S12G Examples Pack
S12G Examples Pack
S12G Examples Pack
Example code pack for S12G contains simple code examples how to initialize and how to use MCU module/feature.
List of examples:
G128-API_wakeup_from_Stop_Mode
G128-Clock and COP examples
G128-Interrupt_catcher-CW51
G128-LIN-CW51
G128-PLL_PEEmode-CW51
G128-Security-CW51
G240-API+STOP-CW51
G240-API-CW51
G240-ATD+GPIO-CW51
G240-ATD-Continuous_conversion_with_interrupt-CW51
G240-ATD-Multichannel_single_conversion-CW51
G240-ATD-Single_conversion-CW51
G240-Checksum-CW51
G240-Flash-CW51
G240-PLL-PBE_mode-CW51
G240-PLL-PEE_mode-CW51
G240-PLL-PEI_mode-CW51
G240-TIM_50us_interval-CW51
G240-TIM_50us_period-CW51
GN32-EEPROM-EW-CW51
GN32-LIN-CW51
GN32-PWM16b_GPIO
GN32-PWM_8bit-CW51
GN32-SCI_SPI_Gateway-CW51
GN32-SCI_wake_up_from_stop-CW51
Oct-22-2013 Update:
I added G128-CAN-CW51, G240-SPI-MC33810-CW51, G240-SPI-Slave examples.
I added PLL calculator.
I fixed error in GN32-EEPROM-EW-CW51 example code.
Aug-21-2015 Update:
Updated G240-Flash-CW51 example code.
Removed image files and object code from projects (9MB->2MB size)
Comments
The attached zip file S12G_examples.zip can not be opened. Please attach the correct one. I only need the GN32-EEPROM-EW-CW51 example code. Thank you
Thank you for notification.
S12G Example Pack was reloaded.
RadekS
%3CLINGO-SUB%20id%3D%22lingo-sub-1103919%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES12G%20Examples%20Pack%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103919%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%20lang%3D%22EN-GB%22%20style%3D%22font-size%3A%2014pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3EExample%20code%20pack%20for%20S12G%20contains%20simple%20code%20examples%20how%20to%20initialize%20and%20how%20to%20use%20MCU%20module%2Ffeature.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-GB%22%20style%3D%22font-size%3A%2014pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3EList%20of%20examples%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EG128-API_wakeup_from_Stop_Mode%3C%2FP%3E%3CP%3EG128-Clock%20and%20COP%20examples%3C%2FP%3E%3CP%3EG128-Interrupt_catcher-CW51%3C%2FP%3E%3CP%3EG128-LIN-CW51%3C%2FP%3E%3CP%3EG128-PLL_PEEmode-CW51%3C%2FP%3E%3CP%3EG128-Security-CW51%3C%2FP%3E%3CP%3EG240-API%2BSTOP-CW51%3C%2FP%3E%3CP%3EG240-API-CW51%3C%2FP%3E%3CP%3EG240-ATD%2BGPIO-CW51%3C%2FP%3E%3CP%3EG240-ATD-Continuous_conversion_with_interrupt-CW51%3C%2FP%3E%3CP%3EG240-ATD-Multichannel_single_conversion-CW51%3C%2FP%3E%3CP%3EG240-ATD-Single_conversion-CW51%3C%2FP%3E%3CP%3EG240-Checksum-CW51%3C%2FP%3E%3CP%3EG240-Flash-CW51%3C%2FP%3E%3CP%3EG240-PLL-PBE_mode-CW51%3C%2FP%3E%3CP%3EG240-PLL-PEE_mode-CW51%3C%2FP%3E%3CP%3EG240-PLL-PEI_mode-CW51%3C%2FP%3E%3CP%3EG240-TIM_50us_interval-CW51%3C%2FP%3E%3CP%3EG240-TIM_50us_period-CW51%3C%2FP%3E%3CP%3EGN32-EEPROM-EW-CW51%3C%2FP%3E%3CP%3EGN32-LIN-CW51%3C%2FP%3E%3CP%3EGN32-PWM16b_GPIO%3C%2FP%3E%3CP%3EGN32-PWM_8bit-CW51%3C%2FP%3E%3CP%3EGN32-SCI_SPI_Gateway-CW51%3C%2FP%3E%3CP%3EGN32-SCI_wake_up_from_stop-CW51%3C%2FP%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3EOct-22-2013%20Update%3A%3C%2FP%3E%3CP%3EI%20added%20G128-CAN-CW51%2C%20G240-SPI-MC33810-CW51%2C%20G240-SPI-Slave%20examples.%3C%2FP%3E%3CP%3EI%20added%20PLL%20calculator.%3C%2FP%3E%3CP%3EI%20fixed%20error%20in%20GN32-EEPROM-EW-CW51%20example%20code.%3C%2FP%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3EAug-21-2015%20Update%3A%3C%2FP%3E%3CP%3EUpdated%20G240-Flash-CW51%20example%20code.%3CBR%20%2F%3ERemoved%20image%20files%20and%20object%20code%20from%20projects%20(9MB-%26gt%3B2MB%20size)%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1103919%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EGeneral%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103921%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S12G%20Examples%20Pack%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103921%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThank%20you%20for%20notification.%3C%2FP%3E%3CP%3ES12G%20Example%20Pack%20was%20reloaded.%3C%2FP%3E%3CP%3ERadekS%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103920%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S12G%20Examples%20Pack%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103920%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThe%20attached%20zip%20file%20S12G_examples.zip%20can%20not%20be%20opened.%20Please%20attach%20the%20correct%20one.%20I%20only%20need%20the%20GN32-EEPROM-EW-CW51%20example%20code.%20Thank%20you%3C%2FP%3E%3C%2FLINGO-BODY%3E
100% helpful (1/1)
Version history
Last update:
‎11-15-2012 11:37 AM
Updated by:
