CAN baurate error
CAN baurate error
3,526 次查看
Andrew101
Hello everyone,
I have a problem with baurate in classic CAN in S32K3. I reuse an example code "lwip_baremetal_s32k344" and add FlexCAN. Although I configed in clock diagram tab, FlexCAN tab and the S32DS also return the approriate value is 1 MHz (see the pictures below for more details), when I measured CAN_TX by logic analyzer, I see the baurate was just around 400Khz. Does anyone have the same problem with me? Thanks for your help.
khanhhuy_2-1760150458852.pngkhanhhuy_3-1760150484430.pngkhanhhuy_4-1760150505078.pngkhanhhuy_5-1760150580089.png
3,370 次查看
Senlent
Hi@Andrew101
1. Regarding the CAN speed, as I mentioned, the CAN module configuration is correct, at 1M. You can check the ACK bit width; theoretically, it should be 1us. If it's not, check your MCU module.
(I can't run your code properly; I don't know why you're mixing MCAL and Drivers.)
https://community.nxp.com/t5/S32K-Knowledge-Base/RTD600-MCAL-amp-IP-S32K3X4EVB-T172-FlexCAN-Example-...
2. Regarding the LPI2C speed, your "Clock_Ip_ReferencePoints" configuration is incorrect; the clock is not the I2C module's clock.
7 回复数
3,478 次查看
Senlent
Hi@Andrew101
I don't see problem with your flexcan settings, could you please share your test picture and your project so that I can take time to reproduce your issues.
3,474 次查看
Andrew101
Of course,
Let me tell you again my problem. As you can see, in the configuration, the baurate is 1 Mbs, but when I measure on logic analyzer , the signal is just around 400 Kbs. Here are the picture and the whole project. I used on S32K344 EVB SCH 53148 Rev B board and s32ds 3.6.3, RTD 6.0.0
3,405 次查看
Senlent
Hi@Andrew101
I think your measurement method is wrong.
You can use an oscilloscope to measure the minimum pulse width to calculate the bit rate.
In your configuration:
Tq = 5 / 80mhz = 62.5ns
CAN bit time = (1 + 8+ 5 + 2) * 62.5 = 1000ns
Bit rate = 1 / 1000ns = 1000K
3,403 次查看
Andrew101
Can you explain more details, please? I don't really understand. The configuration in the project I gave you is for 1000K. But the logic analyzer just recorded 400K. Additionally, when I debugged deeply into register, I saw a register CTRL1 with the field "PRESDIV" is set 4 but not 0. I don't know if it is the reason?
3,384 次查看
Senlent
Hi@Andrew101
The 400k you are currently displaying is not necessarily a single bit width, it may be multiple bits wide.
"when I debugged deeply into register, I saw a register CTRL1 with the field "PRESDIV" is set 4 but not 0"
In your configuration, the "Prescaler division factor is 5", so the PRESDIV should be 5-1 = 4, so it's correct.
3,381 次查看
Andrew101
Thanks for your answer. So back to my first question, I wonder that what's wrong with my project and config that CAN module can not reach at 1 Mbs? In the project, I reused the example code "lwip_baremetal_s32k344" and added some more peripherals. I don't know if it is the reason? Because I also tried with I2C and the problem is similar to CAN "Baurate of I2C I set is 400 Kbs but it just worked in 100 Kbs". I think I have some conflicts in the project but I can not find. If your project works well, please share with me!!!
3,371 次查看
Senlent
Hi@Andrew101
%3CLINGO-SUB%20id%3D%22lingo-sub-2184167%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ECAN%20%E5%8C%85%E6%8B%89%E7%89%B9%E9%94%99%E8%AF%AF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2184167%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A4%A7%E5%AE%B6%E5%A5%BD%3C%2FP%3E%3CP%3E%E6%88%91%E5%9C%A8%20S32K3%20%E4%B8%AD%E7%9A%84%E7%BB%8F%E5%85%B8%20CAN%20%E4%B8%AD%E9%81%87%E5%88%B0%E4%BA%86%E4%B8%80%E4%B8%AA%E6%9C%89%E5%85%B3%E7%89%9B%E7%A3%BA%E9%85%B8%E7%9B%90%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%E6%88%91%E9%87%8D%E5%A4%8D%E4%BD%BF%E7%94%A8%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%20%22%20lwip_baremetal_s32k344%20%22%20%E7%84%B6%E5%90%8E%E6%B7%BB%E5%8A%A0%E4%BA%86%20FlexCAN%E3%80%82%E5%B0%BD%E7%AE%A1%E6%88%91%E5%9C%A8%E6%97%B6%E9%92%9F%E5%9B%BE%E7%A8%8E%E5%8A%A1%E6%91%8A%E9%94%80%E6%94%B6%E7%9B%8A%E3%80%81FlexCan%20%E7%A8%8E%E5%8A%A1%E6%91%8A%E9%94%80%E6%94%B6%E7%9B%8A%E5%92%8C%20S32DS%20%E4%B8%AD%E8%BF%9B%E8%A1%8C%E4%BA%86%E9%85%8D%E7%BD%AE%EF%BC%8C%E4%BD%86%E8%BF%94%E5%9B%9E%E7%9A%84%E6%AD%A3%E7%A1%AE%E5%80%BC%E6%98%AF%3CSTRONG%3E%201%20MHz%3C%2FSTRONG%3E%20%EF%BC%88%E6%9B%B4%E5%A4%9A%E7%BB%86%E8%8A%82%E8%A7%81%E4%B8%8B%E5%9B%BE%EF%BC%89%EF%BC%8C%E4%BD%86%E6%98%AF%E5%BD%93%E6%88%91%E7%94%A8%E9%80%BB%E8%BE%91%E5%88%86%E6%9E%90%E5%99%A8%E6%B5%8B%E9%87%8F%20CAN_TX%20%E6%97%B6%EF%BC%8C%E6%88%91%E5%8F%91%E7%8E%B0%E4%BF%9D%E4%BF%AE%E7%8E%87%E5%88%9A%E5%A5%BD%E5%9C%A8%3CSTRONG%3E%20400Khz%20%E5%B7%A6%E5%8F%B3%E3%80%82%3C%2FSTRONG%3E%E6%9C%89%E4%BA%BA%E5%92%8C%E6%88%91%E6%9C%89%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%E5%90%97%EF%BC%9F%E8%B0%A2%E8%B0%A2%E6%82%A8%E7%9A%84%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22khanhhuy_0-1760150358678.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22khanhhuy_0-1760150358678.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F360320i6497536DF02B2567%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22khanhhuy_0-1760150358678.png%22%20alt%3D%22khanhhuy_0-1760150358678.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22khanhhuy_1-1760150382392.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22khanhhuy_1-1760150382392.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F360321iD39F4BF4189CE184%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22khanhhuy_1-1760150382392.png%22%20alt%3D%22khanhhuy_1-1760150382392.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22khanhhuy_2-1760150458852.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22khanhhuy_2-1760150458852.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F360323iA41550A9107789DF%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22khanhhuy_2-1760150458852.png%22%20alt%3D%22khanhhuy_2-1760150458852.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22khanhhuy_3-1760150484430.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22khanhhuy_3-1760150484430.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F360324iA2EF859B6B87C5EC%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22khanhhuy_3-1760150484430.png%22%20alt%3D%22khanhhuy_3-1760150484430.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22khanhhuy_4-1760150505078.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22khanhhuy_4-1760150505078.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F360325iC318C288248269A4%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22khanhhuy_4-1760150505078.png%22%20alt%3D%22khanhhuy_4-1760150505078.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22khanhhuy_5-1760150580089.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22khanhhuy_5-1760150580089.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F360326i0D8BF27B576519C9%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22khanhhuy_5-1760150580089.png%22%20alt%3D%22khanhhuy_5-1760150580089.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2184647%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CAN%20baurate%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2184647%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%40%3CSPAN%3EAndrew101%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E1.%E5%85%B3%E4%BA%8E%20CAN%20%E9%80%9F%E5%BA%A6%EF%BC%8C%E5%A6%82%E5%89%8D%E6%89%80%E8%BF%B0%EF%BC%8CCAN%20%E6%A8%A1%E5%9D%97%E7%9A%84%E9%85%8D%E7%BD%AE%E6%98%AF%E6%AD%A3%E7%A1%AE%E7%9A%84%EF%BC%8C%E4%B8%BA%201M%E3%80%82%E6%82%A8%E5%8F%AF%E4%BB%A5%E6%A3%80%E6%9F%A5%20ACK%20%E4%BD%8D%E5%AE%BD%EF%BC%9B%E7%90%86%E8%AE%BA%E4%B8%8A%EF%BC%8C%E5%AE%83%E5%BA%94%E8%AF%A5%E6%98%AF%201us%E3%80%82%E5%A6%82%E6%9E%9C%E4%B8%8D%E6%98%AF%EF%BC%8C%E8%AF%B7%E6%A3%80%E6%9F%A5%E6%82%A8%E7%9A%84%20MCU%20%E6%A8%A1%E5%9D%97%E3%80%82%3CBR%20%2F%3E(%E6%88%91%E6%97%A0%E6%B3%95%E6%AD%A3%E5%B8%B8%E8%BF%90%E8%A1%8C%E4%BD%A0%E7%9A%84%E4%BB%A3%E7%A0%81%EF%BC%9B%E6%88%91%E4%B8%8D%E7%9F%A5%E9%81%93%E4%BD%A0%E4%B8%BA%E4%BB%80%E4%B9%88%E8%A6%81%E6%8A%8A%20MCAL%20%E5%92%8C%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%B7%B7%E5%9C%A8%E4%B8%80%E8%B5%B7%EF%BC%89%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K-Knowledge-Base%2FRTD600-MCAL-amp-IP-S32K3X4EVB-T172-FlexCAN-Example-Interrupt%2Fta-p%2F2142069%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K-Knowledge-Base%2FRTD600-MCAL-amp-IP-S32K3X4EVB-T172-FlexCAN-Example-Interrupt%2Fta-p%2F2142069%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E2.%E5%85%B3%E4%BA%8E%20LPI2C%20%E9%80%9F%E5%BA%A6%EF%BC%8C%E6%82%A8%E7%9A%84%22Clock_Ip_ReferencePoints%22%20%E9%85%8D%E7%BD%AE%E4%B8%8D%E6%AD%A3%E7%A1%AE%EF%BC%9B%E6%97%B6%E9%92%9F%E4%B8%8D%E6%98%AF%20I2C%20%E6%A8%A1%E5%9D%97%E7%9A%84%E6%97%B6%E9%92%9F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2184551%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CAN%20baurate%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2184551%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E8%B0%A2%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E7%AD%94%E3%80%82%E9%82%A3%E4%B9%88%E5%9B%9E%E5%88%B0%E6%88%91%E7%9A%84%E7%AC%AC%E4%B8%80%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%8C%E6%88%91%E6%83%B3%E7%9F%A5%E9%81%93%E6%88%91%E7%9A%84%E9%A1%B9%E7%9B%AE%E5%92%8C%E9%85%8D%E7%BD%AE%E5%87%BA%E4%BA%86%E4%BB%80%E4%B9%88%E9%97%AE%E9%A2%98%EF%BC%8C%E5%AF%BC%E8%87%B4%20CAN%20%E6%A8%A1%E5%9D%97%E6%97%A0%E6%B3%95%E8%BE%BE%E5%88%B0%201%20Mbs%EF%BC%9F%E5%9C%A8%E9%A1%B9%E7%9B%AE%E4%B8%AD%EF%BC%8C%E6%88%91%E9%87%8D%E5%A4%8D%E4%BD%BF%E7%94%A8%E4%BA%86%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%20%22%20lwip_baremetal_s32k344%20%22%20%E5%B9%B6%E6%B7%BB%E5%8A%A0%E4%BA%86%E6%9B%B4%E5%A4%9A%E5%A4%96%E5%9B%B4%E8%AE%BE%E5%A4%87%E3%80%82%E6%88%91%E4%B8%8D%E7%9F%A5%E9%81%93%E6%98%AF%E4%B8%8D%E6%98%AF%E8%BF%99%E4%B8%AA%E5%8E%9F%E5%9B%A0%EF%BC%9F%E5%9B%A0%E4%B8%BA%E6%88%91%E4%B9%9F%E8%AF%95%E8%BF%87%20I2C%EF%BC%8C%E9%97%AE%E9%A2%98%E4%B8%8E%20CAN%20%E7%9B%B8%E4%BC%BC%22%EF%BC%8C%E6%88%91%E8%AE%BE%E5%AE%9A%20I2C%20%E7%9A%84%E9%80%9F%E7%8E%87%E4%B8%BA%20400%20Kbs%EF%BC%8C%E4%BD%86%E5%AE%83%E5%8F%AA%E8%83%BD%E5%9C%A8%20100%20Kbs%22%20%E4%B8%8B%E5%B7%A5%E4%BD%9C%E3%80%82%E6%88%91%E8%A7%89%E5%BE%97%E9%A1%B9%E7%9B%AE%E4%B8%AD%E6%9C%89%E4%B8%80%E4%BA%9B%E5%86%B2%E7%AA%81%EF%BC%8C%E4%BD%86%E6%88%91%E6%89%BE%E4%B8%8D%E5%88%B0%E3%80%82%E5%A6%82%E6%9E%9C%E6%82%A8%E7%9A%84%E9%A1%B9%E7%9B%AE%E8%BF%90%E8%A1%8C%E8%89%AF%E5%A5%BD%EF%BC%8C%E8%AF%B7%E4%B8%8E%E6%88%91%E5%88%86%E4%BA%AB%EF%BC%81.....%EF%BC%81%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2184513%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CAN%20baurate%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2184513%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%40%3CSPAN%3EAndrew101%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E5%BD%93%E5%89%8D%E6%98%BE%E7%A4%BA%E7%9A%84%20400k%20%E4%B8%8D%E4%B8%80%E5%AE%9A%E6%98%AF%E5%8D%95%E4%B8%AA%E4%BD%8D%E5%AE%BD%EF%BC%8C%E5%8F%AF%E8%83%BD%E6%98%AF%E5%A4%9A%E4%B8%AA%E4%BD%8D%E5%AE%BD%E3%80%82%3C%2FP%3E%0A%3CP%3E%22%3CSPAN%3E%E5%BD%93%E6%88%91%E6%B7%B1%E5%85%A5%E8%B0%83%E8%AF%95%E5%AF%84%E5%AD%98%E5%99%A8%E6%97%B6%EF%BC%8C%E6%88%91%E7%9C%8B%E5%88%B0%E5%AF%84%E5%AD%98%E5%99%A8%20CTRL1%20%E7%9A%84%22PRESDIV%22%20%E5%AD%97%E6%AE%B5%E8%AE%BE%E7%BD%AE%E4%B8%BA%204%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%200%3C%2FSPAN%3E%22%3C%2FP%3E%0A%3CP%3E%E5%9C%A8%E6%82%A8%E7%9A%84%E9%85%8D%E7%BD%AE%E4%B8%AD%EF%BC%8C%22%E9%A2%84%E5%88%86%E9%A2%91%E5%99%A8%E7%9A%84%E5%88%86%E9%A2%91%E5%9B%A0%E5%AD%90%E6%98%AF%205%22%20%EF%BC%8C%E5%9B%A0%E6%AD%A4%20PRESDIV%20%E5%BA%94%E8%AF%A5%E6%98%AF%205-1%20%3D%204%EF%BC%8C%E6%89%80%E4%BB%A5%E6%98%AF%E6%AD%A3%E7%A1%AE%E7%9A%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2184483%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CAN%20baurate%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2184483%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%83%BD%E5%90%A6%E8%AF%B7%E6%82%A8%E8%AF%A6%E7%BB%86%E8%A7%A3%E9%87%8A%E4%B8%80%E4%B8%8B%EF%BC%9F%E6%88%91%E7%9C%9F%E7%9A%84%E4%B8%8D%E6%98%8E%E7%99%BD%E3%80%82%E6%88%91%E7%BB%99%E4%BD%A0%E7%9A%84%E9%A1%B9%E7%9B%AE%E4%B8%AD%E7%9A%84%E9%85%8D%E7%BD%AE%E6%98%AF%201000K%E3%80%82%E4%BD%86%E9%80%BB%E8%BE%91%E5%88%86%E6%9E%90%E4%BB%AA%E5%88%9A%E5%88%9A%E8%AE%B0%E5%BD%95%E4%BA%86%20400K%E3%80%82%E6%AD%A4%E5%A4%96%EF%BC%8C%E5%BD%93%E6%88%91%E6%B7%B1%E5%85%A5%E8%B0%83%E8%AF%95%E5%AF%84%E5%AD%98%E5%99%A8%E6%97%B6%EF%BC%8C%E6%88%91%E7%9C%8B%E5%88%B0%E5%AF%84%E5%AD%98%E5%99%A8%20CTRL1%20%E7%9A%84%22PRESDIV%22%20%E5%AD%97%E6%AE%B5%E8%AE%BE%E7%BD%AE%E4%B8%BA%204%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%200%E3%80%82%E4%B8%8D%E7%9F%A5%E9%81%93%E6%98%AF%E4%B8%8D%E6%98%AF%E8%BF%99%E4%B8%AA%E5%8E%9F%E5%9B%A0%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2184473%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CAN%20baurate%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2184473%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22mailto%3AHi%40Andrew101%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E4%BD%A0%E5%A5%BD%40%3CSPAN%3EAndrew101%3C%2FSPAN%3E%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%88%91%E8%AE%A4%E4%B8%BA%E4%BD%A0%E7%9A%84%E6%B5%8B%E9%87%8F%E6%96%B9%E6%B3%95%E6%98%AF%E9%94%99%E8%AF%AF%E7%9A%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E7%A4%BA%E6%B3%A2%E5%99%A8%E6%B5%8B%E9%87%8F%E6%9C%80%E5%B0%8F%E8%84%89%E5%86%B2%E5%AE%BD%E5%BA%A6%E4%BB%A5%E8%AE%A1%E7%AE%97%E6%AF%94%E7%89%B9%E7%8E%87%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Senlent_0-1760324467302.png%22%20style%3D%22width%3A%20590px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Senlent_0-1760324467302.png%22%20style%3D%22width%3A%20590px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F360391i8B71675DF2009E97%2Fimage-dimensions%2F590x367%3Fv%3Dv2%22%20width%3D%22590%22%20height%3D%22367%22%20role%3D%22button%22%20title%3D%22Senlent_0-1760324467302.png%22%20alt%3D%22Senlent_0-1760324467302.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E5%9C%A8%E6%82%A8%E7%9A%84%E9%85%8D%E7%BD%AE%E4%B8%AD%EF%BC%9A%3C%2FP%3E%0A%3CP%3ETq%20%3D%205%20%2F%2080mhz%20%3D%2062.5ns%3C%2FP%3E%0A%3CP%3ECAN%20%E4%BD%8D%E6%97%B6%E9%97%B4%20%3D%20(1%20%2B%208%2B%205%20%2B%202)%20*%2062.5%20%3D%201000ns%3C%2FP%3E%0A%3CP%3E%E6%AF%94%E7%89%B9%E7%8E%87%20%3D%201%20%2F%201000ns%20%3D%201000K%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2184292%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CAN%20baurate%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2184292%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%BD%93%E7%84%B6%EF%BC%8C%3CBR%20%2F%3E%EF%BC%8C%E8%AE%A9%E6%88%91%E5%86%8D%E5%91%8A%E8%AF%89%E4%BD%A0%E4%B8%80%E6%AC%A1%E6%88%91%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%E5%A6%82%E6%82%A8%E6%89%80%E8%A7%81%EF%BC%8C%E5%9C%A8%E9%85%8D%E7%BD%AE%E4%B8%AD%EF%BC%8C%E4%BF%A1%E5%8F%B7%E4%BC%A0%E8%BE%93%E9%80%9F%E7%8E%87%E4%B8%BA%201%20Mbs%EF%BC%8C%E4%BD%86%E5%BD%93%E6%88%91%E7%94%A8%E9%80%BB%E8%BE%91%E5%88%86%E6%9E%90%E4%BB%AA%E6%B5%8B%E9%87%8F%E6%97%B6%EF%BC%8C%E4%BF%A1%E5%8F%B7%E4%BC%A0%E8%BE%93%E9%80%9F%E7%8E%87%E4%BB%85%E4%B8%BA%20400%20Kbs%20%E5%B7%A6%E5%8F%B3%E3%80%82%E4%B8%8B%E9%9D%A2%E6%98%AF%E5%9B%BE%E7%89%87%E5%92%8C%E6%95%B4%E4%B8%AA%E9%A1%B9%E7%9B%AE%E3%80%82%E6%88%91%E5%9C%A8%20S32K344%20EVB%20SCH%2053148%20Rev%20B%20%E6%9D%BF%E5%92%8C%20s32ds%203.6.3%20%E4%B8%8A%E4%BD%BF%E7%94%A8%E8%BF%87%EF%BC%8CRTD%206.0.0%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Andrew101_0-1760177024908.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Andrew101_0-1760177024908.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F360363iFB38AFF082031138%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Andrew101_0-1760177024908.png%22%20alt%3D%22Andrew101_0-1760177024908.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Andrew101_1-1760177276714.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Andrew101_1-1760177276714.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F360365i6F07BEEAD30FE7AD%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Andrew101_1-1760177276714.png%22%20alt%3D%22Andrew101_1-1760177276714.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Andrew101_2-1760177292627.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Andrew101_2-1760177292627.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F360366iCEE80613BD9F4745%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Andrew101_2-1760177292627.png%22%20alt%3D%22Andrew101_2-1760177292627.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2184279%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CAN%20baurate%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2184279%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%40%3CSPAN%3EAndrew101%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%88%91%E7%9C%8B%E4%B8%8D%E5%87%BA%E6%82%A8%E7%9A%84%E6%9F%94%E6%80%A7%E6%89%AB%E6%8F%8F%E8%AE%BE%E7%BD%AE%E6%9C%89%E9%97%AE%E9%A2%98%EF%BC%8C%E8%83%BD%E5%90%A6%E8%AF%B7%E6%82%A8%E6%8F%90%E4%BE%9B%E6%B5%8B%E8%AF%95%E5%9B%BE%E7%89%87%E5%92%8C%E9%A1%B9%E7%9B%AE%EF%BC%8C%E4%BB%A5%E4%BE%BF%E6%88%91%E8%8A%B1%E6%97%B6%E9%97%B4%E9%87%8D%E7%8E%B0%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
