CAN baurate error
CAN baurate error
Andrew101
Hello everyone,
I have a problem with baurate in classic CAN in S32K3. I reuse an example code "lwip_baremetal_s32k344" and add FlexCAN. Although I configed in clock diagram tab, FlexCAN tab and the S32DS also return the approriate value is 1 MHz (see the pictures below for more details), when I measured CAN_TX by logic analyzer, I see the baurate was just around 400Khz. Does anyone have the same problem with me? Thanks for your help.
khanhhuy_2-1760150458852.pngkhanhhuy_3-1760150484430.pngkhanhhuy_4-1760150505078.pngkhanhhuy_5-1760150580089.png
Senlent
Hi@Andrew101
1. Regarding the CAN speed, as I mentioned, the CAN module configuration is correct, at 1M. You can check the ACK bit width; theoretically, it should be 1us. If it's not, check your MCU module.
(I can't run your code properly; I don't know why you're mixing MCAL and Drivers.)
https://community.nxp.com/t5/S32K-Knowledge-Base/RTD600-MCAL-amp-IP-S32K3X4EVB-T172-FlexCAN-Example-...
2. Regarding the LPI2C speed, your "Clock_Ip_ReferencePoints" configuration is incorrect; the clock is not the I2C module's clock.
Senlent
Hi@Andrew101
I don't see problem with your flexcan settings, could you please share your test picture and your project so that I can take time to reproduce your issues.
Andrew101
Of course,
Let me tell you again my problem. As you can see, in the configuration, the baurate is 1 Mbs, but when I measure on logic analyzer , the signal is just around 400 Kbs. Here are the picture and the whole project. I used on S32K344 EVB SCH 53148 Rev B board and s32ds 3.6.3, RTD 6.0.0
Senlent
Hi@Andrew101
I think your measurement method is wrong.
You can use an oscilloscope to measure the minimum pulse width to calculate the bit rate.
In your configuration:
Tq = 5 / 80mhz = 62.5ns
CAN bit time = (1 + 8+ 5 + 2) * 62.5 = 1000ns
Bit rate = 1 / 1000ns = 1000K
Andrew101
Can you explain more details, please? I don't really understand. The configuration in the project I gave you is for 1000K. But the logic analyzer just recorded 400K. Additionally, when I debugged deeply into register, I saw a register CTRL1 with the field "PRESDIV" is set 4 but not 0. I don't know if it is the reason?
Senlent
Hi@Andrew101
The 400k you are currently displaying is not necessarily a single bit width, it may be multiple bits wide.
"when I debugged deeply into register, I saw a register CTRL1 with the field "PRESDIV" is set 4 but not 0"
In your configuration, the "Prescaler division factor is 5", so the PRESDIV should be 5-1 = 4, so it's correct.
Andrew101
Thanks for your answer. So back to my first question, I wonder that what's wrong with my project and config that CAN module can not reach at 1 Mbs? In the project, I reused the example code "lwip_baremetal_s32k344" and added some more peripherals. I don't know if it is the reason? Because I also tried with I2C and the problem is similar to CAN "Baurate of I2C I set is 400 Kbs but it just worked in 100 Kbs". I think I have some conflicts in the project but I can not find. If your project works well, please share with me!!!
Senlent
Hi@Andrew101
%3CLINGO-SUB%20id%3D%22lingo-sub-2184167%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ECAN%20baurate%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2184167%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20everyone%2C%3C%2FP%3E%3CP%3EI%20have%20a%20problem%20with%20baurate%20in%20classic%20CAN%20in%20S32K3.%20I%20reuse%20an%20example%20code%20%22lwip_baremetal_s32k344%22%20and%20add%20FlexCAN.%20Although%20I%20configed%20in%20clock%20diagram%20tab%2C%20FlexCAN%20tab%20and%20the%20S32DS%20also%20return%20the%20approriate%20value%20is%3CSTRONG%3E%201%20MHz%3C%2FSTRONG%3E%20(see%20the%20pictures%20below%20for%20more%20details)%2C%20when%20I%20measured%20CAN_TX%20by%20logic%20analyzer%2C%20I%20see%20the%20baurate%20was%20just%20around%20%3CSTRONG%3E400Khz.%3C%2FSTRONG%3E%20Does%20anyone%20have%20the%20same%20problem%20with%20me%3F%20Thanks%20for%20your%20help.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22khanhhuy_0-1760150358678.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22khanhhuy_0-1760150358678.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F360320i6497536DF02B2567%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22khanhhuy_0-1760150358678.png%22%20alt%3D%22khanhhuy_0-1760150358678.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22khanhhuy_1-1760150382392.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22khanhhuy_1-1760150382392.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F360321iD39F4BF4189CE184%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22khanhhuy_1-1760150382392.png%22%20alt%3D%22khanhhuy_1-1760150382392.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22khanhhuy_2-1760150458852.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22khanhhuy_2-1760150458852.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F360323iA41550A9107789DF%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22khanhhuy_2-1760150458852.png%22%20alt%3D%22khanhhuy_2-1760150458852.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22khanhhuy_3-1760150484430.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22khanhhuy_3-1760150484430.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F360324iA2EF859B6B87C5EC%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22khanhhuy_3-1760150484430.png%22%20alt%3D%22khanhhuy_3-1760150484430.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22khanhhuy_4-1760150505078.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22khanhhuy_4-1760150505078.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F360325iC318C288248269A4%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22khanhhuy_4-1760150505078.png%22%20alt%3D%22khanhhuy_4-1760150505078.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22khanhhuy_5-1760150580089.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22khanhhuy_5-1760150580089.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F360326i0D8BF27B576519C9%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22khanhhuy_5-1760150580089.png%22%20alt%3D%22khanhhuy_5-1760150580089.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2184647%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CAN%20baurate%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2184647%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%40%3CSPAN%3EAndrew101%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E1.%20Regarding%20the%20CAN%20speed%2C%20as%20I%20mentioned%2C%20the%20CAN%20module%20configuration%20is%20correct%2C%20at%201M.%20You%20can%20check%20the%20ACK%20bit%20width%3B%20theoretically%2C%20it%20should%20be%201us.%20If%20it's%20not%2C%20check%20your%20MCU%20module.%3CBR%20%2F%3E(I%20can't%20run%20your%20code%20properly%3B%20I%20don't%20know%20why%20you're%20mixing%20MCAL%20and%20Drivers.)%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K-Knowledge-Base%2FRTD600-MCAL-amp-IP-S32K3X4EVB-T172-FlexCAN-Example-Interrupt%2Fta-p%2F2142069%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K-Knowledge-Base%2FRTD600-MCAL-amp-IP-S32K3X4EVB-T172-FlexCAN-Example-Interrupt%2Fta-p%2F2142069%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E2.%20Regarding%20the%20LPI2C%20speed%2C%20your%20%22Clock_Ip_ReferencePoints%22%20configuration%20is%20incorrect%3B%20the%20clock%20is%20not%20the%20I2C%20module's%20clock.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2184551%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CAN%20baurate%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2184551%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EThanks%20for%20your%20answer.%20So%20back%20to%20my%20first%20question%2C%20I%20wonder%20that%20what's%20wrong%20with%20my%20project%20and%20config%20that%20CAN%20module%20can%20not%20reach%20at%201%20Mbs%3F%20In%20the%20project%2C%20I%20reused%20the%20example%20code%20%22lwip_baremetal_s32k344%22%20and%20added%20some%20more%20peripherals.%20I%20don't%20know%20if%20it%20is%20the%20reason%3F%20Because%20I%20also%20tried%20with%20I2C%20and%20the%20problem%20is%20similar%20to%20CAN%20%22Baurate%20of%20I2C%20I%20set%20is%20400%20Kbs%20but%20it%20just%20worked%20in%20100%20Kbs%22.%20I%20think%20I%20have%20some%20conflicts%20in%20the%20project%20but%20I%20can%20not%20find.%20If%20your%20project%20works%20well%2C%20please%20share%20with%20me!!!%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2184513%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CAN%20baurate%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2184513%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%40%3CSPAN%3EAndrew101%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EThe%20400k%20you%20are%20currently%20displaying%20is%20not%20necessarily%20a%20single%20bit%20width%2C%20it%20may%20be%20multiple%20bits%20wide.%3C%2FP%3E%0A%3CP%3E%22%3CSPAN%3Ewhen%20I%20debugged%20deeply%20into%20register%2C%20I%20saw%20a%20register%20CTRL1%20with%20the%20field%20%22PRESDIV%22%20is%20set%204%20but%20not%200%3C%2FSPAN%3E%22%3C%2FP%3E%0A%3CP%3EIn%20your%20configuration%2C%20the%26nbsp%3B%22Prescaler%20division%20factor%20is%205%22%2C%20so%20the%20PRESDIV%20should%20be%205-1%20%3D%204%2C%20so%20it's%20correct.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2184483%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CAN%20baurate%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2184483%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ECan%20you%20explain%20more%20details%2C%20please%3F%20I%20don't%20really%20understand.%20The%20configuration%20in%20the%20project%20I%20gave%20you%20is%20for%201000K.%20But%20the%20logic%20analyzer%20just%20recorded%20400K.%20Additionally%2C%20when%20I%20debugged%20deeply%20into%20register%2C%20I%20saw%20a%20register%20CTRL1%20with%20the%20field%20%22PRESDIV%22%20is%20set%204%20but%20not%200.%20I%20don't%20know%20if%20it%20is%20the%20reason%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2184473%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CAN%20baurate%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2184473%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22mailto%3AHi%40Andrew101%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EHi%40%3CSPAN%3EAndrew101%3C%2FSPAN%3E%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EI%20think%20your%20measurement%20method%20is%20wrong.%3C%2FP%3E%0A%3CP%3EYou%20can%20use%20an%20oscilloscope%20to%20measure%20the%20minimum%20pulse%20width%20to%20calculate%20the%20bit%20rate.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Senlent_0-1760324467302.png%22%20style%3D%22width%3A%20590px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Senlent_0-1760324467302.png%22%20style%3D%22width%3A%20590px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F360391i8B71675DF2009E97%2Fimage-dimensions%2F590x367%3Fv%3Dv2%22%20width%3D%22590%22%20height%3D%22367%22%20role%3D%22button%22%20title%3D%22Senlent_0-1760324467302.png%22%20alt%3D%22Senlent_0-1760324467302.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EIn%20your%20configuration%3A%3C%2FP%3E%0A%3CP%3ETq%20%3D%205%20%2F%2080mhz%20%3D%2062.5ns%3C%2FP%3E%0A%3CP%3ECAN%20bit%20time%20%3D%20(1%20%2B%208%2B%205%20%2B%202)%20*%2062.5%20%3D%201000ns%3C%2FP%3E%0A%3CP%3EBit%20rate%20%3D%201%20%2F%201000ns%20%3D%201000K%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2184292%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CAN%20baurate%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2184292%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EOf%20course%2C%3CBR%20%2F%3ELet%20me%20tell%20you%20again%20my%20problem.%20As%20you%20can%20see%2C%20in%20the%20configuration%2C%20the%20baurate%20is%201%20Mbs%2C%20but%20when%20I%20measure%20on%20logic%20analyzer%20%2C%20the%20signal%20is%20just%20around%20400%20Kbs.%20Here%20are%20the%20picture%20and%20the%20whole%20project.%20I%20used%20on%20S32K344%20EVB%20SCH%2053148%20Rev%20B%20board%20and%20s32ds%203.6.3%2C%20RTD%206.0.0%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Andrew101_0-1760177024908.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Andrew101_0-1760177024908.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F360363iFB38AFF082031138%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Andrew101_0-1760177024908.png%22%20alt%3D%22Andrew101_0-1760177024908.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Andrew101_1-1760177276714.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Andrew101_1-1760177276714.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F360365i6F07BEEAD30FE7AD%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Andrew101_1-1760177276714.png%22%20alt%3D%22Andrew101_1-1760177276714.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Andrew101_2-1760177292627.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Andrew101_2-1760177292627.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F360366iCEE80613BD9F4745%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Andrew101_2-1760177292627.png%22%20alt%3D%22Andrew101_2-1760177292627.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2184279%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CAN%20baurate%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2184279%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%40%3CSPAN%3EAndrew101%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EI%20don't%20see%20problem%20with%20your%20flexcan%20settings%2C%20could%20you%20please%20share%20your%20test%20picture%20and%20your%20project%20so%20that%20I%20can%20take%20time%20to%20reproduce%20your%20issues.%3C%2FP%3E%3C%2FLINGO-BODY%3E
