Wireless Connectivity Knowledge Base
Discussions
Sort by:
The RW61x series is a highly integrated, low-power tri-radio wireless MCU with an integrated MCU and Wi-Fi® 6 + Bluetooth® Low Energy (LE) 5.4 / 802.15.4 radios designed for a broad array of applications, including connected smart home devices, enterprise and industrial automation, smart accessories and smart energy. The RW61x series MCU subsystem includes a 260 MHz Arm® Cortex®-M33 core with Trustzone™-M, 1.2 MB on-chip SRAM and a high-bandwidth Quad SPI interface with an on-the-fly decryption engine for securely accessing off-chip XIP flash. The RW61x series includes a full-featured 1x1 dual-band (2.4 GHz/5 GHz) 20 MHz Wi-Fi 6 (802.11ax) subsystem bringing higher throughput, better network efficiency, lower latency and improved range over previous generation Wi-Fi standards. The Bluetooth LE radio supports 2 Mbit/s high-speed data rate, long range and extended advertising.  The on-chip 802.15.4 radio can support the latest Thread mesh networking protocol. In addition, the RW612 can support Matter over Wi-Fi or Matter over Thread offering a common, interoperable application layer across ecosystems and products. NXP RW61x Block Diagram Documents RW610 Datasheet: RW610 Datasheet RW612 Datasheet: RW612 Datasheet RW61x User Manual: UM11865: RW61x User Manual RW61x Register Manual: RM00278: RX16x Registers   Certifications FRDM-RW612 Radio Equipment Directive Declaration of Conformity  User Guide Getting Started with FRDM-RW612 Quick Start Guide - FRDM-RW612 UG10185: RW612 Matter-Zigbee Bridge User Guide UG10178: Matter Demo Using NXP Chip Tool App for FRDM-RW612 and FRDM-MCXW71  UG10612: NXP Wi-Fi and Bluetooth Feature Debug for FRDM-RW612 UG10182: NXP 802.15.4 Demo Applications for FRDM-RW612 UG10160: Getting Started with Wireless on FRDM-RW612 Board Running RTOS  UG10171: NXP Wi-Fi and Bluetooth Demo Applications for FRDM-RW61X     RW61x Modules Azurewave: RW612 - AW-CU570 is a highly integrated, low-power tri-radio Wireless RW612 MCU with an integrated MCU and Wi-Fi 6 + Bluetooth Low Energy (LE) 5.2 / 802.15.4 radios designed for a broad array of applications. RW610 - AW-CU598 is a highly integrated, low-power tri-radio Wireless RW610 MCU with an integrated MCU and Wi-Fi 6 + Bluetooth Low Energy (LE) 5.3 radios designed for a broad array of applications U-blox: RW612 - IRIS-W10 Series are small, stand-alone, dual-band Wi-Fi and Bluetooth Low Energy wireless microcontroller unit (MCU) modules. The modules are ideal for users looking to add advanced wireless connectivity to their end products. RW610 - IRIS-W16 Series are small, stand-alone, dual-band Wi-Fi and Bluetooth Low Energy wireless modules, with everything needed for integration into end-products. The modules are ideal for users looking to add advanced wireless connectivity to their end products.  Murata: RW612 - LBES0ZZ2FR-580 Murata’s Type 2FR is a small and very high-performance module based on NXP RW612 combo chipset, supporting IEEE 802.11a/b/g/n/ac/ax + Bluetooth LE 5.4 / IEEE 802.15.4. RW610 - LBES0ZZ2FP-580 Type 2FR/2FP is a family of small and highly integrated multi-radio modules with built-in high-performance MCU with advanced security features for connected smart devices in smart homes, enterprise and industrial automation, smart accessories, and smart energy. It supports the latest Matter smart home connectivity protocol. California Eastern Laboratories (CEL): RW612 - CMP4612 is a fully integrated Dual-Band, Tri-mode (Wi-Fi 6, BT5.4, 802.15.4) radio, that includes a host MCU, Flash, RAM, peripherals, and numerous interfaces (SDIO, UART, USB, Ethernet. SPI, I2C) to support both HOSTLESS (RTOS) and HOSTED (NCP mode) architectures. CEL's solution includes either an on-board antenna or connector.   Evaluation boards  FRDM-RW612 FRDM-RW612 is a compact and scalable development board for rapid prototyping of the RW61x series of Wi-Fi 6 + Bluetooth Low Energy + 802.15.4 tri-radio wireless MCUs. It offers easy access to the MCU’s I/O's and peripherals, integrated open-standard serial interfaces, external flash memory and on-board MCU-Link debugger. FRDM-RW612 Getting Started Getting Started with FRDM-RW612 FRDM-RW612 User Manual: UM12160: FRDM-RW612 Board User Manual Current Measurement configuration: Remove the 0-ohms resistor R103 Solder a couple of pins in JP5. When trying to measure the RW61x current consumption, connect your current meter using the pins in JP5. When using the FRDM board in normal operation, connect a jumper to the pins in JP5.   u-blox   USB-IRIS-W1 The USB-IRIS-W1 development platform is built on the dual-band Wi-Fi 6 and Bluetooth LE module IRIS-W1, based on the NXP RW610/612 chip. The board is designed with a USB interface to simplify evaluation and prototyping directly from a PC. In addition to the IRIS-W1 module with integrated antenna, it also integrates four buttons, an RGB LED, and a USB/UART converter, to further support an easy evaluation. u-blox   EVK-IRIS-W1 The EVK-IRIS-W1 evaluation kit provides stand-alone use of the IRIS-W1 module series featuring the NXP RW610/612 chipset. Azurewave    AW-CU570-EVB Evaluation board for AW-CU570 module includes wireless MCU with Integrated Tri-radio Wi-Fi 6 + Bluetooth Low Energy 5.3 /802.15.4. Murata   2FR EVK Evaluation kit for Murata Type 2FR module (Murata part number LBES0ZZ2FR) includes 3 radios: Wi-Fi, BLE and 802.15.4. It is based on NXP’s RW612 chip. California Eastern Laboratories (CEL) CMP4612-2-EVB The CMP4612 Evaluation Board (CMP4612-2-EVB), based on the NXP RW612 chipset, features dual-band Wi-Fi 6, BLE 5.4 and 802.15.4 radios. The CMP4612 Evaluation Board includes an onboard Ethernet port and PHY hardware as well as an Arduino header, MCULink SWD, and USB ports. This board is designed to facilitate a seamless and efficient evaluation process for customers wanting a certified module for their end product.   Application Notes RM00287: Wi-Fi Driver API for SDK 2.16.100     The radio driver source code provides APIs to send and receive packets over the radio interfaces by communicating with the firmware images. This manual provides the reference documentation for the Wi-Fi driver and Wi-Fi Connection Manager.  UM12133: NXP NCP Application Guide for RW612 with MCU Host - User manual     This user manual describes: • The NXP NCP application for RW612 with MCU host platform i.MX RT1060 as example. • The hardware connections for one of the four supported interfaces to enable NCP mode on the NXP RW612 BGA V4 board (UART, USB, SDIO, or SPI). • The method to build and run the NCP applications on both the NCP host (i.MX RT1060) and the NCP device (RW612). The applications apply to Wi-Fi, Bluetooth Low Energy and OpenThread (OT)    UM12095:  NXP NCP Application Guide for RW612 with MPU Host - User manual      This user manual describes: • The NXP NCP application for RW612 with MPU host platform i.MX 8M Mini as example. • The hardware connections for one of the four supported interfaces to enable NCP mode on the NXP RW612 BGA V4 board (UART, USB, SDIO, or SPI). • The method to build and run the NCP applications on both the NCP host (i.MX 8M Mini) and the NCP device (RW612). The applications apply to Wi-Fi, Bluetooth Low Energy and OpenThread (OT).  AN14439: Migration Guide from FRDM-RW612 Board to Third-Party Module board This Application note provides an overview of what it means to migrate the application to a different board with different flash and pSRAM AN14111: Target Wake Time (TWT) on RW16x This application note describes the target wake time feature and provides examples for RW61X AN13006: Compliance and Certification Considerations This application note provides guidance and tips on how to test products on NXP Wi-Fi devices for regulatory compliance. AN13049: Wi-Fi/Bluetooth/802.15.4 M.2 Key E Pinout Definition This Application note defines M.2 usage for both NXP Wi-Fi/Bluetooth and Tri-Radio M.2 module design AN14489 – Wi-Fi Firmware Automatic Recovery on RW61x Describes Wi-Fi automatic recovery feature as well as how to enable and verify it on RW61x SDK. AN14464 - Low Power Checklist RW61x Family This document provides an overview on how to use the low power consumption features of the RW61x. AN13869 - RW61x Flashloader for Custom Flash Devices: This document provides guidance to program the application image and boot up RW61X from a third party FlexSPI NOR flash device.   AN14125 - Manufacturing Software Development Kit API Specification: This document explains the Labtool Software Development Kit (SDK) used to automate manufacturing test programs.   AN14002 - RW61x Design Guide: Provides design guidelines for RW61x RF: AN14476 - NXP Dual PAN Feature and Performance ResultsThis document provides a comprehensive exploration of the Dual Personal Area Network (Dual-PAN) feature on NXP Wireless Connectivity products implementing IEEE 802.15.4 low-rate wireless protocol area network standard. AN13639 - Calibration Structure for RW61X: This document describes the RF calibration parameters and data structure used to store calibration/configuration data for RW61x. The document explains how to adjust the RF calibration parameters to attain tighter tolerances. AN14282 - RF Test Mode on FreeRTOS:  This document provides an overview of how to enable and use the Radio Frequency (RF) test mode on a Real-time Operating System (RTOS)-based host. Using the RF test mode feature, users can easily set RF parameters, such as the operating channel, TX power, and channel bandwidth for regulatory compliance testing. AN14001 - RW61x TCP Throughput Optimization: This document explains how to optimize TCP throughput for RW61X with MCUXpresso SDK and analyze the test results after tuning with different parameter combinations. AN14463 - Antenna Diversity: This application note describes the antenna diversity feature capabilities of NXP wireless SoCs. Implementation of antenna diversity requires appropriate external hardware (Single Dipole Pole Throw (SPDT) or Double Dipole Pole Throw (DPDT) switches) in the customer design.  AN14714 - Wi-Fi Firmware Download Modes for FreeRTOS:  This document introduces the firmware download process and configuration for these two modes. AN14281 - Channel State Information (CSI) on FreeRTOS: This document explains how to get the CSI records from the Wi-Fi packets in STA mode AN13681 - Wi-Fi Alliance Derivative Certification Process for RW61x: The document presents the Wi-Fi Alliance derivative certification process. AN14466 - Antenna Auto Detection: Describes the antenna auto detection feature AN14121 - Coexistence Overview for RW61X:  Provides an overview of coexistence between Wi-Fi and Bluetooth LE or 802.15.4 radios. Security: AN14544 – EdgeLock 2GO Services for MPU and MCU This application note introduces various methods that the EdgeLock 2GO service can be used with MCU and MPU devices and the features available for each method. AN13813 – Secure Boot on RW61x Describes how to generate and run the secure boot (signed image) on RW61x. AN13814 – Debug Authentication on RW61x Describes the steps for debug authentication using the secure provisioning SDK tool. AN14705  - Using EdgeLock 2GO for Matter Provisioning on RW612 Devices: This document explains how to use the NXP EdgeLock 2GO service to provision an RW612 device for Matter. AN15038 - EdgeLock 2Go Provisioning MCUs via Product Type using Secure Provisioning (SEC) Tool: This document offers an outline of the EdgeLock 2GO platform and discusses the "Device provisioning via product type" flow. The document focuses on the initial device provisioning using secure objects from the EdgeLock 2GO cloud server. AN14670 - EdgeLock 2GO Provisioning via SPSDK for MCUs: This document offers an outline of the EdgeLock 2GO platform and discusses the “Device provisioning via proxy” flow. The document focuses on the initial device provisioning using secure objects from the EdgeLock 2GO cloud server.  AN14624 EdgeLock 2GO Provisioning via Secure Provisioning Tool (SEC) for MCUs: This document offers an outline of the EdgeLock 2GO platform and discusses the "Device provisioning via proxy" flow. Import Wrapped Blob using ELS Cryptolib - Uses ELS Cryptolib to import a blob from OTP that was wrapped using HSM_STORE_KEY trust provisioning command.  Import Wrapped Blob using PSA APIs - Uses PSA API to import a blob from OTP that was wrapped using HSM_STORE_KEY trust provisioning command. Training RW61x Series Training - NXP Community   Equipment Wireless Equipment: This article provides the links to the wireless equipment to help you accelerate your project development Development Tools  SDK builder The MCUXpresso SDK brings open-source drivers, middleware, and reference example application to speed your software development. NXP MCUXpresso MCUXpresso IDE offers advanced editing, compiling and debugging features with the addition of MCU-Specific debugging and supports connections with all general-purpose Arm Cortex-M.  VSCode MCUXpresso for Visual Studio Code (VS Code) provides an optimized embedded developer experience for code editing and development. Zephyr RTOS  The Zephyr OS is based on a small-footprint kernel designed for use on resource-constrained and embedded systems: from simple embedded environmental sensors and LED wearables to sophisticated embedded controllers, smart watches, and IoT wireless applications. NXP Application Code Hub Application Code Hub (ACH) repository enables engineers to easily find microcontroller software examples, code snippets, application software packs and demos developed by our in-house experts. This space provides a quick, easy and consistent way to find microcontroller applications. NXP SPSDK Is a unified, reliable, and easy to use Python SDK library working across the NXP MCU portfolio providing a strong foundation from quick customer prototyping up to production deployment. NXP SEC Tool The MCUXpresso Secure Provisioning Tool us a GUI-based application provided to simplify generation and provisioning of bootable executables on NCP MCU devices. NXP OTAP Tool Is an application that helps the user to perform an over the air firmware update of an NXP development board. SDK Examples for Wireless MCUs The wireless examples feature many common connectivity configurations.   Useful Links Connecting LCD_PAR_S035 to the U-blox IRIS-W1-EVK: This article describes how to connect the LCD_PAR_S035 display to the U-blox IRIS-W1 EVK using the 8080 8-bit parallel interface, including the required GPIO mapping and hardware modifications. It also explains the display configuration and software setup needed to run LVGL-based graphical applications on the platform Bluetooth Interested in Bluetooth technology? Bluetooth® Low Energy Primer – Essential reading for understanding BLE fundamentals. Bluetooth® Specifications – Full list of standards, protocols, and technical documents. Bluetooth Feature Overview Bluetooth_5.0_Feature_Overview  Bluetooth_5.1_Feature_Overview  Bluetooth_5.2_Feature_Overview Bluetooth_5.3_Feature_Overview Bluetooth_5.4_Feature_Overview Bluetooth_6_Feature_Overview
View full article
The LCD_PAR_S035 can be interfaced with the U-blox IRIS-W1 EVK using the 8080 8-bit parallel interface. Enabling this configuration requires a combination of GPIO routing, jumper wiring, and two resistor population changes on the EVK. The reason for this additional wiring is that the signals required by the LCD's 8080 interface are distributed across multiple expansion connectors on the EVK. Additionally, the CS (Chip Select) and DC (Data/Command) signals are not routed by default to the required GPIOs and must be reassigned through resistor rework. Without these modifications, the LCD controller cannot be properly controlled by the IRIS-W1 device when operating in 8080 parallel mode.   Signal Mapping The following GPIO assignments have been verified for operation with the LCD_PAR_S035:   GPIO56 -> CS Available on J48 after removing R263 and populating R264 GPIO57 -> DC Available on J48 after removing R265 and populating R266 GPIO54 -> WR Available on J43 by default GPIO48 -> RD Available on J44 by default GPIO44 -> RST Available on J3 by default GPIO45 -> TE Available on J4 by default GPIO53 -> D7 Available on J43 by default GPIO52 -> D6 Available on J44 by default GPIO51 -> D5 Available on J43 by default GPIO49 -> D4 Available on J43 by default GPIO47 -> D3 Available on J43 by default GPIO46 -> D2 Available on J48 by default GPIO43 -> D1 Available on J4 by default GPIO42 -> D0 Available on J3 by default GPIO17 -> I2C_SCL Available on J47 by default GPIO16 -> I2C_SDA Available on J10 by default   Required Hardware Rework Two routing modifications are required to expose the LCD control signals through the desired GPIOs: CS Signal Routing:   Remove : R263 Populate : R264  DC Signal Routing: Remove : R265 Populate : R266   Populate:     Remove:   LCD Configuration The LCD module must be configured for 8080 8-bit parallel mode before power-up. The interface selection switch located on the back of the LCD_PAR_S035 should be set to: 110     Incorrect switch settings will prevent communication between the display controller and the IRIS-W1. Software Configuration After completing the hardware setup, any compatible LVGL example from the SDK can be used as a starting point. The selected project must use a flash configuration that matches the flash device populated on the target hardware. Reference flash configurations are available in the following repository: https://github.com/u-blox/u-blox-sho-OpenCPU/tree/master/MCUXpresso/IRIS-W1/sw_config/flash_config Reference Design Files Additional information regarding connector locations, GPIO routing, resistor options, and board-level implementation can be found in the EVK design package: https://github.com/u-blox/evk_designs_sho_altium/tree/main/EVK-IRIS-W10/Deliverables Summary Enabling the LCD_PAR_S035 on the U-blox IRIS-W1 EVK through the 8080 8-bit interface requires: Configuring the display for 8080 8-bit mode (switch setting 110 ). Reworking resistor populations for CS and DC routing. Connecting the LCD control and data signals according to the GPIO mapping listed above. Selecting the appropriate flash configuration for the target hardware. Using an LVGL-based application to validate display operation. This configuration provides direct access to the LCD through the parallel interface and serves as a useful reference for graphics evaluations and GUI development on the IRIS-W1 platform. Results:
View full article
In this lab, we'll learn how to access Application Code Hub directly from Visual Studio Code, download a RTP USB Camera Stream over WiFi (FRDM‑MCXN947 + IW610), and run it on the FRDM-MCXN947 using IW610G-M2 + FRDM-ADPT-MCX-M2 to add Wi-Fi capabilities and USB camera to video stream. Hardware Requirements: FRDM-MCXN947 FRDM-ADPT-MCX-M2 IW610G-M2 Logitech C920 HD Pro WebCam Type C USB Cable Software Requirements: IDE: Visual Studio Code 1.130 or later SDK: V26.06.00 LTS VLC  RTP USB Camera Stream over Wi-Fi lab guide Community Support If you have questions regarding this training, please leave your comments in our MCU Community! here
View full article
In this lab, we'll learn how to access Application Code Hub directly from Visual Studio Code, download a https-wifi-server-temperature-monitor-demo, and run it on the FRDM-MCXN947 using IW610G-M2 + FRDM-ADPT-MCX-M2 to add WiFi capabilities. Hardware Requirements: FRDM-MCXN947 FRDM-ADPT-MCX-M2 IW610G-M2 Type C USB Cable Software Requirements: IDE: Visual Studio Code 1.130 or later SDK: V26.06.00 LTS Wi-Fi Server Temperature Monitor Lab Guide Community Support If you have questions regarding this training, please leave your comments in our MCU Community! here
View full article
  Welcome to IW610 M.2 and FRDM Adapter Product Training! This page provides access to training materials, presentations, demos, recordings, and supporting resources related to the IW610 M.2 development card and the FRDM adapter. While live Q&A support will be available during the training period, all content will remain accessible for future reference and self-paced learning.  Instructions  To get started with the IW610 M.2 and FRDM Adapter training, you will need to have your FRDM-MCXN947, IW610G-M2 and FRDM Adapter board in hand and perform the set-up operations according to the IW610G-M2 and FRDM-ADPT-MCX-M2 Getting Started Page which is a pre-requisite.   Step 1. Mandatory pre-work before starting with the labs:  Getting Started with IW610G-M2 Getting Started with FRDM-ADPT-MCX-M2 Step 2. After completing the pre-work, download the lab guides. Each lab has its own guide document and a video guide you can use as support material in case you have any question at any step:  Lab1: Wi-Fi Server Temperature Monitor Description This demo connects the IW610G-M2 to an FRDM-MCXN947 using an FRDM-M2-ADAPTER board and sends temperature measurements to an HTTPS server over Wi-Fi. Also creates an access point to enable connections. The online dashboard can also be used to wirelessly control the onboard LEDs. (End applications: home automation, industrial monitoring) Lab2: RTP USB Camera Stream over Wi-Fi Description This demo connects the IW610G-M2 to an FRDM-MCXN947 using an FRDM-M2-ADAPTER board and uses a camera module to stream real-time video over Wi-Fi to a laptop or another FRDM-MCXN947 with an IW610G-M2. The captured video is displayed on an LCD-PAR screen (In case to use a FRDM-MCXN947). (End application: Interphone, security camera) Step 3. Review the support material and useful links to get you up to speed with some product information, M.2 development card and FRDM adapter information and getting started. Below also includes additional reading material.   IW610 M2 Module | NXP Semiconductors Getting Started with IW610G-M2 | NXP Semiconductors https://nww.preview-cloud.nxp.com/pages/:FRDM-ADPT-MCX-M2 Getting Started with FRDM-ADPT-MCX-M2 | NXP Semiconductors Community Support If you have questions regarding this training, please leave your comments in our Wireless Community! here
View full article
The MCX W72x family features a 96 MHz Arm® Cortex®-M33 core coupled with a multiprotocol radio subsystem supporting Matter, Thread, Zigbee and Bluetooth LE. The independent radio subsystem, with a dedicated core and memory, offloads the main CPU, preserving it for the primary application and allowing firmware updates to support future wireless standards. The MCX W72x also offers advanced security with an integrated EdgeLock® Secure Enclave Core Profile and will be supported by NXP's EdgeLock 2GO cloud services for credential sharing. The MCX W72x family includes Bluetooth Channel Sounding capabilities, with a dedicated on-chip Localization Compute Engine to reduce ranging latency. It incorporates additional memory to support application-specific code, connectivity stacks and over-the-air firmware updates. In addition, the radio subsystem can run the full Thread or Zigbee stack alongside the Bluetooth Low Energy stack. This delivers reliable wireless performance, as the real-time activities of the radio run on a separate core from the application. Building on NXP's strong history of providing industrial edge solutions, the MCX W series offers a wide operating temperature range from -40 °C to 125 °C and peripherals for industrial applications, including an optional CAN interface and will be part of NXP's 15-year Product Longevity program to support long-term industrial use. The MCX W series is supported by the MCUXpresso Developer Experience to optimize, ease and help accelerate embedded system development.   Security Certifications  PSA Certified Level 2 SESIP Level 2 Security Target  SESIP Level 2 KW47/MCXW72 SESIP certificate and ST are on TrustCB website Regulatory Certifications European Union Declaration of Conformity - FRDM MCXW72 MIC Radio Certificate - FRDM-MCXW72 European Union Declaration of Conformity - MCXW72-LOC MIC Radio Certificate - MCXW72-LOC Bluetooth Qualifications Qualified Products | Bluetooth® Technology Website Q360996: KW47 / MCX W72 Bluetooth LE 6.0 (Channel Sounding) Controller Q332147: KW47 / MCX W72 Bluetooth LE 6.0 (Channel Sounding) Host Documents MCX W72 Product Family Data Sheet MCX W72 Reference Manual Errata Sheet for MCX W72 MCXW72 Hardware Design Guide   Getting Started with Matter on MCX W72 platforms Getting Started with OpenThread on NXP MCX W72    FRDM-MCXW72 User Manual Getting Started with the FRDM-MCXW72   MCX W72-LOC User Manual Bluetooth Interested in Bluetooth technology? Bluetooth® Low Energy Primer – Essential reading for understanding BLE fundamentals. Bluetooth® Specifications – Full list of standards, protocols, and technical documents. Awards and Recognition - Every year, the Bluetooth Special Interest Group (SIG) celebrates the hard work and commitment of working groups, committee members, and contributors who have been recognized by their peers as making a difference in advancing Bluetooth technology.  2024: Channel Sounding 2025: Channel sounding amplitude-based attack resilience, LE test mode enhancements and Ranging profile and service.  Bluetooth AI Assistant - Amber   Bluetooth Feature Overview Bluetooth_5.0_Feature_Overview  Bluetooth_5.1_Feature_Overview  Bluetooth_5.2_Feature_Overview Bluetooth_5.3_Feature_Overview Bluetooth_5.4_Feature_Overview Bluetooth_6_Feature_Overview Bluetooth_6.1_Feature_Overview Bluetooth_6.2_Feature_Overview Bluetooth_6.3_Feature_Overview Bluetooth Core Specification Core Specification 4.0 Core Specification 4.1 Bluetooth 4.1 FAQ Core Specification 4.2 Bluetooth 4.2 FAQ Core Specification 5.0 Core Specification 5.1 Core Specification 5.2 Core Specification 5.3 Core Specification 5.4 Core Specification 6.0 Core Specification 6.1 Core Specification 6.2 Core Specification 6.3   Application Notes Software, Hardware and Peripherals: AN14850 Boosting application performance with MCX W72: This application note describes the usage of the dual-core architecture in the MCX W72 microcontroller to improve performance in generic embedded applications. AN14937 32kHz Crystal-less mode on MCX W72: This application note provides information on the 32 kHz Crystal-less mode on the MCX W72 device. This mode allows you to reduce the cost of the system, without compromising the 32 kHz clock accuracy. The Free‑Running Oscillator (FRO32K) is used as the 32 kHz clock source and is calibrated against the 32 MHz RF oscillator through the Signal Frequency Analyzer (SFA) module of MCX W72 AN14745 Features, Usage, and Capabilities of Smart Power Switch on the MCX W72: This application note describes the use of the smart power switch in the MCX W72microcontroller. The MCX W72 integrates a programmable solid-state switch that turns connected components on or off, including MCX W72 power domains. AN14747 Loadpull test Report for MCX W72: This document explains the purpose of measuring the supply current, the transmit power, and the harmonics level. These measurements are monitored while the complex output load seen by the device under test (DUT) is tuned in amplitude and phase. Power Management:  AN14739 MCX W72 Bluetooth Low Energy Power Consumption Analysis: This document provides the power consumption analysis of the MCX W72 (IIOT) wireless MCU using the MCXW72-EVK board AN14745 Features Usage and Capabilities of Smart Power Switch on MCX W72 Microcontroller:  This application note describes the use of the smart power switch in the MCX W72 microcontroller. The MCX W72 integrates a programmable solid-state switch that turns connected components on or off, including MCX W72 power domains. AN14841 802.15.4 Matter and Zigbee Power Consumption Analysis for MCX W72: This document provides the power consumption analysis of the Kinetis MCX W72 (IIoT) wireless MCUs. AN14742 Power Management Hardware for the MCX W72: This application note describes the usage of the different modules dedicated to power management in the MCX W72microcontroller AN14664 Coincell Hardware Recommendations for Kinetis BLE Applications: his document describes some hardware and software solutions to minimize the peaks of current at the coin cell level AN14889: FRDM-MCXW72 Radio Frequency System Evaluation Report for Bluetooth Low Energy and for IEEE 802.15.4 This document provides the radio frequency (RF) evaluation test results of the FRDM-MCXW72 board for Bluetooth Low Energy (2FSK modulation) and IEEE 802.15.4 (OQPSK modulation) applications.  RF: AN14865 Channel Sounding Fundamentals for the KW47 and MCX W72: This document provides an overview of the fundamentals for CS technology and how it can be used for custom solutions and applications. AN14779 Printed Channel Sounding Antennas for the KW47 and MCX W72: his application note is focused on printed antennas implemented on printed-circuit boards (PCB), designed by NXP for the KW47 and MCX W72 controllers AN14832 Fundamental Steps to Design a Channel Sounding Board - Creating a Simple PCB without Diversity: In this document, an example of a minimalistic CS subsystem is presented. Attention is paid to the Radio-Frequency (RF) path, since RF circuitry strongly influences the properties of the whole CS application. AN14747 Loadpull Test Report for MCX W72: This document explains the purpose of measuring the supply current, the transmit power, and the harmonics level. These measurements are monitored while the complex output load seen by the device under test (DUT) is tuned in amplitude and phase. AN14868 RF Modeling of Channel Sounding in ANSYS: focuses on techniques for simulating and analyzing channel sounding in wireless communication systems using ANSYS tools AN14855 Channel Sounding Tests in Different Environments: This application note is about Bluetooth Channel Sounding (CS), a technique for measuring the distance between two devices in the Bluetooth frequency band. It explains key factors affecting accuracy AN14869 Fundamental Steps to Design a Complex Channel Sounding Board:  It focuses on creating hardware that supports advanced CS features, including antenna diversity and optimized RF paths, to improve accuracy and mitigate issues like multipath propagation. AN2731 Compact Planar Antennas for 2.4GHz Communication: This document is not an exhaustive inquiry into antenna design. It is instead focused on helping the customers understand enough board layout and antenna basics to select a correct antenna type for their application, as well as avoiding typical layout mistakes that cause performance issues that lead to delays Security: AN14648 MCX W72 In-System Programming Utility: The document provides steps to boot the MCX W72 MCU in ISP mode and establish various serial connections to communicate with the MCU AN14613 MCX W72 Secure Boot using SEC tool: The MCX W72 is a low-power, highly secure, single-chip wireless MCU, the contents of flash memory can be saved as encrypted data, which can be decrypted instantly. It helps in protecting the sensitive data and algorithms. AN14646 Debug Authentication on MCX W72: This application note describes the steps for debug authentication using the MCUXpresso Secure Provisioning Tool (SEC). AN14728 MCX W72 Flash Encryption using NPX: There is an increasing requirement to protect the application code and data stored in flash memories in an encrypted form due to security reasons. The NVM PRINCE XEX (NPX) is a module inside the Flash Memory Controller (FMC) that allows customers to protect the contents of flash regions (up to four regions). It performs on-the-fly, low-latency encryption and decryption of flash contents, and it is transparent to the developer and to the Cortex-M33 platform. No special handle is needed from the perspective of the developer. AN14644 MCX W72 Managing Lifecycles: This document describes the following: Lifecycle stages that are available to the user, how to access the lifecycles, limitations of the lifecycles, how to transition to the next lifecycle AN14670 EdgeLock 2GO Provisioning via SPSDK for MCUs: EdgeLock 2GO is a fully managed cloud platform operated by NXP that provides secure provisioning services for easy deployment and maintenance of IoT devices that integrate NXP MCU, MPU, and EdgeLock SE05x secure elements. AN14624 EdgeLock 2GO PRovisioning via Secure Provisioning Tool (SEC) for MCUs: EdgeLock 2GO is a fully managed cloud platform operated by NXP that provides secure provisioning services for easy deployment and maintenance of IoT devices that integrate NXP MCU, MPU, and EdgeLock SE05x secure elements. AN14544 EdgeLock 2Go Services for MPU and MCU: EdgeLock 2GO is the service platform of NXP for provisioning and managing IoT devices. It lets you securely install keys and certificates into your devices, either during manufacturing or in the field, and then keep credentials up to date during the device life cycle. EdgeLock 2GO uses the security capability of each device, for optimal levels of security across your entire IoT fleet. Bluetooth Training Bluetooth Low Energy 6.0 NXP Training MCX W Series Training - NXP Community   RF Switch Comparison Absorptive/Reflective Standards Comparison ETSI / FCC / ARIB requirements BLE Channel Sounding  - Overview BLE Channel Sounding - RF Hardware BLE Channel Sounding - ANSYS Modeling Tools  BLE Channel Sounding - Antenna Prototypes Validation Measurements Equipment Wireless Equipment: This article provides the links to the Equipment that helps to the project development  Useful Links Debug probe firmware installation for the KW47-EVK and FRDM-MCXW72 This post will cover how to install the CMSIS-DAP/SEGGER J-link firmware for the KW47-EVK and FRDM-MCXW72 using NXP’s MCU-LINK installer. How to generate a Standalone IAR toolchain project from MCUXSDK application example - KWX/MCWX  Updating NBU for Wireless Examples on KW47/MCXW72This post will cover how to update the NBU firmware How to import and run demo examples with MCUXpresso for Visual Studio Code: This article gives information on how to import and run demo examples from the new SDK with ARM GCC toolchain, in MCUXpresso for Visual Studio Code. [MCUXSDK] How to use GitHub SDK for KW4x, MCXW7x, MCXW2x - NXP Community this community post provides step by step how to use GitHub SDK [MCUXSDK] GitHub SDK - Documentation for Bluetooth LE platforms - NXP Community this community post provides the documentation for BLE platforms.  The best way to build a PCB first time right with KW47 (Automotive) or MCXW72 (IoT/Industrial): In this community provides the important link to build a PCB using a KW45 or K32W148 and MCXW71 and all concerning the radio performances, low power and radio certification (CE/FCC/ICC) Workaround implementation for DCDC failure during drive strength change a DCDC failure can occur infrequently during a drive strength change to low, and the DCDC output voltage becomes greater than or equal to the current output voltage. How to use the HCI_bb on Kinetis family products and get access to the DTM mode:  This article is presenting two parts: How to flash the HCI_bb binary into the Kinetis product. Perform RF measurement using the R&S CMW270 BLE HCI Application to set transmitter/receiver test commands: This article provides the steps to show how user could send serial commands to the device. Bluetooth LE HCI Black Box Quick Start Guide : This article describes a simple process for enabling the user controls the radio through serial commands. Using HCI_VENDOR_CONFIG_TX_POWER on KW47 and MCXW72 Bluetooth LE Devices Kinetis (../45/47/43;MCX W71/72/70) & MCX W23 Power Profile Tools (including Localization):  This page is dedicated to the Kinetis (KW35/KW38/KW45/KW47/KW43) and MCX W7x (MCX W71/W72/W70) Power Profile Tools. It will help you to estimate the power consumption in your application (Automotive or IIoT) and evaluate the battery lifetime of your solution. One Wireless Connectivity Power Profile Tool KW47/MCXW72 32MHz & 32kHz Oscillation margins: this article provides the properly configuration for the Oscillation margins for the circuit. Errata ERR053377: Use Cases for Different Message Buffer ConfigurationsThis article discusses the different use cases and configuration of the errata "ERR053377: FlexCAN: Message Buffer (MB) and Enhanced RX FIFO Filter Element (ERFFEL) Memory Corruption" CAN-FD maximum baud rate on KW47 and MCXW72  This article describes the clock accuracy requirements and FlexCAN configuration needed to achieve the maximum supported CAN FD data rate of 6 Mbps on KW47 and MCXW72 devices. It explains how to use the FRO192 clock in closed-loop trim mode with a 32 MHz crystal reference and provides example code for clock and CAN FD configuration. Videos NXP Channel Sounding technology interfacing with Google Pixel 10 This is a demo showing the MCX W72 LOC board interacting with Google Pixel 10 phone using channel sounding Exploring Bluetooth Channel Sounding on FRDM-MCXW72 - Part 1: In this video, you will see step‑by‑step how Bluetooth® Channel Sounding works using NXP’s Rate2 distance‑estimation solution. Performing the demonstration includes a computer with VS Code, the MCUXpresso extension and toolchains installed, a FRDM‑MCXW72 development board and a smartphone running the BLE Hero application. Exploring Bluetooth Channel Sounding on FRM-MCXW72 - Part 2:  Concluding the demonstration of Bluetooth® Channel Sounding, part two of this presentation continues with a brief review of the testing setup and walks you through running board‑to‑board measurements
View full article
KW47 family features a 96 MHz Arm® Cortex®-M33 core coupled with a Bluetooth LE subsystem. The independent radio subsystem, with a dedicated core and memory, offloads the main CPU, preserving it for the primary application and allowing firmware updates to support future wireless standards. The KW47 also offers advanced security with an integrated EdgeLock® Secure Enclave Core Profile and will be supported by NXP's EdgeLock 2GO cloud services for credential sharing. The KW47 family includes Bluetooth Channel Sounding capabilities, with a dedicated on-chip Localization Compute Engine to reduce ranging latency. It incorporates additional memory to support application-specific code, connectivity stacks and over-the-air firmware updates. This delivers reliable wireless performance, as the real-time activities of the radio run on a separate core from the application. Building on NXP's strong history of providing automotive solutions, the KW47 family offers a wide operating temperature range from -40 °C to 125 °C and peripherals for automotive applications, KW47 will be part of NXP's 15-year Product Longevity program to support long-term use. The KW47 series is supported by the MCUXpresso Developer Experience to optimize, ease and help accelerate embedded system development.   KW47 boards KW47-EVK Getting Started with the KW47 EVK KW47-EVK Board User Manual KW47-M2 Board User Manual  KW47-EVK Quick Start Guide KW47-M2 Quick Start Guide   KW47-LOC Getting Started with the KW47-LOC KW47-LOC Board User Manual KW47-LOC Quick Start Guide KW47: Bluetooth Channel Sounding MCU with On-Chip Localization Compute Engine the KW47 Security Certifications  PSA Certified Level 2 SESIP Level 2 Security Target  SESIP Level 2 KW47/MCXW72 SESIP certificate and ST are on TrustCB website  Regulatory Certifications European Union Declaration of Conformity - KW47-EVK MIC Radio Certificate - KW47-EVK European Union Declaration of Conformity - KW47-LOC MIC Radio Certificate - KW47-LOC  Bluetooth Qualifications Qualified Products | Bluetooth® Technology Website Q360996: KW47 / MCX W72 Bluetooth LE 6.0 (Channel Sounding) Controller Q332147: KW47 / MCX W72 Bluetooth LE 6.0 (Channel Sounding) Host Documents  KW47 Product Family Data Sheet KW47 Reference Manual Errata for KW47 KW47 Hardware Design Guide Bluetooth Interested in Bluetooth technology? Bluetooth® Low Energy Primer – Essential reading for understanding BLE fundamentals. Bluetooth® Specifications – Full list of standards, protocols, and technical documents. Awards and Recognition - Every year, the Bluetooth Special Interest Group (SIG) celebrates the hard work and commitment of working groups, committee members, and contributors who have been recognized by their peers as making a difference in advancing Bluetooth technology, like NXP! 2024: Channel Sounding 2025: Channel sounding amplitude-based attack resilience, LE test mode enhancements and Ranging profile and service.  Bluetooth AI Assistant - Amber   Bluetooth Feature Overview Bluetooth_5.0_Feature_Overview  Bluetooth_5.1_Feature_Overview  Bluetooth_5.2_Feature_Overview Bluetooth_5.3_Feature_Overview Bluetooth_5.4_Feature_Overview Bluetooth_6_Feature_Overview Bluetooth_6.1_Feature_Overview Bluetooth_6.2_Feature_Overview Bluetooth_6.3_Feature_Overview Bluetooth Core Specification Core Specification 4.0 Core Specification 4.1 Bluetooth 4.1 FAQ Core Specification 4.2 Bluetooth 4.2 FAQ Core Specification 5.0 Core Specification 5.1 Core Specification 5.2 Core Specification 5.3 Core Specification 5.4 Core Specification 6.0 Core Specification 6.1 Core Specification 6.2 Core Specification 6.3 Application Notes Software, Hardware and Peripherals: AN14884 32kHz Cristal-less mode on KW47: This application note provides information on the 32 kHz Crystal-less mode on the KW47 device. This mode allows you to reduce the cost of the system, without compromising the 32 kHz clock accuracy.  AN14846 Boosting Application Performance with the KW47 Dual-Core Architecture: This application note describes how to use the dual-core architecture in the KW47 microcontroller to improve performance in generic embedded applications AN14796 Migration Guide from the KW45 to the KW47:  This document describes the procedure to migrate from KW45B41Z to KW47 with emphasis on the connectivity software. The document is intended for software engineers, software testers, software integrators, and customers designing their own hardware. Power Management: AN14709 Power Management Hardware for the KW47: This application note describes the usage of the different modules dedicated to power management in the KW47microcontroller. TheKW47integrates a DC-DC buck converter, a couple of low-dropout regulators, and a programmable solid-state switch to turn on/off theKW47power domains AN14684 Features, Usage, and Capabilities of Smart Power Switch on the KW47 Microcontroller: This application note describes the use of the smart power switch in the KW47 microcontroller. The KW47 integrates a programmable solid-state switch that turns connected components on or off, including KW47 power domains AN14664 Coincell Hardware Recommendations for Kinetis BLE Applications: his document describes some hardware and software solutions to minimize the peaks of current at the coin cell level AN14554 KW47 Bluetooth Low Energy Power Consumption Analysis:  This document provides the power consumption analysis of the Kinetis KW47 (automotive) wireless MCU using the KW47-EVK board RF: AN14719 Integrating the OTAP Client Service into a KW47 BLE Peripheral Device: This application note outlines the use of the NXP Over the Air Programming (OTAP) custom Bluetooth Low Energy (Bluetooth LE) service to upgrade software on a Microcontroller Unit (MCU) without using physical cables. AN14940 KW47 Coexistence with RF System Evaluation Report for the Bluetooth LE Applications: This document provides the coexistence RF evaluation test results of the KW47-EVK for Bluetooth LE applications (2FSK modulation). It includes the test setup description and the tools used to perform the tests on your own. For the KW47 radio parameters AN14461 KW47-EVK RF System Evaluation Report for Bluetooth LE Applications: This document provides the RF evaluation test results of the KW47-EVK board for Bluetooth LE (2FSK modulation) applications. It includes the test setup description and the tools used to perform the tests. AN14826 KW47-LOC System Evaluation Report for BLE Applications: This document provides the RF evaluation test results of the KW47 Localization board (KW47-LOC) for Bluetooth LE (2FSK modulation) applications. It includes the test setup description, and the tools used to perform the tests on your own. AN14696 Loadpull Test Report for KW47: This document explains the purpose of measuring the supply current, the transmit power, and the harmonics level. These measurements are monitored while the complex output load seen by the device under test (DUT) is tuned in amplitude and phase. AN14628 KW47 CCC Channel Sounding Power Profile Analysis:  this document explains power consumption measurement at each step of the full distance measurement procedure, changing of the code to set the different option in the SDK software, and usage of the associated power profile estimator tool. AN14865 Channel Sounding Fundamentals for the KW47 and MCX W72: This document provides an overview of the fundamentals for CS technology and how it can be used for custom solutions and applications. AN14832 Fundamental Steps to Design a Channel Sounding Board - Creating a Simple PCB without Diversity: In this document, an example of a minimalistic CS subsystem is presented. Attention is paid to the Radio-Frequency (RF) path, since RF circuitry strongly influences the properties of the whole CS application. AN14779 Printed Channel Sounding Antennas for the KW47 and MCX W72: his application note is focused on printed antennas implemented on printed-circuit boards (PCB), designed by NXP for the KW47 and MCX W72 controllers AN14720 Creation of Firmware Update Image for KW47 using Over the Air Programming Tool: This document outlines the steps to create and upgrade the image on the KW47–EVK board AN14868 RF Modeling of Channel Sounding in ANSYS: focuses on techniques for simulating and analyzing channel sounding in wireless communication systems using ANSYS tools AN14855 Channel Sounding Tests in Different Environments: This application note is about Bluetooth Channel Sounding (CS), a technique for measuring the distance between two devices in the Bluetooth frequency band. It explains key factors affecting accuracy AN14869 Fundamental Steps to Design a Complex Channel Sounding Board:  It focuses on creating hardware that supports advanced CS features, including antenna diversity and optimized RF paths, to improve accuracy and mitigate issues like multipath propagation. AN2731 Compact Planar Antennas for 2.4 GHz Communication: This document is not an exhaustive inquiry into antenna design. It is instead focused on helping the customers understand enough board layout and antenna basics to select a correct antenna type for their application, as well as avoiding typical layout mistakes that cause performance issues that lead to delays Security: AN14727 KW47 Flash Encryption using NPX: There is an increasing requirement to protect the application code and data stored in flash memories in an encrypted form due to security reasons. The NVM PRINCE XEX (NPX) is a module inside the Flash Memory Controller (FMC) that allows customers to protect the contents of flash regions (up to four regions). It performs on-the-fly, low-latency encryption and decryption of flash contents, and it is transparent to the developer and to the Cortex-M33 platform. No special handle is needed from the perspective of the developer. AN14607 KW47 Secure Boot using SEC tool: The KW47 is a low-power, highly secure, single-chip wireless MCU, the contents of flash memory can be saved as encrypted data, which can be decrypted instantly. It helps in protecting the sensitive data and algorithms. AN14647 KW47-LOC In-System Programming Utility: The document provides steps to boot the KW47 MCU in ISP mode and establish various serial connections to communicate with the MCU AN14653 Debug Authentication on KW47: This application note describes the steps for debug authentication using the MCUXpresso Secure Provisioning Tool (SEC). AN14649 KW47-EVK In-System Programming Utility: This document provides steps to boot the KW47 MCU into ISP mode and establish various serial connections to communicate with the MCU. AN14643 KW47 Managing Lifecycles: This document describes the following: Lifecycle stages that are available to the user, how to access the lifecycles, limitations of the lifecycles, how to transition to the next lifecycle AN15038 EdgeLock 2GO Provisioning MCUs via Product Type using Secure Provisioning (SEC) Tool:  This document offers an outline of the EdgeLock 2GO platform and discusses the "Device provisioning via product type" flow. The document focuses on the initial device provisioning using secure objects from the EdgeLock 2GO cloud server. Training Bluetooth Low energy 6.0 NXP Introduction KW4x: Automotive Bluetooth Low Energy MCUs for Secure Car Access RF Switch Comparison Absorptive/Reflective Standards Comparison ETSI / FCC / ARIB requirements BLE Channel Sounding  - Overview BLE Channel Sounding - RF Hardware BLE Channel Sounding - ANSYS Modeling Tools  BLE Channel Sounding - Antenna Prototypes Validation Measurements   Equipment Wireless Equipment: This article provides the links to the Equipment that helps to the project development  Useful Links How to run KW47-M2 standalone - NXP Community How to generate a Standalone IAR toolchain project from MCUXSDK application example - KWX/MCWX  Debug probe firmware installation for the KW47-EVK and FRDM-MCXW72 This post will cover how to install the CMSIS-DAP/SEGGER J-link firmware for the KW47-EVK and FRDM-MCXW72 using NXP’s MCU-LINK installer. Updating NBU for Wireless Examples on KW47/MCXW72This post will cover how to update the NBU firmware How to import and run demo examples with MCUXpresso for Visual Studio Code: This article gives information on how to import and run demo examples from the new SDK with ARM GCC toolchain, in MCUXpresso for Visual Studio Code. [MCUXSDK] How to use GitHub SDK for KW4x, MCXW7x, MCXW2x - NXP Community this community post provides step by step how to use GitHub SDK [MCUXSDK] GitHub SDK - Documentation for Bluetooth LE platforms - NXP Community this community post provides the documentation for BLE platforms.  The best way to build a PCB first time right with KW47 (Automotive) or MCX W72 (IoT/Industrial) - NXP Community : In this community provides the important link to build a PCB using a KW47 and MCX W72 and all concerning the radio performances, low power and radio certification (CE/FCC/ICC). Workaround implementation for DCDC failure during drive strength change a DCDC failure can occur infrequently during a drive strength change to low, and the DCDC output voltage becomes greater than or equal to the current output voltage. How to use the HCI_bb on Kinetis family products and get access to the DTM mode:  This article is presenting two parts: How to flash the HCI_bb binary into the Kinetis product. Perform RF measurement using the R&S CMW270 BLE HCI Application to set transmitter/receiver test commands: This article provides the steps to show how user could send serial commands to the device. Bluetooth LE HCI Black Box Quick Start Guide : This article describes a simple process for enabling the user controls the radio through serial commands. Using HCI_VENDOR_CONFIG_TX_POWER on KW47 and MCXW72 Bluetooth LE Devices Kinetis (../45/47/43;MCX W71/72/70) & MCX W23 Power Profile Tools (including Localization):  This page is dedicated to the Kinetis (KW35/KW38/KW45/KW47/KW43) and MCX W7x (MCX W71/W72/W70) Power Profile Tools. It will help you to estimate the power consumption in your application (Automotive or IIoT) and evaluate the battery lifetime of your solution. One Wireless Connectivity Power Profile Tool KW47/MCXW72 32MHz & 32kHz Oscillation margins: this article provides the properly configuration for the Oscillation margins for the circuit. Changing CAN interface configuration on KW47-EVK while using serial terminal:Most available example applications use UART as the serial interface for terminal communication. This approach is commonly chosen because a terminal provides a simple and efficient method for interacting with the application during development and debugging. Errata ERR053377: Use Cases for Different Message Buffer ConfigurationsThis article discusses the different use cases and configuration of the errata "ERR053377: FlexCAN: Message Buffer (MB) and Enhanced RX FIFO Filter Element (ERFFEL) Memory Corruption" CAN-FD maximum baud rate on KW47 and MCXW72 This article describes the clock accuracy requirements and FlexCAN configuration needed to achieve the maximum supported CAN FD data rate of 6 Mbps on KW47 and MCXW72 devices. It explains how to use the FRO192 clock in closed-loop trim mode with a 32 MHz crystal reference and provides example code for clock and CAN FD configuration. Reference Designs Bluetooth Ranging Access Vehicle Enablement System - NXP Community Blue Ravens (Bluetooth Ranging Access Vehicle Enablement System) is a system solution developed by NXP to assist customers in designing their own BLE-based car access solutions using NXP products. Videos NXP Channel Sounding technology interfacing with Google Pixel 10 This is a demo showing the MCX W72 LOC board interacting with Google Pixel 10 phone using channel sounding
View full article
  Thread provides basic services required for application frameworks implementation with the usage of Unicast and Multicast transmissions over UDP. Thread specification is only focused on the network layer; many application layers can be designed to run without any problem as it is application layer agnostic.  In this laboratory the user will work with the Constrain Application Protocol (CoAP) for this application layer as the Thread stack uses CoAP for most of the multi-hop network management and commissioning messages. The Constrained Application Protocol (CoAP) is a specialized web transfer protocol to use with constrained nodes and constrained networks in the Internet of Thing.  It uses a binary RESTful protocol with four methods POST GET PUT DELETE   CoAP also uses ACK responses; CONfirmable (ACK requested) and NONconfirmable messages. The Thread stack uses CoAP for the majority of multi-hop network management and commissioning messages     Objectives Through this laboratory the user will modify the firmware to achieve the following list: Add 2 new COAP URI resources “/resource1” and “/resource2”. Send an ACK message in “/resource1” in case a CON request was received as specified by the CoAP standard. Include a default payload in the ACK message. All packets destined to “/resource1” will trigger a NON POST packet reply (independent from the expected ACK packet) destined to “/resource2” URI path with a default payload. Print in shell all CoAP transactions to fully understand when a request was sent and when a response was received, indicating the method and the resource, e.g. If a CON POST was received, print on shell “‘NON’ packet received, ‘POST’ with payload of ‘<payload>’ If a NON POST was sent, print on shell “‘NON’ packet sent, ‘POST’ with payload ‘<payload>’   The process desired behavior by the laboratory is shown in figure 1.   Figure 1 Diagram showing the desired behavior of the laboratory     Setup In the following list, the components with a dash (—) will be the ones used to create this laboratory.   2 FRDM-KW41Z       — Rev.  A Connectivity Software from the latest NXP release.       — Thread Router Eligible Device project Serial Terminal       — TeraTerm   Figure 2 FRDM-KW41Z      Modifying Firmware         The following changes will be made in the router_eligible_device_app.c file.  1. Define the URI path names that will be used in the shell to access the resources. #define APP_RESOURCE1_URI_PATH                       "/resource1" #define APP_RESOURCE2_URI_PATH                       "/resource2"     2. Declare the URI resources with coapUriPath_t. When using this struct the user must enter the length of the URI path and the path created in the last step. const coapUriPath_t gAPP_RESOURCE1_URI_PATH = {SizeOfString(APP_RESOURCE1_URI_PATH), (uint8_t *)APP_RESOURCE1_URI_PATH}; const coapUriPath_t gAPP_RESOURCE2_URI_PATH = {SizeOfString(APP_RESOURCE2_URI_PATH), (uint8_t *)APP_RESOURCE2_URI_PATH};     3. Create the callbacks for the resources. This callbacks will handle the packet received and perform the desired action depending on the type of COAP method received. static void APP_CoapResource1Cb(coapSessionStatus_t sessionStatus, void *pData, coapSession_t *pSession, uint32_t dataLen); static void APP_CoapResource2Cb(coapSessionStatus_t sessionStatus, void *pData, coapSession_t *pSession, uint32_t dataLen);       4. Add the callback handler for the packet received, in this function it will be defined which action will be performed depending on the type of COAP method received. APP_CoapResource1Cb     static void APP_CoapResource1Cb ( coapSessionStatus_t sessionStatus, void *pData, coapSession_t *pSession, uint32_t dataLen ) {   static uint8_t pMySessionPayload[3]={0x31,0x32,0x33};   static uint32_t pMyPayloadSize=3;   coapSession_t *pMySession = NULL;   pMySession = COAP_OpenSession(mAppCoapInstId);   //COAP_AddOptionToList(pMySession,COAP_URI_PATH_OPTION, APP_RESOURCE2_URI_PATH,SizeOfString(APP_RESOURCE2_URI_PATH)); pMySession->pUriPath = (coapUriPath_t *)&gAPP_RESOURCE2_URI_PATH;     if (gCoapConfirmable_c == pSession->msgType)   {     if (gCoapGET_c == pSession->code)     {       shell_write("'CON' packet received 'GET' with payload: ");     }     if (gCoapPOST_c == pSession->code)     {       shell_write("'CON' packet received 'POST' with payload: ");     }     if (gCoapPUT_c == pSession->code)     {       shell_write("'CON' packet received 'PUT' with payload: ");     }         if (gCoapFailure_c!=sessionStatus)     {       COAP_Send(pSession, gCoapMsgTypeAckSuccessChanged_c, pMySessionPayload, pMyPayloadSize);     }   }   else if(gCoapNonConfirmable_c == pSession->msgType)   {     if (gCoapGET_c == pSession->code)     {       shell_write("'NON' packet received 'GET' with payload: ");     }     if (gCoapPOST_c == pSession->code)     {       shell_write("'NON' packet received 'POST' with payload: ");     }     if (gCoapPUT_c == pSession->code)     {       shell_write("'NON' packet received 'PUT' with payload: ");     }      }   shell_writeN(pData, dataLen);   shell_write("\r\n");   pMySession -> msgType=gCoapNonConfirmable_c;   pMySession -> code= gCoapPOST_c;   pMySession -> pCallback =NULL;   //FLib_MemCpy(&pMySession->remoteAddr,&gCoapDestAddress,sizeof(ipAddr_t)); FLib_MemCpy(&pMySession->remoteAddrStorage.ss_addr, &gCoapDestAddress, sizeof(ipAddr_t));   //COAP_SendMsg(pMySession,  pMySessionPayload, pMyPayloadSize); COAP_Send(pMySession, gCoapMsgTypeNonPost_c, pMySessionPayload, pMyPayloadSize);   shell_write("'NON' packet sent 'POST' with payload: ");   shell_writeN((char*) pMySessionPayload, pMyPayloadSize);   shell_write("\r\n"); }   There can be one COAP instance per UDP port, in case the application only uses one port, one instance will be enough. There can be multiple COAP sessions per instance, a COAP session is per packet/transaction. In this case as the desired result was to have a different response of the ACK, it will be necessary to create a new session with the new resource.   APP_CoapResource2Cb   static void APP_CoapResource2Cb ( coapSessionStatus_t sessionStatus, void *pData, coapSession_t *pSession, uint32_t dataLen ) {   if (gCoapNonConfirmable_c == pSession->msgType)   {       shell_write("'NON' packet received 'POST' with payload: ");        shell_writeN(pData, dataLen);       shell_write("\r\n");   }  }   5. After creating the callbacks, those must be registered in the CoAP callback array in the function APP_InitCoapDemo(void)     {APP_CoapResource1Cb, (coapUriPath_t*)&gAPP_RESOURCE1_URI_PATH}, {APP_CoapResource2Cb, (coapUriPath_t*)&gAPP_RESOURCE2_URI_PATH},   There are some things to mention of the usage of the CoAP library that were not used for this laboratory but might be useful for other types of applications. When using COAP_Send() the session will close automatically by default unless it is indicated with the usage of pSession->autoClose. There are two options while sending the message: Confirmable (CON): It waits for an ACK reply and until it gets the message it will close the session or it will close the session when retransmissions are exhausted. Non-confirmable (NON): For NON, immediately after sending the message. In case a message was sent and there was no response a retransmission will be sent each COAP_ACK_TIMEOUT (in miliseconds), the retransmissions are sent exponentially: first after random (2, 3) seconds, next doubles the timeout and so on, until COAP_MAX_RETRANSMIT is reached. After retransmissions stop, the session is automatically closed and informs the application of failure the application callback will be called with status gCoapFailure_c. When the callback is called the current session is still valid, but CoAP session will close it after exiting the function. There are two different work this out: A new session must be created Set pSession->autoClose = FALSE. If autoClose is set to FALSE, without forgetting to close the session from application, using COAP_CloseSession().     Running the demo      1. Download the modified firmware in the boards 2. Open a serial terminal for each board with a baud rate of 115200 Figure 3 Serial terminal and its configuration  3. In one of the board’s terminal type “thr create”, this board will be the leader. Figure 4 Board 1 with command "thr create" Figure 5 Board 1 after the command "thr create"   4. Once the network has been created type “thr join” in the second board’s terminal.   Figure 6 Board 2 with command "thr join" Figure 7 Board 2 after command "thr join" 5. In both serial terminals type the command “ifconfig”. This command will display all the addresses of the board.   Figure 8 Board 1 after command "ifconfig" Figure 9 Board 2 after command "ifconfig"   6. To test the callbacks created, a CoAP message must be sent. The following command must be typed;   coap <type> <method> <address> <URI> <payload>        coap CON POST fe80::5df0:2bf0:d69b:1b3c  /resource1 hello        Figure 10 CoAP command to send 7. The result of sending must look like :   — Board 1 The board 1 will request the board 2 the resource1 Figure 11 Board 1 before sending the CoAP command As it was coded the other board will send an ACK and print the message. Figure 12 Board 1 after sending the CoAP command — Board 2 Figure 13 Board 2 after receiving the CoAP command If using the CON message the requester board will receive a response, while if the message is a NON type it will not have the response.   When using this types of messages independently of the package type when sending a message a new session will be open and it will send a NON type of message.
View full article
The KW43 product family is a low-power, secure, single-chip wireless MCU that integrates a high performance, Bluetooth Low Energy, Bluetooth Channel Sounding, EdgeLock Secure Accelerators, and various MCU peripherals targeted for Automotive applications. The KW43 family utilizes an Arm® Cortex®-M33 core (Armv8-M architecture) running up to 96 MHz for customer applications. The family includes memory configurations of up to 1.5MB flash and 256 KB SRAM across all listed part numbers. All devices in the family integrate a state-of-the-art, scalable security architecture including Arm’s TrustZone®-M, a resource domain controller and an isolated EdgeLock Secure Accelerators supporting hardware cryptographic accelerators, random number generators and key generation, storage, and management along with secure debug. All members of the KW43 family are designed to be compliant to a SESIP Level 3 certification following the Arm PSA Level 3 profile. KW43 uses dual Arm Core Cortex-M33 (‘CM33’) and supports multiple interfaces and security features. One is for application and system use and other is for radio link layer and both cores share a common flash of 1.5 MB. The devices include a full certified Bluetooth LE 6.x controller stack with support for up to 10 simultaneous connections in any controller/peripheral combination. The multiprotocol radio subsystem integrated in the KW43 Family is energy efficient and is designed for Wi-Fi coexistence. The radio is supported with tested software stacks for Bluetooth Low Energy for standalone and hosted applications to enable a range of Automotive, IoT and industrial applications. There is also software and hardware support for 2.4 GHz proprietary protocols. To address ranging requirements, the Localization Engine (LCE) is integrated into the system for enhanced localization performance. The KW43 series is supported by the MCUXpresso Developer Experience to optimize, ease and help accelerate embedded system development. Early access program The KW43 is in pre-production, developers can get started today with the KW45/KW47, which is pin and software compatible.   you can request access contacting NXP sales team - Pascal Bernard ([email protected]) Join KW47 early access program here: KW43 Early Access Training Bluetooth Low energy 6.0 NXP Introduction Interested in Bluetooth technology? Bluetooth® Low Energy Primer – Essential reading for understanding BLE fundamentals. Bluetooth® Specifications – Full list of standards, protocols, and technical documents. Awards and Recognition - Every year, the Bluetooth Special Interest Group (SIG) celebrates the hard work and commitment of working groups, committee members, and contributors who have been recognized by their peers as making a difference in advancing Bluetooth technology.                2024: Channel Sounding              2025: Channel sounding amplitude-based attack resilience, LE test mode enhancements and Ranging profile and service.  Bluetooth AI Assistant - Amber Bluetooth Feature Overview Bluetooth_5.0_Feature_Overview  Bluetooth_5.1_Feature_Overview  Bluetooth_5.2_Feature_Overview Bluetooth_5.3_Feature_Overview Bluetooth_5.4_Feature_Overview Bluetooth_6_Feature_Overview Bluetooth_6.1_Feature_Overview Bluetooth_6.2_Feature_Overview Bluetooth_6.3_Feature_Overview Bluetooth Core Specification Core Specification 4.0 Core Specification 4.1 Bluetooth 4.1 FAQ Core Specification 4.2 Bluetooth 4.2 FAQ Core Specification 5.0 Core Specification 5.1 Core Specification 5.2 Core Specification 5.3 Core Specification 5.4 Core Specification 6.0 Core Specification 6.1 Core Specification 6.2 Core Specification 6.3 RF Switch Comparison Absorptive/Reflective Standards Comparison ETSI / FCC / ARIB requirements BLE Channel Sounding  - Overview BLE Channel Sounding - RF Hardware BLE Channel Sounding - ANSYS Modeling Tools  BLE Channel Sounding - Antenna Prototypes Validation Measurements Equipment Wireless Equipment: This article provides the links to the Equipment that helps to the project development  Useful Links How to import and run demo examples with MCUXpresso for Visual Studio Code: This article gives information on how to import and run demo examples from the new SDK with ARM GCC toolchain, in MCUXpresso for Visual Studio Code. [MCUXSDK] How to use GitHub SDK for KW4x, MCXW7x, MCXW2x - NXP Community this community post provides step by step how to use GitHub SDK [MCUXSDK] GitHub SDK - Documentation for Bluetooth LE platforms - NXP Community this community post provides the documentation for BLE platforms.  How to use the HCI_bb on Kinetis family products and get access to the DTM mode:  This article is presenting two parts: How to flash the HCI_bb binary into the Kinetis product. Perform RF measurement using the R&S CMW270 BLE HCI Application to set transmitter/receiver test commands: This article provides the steps to show how user could send serial commands to the device. Bluetooth LE HCI Black Box Quick Start Guide: This article describes a simple process for enabling the user controls the radio through serial commands.
View full article
KW45’s three-core architecture integrates a 96 MHz CM33 application core, dedicated CM3 radio core and an isolated EdgeLock Secure Enclave. The Flash-based radio core with dedicated SRAM delivers a highly configurable and upgradeable software-implemented radio, freeing resources on the main core for customer application space. The Bluetooth Low Energy 5.3-compliant radio supports up to 24 simultaneous secure connections. The EdgeLock Secure Enclave’s isolated execution environment provides a set of cryptographic accelerators, key store operations and secure lifecycle management that minimizes main core security responsibilities. The KW45 MCU additionally integrates FlexCAN, helping enable seamless integration into an automobile’s in-vehicle or industrial CAN communication network. The FlexCAN module can support CAN’s flexible data rate (CAN FD) for increased bandwidth and lower latency. KW45 Block Diagram KW45 Architecture Block Diagram Documents Reference Manual Datasheet Errata Secure Reference manual** Security Certifications  SESIP Level 2 Cert SESIP Level 2 ST PSA Level 2 Certification Regulatory Certifications RED Certification EUROPEAN UNION DECLARATION OF CONFORMITY (EVK) EUROPEAN UNION DECLARATION OF CONFORMITY (LOC) Japan MIC KW45-LOC _TELEC-20250221 Bluetooth Qualifications Qualified Products | Bluetooth® Technology Website Qualification Workspace - KW45/MCX W71 Bluetooth IInterested in Bluetooth technology? Bluetooth® Low Energy Primer – Essential reading for understanding BLE fundamentals. Bluetooth® Specifications – Full list of standards, protocols, and technical documents. Awards and Recognition - Every year, the Bluetooth Special Interest Group (SIG) celebrates the hard work and commitment of working groups, committee members, and contributors who have been recognized by their peers as making a difference in advancing Bluetooth technology, like NXP! 2024: Channel Sounding 2025: Channel sounding amplitude-based attack resilience, LE test mode enhancements and Ranging profile and service.  Bluetooth AI Assistant - Amber   Bluetooth Feature Overview Bluetooth_5.0_Feature_Overview  Bluetooth_5.1_Feature_Overview  Bluetooth_5.2_Feature_Overview Bluetooth_5.3_Feature_Overview Bluetooth_5.4_Feature_Overview Bluetooth_6_Feature_Overview Bluetooth_6.1_Feature_Overview Bluetooth_6.2_Feature_Overview Bluetooth_6.3_Feature_Overview Bluetooth Core Specification Core Specification 4.0 Core Specification 4.1 Bluetooth 4.1 FAQ Core Specification 4.2 Bluetooth 4.2 FAQ Core Specification 5.0 Core Specification 5.1 Core Specification 5.2 Core Specification 5.3 Core Specification 5.4 Core Specification 6.0 Core Specification 6.1 Core Specification 6.2 Core Specification 6.3   Evaluation boards KW45 KW45-EVK KW45-EVK Schematic KW45-EVK Design Files KW45-EVK User manual KW45-LOC User manual KW45-EVK Getting Started Application Notes Software, Hardware and Peripherals: AN14122 : How to use RTC on KW45 This application note describes how to configure and use the RTC peripheral in a BLE demo AN14141 : Enabling Watchdog Timer Module on KW45 Bluetooth Low Energy Connectivity Stack This application note describes the process to implement the WDOG timer in a Connectivity Stack demo. AN13855 : KW45/K32W1 Integrating the OTAP Client Service into a Bluetooth LE Peripheral Device This Application note provides the steps and process for integrating the Over the Air Programming Client Service into a BLE peripheral device. AN13584 : Kinetis KW45 and K32W1 Loadpull Report This application note describes measurement methodology and associated results on the load-pull characteristics. AN13860 : Creating Firmware Update Image for KW45/K32W1 using OTAP tool This application note provides the steps to create and upgrade the image on the KW45 board via OTAP. AN14077 : Steps to migrating KW45 (1MB) to KW45 (512kB) This application note describes the initial steps require to migrate from 1MB flash to 512kB flash. AN14746 : EEPROM Emulation for the KW45B41Z and K32W148 This document describes the process for the EEPROM emulation for the KW45B41Z and K32W148. AN14298 32kHz Cystal-Less Mode on KW45: This application note provides information on the 32 kHz Crystal-less mode on the KW45 device. This mode allows you to reduce the cost of the system, without compromising the 32 kHz clock accuracy.  AN13227 Hardware Design Considerations for KW45B41Z and K32W148 Bluetooth LE Devices: This application note describes printed-circuit board (PCB) design considerations for the KW45B41Z83AFTA, and KW45B41Z82AFTA and K32W1480VFTAT MKW35A, MKW36A, MKW35Z, and MKW36Z 40-pin HVQFN (6x6) and 48-pin Laminated QFN (HVLQFN-7x7 pitch 0.5 mm) wettable flank) package and KW45B41Z83AFPA and KW45B41Z82AFPA MKW35A, MKW36A, MKW35Z, and MKW36Z 40-pin HVQFN (6x6) and 40-pin Laminated QFN (HVLQFN-6x6 pitch 0.5 mm) wettable flank) package Power Management: AN13230: Kinetis KW45 and K32W1 Bluetooth LE Power Consumption Analysis This application note provides information about the power consumption of KW45 wireless MCUs, the hardware design and optimized for low power operation. AN13831: KW45/K32W1 Power Management Hardware This application note describes the usage of the different modules dedicated to power management in the KW45/K32W1 MCU. AN14664 Coin cell Hardware Recommendations for Kinetis Bluetooth LE Applications: This document describes some hardware and software solutions to minimize the peaks of current at the coin cell level RF: AN13687 : K32W1 Connectivity test for 802.15.4 Application This application note describes how to use the connectivity test tool to perform K32W1 802.15.4 RF performance. AN13728 : KW45 RF System Evaluation Report for Bluetooth LE and IEEE 802.15.4 Applications This application note provides the radio frequency evaluation test results of the KW45 board for BLE (2FSK modulation) and for IEEE 802.15.4 (OQPSK modulation) applications. Also describes the setup and tools that can be used to perform the tests.  AN14098: KW45-LOC RF Test Report This application note provides basic RF test result of the KW45B41Z localization board.  AN13228 : KW45-EVK RF System Evaluation Report for BLE Applications This application note provides the RF evaluation test result of the KW45B41Z-EVK for BLE application using two frequency Shift Keying modulation. AN13229 : KW45-EVK Co-existence with RF System Evaluation Report for BLE application This application note provides the RF evaluation test results of the KW45B41Z-EVK for BLE application (2FSK modulation) AN13512 : Kinetis Wireless Family Products BLE Coexistence with Wi-Fi Application This application note provides the K32W1/4X low energy family products immunity on Wi-Fi signals and methods to improve coexistence with Wi-Fi  AN14294 : Out of Band Implementation with KW45 This document explains the steps required to set up an Out of Band (OOB) pairing connection between two KW45 EVK boards, using UART and CAN communication interfaces to share OOB data. AN2731 Compact Planar Antennas for 2.5GHz Communication: This document is not an exhaustive inquiry into antenna design. It is instead focused on helping the customers understand enough board layout and antenna basics to select a correct antenna type for their application, as well as avoiding typical layout mistakes that cause performance issues that lead to delays AN14645 How to Use Random Static Device Address for Bluetooth Application: This document introduces how to enable Random Static Device Address for a Bluetooth Low Energy application. The default device address type in the SDK is Public Device Address. AN14112 Car Connectivity Consortium (CCC) Digital Key R3 - Bluetooth LE Vehicle Keyless Access System: This document provides a hardware and software platform to implement a simple CCC Digital Key Release 3.0 system. The hardware and software components of this system allow the user to get familiar with the CCC Digital Keys R3 specification and how it can be implemented using NXP products and tools. AN13953 Integrating NFC Reader Library in a KW4X Bluetooth Low Energy Application:  This document gives instructions on how to create a Bluetooth Low Energy (Bluetooth LE) project for the EVK-KW45 development board and MCUXpresso IDE, and how to integrate NFC Reader Library. AN13049 Wi-Fi/Bluetooth/802.15.4 M.2 Key E Pinout Definition: This document defines M.2 usage for both NXP Wi-Fi/Bluetooth and Tri-Radio M.2 module design Security: AN13859 : KW45/K32W1 In-System Programming Utility This application note provides steps to boot KW45/K32W1 MCU in ISP mode and establish various serial connections to communicate with the MCU. AN14003 : Programming the KW45 Flash for Application and Radio Firmware via Serial Wire Debug during mass production This application note describes the steps to write, burn and programming all the necessary settings via SWD in mass production.  AN13883 : Updating KW45 Radio Firmware Via ISP Using SPSDK This application note provides steps to boot KW45/K32W1 MCU in ISP mode and update the radio firmware with secure binary. AN14109 : KW45 and K32W148 Secure  Boot Using the SEC Tool This application note provides steps to do secure boot KW45/K32W1 MCU using signed images and secure binaries on the SEC GUI tool. AN13838 :  KW45 and K32W148 Secure  Boot Using the SPSDK Command line Tool This application note provides steps to do secure boot KW45/K32W1 MCU using signed images and secure binaries on the SPSDK command line tool. AN13931 : Managing Lifecycles on KW45 and K32W148 This application note provides steps to do transition lifecycles KW45/K32W1 MCU using the SEC GUI and SPSDK command line tools.  AN14158: Debug Authentication on KW45/ K32W148 This application note describes how to do debug authentication to securely debug an application in the field.  AN14544 : EdgeLock 2GO Services for MPU and MCU This application note introduces the EL2GO services for NXP devices. This allows trust provisioning of the device in an untrusted environment.  AN14174: KW45/K32W1 Flash Encryption using NPXThis application note provides steps to do enable on-the-fly encryption on KW45/K32W1 MCU. AN14158: debug authentication on KW45/K32W148 This application note describes the steps for debug authentication using the Secure Provisioning SDK tool (SPSDK). AN15038 EdgeLock 2GO Provisioning MCUs via Product Type using Secure Provisioning (SEC) Tool:  This document offers an outline of the EdgeLock 2GO platform and discusses the "Device provisioning via product type" flow. The document focuses on the initial device provisioning using secure objects from the EdgeLock 2GO cloud server. AN14670  EdgeLock 2GO Provisioning via SPSDK for MCUs: This document offers an outline of the EdgeLock 2GO platform and discusses the “Device provisioning via proxy” flow. The document focuses on the initial device provisioning using secure objects from the EdgeLock 2GO cloud server.  AN14624 EdgeLock 2GO Provisioning via Secure Provisioning Tool (SEC) for MCUs: This document offers an outline of the EdgeLock 2GO platform and discusses the "Device provisioning via proxy" flow. Useful Links   [MCUXSDK] How to use GitHub SDK for KW4x, MCXW7x, MCXW2x - NXP Community this community post provides step by step how to use GitHub SDK [MCUXSDK] GitHub SDK - Documentation for Bluetooth LE platforms - NXP Community this community post provides the documentation for BLE platforms.  Clock Measuring using the Signal Frequency Analyzer (SFA) module for KW45/KW47/MCXW71/MCXW72 - NXP Community : this community provides the steps on how to use the Signal Frequency Analyzer  The best way to build a PCB first time right with KW45 (Automotive) or K32W1/MCXW71 (IoT/Industrial)... Community : In this community provides the important link to build a PCB using a KW45 or K32W148 and MCXW71 and all concerning the radio performances, low power and radio certification (CE/FCC/ICC) How to use the HCI_bb on Kinetis family products and get access to the DTM mode:  This article is presenting two parts: How to flash the HCI_bb binary into the Kinetis product. Perform RF measurement using the R&S CMW270 BLE HCI Application to set transmitter/receiver test commands: This article provides the steps to show how user could send serial commands to the device. Bluetooth LE HCI Black Box Quick Start Guide : This article describes a simple process for enabling the user controls the radio through serial commands. Kinetis (../45/47/43;MCX W71/72/70) & MCX W23 Power Profile Tools (including Localization):  This page is dedicated to the Kinetis (KW35/KW38/KW45/KW47/KW43) and MCX W7x (MCX W71/W72/W70) Power Profile Tools. It will help you to estimate the power consumption in your application (Automotive or IIoT) and evaluate the battery lifetime of your solution. KW45/K32W1 32MHz & 32kHz Oscillation margins: this article provides the properly configuration for the Oscillation margins for the circuit. KW45/MCXW71 Changing Clocking peripherals from FRO6M to other clock sources:  This article provides a comprehensive guide to selecting and configuring alternative clock sources   Reference Designs Bluetooth Ranging Access Vehicle Enablement System - NXP Community Blue Ravens (Bluetooth Ranging Access Vehicle Enablement System) is a system solution developed by NXP to assist customers in designing their own BLE-based car access solutions using NXP products.   Demo (video) KW45 Based CS 1 to Many Demo NXP - Channel Sounding   Training BLE Introduction  RF Switch Comparison Absorptive/Reflective Standards Comparison ETSI / FCC / ARIB requirements BLE Channel Sounding  - Overview BLE Channel Sounding - RF Hardware BLE Channel Sounding - ANSYS Modeling Tools  BLE Channel Sounding - Antenna Prototypes Validation Measurements     Equipment Wireless Equipment: This article provides the links to the Equipment that helps to the project development  Development Tools  SDK builder: The MCUXpresso SDK brings open-source drivers, middleware, and reference example application to speed your software development. SDK GitHub: SDK open-source Drivers, middleware and reference examples in Github NXP MCUXpresso: MCUXpresso IDE offers advanced editing, compiling and debugging features with the addition of MCU-Specific debugging. Supports connections with all general-purpose Arm Cortex-M.  NXP SPSDK: Is a unified, reliable, and easy to use Python SDK library working across the NXP MCU portfolio providing a strong foundation from quick customer prototyping up to production deployment. NXP SEC Tool: The MCUXpresso Secure Provisioning Tool us a GUI-based application provided to simplify generation and provisioning of bootable executables on NCP MCU devices. NXP OTAP Tool: Is an application that helps the user to perform an over the air firmware update of an NXP development board. Config Tool: MCUXpresso Config Tools, an integrated suite of configuration tools, these configuration tools allow developers to quickly build a custom SDK and leverage pins, clocks and peripheral to generate initialization C code or register values for custom board support. SDK Examples for Wireless MCUs: The wireless examples feature many common Bluetooth configurations. **For secure files is necessary to request additional access.
View full article
The MCX W23 is a family of devices. All devices are Arm Cortex®-M33 based wireless microcontrollers for embedded applications supporting Bluetooth Low Energy 5.3. It can be used to develop IoT solutions. MCX W23xA supports LV_SM mode. MCX W23xB supports HV_SM and XR_SM mode. Building on NXP's strong history of providing industrial edge solutions, the MCX W series offers a wide operating temperature range from -40 °C to 125 °C. The Arm Cortex-M33 provides a security foundation, offering isolation to protect valuable IP and data with Trust Zone technology. It simplifies the design and software development of digital signal control systems with the integrated digital signal processing (DSP) instructions. To support security requirements, the MCX W23 also offers support for SHA-1, SHA2-256, AES, RSA, ECC, UUID, dynamic encryption, and decryption of the flash data using a PRINCE engine, debug authentication, and TBSA-M compliance.   Documents Reference Manual Fact sheet Data Sheet Errata for MCX W23xUIK MCX W23 Hardware Design Guide Secure Reference manual** European Union Declaration of Conformity for FRDM-MCXW23 FRDM-MCXW23 Board User Manual Bluetooth Specifications The MCX W23 is compatible with the Bluetooth Low Energy 5.3 specification: – Bluetooth Low Energy 5.3 controller subsystem (QDID 200592) – Bluetooth Low Energy 5.3 host subsystem (QDID 226395) – Includes a 48-bit unique Bluetooth device address – Up to 4 simultaneous connections supported The MCX W23 supports the following Bluetooth Low Energy features: – Device privacy and network privacy modes (version 5.0) – Advertising extension PDUs (version 5.0) – Anonymous device address type (version 5.0) – Up to 2 Mbps data rate (version 5.0) – Long range (version 5.0) – High-duty cycle, Non connectable advertising (version 5.0) – Channel selection algorithm #2 (version 5.0) – High output power (version 5.0) – Advertising channel index (version 5.1) – Periodic advertising sync transfer (PAST) (version 5.1) – Supports LE power control feature (version 5.2) RF antenna: 50 Ω single-ended RF receiver characteristics: – Sensitivity −94 dBm in Bluetooth Low Energy 2 Mbps – Sensitivity −97 dBm in Bluetooth Low Energy 1 Mbps – Sensitivity −100 dBm in Bluetooth Low Energy 500 kbps – Sensitivity −102 dBm in Bluetooth Low Energy 125 kbps – Accurate RSSI measurement with ±3 dB accuracy Flexible RF transmitter level configurability: – TX mode 1 (TXM1): Range from −31 dBm to +2 dBm when VDD_RF exceeds 1.1 V – TX mode 2 (TXM2): Range from −28 dBm to +6 dBm when VDD_RF exceeds 1.7   Bluetooth_5.0_Feature_Overview Bluetooth_5.1_Feature_Overview  Bluetooth_5.2_Feature_Overview Bluetooth_5.3_Feature_Overview   Training MCX W Series Training - NXP Community   Equipment Wireless Equipment: This article provides the links to the Equipment that helps to the project development    Application Notes Power Management: AN14660: Power Management for MCX W23: This App Note provides information about the power manager software component. The application uses this component and the operating system to achieve optimal low-power states, based on the requirements of the application. RF: AN14575: MCX W23 Health Care IoT Peripheral Software Architecture: This App Note provides an overview of the software architecture for the MCX W23 Health care IoT Peripheral application. Designed as a model implementation, this application showcases the key features of the MCX W23 platform and serves as a foundation for developing product-quality applications. AN14659: MCX W23 Bluetooth Low Energy Power Consumption Analysis: This App Note describes the power consumption of the MCX W23 Bluetooth Low Energy (LE) device and the procedure to measure the current consumption using the MCXW23_EVK_BB and MCXW236B_RDM boards. AN2731: Compact Planar Antennas for 2.4 GHz Communication: This App Note is not an exhaustive inquiry into antenna design. It is instead focused on helping the customers understand enough board layout and antenna basics to select a correct antenna type for their application, as well as avoiding typical layout mistakes that cause performance issues that lead to delays Security: AN14657: Getting Started with Secure Boot on MCX W23: This application note covers the design of the bootloader ROM code that NXP has developed on the MCX W23, and how to use all its features. Useful Links Bluetooth LE FSCI Host Application running on FRDM-MCXN947 and MCXW23B-Click Board: The Bluetooth LE FSCI Host application demonstrates a host-side implementation for the Health Thermometer use case. It is designed to work alongside the FSCI Blackbox application, which runs on platforms such as the MCXW236 Click Board, FRDM-MCXW236, or other compatible Bluetooth LE wireless MCUs. Transmitter Maximum Output Power Override Application Note   Kinetis (../45/47/43;MCX W71/72/70) & MCX W23 Power Profile Tools (including Localization):  This page is dedicated to the Kinetis (KW35/KW38/KW45/KW47/KW43) and MCX W7x (MCX W71/W72/W70) Power Profile Tools. It will help you to estimate the power consumption in your application (Automotive or IIoT) and evaluate the battery lifetime of your solution. Development Tools    VSCode: MCUXpresso for Visual Studio Code (VS Code) provides an optimized embedded developer experience for code editing and development. Zephyr RTOs  NXP Application Code Hub: Application Code Hub (ACH) repository enables engineers to easily find microcontroller software examples, code snippets, application software packs and demos developed by our in-house experts. This space provides a quick, easy and consistent way to find microcontroller applications. NXP SPSDK: Is a unified, reliable, and easy to use Python SDK library working across the NXP MCU portfolio providing a strong foundation from quick customer prototyping up to production deployment. NXP SEC Tool: The MCUXpresso Secure Provisioning Tool us a GUI-based application provided to simplify generation and provisioning of bootable executables on NCP MCU devices. NXP OTAP Tool: Is an application that helps the user to perform an over the air firmware update of an NXP development board.
View full article
Please, find the important link to build a PCB using a KW4x or MCX W7x and all concerning the radio performances, low power and radio certification (CE/FCC/IC).   “As RF behavior are dependent of PCB layout & manufacturing; PCB prototypes (based on NXP recommendations) will have to be fine-tuned to insure the expected qualified in RF is reached on the final productized platform.” KW47 product NXP web page:  https://www.nxp.com/products/KW47 MCXW72 product NXP web page: https://www.nxp.com/products/MCX-W72 Board pages:  KW47-EVK Evaluation Kit with Bluetooth® Low Energy 6.0 KW47-LOC Localization Reference Design using KW47 MCXW72-LOC Localization Board for MCX W72 Bluetooth Channel Sounding MCU FRDM-MCXW72 Development Board for MCX W72 Wireless MCU   in addition of the product webpages please refer to KW47 Knowledge Hub   Do not use pre-production or production board prior to April 2026 KW47-LOC or MCXW72-LOC platform for Channel Sounding certification - contact NXP for further note NXP Channel Sounding PAGE        (Bluetooth ®  SiG Channel Sounding Technical Overview ) More Channel Sounding enablement Available on request to NXP  Channel Sounding Fundamentals for the KW47 and MCX W72[AN14865] Fundamental Steps to Design a Channel Sounding Board - Creating a Simple PCB without Diversity[AN14832] Fundamental Steps to Design a Complex Channel Sounding Board[AN14869]        Printed Channel Sounding Antennas for the KW47 and MCX W72[AN14779] HARDWARE KW47-MCXW72-EVK HW guideline: KW47 Hardware Design Guide[UG10127] MCX W72 Hardware Design Guide[UG10273] HVQFN48 package specification: SOT619-17(D)   pending release of SOT619-17(DD)   KW47-MCXW72-EVK User Manual  KW47-LOC Board User Manual[UM12114] KW47-EVK Board User Manual[UM12094] MCXW72-LOC Board User Manual[UM12113] FRDM-MCXW72 User Manual[UM12222] Minimum BoM (attached file)  DCDC management guide (AN13831) :  Power Management Hardware (nxp.com) - KW45 applicable for KW47 waiting release of KW47/MCXW72  Design-In check list: see attached file at the bottom of this article RF matching: S parameters (attached file) Available on request    How to handle coincell application on PCB:  Coin Cell Hardware Recommendations for Kinetis Bluetooth LE Applications[AN14664] KW47-MCXW72 module can also be handled in standalone:  How to run KW47-M2 standalone RF output power level: Please note it is expected that each final PCB platform, is refine with the right RF matching and filtering, to fit your market and region mandatory certification. For instance the +10dBm at pin level can be exceeded in some configuration. It is final PCB owner responsibility to build a system (incl. all Rf path loss) with the expected target power level fitting with Bluetooth SiG Core spec and European radio certification target. Then the Tx power has to be adjusted at application level.   UFL SMA CABLE: On EVK, to connect M10 module for RF trials a µFL to SMA cable is recommended:  CSH-SGFB-200-UFFR TE Connectivity / Linx Technologies | Mouser France On KW47-LOC or MCXW72-LOC to connect SMA specific connector has to be populated: TE Connectivity Ltd CONSMA021.062-G. Warning to solder SMA connector:  please insure the PCB edge is well cut and right smooth; if not please mill a bit with a sand paper. (risk is to get SMA core line not well soldered on PCB line) Also for higher Harmonics the µFL is not convenient as connector is limited above 6GHz (an SMA has to be soldered to control RF losses ) RF matching component tolerance: Please note, on NXP EVK, FRDM and LOCalization platform the RF matching components (Inductors, Capacitors) are using the HIGH tolerance Muratasets. During your RF board tuning you may need to use low tolerance Murata set to insure all RF limits are passing. Eg: GJM1555C1H3R3CB01D is +/-0.25pF tolerance where GJM1555C1H3R3BB01 with +/-0.1pF tolerance may be preferred Eg2: LQG15HS1N3S02D  is +/-0.3nH tolerance where LQG15HS1N3B02D   with +/-0.1nH tolerance may be preferred KW47 from KW45 hardware porting :  KW47 is pin to pin compatible with KW45. However from HW point of view, some components values will have to be adjusted like RF matching components values. Other components around KW4x are not foreseen as to change based on current silicon validation.  Please also note some new muxing is in place to get new features of KW47 on pins. For instance on KW47 a second Flex CAN is available. See attached file RADIO RF report:         AN14461: KW47-EVK RF System Evaluation Report for Bluetooth Low Energy Applications | NXP Semiconductors KW47-LOC RF System Evaluation Report for Bluetooth Low Energy Applications        AN14580: MCX W72 RF System Evaluation Report for Bluetooth and IEEE.802.15.4 Applications | NXP Semiconductors   Radio co-existence:  Kinetis Wireless Family Products Bluetooth Low Energy Coexistence with Wi-Fi Application (nxp.com) pending release of KW47/MCXW72  Antenna:  Compact Planar Antennas for 2.4 GHz Communication Designs and Applications within NXP EVK Boards Printed Channel Sounding Antennas for the KW47 and MCX W72[AN14779] Return loss (S11) measurement: How to measure the return loss of your RF matching (S11) part of the RF report (AN13728) Loadpull: Loadpull Test Report for KW47[AN14696] SW tools for RF trials:     IoT Tool box (mobile application)     Connectivity test tool for connectivity products (part of the IoT toolbox)     DTM: How to use the HCI_bb on Kinetis family products a... - NXP Community https://community.nxp.com/t5/Wireless-Connectivity-Knowledge/BLE-HCI-Application-to-set-transmitter-...   CRYSTAL   Recommended Crystal attached   Articles: KW47/MCX W72 32MHz & 32kHz Oscillation margins - NXP Community  32 kHz Crystal-less Mode on KW47[AN14884]   Please note for Channel Sounding feature with higher 10dBm transmit output, some specific care have to be taken adding to pass all harmonics on all Bluetooth Channels: see "32 MHz crystal harmonics design recommendations" chapter in "AN14826: KW47-LOC RF System Evaluation Report" where an extra inline inductor on Xtal path may be needed. LowPower      All power profiling tools are available in this NXP community web page:              KW35, KW38, KW45, KW47 & MCX W71, MCX W72 & MCX W23 Power Profile Tools (including Localization)        Bluetooth LE power profile estimator Tool               KW45_WK47_MCXW71_MCXW72_BLE_power_profile_calculator vx.x.xls              AN14554 Kinetis KW47 & MCX W72 Bluetooth LE Power profile analysis release.pdf      802.15.4 Matter & Zigbee power profile estimator Tool               MCX W7x 802.15.4 Matter ICD SIT LIT & ZED Power profile vx.x.xls               AN MCX W72 802.15.4 Matter and Zigbee Power profile analysis.pdf      CCC Channel Sounding BLE power profile estimator Tool               KW47 Digital Key CCC CS Power Estimator tool vx.x.xls               AN14628_AN14628_KW47_CCC_CS_Power_Profile_estimator tool_release.pdf   CERTIFICATION RF full certification of KW47/MCXW72  available on board product pages KW47 and MCXW72 are Bluetooth 6.x channel Sounding certified!
View full article
The clock tolerance for CAN FD at high baud rates is generally considered to be tight compared to lower baud rates, meaning that the clock frequency needs to be very precise to ensure reliable communication; this is due to the high data rate requiring precise bit timing. CAN generally requires crystal or PLL clock source due to accuracy requirements, on KW45/7 that is limited to 32 MHz crystal (SOSC) since there is no PLL available. However, the FRO192 (FIRC) can be fine trimmed to the SOSC crystal as reference, in a closed loop configuration. When operating in closed loop the FRO192 accuracy is +/-0.25%. The FRO192 when operating in open loop (default) will not be accurate enough for CAN-FD (+/-3%). Closed loop operation is enabled while SCG0→FIRCCSR[FIRCTRUP] = 1 and SCG0→FIRCCSR[FIRCTREN] =1. The auto trim continues as long as those bits are set (for example if change in temperature causes the FRO192clock frequency to drift). Once locked, only the fine trim bits would be updated on subsequent corrections. Refer to code snippet below for correct clock configuration: #include "clock_config.h" #include "fsl_clock.h" const scg_sosc_config_t g_scgSysOscConfig_BOARD_BootClockRUN = { .freq = 32000000U, /* System Oscillator frequency: 32000000Hz */ .monitorMode = kSCG_SysOscMonitorDisable, /* System OSC Clock Monitor is disabled */ .enableMode = kSCG_SoscEnable, /* System OSC Enable */ }; const scg_sys_clk_config_t g_sysClkConfig_BOARD_BootClockRUN = { .divSlow = (uint32_t)kSCG_SysClkDivBy4, /* Slow Clock Divider: divided by 4 */ .divBus = (uint32_t)kSCG_SysClkDivBy1, /* Bus Clock Divider: divided by 1 */ .divCore = (uint32_t)kSCG_SysClkDivBy1, /* Core Clock Divider: divided by 1 */ .src=(uint32_t)kSCG_SysClkSrcFirc, /* Fast IRC is selected as System Clock Source */ }; static const scg_firc_trim_config_t FircTrimConfig_BOARD_BootClockRUN = { .trimMode = kSCG_FircTrimUpdate, /* FIRC trim is enabled and trim value update is enabled */ .trimsrc=kSCG_FircTrimSrcSysOsc, /* Trim source is System OSC */ .trimDiv = 31U, /* Divided by 32 */ .trimCoar = 0U, /* Trim value, see Reference Manual for more information */ .trimFine = 0U, /* Trim value, see Reference Manual for more information */ }; const scg_firc_config_t g_scgFircConfig_BOARD_BootClockRUN = { .enableMode = kSCG_FircEnable, /* Fast IRC is enabled */ .range = kSCG_FircRange96M, /* 96 Mhz FIRC clock selected */ .trimConfig = &FircTrimConfig_BOARD_BootClockRUN, }; /* Unlock FIRC and SOSC control status registers */ CLOCK_UnlockFircControlStatusReg(); CLOCK_UnlockSysOscControlStatusReg(); /* Init FIRC */ CLOCK_CONFIG_FircSafeConfig(&g_scgFircConfig_BOARD_BootClockRUN); /* Set SCG to FIRC mode */ CLOCK_SetRunModeSysClkConfig(&g_sysClkConfig_BOARD_BootClockRUN); /* Wait for clock source switch finished */ do { CLOCK_GetCurSysClkConfig(&curConfig); } while (curConfig.src != g_sysClkConfig_BOARD_BootClockRUN.src); /* Initializes SOSC according to board configuration */ (void)CLOCK_InitSysOsc(&g_scgSysOscConfig_BOARD_BootClockRUN); /* Set the XTAL0 frequency based on board settings */ CLOCK_SetXtal0Freq(g_scgSysOscConfig_BOARD_BootClockRUN.freq); /* For 6 mbps baud rate requires FRO192M as FlexCAN source clock */ CLOCK_SetIpSrc(kCLOCK_Can0, kCLOCK_IpSrcFro192M); CLOCK_SetIpSrcDiv(kCLOCK_Can0, kSCG_SysClkDivBy1); The maximum supported baud rate for KW47 and MCXW72 devices is 6 Mbps. Although higher rates may be achievable on some SoCs, 6 Mbps is the highest baud rate supported by the device clock specifications.  For simplicity, the FlexCAN driver APIs can be used to configure the CAN FD baud rate, as shown in the following code snippet: #include "fsl_flexcan.h" #define EXAMPLE_CAN CAN0 #define USE_CANFD (1) #define RX_MESSAGE_BUFFER_NUM (0) #define TX_MESSAGE_BUFFER_NUM (1) #define BYTES_IN_MB kFLEXCAN_64BperMB /* For 6 Mbps use case. FRO192 must be selected as clock source */ #define EXAMPLE_CAN_CLK_FREQ CLOCK_GetFreq(kCLOCK_ScgFircClk) #define USE_IMPROVED_TIMING_CONFIG (1) flexcan_config_t flexcanConfig; /* Get FlexCAN module default Configuration. */ /* * flexcanConfig.clksrc=kFLEXCAN_ClkSrc0; * flexcanConfig.bitRate = 1000000U; * flexcanConfig.bitRateFD = 2000000U; * flexcanConfig.maxMbNum = 16; * flexcanConfig.enableLoopBack = false; * flexcanConfig.enableSelfWakeup = false; * flexcanConfig.enableIndividMask = false; * flexcanConfig.disableSelfReception = false; * flexcanConfig.enableListenOnlyMode = false; * flexcanConfig.enableDoze = false; */ FLEXCAN_GetDefaultConfig(&flexcanConfig); /* Manually override default CAN FD config to 1 Mbps for nominal rate and 6 Mbps for data rate */ flexcanConfig.bitRate = 1000000U; flexcanConfig.bitRateFD = 6000000U; #if (defined(USE_IMPROVED_TIMING_CONFIG) && USE_IMPROVED_TIMING_CONFIG) flexcan_timing_config_t timing_config; memset(&timing_config, 0, sizeof(flexcan_timing_config_t)); if (FLEXCAN_FDCalculateImprovedTimingValues(EXAMPLE_CAN, flexcanConfig.bitRate, flexcanConfig.bitRateFD, EXAMPLE_CAN_CLK_FREQ, &timing_config)) { /* Update the improved timing configuration*/ memcpy(&(flexcanConfig.timingConfig), &timing_config, sizeof(flexcan_timing_config_t)); } #endif FLEXCAN_FDInit(EXAMPLE_CAN, &flexcanConfig, EXAMPLE_CAN_CLK_FREQ, BYTES_IN_MB, true); Note: The maximum supported CAN baud rate for KW47 and MCXW72 devices is 2 Mbps. While higher rates may be achievable under certain conditions, operation above 2 Mbps is outside the supported specification and is not recommended for applications in the field.
View full article
In default, IMX95-19x19 EVK board enables the PCIe M.2 interface for Wi-Fi modules. But for SDIO interface M.2 Wi-Fi module, we could not use it directly. This doc is a step by step guide about how to make IW612 SDIO M.2 module(Murata 2EL) working on IMX95-19x19 EVK board based on Android 16. 1.Download I.MX Android BSP package, copy with scp to VMSIS. 16.0.0_1.4.0_ANDROID_SOURCE 2.Decompressing android bsp tar -xzf imx-android-16.0.0_1.4.0.tar.gz 3. source ./imx_android_setup.sh to download Android source code. 4.Prepare cross compiler GCC cross compiler: Download the tool chain for the AArch32 and AArch64 on: Arm GNU Toolchain I download the latest version: Arm GNU Toolchain 15.3.rel1 Need to pay attention, for I.MX95, need both 64 bit and 32 bit GCC compile tool. 64bit: arm-gnu-toolchain-15.3.rel1-x86_64-aarch64-none-linux-gnu.tar.xz 32 bit: arm-gnu-toolchain-15.3.rel1-x86_64-arm-none-eabi.tar.xz For AArch64 toolchain nxf93258@lsv051430:~/GCC_cross_compile_toolchain$sudo tar -xvJf arm-gnu-toolchain-15.3.rel1-x86_64-aarch64-none-linux-gnu.tar.xz -C /opt/ nxf93258@lsv051430:~/Android/imx-android-16.0.0_1.4.0/android_build$export AARCH64_GCC_CROSS_COMPILE=/opt/arm-gnu-toolchain-15.3.rel1-x86_64-aarch64-none-linux-gnu/bin/aarch64-none-linux-gnu- For 32bit toolchain: nxf93258@lsv051430:~/GCC_cross_compile_toolchain$sudo tar -xvJf arm-gnu-toolchain-15.3.rel1-x86_64-arm-none-eabi.tar.xz -C /opt/ nxf93258@lsv051430:~/Android/imx-android-16.0.0_1.4.0/android_build$ export AARCH32_GCC_CROSS_COMPILE=/opt/arm-gnu-toolchain-15.3.rel1-x86_64-arm-none-eabi/bin/arm-none-eabi- 5.Set the external clang, kernel-build-tools, rust, and clang-tools tools for kernel building: nxf93258@lsv051430:~/Android/imx-android-16.0.0_1.4.0/android_build$ sudo ./device/nxp/common/tools/setup_android_kernel_prebuilts.sh 6.Set up the environment for building. This only configures the current terminal, if change to another terminal need to re-run the configurations. nxf93258@lsv051430:~/Android/imx-android-16.0.0_1.4.0/android_build$ source build/envsetup.sh 7.Execute the Android lunch command for i.MX95-EVK. nxf93258@lsv051430:~/Android/imx-android-16.0.0_1.4.0/android_build$lunch evk_95-nxp_stable-userdebug 8.Optional Steps: Execute the imx-make.sh script to finish the whole images compiling. Or you can follow below steps to only build required images. nxf93258@lsv051430:~/Android/imx-android-16.0.0_1.4.0/android_build$ ./imx-make.sh -j4 2>&1 | tee build-log.txt 9.Modify the device tree to disable pcie0 and enable usdhc3 like below: ~/Android/imx-android-16.0.0_1.4.0/android_build/vendor/nxp-opensource/kernel_imx/arch/arm64/boot/dts/freescale$ git diff diff --git a/arch/arm64/boot/dts/freescale/imx95-19x19-evk.dts b/arch/arm64/boot/dts/freescale/imx95-19x19-evk.dts index 69508a66f1c8..dfa1d3d51a9c 100644 --- a/arch/arm64/boot/dts/freescale/imx95-19x19-evk.dts +++ b/arch/arm64/boot/dts/freescale/imx95-19x19-evk.dts @@ -26,10 +26,19 @@ / { aliases { mmc0 = &usdhc1; mmc1 = &usdhc2; + mmc2 = &usdhc3; serial0 = &lpuart1; ethernet0 = &enetc_port0; ethernet1 = &enetc_port2; }; + + usdhc3_pwrseq: usdhc3_pwrseq { + compatible = "mmc-pwrseq-simple"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usdhc3_pwrseq>; + post-power-on-delay-ms = <100>; + }; + bt_sco_codec: audio-codec-bt-sco { #sound-dai-cells = <1>; @@ -651,7 +660,7 @@ &pcie0 { reset-gpio = <&i2c7_pcal6524 5 GPIO_ACTIVE_LOW>; vpcie-supply = <&reg_pcie0>; supports-clkreq; - status = "okay"; + status = "disable"; }; &pcie1 { @@ -733,6 +742,22 @@ &usdhc2 { status = "okay"; }; +&usdhc3 { + pinctrl-names = "default", "state_100mhz", "state_200mhz", "sleep"; + pinctrl-0 = <&pinctrl_usdhc3>; + pinctrl-1 = <&pinctrl_usdhc3_100mhz>; + pinctrl-2 = <&pinctrl_usdhc3_200mhz>; + pinctrl-3 = <&pinctrl_usdhc3>; + mmc-pwrseq = <&usdhc3_pwrseq>; + vmmc-supply = <&reg_pcie0>; //Both PCIE0 and USDHC3 use same power supply. + bus-width = <4>; + keep-power-in-suspend; + non-removable; + wakeup-source; + status = "okay"; +}; + + &enetc_port0 { pinctrl-names = "default"; pinctrl-0 = <&pinctrl_enetc0>; @@ -1225,6 +1250,45 @@ IMX95_PAD_SD2_DATA3__USDHC2_DATA3 0x138e IMX95_PAD_SD2_VSELECT__USDHC2_VSELECT 0x51e >; }; + + pinctrl_usdhc3_pwrseq: usdhc3pwrseq { + fsl,pins = < + IMX95_PAD_XSPI1_SCLK__GPIO5_IO_BIT9 0x31e + >; + }; + + pinctrl_usdhc3: usdhc3grp { + fsl,pins = < + IMX95_PAD_SD3_CLK__USDHC3_CLK 0x158e + IMX95_PAD_SD3_CMD__USDHC3_CMD 0x138e + IMX95_PAD_SD3_DATA0__USDHC3_DATA0 0x138e + IMX95_PAD_SD3_DATA1__USDHC3_DATA1 0x138e + IMX95_PAD_SD3_DATA2__USDHC3_DATA2 0x138e + IMX95_PAD_SD3_DATA3__USDHC3_DATA3 0x138e + >; + }; + + pinctrl_usdhc3_100mhz: usdhc3-100mhzgrp { + fsl,pins = < + IMX95_PAD_SD3_CLK__USDHC3_CLK 0x158e + IMX95_PAD_SD3_CMD__USDHC3_CMD 0x138e + IMX95_PAD_SD3_DATA0__USDHC3_DATA0 0x138e + IMX95_PAD_SD3_DATA1__USDHC3_DATA1 0x138e + IMX95_PAD_SD3_DATA2__USDHC3_DATA2 0x138e + IMX95_PAD_SD3_DATA3__USDHC3_DATA3 0x138e + >; + }; + + pinctrl_usdhc3_200mhz: usdhc3-200mhzgrp { + fsl,pins = < + IMX95_PAD_SD3_CLK__USDHC3_CLK 0x15fe + IMX95_PAD_SD3_CMD__USDHC3_CMD 0x13fe + IMX95_PAD_SD3_DATA0__USDHC3_DATA0 0x13fe + IMX95_PAD_SD3_DATA1__USDHC3_DATA1 0x13fe + IMX95_PAD_SD3_DATA2__USDHC3_DATA2 0x13fe + IMX95_PAD_SD3_DATA3__USDHC3_DATA3 0x13fe + >; + }; }; &thermal_zones { 10.Build dtbo image. Need about 40 minutes. DTBO image holds the device tree binary of the board. nxf93258@lsv051430:~/Android/imx-android-16.0.0_1.4.0/android_build$ source build/envsetup.sh nxf93258@lsv051430:~/Android/imx-android-16.0.0_1.4.0/android_build$ lunch evk_95-nxp_stable-userdebug nxf93258@lsv051430:~/Android/imx-android-16.0.0_1.4.0/android_build$./imx-make.sh dtboimage -j4 Then you will see that the dtbo images time stamp are updated as below: Below info is for your reference. ~/Android/imx-android-16.0.0_1.4.0/android_build/device/nxp/common/build/dtbo.mk This makefile includes the logic how to pack dtbo image. ~/Android/imx-android-16.0.0_1.4.0/android_build/device/nxp/imx9/evk_95/SharedBoardConfig.mk  This Macro: SUPPORT_GBL is not enabled in default, so still use dtbo image for the device tree. ~/Android/imx-android-16.0.0_1.4.0/android_build/device/nxp/imx9/evk_95/BoardConfig.mk  Wi-Fi/Bluetooth FW located here:  Wi-Fi/Bluetooth driver located here: Can modify the Makefile accordingly if needed. After compiled, the Wi-Fi driver and cfg80211.ko is located here: 11.Download prebuilt Image and decompress it. 16.0.0_1.4.0_DEMO_95//Pay attention to the version, need to match with our Android Source code download version. 12.Replace dtbo image. Rename the original dtbo-imx95.img to dtbo-imx95_original.img in the prebuilt image directory to be a backup. Then copy the dtbo-imx95.img from the remote android source code compiled directory: ~/Android/imx-android-16.0.0_1.4.0/android_build/out/target/product/evk_95/dtbo-imx95.img to the prebuilt image directory. Like below:   13.Flash images into board. Change the I.MX95-19*19-EVK board's SW7 to 1001 (from 1-4 bit) to enter serial download mode, then connect the board's USB1 port with type C cable to Windows PC. Download the UUU binary file from GitHub: Releases · nxp-imx/mfgtools Open the cmd interface in administrator mode, and enter to the prebuilt image directory. Flash the images into I.MX95-19*19-EVK board with below command: uuu_imx_android_flash.bat -f imx95 -a -e -u trusty-dual For the details of each parameter, can refer to: Android Quick Start Guide 14.Verify Wi-Fi and Bluetooth functions. After flash finished successfully, power off the board and change the board's SW7 to switch the board back to 1010 (form 1-4 bit) to enter eMMC boot mode. Check dmesg logs to confirm IW612 Wi-Fi driver is loaded successfully:   Check Wi-fi and Bluetooth work as expected in UI.  Can use this application: scrcpy on windows instead of connecting a LCD. This guide can also be a reference for other M.2 Wi-Fi modules with SDIO interface working on I.MX95 19*19-EVK board with Android or Linux OS. Reference: Android Quick Start Guide Android User's Guide Linux-Kernel Archive: [PATCH V3 2/3] arm64: dts: imx95-15x15-evk: Disable PCIe bus in the default dts   Finished by Christine.Li. Aug 5 2026.
View full article
This doc is a brief step by step introduction for how to play music through A2DP on IW612 + I.MX8MPlus-EVK based on L6.6.52. Step 1: Load WiFi/Bluetooth Driver • NXP i.MX Release Distro 6.6-scarthgap imx8mpevk ttymxc1 imx8mpevk login: root root@imx8mpevk:~# modprobe moal mod_para=nxp/wifi_mod_para.conf root@imx8mpevk:~# root@imx8mpevk:~# dmesg | grep wlan [ 562.728200] wlan: Loading MWLAN driver [ 562.728788] wlan: Register to Bus Driver... [ 562.730460] wlan: Enable TX SG mode [ 562.730464] wlan: Enable RX SG mode [ 563.554778] wlan: uap%d set max_mtu 2000 [ 563.622367] wlan: version = SDIW612---18.99.3.p21.10-MM6X18505.p4-GPL-(FP92) [ 563.625611] wlan: Register to Bus Driver Done [ 563.625622] wlan: Driver loaded successfully root@imx8mpevk:~#modprobe btnxpuart root@imx8mpevk:~# hciconfig -a hci0: Type: Primary Bus: UART BD Address: D0:17:69:EE:71:4F ACL MTU: 1021:7 SCO MTU: 120:6 DOWN RX bytes:774 acl:0 sco:0 events:48 errors:0 TX bytes:496 acl:0 sco:0 commands:47 errors:0 Features: 0xbf 0xfe 0x8f 0xfe 0xdb 0xff 0x7b 0x87 Packet type: DM1 DM3 DM5 DH1 DH3 DH5 HV1 HV2 HV3 Link policy: RSWITCH SNIFF Link mode: PERIPHERAL ACCEPT • Step 2: Up BT interface and enable the power save feature root@imx8mpevk:~# hciconfig hci0 up root@imx8mpevk:~# hciconfig hci0 piscan root@imx8mpevk:~#hciconfig hci0 noencrypt root@imx8mpevk:~# hciconfig -a hci0: Type: Primary Bus: UART BD Address: D0:17:69:EE:71:4F ACL MTU: 1021:7 SCO MTU: 120:6 UP RUNNINGPSCAN ISCAN RX bytes:1900 acl:0 sco:0 events:109 errors:0 TX bytes:1365 acl:0 sco:0 commands:108 errors:0 Features: 0xbf 0xfe 0x8f 0xfe 0xdb 0xff 0x7b 0x87 Packet type: DM1 DM3 DM5 DH1 DH3 DH5 HV1 HV2 HV3 Link policy: RSWITCH SNIFF Link mode: PERIPHERAL ACCEPT Name: 'imx8mpevk' Class: 0x200000 Service Classes: Audio Device Class: Miscellaneous, CI Version: 5.4 (0xd) Revision: 0x8300 LMP Version: 5.4 (0xd) Subversion: 0x1015 Manufacturer: NXP Semiconductors (formerly Philips Semiconductors) (37) • Step 3: Scan, Pair and Connect to Headset root@imx8mpevk:~# bluetoothctl hci0 new_settings: powered connectable discoverable bondable ssp br/edr le secure-conn cis-central cis-peripheral Agent registered [CHG] Controller D0:17:69:EE:71:4F Pairable: yes [bluetooth]# power on Changing power on succeeded [bluetooth]# default-agent Default agent request successful [bluetooth]# agent on Agent is already registered [bluetooth]# scan on [NEW] Device B1:96:11:68:9C:09 联想thinkplus-HE05X II代 [bluetooth]# scan off [bluetooth]# pair B1:96:11:68:9C:09 Attempting to pair with B1:96:11:68:9C:09 hci0 device_flags_changed: B1:96:11:68:9C:09 (BR/EDR) supp: 0x00000000 curr: 0x00000000 [DEL] Device 67:02:B9:7C:ED:B5 67-02-B9-7C-ED-B5 [DEL] Device 80:F4:16:4C:48:F2 HI-Apiyoo-12MIQ001981 hci0 B1:96:11:68:9C:09 type BR/EDR connected eir_len 34 [CHG] Device B1:96:11:68:9C:09 Connected: yes hci0 new_link_key B1:96:11:68:9C:09 type 0x04 pin_len 0 store_hint 1 [CHG] Device B1:96:11:68:9C:09 Bonded: yes [DEL] Device 6A:98:7A:08:0F:B8 6A-98-7A-08-0F-B8 [CHG] Device B1:96:11:68:9C:09 ServicesResolved: yes [CHG] Device B1:96:11:68:9C:09 Paired: yes Pairing successful5X II代]# [DEL] Device 6C:59:25:E5:66:77 6C-59-25-E5-66-77 [DEL] Device 61:CC:7D:CE:20:4E 61-CC-7D-CE-20-4E [DEL] Device 64:C1:4B:76:C1:80 64-C1-4B-76-C1-80 [DEL] Device 72:50:16:14:52:A6 72-50-16-14-52-A6 hci0 B1:96:11:68:9C:09 type BR/EDR disconnected with reason 2 [CHG] Device B1:96:11:68:9C:09 ServicesResolved: no [CHG] Device B1:96:11:68:9C:09 Connected: no [bluetooth]#trust B1:96:11:68:9C:09 [CHG] Device B1:96:11:68:9C:09 Trusted: yes Changing B1:96:11:68:9C:09 trust succeeded [bluetooth]#connect B1:96:11:68:9C:09 Attempting to connect to B1:96:11:68:9C:09 hci0 B1:96:11:68:9C:09 type BR/EDR connected eir_len 34 [CHG] Device B1:96:11:68:9C:09 Connected: yes [NEW] Endpoint /org/bluez/hci0/dev_B1_96_11_68_9C_09/sep1 [NEW] Endpoint /org/bluez/hci0/dev_B1_96_11_68_9C_09/sep2 [NEW] Transport /org/bluez/hci0/dev_B1_96_11_68_9C_09/sep1/fd0 [CHG] Transport /org/bluez/hci0/dev_B1_96_11_68_9C_09/sep1/fd0 Delay: 0x05dc (1500) Connection successfulII代]# [CHG] Device B1:96:11:68:9C:09 ServicesResolved: yes [联想thinkplus-HE05X II代]#quit • Step 4: Start pipewire and wireplumber Service then list and choose default Audio Source/Sink Card root@imx8mpevk:~#systemctl --user start pipewire wireplumber root@imx8mpevk:~#wpctl status PipeWire 'pipewire-0' [1.0.5, root@imx8mpevk, cookie:831282980] Clients: 32. WirePlumber [1.0.5, root@imx8mpevk, pid:1528] 40. WirePlumber [export] [1.0.5, root@imx8mpevk, pid:1528] 87. wpctl [1.0.5, root@imx8mpevk, pid:1552] Audio -Devices: 41. Built-in Audio [alsa] 42. Built-in Audio [alsa] 43. Built-in Audio [alsa] 44. Built-in Audio [alsa] 45. Built-in Audio [alsa] 81. 联想thinkplus-HE05X II代 [bluez5] -Sinks: 47. Built-in Audio Mono [vol: 0.40] 48. Built-in Audio Stereo [vol: 0.40] 50. Built-in Audio Stereo [vol: 0.40] 58. Built-in Audio Digital Stereo (IEC958) [vol: 0.40] * 82. 联想thinkplus-HE05X II代 [vol: 0.40] -Sources: 46. Built-in Audio Mono [vol: 1.00] 49. Built-in Audio Stereo [vol: 1.00] 51. Built-in Audio Stereo [vol: 1.00] * 59. Built-in Audio Digital Stereo (IEC958) [vol: 1.00] -Filters: -Streams: Video -Devices: 52. mxc-isi-m2m_v1 [v4l2] 53. vsi_v4l2enc [v4l2] 54. vsi_v4l2dec [v4l2] Streams: Settings Default Configured Devices: root@imx8mpevk:~#wpctl set-default 82 root@imx8mpevk:~#wpctl set-default 59 root@imx8mpevk:~# wpctl status PipeWire 'pipewire-0' [1.0.5, root@imx8mpevk, cookie:831282980] Clients: 32. WirePlumber [1.0.5, root@imx8mpevk, pid:1528] 40. WirePlumber [export] [1.0.5, root@imx8mpevk, pid:1528] 87. wpctl [1.0.5, root@imx8mpevk, pid:1572] Audio 41. Built-in Audio [alsa] 42. Built-in Audio [alsa] 43. Built-in Audio [alsa] 44. Built-in Audio [alsa] 45. Built-in Audio [alsa] 81. 联想thinkplus-HE05X II代 [bluez5] 47. Built-in Audio Mono [vol: 0.40] 48. Built-in Audio Stereo [vol: 0.40] 50. Built-in Audio Stereo [vol: 0.40] 58. Built-in Audio Digital Stereo (IEC958) [vol: 0.40] * 82. 联想thinkplus-HE05X II代 [vol: 0.40] 46. Built-in Audio Mono [vol: 1.00] 49. Built-in Audio Stereo [vol: 1.00] 51. Built-in Audio Stereo [vol: 1.00] * 59. Built-in Audio Digital Stereo (IEC958) [vol: 1.00] 分区Bluetooth 的第4 页 * 59. Built-in Audio Digital Stereo (IEC958) [vol: 1.00] Streams: Video 52. mxc-isi-m2m_v1 [v4l2] 53. vsi_v4l2enc [v4l2] 54. vsi_v4l2dec [v4l2] Streams: Settings Default Configured Devices: 0. Audio/Sink bluez_output.B1_96_11_68_9C_09.1 1. Audio/Source alsa_input.platform-sound-xcvr.iec958-stereo Step 5: Copy、Play and Enjoy Music Drag the music file yesterday-once-more.wavto I.MX8MP-EVK board by connecting Windows PC and I.MX8MP-EVK board into one local area network. root@imx8mpevk:~# pw-play -v ./yesterday-once-more.wav sndfile: opened file "yesterday-once-more.wav" format 00010002 channels:2 rate:44100 sndfile: using default channel map: FL,FR PCM: fmt:s16 rate:44100 channels:2 width:2 rate:44100 latency:4410 (0.100s) connecting playback stream; target=(null) stream state changed unconnected -> connecting stream param change: Spa:Enum:ParamId:Latency stream param change: Spa:Enum:ParamId:Tag stream param change: Spa:Enum:ParamId:Props stream properties: application.name = "pw-play" node.name = "pw-play" media.software = "Lavf58.29.100" media.format = "WAV (Microsoft)" node.rate = "1/44100" node.latency = "4410/44100" media.type = "Audio" media.category = "Playback" media.role media.filename = "yesterday-once-more.wav" media.name = "yesterday-once-more.wav" stream.is-live = "true" node.want-driver = "true" node.autoconnect = "true" media.class = "Stream/Output/Audio" remote 0 is named "pipewire-0" stream state changed connecting -> paused stream param change: Spa:Enum:ParamId:Props stream param change: Spa:Enum:ParamId:Latency stream param change: Spa:Enum:ParamId:Latency stream param change: Spa:Enum:ParamId:Format stream state changed paused -> streaming stream set volume to 1.000 -success stream node 88 stream time: now:0 rate:1/48000 ticks:0 delay:9248 queued:0 buffered:0 buffers:0 avail:2 size:0 stream time: now:4821374572568 rate:1/48000 ticks:49152 delay:9248 queued:1882 buffered:32 buffers:1 avail:1 size:1882 stream time: now:4822355905886 rate:1/48000 ticks:96256 delay:9248 queued:1882 buffered:32 buffers:1 avail:1 size:1882 stream time: now:4823379905870 rate:1/48000 ticks:145408 delay:9248 queued:1881 buffered:32 buffers:1 avail:1 size:1881 Finished By Christine.Li Jul 22th,2026.
View full article
This article discusses the different use cases and configuration of the errata "ERR053404: FlexCAN: Message Buffer (MB) and Enhanced RX FIFO Filter Element (ERFFEL) Memory Corruption". The errata is impacting Messabe Buffers (MB) and Enhanced RX FIFO Filter Elements (ERFFEL), the impact of each MB or ERFFEL depends on the configuration of the payload buffer, MB and/or ERFFEL. In this post, we plan to provide some examples of such configuration and impact on the FlexCAN IP.  Taking a 64-byte payload as an example, the following configurations illustrate the trade-off between the number of Message Buffers (MBs) and acceptance filters: /* ERR053404: This errata explains affected words depends on MB payload size, this example applies for MB configured for 64-byte payload */ #define BYTES_IN_MB kFLEXCAN_64BperMB FLEXCAN_FDInit(EXAMPLE_CAN, &flexcanConfig, EXAMPLE_CAN_CLK_FREQ, BYTES_IN_MB, true); 1. MB0 is not used, MB1 is used. In this configuration, ERFFEL[0–29] can be fully utilized as acceptance filters, while MB1–MB6 are available as Message Buffers, maximum ERFCR[NFE] is 14. The following code can be used as reference for the driver configuration for this case.  /* Config fifo filters to make it accept STD frame with ID 0x123 ~ 0x140. Used ERFFEL[0–29], ERFCR[NFE]=14 */ uint32_t rxEnFifoFilter[] = {FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x123, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x124, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x125, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x126, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x127, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x128, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x129, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x12A, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x12B, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x12C, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x12D, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x12E, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x12F, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x130, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x131, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x132, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x133, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x134, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x135, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x136, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x137, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x138, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x139, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x13A, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x13B, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x13C, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x13D, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x13E, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x13F, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x140, 0, 0x3F, 0)}; flexcan_enhanced_rx_fifo_config_t rxEhFifoConfig; flexcan_rx_mb_config_t mbConfig; /* Setup Enhanced Rx FIFO. */ rxEhFifoConfig.idFilterTable = rxEnFifoFilter; rxEhFifoConfig.idFilterPairNum = sizeof(rxEnFifoFilter) / sizeof(rxEnFifoFilter[0]) / 2U; rxEhFifoConfig.extendIdFilterNum = 0; rxEhFifoConfig.fifoWatermark = RX_MESSAGE_COUNT - 1U; /* Reduce the frequency to enter IRQ. */ rxEhFifoConfig.dmaPerReadLength = kFLEXCAN_19WordPerRead; rxEhFifoConfig.priority = kFLEXCAN_RxFifoPrioHigh; FLEXCAN_SetEnhancedRxFifoConfig(EXAMPLE_CAN, &rxEhFifoConfig, true); rxFifoXfer.framefd = &rxFrame[0]; rxFifoXfer.frameNum = RX_MESSAGE_COUNT; /* Set Rx Masking mechanism for MB. Only accept data frame with desired ID. */ FLEXCAN_SetRxMbGlobalMask(EXAMPLE_CAN, FLEXCAN_RX_MB_STD_MASK(0x7FFU, 0, 0)); #define RX_MESSAGE_BUFFER_1 (1U) /* Setup Rx Message Buffer 1. */ mbConfig.format = kFLEXCAN_FrameFormatStandard; mbConfig.type = kFLEXCAN_FrameTypeData; mbConfig.id = FLEXCAN_ID_STD(0x121U); FLEXCAN_SetFDRxMbConfig(EXAMPLE_CAN, RX_MESSAGE_BUFFER_1, &mbConfig, true); 2. MB0 and MB1 are not used. In this case, ERFFEL[0–31] are available for acceptance filtering, and MB2–MB6 are reserved as Message Buffers, maximum ERFCR[NFE] is 15. The following code can be used as reference for the driver configuration for this case.  /* Config fifo filters to make it accept STD frame with ID 0x123 ~ 0x142. Used ERFFEL[0–31], ERFCR[NFE]=15 */ uint32_t rxEnFifoFilter[] = {FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x123, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x124, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x125, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x126, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x127, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x128, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x129, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x12A, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x12B, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x12C, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x12D, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x12E, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x12F, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x130, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x131, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x132, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x133, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x134, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x135, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x136, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x137, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x138, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x139, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x13A, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x13B, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x13C, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x13D, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x13E, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x13F, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x140, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x141, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x142, 0, 0x3F, 0)}; flexcan_enhanced_rx_fifo_config_t rxEhFifoConfig; /* Setup Enhanced Rx FIFO. */ rxEhFifoConfig.idFilterTable = rxEnFifoFilter; rxEhFifoConfig.idFilterPairNum = sizeof(rxEnFifoFilter) / sizeof(rxEnFifoFilter[0]) / 2U; rxEhFifoConfig.extendIdFilterNum = 0; rxEhFifoConfig.fifoWatermark = RX_MESSAGE_COUNT - 1U; /* Reduce the frequency to enter IRQ. */ rxEhFifoConfig.dmaPerReadLength = kFLEXCAN_19WordPerRead; rxEhFifoConfig.priority = kFLEXCAN_RxFifoPrioHigh; FLEXCAN_SetEnhancedRxFifoConfig(EXAMPLE_CAN, &rxEhFifoConfig, true); rxFifoXfer.framefd = &rxFrame[0]; rxFifoXfer.frameNum = RX_MESSAGE_COUNT; 3. MB0 and MB1 are both used. Under this configuration, only ERFFEL[0–11] can be used as acceptance filters. ERFFEL[12–31] are not available, while MB0–MB6 can be used as Message Buffers, maximum ERFCR[NFE] is 5. The following code can be used as reference for the driver configuration for this case.  /* Config fifo filters to make it accept STD frame with ID 0x123 ~ 0x12E. Used ERFFEL[0–11], ERFCR[NFE]=5 */ uint32_t rxEnFifoFilter[] = {FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x123, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x124, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x125, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x126, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x127, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x128, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x129, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x12A, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x12B, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x12C, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x12D, 0, 0x3F, 0), FLEXCAN_ENHANCED_RX_FIFO_STD_MASK_AND_FILTER(0x12E, 0, 0x3F, 0)}; flexcan_enhanced_rx_fifo_config_t rxEhFifoConfig; flexcan_rx_mb_config_t mbConfig; /* Setup Enhanced Rx FIFO. */ rxEhFifoConfig.idFilterTable = rxEnFifoFilter; rxEhFifoConfig.idFilterPairNum = sizeof(rxEnFifoFilter) / sizeof(rxEnFifoFilter[0]) / 2U; rxEhFifoConfig.extendIdFilterNum = 0; rxEhFifoConfig.fifoWatermark = RX_MESSAGE_COUNT - 1U; /* Reduce the frequency to enter IRQ. */ rxEhFifoConfig.dmaPerReadLength = kFLEXCAN_19WordPerRead; rxEhFifoConfig.priority = kFLEXCAN_RxFifoPrioHigh; FLEXCAN_SetEnhancedRxFifoConfig(EXAMPLE_CAN, &rxEhFifoConfig, true); rxFifoXfer.framefd = &rxFrame[0]; rxFifoXfer.frameNum = RX_MESSAGE_COUNT; /* Set Rx Masking mechanism for MB. Only accept data frame with desired ID. */ FLEXCAN_SetRxMbGlobalMask(EXAMPLE_CAN, FLEXCAN_RX_MB_STD_MASK(0x7FFU, 0, 0)); #define RX_MESSAGE_BUFFER_0 (0U) /* Setup Rx Message Buffer 0. */ mbConfig.format = kFLEXCAN_FrameFormatStandard; mbConfig.type = kFLEXCAN_FrameTypeData; mbConfig.id = FLEXCAN_ID_STD(0x120U); FLEXCAN_SetFDRxMbConfig(EXAMPLE_CAN, RX_MESSAGE_BUFFER_0, &mbConfig, true); #define RX_MESSAGE_BUFFER_1 (1U) /* Setup Rx Message Buffer 1. */ mbConfig.format = kFLEXCAN_FrameFormatStandard; mbConfig.type = kFLEXCAN_FrameTypeData; mbConfig.id = FLEXCAN_ID_STD(0x121U); FLEXCAN_SetFDRxMbConfig(EXAMPLE_CAN, RX_MESSAGE_BUFFER_1, &mbConfig, true); Recommendation: To achieve a balanced trade-off between the number of Message Buffers and acceptance filters, Option 1 is recommended.
View full article
This post provides guidance on how to update the NBU firmware on MCX W72 and KW47 devices through several methods: Bootloader Host Application (blhost), Secure Provisioning Tool, LinkServer. The Narrow Band Unit (NBU) is a dedicated compute subsystem for the Narrowband Radio, present in select NXP wireless microcontrollers. It is comprised of an Arm® Cortex®-M33 and associated peripherals that, in conjunction with the Bluetooth Unit, support the Bluetooth LE protocol. Running at 96 MHz alongside a 2.4 GHz transceiver, the NBU operates independently from the main application core, offloading all radio processing from the primary CPU and freeing it for application tasks. While the NBU allows for flexibility for evolving requirements, firmware to implement radio protocols is intended to be developed and delivered by NXP. Note: It is important that the NBU firmware version matches the SDK version of the application. After downloading the SDK and before running any wireless examples, update the NBU firmware using the binaries provided in the SDK folder. The NBU binary file is located in the SDK folder. Go to the SDK root folder and open the path: path_to_SDK\mcuxsdk\middleware\wireless\ble_controller\bin   Prerequisites To follow this guide, the following environment is required: Software Setup Bootloader Host Application (blhost). Download here. MCUXpresso Secure Provisioning Tool. Download here. LinkServer for Microcontrollers. Download here. Hardware Setup Development boards associated with the MCX W72 or KW47 microcontroller families may be used. The ISP button varies by board and is referred to as ISP_button  throughout this guide: Development board ISP_button FRDM-MCXW72 SW3 MCXW72-LOC SW4 KW47-EVK SW4 KW47-LOC SW4   To set the board to the Bootloader ISP mode, press and hold the ISP_button , connect the development board via the MCU-Link connector to the PC, then release ISP_button .   Bootloader Host Application (blhost) Place the board in ISP mode by pressing and holding ISP_button . Connect the USB cable to the MCU-Link connector and release ISP_button after the connection is established. Verify the COM port assigned to the board by opening Device Manager in Windows and searching for Ports (COM & LPT). Identify and note the corresponding COM port number. Open a command prompt and change the directory to the location of the blhost.exe file: (BLHost_root_location)\blhost_2.6.7\bin\win Verify communication by running the following command, making sure to replace COMX with the COM port assigned to your device: blhost.exe -p COMX get-property 1 Update the NBU firmware image. First, erase the NBU memory: blhost.exe -p COMX flash-erase-all 2 Write the new firmware image using the following command. The write-memory command uses 0x48800000 as the start address, which corresponds to the NBU memory base. Provide the full path to the binary file, or alternatively, copy the .bin file into the same directory as blhost.exe to simplify the command: blhost.exe -p COMX write-memory 0x48800000 <nbu_binary>.bin   MCUXpresso Secure Provisioning Tool Create a workspace for the device. To use the keys same as the development board, select the processor relevant to the FRDM/EVK board. Place the board in ISP mode by pressing and holding ISP_button . Connect the USB cable to the MCU-Link connector and release ISP_button after the connection is established. To verify communication, click the UART tab, refresh the Port field selection and select the assigned COM Port identified. Click Test connection and confirm that the result displays OK. In the toolbar, select the boot type as Plain unsigned or Plain with CRC. In the Build Image view, load the binary file in Source executable image, enter the start address as  0x48800000  (which corresponds to the NBU memory base), and click Build image. Navigate to the Write Image view, select Use built image, and click Write image. A success message appears when the NBU firmware loading is complete.   LinkFlash Tool For this method, a LinkServer debug probe must be available on the board. The steps on how to install the CMSIS-DAP/SEGGER J-link firmware are available here. Navigate to the main LinkServer folder in your computer and execute the  LinkFlash.exe  file. Place the board in ISP mode by pressing and holding ISP_button . Connect the USB cable to the MCU-Link connector and release ISP_button after the connection is established. In the LinkFlash tool, after the device is connected, click the Refresh button to update and set the probe target of the board. Go to the Program tab, click Browse, select the NBU firmware file, and enter the start address  0x48800000 . Ensure to check the boxes Mass erase before programming and Reset target after programming. To load the NBU firmware, click Program.
View full article
This document takes i.MXRT 1060 evkc and iw610 M.2 module as example to share how to setup manufactory mode in i.MXRT platform for NXP wifi product.  Hardware Host platform: i.MXRT 1060 evkc Wi-Fi chip: iw610 M.2 evk Software RT1060EVKC SDK 25.12.00 MFG TOOL: MFG-SD-IW610-MF-LABTOOL-Native-BRG-WIN-X86-2.0.0.39.0-18.80.5.p77
View full article
When performing Bluetooth LE RF testing on KW47 and MCXW72 devices, it may be necessary to configure the transmitter output power through a vendor-specific HCI command. NXP's Test Tool provides a convenient way to send HCI commands during Direct Test Mode (DTM) validation and characterization. Although the Test Tool is still commonly referenced in documentation and application workflows, it is no longer actively maintained. As a result, the default HCI command XML definitions included with the tool do not correctly support the vendor-specific Tx power command required by KW47 and MCXW72 devices. The default Test Tool XML does not correctly define the vendor-specific HCI_VENDOR_CONFIG_TX_POWER command for KW47 and MCXW72 devices. As a result, the command is not available in the GUI. Edit BLE HCI 5.0 1.6.1.xml (typically located in C:\nxp\Test Tool 12.9.2.2\Xml) and replace the command definition with the XML snippet provided in this article. Alternatively, replace the original XML file with the updated file attached to this article. <Vendor_Commands> <GroupDesc>Vendor_Commands</GroupDesc> <Cmd> <CmdName>HCI_VENDOR_CONFIG_TX_POWER</CmdName> <CmdDesc>HCI_VENDOR_CONFIG_TX_POWER Desc. OgB: FD OcB: 2D </CmdDesc> <CmdSync>01</CmdSync> <CmdHeader>3F 012D</CmdHeader> <CmdParms> <Parm> <ParmName>tx_power</ParmName> <ParmDesc>tx_power Desc</ParmDesc> <ParmSize>1</ParmSize> <ParmType>tInt</ParmType> <ParmLastValue>00</ParmLastValue> <ParmDefaultValue>00</ParmDefaultValue> </Parm> <Parm> <ParmName>Channel</ParmName> <ParmDesc>type Desc</ParmDesc> <ParmSize>1</ParmSize> <ParmType>tInt</ParmType> <ParmLastValue>00</ParmLastValue> <ParmDefaultValue>00</ParmDefaultValue> </Parm> <Parm> <ParmName>NotUsed</ParmName> <ParmDesc>Not Used</ParmDesc> <ParmSize>2</ParmSize> <ParmType>tInt</ParmType> <ParmLastValue>00</ParmLastValue> <ParmDefaultValue>00</ParmDefaultValue> </Parm> </CmdParms> </Cmd> </Vendor_Commands>​ After updating the XML file and restarting Test Tool, HCI_VENDOR_CONFIG_TX_POWER should appear in the GUI. HCI_VENDOR_CONFIG_TX_POWER command parameters: tx_power[1]: Supported values are 0x00 (0 dBm), 0x07 (7 dBm), and 0x0A (10 dBm). Channel[1]: Supported values are 0x00 (applies to advertising channels) and 0x01 (applies to non-advertising channels). NotUsed[2]: Reserved parameter. Always set this field to 0x0000.
View full article
To generate a hello world (suppose) example for KW47-EVK for IAR toolchain. We asume that IAR toolchain is already installed. Set IAR_DIR environment variable. In Windows, this can be done via Edit environment variables system option. Example: IAR_DIR=C:\iar\ewarm-9.60.1.    Note: IAR toolchain version may change. Type the following commands on your MCUXSDK workspace: cd mcuxsdk west build -b kw47evk ./examples/demos_apps/hello_world --toolchain=iar -t standalone_project -Dcore_id=cm33_core0 --pristine -d ./build/kw47evk/kw47evk_standalone_hello_world_iar​ IAR project should have been generated on  MCUXSDK_WS/mcuxsdk/build/kw47evk/kw47evk_standalone_hello_world_iar/iar directory. IAR project has .eww file extension.     Relevant links IDE Project Generation: https://mcuxpresso.nxp.com/mcuxsdk/latest/html/develop/build_system/IDE_Project.html# Note: Ruby is required for this feature. Typically, this tool is installed via MCUXpresso Installer. However, if having issues with this tool refer to the next link: Ruby Environment Setup: https://mcuxpresso.nxp.com/mcuxsdk/latest/html/develop/build_system/IDE_Project.html#ruby-environment-setup Suppose you want to generate a hello world example for KW47-EVK for IAR toolchain as the previous example, but this time LPTMR driver is required for low-power timer operating purposes. We asume that IAR toolchain is already installed and IAR_DIR variable is already set. The easiest way to accomplish this is to add the lptmr Kconfig symbols with ‘yes’ value at Board-Application level (Refer to Kconfig User Guide). In this case, the target prj.conf file is located on  MCUXSDK_WS/mcuxsdk/examples/_boards/kw47evk/demo_apps/hello_world.​ Edit this file and add the LPTMR required symbols:  CONFIG_MCUX_COMPONENT_driver.lptmr=y CONFIG_MCUX_COMPONENT_component.lptmr_adapter=y​       Type the following command on your MCUXSDK workspace:  west build -b kw47evk ./examples/demo_apps/hello_world --toolchain=iar -t standalone_project -Dcore_id=cm33_core0 --pristine -d ./build/kw47evk/kw47evk_standalone_hello_world_iar IAR project should have been generated on MCUXSDK_WS/mcuxsdk/build/kw47evk/kw47evk_standalone_hello_world_iar/iar directory. IAR project has .eww file extension. This time LPTMR drivers should be included in iar/drivers/lptmr
View full article
