Is a KSDK_1.1.0 based fsl_usb_device_cdc_class PEx component forthcoming?
(ie similar to fsl_usb_device_msd_class or fsl_usb_device_hid_class)
已解决! 转到解答。
 marek_neuzil
			marek_neuzil
The fsl_usb_device_cdc_class PEx component will be available in KSDK 1.3.0 release this year (Q3/2015).
Marek Neuzil
 marek_neuzil
			marek_neuzil
I have checked the current status and the fsl_usb_device_cdc_class PEx component support has been postponed. This PEx component will not be available in KSDK 1.3.0 release in September. But the Kinetis SDK USB CDC drivers are available, see for example documentation in KSDK_1.2.0\doc\usb\ folder (these USB CDC drivers can be used in any Kinetis project).
Marek Neuzil
 michaelsteffenf
			michaelsteffenf
		Marek,
Is there some documentation or guide on implementing our USB CDC Class driver into an existing KSDK PEx project. I've got a customer using PEx for the entire project and he wants to use the PEx CDC component, but its not available, nor will be available in KSDK 2.0. How can he implement the example USB CDC project into his PEx project?
Mike
