Silicon Revision on iMX8QXP Dev Kit
2,859 次查看
rlumo
I would like to know what is the Silicon Revision on my iMX8QXP Dev Kit.
I have the following stickers on the back of my dev kit:
S/N VV 19420385
SCH-29683 REV C2
700-29683 REV C2
TDA 7239
2,807 次查看
AldoG
You may try 2 ways to identify the silicon revision for the chip:
  • Use "misc_get_control" with "SC_R_SYSTEM" and "SC_C_ID" to get the REV info.
  • Check the last letter of the part number, which indicates the silicon reversion.
In your case it may be easier to identify using the second method, simx8qx6avlf1bb -> B0 chip
Hope this helps,
Aldo.
2,779 次查看
darsh_dev
2,807 次查看
rlumo
Also these are the markings on the chip.
simx8qx6avlf1bb
sbae 1928
1N95W
korea mbaesbc
