i.MX RT1176 program to SD/EMMC and debugging
1,515 次查看
JayCao
Hello all,
I am working on a project using SD/EMMC to store Firmware instead of Flash memory.
I have some questions as below:
1. Is there any guide to do that on RT1176?
I followed the guide below but did not work on our EVKs.
https://community.nxp.com/t5/i-MX-RT-Knowledge-Base/RT1050-SDRAM-app-code-boot-from-SDcard-burn-with...
2. Do we need to load any bootloader first and then follow the guide in 1st question for it to work?
3. How to debugger the firmware ?
Hope to hear from you soon.
Best regard,
Tu
标记 (4)
1,446 次查看
Gavin_Jia
1,447 次查看
Gavin_Jia
Please refer to our previous post for the solution: https://community.nxp.com/t5/i-MX-RT/LED-cannot-blinking-when-loading-firmware-via-SDcard/td-p/18345...
Wish you have a nice day!
