GPIOs Interruption IMX8MM SDK Cortex M4
In the IMX8MM SDK unfortunately we cannot find any example about of use a GPIO as an input with interrupt.
To use a GPIO as input with interrupt we need to keep in mind how the GPIO IRQs works in the ARM Cortex M4.
We can find in Table 7-2 (CM4 Interrupt Summary) of IMX8MMRM (IMX8MM Reference Manual) the GPIOs IRQs are divided by two parts:
  • Combined interrupt indication for GPIOn signal 0 throughout 15
  • Combined interrupt indication for GPIOn signal 16 throughout 31
This basically means, the pines of GPIOn from 0 to 15 are handled by Combined interrupt indication for GPIOn signal 0 throughout 15 and the pines from 16 to 31 are handled by Combined interrupt indication for GPIOn signal 16 throughout 31.
In SDK we can find these definitions in:
<SDK root>/devices/MIMX8MM6/MIMX8MM6_cm4.h (Remember this is for IM8MM SDK)
In this example I will use GPIO5_IO12 (ECSPI2_MISO) as Input with IRQ and GPIO5_IO11 (ECSPI_MOSI) as Output of IMX8MM-EVK. I will connect the Output to the Input and will see the behavior of the IRQ in Rising and Falling edge.
Alejandro_Salas_2-1706127787773.pngAlejandro_Salas_2-1706127787773.pngAlejandro_Salas_3-1706127804093.pngAlejandro_Salas_3-1706127804093.png
For this example I will connect ECSPI2_MOSI (GPIO5_IO11) to ECSPI_MISO (GPIO5_IO12):
See the below definitions:
#define IN_GPIO
GPIO5
This define the GPIO base of the IN pin
#define IN_GPIO_PIN
12u
This define the pin number (for in)
#define IN_IRQ
GPIO5_Combined_0_15_IRQn
This define the IRQ number (72 in this case)
#define GPIO_IRQ_HANDLER
GPIO5_Combined_0_15_IRQHandler
This is a "pointer" to function that will handle the interrupt
#define IN_NAME
"IN GPIO5_IO12"
This is only a name or description for the pin
See below definitions:
#define OUT_GPIO
GPIO5
This is the GPIO base of OUT pin
#define OUT_GPIO_PIN
11u
This define the pin number (for out)
#define OUT_NAME
"OUT GPIO5_IO11"
Now the below section is the IRQ handler (which was defined before)
The GPIO_ClearPinsInterruptFlags(IN_GPIO, 1u << IN_GPIO_PIN); refers to GPIOx_ISR register:
Alejandro_Salas_9-1706128379494.pngAlejandro_Salas_9-1706128379494.pngAlejandro_Salas_10-1706128389932.pngAlejandro_Salas_10-1706128389932.png
For this example, the IRQ Handler will print "IRQ detected ............" in each interrupt.
We will create two different GPIOs config, one for Output and other one for Input with IRQ Falling edge:
Then configure the GPIOs and IRQ:
EnableIRQ refers to enable the 72 IRQ.
GPIO_PortEnableInterrupts refers to GPIOx_IMR:
Finally, the example put the out GPIO5_IO11 in High state and then in low state many. First the IRQ is configured as Falling edge, then as Rising edge.
 I will attach the complete source file.
To compile it you can use ARMGCC toolchain directly, but I like to use VSCode with MCUXpresso integration.
Once, when you have your .bin file (in my case igpio_led_output.bin) you can load to board with UUU tool:
In your Linux machine:
sudo uuu -b fat_write igpio_led_output.bin mmc 2:1 gpio.bin
In U-boot board:
u-boot=> fastboot 0
Then, when the .bin file was loaded, you can load to the CORTEX M4 in U-boot with:
u-boot=> fatload mmc 2:1 ${loadaddr} gpio.bin
7076 bytes read in 14 ms (493.2 KiB/s)
u-boot=> cp.b 0x80000000 0x7e0000 0x10000
u-boot=> bootaux 0x7e0000
## No elf image ar address 0x007e0000
## Starting auxiliary core stack = 0x20020000, pc = 0x1FFE02CD...
u-boot=>
NOTE: You can load the binary to cortex m4 with Custom bootscripts for practicity.
Once the binary loaded in M4 core you should see in seria terminal this logs (Remember GPIO5_IO11 and GPIO5_IO12 must be connected to get the same logs):
And the logs when you disconnect the GPIO5_IO11 and GPIO5_IO12 in execution time:
Disconnection (Red color)
Reconnection (Blue color)
I hope this can helps.
Best regards!
Salas.
添付
コメント
Thank you for this article.  I am doing a similar task and I got the interrupt working at the u-boot stage.
However I observed that, when the linux kernel is started, the initial interrupt setting for the cortex M4 is overwritten and the interrupt functionality of the GPIO pin is no longer possible.
Have you also observed this?  I observed that in your example, you did not proceed to start the linux kernel.  Is there a reason for this?
I have checked the entire kernel to see why this behaviour but I could not find any.
What is the solution to this.
Thanks.
Hello @ababatola
This behavior is because Linux is handling the peripheral, in this case, with this application you need to disable the gpio5 in device tree, then you will be able to handle the entire gpio5 and interrupts from cortex M.
Salas.
Thanks.
%3CLINGO-SUB%20id%3D%22lingo-sub-1794895%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EGPIO%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BFIMX8MM%20SDK%20Cortex%20M4%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1794895%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%0A%3CP%3E%3CSPAN%20data-contrast%3D%22auto%22%3E%E6%AE%8B%E5%BF%B5%E3%81%AA%E3%81%8C%E3%82%89%E3%80%81IMX8MM%20SDK%E3%81%A7%E3%81%AFGPIO%E3%82%92%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E4%BB%98%E3%81%8D%E3%81%AE%E5%85%A5%E5%8A%9B%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E4%BE%8B%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20data-contrast%3D%22auto%22%3EGPIO%E3%82%92%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E4%BB%98%E3%81%8D%E3%81%AE%E5%85%A5%E5%8A%9B%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81ARM%20Cortex%20M4%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8BGPIO%20IRQ%E3%81%AE%E5%8B%95%E4%BD%9C%E3%82%92%E8%80%83%E6%85%AE%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20data-contrast%3D%22auto%22%3EIMX8MMRM%EF%BC%88IMX8MM%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%EF%BC%89%E3%81%AE%E8%A1%A8%207-2%EF%BC%88CM4%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%81%AE%E6%A6%82%E8%A6%81%EF%BC%89%E3%82%92%E8%A6%8B%E3%82%8B%E3%81%A8%E3%80%81GPIO%E3%81%AEIRQ%E3%81%8C2%E3%81%A4%E3%81%AE%E9%83%A8%E5%88%86%E3%81%AB%E5%88%86%E3%81%8B%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E5%88%86%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CUL%3E%0A%3CLI%20data-aria-posinset%3D%221%22%20data-aria-level%3D%222%22%3E%3CSPAN%20data-contrast%3D%22auto%22%3EGPIOn%E4%BF%A1%E5%8F%B70%E3%81%8B%E3%82%8915%E3%81%BE%E3%81%A7%E3%81%AE%E8%A4%87%E5%90%88%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E8%A1%A8%E7%A4%BA%3C%2FSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%20data-aria-posinset%3D%222%22%20data-aria-level%3D%222%22%3E%3CSPAN%20data-contrast%3D%22auto%22%3EGPIOn%E4%BF%A1%E5%8F%B716%E3%81%8B%E3%82%8931%E3%81%BE%E3%81%A7%E3%81%AE%E8%A4%87%E5%90%88%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E8%A1%A8%E7%A4%BA%3C%2FSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20data-contrast%3D%22auto%22%3E%E3%81%93%E3%82%8C%E3%81%AF%E5%9F%BA%E6%9C%AC%E7%9A%84%E3%81%AB%E3%81%AF%E3%80%81%3C%2FSPAN%3E%3CSTRONG%3E%3CI%3E%3CSPAN%20data-contrast%3D%22auto%22%3E0%E3%81%8B%E3%82%8915%E3%81%BE%E3%81%A7%E3%81%AEGPIOn%E3%81%AE%E3%83%94%E3%83%B3%E3%81%8C%3C%2FSPAN%3E%3C%2FI%3E%3C%2FSTRONG%3E%3CSTRONG%3E%3CSPAN%20data-contrast%3D%22auto%22%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSTRONG%3E%3CI%3E%3CSPAN%20data-contrast%3D%22auto%22%3EGPIOn%E4%BF%A1%E5%8F%B70%E3%81%8B%E3%82%8915%E3%81%BE%E3%81%A7%E3%81%AE%E8%A4%87%E5%90%88%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E8%A1%A8%E7%A4%BA%3C%2FSPAN%3E%3C%2FI%3E%3C%2FSTRONG%3E%E3%81%A7%E5%87%A6%E7%90%86%E3%81%95%E3%82%8C%E3%80%81%3CSTRONG%3E%3CI%3E%3CSPAN%20data-contrast%3D%22auto%22%3E16%E3%81%8B%E3%82%8931%E3%81%BE%E3%81%A7%E3%81%AE%E3%83%94%E3%83%B3%E3%81%8CGPIOn%E4%BF%A1%E5%8F%B716%E3%81%8B%E3%82%8931%E3%81%BE%E3%81%A7%E3%81%AE%3C%2FSPAN%3E%3C%2FI%3E%3C%2FSTRONG%3E%3CSPAN%20data-contrast%3D%22auto%22%3E%3C%2FSPAN%3E%3CSTRONG%3E%3CI%3E%3CSPAN%20data-contrast%3D%22auto%22%3E%E8%A4%87%E5%90%88%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E8%A1%A8%E7%A4%BA%3C%2FSPAN%3E%3C%2FI%3E%3C%2FSTRONG%3E%E3%81%A7%E5%87%A6%E7%90%86%E3%81%95%E3%82%8C%E3%82%8B%E3%81%A8%E3%81%84%E3%81%86%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3CI%3E%3CSPAN%20data-contrast%3D%22auto%22%3E%3C%2FSPAN%3E%3C%2FI%3E%3CSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Alejandro_Salas_0-1706127701440.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Alejandro_Salas_0-1706127701440.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F259921iCDC749935D79E318%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Alejandro_Salas_0-1706127701440.png%22%20alt%3D%22Alejandro_Salas_0-1706127701440.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EAlejandro_Salas_0-1706127701440.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20data-contrast%3D%22auto%22%3ESDK%E3%81%A7%E3%81%AF%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E5%AE%9A%E7%BE%A9%E3%82%92%E6%AC%A1%E3%81%AE%E5%A0%B4%E6%89%80%E3%81%A7%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20data-contrast%3D%22auto%22%3E%3CSDK%20root%3D%22%22%3E%2Fdevices%2FMIMX8MM6%2FMIMX8MM6_cm4.h%EF%BC%88%E3%81%93%E3%82%8C%E3%81%AFIM8MM%20SDK%E7%94%A8%E3%81%A7%E3%81%99%E3%81%AE%E3%81%A7%E6%B3%A8%E6%84%8F%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%EF%BC%89%3C%2FSDK%3E%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Alejandro_Salas_1-1706127740049.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Alejandro_Salas_1-1706127740049.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F259922i8DA0EEEE02114002%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Alejandro_Salas_1-1706127740049.png%22%20alt%3D%22Alejandro_Salas_1-1706127740049.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EAlejandro_Salas_1-1706127740049.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20class%3D%22TextRun%20%20BCX7%20SCXO186802705%22%20data-contrast%3D%22auto%22%3E%3CSPAN%20class%3D%22NormalTextRun%20%20BCX7%20SCXO186802705%22%3E%E3%81%93%E3%81%AE%E4%BE%8B%E3%81%A7%E3%81%AF%E3%80%81GPIO5_IO12%EF%BC%88%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22TextRun%20%20BCX7%20SCXO186802705%22%20data-contrast%3D%22auto%22%3E%3CSPAN%20class%3D%22NormalTextRun%20%20BCX7%20SCXO186802705%22%3EECSPI2_MISO%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22TextRun%20%20BCX7%20SCXO186802705%22%20data-contrast%3D%22auto%22%3E%3CSPAN%20class%3D%22NormalTextRun%20%20BCX7%20SCXO186802705%22%3E%EF%BC%89%E3%82%92IRQ%E5%85%A5%E5%8A%9B%E3%81%A8%E3%81%97%E3%81%A6%E3%80%81GPIO5_IO11%EF%BC%88ECSPI_MOSI%EF%BC%89%E3%82%92IMX8MM-EVK%E3%81%AE%E5%87%BA%E5%8A%9B%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E5%87%BA%E5%8A%9B%E3%82%92%E5%85%A5%E5%8A%9B%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%80%81%E7%AB%8B%E3%81%A1%E4%B8%8A%E3%81%8C%E3%82%8A%E3%82%A8%E3%83%83%E3%82%B8%E3%81%A8%E7%AB%8B%E3%81%A1%E4%B8%8B%E3%81%8C%E3%82%8A%E3%82%A8%E3%83%83%E3%82%B8%E3%81%AEIRQ%E3%81%AE%E6%8C%99%E5%8B%95%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%26nbsp%3B%3C%2FP%3E%0A%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Alejandro_Salas_2-1706127787773.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Alejandro_Salas_2-1706127787773.png%22%20style%3D%22width%3A%20394px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F259923i76A92AF56B8420C9%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Alejandro_Salas_2-1706127787773.png%22%20alt%3D%22Alejandro_Salas_2-1706127787773.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EAlejandro_Salas_2-1706127787773.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Alejandro_Salas_3-1706127804093.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Alejandro_Salas_3-1706127804093.png%22%20style%3D%22width%3A%20383px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F259924i05D3A4C56F673292%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Alejandro_Salas_3-1706127804093.png%22%20alt%3D%22Alejandro_Salas_3-1706127804093.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EAlejandro_Salas_3-1706127804093.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20class%3D%22TextRun%20SCXO223984749%20BCX7%22%20data-contrast%3D%22auto%22%3E%3CSPAN%20class%3D%22NormalTextRun%20SCXO223984749%20BCX7%22%3E%E3%81%93%E3%81%AE%E4%BE%8B%E3%81%A7%E3%81%AF%E3%80%81ECSPI2_MOSI%EF%BC%88GPIO5_IO11%EF%BC%89%E3%82%92%20ECSPI_MISO%EF%BC%88GPIO5_IO12%EF%BC%89%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22EOP%20SCXO223984749%20BCX7%22%3E%26nbsp%3B%3C%2FSPAN%3E%26nbsp%3B%3C%2FP%3E%0A%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Alejandro_Salas_4-1706127830066.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Alejandro_Salas_4-1706127830066.png%22%20style%3D%22width%3A%20386px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F259925i0DD2CEB81A919730%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Alejandro_Salas_4-1706127830066.png%22%20alt%3D%22Alejandro_Salas_4-1706127830066.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EAlejandro_Salas_4-1706127830066.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%0A%3CP%3E%3CSPAN%20class%3D%22TextRun%20SCXO261507251%20BCX7%22%20data-contrast%3D%22auto%22%3E%3CSPAN%20class%3D%22NormalTextRun%20SCXO261507251%20BCX7%22%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E5%AE%9A%E7%BE%A9%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Alejandro_Salas_5-1706127847121.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Alejandro_Salas_5-1706127847121.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F259926iCB8710D443BC4AFE%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Alejandro_Salas_5-1706127847121.png%22%20alt%3D%22Alejandro_Salas_5-1706127847121.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EAlejandro_Salas_5-1706127847121.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%0A%3CBR%20%2F%3E%0A%3CTABLE%20style%3D%22font-weight%3A%20400%3B%22%3E%0A%3CTBODY%3E%0A%3CTR%3E%0A%3CTD%3E%0A%3CP%3E%3CSPAN%20data-contrast%3D%22auto%22%3E%23define%20IN_GPIO%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%3E%0A%3CP%3E%3CSPAN%20data-contrast%3D%22auto%22%3EGPIO5%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%3E%0A%3CP%3E%3CSPAN%20data-contrast%3D%22auto%22%3E%E3%81%93%E3%82%8C%E3%81%A7IN%E3%83%94%E3%83%B3%E3%81%AEGPIO%E3%83%99%E3%83%BC%E3%82%B9%E3%82%92%E5%AE%9A%E7%BE%A9%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3E%0A%3CP%3E%3CSPAN%20data-contrast%3D%22auto%22%3E%23define%20IN_GPIO_PIN%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%3E%0A%3CP%3E%3CSPAN%20data-contrast%3D%22auto%22%3E12u%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%3E%0A%3CP%3E%3CSPAN%20data-contrast%3D%22auto%22%3E%E3%81%93%E3%82%8C%E3%81%A7%E5%85%A5%E5%8A%9B%E3%81%AE%E3%83%94%E3%83%B3%E7%95%AA%E5%8F%B7%E3%82%92%E5%AE%9A%E7%BE%A9%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3E%0A%3CP%3E%3CSPAN%20data-contrast%3D%22auto%22%3E%23define%20IN_IRQ%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%3E%0A%3CP%3E%3CSPAN%20data-contrast%3D%22auto%22%3EGPIO5_Combined_0_15_IRQn%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%3E%0A%3CP%3E%3CSPAN%20data-contrast%3D%22auto%22%3E%E3%81%93%E3%82%8C%E3%81%A7IRQ%E7%95%AA%E5%8F%B7%E3%82%92%E5%AE%9A%E7%BE%A9%E3%81%97%E3%81%BE%E3%81%99%EF%BC%88%E3%81%93%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF72%E3%81%A7%E3%81%99%EF%BC%89%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3E%0A%3CP%3E%3CSPAN%20data-contrast%3D%22auto%22%3E%23define%20GPIO_IRQ_HANDLER%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%3E%0A%3CP%3E%3CSPAN%20data-contrast%3D%22auto%22%3EGPIO5_Combined_0_15_IRQHandler%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%3E%0A%3CP%3E%3CSPAN%20data-contrast%3D%22auto%22%3E%E3%81%93%E3%82%8C%E3%81%AF%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%92%E5%87%A6%E7%90%86%E3%81%99%E3%82%8B%E9%96%A2%E6%95%B0%E3%81%B8%E3%81%AE%E3%80%8C%E3%83%9D%E3%82%A4%E3%83%B3%E3%82%BF%E3%80%8D%E3%81%A7%E3%81%99%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3E%0A%3CP%3E%3CSPAN%20data-contrast%3D%22auto%22%3E%23define%20IN_NAME%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%3E%0A%3CP%3E%3CSPAN%20data-contrast%3D%22auto%22%3E%22IN%20GPIO5_IO12%22%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%3E%0A%3CP%3E%3CSPAN%20data-contrast%3D%22auto%22%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%83%94%E3%83%B3%E3%81%AE%E5%90%8D%E5%89%8D%E3%81%BE%E3%81%9F%E3%81%AF%E8%AA%AC%E6%98%8E%E3%81%AE%E3%81%BF%E3%81%A7%E3%81%99%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20class%3D%22TextRun%20SCXO75184953%20BCX7%22%20data-contrast%3D%22auto%22%3E%3CSPAN%20class%3D%22NormalTextRun%20SCXO75184953%20BCX7%22%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E5%AE%9A%E7%BE%A9%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22EOP%20SCXO75184953%20BCX7%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Alejandro_Salas_6-1706128301737.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Alejandro_Salas_6-1706128301737.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F259927i25CF2A66A603A6B3%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Alejandro_Salas_6-1706128301737.png%22%20alt%3D%22Alejandro_Salas_6-1706128301737.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EAlejandro_Salas_6-1706128301737.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%0A%3CBR%20%2F%3E%0A%3CTABLE%20style%3D%22font-weight%3A%20400%3B%22%3E%0A%3CTBODY%3E%0A%3CTR%3E%0A%3CTD%3E%0A%3CP%3E%3CSPAN%20data-contrast%3D%22auto%22%3E%23define%20OUT_GPIO%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%3E%0A%3CP%3E%3CSPAN%20data-contrast%3D%22auto%22%3EGPIO5%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%3E%0A%3CP%3E%3CSPAN%20data-contrast%3D%22auto%22%3E%E3%81%93%E3%82%8C%E3%81%AFOUT%E3%83%94%E3%83%B3%E3%81%AEGPIO%E3%83%99%E3%83%BC%E3%82%B9%E3%81%A7%E3%81%99%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3E%0A%3CP%3E%3CSPAN%20data-contrast%3D%22auto%22%3E%23define%20OUT_GPIO_PIN%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%3E%0A%3CP%3E%3CSPAN%20data-contrast%3D%22auto%22%3E11u%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%3E%0A%3CP%3E%3CSPAN%20data-contrast%3D%22auto%22%3E%E3%81%93%E3%82%8C%E5%87%BA%E5%8A%9B%E3%81%AE%E3%83%94%E3%83%B3%E7%95%AA%E5%8F%B7%E3%82%92%E5%AE%9A%E7%BE%A9%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3E%0A%3CP%3E%3CSPAN%20data-contrast%3D%22auto%22%3E%23define%20OUT_NAME%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%3E%0A%3CP%3E%3CSPAN%20data-contrast%3D%22auto%22%3E%22OUT%20GPIO5_IO11%22%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%3E%0A%3CP%3E%3CSPAN%20data-contrast%3D%22auto%22%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%83%94%E3%83%B3%E3%81%AE%E5%90%8D%E5%89%8D%E3%81%BE%E3%81%9F%E3%81%AF%E8%AA%AC%E6%98%8E%E3%81%AE%E3%81%BF%E3%81%A7%E3%81%99%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20class%3D%22TextRun%20SCXO135787391%20BCX7%22%20data-contrast%3D%22auto%22%3E%3CSPAN%20class%3D%22NormalTextRun%20SCXO135787391%20BCX7%22%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AFIRQ%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%EF%BC%88%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22TextRun%20SCXO135787391%20BCX7%22%20data-contrast%3D%22auto%22%3E%3CSPAN%20class%3D%22NormalTextRun%20SCXO135787391%20BCX7%22%3E%E4%BB%A5%E5%89%8D%E3%81%AB%E5%AE%9A%E7%BE%A9%E3%81%95%E3%82%8C%E3%81%9F%E3%82%82%E3%81%AE%EF%BC%89%E3%81%A7%E3%81%99%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22TextRun%20SCXO135787391%20BCX7%22%20data-contrast%3D%22auto%22%3E%3CSPAN%20class%3D%22NormalTextRun%20SCXO135787391%20BCX7%22%3E%3CLI-EMOJI%20id%3D%22lia_disappointed-face%22%20title%3D%22%3Adisappointed_face%3A%22%3E%3C%2FLI-EMOJI%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Alejandro_Salas_8-1706128362819.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Alejandro_Salas_8-1706128362819.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F259929i8FDDCA9E457752F6%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Alejandro_Salas_8-1706128362819.png%22%20alt%3D%22Alejandro_Salas_8-1706128362819.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EAlejandro_Salas_8-1706128362819.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%0A%3CBR%20%2F%3E%0A%0A%3CDIV%20class%3D%22lia-message-template-content-zone%22%3E%3CSPAN%20class%3D%22TextRun%20SCXO184695698%20BCX7%22%20data-contrast%3D%22auto%22%3E%3CSPAN%20class%3D%22NormalTextRun%20SCXO184695698%20BCX7%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22SpellingError%20SCXO184695698%20BCX7%22%3EGPIO_ClearPinsInterruptFlags%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22NormalTextRun%20SCXO184695698%20BCX7%22%3E%EF%BC%88IN_GPIO%2C%201u%20%26lt%3B%26lt%3B%20IN_GPIO_PIN%EF%BC%89%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81GPIOx_ISR%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22EOP%20SCXO184695698%20BCX7%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20class%3D%22lia-message-template-content-zone%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%20class%3D%22lia-message-template-content-zone%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Alejandro_Salas_9-1706128379494.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Alejandro_Salas_9-1706128379494.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F259930iD2A39E18DCFFA865%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Alejandro_Salas_9-1706128379494.png%22%20alt%3D%22Alejandro_Salas_9-1706128379494.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EAlejandro_Salas_9-1706128379494.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Alejandro_Salas_10-1706128389932.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Alejandro_Salas_10-1706128389932.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F259931iE5ECEB0F254A73CA%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Alejandro_Salas_10-1706128389932.png%22%20alt%3D%22Alejandro_Salas_10-1706128389932.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EAlejandro_Salas_10-1706128389932.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20class%3D%22TextRun%20SCXO223621585%20BCX7%22%20data-contrast%3D%22auto%22%3E%3CSPAN%20class%3D%22NormalTextRun%20SCXO223621585%20BCX7%22%3E%E3%81%93%E3%81%AE%E4%BE%8B%E3%81%A7%E3%81%AF%E3%80%81IRQ%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%81%8C%E5%90%84%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%81%A7%E3%80%8C%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22TextRun%20SCXO223621585%20BCX7%22%20data-contrast%3D%22auto%22%3E%3CSPAN%20class%3D%22NormalTextRun%20SCXO223621585%20BCX7%22%3EIRQ%20detected%20............%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22TextRun%20SCXO223621585%20BCX7%22%20data-contrast%3D%22auto%22%3E%3CSPAN%20class%3D%22NormalTextRun%20SCXO223621585%20BCX7%22%3E%E3%80%8D%E3%81%A8%E5%87%BA%E5%8A%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22EOP%20SCXO223621585%20BCX7%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20class%3D%22TextRun%20SCXO235779073%20BCX7%22%20data-contrast%3D%22auto%22%3E%3CSPAN%20class%3D%22NormalTextRun%20SCXO235779073%20BCX7%22%3E2%E3%81%A4%E3%81%AE%E7%95%B0%E3%81%AA%E3%82%8BGPIO%E6%A7%8B%E6%88%90%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%821%E3%81%A4%E3%81%AFIRQ%E7%AB%8B%E3%81%A1%E4%B8%8B%E3%81%8C%E3%82%8A%E3%82%A8%E3%83%83%E3%82%B8%E3%81%AE%E5%87%BA%E5%8A%9B%E7%94%A8%E3%80%81%E3%82%82%E3%81%861%E3%81%A4%E3%81%AF%E5%85%A5%E5%8A%9B%E7%94%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22EOP%20SCXO235779073%20BCX7%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Alejandro_Salas_11-1706128421672.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Alejandro_Salas_11-1706128421672.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F259932iA7E2BE099F67946D%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Alejandro_Salas_11-1706128421672.png%22%20alt%3D%22Alejandro_Salas_11-1706128421672.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EAlejandro_Salas_11-1706128421672.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20class%3D%22TextRun%20SCXO39976947%20BCX7%22%20data-contrast%3D%22auto%22%3E%3CSPAN%20class%3D%22NormalTextRun%20SCXO39976947%20BCX7%22%3E%E6%AC%A1%E3%81%ABGPIO%E3%81%A8IRQ%E3%82%92%E6%A7%8B%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22EOP%20SCXO39976947%20BCX7%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Alejandro_Salas_12-1706128434880.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Alejandro_Salas_12-1706128434880.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F259933i680F72D7B6404258%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Alejandro_Salas_12-1706128434880.png%22%20alt%3D%22Alejandro_Salas_12-1706128434880.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EAlejandro_Salas_12-1706128434880.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20class%3D%22TextRun%20SCXO58634800%20BCX7%22%20data-contrast%3D%22auto%22%3E%3CSPAN%20class%3D%22SpellingError%20SCXO58634800%20BCX7%22%3EEnableIRQ%3C%2FSPAN%3E%3CSPAN%20class%3D%22NormalTextRun%20SCXO58634800%20BCX7%22%3E%E3%81%AF%3CSPAN%3E%3C%2FSPAN%3E72%20IRQ%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%A8%E3%81%84%E3%81%86%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22EOP%20SCXO58634800%20BCX7%22%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22SpellingError%20SCXO34491208%20BCX7%22%3EGPIO_PortEnableInterrupts%3C%2FSPAN%3E%3CSPAN%20class%3D%22NormalTextRun%20SCXO34491208%20BCX7%22%3E%3CSPAN%3E%3C%2FSPAN%3E%E3%81%AF%3CSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22SpellingError%20SCXO34491208%20BCX7%22%3EGPIOx_IMR%3C%2FSPAN%3E%3CSPAN%20class%3D%22NormalTextRun%20SCXO34491208%20BCX7%22%3E%E3%82%92%E6%8C%87%E3%81%97%E3%81%BE%E3%81%99%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%0A%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Alejandro_Salas_13-1706128465396.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Alejandro_Salas_13-1706128465396.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F259934iD07AC5E488A93BFF%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Alejandro_Salas_13-1706128465396.png%22%20alt%3D%22Alejandro_Salas_13-1706128465396.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EAlejandro_Salas_13-1706128465396.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%0A%3CP%3E%3CSPAN%20class%3D%22TextRun%20SCXO116809601%20BCX7%22%20data-contrast%3D%22auto%22%3E%3CSPAN%20class%3D%22NormalTextRun%20SCXO116809601%20BCX7%22%3E%E6%9C%80%E5%BE%8C%E3%81%AB%E3%80%81%E3%81%93%E3%81%AE%E4%BE%8B%E3%81%A7%E3%81%AFGPIO5_IO11%E3%82%92High%E7%8A%B6%E6%85%8B%E3%81%AB%E3%81%97%E3%81%A6Low%E7%8A%B6%E6%85%8B%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E5%A4%9A%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%E3%81%BE%E3%81%9AIRQ%E3%82%92%E7%AB%8B%E3%81%A1%E4%B8%8B%E3%81%8C%E3%82%8A%E3%82%A8%E3%83%83%E3%82%B8%E3%81%A8%E3%81%97%E3%81%A6%E8%A8%AD%E5%AE%9A%E3%81%97%E3%80%81%E6%AC%A1%E3%81%AB%E7%AB%8B%E3%81%A1%E4%B8%8A%E3%81%8C%E3%82%8A%E3%82%A8%E3%83%83%E3%82%B8%E3%81%A8%E3%81%97%E3%81%A6%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22EOP%20SCXO116809601%20BCX7%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Alejandro_Salas_14-1706128482221.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Alejandro_Salas_14-1706128482221.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F259935i59F8531AFC7F980A%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Alejandro_Salas_14-1706128482221.png%22%20alt%3D%22Alejandro_Salas_14-1706128482221.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EAlejandro_Salas_14-1706128482221.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSTRONG%3E%3CSPAN%20class%3D%22TextRun%20SCXO249691410%20BCX7%22%20data-contrast%3D%22auto%22%3E%3CSPAN%20class%3D%22NormalTextRun%20SCXO249691410%20BCX7%22%3E%E5%AE%8C%E5%85%A8%E3%81%AA%E3%82%BD%E3%83%BC%E3%82%B9%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E6%B7%BB%E4%BB%98%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22EOP%20SCXO249691410%20BCX7%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%99%E3%82%8B%E9%9A%9B%E3%81%AB%E3%80%81ARMGCC%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%82%92%E7%9B%B4%E6%8E%A5%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E7%A7%81%E3%81%AF%E5%A5%BD%E3%81%BF%E3%81%A7%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FMCUXpresso-for-VSCode-Knowledge%2FTraining-Walkthrough-of-MCUXpresso-for-VS-Code%2Fta-p%2F1634002%22%20target%3D%22_self%22%3EVSCode%E3%81%A8MCUXpresso%E3%81%AE%E7%B5%B1%E5%90%88%3C%2FA%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E.bin%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E3%81%82%E3%82%8C%E3%81%B0%E3%80%81%EF%BC%88%E7%A7%81%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%3CSTRONG%3Eigpio_led_output.bin%3C%2FSTRONG%3E%EF%BC%89%E3%80%81UUU%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%8A%E4%BD%BF%E3%81%84%E3%81%AELinux%E3%83%9E%E3%82%B7%E3%83%B3%E3%81%AE%E5%A0%B4%E5%90%88%EF%BC%9A%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Esudo%20uuu%20-b%20fat_write%20igpio_led_output.bin%20mmc%202%3A1%20gpio.bin%0A%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3EU-Boot%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E5%A0%B4%E5%90%88%EF%BC%9A%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Eu-boot%3D%26gt%3B%20fastboot%200%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%AC%A1%E3%81%AB%E3%80%81.bin%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%9F%E3%82%89%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%ABU-boot%20whit%E3%81%AECORTEX%20M4%E3%81%AB%E3%83%AD%E3%83%BC%E3%83%89%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Eu-boot%3D%26gt%3B%20fatload%20mmc%202%3A1%20%24%7Bloadaddr%7D%20gpio.bin%0A7076%20bytes%20read%20in%2014%20ms%20(493.2%20KiB%2Fs)%0Au-boot%3D%26gt%3B%20cp.b%200x80000000%200x7e0000%200x10000%0Au-boot%3D%26gt%3B%20bootaux%200x7e0000%0A%23%23%20No%20elf%20image%20ar%20address%200x007e0000%0A%23%23%20Starting%20auxiliary%20core%20stack%20%3D%200x20020000%2C%20pc%20%3D%200x1FFE02CD...%0Au-boot%3D%26gt%3B%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%E5%AE%9F%E7%94%A8%E6%80%A7%E3%82%92%E9%AB%98%E3%82%81%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FCustom-Scripts-in-U-Boot%2Fta-p%2F1792382%22%20target%3D%22_self%22%3E%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%E3%83%96%E3%83%BC%E3%83%88%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%3C%2FA%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81Cortex-M4%E3%81%AB%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20class%3D%22EOP%20SCXO249691410%20BCX7%22%3E%3CSPAN%20class%3D%22TextRun%20SCXO88881517%20BCX7%22%20data-contrast%3D%22auto%22%3E%3CSPAN%20class%3D%22NormalTextRun%20SCXO88881517%20BCX7%22%3E%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%81%8CM4%E3%82%B3%E3%82%A2%E3%81%AB%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%82%8B%E3%81%A8%E3%80%81%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%BF%E3%83%BC%E3%83%9F%E3%83%8A%E3%83%AB%E3%81%AB%E6%AC%A1%E3%81%AE%E3%83%AD%E3%82%B0%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%EF%BC%88%E5%90%8C%E3%81%98%E3%83%AD%E3%82%B0%E3%82%92%E5%8F%96%E5%BE%97%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81GPIO5_IO11%E3%81%A8GPIO5_IO12%E3%82%92%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%AE%E3%81%A7%E6%B3%A8%E6%84%8F%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%EF%BC%89%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22EOP%20SCXO88881517%20BCX7%22%3E%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Alejandro_Salas_15-1706128516905.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Alejandro_Salas_15-1706128516905.png%22%20style%3D%22width%3A%20222px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F259937iA54B2786BF6D72EF%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Alejandro_Salas_15-1706128516905.png%22%20alt%3D%22Alejandro_Salas_15-1706128516905.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EAlejandro_Salas_15-1706128516905.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20class%3D%22TextRun%20SCXO175019325%20BCX7%22%20data-contrast%3D%22auto%22%3E%3CSPAN%20class%3D%22NormalTextRun%20SCXO175019325%20BCX7%22%3E%E5%AE%9F%E8%A1%8C%E4%B8%AD%E3%81%AEGPIO5_IO11%E3%81%A8GPIO5_IO12%E3%82%92%E5%88%87%E6%96%AD%E3%81%97%E3%81%9F%E3%81%A8%E3%81%8D%E3%81%AE%E3%83%AD%E3%82%B0%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22TextRun%20SCXO175019325%20BCX7%22%20data-contrast%3D%22auto%22%3E%3CSPAN%20class%3D%22NormalTextRun%20SCXO175019325%20BCX7%22%3E%EF%BC%9A%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22EOP%20SCXO175019325%20BCX7%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%0A%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Alejandro_Salas_16-1706128531282.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Alejandro_Salas_16-1706128531282.png%22%20style%3D%22width%3A%20251px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F259938iD3079069D960030E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Alejandro_Salas_16-1706128531282.png%22%20alt%3D%22Alejandro_Salas_16-1706128531282.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EAlejandro_Salas_16-1706128531282.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%0A%3CP%3E%3CSPAN%20class%3D%22TextRun%20SCXO178116070%20BCX7%22%20data-contrast%3D%22auto%22%3E%3CSPAN%20class%3D%22NormalTextRun%20SCXO178116070%20BCX7%22%3E%3CLI-EMOJI%20id%3D%22lia_red-circle%22%20title%3D%22%3Ared_circle%3A%22%3E%3C%2FLI-EMOJI%3E%E5%88%87%E6%96%AD%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22EOP%20SCXO178116070%20BCX7%22%3E%EF%BC%88%E8%B5%A4%E8%89%B2%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22EOP%20SCXO178116070%20BCX7%22%3E%3CSPAN%20class%3D%22TextRun%20SCXO140094344%20BCX7%22%20data-contrast%3D%22auto%22%3E%3CSPAN%20class%3D%22NormalTextRun%20SCXO140094344%20BCX7%22%3E%3CLI-EMOJI%20id%3D%22lia_blue-circle%22%20title%3D%22%3Ablue_circle%3A%22%3E%3C%2FLI-EMOJI%3E%E5%86%8D%E6%8E%A5%E7%B6%9A%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22EOP%20SCXO140094344%20BCX7%22%3E%EF%BC%88%E9%9D%92%E8%89%B2%EF%BC%89%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20data-contrast%3D%22auto%22%3E%E3%81%93%E3%82%8C%E3%81%8C%E3%81%8A%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A6%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20data-contrast%3D%22auto%22%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20data-contrast%3D%22auto%22%3ESalas.%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1794895%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208M%20%7C%20i.MX%208M%20Mini%20%7C%20i.MX%208M%20Nano%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EWindows%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
評価なし
バージョン履歴
最終更新日:
‎07-29-2025 02:40 PM
更新者:
