clock initilisation for mc9s12G128
4,743 次查看
War123
hello, i am trying to initilise the clock for mc9s12G128 microcontroller. As i am new in coding can u help me how to initilise the clock using embedded c?
4,735 次查看
lama
You can find
G240-PLL-PBE_mode-CW51
G240-PLL-PEE_mode-CW51
G240-PLL-PEI_mode-CW51
.... and something more at:
https://community.nxp.com/t5/S12-MagniV-Microcontrollers/S12G-Examples-Pack/ta-p/1103919
Ladislav
4,704 次查看
War123
thanks for reply, it really helpful.
I wanted to know that if i want to test code for mc9s12G128 on sw, is any sw like proteus to test and verify the code before test on hardware.
4,699 次查看
lama
unfortunately, the simulator features were not implemented for S12G devices.
However, if you want to simulate algorithms, routines, some principles you can still use CodeWarrior and open target for simulator but select device S12P which has the same core and a lot of features. I know it is not full simulation but it helps to check some principles and routines.
Ladislav
标记 (1)
4,736 次查看
lama
You can find
Ladislav
