96%8B%E3%81%8F%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81VPU%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AF4%E3%83%81%E3%83%A3%E3%83%B3%E3%83%8D%E3%83%AB720P%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110270%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110270%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22display%3A%20inline%20!important%3B%20float%3A%20none%3B%20background-color%3A%20transparent%3B%20color%3A%20%2351626f%3B%20font-family%3A%20arial%2Chelvetica%2C'helvetica%20neue'%2Cverdana%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%22%3EHi%EF%BC%8Cliqiang%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22display%3A%20inline%20!important%3B%20float%3A%20none%3B%20background-color%3A%20transparent%3B%20color%3A%20%2351626f%3B%20font-family%3A%20arial%2Chelvetica%2C'helvetica%20neue'%2Cverdana%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%22%3EIMX6Q%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%8F%BE%E5%9C%A8%E3%80%814%E3%83%81%E3%83%A3%E3%83%B3%E3%83%8D%E3%83%AB%E3%81%AE%E3%83%93%E3%83%87%E3%82%AA%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E5%90%84%E3%83%81%E3%83%A3%E3%83%B3%E3%83%8D%E3%83%AB%E3%81%AE%E3%83%93%E3%83%87%E3%82%AA%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E5%80%8B%E5%88%A5%E3%81%AB%E4%BF%9D%E5%AD%98%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%824%E3%83%81%E3%83%A3%E3%83%B3%E3%83%8D%E3%83%AB%E3%81%AE%E3%83%93%E3%83%87%E3%82%AA%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%E3%81%AF%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%97%E3%81%A6VPU%E3%81%AB%E5%85%A5%E5%8A%9B%E3%81%95%E3%82%8C%E3%80%81%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%E3%83%81%E3%83%A3%E3%83%B3%E3%83%8D%E3%83%AB%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E6%96%B9%E3%81%8C%E5%AE%9F%E8%A3%85%E3%81%8C%E7%B0%A1%E5%8D%98%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22display%3A%20inline%20!important%3B%20float%3A%20none%3B%20background-color%3A%20transparent%3B%20color%3A%20%2351626f%3B%20font-family%3A%20arial%2Chelvetica%2C'helvetica%20neue'%2Cverdana%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%22%3E4%E3%83%81%E3%83%A3%E3%83%B3%E3%83%8D%E3%83%AB%E3%81%AE%E3%83%93%E3%83%87%E3%82%AA%E4%BF%A1%E5%8F%B7%E3%82%92VPU%E3%81%AB%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%81%A7%E9%80%81%E4%BF%A1%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%83%AD%E3%82%B8%E3%83%83%E3%82%AF%E3%82%92%E3%81%A9%E3%81%86%E5%AE%9F%E8%A3%85%E3%81%99%E3%82%8C%E3%81%B0%E3%81%84%E3%81%84%E3%81%AE%E3%81%8B%E5%85%A8%E3%81%8F%E5%88%86%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E5%90%8C%E6%A7%98%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%84%E3%83%87%E3%83%A2%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22display%3A%20inline%20!important%3B%20float%3A%20none%3B%20background-color%3A%20transparent%3B%20color%3A%20%2351626f%3B%20font-family%3A%20arial%2Chelvetica%2C'helvetica%20neue'%2Cverdana%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%22%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110267%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110267%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EglTexDirectVIVMap()%20%E3%81%AF%E7%89%A9%E7%90%86%E7%9A%84%E3%81%AA%E9%80%A3%E7%B6%9A%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%82%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E6%9C%80%E5%BE%8C%E3%81%AE%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%20Physical%20%E3%81%AF%E3%80%81IPU%20%E3%82%BF%E3%82%B9%E3%82%AF%E6%93%8D%E4%BD%9C%E3%81%8A%E3%82%88%E3%81%B3%20G2D%20%E6%93%8D%E4%BD%9C%E3%81%AE%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110266%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110266%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81glTexDirectVIV%E3%81%A7%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%82%8B%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AF%E7%89%A9%E7%90%86%E7%9A%84%E3%81%AB%E9%80%A3%E7%B6%9A%E3%81%97%E3%81%9F%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110265%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110265%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%A8%E3%81%93%E3%82%8D%E3%81%A7%E3%80%81%E8%B3%AA%E5%95%8F%E3%81%95%E3%81%9B%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3EglTexDirectVIVMap%20%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E3%83%9E%E3%83%83%E3%83%97%E3%81%95%E3%82%8C%E3%82%8B%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AF%E7%89%A9%E7%90%86%E7%9A%84%E3%81%AB%E9%80%A3%E7%B6%9A%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%20%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110264%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110264%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%88%86%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110263%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110263%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Eg2d_allo%20%E3%81%AF%E7%89%A9%E7%90%86%E7%9A%84%E3%81%AB%E9%80%A3%E7%B6%9A%E3%81%97%E3%81%9F%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81malloc%20%E3%81%AF%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%AB%E3%83%A1%E3%83%A9%E7%94%BB%E5%83%8F%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%80%81IPU%20%E3%82%BF%E3%82%B9%E3%82%AF%E6%93%8D%E4%BD%9C%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%20G2D%20%E6%93%8D%E4%BD%9C%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%20%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%A8%E5%AE%9B%E5%85%88%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%AF%E3%80%81%E7%89%A9%E7%90%86%E7%9A%84%E3%81%AB%E9%80%A3%E7%B6%9A%E3%81%97%E3%81%9F%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%A7%E3%81%82%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110262%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110262%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%EF%BC%8Cliqiang%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26gt%3B%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%20DMA%20%E6%93%8D%E4%BD%9C%E3%81%A7%E3%81%AF%E7%89%A9%E7%90%86%E7%9A%84%E3%81%AB%E9%80%A3%E7%B6%9A%E3%81%97%E3%81%9F%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AE%E4%BD%BF%E7%94%A8%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81malloc%20%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%9F%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AF%E3%81%93%E3%81%AE%E8%A6%81%E4%BB%B6%E3%82%92%E6%BA%80%E3%81%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%2351626f%3B%22%3E%E3%81%94%E7%A2%BA%E8%AA%8D%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%2351626f%3B%22%3E%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF%20DMA%20%E3%82%92%E3%81%A9%E3%81%93%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%2351626f%3B%22%3E%3CSPAN%3Eg2d_alloc%20%E3%81%AF%E9%9D%9E%E9%80%A3%E7%B6%9A%E3%81%AA%E7%89%A9%E7%90%86%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%8B%E3%81%A8%E3%81%84%E3%81%86%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%20g2d_alloc%20%E3%81%AF%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%2351626f%3B%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%2351626f%3B%22%3E%3CSPAN%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%EF%BC%81%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%2351626f%3B%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%2351626f%3B%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%2351626f%3B%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110260%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AiMX6%20TW686x%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110260%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20border-image-outset%3A%200%3B%20border-image-repeat%3A%20stretch%3B%20border-image-slice%3A%20100%25%3B%20border-image-source%3A%20none%3B%20border-image-width%3A%201%3B%20color%3A%20%2351626f%3B%20font-family%3A%20arial%2Chelvetica%2C%22%20helvetica%3D%22%22%20neue%3D%22%22%3EHi%20Qiang%20Li%EF%BC%9A%3C%2FP%3E%3CDIV%20style%3D%22background-color%3A%20transparent%3B%20border-image-outset%3A%200%3B%20border-image-repeat%3A%20stretch%3B%20border-image-slice%3A%20100%25%3B%20border-image-source%3A%20none%3B%20border-image-width%3A%201%3B%20color%3A%20%2351626f%3B%20font-family%3A%20arial%2Chelvetica%2C%22%20helvetica%3D%22%22%20neue%3D%22%22%3EIMX6Q%E3%82%B3%E3%82%A2%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82GC2000%20%E3%81%A8%20GC320%20%E3%81%AE%E4%B8%A1%E6%96%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E7%94%BB%E9%9D%A2%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AB%E7%94%BB%E5%83%8F%E3%81%8C%E3%81%A1%E3%82%89%E3%81%A4%E3%81%8F%E3%81%93%E3%81%A8%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20style%3D%22border-image-outset%3A%200%3B%20border-image-repeat%3A%20stretch%3B%20border-image-slice%3A%20100%25%3B%20border-image-source%3A%20none%3B%20border-image-width%3A%201%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-weight%3A%20400%3B%20vertical-align%3A%20baseline%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%20border%3A%200px%20none%20%2351626f%3B%22%20%2F%3E%E5%85%B7%E4%BD%93%E7%9A%84%E3%81%AA%E5%AE%9F%E8%A3%85%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20style%3D%22border-image-outset%3A%200%3B%20border-image-repeat%3A%20stretch%3B%20border-image-slice%3A%20100%25%3B%20border-image-source%3A%20none%3B%20border-image-width%3A%201%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-weight%3A%20400%3B%20vertical-align%3A%20baseline%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%20border%3A%200px%20none%20%2351626f%3B%22%20%2F%3E4%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%AE%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%BF%E3%82%A4%E3%83%A0%E3%83%93%E3%83%87%E3%82%AA%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%80%81GPU%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%97%E3%81%A6%E3%80%81lvds%E7%94%BB%E9%9D%A2%E3%81%AB%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%BF%E3%82%A4%E3%83%A0%E3%81%A7%E8%A1%A8%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E5%90%8C%E6%99%82%E3%81%AB%E3%80%81%E3%83%93%E3%83%87%E3%82%AA%E3%81%AE%204%20%E3%81%A4%E3%81%AE%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%81%8C%20g2d%20%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%95%E3%82%8C%E3%80%81%E3%82%B5%E3%82%A4%E3%82%BA%E5%A4%89%E6%9B%B4%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AE%20g2g_blit%20%E9%96%A2%E6%95%B0%E3%81%8C%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E5%90%84%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%81%AE%E7%94%BB%E5%83%8F%E3%81%AF%20720P%20%E3%81%A7%20640*480%20%E3%81%AB%E3%82%B5%E3%82%A4%E3%82%BA%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%80%811%20%E3%81%A4%E3%81%AE%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%81%AB%E5%90%88%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%821%E3%81%A4%E3%81%AE%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%81%AB4%E3%83%81%E3%83%A3%E3%83%B3%E3%83%8D%E3%83%AB%E3%81%AE%E3%83%93%E3%83%87%E3%82%AA%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E3%82%B9%E3%83%97%E3%83%A9%E3%82%A4%E3%82%B9%E3%81%95%E3%82%8C%E3%81%9F%E3%83%93%E3%83%87%E3%82%AA%E3%81%AF%E7%94%BB%E9%9D%A2%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%9A%E3%80%81%E3%83%93%E3%83%87%E3%82%AA%E3%81%AB%E7%9B%B4%E6%8E%A5%E4%BF%9D%E5%AD%98%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81GPU%E3%83%AC%E3%83%B3%E3%83%80%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%BF%E3%82%A4%E3%83%A0%E3%81%A7%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%82%8B%E3%83%93%E3%83%87%E3%82%AA%E3%81%8C%E7%A0%B4%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E4%BF%9D%E5%AD%98%E3%81%97%E3%81%9F%E3%83%93%E3%83%87%E3%82%AA%E3%82%92%E5%86%8D%E7%94%9F%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E7%94%BB%E5%83%8F%E3%81%AB%E3%83%86%E3%82%A3%E3%82%A2%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E8%A1%A8%E7%A4%BA%E5%8A%B9%E6%9E%9C%E3%81%AB%E5%BD%B1%E9%9F%BF%E3%82%92%E4%B8%8E%E3%81%88%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FDIV%3E%3CDIV%20style%3D%22background-color%3A%20transparent%3B%20border-image-outset%3A%200%3B%20border-image-repeat%3A%20stretch%3B%20border-image-slice%3A%20100%25%3B%20border-image-source%3A%20none%3B%20border-image-width%3A%201%3B%20color%3A%20%2351626f%3B%20font-family%3A%20arial%2Chelvetica%2C%22%20helvetica%3D%22%22%20neue%3D%22%22%3E%20%3C%2FDIV%3E%3CDIV%20style%3D%22background-color%3A%20transparent%3B%20border-image-outset%3A%200%3B%20border-image-repeat%3A%20stretch%3B%20border-image-slice%3A%20100%25%3B%20border-image-source%3A%20none%3B%20border-image-width%3A%201%3B%20color%3A%20%2351626f%3B%20font-family%3A%20arial%2Chelvetica%2C%22%20helvetica%3D%22%22%20neue%3D%22%22%3EGPU%E3%83%AC%E3%83%B3%E3%83%80%E3%83%AA%E3%83%B3%E3%82%B0%E8%A1%A8%E7%A4%BA%E3%82%92%E5%88%A5%E9%80%94%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%9F%E3%82%8A%E3%80%814%E3%83%81%E3%83%A3%E3%83%B3%E3%83%8D%E3%83%AB%E3%81%AE%E5%8B%95%E7%94%BB%E3%82%92G2D%E5%90%88%E6%88%90%E3%81%A7%E4%BF%9D%E5%AD%98%E3%81%97%E3%81%9F%E3%82%8A%E3%81%99%E3%82%8C%E3%81%B0%E3%80%81%E7%94%BB%E5%83%8F%E3%81%AE%E3%83%86%E3%82%A3%E3%82%A2%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AF%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20style%3D%22border-image-outset%3A%200%3B%20border-image-repeat%3A%20stretch%3B%20border-image-slice%3A%20100%25%3B%20border-image-source%3A%20none%3B%20border-image-width%3A%201%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-weight%3A%20400%3B%20vertical-align%3A%20baseline%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%20border%3A%200px%20none%20%2351626f%3B%22%20%2F%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%81%93%E3%82%8C%E3%82%892%E3%81%A4%E3%81%AE%E6%A9%9F%E8%83%BD%E3%81%8C1%E3%81%A4%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AB%E3%81%BE%E3%81%A8%E3%82%81%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E9%99%90%E3%82%8A%E3%80%81%E3%83%93%E3%83%87%E3%82%AA%E3%81%AE%E8%A1%A8%E7%A4%BA%E6%99%82%E3%81%A8%E4%BF%9D%E5%AD%98%E6%99%82%E3%81%AB%E7%94%BB%E5%83%8F%E3%81%AE%E3%83%86%E3%82%A3%E3%82%A2%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%20style%3D%22background-color%3A%20transparent%3B%20border-image-outset%3A%200%3B%20border-image-repeat%3A%20stretch%3B%20border-image-slice%3A%20100%25%3B%20border-image-source%3A%20none%3B%20border-image-width%3A%201%3B%20color%3A%20%2351626f%3B%20font-family%3A%20arial%2Chelvetica%2C%22%20helvetica%3D%22%22%20neue%3D%22%22%3E%20%3C%2FDIV%3E%3CDIV%20style%3D%22background-color%3A%20transparent%3B%20border-image-outset%3A%200%3B%20border-image-repeat%3A%20stretch%3B%20border-image-slice%3A%20100%25%3B%20border-image-source%3A%20none%3B%20border-image-width%3A%201%3B%20color%3A%20%2351626f%3B%20font-family%3A%20arial%2Chelvetica%2C%22%20helvetica%3D%22%22%20neue%3D%22%22%3E1.%20IMX6%E3%81%AEGC2000%E3%81%A8GC320%E3%81%AF%E5%90%8C%E6%99%82%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3FGPU%E3%83%AA%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%AE%E3%83%97%E3%83%AA%E3%82%A8%E3%83%B3%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3CBR%20style%3D%22border-image-outset%3A%200%3B%20border-image-repeat%3A%20stretch%3B%20border-image-slice%3A%20100%25%3B%20border-image-source%3A%20none%3B%20border-image-width%3A%201%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-weight%3A%20400%3B%20vertical-align%3A%20baseline%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%20border%3A%200px%20none%20%2351626f%3B%22%20%2F%3E2.%20GPU%E3%81%A7%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AE%E7%AB%B6%E5%90%88%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%99%E3%81%A7%E3%81%ABGC2000%E3%81%A8GC320%E3%81%AB%E3%83%96%E3%83%83%E3%83%95%E3%82%A7%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E5%8F%96%E5%BE%97%E3%81%95%E3%81%9B%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%812%E3%81%A4%E3%81%AE%E6%A9%9F%E8%83%BD%E3%82%92%E7%B5%B1%E5%90%88%E3%81%97%E3%81%9F%E5%BE%8C%E3%82%82%E3%80%81%E3%83%93%E3%83%87%E3%82%AA%E3%81%AE%E3%83%86%E3%82%A3%E3%82%A2%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E6%AE%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%20style%3D%22background-color%3A%20transparent%3B%20border-image-outset%3A%200%3B%20border-image-repeat%3A%20stretch%3B%20border-image-slice%3A%20100%25%3B%20border-image-source%3A%20none%3B%20border-image-width%3A%201%3B%20color%3A%20%2351626f%3B%20font-family%3A%20arial%2Chelvetica%2C%22%20helvetica%3D%22%22%20neue%3D%22%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%BE%AE%E4%BF%A1%E5%9B%BE%E7%89%87_20190105150729.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%BE%AE%E4%BF%A1%E5%9B%BE%E7%89%87_20190105150729.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F71446i32E371FA8C04993D%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22%E5%BE%AE%E4%BF%A1%E5%9B%BE%E7%89%87_20190105150729.png%22%20alt%3D%22%E5%BE%AE%E4%BF%A1%E5%9B%BE%E7%89%87_20190105150729.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110259%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110259%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%20DMA%20%E6%93%8D%E4%BD%9C%E3%81%A7%E3%81%AF%E7%89%A9%E7%90%86%E7%9A%84%E3%81%AB%E9%80%A3%E7%B6%9A%E3%81%97%E3%81%9F%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AE%E4%BD%BF%E7%94%A8%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81malloc%20%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%9F%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AF%E3%81%93%E3%81%AE%E8%A6%81%E4%BB%B6%E3%82%92%E6%BA%80%E3%81%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110258%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110258%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%94%E5%9B%9E%E7%AD%94%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%3C%2FP%3E%3CP%3E1.%EF%BC%89VDI%E5%88%B0g2d%EF%BC%8C%3C%2FP%3E%3CP%3E2.)%20%E6%AC%A1%E3%81%AB%E3%80%81gl%20%E3%82%92%E9%80%9A%E3%81%98%E3%81%A6%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92%E3%83%9E%E3%83%83%E3%83%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110256%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110256%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%A3%9C%E5%85%85%3A%3C%2FP%3E%3CP%3E%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%82%A4%E3%82%B9%E3%81%AF%E3%80%81%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%20%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%20g2d_alloc%20%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81glTexDirectVIV%20%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%8C%20VDI%20%E3%81%A7%20IPU%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%99%E3%82%8B%E7%90%86%E7%94%B1%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eg2d_alloc%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AB%E3%81%AE%E3%81%BF%20VDI%20%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E7%A2%BA%E8%AA%8D%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82malloc%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%8C%E3%83%95%E3%83%AA%E3%83%BC%E3%82%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%20(%20%3CSTRONG%3ELinux%20L4.1.15_1.1.0-ga.7%20%E7%94%A8%E3%81%AE%20TW6865%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FSTRONG%3E)%20%E3%81%AF%E3%80%81g2d_alloc%20%E7%A9%BA%E9%96%93%E3%81%B8%E3%81%AE%20VDI%20%E3%81%AE%E3%81%BF%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%80%81malloc%20%E7%A9%BA%E9%96%93%E3%81%B8%E3%81%AE%20VDI%20%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%AA%E3%81%84%E3%81%A8%E3%81%84%E3%81%86%E3%81%93%E3%81%A8%E3%82%92%E7%90%86%E8%A7%A3%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Emalloc%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AA%E5%A0%B4%E5%90%88%E3%81%AF%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%AF%BE%E5%BF%9C%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%20%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%EF%BC%81%EF%BD%9E%EF%BD%9E%EF%BD%9E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110255%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110255%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%AE%E3%82%B3%E3%83%94%E3%83%BC%E3%82%BC%E3%83%AD%E3%82%92%E7%9B%AE%E6%A8%99%E3%81%AB%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E7%8F%BE%E8%B1%A1%E3%81%A8%E3%81%97%E3%81%A6%E3%81%AFVDI%E3%82%92%E8%A1%8C%E3%81%86%E3%81%A8%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%8C%E3%83%95%E3%83%AA%E3%83%BC%E3%82%BA%E3%81%97%E3%81%A6%E3%81%97%E3%81%BE%E3%81%86%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FQiang_FSL%22%20target%3D%22_blank%22%3EQiang_FSL%3C%2FA%3E%E2%80%8C%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110254%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AiMX6%20TW686x%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110254%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%A6%AA%E6%84%9B%E3%81%AA%E3%82%8B%E3%80%81Liqiang%3C%2FP%3E%3CP%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FQiang_FSL%22%20target%3D%22_blank%22%3EQiang_FSL%3C%2FA%3E%E2%80%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%83%91%E3%83%83%E3%83%81(%20%3CSTRONG%3ELinux%20L4.1.15_1.1.0-ga.7z%E7%94%A8%E3%81%AETW6865%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FSTRONG%3E)%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82imx6d%E3%83%81%E3%83%83%E3%83%97%E3%81%A8PCIE%20%5C%20TW68x%20%5C%20CVBS%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%92%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AB4%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E9%96%8B%E7%99%BA%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF%E5%B8%B8%E3%81%AB%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A7%E3%83%95%E3%83%AA%E3%83%BC%E3%82%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E--------------%3C%2FP%3E%3CP%3Eif%20(ioctl(m_ifd%2C%20IPU_CHECK_TASK%2C%20%26amp%3Bm_sTask)%20!%3D%20IPU_CHECK_OK)%20%7B%3CBR%20%2F%3Eprintf(%22IPU_CHECK_TASK%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%5Cr%5Cn%22)%3B%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26nbsp%3B-1%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%7D%3C%2FP%3E%3CP%3E-------------%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%AE%E7%90%86%E7%94%B1%E3%82%92%E3%81%94%E5%AD%98%E7%9F%A5%E3%81%A7%E3%81%99%E3%81%8B%3F%E3%81%A9%E3%81%86%E3%82%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110253%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AiMX6%20TW686x%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110253%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%99%E3%81%BF%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81%E5%BF%98%E3%82%8C%E3%81%A6%E3%81%97%E3%81%BE%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E3%80%8C%E3%83%AC%E3%82%A4%E3%83%86%E3%83%B3%E3%82%B7%E3%83%BC%E3%80%8D%E3%81%A8%E3%81%AF%E9%81%85%E5%BB%B6%E3%81%AE%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%81%8B%3F%E3%81%9D%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%AB%E9%81%85%E5%BB%B6%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fdrive.google.com%2Ffile%2Fd%2F0B81cVqIF9a8LY1lEZ0RvOV9JVlk%2Fview%3Fusp%3Dsharing%22%20title%3D%22https%3A%2F%2Fdrive.google.com%2Ffile%2Fd%2F0B81cVqIF9a8LY1lEZ0RvOV9JVlk%2Fview%3Fusp%3Dsharing%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Equirks.c%20-%20Google%E3%83%89%E3%83%A9%E3%82%A4%E3%83%96%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110252%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AiMX6%20TW686x%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110252%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Lei%20Ma%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AE%E5%85%83%E3%81%AE%E4%BD%9C%E8%80%85%E3%81%8B%E3%82%89%E3%80%81imxv4l2videosrc%E3%81%AFcsi%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%A7%E3%81%AE%E3%81%BF%E6%A9%9F%E8%83%BD%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%9F%A5%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%81%AEpci%E3%81%AE%E3%82%82%E3%81%AE%E3%81%A7%E3%81%AF%E9%81%95%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81%E6%AD%A3%E3%81%97%E3%81%84%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%AFv4l2src%E3%81%A7%E3%81%99!%3C%2FP%3E%3CP%3E%E3%81%A8%E3%81%93%E3%82%8D%E3%81%A7%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E5%8D%98%E4%B8%80%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%AFgst-launch-1.0%E3%81%A7%E3%81%86%E3%81%BE%E3%81%8F%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99imxv4l2sink%E3%82%82%3F%E3%83%AC%E3%82%A4%E3%83%86%E3%83%B3%E3%82%B7%E3%83%BC%E3%81%AA%E3%81%97%3F%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AEPCI%20%2F%20Quirks.c%E3%82%82%E8%A6%8B%E3%81%9B%E3%81%A6%E3%82%82%E3%82%89%E3%81%88%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%82%3C%2FP%3E%3CP%3E.........%E3%81%94%E7%A2%BA%E8%AA%8D%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%A2%E3%83%8C%E3%83%A9%E3%83%BC%E3%83%80%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110251%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AiMX6%20TW686x%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110251%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%A7%81%E3%81%AF%E3%81%9D%E3%82%8C%E3%82%92%E7%9F%A5%E3%82%89%E3%81%AA%E3%81%84%E3%80%81%E7%A7%81%E3%81%AE%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AF4.1.15%E3%81%A7%E3%81%99%E3%80%81%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E3%81%93%E3%82%8C%E3%82%892%E3%81%A4%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E5%B0%91%E3%81%97%E7%95%B0%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fdrive.google.com%2Fopen%3Fid%3D0B81cVqIF9a8LTEtTY2FncWRqWTg%22%20title%3D%22https%3A%2F%2Fdrive.google.com%2Fopen%3Fid%3D0B81cVqIF9a8LTEtTY2FncWRqWTg%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Evideobuf-dma-contig.c%20-%20Google%20Drive%3C%2FA%3E%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%3E%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fdrive.google.com%2Fopen%3Fid%3D0B81cVqIF9a8LUTZhU05RZTltbnc%22%20title%3D%22https%3A%2F%2Fdrive.google.com%2Fopen%3Fid%3D0B81cVqIF9a8LUTZhU05RZTltbnc%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Emxc_vpu.c%20-%20Google%E3%83%89%E3%83%A9%E3%82%A4%E3%83%96%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110246%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AiMX6%20TW686x%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110246%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%EF%BC%8C%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%8C%E7%A7%81%E3%81%AE%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E8%A8%AD%E5%AE%9A%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%81%20%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fdrive.google.com%2Fopen%3Fid%3D0B81cVqIF9a8Ld0ttby1lLTIwdEk%22%20title%3D%22https%3A%2F%2Fdrive.google.com%2Fopen%3Fid%3D0B81cVqIF9a8Ld0ttby1lLTIwdEk%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E.config%20-%20Google%E3%83%89%E3%83%A9%E3%82%A4%E3%83%96%3C%2FA%3E%E3%81%A7%E3%81%99%E3%80%81%E7%A7%81%E3%81%AF%E3%81%BE%E3%81%9Fpcie%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%92%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110243%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AiMX6%20TW686x%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110243%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Lei%20Ma%2C%3C%2FP%3E%3CP%3E%E5%A2%83%E7%95%8C%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%A7%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%E7%A7%81%E3%81%AF%E3%81%BE%E3%81%A0%E3%81%93%E3%81%AE%E9%81%85%E5%BB%B6%E3%81%A8%E3%83%95%E3%83%AA%E3%83%BC%E3%82%BA%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E6%8A%B1%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AFtw6865%E3%83%81%E3%83%83%E3%83%97%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%81%AE%E5%9B%9E%E8%B7%AF%E5%9B%B3%E3%81%AB%E5%8E%B3%E5%AF%86%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99!%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110240%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AiMX6%20TW686x%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110240%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3Eimxv4l2src%E3%83%93%E3%83%87%E3%82%AA%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E3%81%BE%E3%81%9A%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%BE%E3%81%9F%E3%81%AFgstreamer%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82nfs%20root%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%82%82%E3%81%84%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%E3%82%82%E3%81%97%E3%81%9D%E3%81%86%E3%81%AA%E3%82%89%E3%80%81%E3%81%93%E3%81%AE%20rootfs%20%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%82%8B%E3%81%A8%E3%81%A8%E3%81%A6%E3%82%82%E4%BE%BF%E5%88%A9%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fdrive.google.com%2Ffile%2Fd%2F0B81cVqIF9a8LampYTFE2NzdzUWc%2Fview%3Fusp%3Dsharing%22%20title%3D%22https%3A%2F%2Fdrive.google.com%2Ffile%2Fd%2F0B81cVqIF9a8LampYTFE2NzdzUWc%2Fview%3Fusp%3Dsharing%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Erootfs.tar.bz2%20-%20Google%E3%83%89%E3%83%A9%E3%82%A4%E3%83%96%3C%2FA%3E%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AF%E7%A7%81%E3%81%AElinux%203.0.5%E7%94%A8%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AF%E7%A7%81%E3%81%AElinux%204.1.15%E3%81%A7%E3%82%82%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E6%B3%A8%E6%84%8F%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E4%BB%98%E3%81%8D%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%23000080%3B%22%3Egst-launch-0.10%20v4l2src%20device%3D%2Fdev%2Fvideo0%20!'video%2Fx-raw-yuv%2C%20format%3D(fourcc)UYVY'%20!mfw_isink%20disp-width%3D512%20disp-height%3D300%20axis-left%3D0%20axis-top%3D0%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%23000080%3B%22%3E%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110238%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AiMX6%20TW686x%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110238%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%A7%81%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AF%E5%A2%83%E7%95%8C%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E5%B1%9E%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3Eyocto%20distro%3A%26nbsp%3B%224.1.15-2.0.1%22%2C%20%22fsl-imx-x11%22%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%9E%E3%83%83%E3%83%97%3A%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%E3%83%A1%E3%83%A2%E3%83%AA%3A698176K%20%2F%201048576K%E3%81%8C%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD(8364K%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%80%81432K%20rwdata%E3%80%813000K%20rodata%E3%80%81432K%20init%E3%80%81450K%20bss%E3%80%8122720K%E4%BA%88%E7%B4%84%E6%B8%88%E3%81%BF%E3%80%81327680K%20cma-%E4%BA%88%E7%B4%84%E6%B8%88%E3%81%BF%E3%80%810K%20highmem)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%5B%200.000000%5D%20%E4%BB%AE%E6%83%B3%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AE%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%3A%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%20%E3%83%99%E3%82%AF%E3%82%BF%E3%83%BC%20%3A%200xffff0000%20-%200xffff1000%20(%204%20kB)%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%20%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%82%B9%E3%83%9E%E3%83%83%E3%83%97%20%3A%200xffc00000%20-%200xfff00000%20(3072%20kB)%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%20vmalloc%20%3A%200xc0800000%20-%200xff000000%20(1000%20MB)%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%20lowmem%20%3A%200x80000000%20-%200xc0000000%20(1024%20MB)%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%20pkmap%20%3A%200x7fe00000%20-%200x80000000%20(%202%E3%83%A1%E3%82%AC%E3%83%90%E3%82%A4%E3%83%88)%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%20%3A%200x7f000000%20-%200x7fe00000%20(%2014%20MB)%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%20.text%20%3A%200x80008000%20-%200x80b215e0%20(11366%20kB)%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%20.init%20%3A%200x80b22000%20-%200x80b8e000%20(%20432%20kB)%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%20.data%20%3A%200x80b8e000%20-%200x80bfa160%20(%20433%20kB)%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%20.bss%20%3A%200x80bfd000%20-%200x80c6d8c0%20(%20451%20kB)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%85%AC%E5%BC%8F%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%81%3CSPAN%3E%E5%A2%83%E7%95%8C%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AEtw686x%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%81quirk.c%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%82%E7%B7%A8%E9%9B%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110237%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AiMX6%20TW686x%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110237%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%AE%E5%AE%9F%E8%A1%8C%E4%B8%AD%E3%81%AB%E3%80%8C%E4%BA%88%E6%9C%9F%E3%81%97%E3%81%AA%E3%81%84p-b%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%80%8D%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E8%A6%9A%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%82%8C%E3%81%AFBoundary%20Devices%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE1%E3%81%A4%E3%81%A7%E5%AE%9F%E9%A8%93%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%A9%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A8%E3%83%87%E3%82%A3%E3%82%B9%E3%83%88%E3%83%AA%E3%83%93%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%AD%E3%82%B0%E3%81%AB%E7%8F%BE%E5%9C%A8%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%9E%E3%83%83%E3%83%97%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%82%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3Ei.e%20%3A-%26nbsp%3B%3C%2FP%3E%3CDIV%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3E%E3%83%A1%E3%83%A2%E3%83%AA%3A3551600K%20%2F%203932156K%E3%81%8C%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD(8196K%20%3CSPAN%20class%3D%22%22%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%3C%2FSPAN%3E%20%E3%82%B3%E3%83%BC%E3%83%89%E3%80%81314K%20rwdata%E3%80%812448K%20rodata%E3%80%811024K%20init%E3%80%81444K%20bss%E3%80%8152876K%E4%BA%88%E7%B4%84%E6%B8%88%E3%81%BF%E3%80%81327680K%20cma-%E4%BA%88%E7%B4%84%E6%B8%88%E3%81%BF%E3%80%812260988K%E9%AB%98%E8%A8%98%E6%86%B6)%3C%2FDIV%3E%3CDIV%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3E%E4%BB%AE%E6%83%B3%20%3CSPAN%20class%3D%22%22%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%3C%2FSPAN%3E%20%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AE%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%3A%3C%2FDIV%3E%3CDIV%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3E%E3%83%99%E3%82%AF%E3%82%BF%E3%83%BC%20%3A%200xffff0000%20-%200xffff1000%20(%204%20kB)%3C%2FDIV%3E%3CDIV%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3E%26nbsp%3B%20%26nbsp%3B%20fixmap%20%26nbsp%3B%3A%200xffc00000%20-%200xfff00000%20%26nbsp%3B%20(3072%20kB)%3C%2FDIV%3E%3CDIV%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3E%26nbsp%3B%20%26nbsp%3B%20vmalloc%20%3A%200xe6800000%20-%200xff000000%20%26nbsp%3B%20(%20392%20MB)%3C%2FDIV%3E%3CDIV%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3E%26nbsp%3B%20%26nbsp%3B%20lowmem%20%26nbsp%3B%3A%200x80000000%20-%200xe6000000%20%26nbsp%3B%20(1632%20MB)%3C%2FDIV%3E%3CDIV%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3E%26nbsp%3B%20%26nbsp%3B%20pkmap%20%26nbsp%3B%20%3A%200x7fe00000%20-%200x80000000%20%26nbsp%3B%20(%20%26nbsp%3B%202%20MB)%3C%2FDIV%3E%3CDIV%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3E%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%20%3A%200x7f000000%20-%200x7fe00000%20(%2014%20MB)%3C%2FDIV%3E%3CDIV%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20.text%20%3A%200x80008000%20-%200x80b650ac%20%26nbsp%3B%20(11637%20kB)%3C%2FDIV%3E%3CDIV%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3E.init%3A%200x80c00000%20-%200x80d00000%20(1024%20kB)%3C%2FDIV%3E%3CDIV%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3E%E3%80%82%E3%83%87%E3%83%BC%E3%82%BF%3A%200x80d00000%20-%200x80d4ea40%20(%20315%20kB)%3C%2FDIV%3E%3CDIV%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B.bss%20%3A%200x80d51000%20-%200x80dc0320%20%26nbsp%3B%20(%20445%20kB)%3C%2FDIV%3E%3CDIV%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3E%20%3C%2FDIV%3E%3CP%3EBR%3C%2FP%3E%3CP%3E%E3%82%A2%E3%83%8C%E3%83%A9%E3%83%BC%E3%83%80%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110232%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AiMX6%20TW686x%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110232%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3Etw686x%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81gst-lanuch-1.0%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81%E7%A7%81%E3%81%AF%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3CSTRONG%3E%22gst-launch-1.0%20imxv4l2src%20device%3D%2Fdev%2Fvideo2%22%20%E3%80%81%E5%87%BA%E5%8A%9B%3A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%3D%3D%3D%3D%3D%3D%20IMXV4L2SRC%3A4.1.4%202017%E5%B9%B41%E6%9C%8831%E6%97%A520%3A15%3A40%E3%81%AB%E3%83%93%E3%83%AB%E3%83%89%E3%80%82%3D%3D%3D%3D%3D%3D%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%92%E4%B8%80%E6%99%82%E5%81%9C%E6%AD%A2%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AF%E7%A8%BC%E5%83%8D%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81PREROLL%E3%81%AF%E5%BF%85%E8%A6%81%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93...%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E(gst-launch-1.0%3A990)%3AGStreamer-CRITICAL%20**%3Agst_mini_object_ref%3A%E3%82%A2%E3%82%B5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20'mini_object%20!%3D%20NULL'%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E**%20(GST-%E3%83%AD%E3%83%BC%E3%83%B3%E3%83%81-1.0%3A990)%3A%E9%87%8D%E5%A4%A7%20**%3A%20gst_video_info_from_caps%3A%20%E3%82%A2%E3%82%B5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20'caps%20!%3D%20NULL'%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E(gst-launch-1.0%3A990)%3AGStreamer-CRITICAL%20**%3Agst_caps_get_structure%3A%E3%82%A2%E3%82%B5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%80%8CGST_IS_CAPS%EF%BC%88%E5%A4%A7%E6%96%87%E5%AD%97%EF%BC%89%E3%80%8D%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E**(gst-launch-1.0%3A990)%3A%E3%82%AF%E3%83%AA%E3%83%86%E3%82%A3%E3%82%AB%E3%83%AB**%3Agst_video_info_from_caps%3A%E3%82%A2%E3%82%B5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20'caps%20!%3D%20NULL'%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%E8%A6%81%E7%B4%A0%2F%20GstPipeline%3Apipeline0%20%2F%20GstImxV4l2Src%3Aimxv4l2src0%E3%81%8B%E3%82%89%3A%E5%86%85%E9%83%A8%E3%83%87%E3%83%BC%E3%82%BF%E3%83%95%E3%83%AD%E3%83%BC%E3%82%A8%E3%83%A9%E3%83%BC%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%E8%BF%BD%E5%8A%A0%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E6%83%85%E5%A0%B1%3A%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E..%2F..%2F..%2F..%2Fgstreamer-1.8.1%2Flibs%2Fgst%2Fbase%2Fgstbasesrc.c(2948)%3Agst_base_src_loop()%3A%2FGstPipeline%3Apipeline0%2FGstImxV4l2Src%3Aimxv4l2src0%3A%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%9F%E3%83%B3%E3%82%B0%20%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%8C%E4%B8%80%E6%99%82%E5%81%9C%E6%AD%A2%E3%81%97%E3%80%81%E7%90%86%E7%94%B1%E3%81%8C%E3%83%8D%E3%82%B4%E3%82%B7%E3%82%A8%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%20(-4)%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AF%E3%83%97%E3%83%AA%E3%83%AD%E3%83%BC%E3%83%AB%E3%82%92%E6%9C%9B%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%92%E4%B8%80%E6%99%82%E5%81%9C%E6%AD%A2%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%92%20READY%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%92%20NULL%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20...%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%92%E8%A7%A3%E6%94%BE%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%22dmesg%22%20outputs%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%E3%82%A8%E3%83%A9%E3%83%BC%3Av4l2%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%3A%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93!%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%80%8Cimxv4l2videosrc%E3%80%8D%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%87%BA%E5%8A%9B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3A%20%E8%A6%81%E7%B4%A0%20%22imxv4l2videosrc%22%20%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%EF%BC%9A%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3Egst-launch-1.0%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%201.8.1%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3EGStreamer%201.8.1%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3EL3.0.5%20%E3%81%AB%E5%8F%A4%E3%81%84%20rootfs%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%81%E4%B8%8A%E8%A8%98%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%81%AE%E3%81%A8%E5%90%8C%E3%81%98%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%204.1.15%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E5%87%BA%E5%8A%9B%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3Egst-launch%20v4l2src%20device%3D%2Fdev%2Fvideo0%20!'video%2Fx-raw-yuv%2C%20format%3D(fourcc)UYVY'%20!mfw_isink%20disp-width%3D512%20disp-height%3D300%20axis-left%3D0%20axis-top%3D0%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3Egst-launch%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3Egst-launch-0.10%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%200.10.35%3CBR%20%2F%3EGStreamer%200.10.35%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110231%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AiMX6%20TW686x%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110231%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHI%E3%80%82%3C%2FP%3E%3CP%3EAndroid4.4.2%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%E3%80%81%E3%81%9D%E3%82%8C%E3%81%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%AA%E3%82%89%E3%80%81%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110230%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AiMX6%20TW686x%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110230%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Lei%20Ma%2C%3C%2FP%3E%3CP%3Edmesg%20%E3%82%92%E8%A9%A6%E3%81%99%20%7Cgrep%20tw68%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%80%81DMA%20%E3%83%A1%E3%83%A2%E3%83%AA%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%A8%E3%83%A9%E3%83%BC%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%80%8C%E3%81%AF%E3%81%84%E3%80%8D%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%A8%E3%81%97%E3%81%A6%20coherent_pool%20%3D%20128M%20(%E3%81%BE%E3%81%9F%E3%81%AF%E9%81%A9%E5%88%87%E3%81%AA%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%B5%E3%82%A4%E3%82%BA)%20%E3%82%92%E6%B8%A1%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81uboot%20%E3%81%BE%E3%81%9F%E3%81%AF%206x_bootscript%20%E3%81%AE%20setenv%20bootargs%20%3D%20%22%20%3CSPAN%3E%24%7Bbootargs%7Dcoherent_pool%20%3D%20128M%22%20%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%8C%E3%83%A1%E3%83%A2%E3%83%AA%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%81%AB%E3%81%82%E3%81%A3%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81%E3%83%93%E3%83%87%E3%82%AA%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C%E5%88%97%E6%8C%99%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%83%A1%E3%82%A4%E3%83%B3%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AEtw686x%20linux%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AF%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%82%B1%E3%83%BC%E3%82%B9%E3%81%A7%E6%A9%9F%E8%83%BD%E3%81%99%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99!%3C%2FSPAN%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ERgs%E3%81%AE%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%82%A2%E3%83%8C%E3%83%A9%E3%83%BC%E3%83%80%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110229%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AiMX6%20TW686x%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110229%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%8A%E8%BF%94%E4%BA%8B%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99!%3C%2FP%3E%3CP%3E%E3%80%8Ctw68-core.c%E3%80%8D%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%8Ctw68-video.c%E3%80%8D...Linux%204.1.15%20%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%BD%E3%83%BC%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%80%81%E7%A7%81%E3%81%AF%E5%BD%BC%E3%82%89%E3%81%8Ctw6865%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E5%83%8D%E3%81%84%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81%E7%A7%81%E3%81%AF%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%A7tw68%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81tw6865%E3%81%AB%E5%AF%BE%E5%BF%9C%E3%81%99%E3%82%8B%2F%20dev%20%2F%20videoX%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%A0%E3%81%8B%E3%82%89%E7%A7%81%E3%81%AF%E3%81%93%E3%82%8C%E3%81%8Ctw6865%E3%81%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%81Linux%204.1.15%20%E3%82%BD%E3%83%BC%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%81%AE%3C%2FSPAN%3E%20%22%2Fdrivers%2Fmedia%2Fpci%2Ftw68%2F%22%20%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E--------------------------------------------------%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3Etw68%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AE%E4%BD%9C%E8%80%85%E3%81%AB%E5%B0%8B%E3%81%AD%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81tw6865%E7%94%A8%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3ETw6865%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AF%E3%81%93%E3%81%93%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fgithub.com%2Fsasamy%2Ftw6869%22%20title%3D%22https%3A%2F%2Fgithub.com%2Fsasamy%2Ftw6869%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EGitHub%20-%20sasamy%2Ftw6869%3A%20tw6869%2F65%20%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3C%2FA%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110224%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AiMX6%20TW686x%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110224%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%A6%AA%E6%84%9B%E3%81%AA%E3%82%8B%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FJiangJustin%22%20target%3D%22_blank%22%3E%E3%82%B8%E3%83%A3%E3%83%B3%E3%82%B8%E3%83%A3%E3%82%B9%E3%83%86%E3%82%A3%E3%83%B3%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EIntersil%20TW6865%E3%83%81%E3%83%83%E3%83%97(Freescale%20TW6865%20miniPCIe%20Daughter%20Board%E3%81%A8%E5%90%8C%E3%81%98)%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81PCIe%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6iMAX6Q%20Sabre%20Lite%E9%96%8B%E7%99%BA%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB2%E5%8F%B0%E3%81%AE%E3%82%A2%E3%83%8A%E3%83%AD%E3%82%B0%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%92%E5%85%A5%E5%8A%9B%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%AB%E3%83%A1%E3%83%A9%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E9%96%8B%E7%99%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E6%AC%A1%E3%81%AE%E7%82%B9%E3%82%92%E6%98%8E%E7%A2%BA%E3%81%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%26gt%3B%26gt%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EiMAX6Q%20Sabre%20Lite%20for%20PCIe%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AB%E3%81%AF%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE7%E3%83%94%E3%83%B3%E6%8E%A5%E7%B6%9A%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%2B3.3V%E3%80%81PCIE_RXM%E3%80%81PCIE_RXP%E3%80%81PCIE_TXM%E3%80%81PCIE_TXP%E3%80%81GND%E3%80%81GND%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20220px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F2825i7095A79C98737FBA%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EIntersil%20TW6865%E3%83%81%E3%83%83%E3%83%97%E3%81%AF%E3%80%81%E5%B7%AE%E5%8B%95%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%83%BB%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E5%85%A5%E5%8A%9B%E7%94%A8%E3%81%AEREFCLK-%E3%80%81REFCLK%2B%E3%83%94%E3%83%B3%E6%8E%A5%E7%B6%9A%E3%82%92%E5%82%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_5.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_5.png%22%20style%3D%22width%3A%20395px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F2860i444D114E1763B679%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_5.png%22%20alt%3D%22pastedImage_5.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3EPCIe%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%A8%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%97%E3%81%9F%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81%E3%81%93%E3%81%AE%E3%83%94%E3%83%B3%E3%82%92iMAX6Q%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A8%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3EPeter%20Amond.imx6_pcie_msi_handler%3C%2FP%3E%3CP%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110221%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AiMX6%20TW686x%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110221%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%A6%AA%E6%84%9B%E3%81%AA%E3%82%8B%20%3CA%20_jive_internal%3D%22true%22%20data-content-finding%3D%22Community%22%20data-userid%3D%22203567%22%20data-username%3D%22JiangJustin%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FJiangJustin%22%20style%3D%22font-weight%3A%20600%3B%20font-size%3A%2011.9994010925293px%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%238ca9cd%3B%22%20target%3D%22_blank%22%3EQingrong%20Jiang%3C%2FA%3E%3A%3C%2FP%3E%3CP%3EHi%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E6%96%B9%E6%B3%95%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6v4l2%20capture.c%E3%81%A7%E7%94%BB%E5%83%8F%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E5%8F%96%E5%BE%97%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%81%93%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E4%BC%9A%E3%81%84%E3%81%BE%E3%81%99%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22tw.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22tw.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F59796i38955AE3EC02F138%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22tw.png%22%20alt%3D%22tw.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fbbs.21ic.com%2Ficview-1205710-1-2.html%22%20title%3D%22http%3A%2F%2Fbbs.21ic.com%2Ficview-1205710-1-2.html%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ei.MX6Q%20%2BPCIE%2BTW68%20%E9%A9%B1%E5%8A%A8%E6%98%BE%E7%A4%BA%E7%AD%89%E9%97%AE%E9%A2%98-%E6%81%A9%E6%99%BA%E6%B5%A6MCU%E8%AE%BA%E5%9D%9B%E8%AE%BA%E5%9D%9B%20-%2021ic%E7%94%B5%E5%AD%90%E6%8A%80%E6%9C%AF%E8%AE%BA%E5%9D%9B%3C%2FA%3E%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110220%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AiMX6%20TW686x%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110220%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%20Qingrong%20Jiang!%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E9%9F%93%E5%9B%BD%E3%81%AENXP%E3%83%87%E3%82%A3%E3%82%B9%E3%83%88%E3%83%AA%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%AE1%E3%81%A4%E3%81%A7%E3%81%82%E3%82%8BSTC%E3%81%AEFAE%E3%81%A7%E3%81%99%E3%80%82%20%3CBR%20%2F%3ETW6865%E3%83%86%E3%82%B9%E3%83%88%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E8%A3%BD%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81MX6Q-SABRESDP%20%E3%81%A7%20HDMI%20%E3%81%A7%204ch%20%E3%81%AE%E7%94%BB%E5%83%8F%E3%82%92%E8%A6%8B%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%AE%E5%89%8D%E3%81%A7%E6%89%8B%E3%82%92%E9%80%9F%E3%81%8F%E5%8B%95%E3%81%8B%E3%81%99%E3%81%A8%E6%AE%8B%E5%83%8F%E3%81%8C%E8%A6%8B%E3%81%88%E3%81%A6%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82(%E6%B7%BB%E4%BB%98%E3%81%AE%E5%8B%95%E7%94%BB%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E(BSP%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3AL3.0.35_4.1.0)%3CBR%20%2F%3E%E7%A7%81%E3%81%AFintersil%20FAE%E3%81%AB%E4%BC%9A%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E5%BD%BC%E3%81%AF%E3%81%9D%E3%82%8C%E3%81%8C%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%AC%E3%83%BC%E3%82%B9%E8%A7%A3%E9%99%A4%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%A7%E3%81%82%E3%82%8B%E3%81%A8%E8%A8%80%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%20%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%82%AC%E3%82%A4%E3%83%89%E3%82%84%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SVM.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SVM.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F59691i79D40C74EF3D8096%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22SVM.jpg%22%20alt%3D%22SVM.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110218%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AiMX6%20TW686x%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110218%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%EF%BC%8C%3C%2FP%3E%3CP%3E%E3%83%AC%E3%83%B3%E3%82%BA%E3%81%A7%E6%92%AE%E5%BD%B1%E3%81%97%E3%81%9F%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AE%E4%BF%9D%E5%AD%98%E6%96%B9%E6%B3%95%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%81%84%E3%81%A3%E3%81%A6%E3%82%89%E3%81%A3%E3%81%97%E3%82%83%E3%81%84%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110217%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AiMX6%20TW686x%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110217%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF~%E8%A6%AA%E6%84%9B%E3%81%AA%E3%82%8B%E6%A7%98%3C%2FP%3E%3CP%3E%E4%BB%8A%E3%80%81%E7%A7%81%E3%81%AFIMX6%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%E3%81%A7%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AB%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E8%A8%98%E9%8C%B2%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AEApplitcatin%E3%81%AFmxc_v4l2_tvin.out%E3%81%A7%E3%81%99%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%3CSPAN%20style%3D%22color%3A%20%23444444%3B%20font-family%3A%20Tahoma%2C%20'Microsoft%20Yahei'%2C%20Simsun%3B%20background-color%3A%20%23eff5f9%3B%22%3E%E3%80%81V4L2_MEMORY_USERPTR%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%93%E3%83%87%E3%82%AA%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%E3%82%92%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%3C%2FSPAN%3E%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%9A%E3%80%81%E3%80%8C%3CSPAN%20style%3D%22background-color%3A%20%23eff5f9%3B%20color%3A%20%23444444%3B%20font-size%3A%2012px%3B%20font-family%3A%20Tahoma%2C%20'Microsoft%20Yahei'%2C%20Simsun%3B%20line-height%3A%201.5%3B%22%3EUSERPTR%E3%81%AF%E7%8F%BE%E5%9C%A8%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82buffer_prepare%20OOPS%E3%80%8D%E3%81%A8%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%88%E3%81%8F%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AF%E7%87%83%E3%81%88%E5%B0%BD%E3%81%8D%E3%81%A6%E3%81%97%E3%81%BE%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%3CSPAN%20style%3D%22color%3A%20%23444444%3B%20font-family%3A%20Tahoma%2C%20'Microsoft%20Yahei'%2C%20Simsun%3B%20background-color%3A%20%23eff5f9%3B%22%3E%E3%80%81V4L2_MEMORY_MMAPED%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E9%80%9A%E5%B8%B8%E3%81%AF%E3%83%93%E3%83%87%E3%82%AA%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%E3%82%92%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23eff5f9%3B%20color%3A%20%23444444%3B%20font-size%3A%2012px%3B%20font-family%3A%20Tahoma%2C%20'Microsoft%20Yahei'%2C%20Simsun%3B%20line-height%3A%201.5%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23eff5f9%3B%20color%3A%20%23444444%3B%20font-size%3A%2012px%3B%20font-family%3A%20Tahoma%2C%20'Microsoft%20Yahei'%2C%20Simsun%3B%20line-height%3A%201.5%3B%22%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20sans-serif%3B%22%3EHDMI(%E9%AB%98%E7%B2%BE%E7%B4%B0%E5%BA%A6%E3%83%9E%E3%83%AB%E3%83%81%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20sans-serif%3B%22%3E.%2Fmxc_v4l2_tvin.out%20-x%200%20-ot%200%20-ol%200%20-ow%20960%20-OH%20540%20-m%202%20%26amp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20sans-serif%3B%22%3E.%2Fmxc_v4l2_tvin.out%20-x%201%20-ot%200%20-ol%20960%20-ow%20960%20-OH%20540%20-m%202%20%26amp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20sans-serif%3B%22%3E.%2Fmxc_v4l2_tvin.out%20-x%202%20-ot%20540%20-ol%200%20-ow%20960%20-OH%20540%20-m%202%20%26amp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20sans-serif%3B%22%3E.%2Fmxc_v4l2_tvin.out%20-x%203%20-ot%20540%20-ol%20960%20-ow%20960%20-OH%20540%20-m%202%20%26amp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%3AIMX6Q-SABRESED%20%2B%20PCIE%20%2B%20TW6865%3C%2FP%3E%3CP%3ELTIB%3A%20L3.0.35_4.1.0_130816_source.tar.gz%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110216%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AiMX6%20TW686x%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110216%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%EF%BC%81%40%3C%2FP%3E%3CP%3E%E7%A7%81%E3%82%82%E5%90%8C%E3%81%98%E3%81%93%E3%81%A8%E3%82%92%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99!%E7%A7%81%E3%81%AFtw6865%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%8B%E3%82%89%E7%94%BB%E5%83%8F%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%82%AD%E3%83%A3%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E8%A7%A3%E5%83%8F%E5%BA%A6%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%81%8C%E7%A7%81%E3%82%92%E6%B7%B7%E4%B9%B1%E3%81%95%E3%81%9B%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AFV4L2%20lib%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%3CSTRONG%3E720%20*%20576%E3%81%A7%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%85%A8%E4%BD%93%E5%83%8F%E3%81%8C%E5%BE%97%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20151113_180740.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20151113_180740.jpg%22%20style%3D%22width%3A%20749px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F29787i44548654668FDCBD%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22IMG_20151113_180740.jpg%22%20alt%3D%22IMG_20151113_180740.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E360%20*%20288%2C640%20*%20480%E3%82%84320%20*%20240%E3%81%AA%E3%81%A9%E3%81%AE%E4%BB%96%E3%81%AE%E8%A7%A3%E5%83%8F%E5%BA%A6%E3%81%A7%E6%A7%8B%E6%88%90%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E4%B8%8D%E5%AE%8C%E5%85%A8%E3%81%AA%E7%94%BB%E5%83%8F%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20151113_175032.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20151113_175032.jpg%22%20style%3D%22width%3A%20749px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F29788i90A261F52B069AD4%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22IMG_20151113_175032.jpg%22%20alt%3D%22IMG_20151113_175032.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%AE%9A%E7%BE%A9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E8%A7%A3%E5%83%8F%E5%BA%A6%E3%82%92%E5%AE%9A%E7%BE%A9%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E%23define%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E%E7%94%BB%E5%83%8F%E3%81%AE%E5%B9%85%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E720%3C%2FSPAN%3E%E5%90%8D%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E%23define%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3EIMAGEHEIGHT%3C%2FSPAN%3E%20%E3%81%A7%E3%81%99%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E576%3C%2FSPAN%3E%E5%90%8D%3C%2FPRE%3E%3CP%3E%E8%A8%AD%E5%AE%9A%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E6%AC%A1%E3%81%AB%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3Eint%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800080%3B%22%3ECamera_type%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3A%3A%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3Einit_v4l2%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E()%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3Eif((%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AB%E3%83%A1%E3%83%A9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%20%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%20fd%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%20%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%20open(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AB%E3%83%A1%E3%83%A9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%20%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3Edevice_add%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E%20O_RDWR%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%20%7C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E%20O_NONBLOCK%2C0))%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%20-%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E%201)%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3Eprintf(%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%20V4L%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%20%E3%82%92%E9%96%8B%E3%81%8F%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%20%E3%81%A8%E3%81%8D%E3%81%AB%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20%5Cn%22)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3E%E6%88%BB%E3%82%8A%E5%80%A4%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3Efalse%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%E3%82%AF%E3%82%A8%E3%83%AA%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%E3%81%AE%E4%B8%8A%E9%99%90%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3Eif%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3Eioctl%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3EFD%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%81%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3EVIDIOC_QUERYCAP%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%81%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AB%E3%83%A1%E3%83%A9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecap%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E-%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E1%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%2F*%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%E8%8E%B7%E5%8F%96%E8%AE%BE%E5%A4%87%E6%94%AF%E6%8C%81%E7%9A%84%E6%93%8D%E4%BD%9C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E*%2F%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3Eprintf(%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%20%25s%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%E3%82%92%E9%96%8B%E3%81%8F%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%20%E3%81%A8%E3%81%8D%E3%81%AB%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E3%82%AF%E3%82%A8%E3%83%AA%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%20%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%20%E3%80%82%5Cn%22%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%20camera.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3Edevice_add)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3E%E6%88%BB%E3%82%8A%E5%80%A4%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3Efalse%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3Eelse%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22driver%3A%5Ct%5Ct%25s%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AB%E3%83%A1%E3%83%A9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AD%E3%83%A3%E3%83%83%E3%83%97%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22%E3%82%AB%E3%83%BC%E3%83%89%3A%5Ct%5Ct%25s%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AB%E3%83%A1%E3%83%A9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AD%E3%83%A3%E3%83%83%E3%83%97%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AB%E3%83%BC%E3%83%89%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22bus_info%3A%5Ct%25s%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AB%E3%83%A1%E3%83%A9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AD%E3%83%A3%E3%83%83%E3%83%97%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ebus_info%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%5Ct%25d%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AB%E3%83%A1%E3%83%A9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AD%E3%83%A3%E3%83%83%E3%83%97%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22capabilities%3A%5Ct%25x%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AB%E3%83%A1%E3%83%A9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AD%E3%83%A3%E3%83%83%E3%83%97%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E6%A9%9F%E8%83%BD%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3Eif%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E((%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AB%E3%83%A1%E3%83%A9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AD%E3%83%A3%E3%83%83%E3%83%97%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E8%83%BD%E5%8A%9B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3EV4L2_CAP_VIDEO_CAPTURE%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3EV4L2_CAP_VIDEO_CAPTURE%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%25s%3A%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%20%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%E3%80%82%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Edevice_add%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3Eif%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E((%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AB%E3%83%A1%E3%83%A9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AD%E3%83%A3%E3%83%83%E3%83%97%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecapabilities%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3EV4L2_CAP_STREAMING%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3EV4L2_CAP_STREAMING%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%25s%3A%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%20%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%9F%E3%83%B3%E3%82%B0%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%E3%80%82%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AB%E3%83%A1%E3%83%A9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Edevice_add%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3EEMU%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%20%E3%81%AF%E3%81%99%E3%81%B9%E3%81%A6%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%20FMT%20%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmtdesc%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Eindex%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E0%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AB%E3%83%A1%E3%83%A9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmtdesc%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%BF%E3%82%A4%E3%83%97%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800080%3B%22%3EV4L2_BUF_TYPE_VIDEO_CAPTURE%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%E5%BD%A2%E5%BC%8F%3A%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3Ewhile%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3Eioctl%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AB%E3%83%A1%E3%83%A9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efd%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%81%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3EVIDIOC_ENUM_FMT%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%81%26amp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmtdesc%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)!%3D-%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E1%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%2F*%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%E8%8E%B7%E5%8F%96%E8%AE%BE%E7%BD%AE%E6%94%AF%E6%8C%81%E7%9A%84%E8%A7%86%E9%A2%91%E6%A0%BC%E5%BC%8F%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E*%2F%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22%5Ct%25d.%25s%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AB%E3%83%A1%E3%83%A9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmtdesc%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E1%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%81%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AB%E3%83%A1%E3%83%A9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmtdesc%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E8%AA%AC%E6%98%8E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmtdesc%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Eindex%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2B%2B%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%2F%2Fset%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3Efmt%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AB%E3%83%A1%E3%83%A9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%BF%E3%82%A4%E3%83%97%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800080%3B%22%3EV4L2_BUF_TYPE_VIDEO_CAPTURE%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Epix%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Epixelformat%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3EV4L2_PIX_FMT_YUYV%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AB%E3%83%A1%E3%83%A9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Epix%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E9%AB%98%E3%81%95%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3EIMAGEHEIGHT%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AB%E3%83%A1%E3%83%A9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Epix%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E5%B9%85%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E%E7%94%BB%E5%83%8F%E5%B9%85%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AB%E3%83%A1%E3%83%A9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Epix%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%83%95%E3%82%A3%E3%83%BC%E3%83%AB%E3%83%89%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800080%3B%22%3EV4L2_FIELD_INTERLACED%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3Eif%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3Eioctl%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AB%E3%83%A1%E3%83%A9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3EFD%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%81%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3EVIDIOC_S_FMT%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%81%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%81%8A%E3%82%88%E3%81%B3%E3%82%AB%E3%83%A1%E3%83%A9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E-%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E1%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%2F*%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%E8%AE%BE%E7%BD%AE%E6%8D%95%E8%8E%B7%E8%A7%86%E9%A2%91%E7%9A%84%E6%A0%BC%E5%BC%8F%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E*%2F%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3Eprintf(%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%20%E3%82%92%20%E8%A8%AD%E5%AE%9A%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%20%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%20%5Cn%22)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3Efalse%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3Eif%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3Eioctl%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AB%E3%83%A1%E3%83%A9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3EFD%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%81%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3EVIDIOC_G_FMT%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%81%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%81%8A%E3%82%88%E3%81%B3%E3%82%AB%E3%83%A1%E3%83%A9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E-%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E1%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%2F*%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%E8%8E%B7%E5%8F%96%E8%AE%BE%E7%BD%AE%E7%9A%84%E8%A7%86%E9%A2%91%E6%A0%BC%E5%BC%8F%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E*%2F%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3Eprintf(%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%20%E3%82%92%E5%8F%96%E5%BE%97%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%20%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%20%5Cn%22)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3Efalse%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22fmt.type%3A%5Ct%5Ct%25d%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AB%E3%83%A1%E3%83%A9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%BF%E3%82%A4%E3%83%97%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22pix.pixelformat%3A%5Ct%25c%25c%25c%25c%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AB%E3%83%A1%E3%83%A9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Epix%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Epixelformat%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E0xFF%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AB%E3%83%A1%E3%83%A9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Epix%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%26gt%3B%26gt%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E8%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E0xFF%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AB%E3%83%A1%E3%83%A9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Epix%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3EPixelFormat%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%26gt%3B%26gt%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E16%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E0xFF%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AB%E3%83%A1%E3%83%A9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Epix%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%26gt%3B%26gt%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E24%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E0xFF%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22pix.height%3A%5Ct%5Ct%25d%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AB%E3%83%A1%E3%83%A9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Epix%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E8%BA%AB%E9%95%B7%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22pix.width%3A%5Ct%5Ct%25d%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AB%E3%83%A1%E3%83%A9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Epix%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E5%B9%85%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22pix.field%3A%5Ct%5Ct%25d%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AB%E3%83%A1%E3%83%A9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Epix%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%83%95%E3%82%A3%E3%83%BC%E3%83%AB%E3%83%89%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3EFPS%20%E3%81%AE%E8%A8%AD%E5%AE%9A%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22%E5%88%9D%E6%9C%9F%E5%8C%96%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%25s%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%5Ct%5BOK%5D%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AB%E3%83%A1%E3%83%A9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Edevice_add%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3Etrue%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FPRE%3E%3CP%3E%E3%81%A9%E3%81%93%E3%81%8C%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%8B%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110215%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AiMX6%20TW686x%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110215%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%A7%81%E3%82%82%E5%90%8C%E3%81%98%E3%81%93%E3%81%A8%E3%82%92%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99!%E7%A7%81%E3%81%AFtw6865%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%8B%E3%82%89%E7%94%BB%E5%83%8F%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%82%AD%E3%83%A3%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E8%A7%A3%E5%83%8F%E5%BA%A6%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%81%8C%E7%A7%81%E3%82%92%E6%B7%B7%E4%B9%B1%E3%81%95%E3%81%9B%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AFV4L2%20lib%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%3CSTRONG%3E720%20*%20576%E3%81%A7%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%85%A8%E4%BD%93%E5%83%8F%E3%81%8C%E5%BE%97%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20151113_180740.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20151113_180740.jpg%22%20style%3D%22width%3A%20749px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F29787i44548654668FDCBD%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22IMG_20151113_180740.jpg%22%20alt%3D%22IMG_20151113_180740.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E360%20*%20288%2C640%20*%20480%E3%82%84320%20*%20240%E3%81%AA%E3%81%A9%E3%81%AE%E4%BB%96%E3%81%AE%E8%A7%A3%E5%83%8F%E5%BA%A6%E3%81%A7%E6%A7%8B%E6%88%90%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E4%B8%8D%E5%AE%8C%E5%85%A8%E3%81%AA%E7%94%BB%E5%83%8F%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20151113_175032.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20151113_175032.jpg%22%20style%3D%22width%3A%20749px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F29788i90A261F52B069AD4%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22IMG_20151113_175032.jpg%22%20alt%3D%22IMG_20151113_175032.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%AE%9A%E7%BE%A9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E8%A7%A3%E5%83%8F%E5%BA%A6%E3%82%92%E5%AE%9A%E7%BE%A9%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E%23define%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E%E7%94%BB%E5%83%8F%E3%81%AE%E5%B9%85%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E720%3C%2FSPAN%3E%E5%90%8D%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E%23define%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3EIMAGEHEIGHT%3C%2FSPAN%3E%20%E3%81%A7%E3%81%99%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E576%3C%2FSPAN%3E%E5%90%8D%3C%2FPRE%3E%3CP%3E%E8%A8%AD%E5%AE%9A%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E6%AC%A1%E3%81%AB%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3Eint%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800080%3B%22%3ECamera_type%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3A%3A%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3Einit_v4l2%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E()%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3Eif((%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AB%E3%83%A1%E3%83%A9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%20%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%20fd%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%20%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%20open(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AB%E3%83%A1%E3%83%A9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%20%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3Edevice_add%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E%20O_RDWR%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%20%7C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E%20O_NONBLOCK%2C0))%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%20-%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E%201)%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3Eprintf(%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%20V4L%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%20%E3%82%92%E9%96%8B%E3%81%8F%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%20%E3%81%A8%E3%81%8D%E3%81%AB%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20%5Cn%22)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3E%E6%88%BB%E3%82%8A%E5%80%A4%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3Efalse%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%E3%82%AF%E3%82%A8%E3%83%AA%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%E3%81%AE%E4%B8%8A%E9%99%90%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3Eif%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3Eioctl%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3EFD%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%81%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3EVIDIOC_QUERYCAP%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%81%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AB%E3%83%A1%E3%83%A9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecap%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E-%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E1%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%2F*%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%E8%8E%B7%E5%8F%96%E8%AE%BE%E5%A4%87%E6%94%AF%E6%8C%81%E7%9A%84%E6%93%8D%E4%BD%9C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E*%2F%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3Eprintf(%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%20%25s%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%E3%82%92%E9%96%8B%E3%81%8F%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%20%E3%81%A8%E3%81%8D%E3%81%AB%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E3%82%AF%E3%82%A8%E3%83%AA%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%20%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%20%E3%80%82%5Cn%22%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%20camera.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3Edevice_add)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3E%E6%88%BB%E3%82%8A%E5%80%A4%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3Efalse%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3Eelse%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22driver%3A%5Ct%5Ct%25s%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AB%E3%83%A1%E3%83%A9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AD%E3%83%A3%E3%83%83%E3%83%97%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22%E3%82%AB%E3%83%BC%E3%83%89%3A%5Ct%5Ct%25s%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AB%E3%83%A1%E3%83%A9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AD%E3%83%A3%E3%83%83%E3%83%97%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AB%E3%83%BC%E3%83%89%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22bus_info%3A%5Ct%25s%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AB%E3%83%A1%E3%83%A9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AD%E3%83%A3%E3%83%83%E3%83%97%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ebus_info%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%5Ct%25d%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AB%E3%83%A1%E3%83%A9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AD%E3%83%A3%E3%83%83%E3%83%97%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22capabilities%3A%5Ct%25x%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AB%E3%83%A1%E3%83%A9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AD%E3%83%A3%E3%83%83%E3%83%97%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E6%A9%9F%E8%83%BD%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3Eif%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E((%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AB%E3%83%A1%E3%83%A9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AD%E3%83%A3%E3%83%83%E3%83%97%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E8%83%BD%E5%8A%9B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3EV4L2_CAP_VIDEO_CAPTURE%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3EV4L2_CAP_VIDEO_CAPTURE%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%25s%3A%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%20%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%E3%80%82%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Edevice_add%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3Eif%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E((%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AB%E3%83%A1%E3%83%A9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AD%E3%83%A3%E3%83%83%E3%83%97%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecapabilities%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3EV4L2_CAP_STREAMING%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3EV4L2_CAP_STREAMING%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%25s%3A%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%20%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%9F%E3%83%B3%E3%82%B0%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%E3%80%82%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AB%E3%83%A1%E3%83%A9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Edevice_add%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3EEMU%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%20%E3%81%AF%E3%81%99%E3%81%B9%E3%81%A6%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%20FMT%20%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmtdesc%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Eindex%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E0%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AB%E3%83%A1%E3%83%A9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmtdesc%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%BF%E3%82%A4%E3%83%97%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800080%3B%22%3EV4L2_BUF_TYPE_VIDEO_CAPTURE%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%E5%BD%A2%E5%BC%8F%3A%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3Ewhile%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3Eioctl%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AB%E3%83%A1%E3%83%A9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efd%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%81%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3EVIDIOC_ENUM_FMT%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%81%26amp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmtdesc%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)!%3D-%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E1%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%2F*%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%E8%8E%B7%E5%8F%96%E8%AE%BE%E7%BD%AE%E6%94%AF%E6%8C%81%E7%9A%84%E8%A7%86%E9%A2%91%E6%A0%BC%E5%BC%8F%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E*%2F%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22%5Ct%25d.%25s%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AB%E3%83%A1%E3%83%A9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmtdesc%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E1%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%81%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AB%E3%83%A1%E3%83%A9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmtdesc%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E8%AA%AC%E6%98%8E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmtdesc%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Eindex%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2B%2B%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%2F%2Fset%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3Efmt%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AB%E3%83%A1%E3%83%A9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%BF%E3%82%A4%E3%83%97%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800080%3B%22%3EV4L2_BUF_TYPE_VIDEO_CAPTURE%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Ecamera%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Epix%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Epixelformat%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3EV4L2_PIX_FMT_YUYV%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AB%E3%83%A1%E3%83%A9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Epix%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E9%AB%98%E3%81%95%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3EIMAGEHEIGHT%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AB%E3%83%A1%E3%83%A9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Epix%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E5%B9%85%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E%E7%94%BB%E5%83%8F%E5%B9%85%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AB%E3%83%A1%E3%83%A9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Epix%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%83%95%E3%82%A3%E3%83%BC%E3%83%AB%E3%83%89%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800080%3B%22%3EV4L2_FIELD_INTERLACED%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3Eif%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3Eioctl%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AB%E3%83%A1%E3%83%A9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3EFD%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%81%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3EVIDIOC_S_FMT%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%81%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%81%8A%E3%82%88%E3%81%B3%E3%82%AB%E3%83%A1%E3%83%A9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E-%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E1%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%2F*%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%E8%AE%BE%E7%BD%AE%E6%8D%95%E8%8E%B7%E8%A7%86%E9%A2%91%E7%9A%84%E6%A0%BC%E5%BC%8F%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E*%2F%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3Eprintf(%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%20%E3%82%92%20%E8%A8%AD%E5%AE%9A%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%20%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%20%5Cn%22)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3Efalse%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3Eif%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3Eioctl%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AB%E3%83%A1%E3%83%A9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3EFD%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%81%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3EVIDIOC_G_FMT%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%81%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%81%8A%E3%82%88%E3%81%B3%E3%82%AB%E3%83%A1%E3%83%A9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E-%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E1%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%2F*%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%E8%8E%B7%E5%8F%96%E8%AE%BE%E7%BD%AE%E7%9A%84%E8%A7%86%E9%A2%91%E6%A0%BC%E5%BC%8F%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E*%2F%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3Eprintf(%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%20%E3%82%92%E5%8F%96%E5%BE%97%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%20%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%20%5Cn%22)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3Efalse%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22fmt.type%3A%5Ct%5Ct%25d%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AB%E3%83%A1%E3%83%A9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%BF%E3%82%A4%E3%83%97%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22pix.pixelformat%3A%5Ct%25c%25c%25c%25c%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AB%E3%83%A1%E3%83%A9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Epix%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Epixelformat%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E0xFF%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AB%E3%83%A1%E3%83%A9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Epix%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%26gt%3B%26gt%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E8%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E0xFF%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AB%E3%83%A1%E3%83%A9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Epix%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3EPixelFormat%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%26gt%3B%26gt%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E16%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E0xFF%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AB%E3%83%A1%E3%83%A9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Epix%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%26gt%3B%26gt%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E24%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E0xFF%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22pix.height%3A%5Ct%5Ct%25d%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AB%E3%83%A1%E3%83%A9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Epix%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E8%BA%AB%E9%95%B7%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22pix.width%3A%5Ct%5Ct%25d%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AB%E3%83%A1%E3%83%A9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Epix%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E5%B9%85%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22pix.field%3A%5Ct%5Ct%25d%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AB%E3%83%A1%E3%83%A9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Epix%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%83%95%E3%82%A3%E3%83%BC%E3%83%AB%E3%83%89%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3EFPS%20%E3%81%AE%E8%A8%AD%E5%AE%9A%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%22%E5%88%9D%E6%9C%9F%E5%8C%96%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%25s%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%5Ct%5BOK%5D%5Cn%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3E%E3%82%AB%E3%83%A1%E3%83%A9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23800000%3B%22%3Edevice_add%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3Etrue%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23c0c0c0%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23808000%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FPRE%3E%3CP%3E%E3%81%A9%E3%81%93%E3%81%8C%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%8B%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110214%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AiMX6%20TW686x%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110214%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AF%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%A4%E3%81%84%E3%81%AB%E8%87%AA%E5%88%86%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E4%BD%9C%E3%82%8A%E6%96%B9%E3%82%92%E5%A4%89%E3%81%88%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110213%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AiMX6%20TW686x%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110213%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Ehi%20%3A%3C%2FP%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%A8%E5%90%8C%E3%81%98%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89(iMX6Q%20SabreSD%E3%83%9C%E3%83%BC%E3%83%89)%E3%81%A7%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E8%AA%8D%E8%AD%98%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%E3%82%82%E3%81%97%E3%81%9D%E3%81%86%E3%81%AA%E3%82%89%E3%80%81%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%E3%81%BE%E3%81%9F%E3%81%AF%E3%80%81%E7%A7%81%E3%81%AE%E3%83%A1%E3%83%BC%E3%83%AB%20lxl2988%40163.com%20%E3%81%AB%E7%94%BB%E5%83%8F%E3%82%92%E9%80%81%E4%BF%A1%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110210%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AiMX6%20TW686x%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110210%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%8C%E4%BB%A5%E5%89%8D%E3%81%AB%E7%9F%A5%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E3%83%89%E3%83%BC%E3%82%BF%E3%83%BC%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AF%E5%86%85%E9%83%A8%E4%BD%BF%E7%94%A8%E3%81%AE%E3%81%9F%E3%82%81%E3%81%A0%E3%81%91%E3%81%A7%E3%81%82%E3%82%8B%E3%81%B9%E3%81%8D%E3%81%A7%E3%81%99%E3%80%82%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%8C%E3%81%A9%E3%81%86%E3%82%84%E3%81%A3%E3%81%A6%E6%89%8B%E3%81%AB%E5%85%A5%E3%82%8C%E3%82%8B%E3%81%AE%E3%81%8B%E3%80%81%E6%B5%81%E3%82%8C%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E6%83%85%E5%A0%B1%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81FAE%E3%81%AB%E5%95%8F%E3%81%84%E5%90%88%E3%82%8F%E3%81%9B%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E6%84%9F%E8%AC%9D%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110209%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AiMX6%20TW686x%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110209%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%A6%AA%E6%84%9B%E3%81%AA%E3%82%8B%E8%B6%99%E3%81%95%E3%82%93%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CIMG%20id%3D%22smileyhappy%22%20class%3D%22emoticon%20emoticon-smileyhappy%22%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fi%2Fsmilies%2F16x16_smiley-happy.png%22%20alt%3D%22Smiley%20Happy%22%20title%3D%22Smiley%20Happy%22%20%2F%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E6%83%85%E5%A0%B1%E3%82%92%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%3B%3C%2FP%3E%3CP%3ESubrata%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110206%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AiMX6%20TW686x%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110206%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fb47504%22%20target%3D%22_blank%22%3Eb47504%3C%2FA%3E%2C%3C%2FP%3E%3CP%3EFAE%E3%81%8B%E3%82%89TW68xx%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E5%85%A5%E6%89%8B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%20!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110205%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AiMX6%20TW686x%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110205%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%26nbsp%3B%20simon%20yeh%2C%3C%2FP%3E%3CP%3E3.10.17%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%81%B9%E3%81%8D%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E3%81%A7%E3%81%99%E3%81%8B%E3%82%89%E3%80%81FAE%E3%81%AB%E9%80%A3%E7%B5%A1%E3%81%97%E3%81%A6%E5%85%A5%E6%89%8B%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110202%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AiMX6%20TW686x%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110202%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%EF%BC%81%E6%8A%95%E7%A8%BF%E3%82%92%E3%81%A9%E3%81%86%E3%82%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%82%3C%2FP%3E%3CP%3E%E5%90%84%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%A7%E5%BE%97%E3%81%9F%E6%9C%80%E5%A4%A7%E8%A7%A3%E5%83%8F%E5%BA%A6%E3%81%AF%E3%81%A9%E3%82%8C%E3%81%8F%E3%82%89%E3%81%84%E3%81%A7%E3%81%97%E3%81%9F%E3%81%8B(%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E7%94%BB%E5%83%8F%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%E3%82%92%E7%AE%A1%E7%90%86%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AACPU%E3%83%91%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%B9%E3%81%A8%E6%AF%94%E8%BC%83%E3%81%97%E3%81%A6)%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%3C%2FP%3E%3CP%3EBruno%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110199%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AiMX6%20TW686x%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110199%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%8B%E3%82%89%E6%A7%8B%E7%AF%89%E3%81%97%E3%81%9F%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8C%E3%83%86%E3%82%B9%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E3%81%84%E3%81%86%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%81%8B%20%3C%2FP%3E%3CP%3ETW6865%20PCI%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E5%A4%A7%E4%B8%88%E5%A4%AB%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fitem.taobao.com%2Fitem.htm%3Fspm%3Da1z10.1.w4004-5299295193.32.YwybCE%26amp%3Bid%3D22108840583%22%20target%3D%22test_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttp%3A%2F%2Fitem.taobao.com%2Fitem.htm%3Fspm%3Da1z10.1.w4004-5299295193.32.YwybCE%26amp%3Bid%3D22108840583%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110198%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AiMX6%20TW686x%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110198%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%AC%A1%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%8B%E3%82%89%E8%B3%BC%E5%85%A5%E3%81%97%E3%81%9F%E6%83%85%E5%A0%B1%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E1.%20%20%20%20%20%20%3CA%20href%3D%22http%3A%2F%2Fitem.taobao.com%2Fitem.htm%3Fspm%3Da1z10.1.w4004-5299295193.32.YwybCE%26amp%3Bid%3D22108840583%22%20target%3D%22test_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttp%3A%2F%2Fitem.taobao.com%2Fitem.htm%3Fspm%3Da1z10.1.w4004-5299295193.32.YwybCE%26amp%3Bid%3D22108840583%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E2.%E5%A8%98%E3%82%AB%E3%83%BC%E3%83%89%E7%95%AA%E5%8F%B7%E3%81%AF%E9%99%90%E3%82%89%E3%82%8C%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E4%BB%96%E3%81%AB%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%E3%82%82%E3%81%AE%E3%81%AF%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110196%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6%20TW686x%20Surround%20view%20patch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110196%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EIf%20we%20enable%20%3CSPAN%20lang%3D%22EN%22%20style%3D%22font-family%3A%20'Helvetica'%2C'sans-serif'%3B%20color%3A%20red%3B%20font-size%3A%2010pt%3B%22%3ECONFIG_IMX_PCIE_EP_MODE_IN_EP_RC_SYS%20%3C%2FSPAN%3Eitem%2C%20the%20pice%20reference%20clock%20will%20not%20output%20by%20default%20%2C%20and%20it%20will%20work%20in%20separate%20clock%20mode.%20So%20we%20checked%20the%20.config%20file%20firstly.%20%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Calibri'%2C'sans-serif'%3B%20font-size%3A%2011pt%3B%22%3EIf%20you%20can%20recognize%20other%20pcie%20device%2C%26nbsp%3B%20I%20think%20your%20issue%26nbsp%3B%20is%20not%20same%20with%20this.%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110195%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AiMX6%20TW686x%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110195%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%A7%81%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E1.%3CA%20href%3D%22http%3A%2F%2Fitem.taobao.com%2Fitem.htm%3Fspm%3Da230r.1.14.36.DrGbFa%26amp%3Bid%3D35526656445%26amp%3Bns%3D1%23detail%22%20title%3D%22http%3A%2F%2Fitem.taobao.com%2Fitem.htm%3Fspm%3Da230r.1.14.36.DrGbFa%26amp%3Bid%3D35526656445%26amp%3Bns%3D1%23detail%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%5BIdeaTrust%E5%87%BA%E5%93%81%5D%20MINI%20PCI-E%E8%BD%ACPCI-E%201X%20minipcie%E8%BD%ACpcie%20%E8%BD%AC%E6%8E%A5%E5%8D%A1-%E6%B7%98%E5%AE%9D%E7%BD%91%3C%2FA%3E%3C%2FP%3E%3CP%3E2.%3CA%20href%3D%22http%3A%2F%2Fitem.taobao.com%2Fitem.htm%3Fspm%3Da230r.1.14.1.gzXu6T%26amp%3Bid%3D21941676978%26amp%3Bns%3D1%23detail%22%20title%3D%22http%3A%2F%2Fitem.taobao.com%2Fitem.htm%3Fspm%3Da230r.1.14.1.gzXu6T%26amp%3Bid%3D21941676978%26amp%3Bns%3D1%23detail%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fitem.taobao.com%2Fitem.htm%3Fspm%3Da230r.1.14.1.gzXu6T%26amp%3Bid%3D21941676978%26amp%3Bns%3D1%23detail%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110194%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AiMX6%20TW686x%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110194%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%81%E5%88%A5%E3%81%AE%E3%83%87%E3%82%A3%E3%82%B9%E3%82%AB%E3%83%83%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%A7%E8%A8%80%E5%8F%8A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8Bpcie%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AE%E6%9C%89%E5%8A%B9%E5%8C%96%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%26gt%3B%E3%83%9B%E3%83%B3%E3%82%B7%E3%83%B3%E3%80%81%E3%81%94%E5%9B%9E%E7%AD%94%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%26gt%3B%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AEIMX6QSD%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%83%BB%E3%83%AA%E3%82%BD%E3%83%BC%E3%82%B9%E3%83%BB%E3%82%A6%E3%82%A7%E3%83%96%E3%82%B5%E3%82%A4%E3%83%88%E3%81%8B%E3%82%89%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%9FL3.0.35_4.1.0_130816_source.tar.gz%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%26gt%3B%E3%81%93%E3%82%8C%E3%81%A7%E5%95%8F%E9%A1%8C%E3%81%AF%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82IMX6%20%E3%81%8C%20RC%20%E3%81%A8%E3%81%97%E3%81%A6%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AB%E3%80%81PCIe%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E5%87%BA%E5%8A%9B%E3%81%8C%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A7%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fmessage%2F365363%22%20target%3D%22_blank%22%3EIMX6QSD%20%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%A7%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E3%83%96%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%81%A8%20PCIE%20%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E3%81%93%E3%81%AE%E3%81%93%E3%81%A8%E3%82%92%E6%9C%80%E5%88%9D%E3%81%AB%E8%A1%8C%E3%81%A3%E3%81%9F%E3%81%A8%E3%81%8D%E3%80%81%E5%A8%98%E3%82%AB%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%89%8D%E3%81%AB%E3%80%81%3C%2FP%3E%3CP%3E%E3%81%A9%E3%81%AE%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%82%AB%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%E7%A7%81%E3%81%8C%E3%81%9D%E3%82%8C%E3%82%92%E8%B2%B7%E3%81%86%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%82%8B%E5%A0%B4%E6%89%80%E3%81%AEURL%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%82%82%E3%82%89%E3%81%88%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E5%A8%98%E3%82%AB%E3%83%BC%E3%83%89%E3%82%92%E5%80%9F%E3%82%8A%E3%82%8B%E3%81%93%E3%81%A8%E3%82%82%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%20%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%81%AF%E3%80%81%E5%8F%A4%E3%81%84%E7%92%B0%E5%A2%83(Mini-PCIe2PCIe%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%82%AB%E3%83%BC%E3%83%89%26amp%3BTW6865PCIe%E3%82%AB%E3%83%BC%E3%83%89)%E3%82%92%E5%80%9F%E3%82%8A%E3%82%8B(%E8%B3%BC%E5%85%A5%E3%81%99%E3%82%8B)%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110189%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AiMX6%20TW686x%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110189%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%84%E3%81%84%E3%81%88%E3%80%81%E7%A7%81%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E8%A6%8B%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%82%82%E3%81%97%E3%81%8B%E3%81%97%E3%81%9F%E3%82%89%E3%80%81%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%E3%81%AE%E7%AE%A1%E7%90%86%E6%A4%9C%E6%9F%BB%E3%81%8C%E3%82%A2%E3%82%BF%E3%83%83%E3%83%81%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AB%E3%81%AA%E3%82%8B%E3%81%BE%E3%81%A7%E3%81%AB%E6%99%82%E9%96%93%E3%81%8C%E3%81%8B%E3%81%8B%E3%82%8B%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Epcie%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E8%A8%AD%E5%AE%9A%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E6%8F%83%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20red%3B%22%3E%23%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20red%3B%22%3E%23%20MX6%20Options%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20red%3B%22%3E%23%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20red%3B%22%3ECONFIG_IMX_PCIE%3Dy%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20red%3B%22%3E%23%20CONFIG_IMX_PCIE_EP_MODE_IN_EP_RC_SYS%E3%81%8C%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20red%3B%22%3E%23%20CONFIG_IMX_PCIE_RC_MODE_IN_EP_RC_SYS%E3%81%8C%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110188%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AiMX6%20TW686x%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110188%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%A8%AD%E5%AE%9A%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%83%9A%E3%83%BC%E3%82%B8%E3%81%AB%E3%81%AF%E4%BD%95%E3%82%82%E6%9B%B8%E3%81%8B%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E6%B7%BB%E4%BB%98%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E9%80%81%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%81%84%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%E3%83%A1%E3%83%BC%E3%83%AB%E3%81%AF%E5%A4%A7%E4%B8%88%E5%A4%AB%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110185%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AiMX6%20TW686x%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110185%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FJiangJustin%22%20target%3D%22_blank%22%3EJiangJustin%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E4%B8%8A%E3%81%A7%E3%81%97%E3%81%9F%E3%81%AE%E3%81%A8%E5%90%8C%E3%81%98%E3%81%93%E3%81%A8%E3%82%92%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E7%A7%81%E3%81%AEtw6865%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AF%E8%AD%98%E5%88%A5%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E4%BB%A5%E4%B8%8B%E3%81%AF%E7%A7%81%E3%81%8C%E3%82%84%E3%81%A3%E3%81%9F%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E1%20.%E3%83%91%E3%83%83%E3%83%81%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AFL3.0.35_4.1.0_%E3%81%A7%E3%81%99130816%3C%2FP%3E%3CP%3E2.%20make%20menuconfig%20%E5%86%85%E3%81%AE%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%20%E3%82%B3%E3%83%B3%E3%83%95%E3%82%A3%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%A6%E3%80%81tw6865%20%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E3.%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%80%81SD%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82i.mx6q%20sabreSDB%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E4.%20mini-pcie%20%3D%20%26gt%3BPCIe%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%E3%83%BC%E3%81%A8attchTW6865%E3%82%AB%E3%83%BC%E3%83%89%E3%82%92%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%E3%83%BC%E3%81%AEPCIe%E3%82%B9%E3%83%AD%E3%83%83%E3%83%88%E3%81%AB%E5%8F%96%E3%82%8A%E4%BB%98%E3%81%91%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E5.%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8C%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AB%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%80%8CLSPCI%E3%80%8D%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E4%BD%95%E3%82%82%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E6.%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%96%E3%83%BC%E3%83%88%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E3%80%8Cdmesg%E3%80%8D%E3%81%A7%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EiMX6%20PCIe%20PCIe%20RC%20mode%20imx_pcie_pltfm_probe%20entering.%3C%2FP%3E%3CP%3EPCIE%3A%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%82%92%E9%96%8B%E5%A7%8Bimx_pcie_pltfm_probe%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81DB_R0%3A0x004abc43%E3%80%81DB_R1%3A0x08000000!%3C%2FP%3E%3CP%3EIMX%20PCIe%20port%3A%20link%20down!%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%9F%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%82%92%E6%84%9B%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%82%A2%E3%83%89%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110184%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AiMX6%20TW686x%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110184%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%A7%81%E3%81%AE%E5%9C%B0%E5%85%83%E5%81%B4%E3%81%A7%E3%83%86%E3%82%B9%E3%83%88%E6%B8%88%E3%81%BF%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ETop%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%A7%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%A1%E3%83%A2%E3%83%AA%3A109772K%E4%BD%BF%E7%94%A8%E3%80%81787076K%E7%A9%BA%E3%81%8D%E3%80%810Kshrd%E3%80%813520K%E3%83%90%E3%83%95%E3%80%8124616K%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%3C%2FP%3E%3CP%3ECPU%3A12.2%25%E3%80%81usr%2015.3%25%E3%80%81sys%200.0%25NIC%2063.7%25%20%E3%82%A2%E3%82%A4%E3%83%89%E3%83%AB%200.0%25%E3%82%A2%E3%82%A4%E3%82%AA%200.0%25IRQ%208.6%25%20%E3%82%B5%E3%83%BC%E3%82%AF%3C%2FP%3E%3CP%3E%E8%B2%A0%E8%8D%B7%E5%B9%B3%E5%9D%87%3A%207.02%205.16%202.56%204%2F94%203535%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EMMDC%20%E3%83%84%E3%83%BC%E3%83%AB%E3%81%A7%E3%83%86%E3%82%B9%E3%83%88%E3%81%99%E3%82%8B%3A%3C%2FP%3E%3CP%3Eroot%40freescale%20~%24%20.%2Fmmdc_prof%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EMMDC%20%E3%81%AE%E6%96%B0%E3%81%97%E3%81%84%E3%83%97%E3%83%AD%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AA%E3%83%B3%E3%82%B0%E7%B5%90%E6%9E%9C%3A%3C%2FP%3E%3CP%3E***********************%3C%2FP%3E%3CP%3E%E5%90%88%E8%A8%88%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E6%95%B0%3A528091007%3C%2FP%3E%3CP%3E%E3%83%93%E3%82%B8%E3%83%BC%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%3A385370313%3C%2FP%3E%3CP%3E%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E6%95%B0%3A%209834967%3C%2FP%3E%3CP%3E%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E6%95%B0%3A%2010137409%3C%2FP%3E%3CP%3E%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%83%90%E3%82%A4%E3%83%88%E6%95%B0%3A%20466175272%3C%2FP%3E%3CP%3E%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%83%90%E3%82%A4%E3%83%88%E6%95%B0%3A%20379222896%3C%2FP%3E%3COL%20style%3D%22list-style-type%3A%20upper-alpha%3B%22%3E%3CLI%3E%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%83%90%E3%83%BC%E3%82%B9%E3%83%88%E3%82%B5%E3%82%A4%E3%82%BA%3A47%3C%2FLI%3E%3CLI%3E%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%83%90%E3%83%BC%E3%82%B9%E3%83%88%E3%82%B5%E3%82%A4%E3%82%BA%3A37%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%3A%20444.58%20MB%2F%E7%A7%92%20%2F%20%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%3A%20361.66%20MB%2F%E7%A7%92%20%E5%90%88%E8%A8%88%3A%20806.23%20MB%2F%E7%A7%92%3C%2FP%3E%3CP%3E%E5%88%A9%E7%94%A8%E7%8E%87%3A13%25%3C%2FP%3E%3CP%3E%E3%83%90%E3%82%B9%E8%B2%A0%E8%8D%B7%3A72%25%3C%2FP%3E%3CP%3E%E3%83%90%E3%82%A4%E3%83%88%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%3A42%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎07-17-2013 01:19 AM
更新者:
