KDS porting
KDS porting
2,594 次查看
vigneshbalaji
Senior Contributor I
I want to port this example project in CodeWarrior which I have attached here to KDS 3.2. ? Please check it on your side and provide me a working KDS project of the same explaining the changes that you have done.
Original Attachment has been moved to: kds_porting.zip
标记 (3)
2,406 次查看
Hi VIGNESH,
Sure , i create one new KDS project ,then copy your file ,
then add the "Includes paths" :
Alice
4 回复数
2,406 次查看
I have configure it , please check the attachment .
Alice
2,406 次查看
vigneshbalaji
Hi Alice,
            Thanks a lot.I am able to build and compile with the project and add things easily.
1)Can you please tell me what changes you have done compared to project which I gave you?
2,407 次查看
Hi VIGNESH,
Alice
2,406 次查看
vigneshbalaji
Hi Alice,
             Instead of the two dots specifying the path.Can I use ${ProjName} Variable? in the linker includes path???
