One or more Launch Configurations need to be updated?
1,628 次查看
jeffcharles
I just installed CW10.7 the other day. The Development Studio gives the following warning when I build a new project based on MC9S12ZVL32. After I click the OK button, it reports a error. How to solve this problem?
1,558 次查看
dianabatrlova
Your issue is probably caused because of wrong installation path.
Did you change the default installation path for CodeWarrior?
It should be located in "C:\Freescale" directory.
So, the solution is to install the CodeWarrior again, but into a default folder.
I hope it helps you.
Diana
1,559 次查看
dianabatrlova
Diana
